yar83 Posted August 18, 2022 Posted August 18, 2022 Hi al!! I managed to find img with which my OPi Zero 2 starts, it's Armbian_22.02.2_Orangepizero2_focal_legacy_4.9.255. But it stops load after first `apt upgrade`. I've freezed kernel with armbian-config. Now I want to use wireguard + nftables. But everytime i'm trying to set wg up I've message: [#] nft -f /dev/fd/63 /dev/fd/63:1:1-26: Error: Could not process rule: Operation not supported ... Quick google search showed something concerning nf_tables module in kernel or something like this. (I'm not an experienced linux user). Is there any chance to set up my OPi Z 2 with wg + nftables? Thanks. 0 Quote
Werner Posted August 18, 2022 Posted August 18, 2022 Not sure if either nftables or wireguard are even available for 4.9.y... 0 Quote
yar83 Posted August 18, 2022 Author Posted August 18, 2022 :~$ lsmod Module Size Used by option 57344 0 usb_wwan 24576 1 option usbserial 65536 2 option,usb_wwan wireguard 147456 0 zram 36864 2 sprdwl_ng 438272 0 sprdbt_tty 40960 2 uwe5622_bsp_sdio 294912 2 sprdbt_tty,sprdwl_ng Looks like wireguard is available. Anyway maybe I can use iptables with this build. 1 Quote
ALIGMSTEN Posted August 18, 2022 Posted August 18, 2022 sudo update-alternatives --set iptables /usr/sbin/iptables-legacy sudo update-alternatives --set ip6tables /usr/sbin/ip6tables-legacy 1 Quote
Igor Posted August 30, 2022 Posted August 30, 2022 On 8/18/2022 at 12:42 PM, yar83 said: Looks like wireguard is available. Yes it is. We provide it for older kernels https://github.com/armbian/build/blob/master/lib/compilation-prepare.sh#L236-L263 0 Quote
