Hi all. In this video I show how to install Open Media Vault on your SBC with Armbian Buster.
I've used the Odroid HC4, this is the same for any board you'd like to use.
Here my video.
Greetings.
NicoD
10 minutes ago, ElizabethSasha said:
I have tried all steps in this videos but nothing help.
Due to the insane amount of detail you gave with your error description it will take quite a while to sort things out.
Similar issue here. Armbian-config actually didn't install openmediavault, it just configured apt so that openmediavault can be installed.
Therefore, after armbian-config was finished with configuration, i'd to drop back to shell and install OMV with
apt install openmediavault
vor 21 Stunden schrieb horvat.kamca:
Or you use the OMV install script at https://github.com/OpenMediaVault-Plugin-Developers/installScript installing OMV5 on Buster or OMV6 on Bullseye.
I could be wrong, but I would suspect that the armbian-config script should actually install it.  But maybe it's broken?
So, if anyone does figure it out, please do submit a patch!
