After upgrade to Bullseye 5.15.26 I can't enable spi-dev on my board. Previously I used Buster 5.3.9 and everything worked well, after upgrade /dev/spidev0.0 dissappeared.
Board is working fine (reinstalled 5.3.9 and SPI working). Is there any trick which need to be made to enable it ?
armbianmonitor.txt
I am also having a problem with spidev. I am using Banana-pi-m2-zero with ARMBIAN based Ubuntu Focal. I can't enable spi-dev. I have write in armbiancomfig.txt the following:
overlays=cpu-clock-1.3GHz-1.3v i2c0 spi-spidev
param_spidev_spi_bus=0
param_spidev_spi_cs=0
Checking the kernel logs with "dmesg | grep spidev" no show relevant info.
Reading other posts: Do I have to change sun8i-h3-spi-spidev.dtbo?
I have seen similar problem with this processor:https://archlinuxarm.org/forum/viewtopic.php?f=60&t=15395
U-Boot 2021.10-armbian (Nov 05 2021 - 13:19:06 -0600) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Banana Pi BPI-M2-Zero
DRAM:  512 MiB
MMC:   mmc@1c0f000: 0, mmc@1c10000: 2
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   No ethernet found.
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3964 bytes read in 4 ms (967.8 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
352 bytes read in 4 ms (85.9 KiB/s)
10388878 bytes read in 440 ms (22.5 MiB/s)
8303240 bytes read in 351 ms (22.6 MiB/s)
34107 bytes read in 11 ms (3 MiB/s)
478 bytes read in 9 ms (51.8 KiB/s)
Applying kernel provided DT overlay sun8i-h3-cpu-clock-1.2GHz-1.3v.dtbo
374 bytes read in 10 ms (36.1 KiB/s)
Applying kernel provided DT overlay sun8i-h3-i2c0.dtbo
788 bytes read in 10 ms (76.2 KiB/s)
Applying kernel provided DT overlay sun8i-h3-spi-spidev.dtbo
502 bytes read in 10 ms (48.8 KiB/s)
Applying kernel provided DT overlay sun8i-h3-uart1.dtbo
Applying kernel provided DT overlay sun8i-h3-uart2.dtbo
Applying kernel provided DT overlay sun8i-h3-uart3.dtbo
504 bytes read in 10 ms (48.8 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost0.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost1.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
4185 bytes read in 11 ms (371.1 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 45000000
Kernel image @ 0x42000000 [ 0x000000 - 0x7eb288 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    10388814 Bytes = 9.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 43000000
   Booting using the fdt blob at 0x43000000
   Loading Ramdisk to 49617000, end 49fff54e ... OK
   Loading Device Tree to 495a6000, end 49616fff ... OK
Starting kernel ...
I have the same problem with spidev on Orange Pi Zero. I tryed to use Armbian_22.02.1_Orangepizero_focal_current_5.15.25 and it didn't work. To make it work I had to use version of Armbian_21.08.1_Orangepizero_focal_current_5.10.60 without upgrade
I god the same problem,but I have no Armbian_21.08.1_Orangepizero_focal_current_5.10.60 image, and noway to download it, can you give me one?
Try downgrade kernel version via armbian-config.
My board(not orangepi tho) also had a kernel issue and it was gone after downgrade kernel version to 5.10
This problem was fixed but hasn't been released yet. Once it will be, there won't be any need for searching and switching to older kernels, where this function was still working.
That's great, but my opi zero just broken today😭
I want to buy a new one,but it's too expensive right this time.
I have to wait sometime after it price reduction.
maybe when I habe a new board,I can get the new armbian image with new kernal fixed this problem.😅
thanks for tall me this message!😃
