ghoul Posted May 30, 2021 Posted May 30, 2021 Recently has appeared some 3566 tv boxes in the wild, would be doable to run armbian on them? Since Rockchip seems kinda dedicated to openness the same goes for the RK3566? 0 Quote
Werner Posted May 31, 2021 Posted May 31, 2021 In terms of mainline support this should be possible if the device tree is known since lots of stuff for rk3568 has been spotted in the Linux ARM mailing list. However it seems like only initial support has been approved yet and is up to being released with 5.13. 1 Quote
ghoul Posted May 31, 2021 Author Posted May 31, 2021 4 hours ago, Werner said: In terms of mainline support this should be possible if the device tree is known since lots of stuff for rk3568 has been spotted in the Linux ARM mailing list. However it seems like only initial support has been approved yet and is up to being released with 5.13. So we basically need only to be patient and wait, and this is great because GNU/Linux on RK3566 and RK3568 should give a truly enjoyable experience. Anyway, thanks for the reply! 0 Quote
zella Posted September 6, 2021 Posted September 6, 2021 There are a lot of cheap tv boxes with 8gb ram, so armbian will be very intersting. 1 Quote
Werner Posted September 6, 2021 Posted September 6, 2021 54 minutes ago, zella said: There are a lot of cheap tv boxes with 8gb ram, so armbian will be very intersting. If somebody wants to waste time on it maybe. Nothing official however. Check https://docs.armbian.com/User-Guide_FAQ/#i-have-a-tv-box-from-insert-random-vendor-can-i-use-armbian-on-it 1 Quote
chinhhut Posted October 31, 2021 Posted October 31, 2021 Personally, we still hope our hero @jock will take a look on rk3566 soon in near future. For now, I feel happy with my 3318 box. 1 Quote
qm3ster Posted March 25, 2022 Posted March 25, 2022 I wonder why RK3566 and even RK3228A TV boxes come with 8GB RAM, but the vastly superior RK3399 is only ever seen with 4GB. Also, this may interest some people here (whoops if already posted). It's a random(?) putting what appears to be a @balbes150's RK3566 build on X96 X6, a 8GB TV box, and claiming that even WiFi/Bluetooth works? Unclear. 0 Quote
jock Posted March 25, 2022 Posted March 25, 2022 10 hours ago, qm3ster said: I wonder why RK3566 and even RK3228A TV boxes come with 8GB RAM, but the vastly superior RK3399 is only ever seen with 4GB. Because rk3228a with 8gb ram has huge fakes. The chip cannot address more than 2gb of ram and that's a fact. 1 Quote
Lelle Posted April 2, 2023 Posted April 2, 2023 I bought a "X88 Pro 20" box (RK3566). After enjoying my old X96 going Linux. Questions: which *.IMG to use and how to use it? Thx 0 Quote
SteeMan Posted April 2, 2023 Posted April 2, 2023 @Lelle I'm not aware of anyone in the Armbian community working on TV boxes with the rk3566. Note that Armbian doesn't support TV boxes in any official way. TV box support is left to the community to pick up. https://forum.armbian.com/topic/16976-status-of-armbian-on-tv-boxes-please-read-first/#comment-118794 0 Quote
mmie4jbcu Posted May 27, 2023 Posted May 27, 2023 > mmie4jbcu has reported armbian on x88 pro 20 Thanks @maka for mentioning @Lelle I usually use the Station M2 edge images from the community builds: https://github.com/armbian/community I prefer the Ubuntu based images (lunar as of now). Most importantly, you'd need a proper dtb to point to. I have attached the rk3566-box-demo dtb (and its source dts) that I'm using right now. This dts is the latest from mainline kernel with an additional patch to allow the usb 2.0 port to function. I assume you know where to place the dtb file and how to update your extlinux.conf file to point to it. If not, then please feel free to ask further questions. rk3566-box-demo.zip 2 Quote
Petru Susa Posted June 21, 2023 Posted June 21, 2023 Hello (i'm new on Armbian ) @mmie4jbcu : I will be interested to know more about how to work with dtb file and update extlinux.conf file using an existing armbian img. I have a tv box with rk3566/4Gb RAM (btw: the seller was promoting it as 8Gb RAM...in reality it is 4...) Thank you in advance for guidance 0 Quote
Hqnicolas Posted June 22, 2023 Posted June 22, 2023 23 hours ago, Petru Susa said: Hello welcome to armbian, TVBoxes isn't supported here. So, you will need to done all by your own. See My example before read this and follow this guis 0 Quote
mmie4jbcu Posted June 25, 2023 Posted June 25, 2023 Hi @Petru Susa As @hotnikq mentioned in his comment, please go through the links he shared. Feel free to ask here about any follow up questions. To directly answer your question, dtb files are found usually under the dtb directory in the /boot directory. If you have written an armbian image onto a sdcard, you can insert in your computer and browse to where it is mounted. The dtb files for rockchip will be in /boot/dtb/rockchip directory. The extlinux.conf file is used to define the path to kernel as well as the dtb file. In extlinux.conf, you can update the dtb path to whatever dtb you want to use. What is the box that you have got? Can you share some pictures of the board? This way, awesome people in this community will be able to help - someone may recognize this board or offer some more hints to where to look further. 0 Quote
FuSan Posted March 3, 2024 Posted March 3, 2024 @mmie4jbcuwhat version of armbian is best for x88 pro 20? Can you share the dtb too? 0 Quote
FuSan Posted March 3, 2024 Posted March 3, 2024 (edited) @mmie4jbcu asking this even after you mentioned some suggestions regarding this; because I can't seem to make the wifi or Bluetooth to work in any of the versions. Edited March 3, 2024 by FuSan 0 Quote
mmie4jbcu Posted March 4, 2024 Posted March 4, 2024 Hi @FuSan Quote what version of armbian is best for x88 pro 20? Can you share the dtb too? The latest version of Armbian will work just fine. The mainline dtb named rk3566-box-demo.dtb has pretty much everything working for a x88 pro 20 box (except BT and USB 2.0 port) Quote asking this even after you mentioned some suggestions regarding this; because I can't seem to make the wifi or Bluetooth to work in any of the versions. I have attached the dtb file that I use (and its source dts file too, in case you want to have a look). This dtb enables the bluetooth to work and also USB 2.0 port. Try it out and let us know. rk3566-box-demo.dtb rk3566-box-demo.dts 2 Quote
FuSan Posted March 4, 2024 Posted March 4, 2024 (edited) @mmie4jbcu Yeah, it seems wifi and bluetooth aren't working for me. My memory configuration is also weird. I was supposed to have 8gb ram but it shows 5.53gb ram and 2.77gb swap. I do have the 6221A-SRC metal cover which should be the same RTL8821CS network chip. Any idea how to debug the wifi? On the sidenote, I saw that many of the updated stock android firmware (x88 pro 20) from 4pda didn't work for me. Only the initial firmware worked for me. I did manage to flash t95plus android firmware and it booted. Edited March 4, 2024 by FuSan 0 Quote
mmie4jbcu Posted March 4, 2024 Posted March 4, 2024 (edited) @FuSan Please share the output of the dmesg command just after you log in into Armbian. I recall that the swap configuration can be changed by editing the file /etc/default/armbian-zram-config. If you disable zram, then you will see almost 8GB ram in your htop output. Edited March 4, 2024 by mmie4jbcu additional info 1 Quote
FuSan Posted March 4, 2024 Posted March 4, 2024 @mmie4jbcu Thanks for looking. I didn't find anything regarding wlan. Although there are some bluetooth related logs, it doesnt work. No controller is shown in bluetoothctl. dmesg.txt 0 Quote
mmie4jbcu Posted March 4, 2024 Posted March 4, 2024 @FuSan So, you have kernel 6.1.x running on your Armbian install. The driver for RTL8821CS chip was added in version 6.3 or 6.4 in the mainline kernel. You can change to a kernel with version 6.6 or later. Try searching for 'linux-image-rockchip64' using apt search command and install that kernel. I usually prefer the edge kernels because I like to stay on the bleeding edge Then, also install 'armbian-firmware-full' because it has firmware blobs to enable both wifi and bt for 8821cs. 1 Quote
FuSan Posted March 4, 2024 Posted March 4, 2024 (edited) @mmie4jbcu I think it was rebased to 6.1.x for some reason. I am on an automated nightly build. [Armbian build PR] - Rockchip64 reinstate kernel configs for current 6.6 and edge 6.7 - SBC News - Armbian Community Forums I can't find linux-image-rockchip64 kernel anymore. You know anyway to upgrade kernel at this stage? Can't find any image that has 6.3+ kernel. Edit: Well according to this post rtw88 should work even in 6.1 kernel. Which it is not. Edited March 4, 2024 by FuSan 0 Quote
SteeMan Posted March 4, 2024 Posted March 4, 2024 @FuSan The recommended way to switch kernels.in Armbian is through armbian-config 2 Quote
FuSan Posted March 5, 2024 Posted March 5, 2024 (edited) @mmie4jbcu It was linux-image-edge-rockchip64. So couldn't find it as I used linux-image-rockchip64. Installing this fixed everything. Thank you so much for everything. Btw which device build did you start with? By that I mean device source ig. Edited March 5, 2024 by FuSan 0 Quote
mmie4jbcu Posted March 6, 2024 Posted March 6, 2024 (edited) @FuSan Cheers! Have fun with your device 13 hours ago, FuSan said: Btw which device build did you start with? By that I mean device source ig Do you mean which Armbian build I started with for my device? I started with Station M2 community builds (edge), because it is also a rk3566 device. These days I run Fedora on my box. Edited March 6, 2024 by mmie4jbcu 1 Quote
MMorales Posted October 16, 2024 Posted October 16, 2024 (edited) Hello. I recently adquired a RUPA 8g 64g rk3566 which is a clone of x88 pro 20. I ve installed the image i found in t95plus page and copied the dts file from @mmie4jbcu and installed the linux-image-edge-rockchip64 who @FuSan found, but allwais recognice 4 gigas of ram and not the 8gb what supose to have. After some differents tries i opened the box to see what kind of chips are in... There are only one chip for memory and one for emmc, the name of mem chip is D9WLV which correspond to MT53E2G32D8QD-046 I found in that page and in other sales pages what that chip is 8gb. So at the beggining i was thinking this memory its a fake but now im not sure. And when o boot from android and run aida64 it show me 8gb of ram. But only 2gb of Free mem which is suspicious. this is only for remembering purposes a benchmark to this device booting from sd: Quote sbc-bench v0.9.67 Rockchip RK3566 BOX DEMO Board (Wed, 16 Oct 2024 11:18:03 +0200) Distributor ID: Debian Description: Armbian-unofficial 24.2.0-trunk bookworm Release: 12 Codename: bookworm Build system: https://github.com/armbian/build, 24.2.0-trunk, Station M2, media, media /usr/bin/gcc (Debian 12.2.0-14) 12.2.0 Uptime: 11:18:04 up 20 min, 3 users, load average: 1.07, 1.00, 0.66, 50.0°C, 389420435 Linux 6.11.0-edge-rockchip64 (station-m2) 10/16/24 _aarch64_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 11.37 0.00 2.07 1.12 0.00 85.43 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk0 13.94 374.04 838.96 0.00 469047 1052049 0 mmcblk2 0.88 19.08 0.00 0.00 23924 0 0 zram0 0.04 0.95 0.00 0.00 1192 4 0 zram1 0.31 0.33 1.97 0.00 420 2472 0 total used free shared buff/cache available Mem: 3.8Gi 308Mi 3.5Gi 37Mi 118Mi 3.5Gi Swap: 1.9Gi 0B 1.9Gi Filename Type Size Used Priority /dev/zram0 partition 2001268 0 5 ########################################################################## Checking cpufreq OPP (Cortex-A55): Cpufreq OPP: 1800 Measured: 1718 (1718.657/1718.335/1717.992) (-4.6%) Cpufreq OPP: 1608 Measured: 1498 (1498.408/1498.352/1497.305) (-6.8%) Cpufreq OPP: 1416 Measured: 1299 (1299.694/1298.784/1298.670) (-8.3%) Cpufreq OPP: 1104 Measured: 1231 (1232.112/1231.710/1231.679) (+11.5%) Cpufreq OPP: 816 Measured: 812 (812.215/812.215/811.885) Cpufreq OPP: 600 Measured: 595 (596.209/595.806/595.114) Cpufreq OPP: 408 Measured: 403 (404.063/403.976/402.748) (-1.2%) ########################################################################## Hardware sensors: cpu_thermal-virtual-0 temp1: +52.5 C gpu_thermal-virtual-0 temp1: +53.8 C ########################################################################## Executing benchmark on cpu0 (Cortex-A55): tinymembench v0.4.9-nuumio (simple benchmark for memory throughput and latency) CFLAGS: bandwidth test min repeats (-b): 2 bandwidth test max repeats (-B): 3 bandwidth test mem realloc (-M): no (-m for realloc) latency test repeats (-l): 3 latency test count (-c): 1000000 ========================================================================== == Memory bandwidth tests == == == == Note 1: 1MB = 1000000 bytes == == Note 2: Test result is the best of repeated runs. Number of repeats == == is shown in brackets == == Note 3: Results for 'copy' tests show how many bytes can be == == copied per second (adding together read and writen == == bytes would have provided twice higher numbers) == == Note 4: 2-pass copy means that we are using a small temporary buffer == == to first fetch data into it, and only then write it to the == == destination (source -> L1 cache, L1 cache -> destination) == == Note 5: If sample standard deviation exceeds 0.1%, it is shown in == == brackets == ========================================================================== C copy backwards : 1536.3 MB/s (3, 14.3%) C copy backwards (32 byte blocks) : 1513.8 MB/s (2) C copy backwards (64 byte blocks) : 1525.4 MB/s (2) C copy : 2239.6 MB/s (2) C copy prefetched (32 bytes step) : 1494.9 MB/s (3, 0.2%) C copy prefetched (64 bytes step) : 2212.1 MB/s (3, 1.9%) C 2-pass copy : 1312.1 MB/s (3) C 2-pass copy prefetched (32 bytes step) : 905.1 MB/s (2) C 2-pass copy prefetched (64 bytes step) : 1324.4 MB/s (2) C scan 8 : 420.0 MB/s (2) C scan 16 : 833.0 MB/s (2) C scan 32 : 1630.4 MB/s (2) C scan 64 : 2961.8 MB/s (3, 0.2%) C fill : 5763.6 MB/s (2) C fill (shuffle within 16 byte blocks) : 5766.3 MB/s (2) C fill (shuffle within 32 byte blocks) : 5762.0 MB/s (2) C fill (shuffle within 64 byte blocks) : 5761.8 MB/s (2) --- libc memcpy copy : 1969.8 MB/s (3, 0.7%) libc memchr scan : 2475.0 MB/s (3, 0.3%) libc memset fill : 5766.5 MB/s (3) --- NEON LDP/STP copy : 2239.8 MB/s (2) NEON LDP/STP copy pldl2strm (32 bytes step) : 1822.9 MB/s (3, 0.1%) NEON LDP/STP copy pldl2strm (64 bytes step) : 2138.4 MB/s (3, 1.6%) NEON LDP/STP copy pldl1keep (32 bytes step) : 1693.7 MB/s (2) NEON LDP/STP copy pldl1keep (64 bytes step) : 2257.0 MB/s (2) NEON LD1/ST1 copy : 2238.5 MB/s (2) NEON LDP load : 4889.8 MB/s (3, 0.1%) NEON LDNP load : 5090.1 MB/s (3, 1.5%) NEON STP fill : 5768.6 MB/s (3) NEON STNP fill : 1601.2 MB/s (3, 1.7%) ARM LDP/STP copy : 2239.5 MB/s (2) ARM LDP load : 4885.5 MB/s (2) ARM LDNP load : 5086.8 MB/s (3, 1.4%) ARM STP fill : 5769.6 MB/s (3, 19.1%) ARM STNP fill : 1659.3 MB/s (3, 3.1%) ========================================================================== == Framebuffer read tests. == == == == Many ARM devices use a part of the system memory as the framebuffer, == == typically mapped as uncached but with write-combining enabled. == == Writes to such framebuffers are quite fast, but reads are much == == slower and very sensitive to the alignment and the selection of == == CPU instructions which are used for accessing memory. == == == == Many x86 systems allocate the framebuffer in the GPU memory, == == accessible for the CPU via a relatively slow PCI-E bus. Moreover, == == PCI-E is asymmetric and handles reads a lot worse than writes. == == == == If uncached framebuffer reads are reasonably fast (at least 100 MB/s == == or preferably >300 MB/s), then using the shadow framebuffer layer == == is not necessary in Xorg DDX drivers, resulting in a nice overall == == performance improvement. For example, the xf86-video-fbturbo DDX == == uses this trick. == ========================================================================== NEON LDP/STP copy (from framebuffer) : 197.7 MB/s (3, 0.4%) NEON LDP/STP 2-pass copy (from framebuffer) : 188.7 MB/s (3, 0.9%) NEON LD1/ST1 copy (from framebuffer) : 53.9 MB/s (2) NEON LD1/ST1 2-pass copy (from framebuffer) : 53.2 MB/s (2) ARM LDP/STP copy (from framebuffer) : 106.0 MB/s (2) ARM LDP/STP 2-pass copy (from framebuffer) : 103.2 MB/s (2) ========================================================================== == Memory latency test == == == == Average time is measured for random memory accesses in the buffers == == of different sizes. The larger is the buffer, the more significant == == are relative contributions of TLB, L1/L2 cache misses and SDRAM == == accesses. For extremely large buffer sizes we are expecting to see == == page table walk with several requests to SDRAM for almost every == == memory access (though 64MiB is not nearly large enough to experience == == this effect to its fullest). == == == == Note 1: All the numbers are representing extra time, which needs to == == be added to L1 cache latency. The cycle timings for L1 cache == == latency can be usually found in the processor documentation. == == Note 2: Dual random read means that we are simultaneously performing == == two independent memory accesses at a time. In the case if == == the memory subsystem can't handle multiple outstanding == == requests, dual random read has the same timings as two == == single reads performed one after another. == ========================================================================== block size : single random read / dual random read, [MADV_NOHUGEPAGE] 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 0.2 ns / 0.2 ns 32768 : 3.5 ns / 6.4 ns 65536 : 9.7 ns / 13.9 ns 131072 : 13.3 ns / 17.0 ns 262144 : 16.2 ns / 18.6 ns 524288 : 31.0 ns / 43.8 ns 1048576 : 100.3 ns / 147.8 ns 2097152 : 141.6 ns / 189.2 ns 4194304 : 164.1 ns / 204.5 ns 8388608 : 182.8 ns / 221.5 ns 16777216 : 193.3 ns / 231.9 ns 33554432 : 200.9 ns / 239.2 ns 67108864 : 204.6 ns / 244.5 ns block size : single random read / dual random read, [MADV_HUGEPAGE] 1024 : 0.0 ns / 0.0 ns 2048 : 0.0 ns / 0.0 ns 4096 : 0.0 ns / 0.0 ns 8192 : 0.0 ns / 0.0 ns 16384 : 1.3 ns / 1.7 ns 32768 : 0.6 ns / 0.8 ns 65536 : 8.7 ns / 13.9 ns 131072 : 13.4 ns / 17.1 ns 262144 : 16.8 ns / 18.6 ns 524288 : 20.1 ns / 21.4 ns 1048576 : 99.2 ns / 148.1 ns 2097152 : 140.7 ns / 189.2 ns 4194304 : 162.0 ns / 203.2 ns 8388608 : 173.6 ns / 207.9 ns 16777216 : 178.4 ns / 209.8 ns 33554432 : 180.3 ns / 210.1 ns 67108864 : 181.4 ns / 210.6 ns ########################################################################## Executing ramlat on cpu0 (Cortex-A55), results in ns: size: 1x32 2x32 1x64 2x64 1xPTR 2xPTR 4xPTR 8xPTR 4k: 1.772 1.790 1.773 1.769 1.170 1.754 2.378 4.795 8k: 1.750 1.752 1.751 1.754 1.170 1.754 2.377 4.793 16k: 1.752 1.754 1.758 1.756 1.169 1.755 2.380 4.793 32k: 1.797 1.761 1.797 1.765 1.175 1.762 2.386 4.806 64k: 15.54 18.10 15.54 17.96 15.22 17.90 28.90 52.82 128k: 18.55 18.90 18.58 18.91 17.51 18.90 33.30 64.37 256k: 19.10 19.16 19.00 19.20 18.21 19.17 32.77 65.51 512k: 48.68 62.71 47.73 63.44 47.96 80.03 102.7 188.1 1024k: 132.7 145.5 125.6 145.5 125.5 145.0 217.0 408.8 2048k: 167.6 168.2 159.6 168.5 158.6 172.6 256.3 471.9 4096k: 183.8 182.9 178.8 182.9 176.9 184.1 265.1 482.2 8192k: 193.7 196.0 190.2 193.3 189.5 192.3 269.8 496.0 16384k: 193.0 200.0 194.6 195.2 192.0 194.9 272.8 501.8 32768k: 207.2 209.9 206.6 209.7 206.1 215.9 282.1 514.9 65536k: 207.9 210.3 207.1 210.4 206.1 209.9 282.3 534.5 131072k: 213.3 213.9 208.9 213.4 207.8 212.3 284.4 542.3 ########################################################################## Executing benchmark twice on cluster 0 (Cortex-A55) OpenSSL 3.0.14, built on 4 Jun 2024 (Library: OpenSSL 3.0.14 4 Jun 2024) type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes 16384 bytes aes-128-cbc 150558.23k 449964.99k 879854.17k 1162769.41k 1283497.98k 1292479.15k aes-128-cbc 150275.64k 448584.55k 881040.55k 1164742.66k 1284489.22k 1293817.17k aes-192-cbc 144778.27k 400601.90k 716402.35k 895496.19k 938732.20k 939278.34k aes-192-cbc 144920.35k 401338.88k 718051.67k 897160.87k 967704.58k 972892.84k aes-256-cbc 138603.79k 365614.36k 618102.61k 749334.87k 798023.68k 800101.72k aes-256-cbc 139451.34k 369687.74k 622000.90k 751485.95k 800393.90k 804006.57k ########################################################################## Executing benchmark single-threaded on cpu0 (Cortex-A55) 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 64000000 - - - - - - - - RAM size: 3908 MB, # CPU hardware threads: 4 RAM usage: 435 MB, # Benchmark threads: 1 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 872 100 850 849 | 19595 100 1675 1673 23: 812 100 829 828 | 19145 100 1659 1657 24: 757 100 816 815 | 18644 100 1639 1637 25: 716 100 819 818 | 18107 100 1614 1612 ---------------------------------- | ------------------------------ Avr: 100 828 827 | 100 1647 1645 Tot: 100 1238 1236 ########################################################################## Executing benchmark 3 times multi-threaded on CPUs 0-3 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 64000000 - - 64000000 128000000 256000000 512000000 1024000000 - RAM size: 3908 MB, # CPU hardware threads: 4 RAM usage: 882 MB, # Benchmark threads: 4 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 2638 356 721 2566 | 74692 399 1597 6372 23: 2553 369 705 2601 | 71223 393 1568 6163 24: 2435 372 704 2619 | 69364 393 1548 6089 25: 2371 383 706 2707 | 66812 393 1514 5946 ---------------------------------- | ------------------------------ Avr: 370 709 2623 | 394 1557 6143 Tot: 382 1133 4383 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: 64000000 - - - - - - - - RAM size: 3908 MB, # CPU hardware threads: 4 RAM usage: 882 MB, # Benchmark threads: 4 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 2593 351 720 2523 | 74333 399 1591 6342 23: 2483 362 699 2531 | 71069 398 1543 6149 24: 2455 375 705 2640 | 67303 398 1483 5908 25: 2339 380 702 2671 | 63556 398 1421 5656 ---------------------------------- | ------------------------------ Avr: 367 707 2591 | 398 1510 6014 Tot: 383 1108 4303 7-Zip (a) [64] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21 p7zip Version 16.02 (locale=C,Utf16=off,HugeFiles=on,64 bits,4 CPUs LE) LE CPU Freq: - 64000000 - - - - - - - RAM size: 3908 MB, # CPU hardware threads: 4 RAM usage: 882 MB, # Benchmark threads: 4 Compressing | Decompressing Dict Speed Usage R/U Rating | Speed Usage R/U Rating KiB/s % MIPS MIPS | KiB/s % MIPS MIPS 22: 2588 351 717 2518 | 66641 399 1426 5686 23: 2521 367 700 2569 | 64652 398 1406 5594 24: 2440 373 703 2624 | 62932 398 1388 5525 25: 2329 380 700 2660 | 60018 394 1357 5342 ---------------------------------- | ------------------------------ Avr: 368 705 2593 | 397 1394 5536 Tot: 382 1050 4065 Compression: 2623,2591,2593 Decompression: 6143,6014,5536 Total: 4383,4303,4065 ########################################################################## ** cpuminer-multi 1.3.7 by tpruvot@github ** BTC donation address: 1FhDPLPpw18X4srecguG3MxJYe4a1JsZnd (tpruvot) [2024-10-16 11:30:05] 4 miner threads started, using 'scrypt' algorithm. [2024-10-16 11:30:06] CPU #1: 1.39 kH/s [2024-10-16 11:30:06] CPU #0: 1.31 kH/s [2024-10-16 11:30:06] CPU #2: 1.31 kH/s [2024-10-16 11:30:06] CPU #3: 1.01 kH/s [2024-10-16 11:30:06] Total: 5.03 kH/s [2024-10-16 11:30:09] Total: 5.24 kH/s [2024-10-16 11:30:10] Total: 5.22 kH/s [2024-10-16 11:30:15] CPU #0: 1.38 kH/s [2024-10-16 11:30:15] CPU #2: 1.38 kH/s [2024-10-16 11:30:15] CPU #1: 1.38 kH/s [2024-10-16 11:30:15] CPU #3: 1.38 kH/s [2024-10-16 11:30:15] Total: 5.52 kH/s [2024-10-16 11:30:20] Total: 5.53 kH/s [2024-10-16 11:30:25] CPU #0: 1.38 kH/s [2024-10-16 11:30:25] CPU #2: 1.37 kH/s [2024-10-16 11:30:25] CPU #1: 1.38 kH/s [2024-10-16 11:30:25] CPU #3: 1.38 kH/s [2024-10-16 11:30:25] Total: 5.51 kH/s [2024-10-16 11:30:30] Total: 5.54 kH/s [2024-10-16 11:30:35] CPU #0: 1.38 kH/s [2024-10-16 11:30:35] CPU #2: 1.38 kH/s [2024-10-16 11:30:35] CPU #1: 1.38 kH/s [2024-10-16 11:30:35] CPU #3: 1.38 kH/s [2024-10-16 11:30:35] Total: 5.53 kH/s [2024-10-16 11:30:40] Total: 5.55 kH/s [2024-10-16 11:30:45] CPU #0: 1.39 kH/s [2024-10-16 11:30:45] CPU #2: 1.39 kH/s [2024-10-16 11:30:45] CPU #1: 1.39 kH/s [2024-10-16 11:30:45] CPU #3: 1.38 kH/s [2024-10-16 11:30:45] Total: 5.54 kH/s [2024-10-16 11:30:50] Total: 5.52 kH/s [2024-10-16 11:30:55] CPU #0: 1.36 kH/s [2024-10-16 11:30:55] CPU #2: 1.37 kH/s [2024-10-16 11:30:55] CPU #1: 1.36 kH/s [2024-10-16 11:30:55] CPU #3: 1.36 kH/s [2024-10-16 11:30:55] Total: 5.46 kH/s [2024-10-16 11:31:00] Total: 5.55 kH/s [2024-10-16 11:31:05] CPU #0: 1.39 kH/s [2024-10-16 11:31:05] CPU #2: 1.39 kH/s [2024-10-16 11:31:05] CPU #1: 1.39 kH/s [2024-10-16 11:31:05] CPU #3: 1.39 kH/s [2024-10-16 11:31:05] Total: 5.56 kH/s [2024-10-16 11:31:10] Total: 5.52 kH/s [2024-10-16 11:31:15] CPU #0: 1.37 kH/s [2024-10-16 11:31:15] CPU #2: 1.37 kH/s [2024-10-16 11:31:15] CPU #1: 1.37 kH/s [2024-10-16 11:31:15] CPU #3: 1.37 kH/s [2024-10-16 11:31:15] Total: 5.49 kH/s [2024-10-16 11:31:20] Total: 5.53 kH/s [2024-10-16 11:31:25] CPU #0: 1.38 kH/s [2024-10-16 11:31:25] CPU #2: 1.38 kH/s [2024-10-16 11:31:25] CPU #1: 1.38 kH/s [2024-10-16 11:31:25] CPU #3: 1.38 kH/s [2024-10-16 11:31:25] Total: 5.51 kH/s [2024-10-16 11:31:30] Total: 5.54 kH/s [2024-10-16 11:31:35] CPU #0: 1.39 kH/s [2024-10-16 11:31:35] CPU #2: 1.39 kH/s [2024-10-16 11:31:35] CPU #1: 1.39 kH/s [2024-10-16 11:31:35] CPU #3: 1.39 kH/s [2024-10-16 11:31:35] Total: 5.55 kH/s [2024-10-16 11:31:40] Total: 5.50 kH/s [2024-10-16 11:31:45] CPU #0: 1.38 kH/s [2024-10-16 11:31:45] CPU #2: 1.38 kH/s [2024-10-16 11:31:45] CPU #1: 1.38 kH/s [2024-10-16 11:31:45] CPU #3: 1.38 kH/s [2024-10-16 11:31:45] Total: 5.52 kH/s [2024-10-16 11:31:50] Total: 5.41 kH/s [2024-10-16 11:31:55] CPU #2: 1.38 kH/s [2024-10-16 11:31:55] CPU #0: 1.36 kH/s [2024-10-16 11:31:55] CPU #1: 1.38 kH/s [2024-10-16 11:31:55] CPU #3: 1.37 kH/s [2024-10-16 11:31:55] Total: 5.49 kH/s [2024-10-16 11:32:00] Total: 5.51 kH/s [2024-10-16 11:32:05] CPU #0: 1.39 kH/s [2024-10-16 11:32:05] CPU #2: 1.38 kH/s [2024-10-16 11:32:05] CPU #1: 1.38 kH/s [2024-10-16 11:32:05] CPU #3: 1.38 kH/s [2024-10-16 11:32:05] Total: 5.54 kH/s [2024-10-16 11:32:10] Total: 5.53 kH/s [2024-10-16 11:32:15] CPU #0: 1.38 kH/s [2024-10-16 11:32:15] CPU #2: 1.38 kH/s [2024-10-16 11:32:15] CPU #1: 1.38 kH/s [2024-10-16 11:32:15] CPU #3: 1.38 kH/s [2024-10-16 11:32:15] Total: 5.53 kH/s [2024-10-16 11:32:20] Total: 5.49 kH/s [2024-10-16 11:32:25] CPU #2: 1.38 kH/s [2024-10-16 11:32:25] CPU #0: 1.37 kH/s [2024-10-16 11:32:25] CPU #1: 1.38 kH/s [2024-10-16 11:32:25] CPU #3: 1.38 kH/s [2024-10-16 11:32:25] Total: 5.50 kH/s [2024-10-16 11:32:30] Total: 5.56 kH/s [2024-10-16 11:32:35] CPU #0: 1.38 kH/s [2024-10-16 11:32:35] CPU #2: 1.38 kH/s [2024-10-16 11:32:35] CPU #1: 1.38 kH/s [2024-10-16 11:32:35] CPU #3: 1.38 kH/s [2024-10-16 11:32:35] Total: 5.52 kH/s [2024-10-16 11:32:40] Total: 5.51 kH/s [2024-10-16 11:32:45] CPU #0: 1.38 kH/s [2024-10-16 11:32:45] CPU #2: 1.38 kH/s [2024-10-16 11:32:45] CPU #1: 1.38 kH/s [2024-10-16 11:32:45] CPU #3: 1.38 kH/s [2024-10-16 11:32:45] Total: 5.53 kH/s [2024-10-16 11:32:50] Total: 5.52 kH/s [2024-10-16 11:32:55] CPU #0: 1.38 kH/s [2024-10-16 11:32:55] CPU #2: 1.38 kH/s [2024-10-16 11:32:55] CPU #1: 1.38 kH/s [2024-10-16 11:32:55] CPU #3: 1.38 kH/s [2024-10-16 11:32:55] Total: 5.51 kH/s [2024-10-16 11:33:00] Total: 5.52 kH/s [2024-10-16 11:33:05] CPU #2: 1.37 kH/s [2024-10-16 11:33:05] CPU #0: 1.37 kH/s [2024-10-16 11:33:05] CPU #1: 1.37 kH/s [2024-10-16 11:33:05] CPU #3: 1.37 kH/s [2024-10-16 11:33:05] Total: 5.48 kH/s [2024-10-16 11:33:10] Total: 5.54 kH/s [2024-10-16 11:33:15] CPU #0: 1.38 kH/s [2024-10-16 11:33:15] CPU #2: 1.38 kH/s [2024-10-16 11:33:15] CPU #1: 1.38 kH/s [2024-10-16 11:33:15] CPU #3: 1.38 kH/s [2024-10-16 11:33:15] Total: 5.53 kH/s [2024-10-16 11:33:20] Total: 5.54 kH/s [2024-10-16 11:33:25] CPU #0: 1.38 kH/s [2024-10-16 11:33:25] CPU #2: 1.38 kH/s [2024-10-16 11:33:25] CPU #1: 1.39 kH/s [2024-10-16 11:33:25] CPU #3: 1.38 kH/s [2024-10-16 11:33:25] Total: 5.54 kH/s [2024-10-16 11:33:30] Total: 5.54 kH/s [2024-10-16 11:33:35] CPU #0: 1.39 kH/s [2024-10-16 11:33:35] CPU #2: 1.39 kH/s [2024-10-16 11:33:35] CPU #1: 1.38 kH/s [2024-10-16 11:33:35] CPU #3: 1.38 kH/s [2024-10-16 11:33:35] Total: 5.53 kH/s [2024-10-16 11:33:40] Total: 5.54 kH/s [2024-10-16 11:33:45] CPU #0: 1.38 kH/s [2024-10-16 11:33:45] CPU #2: 1.37 kH/s [2024-10-16 11:33:45] CPU #1: 1.38 kH/s [2024-10-16 11:33:45] CPU #3: 1.38 kH/s [2024-10-16 11:33:45] Total: 5.51 kH/s [2024-10-16 11:33:50] Total: 5.34 kH/s [2024-10-16 11:33:55] CPU #2: 1.37 kH/s [2024-10-16 11:33:55] CPU #0: 1.35 kH/s [2024-10-16 11:33:55] CPU #1: 1.39 kH/s [2024-10-16 11:33:55] CPU #3: 1.38 kH/s [2024-10-16 11:33:55] Total: 5.49 kH/s [2024-10-16 11:34:00] Total: 5.52 kH/s [2024-10-16 11:34:05] CPU #2: 1.38 kH/s [2024-10-16 11:34:05] CPU #0: 1.38 kH/s [2024-10-16 11:34:05] CPU #1: 1.39 kH/s [2024-10-16 11:34:05] CPU #3: 1.38 kH/s [2024-10-16 11:34:05] Total: 5.52 kH/s [2024-10-16 11:34:10] Total: 5.52 kH/s [2024-10-16 11:34:15] CPU #2: 1.38 kH/s [2024-10-16 11:34:15] CPU #0: 1.38 kH/s [2024-10-16 11:34:15] CPU #1: 1.38 kH/s [2024-10-16 11:34:15] CPU #3: 1.38 kH/s [2024-10-16 11:34:15] Total: 5.52 kH/s [2024-10-16 11:34:20] Total: 5.52 kH/s [2024-10-16 11:34:25] CPU #2: 1.38 kH/s [2024-10-16 11:34:25] CPU #0: 1.38 kH/s [2024-10-16 11:34:25] CPU #1: 1.38 kH/s [2024-10-16 11:34:25] CPU #3: 1.37 kH/s [2024-10-16 11:34:25] Total: 5.51 kH/s [2024-10-16 11:34:30] Total: 5.47 kH/s [2024-10-16 11:34:35] CPU #2: 1.37 kH/s [2024-10-16 11:34:35] CPU #0: 1.36 kH/s [2024-10-16 11:34:35] CPU #1: 1.37 kH/s [2024-10-16 11:34:35] CPU #3: 1.37 kH/s [2024-10-16 11:34:35] Total: 5.47 kH/s [2024-10-16 11:34:40] Total: 5.51 kH/s [2024-10-16 11:34:45] CPU #2: 1.38 kH/s [2024-10-16 11:34:45] CPU #0: 1.38 kH/s [2024-10-16 11:34:45] CPU #1: 1.38 kH/s [2024-10-16 11:34:45] CPU #3: 1.38 kH/s [2024-10-16 11:34:45] Total: 5.51 kH/s [2024-10-16 11:34:50] Total: 5.50 kH/s [2024-10-16 11:34:55] CPU #2: 1.37 kH/s [2024-10-16 11:34:55] CPU #0: 1.37 kH/s [2024-10-16 11:34:55] CPU #1: 1.38 kH/s [2024-10-16 11:34:55] CPU #3: 1.37 kH/s [2024-10-16 11:34:55] Total: 5.50 kH/s [2024-10-16 11:35:00] Total: 5.50 kH/s [2024-10-16 11:35:05] CPU #2: 1.37 kH/s [2024-10-16 11:35:05] CPU #0: 1.37 kH/s [2024-10-16 11:35:05] CPU #1: 1.38 kH/s [2024-10-16 11:35:05] CPU #3: 1.37 kH/s [2024-10-16 11:35:05] Total: 5.49 kH/s Total Scores: 5.56,5.55,5.54,5.53,5.52,5.51,5.50,5.49,5.48,5.47,5.46,5.41,5.34,5.22 ########################################################################## Testing maximum cpufreq again, still under full load. System health now: Time CPU load %cpu %sys %usr %nice %io %irq Temp 11:34:31: 1416MHz 4.14 100% 0% 99% 0% 0% 0% 68.8°C Checking cpufreq OPP (Cortex-A55): Cpufreq OPP: 1800 Measured: 1712 (1713.143/1712.821/1712.415) (-4.9%) ########################################################################## Hardware sensors: cpu_thermal-virtual-0 temp1: +62.2 C gpu_thermal-virtual-0 temp1: +61.7 C ########################################################################## Thermal source: /sys/class/hwmon/hwmon0/ (cpu_thermal) System health while running tinymembench: Time CPU load %cpu %sys %usr %nice %io %irq Temp 11:18:37: 1800MHz 1.16 14% 2% 11% 0% 1% 0% 56.1°C 11:18:47: 1800MHz 1.14 25% 0% 25% 0% 0% 0% 57.2°C 11:18:58: 1800MHz 1.12 25% 0% 25% 0% 0% 0% 58.9°C 11:19:08: 1800MHz 1.10 25% 0% 25% 0% 0% 0% 58.3°C 11:19:18: 1800MHz 1.08 25% 0% 24% 0% 0% 0% 58.3°C 11:19:28: 1800MHz 1.07 25% 0% 25% 0% 0% 0% 60.0°C 11:19:38: 1800MHz 1.06 25% 0% 25% 0% 0% 0% 60.0°C 11:19:48: 1800MHz 1.05 26% 1% 24% 0% 0% 0% 57.2°C 11:19:59: 1800MHz 1.11 25% 0% 24% 0% 0% 0% 57.8°C 11:20:09: 1800MHz 1.17 25% 0% 24% 0% 0% 0% 57.8°C System health while running ramlat: Time CPU load %cpu %sys %usr %nice %io %irq Temp 11:20:18: 1800MHz 1.14 15% 1% 12% 0% 1% 0% 59.4°C 11:20:21: 1800MHz 1.13 25% 0% 25% 0% 0% 0% 57.2°C 11:20:24: 1800MHz 1.13 25% 0% 25% 0% 0% 0% 57.8°C 11:20:27: 1800MHz 1.12 25% 0% 25% 0% 0% 0% 58.3°C 11:20:30: 1800MHz 1.12 25% 0% 25% 0% 0% 0% 57.2°C 11:20:34: 1800MHz 1.11 25% 0% 24% 0% 0% 0% 57.2°C 11:20:37: 1800MHz 1.10 25% 0% 24% 0% 0% 0% 57.2°C 11:20:40: 1800MHz 1.10 25% 0% 24% 0% 0% 0% 57.2°C 11:20:43: 1800MHz 1.09 25% 0% 25% 0% 0% 0% 56.7°C 11:20:46: 1800MHz 1.09 25% 0% 24% 0% 0% 0% 57.2°C 11:20:49: 1800MHz 1.09 25% 0% 24% 0% 0% 0% 57.2°C 11:20:52: 1800MHz 1.08 25% 1% 24% 0% 0% 0% 57.2°C System health while running OpenSSL benchmark: Time CPU load %cpu %sys %usr %nice %io %irq Temp 11:20:53: 1800MHz 1.08 15% 1% 12% 0% 0% 0% 60.0°C 11:21:09: 1800MHz 1.06 25% 0% 25% 0% 0% 0% 58.9°C 11:21:25: 1800MHz 1.05 25% 0% 24% 0% 0% 0% 60.6°C 11:21:41: 1800MHz 1.03 25% 0% 25% 0% 0% 0% 59.4°C 11:21:58: 1800MHz 1.02 25% 0% 24% 0% 0% 0% 57.2°C 11:22:14: 1800MHz 1.02 25% 0% 25% 0% 0% 0% 58.3°C 11:22:30: 1800MHz 1.01 25% 0% 25% 0% 0% 0% 55.6°C System health while running 7-zip single core benchmark: Time CPU load %cpu %sys %usr %nice %io %irq Temp 11:22:41: 1800MHz 1.09 16% 1% 13% 0% 0% 0% 56.7°C 11:22:53: 1800MHz 1.15 25% 0% 24% 0% 0% 0% 55.6°C 11:23:06: 1800MHz 1.13 25% 0% 24% 0% 0% 0% 55.6°C 11:23:18: 1800MHz 1.10 25% 0% 24% 0% 0% 0% 55.6°C 11:23:30: 1800MHz 1.08 25% 0% 24% 0% 0% 0% 55.0°C 11:23:42: 1800MHz 1.06 25% 0% 24% 0% 0% 0% 54.4°C 11:23:54: 1800MHz 1.05 25% 0% 24% 0% 0% 0% 55.0°C 11:24:06: 1800MHz 1.04 25% 0% 24% 0% 0% 0% 54.4°C 11:24:18: 1800MHz 1.03 25% 0% 24% 0% 0% 0% 53.8°C 11:24:30: 1800MHz 1.03 25% 0% 24% 0% 0% 0% 53.8°C 11:24:43: 1800MHz 1.02 25% 0% 24% 0% 0% 0% 53.8°C System health while running 7-zip multi core benchmark: Time CPU load %cpu %sys %usr %nice %io %irq Temp 11:24:54: 1800MHz 1.02 17% 1% 14% 0% 0% 0% 56.1°C 11:25:18: 1800MHz 1.97 92% 1% 90% 0% 0% 0% 60.6°C 11:25:42: 1800MHz 2.67 94% 1% 92% 0% 0% 0% 61.7°C 11:26:07: 1800MHz 3.32 91% 2% 89% 0% 0% 0% 62.2°C 11:26:34: 1800MHz 3.78 98% 2% 96% 0% 0% 0% 67.5°C 11:26:58: 1800MHz 4.10 92% 1% 91% 0% 0% 0% 63.9°C 11:27:23: 1800MHz 4.14 94% 1% 92% 0% 0% 0% 64.4°C 11:27:48: 1800MHz 4.16 92% 2% 89% 0% 0% 0% 65.0°C 11:28:15: 1608MHz 4.30 98% 2% 96% 0% 0% 0% 68.1°C 11:28:40: 1800MHz 4.06 95% 0% 94% 0% 0% 0% 68.8°C 11:29:05: 1800MHz 4.04 93% 1% 91% 0% 0% 0% 66.2°C 11:29:29: 1800MHz 3.93 93% 1% 91% 0% 0% 0% 66.9°C 11:29:53: 1800MHz 4.43 97% 3% 94% 0% 0% 0% 66.2°C System health while running cpuminer: Time CPU load %cpu %sys %usr %nice %io %irq Temp 11:30:10: 1800MHz 4.57 29% 1% 27% 0% 0% 0% 68.8°C 11:30:54: 1608MHz 4.34 100% 0% 99% 0% 0% 0% 68.1°C 11:31:37: 1608MHz 4.20 100% 0% 99% 0% 0% 0% 68.1°C 11:32:20: 1608MHz 4.18 100% 0% 99% 0% 0% 0% 68.8°C 11:33:04: 1608MHz 4.09 100% 0% 99% 0% 0% 0% 68.1°C 11:33:47: 1608MHz 4.20 100% 0% 99% 0% 0% 0% 68.1°C 11:34:31: 1416MHz 4.14 100% 0% 99% 0% 0% 0% 68.8°C ########################################################################## Throttling statistics (time spent on each cpufreq OPP): 1800 MHz: 673.85 sec 1608 MHz: 293.70 sec 1416 MHz: 21.96 sec 1104 MHz: 0 sec 816 MHz: 0 sec 600 MHz: 0 sec 408 MHz: 0 sec ########################################################################## Linux 6.11.0-edge-rockchip64 (station-m2) 10/16/24 _aarch64_ (4 CPU) avg-cpu: %user %nice %system %iowait %steal %idle 36.63 0.01 1.56 0.62 0.00 61.18 Device tps kB_read/s kB_wrtn/s kB_dscd/s kB_read kB_wrtn kB_dscd mmcblk0 7.78 208.99 461.49 0.00 476735 1052737 0 mmcblk2 0.48 10.49 0.00 0.00 23924 0 0 zram0 0.02 0.52 0.00 0.00 1192 4 0 zram1 0.19 0.20 1.15 0.00 448 2612 0 total used free shared buff/cache available Mem: 3.8Gi 341Mi 3.5Gi 37Mi 126Mi 3.5Gi Swap: 1.9Gi 0B 1.9Gi Filename Type Size Used Priority /dev/zram0 partition 2001268 0 5 CPU sysfs topology (clusters, cpufreq members, clockspeeds) cpufreq min max CPU cluster policy speed speed core type 0 0 0 408 1800 Cortex-A55 / r2p0 1 0 0 408 1800 Cortex-A55 / r2p0 2 0 0 408 1800 Cortex-A55 / r2p0 3 0 0 408 1800 Cortex-A55 / r2p0 Architecture: aarch64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Vendor ID: ARM Model name: Cortex-A55 Model: 0 Thread(s) per core: 1 Core(s) per cluster: 4 Socket(s): - Cluster(s): 1 Stepping: r2p0 CPU(s) scaling MHz: 100% CPU max MHz: 1800.0000 CPU min MHz: 408.0000 BogoMIPS: 48.00 Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp NUMA node(s): 1 NUMA node0 CPU(s): 0-3 Vulnerability Gather data sampling: Not affected Vulnerability Itlb multihit: Not affected Vulnerability L1tf: Not affected Vulnerability Mds: Not affected Vulnerability Meltdown: Not affected Vulnerability Mmio stale data: Not affected Vulnerability Reg file data sampling: Not affected Vulnerability Retbleed: Not affected Vulnerability Spec rstack overflow: Not affected Vulnerability Spec store bypass: Not affected Vulnerability Spectre v1: Mitigation; __user pointer sanitization Vulnerability Spectre v2: Not affected Vulnerability Srbds: Not affected Vulnerability Tsx async abort: Not affected SoC guess: Rockchip RK3566 DT compat: rockchip,rk3566-box-demo rockchip,rk3566 Compiler: /usr/bin/gcc (Debian 12.2.0-14) 12.2.0 / aarch64-linux-gnu Userland: arm64 Kernel: 6.11.0-edge-rockchip64/aarch64 CONFIG_HZ=250 CONFIG_HZ_250=y CONFIG_PREEMPTION=y CONFIG_PREEMPT=y CONFIG_PREEMPT_BUILD=y CONFIG_PREEMPT_COUNT=y CONFIG_PREEMPT_NOTIFIERS=y CONFIG_PREEMPT_RCU=y ########################################################################## opp-table-0: 408 MHz 900.0 mV 600 MHz 900.0 mV 816 MHz 900.0 mV 1104 MHz 900.0 mV 1416 MHz 900.0 mV 1608 MHz 975.0 mV 1800 MHz 1050.0 mV opp-table-1: 200 MHz 825.0 mV 300 MHz 825.0 mV 400 MHz 825.0 mV 600 MHz 825.0 mV 700 MHz 900.0 mV 800 MHz 1000.0 mV ########################################################################## Results validation: * Advertised vs. measured max CPU clockspeed: -4.6% before, -4.9% after -> https://tinyurl.com/32w9rr94 * No swapping * Background activity (%system) OK * Throttling occured -> https://tinyurl.com/4ky59sys Status of performance related governors found below /sys (w/o cpufreq): * fde60000.gpu: simple_ondemand / 200 MHz (powersave performance simple_ondemand / 200 300 400 600 700 800) | Rockchip RK3566 BOX DEMO Board | ~1720 (throttled) | 6.11 | Debian 12 (bookworm) tampered by Armbian-unofficial 24.2.0-trunk bookworm arm64 | 4250 | 1236 | 802050 | 1970 | 5770 | 5.55 | Edited October 16, 2024 by MMorales 0 Quote
Hqnicolas Posted October 16, 2024 Posted October 16, 2024 (edited) On 10/16/2024 at 5:01 AM, MMorales said: So at the beggining i was thinking this memory its a fake but now im not sure. Omg! 😮 A TV box with fake memory! Now all that's left is for you is to discover that the original software has malware 😅 the first rule on TV box for Linux is "don't trust TV boxes" stop been scammed and buy a board from Partners My personal favorite is Bpi this information was on media since 2023, you need to take care.... https://youtu.be/1vpepaQ-VQQ?t=445 Edited October 18, 2024 by Hqnicolas 1 Quote
MMorales Posted October 19, 2024 Posted October 19, 2024 @Hqnicolas very thanks for your help. Anyway im so happy with my 25€ expense. It comes with 4g of ddr4. rk3566 , Gigabyte Lan, Dual wifi, 64gb emmc, display, usb3 port, and including a beautiful box, remote and power suply. How much cost the same from a partner board? 1 Quote
