disconnect Posted September 10, 2016 Posted September 10, 2016 Hi Few days ago i've upgraded by armbian to the newest release version 5.17? from 5.11. The problem is, that minidlna DLNA server is only visible for few minutes after the service is started. Later i need a restart the service to make it visible for the new clients. The strange is that when i don't exit/shutdown the client, after the server discovered, it stays visible and works perfectly. But i want to make it visible for a newly started client, i need to restart the service. It doesn't seem to be client problem, as the same happens with my samsung smart tv, and a windows pc with foobar 2000 dlna plugin. What's the problem? (it maybe a broadcasting problem)
disconnect Posted September 15, 2016 Author Posted September 15, 2016 It seems a restart solved this problem
arox Posted September 15, 2016 Posted September 15, 2016 Thanks to advanced automation of configuration and startup, if comes off and on and off and on and off ... and on automatically.
Alessio Carta Posted September 21, 2016 Posted September 21, 2016 cubieboard minidlna[12389]: /usr/sbin/minidlnad: error while loading shared libraries: libavformat-ffmpeg.so.56: cannot open shared object file: No such file or directory hello my MINIDLNA doesn't work see the error above I ran this command: sudo journalctl -xe any idea, Google didn't help here
zador.blood.stained Posted September 22, 2016 Posted September 22, 2016 cubieboard minidlna[12389]: /usr/sbin/minidlnad: error while loading shared libraries: libavformat-ffmpeg.so.56: cannot open shared object file: No such file or directory Looks like this is an issue with our packaging configuration on Jessie. I'll try to fix this for a next release. 1
Alessio Carta Posted September 22, 2016 Posted September 22, 2016 Thank you sir, can I fix installing a previous package .deb? In case which is recommended?
zador.blood.stained Posted September 22, 2016 Posted September 22, 2016 Thank you sir, can I fix installing a previous package .deb? No, it's a conflict between libav packages from Jessie (which are required for minidlna) and FFmpeg packages from Armbian repository (which are required for mpv player in Armbian desktop release). The best way to resolve this would be to provide and support hardware accelerated video decoding only on Xenial based desktop images, at least until Debian Stretch is released. Edit: This is for latest (5.20) prebuilt images, previous ones should work fine I guess...
Alessio Carta Posted September 23, 2016 Posted September 23, 2016 thank you sir, I will do so and let know
