Dennboy Posted May 25, 2022 Share Posted May 25, 2022 Dear maintainers, Guess some device tree issues with neo3 got me into this mess, since rk3328-nanopi-neo3-rev02.dtb is missnig. Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 7 ms (444.3 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 428 bytes read in 6 ms (69.3 KiB/s) 12514638 bytes read in 556 ms (21.5 MiB/s) 30083584 bytes read in 1326 ms (21.6 MiB/s) Failed to load '/boot/dtb/rockchip/rk3328-nanopi-neo3-rev02.dtb' libfdt fdt_check_header(): FDT_ERR_BADMAGIC No FDT memory address configured. Please configure the FDT address via "fdt addr <address>" command. Aborting! Kind regards, Dennis 0 Quote Link to comment Share on other sites More sharing options...
Dennboy Posted May 25, 2022 Author Share Posted May 25, 2022 As a work-around, I managed to reuse dtb-5.10.63-rockchip64/rockchip/rk3328-nanopi-neo3-rev02.dtb from Armbian-21.08 so that I could boot the image again. Just learned that the board is no longer supported, that's probably why the devicetree file got removed. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 25, 2022 Share Posted May 25, 2022 3 hours ago, Dennboy said: Just learned that the board is no longer supported It doesn't have someone https://forum.armbian.com/staffapplications/application/8-single-board-computer-maintainer/ to take care of issues in order to get a better status: https://docs.armbian.com/User-Guide_Board-Support-Rules/ 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 25, 2022 Share Posted May 25, 2022 moved to unsupported 0 Quote Link to comment Share on other sites More sharing options...
TonyMac32 Posted July 10, 2022 Share Posted July 10, 2022 https://github.com/armbian/build/pull/3979 0 Quote Link to comment Share on other sites More sharing options...
