@balbes150Hi, I hope you're doing well. I'm gathering info for OPi800 review. I had not used RK3399 in a long time for desktop. I moved to N2+ instead.
My question. How is it now with the media kernel?
Is everything now integrated for that in all your rk3399 images/media-kernel? Or do I still need a debian image to install the media packages? I'm a bit confused.
Video playback looks good, but I haven't tried any 4k files. Youtube playback ain't perfect. I remember this being better with the media script.
Otherwise the images are pretty good. I tried the 6.0.3. There only on-board wifi wasn't working. The 5.19.6 works great. But haven't gone deep yet.
Thank you for the good work. Cheers.
10 часов назад, NicoD сказал:
Hi. The kernel itself works well with all functions on RK3399 (has patches from LE). For the 1920x1080 video mode, 3399 features are quite enough for full-screen video in Armbian. For full-screen 4k video playback on Armbian there is not enough ffmpeg\HW decoder, but for such modes (4k video), I prefer to use a specialized distribution - LibreELEC, which works great for these purposes.
If  build the latest versions of ffmpeg\mpv\kodi using patches from LE, all HW 4k functions will work in Armbian. I remember that @JMCC was building a test version of these components using the 5.10 kernel and everything worked fine.
VGA does not work on it yet. All functions work on the first version of images with the 5.18.5 kernel (in fact, this is the "legacy" kernel from OPI)
36 минут назад, NicoD сказал:
I don't see OC overlays. Is this possible with your images?
the overlay with extlinux.conf works from a running system. But I doubt the usefulness of this feature for the opi 800.
@balbes150
I'm finishing my research on the OPi800. I wanted to let you know my findings before I make the video.
The best image I tried was Armbian_22.11.0-trunk_Orangepi-800_jammy_current_5.19.16_xfce_desktop.img5.19 Jammy
There I did have an issue with hdmi audio not always working. After a reboot it most of the times is back.
Also I couldn't get 5Ghz wifi working while 2.4Ghz wifi is working well.
This was the error in dmesg
[  230.032015] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection Scarlet-Dekerf 5Ghz failed status code:1!
[  234.585036] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection Scarlet-Dekerf 5Ghz failed status code:1!
[  239.501298] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection Scarlet-Dekerf 5Ghz failed status code:1!
[  244.921950] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection Scarlet-Dekerf 5Ghz failed status code:1!
[  262.054026] unisoc_wifi unisoc_wifi wlan0: sprdwl_report_connection Scarlet-Dekerf 5Ghz failed status code:1!
With Armbian_22.11.0-trunk_Orangepi-800_sid_current_5.18.5_xfce_desktop.img
There is no on-board wifi. I also noticed my 5Ghz wifi dongle drivers aren't installed or working. Works on other armbian devices. It's a realtek 802.11ac
So I again was stuck in 2.4Ghz wifi mode. But then a very old dongle that performs a lot worse than OPi800 2.4Ghz wifi.
I tested the VGA port on this image. VGA does work, dual display works. But there's a problem with the VGA color. It's all yellow. I don't think it's my display, but I haven't used it in a while, so possible.
I still have to test images with kernel 6.0
Here my gathered info until now.
OPi800
Benchmarks
Board              | OS                            | Kernel         | Clockspeeds             | 7z b all cores     | 7z b core small core    | 7z b big core   | NicoD Blender    | Supertuxkart   | Memcpy         | Memset         | SBC-Bench
OPi800               OrangeOS arch xfce4             5.18.5           1.4Ghz A53/1.8Ghz A72     7475                 1283 (core 0)             1906 (core 5)     xxx                7fps
OPi800               Armbian Jammy xfce4             5.19.16          1.4Ghz A53/1.8Ghz A72     7686                 1241 (core 0)             1841 (core 5)     10m11s             7fps                                               http://ix.io/4eiS
OPi800               Armbian Sid xfce4               5.18.5           1.4Ghz A53/1.8Ghz A72     7740                 1253 (core 0)             1844 (core 5)     xxx                7fps
File transfer rates
                   | eMMC read   | eMMC write   | eMMC access time  | sd-read    | sd-write    | USB3 read    | USB3 write     | USB-C read    | USBC-C write
OPi800               244.3 MB/s    165.4 MB/s     0.22 msec           68.4 MB/s    35 MB/s       426.5 MB/s     150.2 MB/s
Temperatures
idle          42C
maxed out     83C
Power consumption
idle        0.55A @ 5.25V
Maxed out   1.55A @ 5.2V
Issue's
Armbian Jammy 5.19   HDMI-audio doesn't always work / No VGA / Problem with 5Ghz wifi(maybe a router problem, don't have it with other devices and rebooted router) 2.4 works well
Armbian Sid 5.18  on-board wifi/bt / Missing 5Ghz usb dongle drivers
Thank you for the great work. It is a nice experience with Jammy 5.19. I installed box64, box86, wine, PPSSPP and tons of games. Runs well for an RK3399. I like that they choose a VGA port instead of dual HDMI. I hope it can be fixed in the future. Cheers.
Also sid 5.18.5 seems to be throttling at 70C while other images don't.
Sid
22:06:30: 1608/1416MHz  5.90  95%   1%  94%   0%   0%   0%  70.0°C
22:06:40: 1608/1416MHz  5.93  85%   1%  83%   0%   0%   0%  69.4°C
22:06:52: 1512/1416MHz  6.02  94%   0%  94%   0%   0%   0%  70.0°C
22:07:07: 1512/1416MHz  6.53  86%   2%  84%   0%   0%   0%  70.6°C
22:07:19: 1608/1416MHz  6.57  89%   1%  88%   0%   0%   0%  68.9°C
22:07:31: 1512/1416MHz  6.63  95%   2%  93%   0%   0%   0%  70.0°C
22:07:41: 1608/1416MHz  6.44  79%   1%  78%   0%   0%   0%  68.9°C
22:07:52: 1800/1416MHz  6.85  99%   2%  96%   0%   0%   0%  68.9°C
22:08:02: 1608/1416MHz  6.88  99%   2%  96%   0%   0%   0%  68.9°C
22:08:12: 1512/1416MHz  6.74  94%   1%  93%   0%   0%   0%  68.9°C
Jammy 5.19
12:15:18: 1800/1416MHz  6.95  99%   2%  95%   0%   0%   1%  68.3°C
12:15:28: 1800/1416MHz  6.95  92%   1%  89%   0%   0%   0%  71.1°C
12:15:38: 1800/1416MHz  6.75  84%   2%  81%   0%   0%   1%  70.0°C
12:15:49: 1800/1416MHz  6.79  83%   1%  81%   0%   0%   0%  72.2°C
12:16:02: 1800/1416MHz  6.98  89%   2%  86%   0%   0%   1%  71.7°C
12:16:14: 1800/1416MHz  6.73  84%   1%  82%   0%   0%   0%  70.6°C
12:16:24: 1800/1416MHz  6.85  97%   3%  92%   0%   0%   1%  71.1°C
12:16:34: 1800/1416MHz  6.88  92%   0%  90%   0%   0%   0%  72.2°C
12:16:44: 1800/1416MHz  6.61  80%   3%  76%   0%   0%   1%  70.0°C
12:16:55: 1800/1416MHz  6.82  99%   2%  95%   0%   0%   1%  69.4°C
12:17:06: 1800/1416MHz  7.07  90%   2%  86%   0%   0%   1%  72.2°C
Jammy 6.0.5 has no hdmi output.
29.10.2022 в 22:19, NicoD сказал:
Check the version with kernel 5.18.
If you configure which device to use by default (for example, through the Volume Control plug-in), I have not seen any problems with switching audio and output to HDMI on all cores.
Have you checked all the images since 5.18 ? There is a difference in them. And it's better to use Ubuntu for tests.
I didn't see any problems with the VGA color. Have you tried running with VGA only ?
The new 6.0.6 images (with Wi-Fi) are still in the build process and will be available on the site only tomorrow.
This was Linux 5.18.5-media and there was no wifi at all here. It was Sid I tried.
The problem is that sometimes HDMI audio isn't there to choose from. Doesn't happen that often. But sometimes it's not there and I have to reboot to have hdmi-audio back. It might be because I'm using a Elgato 4K60 HDMI capture box. I do have issue's with that thing not always working.
Thank you, I'll test a more recent Ubuntu with 5.18. The Sid I tested was the oldest I could find. So there might be the problem. I tried Sid because I had seen great improvements in supertuxkart on BPiM5 with Bullseye. Didn't see that on Sid here.
I will test it again, and also test on my old pentium to see if it's normal there. I didn't try having only VGA running.
I will wait for those before making the video. Now my 5.19.16 Jammy xfce4 image is almost perfect. Everything is running that I want to run. Only the HDMI audio that isn't always there. But that's a minor issue.
I'll also try to build a Buster image from your build script to see if I can use the Media Framework on it. I do miss the perfect video playback on it.
Thank you for the input. Helps a lot. I'll wait at least a day before making the video. Normally I was gonna make it today. Cheers.
I did try to build a Buster image with your script but it never finished. I tried 2 times with the same result.
[ o.k. ] Checking MD5 sum of installed packages [ debsums ]
[ error ] ERROR in function create_rootfs_cache [ functions/cli/cli-entrypoint.sh:108 -> functions/main/default-build.sh:125 -> functions/main/rootfs-image.sh:65 -> functions/rootfs/create-cache.sh:229 -> functions/logging/traps.sh:0 ]
[ error ] MD5 sums check of installed packages failed
[ o.k. ] Process terminated
[ error ] unmount_on_exit() called! [ functions/cli/cli-entrypoint.sh:108 -> functions/main/default-build.sh:125 -> functions/main/rootfs-image.sh:65 -> functions/rootfs/create-cache.sh:229 -> functions/logging/traps.sh:1 -> functions/main/rootfs-image.sh:0 ]
[ o.k. ] Unmounting [ /home/nicod/build/.tmp/rootfs-1dc2499a-f3c6-4fea-a14d-e66babedf043/ ]
[ error ] ERROR in function unmount_on_exit [ functions/cli/cli-entrypoint.sh:108 -> functions/main/default-build.sh:125 -> functions/main/rootfs-image.sh:65 -> functions/rootfs/create-cache.sh:229 -> functions/logging/traps.sh:1 -> functions/main/rootfs-image.sh:26 -> functions/logging/traps.sh:0 ]
[ error ] debootstrap-ng was interrupted
I'll wait for your new images.
Tried the 6.0.6 Jammy xfce4 image.
Wifi works, but again my 5Ghz wifi is unable to connect. 5Ghz dongle works.
I tested Manjaro yesterday and there the 5Ghz works as should.
And also video playback there is perfect. It seems to have hardware accelerated video playback. No screen tearing, no reloads and perfect 1080p youtube and 1440p h264 video files.
So for me Armbian is way better for gaming since I know how to install everything here with armbian-gaming. So I'll show that with gaming.
And Manjaro is a good 2nd image for video playback and light desktop use. Tho more software works on Armbian in my experience.
I hope the media framework can be brought back to life for Armbian on RK3399. I used to love working with it.
Also found out that the strange color on my vga was due to a decaying vga cable. Tried with another cable and it works as it should. Doesn't work on 6.0.6. I think you know that.
Also the on-board speaker doesn't work. But hdmi audio is working on 6.0.6 *** After reboot it's back. So seems sometimes audio devices don't wake up at boot.
Cheers.
8 часов назад, NicoD сказал:
It uses the old 5.18.5 kernel (with a lot of hacks in the code) and the "manual" addition of "presets".  They got the equipment long before us, let's see what happens at least in a few months :)
Due to the simplicity of the packaging and assembly system, they easily take "other people's developments" in different directions and use them at home. But this build system has a big disadvantage (for me) - this system cannot be used in certified conditions, it is a "floating" distribution without a certificate. Such a system can only be used at home, it is not suitable for serious use in corporate settings.
Have you tried Armbian versions with 5.18 kernel ?
The best system for video playback is LibreELEC. Only it has all the most advanced and best for these purposes.  😛
Hmm, everything works for me. But I have seen some problems with turning on the built-in speaker, if you insert and pull it into the 3.5 jack (turning it on/off again solves the problem), perhaps the switch contacts in the connector are not fully restored when pulling out the external connector.
Their kernel is 5.19.15-2
I'll mention they've got the device earlier and are further ahead for now.
I did try the 5.18.5 Sid xfce image and there was no on-board wifi and even my 5Ghz dongle didn't work with it.
5.19.5 and 6.0.6 Jammy xfce were the best images I tried. I'm using my 5Ghz dongle on it and that works. Just only 2.4Ghz with on-board wifi. I do see my 5Ghz network, but can't connect. The same with OPiOS. But works with Manjaro.
I tried LibreElec. OPiRK3399 version. It runs, but no on-board wifi and no sound. So not really useful.
I'm gonna make the video now. Thank you for the great work.
38 минут назад, NicoD сказал:
LE OPiRK3399 version =! LE OPi-800 :)
but there is no LAN yet and you need to manually add firmware and module settings to enable WiFi (USB WiFi should work), I hope to release LE next week with the correction of these bugs.
@jock
Sorry to bother you. I'm testing the OrangePi800, and it doesn't seem to have the media framework working on balbes150 his images. Do you know more about this?
Igor directed me to this -> https://github.com/armbian/build/pull/4098
I'm no developer and have to admit I know little about this.
I used to use the media script on Bionic and after that Buster and that ran great. But had not used RK3399 in a long time for that.
I made a review video, but don't want the info to be outdated in a few days. Cheers.
@NicoD Hello, no bothering at all, I'm happy to help!
That pull request adds the libreelec patches to rockchip64 branch that provide several fixes and multimedia enhancements to mainline kernel so it is possible to use an "almost" mainline ffmpeg/gstreamer for h.264/hevc/vp8/vp9 hardware decoding, DRM fixes, support for 10-bit HDR videos, more DRM planes, etc... etc...
There was an old thread where I provided a ready-to-go mpv executable with hardware acceleration on mainline kernel, but should be rebuilt for recent distros since it is quite old now. It could be a nice idea to try mainline kernel with wayland based desktop environment.
I may build an Opi800 image with kernel 5.19 from that branch, maybe with a fully-fledged KDE, rebuild ffmpeg/mpv and give instructions for a cutting edge test if you think it is reasonable
That is more than reasonable. Would even be fantastic.
I've got a few days. I just need the video to be out before the give away stops.
That is a nice idea. I've never tried wayland on Armbian.
I am now using wayland on Edge2 and VIM4. But without xwayland with GPU acceleration there's not much fun to it. So with a well supported SoC/GPU it must be a lot more fun.
8 часов назад, jock сказал:
The "media" core uses patches from LE, so the core has everything that is in LE for HW video. Only applications\libraries compiled using LE patches (ffmpeg mpv kodi etc) are missing. Previously ,  @JMCC had already built an intermediate test version of all KODI packages using this main kernel and it worked well with HW .
If you have the opportunity (time), it is better to build DEB packages using the latest media-6 kernel, it is now used in LE (and patches from LE are included in this kernel). This will allow, by analogy with the JMC media script, to provide the ability to install HW support for all systems that use the kernel with the necessary patches. The ideal option is to add an extension to the build system that will collect packages (ffmpeg mkv code etc) using the latest LE patches and put them in the Armbian repository. This will allow you to easily install everything you need by any user through regular tools (apt synaptic etc).
@jock By the way, it would be interesting to check the MEDIA core for the rest of the rk3328\3399\3288 etc devices that you have. In the future, can combine their capabilities.
08.11.2022 в 16:54, balbes150 сказал:
All support work has been stopped.
@balbes150 does it mean you've deleted orangepi-800.dtb from your build?
Also wanna ask if it is possible to get Opi4 with your media kernel? cause it doesn't have resolution issues i've been encountering on mainline armbian.
Can it be achieved only by providing right dtb?
Asking cause i was trying to run Armbian_22.11.0-trunk_Orangepi-800_jammy_current_5.19.17.img on Orange Pi 4, everything that i need was working. Bluetooth wasn't. Then apt upgrade erased orangepi-800.dtb, and i had to manually put it back.
6 часов назад, CraftWorld сказал:
There is no longer support for OPI 800 in the media core.
In theory, yes, but I don't have this equipment and I have no idea what it takes.
well, wasn't that hard - all the work was done for me. I've just took your image for Station P1, dts for Orange Pi 800 from your github, dts for OrangePi 4 from armbian github, Then refilled all nodes in  Pi 800s dts with info from Pi 4. only thing that was not building - type c settings, had to cut them off. After that done - got all i need working on OPi 4. (HDMI USB WiFi Bt Ethernet) and no resolution issues with 16:10. Thanks for that.
Slightly off-topic but interesting. Quite a while ago I tested a 16:10 monitor with 1920x1200 resolution on the Station P1 I could not get to work with other kernels than legacy 4.4.y. Which branch did you build against? current or edge?
5.19-media and 6.1-media all of it was curren at the moment of building. 16:10 gave me some head ache - needed to build kernels that allow to specifiy EDID and make specific EDID files. Actually tested only for 1280x800 screen, and only one of them is working totally fine without EDID fix. another one need EDID fix to display cli interface but works okay when it load to login page (but i do believe it's display issue).
Edited by CraftWorld
upd
