der_c Posted January 15, 2021 Posted January 15, 2021 Hi friends, i'm new here, i found an old Orange Pi PC (V1.2) in my treasure-box and try to find a bootable image in the Orange Pi sources. But any image i tried was faulty, one time the system is starting, but not booting completely ore i have a red LED (don't boot). I tried it with a 8GB und a 32GB card. Pls, can you tell me, where i can download a running image and do you know, if a 32GB-Card ist ok? I write the img with "BelanaEtcher" on the SD-Card, same as i write it on a SD-Card für a Rasp-Pi. Thank you for any helpful answer. Stefan
der_c Posted January 20, 2021 Author Posted January 20, 2021 Thank's for the link, this link i know. I tried all available images from there, but no image is running. I tried it with different sd-cards, different manufactures and different sizes, no success.
guidol Posted January 20, 2021 Posted January 20, 2021 11 minutes ago, der_c said: Thank's for the link, this link i know. I tried all available images from there, but no image is running. I tried it with different sd-cards, different manufactures and different sizes, no success. the images are normally OK. Do you got error messages on the images which doesnt boot complete? Or do you got a TTL-serial-dongle to give us the output then your OPi PC v1.2 is trying to boot from a card? 32GB cards should also be OK, because armbian will resize the filesystem and the 4xt filesystem can handle 32GB without problems. Are you sure you have a OPi PC (H3 CPU) and not a Opi PC2 (H5 CPU)? PC: http://www.orangepi.org/orangepipc/ PC2: http://www.orangepi.org/orangepipc2/
der_c Posted January 21, 2021 Author Posted January 21, 2021 (edited) Hi, last question first, yes i#m absolutly shure that i have an oPi-PC, the difference between the boards is significant. Depend on the image what i use, i see a red LED (don't boot) ore i have a green LED and i see a short boot with feedback on the monitor, but it will not boot complete. An Armbian image will not start. I don't have a TTL-serial-dongle, the effort is too great for me. If it is not work, the oPi will go into trash. Edited January 21, 2021 by der_c
Igor Posted January 22, 2021 Posted January 22, 2021 35 minutes ago, der_c said: last question first, yes i#m absolutly shure that i have an oPi-PC, the difference between the boards is significant. Depend on the image what i use, i see a red LED (don't boot) ore i have a green LED and i see a short boot with feedback on the monitor, but it will not boot complete. An Armbian image will not start. Just in case try one version back, older from archive.
