bitfreak Posted June 9, 2021 Posted June 9, 2021 Armbianmonitor: http://ix.io/3pko Hi all, Using Armbian_21.05.1_Odroidn2_buster_current_5.10.34.img.xz I got the error Error: Unable to read database "/var/lib/vnstat/docker0": No such file or directory Merge "docker0+eth0" failed. This is after I installed docker. Never had this in previous version. What can i do do fixes this ?
lanefu Posted June 10, 2021 Posted June 10, 2021 14 hours ago, Werner said: Moved to p2p. Docker is upstream Actually this isnt docker issue. This is our vnstat install and motd making noise. Because of the new interface created by docker
Werner Posted June 10, 2021 Posted June 10, 2021 I see, did not know that. So this also means all boards are affected?
Solution Igor Posted June 10, 2021 Solution Posted June 10, 2021 https://github.com/armbian/build/issues/2886 1
