December 17, 20214 yr Dear All, I just want to share my workflow of successfully installing Box86-Box64, Wine32-Wine64 and Winetricks on Arm64 Big thanks to @NicoD for sharing his source code of Armbian-Gaming. I modified some of his code to be used in Armbian Focal (or any Arm64 distro) and fix the armhf dependencies issue by using the "arm-linux-gnueabihf" Library from TwisterOS. I also used some of Box86 Manual. So many thanks to all of them. Ok Let's Start: 1. Add armhf multiarch sudo dpkg --add-architecture armhf sudo apt-get update 2. Install dependencies for box86 & box64 sudo apt-get install git cmake cabextract gcc-arm-linux-gnueabihf libc6-dev-armhf-cross Then download these "arm-linux-gnueabihf" files and extract them on folder /usr/ (Alternatively, you can manually copy paste the "/usr/arm-linux-gnueabihf" folder from TwisterOS and transfer it to your arm64 OS. This file contains dependencies for Box86) *NOTE: I split the files because Armbian site doesn't allow me to upload more than 1,5MB. arm-linux-gnueabihf.7z.001 arm-linux-gnueabihf.7z.002 arm-linux-gnueabihf.7z.003 arm-linux-gnueabihf.7z.004 3. Compile box86 for general ARM64 board (read box86 manual for more info about your board) cd git clone https://github.com/ptitSeb/box86 cd box86 mkdir build cd build cmake .. -DARM_DYNAREC=ON -DCMAKE_BUILD_TYPE=RelWithDebInfo make -j3 sudo make install sudo systemctl restart systemd-binfmt cd 4. Compile box64 for general ARM64 board (read box64 manual for more info about your board) cd git clone https://github.com/ptitSeb/box64 cd box64 mkdir build cd build cmake .. -DARM_DYNAREC=ON -DCMAKE_BUILD_TYPE=RelWithDebInfo make -j3 sudo make install sudo systemctl restart systemd-binfmt cd 5. Restart your Computer 6. Install Wine32 & Wine64 (Merged is the best option, and please follow the sequence accordingly. Currently at the time of writing, wine 5.21 & Wine 6.0.2 have the best support from Box86-Box64. You can also try a different version of wine if you want) #Wine 5.21 cd cd ~/Downloads wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-i386/wine-devel-i386_5.21~buster_i386.deb wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-i386/wine-devel_5.21~buster_i386.deb wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-amd64/wine-devel-amd64_5.21~buster_amd64.deb wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-amd64/wine-devel_5.21~buster_amd64.deb dpkg-deb -xv wine-devel-i386_5.21~buster_i386.deb wine-installer dpkg-deb -xv wine-devel_5.21~buster_i386.deb wine-installer dpkg-deb -xv wine-devel-amd64_5.21~buster_amd64.deb wine-installer dpkg-deb -xv wine-devel_5.21~buster_amd64.deb wine-installer mv ~/Downloads/wine-installer/opt/wine* ~/wine rm -rf wine-installer cd #Wine 6.0.2 Stable cd cd ~/Downloads wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-i386/wine-stable-i386_6.0.2~buster-1_i386.deb wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-i386/wine-stable_6.0.2~buster-1_i386.deb wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-amd64/wine-stable-amd64_6.0.2~buster-1_amd64.deb wget https://dl.winehq.org/wine-builds/debian/dists/buster/main/binary-amd64/wine-stable_6.0.2~buster-1_amd64.deb dpkg-deb -xv wine-stable-i386_6.0.2~buster-1_i386.deb wine-installer dpkg-deb -xv wine-stable_6.0.2~buster-1_i386.deb wine-installer dpkg-deb -xv wine-stable-amd64_6.0.2~buster-1_amd64.deb wine-installer dpkg-deb -xv wine-stable_6.0.2~buster-1_amd64.deb wine-installer mv ~/Downloads/wine-installer/opt/wine* ~/wine rm -rf wine-installer cd 7. Create Symlink to Wine sudo ln -s ~/wine/bin/wine /usr/local/bin/wine sudo ln -s ~/wine/bin/wineboot /usr/local/bin/wineboot sudo ln -s ~/wine/bin/winecfg /usr/local/bin/winecfg sudo ln -s ~/wine/bin/wineserver /usr/local/bin/wineserver sudo chmod +x /usr/local/bin/wine /usr/local/bin/wineboot /usr/local/bin/winecfg /usr/local/bin/wineserver 8. Setting Wine32 Folder in ~/.wine (set win32 as wine default, because currently winetricks doesn't work in win64. I would gladly use win64 as my default setup only if winetricks works in win64 in the future). WINEPREFIX=~/.wine WINEARCH=win32 wine winecfg 9. Setting Wine64 Folder in ~/.wine64 WINEPREFIX=~/.wine64 WINEARCH=win64 wine winecfg 10. In Home Folder Create alias in .bashrc (to make shorter command for wine64) cd nano .bashrc --> enter this command alias wine64="WINEPREFIX=~/.wine64 wine" --> then save (ctrl+x, choose yes) --> then logout & login 11. Installing & Running 32bit Windows app wine uninstaller wine /File/can/be/drag/and/drop/32bit.exe 12. Installing & Running 64bit Windows app wine64 uninstaller wine64 /File/can/be/drag/and/drop/64bit.exe 13. Install Winetricks sudo apt-get install cabextract -y cd ~/Downloads && wget https://raw.githubusercontent.com/Winetricks/winetricks/master/src/winetricks sudo chmod +x winetricks && sudo mv winetricks /usr/local/bin/ 14. Using Winetricks (ex: Corefonts & Dotnet 4) BOX86_NOBANNER=1 winetricks BOX86_NOBANNER=1 winetricks corefonts dotnet40 15. Creating Wine Desktop Launcher Now create a launcher in the desktop with this code in the command section: wine explorer /desktop=shell,1280x720 explorer.exe As an alternative, I personally like explorer++ mainly because of its GUI and additional feature compared to the original wine explorer. You can download it from here: https://explorerplusplus.com/software/explorer++_1.3.5_x86.zip and then extract it, and then rename to "explorer++.exe" (with small e, not capital E), then copy-paste it to the ~/.wine/drive_c/windows. Then create a launcher in the desktop with this code in the command section: wine explorer /desktop=shell,1280x720 explorer++.exe **NOTE: - With this setting I am able to run Box86 and Box64 without having dependencies conflict between armhf package and arm64 package. - I used the win32 as my default wine. Alternatively you can also use win64 as your default ~/.wine setup. It is up to you (In fact, by default it will create win64 setup in your ~/.wine folder). - For RK3399 users, you can use these scripts to Install and Update Box86 & Box64: install_box86.sh install_box64.sh update_box86.sh update_box64.sh I hope this could help somebody out there. Have a Nice Day! RNA
December 17, 20214 yr 17 hours ago, rna said: Have a Nice Day! Nice job. I had a lot of problems getting it to work on Hirsute. So I never looked into it to make it work on other releases. If you'd be willing to adjust the armbian-gaming script to do this, I'll accept any commit. https://github.com/NicoD-SBC/armbian-gaming I also was planning to add installation of PPSSPP. But never came to it. If you want to do that... I'm working on a new review video. So I ain't got time for that.
December 18, 20214 yr Author 3 hours ago, NicoD said: I had a lot of problems getting it to work on Hirsute. Yes, after running your script manually in Armbian Focal. I have a lot of dependencies conflict especially from armhf package vs. arm64 package. As a result almost all my 64bit program that has dependencies conflicts were removed from the system. After a while, I looked at how TwisterOS do this beautifully without any dependencies conflict. When building Box86 in TwisterOS, I just realized that TwisterOS only need this "arm-linux-gnueabihf" library files. Then I copied this library and pasted them to my Armbian Focal in /usr/ folder. After that I fixed all dependencies conflict by using "sudo aptitude install" and remove all armhf package that has conflict. Magically, all the conflicts were gone and as what I suspected that Box86 could compile successfully even without armhf package dependencies. Now I am very happy because I can run both Box86 and Box64 without interfering each other. even wine32, wine64 and winetricks are working. I'll say that this Library Method is better than the Schroot Method. But I am not sure for some distributions that do not support Multiarch like Manjaro, whether this Library Method is working or not. If it isn't then they have to stick with the Schroot Method. 3 hours ago, NicoD said: If you'd be willing to adjust the armbian-gaming script to do this, I am not good at github and scripting. I trust you, maybe you can try first. If it works, then you can update the armbian-config on Github with the command that I wrote. Many Thanks @NicoD
December 18, 20214 yr Author 10 hours ago, NicoD said: I also was planning to add installation of PPSSPP. But never came to it Why don't you use flatpak? I used it in my RK3399 board and it runs great. I got the latest release of PPSSPP on Armbian Focal. But because the lack of OpenGL ES 3.2 and Vulkan Driver, a demanding game like God of War Chain of Olympus only get around 16-18 fps (2x res, autoframeskip). For a middle game title it runs almost full speed. Like DragonBall Z Shin Budokai 60 fps, Daxter 30 fps with the same setting (2x res, autoframeskip) sudo apt install flatpak flatpak search ppsspp flatpak install org.ppsspp.PPSSPP I also got Dolphin & Flycast Emulator with quite great performance from flatpak. But maybe dolphin need the driver for OpenGL ES 3.2 or Vulkan to get a higher framerate. Currently the only two-emulator that don't work from apt package or Flatpak are N64 Emulator and RetroArch (Installing core is disabled).
March 4, 20224 yr I was having an error when trying to compile box86 on arm64 (marm not recognized). I found on github a good solution https://github.com/fengxue-jrql/box86-and-box64-for-arm64/ . Basically it is the same as shown here, but the box86 is compiled on armhf and then copied to arm64. You can download box86 from the link. For wine I used regular tutorial from box86 site and had no issues. Just wanted to post a reference here in case somebody else has similar problems.
March 7, 20224 yr On 3/4/2022 at 4:02 PM, daniel2 said: I was having an error when trying to compile box86 on arm64 (marm not recognized). I found on github a good solution https://github.com/fengxue-jrql/box86-and-box64-for-arm64/ . Basically it is the same as shown here, but the box86 is compiled on armhf and then copied to arm64. You can download box86 from the link. For wine I used regular tutorial from box86 site and had no issues. Just wanted to post a reference here in case somebody else has similar problems. You almost saved my life hahaha Now I have box86 and box64 runnning OK thanks to you, but I can't manage to run steamcmd (っ˘̩╭╮˘̩)っ I got Box86 with Dynarec v0.2.5 28b05465 built on Jan 16 2022 18:04:17 Error: reading elf header of /root/steamcmd/steamcmd.sh, try to launch natively instead Segmentation fault (core dumped) Do you guys know what is this error? Also, I have the same problem runining box86 with chroot (wich I had installed following the older rna guide). I thought that it was because of the lack of box64 in the envirioment, but aparently it's not.
March 15, 20224 yr On 3/7/2022 at 7:47 PM, otomai said: Box86 with Dynarec v0.2.5 28b05465 built on Jan 16 2022 18:04:17 Error: reading elf header of /root/steamcmd/steamcmd.sh, try to launch natively instead Segmentation fault (core dumped) Do you guys know what is this error? Also, I have the same problem runining box86 with chroot (wich I had installed following the older rna guide). I thought that it was because of the lack of box64 in the envirioment, but aparently it's not. I would suggest to ask on discord Pi Labs, they have a subforum there - box86-steam-unstable
March 17, 20224 yr On 3/15/2022 at 7:32 AM, daniel2 said: I would suggest to ask on discord Pi Labs, they have a subforum there - box86-steam-unstable Thx bro, I'll try to get help there!
June 1, 20224 yr A little update of my previous post about box86 install. I found on ptitSeb github project a reference for apt install of precompiled box86 builds. With that everything should be easier. So I'm posting here steps taken from https://github.com/ptitSeb/box86/blob/master/docs/COMPILE.md and https://github.com/fengxue-jrql/box86-and-box64-for-arm64. All credits to them, I just combined the two. # dependency install sudo dpkg --add-architecture armhf sudo apt update sudo apt install zenity:armhf libasound*:armhf libstdc++6:armhf mesa*:armhf # apt install sudo wget https://itai-nelken.github.io/weekly-box86-debs/debian/box86.list -O /etc/apt/sources.list.d/box86.list wget -qO- https://itai-nelken.github.io/weekly-box86-debs/debian/KEY.gpg | sudo apt-key add - sudo apt update && sudo apt install box86 -y # additional steps in chroot edit with text editor /etc/profile and put at the end this: export BOX86_PATH=~/wine/bin/ export BOX86_LD_LIBRARY_PATH=~/wine/lib/wine/i386-unix/:/lib/i386-linux-gnu:/lib/aarch64-linux-gnu/ (Last part for box64:sudo apt install mesa* zenity*) export BOX64_PATH=~/wine64/bin/ export BOX64_LD_LIBRARY_PATH=~/wine64/lib/i386-unix/:~/wine64/lib/wine/x86_64-unix/:/lib/i386-linux-gnu/:/lib/x86_64-linux-gnu:/lib/aarch64-linux-gnu/ # a note about mesa*:armhf install on arm64. I read on ptitSeb github that installing it on arm64 without chroot can break GPU acceleration. Just a warning, I had so far no issues.
January 5, 20233 yr Daniel. I just wanted to reach out to say thank you for coming back in here and posting your findings. I've spent the last two days working on getting a Windows only server running on Oracle Cloud. After working with the Armbian stuff and messing around with other sources getting wine to work, your solution gave it the Coupe de Grace I needed. Thank you so much.
June 8, 20233 yr At step: Quote WINEPREFIX=~/.wine WINEARCH=win32 wine winecfg I am getting a series of errors: Quote Error: Symbol __gmtime64 not found, cannot apply R_386_JMP_SLOT 0xf76e3010 (0x6056) in /home/[UserName]/wine/bin/../lib/wine/i386-unix/ntdll.so And more similar to this with different Symbols. ntdll.so is not located in the specified path, it is located here /home/[UserName]/wine/lib/wine/i386-unix I had moved files so the symlinks worked. I was also attempting to use the lastest stable wine: 8.0.1 System is ubuntu 22.04 jammy, I subbed in pieces where necessary. The reason I'm using this image is because the rk3328 Renegade can only use overlays for a 3.5" screen with the ubuntu image from what I've found. I do not know enough to understand where to start correcting this error, help is appreciated.
June 9, 20233 yr Hello again and sorry again for posting about ubuntu in an armbian forum. The issue was that newer Wine versions include timing64 files not available on all systems. Wine 7.0.1 worked. This thread made my project possible so thank you.
August 21, 20233 yr Hey, I followed through all steps but whenever i enter ( WINEPREFIX=~/.wine64 WINEARCH=win64 wine winecfg ) command, i get this back { bash: /usr/local/bin/wine: cannot execute binary file: Exec format error } Any ideas?
November 12, 20233 yr Thank you RNA for your hard work. Would this process work with Orange Pi 5 Plus, with the following OS? https://github.com/Joshua-Riek/ubuntu-rockchip - I tried the zip files but I was not able to unzip them with PeaZip, in Ubuntu, and other zip programs in Windows. I am new to Linux... However, any help or suggestions would be really appreciated.
May 13, 20242 yr Hmmm I seem to be having problems following this guide using: - OS: Armbian (unnofical) Noble ~ Armbian (24.04.30-armsurvivors-138) aarch6 - Hardware: On my Lenovo x13s gen 1 ~ sc8280xp - Kernal: 6.9.0-rc7-sc8280xp-arm64 I think im hitting the same problem with arm-linux-gnueabihf depency issues - This is problematic as without the 32bit toolchain (or whatever its called) I cant compile box86 correctly - The depency failures are, libpng16-16:armhf, libncurses5:armhf I would imagine it is because I am attempting this on Ubuntu Noble 24 (Armbian port) instead off earlier versions. I am playing around with trying to get Debian 13 Trixie (The Ubuntu Noble 24 equivilant) on a raspberry pi 4 in 32bit mode but will keep my progress tracked here. I also was messing around with the schroot method but I feel like this is the better way
May 13, 20242 yr 6 minutes ago, Joe Hutchinson said: Armbian (24.04.30-armsurvivors-138) aarch6 That looks like a fork of Armbian. These forums for Armbian builds not forks of Armbian builds. Generally we would recommend you direct questions based on forks of Armbian to those working on those forks.
June 22, 20242 yr For Armbian 24.04 I recommend you see the method used by the Botspot pi-apps application from github, I tested the script method and it worked very well Pi-Apps The script for Armbian 24.04 was the Steam install script, it includes BOX86 and BOX64 After install box Just install Wine normally Edit: plot twist: Steam don't work..... just box86 and box64 Edited June 22, 20242 yr by Hqnicolas
