RoganDawes Posted February 24, 2021 Posted February 24, 2021 Armbianmonitor: http://ix.io/2QEx I've been using the Armbian R1 image (Armbian_20.02.1_Nanopi-r1_buster_current_5.4.20.7z) on the NanoPi R1S with good success. In particular, the USB host port worked perfectly, with no changes required. I thought it was probably about time to upgrade to a newer kernel, so I downloaded Armbian_21.02.1_Nanopi-r1_focal_current_5.10.12.img, flashed it to an SD card, and booted. However, plugging in an external USB device results in absolutely zero shoing up in `dmesg -w`. I tried a USB-UART (STM32-based ACM), USB3 hub, USB 3 Mass Storage (Kingston 16GB), and a Playstation 3 Eye, without any entries in dmesg. To do some debugging, I also downloaded Armbian_21.02.1_Nanopi-r1_buster_current_5.10.12.img, and did the same testing, with the same result. I have verified that there is power on the Vcc, as the camera's microphone light lights up. I should mention that the built-in Realtek 8153 Ethernet port IS recognised: root@nanopi-r1:~# lsusb Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 002: ID 0bda:8153 Realtek Semiconductor Corp. RTL8153 Gigabit Ethernet Adapter Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@nanopi-r1:~# Any suggestions as to what I can do to figure out why this USB port is not working?
RoganDawes Posted February 24, 2021 Author Posted February 24, 2021 I went back to an older version of Armbian for the R1 (Armbian_20.05.2_Nanopi-r1_buster_current_5.4.43.img), and it also failed to detect any USB devices connected to that port. To verify that it was not a hardware fault, I went back to Armbian_20.02.1_Nanopi-r1_buster_current_5.4.20.img and was able to see the device being connected and disconnected. So it would appear that the change was introduced somewhere between those two versions.
Igor Posted February 24, 2021 Posted February 24, 2021 6 hours ago, RoganDawes said: Any suggestions as to what I can do to figure out why this USB port is not working? https://docs.armbian.com/User-Guide_Armbian-Config/ Enable all USB ports in system -> hardware
RoganDawes Posted February 25, 2021 Author Posted February 25, 2021 Thanks! Is there a reason that exposed ports are not enabled by default?
