JonatasPrust Posted May 17, 2022 Posted May 17, 2022 Hi, Nanopi R1 - Kernel and Armbian version: 4.19.62-sunxi #5.92 I have the following problem: If I put the ethernet cable on the interface, and then turn on the nano pi, the interface receives a valid ip. But the problem is, if I start nanopi without the cable connected, and I connect after system boot, the interface does not receive ip configuration. Configs and logs: /etc/network/interfaces: source /etc/network/interfaces.d/* auto eth0 iface eth0 inet dhcp auto eth1 iface eth1 inet static address 10.100.3.1 netmask 255.255.255.0 gateway 10.100.3.1 auto lo iface lo inet loopback up command iptables-restore < /scripts/iptables /scripts/iptables *nat :PREROUTING ACCEPT [120:10027] :INPUT ACCEPT [11:1747] :OUTPUT ACCEPT [24:1848] :POSTROUTING ACCEPT [4:304] -A POSTROUTING -o eth0 -j MASQUERADE COMMIT journalctl -b 0 -u NetworkManager | grep eth0 Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1115] keyfile: add connection /run/NetworkManager/system-connections/eth0.nmconnection (91ae80f1-5092-4e36-8f48-72f86df06873,"eth0") Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1178] device (eth0): state change: unavailable -> disconnected (reason 'connection-assumed', sys-iface-state: 'external') Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1247] device (eth0): Activation: starting connection 'eth0' (91ae80f1-5092-4e36-8f48-72f86df06873) Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1258] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'external') Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1287] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'external') Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1309] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'external') Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1328] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'external') Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1372] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'external') Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1388] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'external') Mar 25 01:38:29 2-0211 NetworkManager[556]: <info> [1648183109.1538] device (eth0): Activation: successful, device activated. Mar 25 01:38:37 2-0211 NetworkManager[556]: <info> [1648183117.8873] device (eth0): carrier: link connected Mar 25 01:39:56 2-0211 NetworkManager[556]: <info> [1648183196.5941] device (eth0): state change: activated -> unavailable (reason 'carrier-changed', sys-iface-state: 'external') Mar 25 01:39:56 2-0211 NetworkManager[556]: <info> [1648183196.7318] device (eth0): carrier: link connected Mar 25 01:39:56 2-0211 NetworkManager[556]: <info> [1648183196.7333] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'external')
Werner Posted May 17, 2022 Posted May 17, 2022 16 minutes ago, JonatasPrust said: 4.19.62-sunxi #5.92 Your firmware is WAY outdated. Resources of Armbian are limited and we can only cover the most recent version of Armbian which is 22.02 atm.
