Efforts to improve video performance on meson64 based TV boxes
It is now 2 weeks I run linux-image-current-meson64 with no problems.
I manage to get rid of tearing while playing video with vlc by using wayland/weston instead of X11/openbox (picom did not help).
While playing video cpu goes from around 40% in X11 to 20% with weston \o/.
You can find vlcd.service, scripts and config files in attached files.
TODO list :
  - Move vlcd.service to weston.service and try to replace vlc-xxxx.sh scripts with ~/.config/systemd/vlcd.service
  - format /boot in ext4
vlcd.service vlcd-start.sh vlcd-stop.sh weston.ini vlcrc.wl
Link to post
Share on other sites
Donate and support the project!
ok it is not perfect with vlc : if video is not the size of screen the video is cropped and moved up...
with mpv it is perfect : you can ssh to your machine, sudo su - vlcd, export XDG_RUNTIME_DIR=/run/user/109 and launch mpv
mpv.conf
or aliases :
function play_movie {
  sudo su -P -s /bin/bash -c "export XDG_RUNTIME_DIR=/run/user/109 && mpv --sub-auto=all --sub-file-paths=Subs $1" vlcd
function play_serie {
  sudo su -P -s /bin/bash -c "export XDG_RUNTIME_DIR=/run/user/109 && mpv --sub-auto=exact $1" vlcd
Link to post
This thread originally started under a topic about upgrading the kernel from a balbes image kernel to an armbian standard meson64 kernel.  The goal of @lgranie in that topic was to be able to access more current kernels to take advantage of improvements. The balbes images stopped supporting amlogic devices on 2020-10-14 at kernel version 5.9.0 and he was looking for an upgrade path.
Link to post
Hi everyone,
I made some new tests this last weekend and realized what I said was not really true.
If you want to use hardware accelerated decoding you need to install armbian-firmware-all (package I just discovered). This package contains the firmware files needed by mpv in /lib/firmware/meson/vdec. Combined with mpv options hwdec-codecs=all and hwdec=auto ( or just v4l2m2m-copy ), cpu usage really drops from 50% to 20% ( and cpu temp from 70c to just over 50c ). But it is a little bugged : no seek forward or backward, and I've got a crach after one hour of movie (just when the bus fly the highway gap in "Speed", damned!).
I imagine that the improvements of video playback quality ( no more little tearing ) I experimented last week was due to weston using GL for render what I was not able to do with X11/picom before.
You do not really need hardware decoding : the  s905x2 is really capable to decode x264 without any problems.
Here the commented containt of my mpv.conf file :
# very usefull to understand what mpv is doing
msg-level=all=v
# video output ( wayland )
vo=gpu
gpu-context=wayland
drm-connector=HDMI-A-1
fs=yes
# hardware decoding ( nothing to do with rendering, uncomment to test )
#hwdec=auto
#hwdec=v4l2m2m-copy
hwdec-codecs=all
# Personnal preferences
sub-font='FreeSerifBold'
sub-file-paths=Subs:Sub:subs:sub
slang=en,eng
alang=en,eng
Link to post
