On 1/9/2022 at 5:56 PM, constantius said:
Is khadas edge supported ?. Once it is in the download section, once it is gone. Not in the archival images?
Mistake, which will be corrected when time is found. We wrote there "build from sources" as what you should do in case you can't find a build you need.
