Miltos Posted September 24, 2016 Posted September 24, 2016 After update the firefox does not run making the image for odroid c2 more or less useless...
mrneilypops Posted October 3, 2016 Posted October 3, 2016 Loving armbian on my C2 but Firefox crashes with a segmentation fault. Will Chromium be available any time soon? Regards, Neil
Igor Posted October 5, 2016 Posted October 5, 2016 Known bug, will be fixed (hopefully) in next update.
Ivan Davidov Posted November 27, 2016 Posted November 27, 2016 Hello there! I just installed Armbian on my C2 and unfortunately I found the same Firefox issue after I updated the distribution packages. Is there any new development on the issue or estimated time frame when the issue will be resolved? Thanks!
Christos Posted November 27, 2016 Posted November 27, 2016 Hello there! I just installed Armbian on my C2 and unfortunately I found the same Firefox issue after I updated the distribution packages. Is there any new development on the issue or estimated time frame when the issue will be resolved? Thanks! Arm64 firefox package is broken, you could try this though -> https://forum.armbian.com/index.php/topic/2793-odroid-c2-31479-kernel-videomode-screwed-up/?p=19397
hojnikb Posted November 27, 2016 Posted November 27, 2016 ff 50 works fine under aarch64. tried under ubuntu 16.04 on h5
