belaid38 Posted April 22, 2018 Posted April 22, 2018 On 4/21/2018 at 6:55 PM, balbes150 said: Image update Armbian kernel next 4.17-rc1 20180420 (directory “test” on the website). Now in the mainline kernel works HDMI, USB, wired network. Expand hi it is my test armbian kernel 4.17 with my device wetek play 2 is work fine hdmi work fine ubuntu speeder The graphics interface is running wired network work h/w video is Very heavy sound not work h 1
Reddwarf Posted April 24, 2018 Posted April 24, 2018 Hi all! I wish to run Armbian on a Beelink Mini MXIII (S905 cpu), I have tried several images but the only ones I can get to boot are the ones from S905 directory, is that the only images that CAN run on this box? I really wanted MALI support and I don't care about Kodi so I use the Mate image. WiFi and BT is not working either, can someone please direct med to what modules I need and how to get/install them? I have extracted the correct dtb file from the Android software update for this box so device tree should be correct. I'd like to run Cinnamon desktop, installed it but it runs in SW rendering, a little sluggish but not too bad actually. Would MALI support fix that? EDIT: The install.sh script does not work, is /dev/data supposed to be the internal memory? In my box is is known as /dev/mmcblk0 to gparted.....
belaid38 Posted April 24, 2018 Posted April 24, 2018 hi @balbes150 you can build libreelec s905 with kernel 4.16 or 4.17 . i need test this my device wetek play 2
balbes150 Posted April 27, 2018 Author Posted April 27, 2018 On 4/24/2018 at 3:14 PM, belaid38 said: you can build libreelec s905 with kernel 4.16 or 4.17 . i need test this Expand All the time (work on this is underway). To All Upgrade images 20180426 with kernel 4.17_rc2_-next. 3
Reddwarf Posted April 27, 2018 Posted April 27, 2018 On 4/24/2018 at 1:12 PM, Reddwarf said: Hi all! I wish to run Armbian on a Beelink Mini MXIII (S905 cpu), I have tried several images but the only ones I can get to boot are the ones from S905 directory, is that the only images that CAN run on this box? I really wanted MALI support and I don't care about Kodi so I use the Mate image. WiFi and BT is not working either, can someone please direct med to what modules I need and how to get/install them? I have extracted the correct dtb file from the Android software update for this box so device tree should be correct. I'd like to run Cinnamon desktop, installed it but it runs in SW rendering, a little sluggish but not too bad actually. Would MALI support fix that? EDIT: The install.sh script does not work, is /dev/data supposed to be the internal memory? In my box is is known as /dev/mmcblk0 to gparted..... Expand It is rather annoying when I ask a question and none bother to answer.... is this forum totally abandoned? Balbes150? Anyone?
talraash Posted April 27, 2018 Posted April 27, 2018 On 4/27/2018 at 12:41 PM, Reddwarf said: It is rather annoying when I ask a question and none bother to answer.... is this forum totally abandoned? Balbes150? Anyone? Expand In this topic from 50 pages. i think 5 or more with like you question and answer... On 4/27/2018 at 12:41 PM, Reddwarf said: I have extracted the correct dtb file from the Android software update Expand Correct for you android image, but not for image with kernel 4.9.x for example... On 4/27/2018 at 12:41 PM, Reddwarf said: I really wanted MALI support and I don't care about Kodi Expand Can compositing from popular DE use gles? Or you need mali for some specific use keys(like qt)? 1
Reddwarf Posted April 27, 2018 Posted April 27, 2018 On 4/27/2018 at 1:10 PM, talraash said: In this topic from 50 pages. i think 5 or more with like you question and answer... Correct for you android image, but not for image with kernel 4.9.x for example... Can compositing from popular DE use gles? Or you need mali for some specific use keys(like qt)? Expand I did not find any posts about Beelink Mini Mx-III in this or other forums... So where can I find the correct device tree for this box? There are some links to yadi.sk but all are dead or does not contain ant relevant dtb... What do you mean by "DE use gles"? I thought Mali support would enable Cinnamon to run in HW acceleration. What about the script to instaall to internal memory?
talraash Posted April 27, 2018 Posted April 27, 2018 On 4/27/2018 at 1:16 PM, Reddwarf said: So where can I find the correct device tree for this box? There are some links to yadi.sk but all are dead or does not contain ant relevant dtb... Expand Specialy for this after img burning you can see boot partition with all necessary DTB, hdmi.sh etc. On 4/27/2018 at 1:16 PM, Reddwarf said: I thought Mali support would enable Cinnamon to run in HW acceleration. Expand What do you mean by acceleration? HW compositing in DE? As i say gles unsuported by all composit managers. If you mean hw acceleration in qt5, it's another difficult task. On 4/27/2018 at 1:16 PM, Reddwarf said: What about the script to instaall to internal memory? Expand Did you try nand_sata_install? Armbian-config? If you have trouble post some error masage, logs or othe important information if you want help.
Reddwarf Posted April 27, 2018 Posted April 27, 2018 On 4/27/2018 at 2:06 PM, talraash said: Specialy for this after img burning you can see boot partition with all necessary DTB, hdmi.sh etc. What do you mean by acceleration? HW compositing in DE? As i say gles unsuported by all composit managers. If you mean hw acceleration in qt5, it's another difficult task. Did you try nand_sata_install? Armbian-config? If you have trouble post some error masage, logs or othe important information if you want help. Expand I may sount like an idiot to you, but I can't find ANY dtb with a name remotely like Beelink Mini MxIII, what is the name for the dtb for my box? I guess it would be HW acceleration in QT since <Cinnamon rely in QT5. What do you mean with DE? There is NO nana_sata script on the image that boots, only install.sh.....
talraash Posted April 27, 2018 Posted April 27, 2018 On 4/27/2018 at 2:44 PM, Reddwarf said: I may sount like an idiot to you, but I can't find ANY dtb with a name remotely like Beelink Mini MxIII, what is the name for the dtb for my box? Expand FAQ in first message "9. If after 7-10 minutes on the monitor not to receive any messages on system startup. Turn off TV box and add in manual in the first partition (FAT) the file "dtb.img". On the media there is a directory dtb from where you can take the files and copy them to the root of the renaming of "dtb.img". Need to pick up the option for the file system will run. Pay attention, after you add\change the dtb file, you need to try to run the system and waiting to run 7-10 minutes. If not happened, repeat with a different dtb file." I would add that you may try all the appropriate soc models of your box and ram volume. On 4/27/2018 at 2:44 PM, Reddwarf said: I guess it would be HW acceleration in QT since <Cinnamon rely in QT5. What do you mean with DE? Expand If you rewrite cinamon DE with gles support...)) https://doc.qt.io/qt-5.10/topics-graphics.html On 4/27/2018 at 2:44 PM, Reddwarf said: There is NO nana_sata script on the image that boots, only install.sh..... Expand Few days ago i install to nand debian 5.41.1 from armbian-config. And you still don't post error massage so i don't know what kind of help you want, sorry if this is rude.
Reddwarf Posted April 27, 2018 Posted April 27, 2018 On 4/27/2018 at 3:32 PM, talraash said: FAQ in first post "9. If after 7-10 minutes on the monitor not to receive any messages on system startup. Turn off TV box and add in manual in the first partition (FAT) the file "dtb.img". On the media there is a directory dtb from where you can take the files and copy them to the root of the renaming of "dtb.img". Need to pick up the option for the file system will run. Pay attention, after you add\change the dtb file, you need to try to run the system and waiting to run 7-10 minutes. If not happened, repeat with a different dtb file." If you rewrite cinamon DE with gles support...)) https://doc.qt.io/qt-5.10/topics-graphics.html And you still don't post error massage. Few days ago i install to nand debian 5.41.1 from armbian-config. Expand Yeah, well, that particular image won't boot on the Beelink Mini MXIII at all, as I said ONLY the image(s) in S905 folder boots. And are you saying that I should GUESS what dtb is the correct one by trial-end-error? With all of them? And where did you find the nand-sata-install please? I still don't understand what you mean by "DE"....
belaid38 Posted April 27, 2018 Posted April 27, 2018 On 4/27/2018 at 11:31 AM, balbes150 said: All the time (work on this is underway). To All Upgrade images 20180426 with kernel 4.17_rc2_-next. Expand THANX MEN
balbes150 Posted April 28, 2018 Author Posted April 28, 2018 Maybe someone will be interested in this information. http://forum.khadas.com/t/armbian-kodi-ubuntu-debian-for-sd-usb-emmc/825/155?u=balbes150 1
cmetz Posted April 30, 2018 Posted April 30, 2018 On 4/16/2018 at 8:34 AM, balbes150 said: Try out test versions of images with a 4.1x kernel Expand Hi, balbes150, I can get the 4.14.11 and 4.17.0-rc2-next images to boot using the p201 dtb. When I do so, although the kernel detects the ethernet PHY and its state correctly, when I configure eth0 with an IP address, it still can't actually talk with the network. This works fine with the 3.14 kernel. Do you have any suggestions about how I can debug this?
balbes150 Posted April 30, 2018 Author Posted April 30, 2018 On 4/30/2018 at 12:04 AM, cmetz said: I can get the 4.14.11 and 4.17.0-rc2-next images to boot using the p201 dtb. When I do so, although the kernel detects the ethernet PHY and its state correctly, when I configure eth0 with an IP address, it still can't actually talk with the network. This works fine with the 3.14 kernel. Do you have any suggestions about how I can debug this? Expand You may need to try to build a new DTB using the correct settings for the 100Mb network (e.g. take them from the p212 model).
Reddwarf Posted May 3, 2018 Posted May 3, 2018 On 4/30/2018 at 8:15 AM, balbes150 said: You may need to try to build a new DTB using the correct settings for the 100Mb network (e.g. take them from the p212 model). Expand Apropos DTB, is there an overview somewhere of what device the various dtb's are for? I'v been trying to guess from the ubuntu-mate images in mali5 directory but I'm at loss.... Edit: I often get this message: Processing triggers for initramfs-tools (0.122ubuntu8.11) ... ln: failed to create hard link '/boot/initrd.img-3.14.29.dpkg-bak' => '/boot/initrd.img-3.14.29': Operation not permitted Is that a showstopper?
David Markey Posted May 5, 2018 Posted May 5, 2018 Any way to get the simple iptv client working here with the armbian kodi builds?
Gonzalo Posted May 5, 2018 Posted May 5, 2018 Hi! Can you add Wireguard support in kernel? seems to be missing some lines in defconfig like : Reveal hidden contents CONFIG_NETFILTER_NETLINK=y CONFIG_NETFILTER_NETLINK_QUEUE=y CONFIG_NETFILTER_NETLINK_LOG=y CONFIG_NF_CT_NETLINK=y CONFIG_SCSI_NETLINK=y CONFIG_IP_ADVANCED_ROUTER=y CONFIG_NET_SCH_INGRESS=y CONFIG_NET_SCHED=y CONFIG_IP_MULTIPLE_TABLES=y CONFIG_NETFILTER_XT_TARGET_MARK=y and others Also i have a issue with kodi, i can use the Desktop, and do anything perfectly at 1080p, but when i tried to open kodi at 1080p, it crashed At 720p works good, all fine i also tried several versions of armbian, same result. Crash log: Reveal hidden contents ############## Kodi CRASH LOG ############### ################ SYSTEM INFO ################ Date: Sat May 5 13:13:50 UTC 2018 Kodi Options: Arch: aarch64 Kernel: Linux 3.14.29 #16 SMP PREEMPT Fri Apr 6 14:53:29 MSK 2018 Release: Ubuntu 16.04.4 LTS (Xenial Xerus) ############## END SYSTEM INFO ############## ############### STACK TRACE ################# gdb not installed, can't get stack trace. ############# END STACK TRACE ############### ################# LOG FILE ################## 13:13:49.943 T:547614097408 NOTICE: special://profile/ is mapped to: special://masterprofile/ 13:13:49.943 T:547614097408 NOTICE: ----------------------------------------------------------------------- 13:13:49.943 T:547614097408 NOTICE: Starting Kodi (17.6 Git:20171117-094825c). Platform: Linux ARM 64-bit 13:13:49.943 T:547614097408 NOTICE: Using Release Kodi x64 build 13:13:49.943 T:547614097408 NOTICE: Kodi compiled Mar 3 2018 by GCC 5.4.0 for Linux ARM 64-bit version 4.4.98 (263266) 13:13:49.943 T:547614097408 NOTICE: Running on Ubuntu 16.04.4 LTS, kernel: Linux ARM 64-bit version 3.14.29 13:13:49.943 T:547614097408 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi 13:13:49.943 T:547614097408 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available 13:13:49.943 T:547614097408 NOTICE: ARM Features: Neon disabled 13:13:49.943 T:547614097408 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi 13:13:49.943 T:547614097408 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi 13:13:49.943 T:547614097408 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons 13:13:49.943 T:547614097408 NOTICE: special://masterprofile/ is mapped to: /home/gonzalo/.kodi/userdata 13:13:49.943 T:547614097408 NOTICE: special://envhome/ is mapped to: /home/gonzalo 13:13:49.943 T:547614097408 NOTICE: special://home/ is mapped to: /home/gonzalo/.kodi 13:13:49.943 T:547614097408 NOTICE: special://temp/ is mapped to: /home/gonzalo/.kodi/temp 13:13:49.943 T:547614097408 NOTICE: special://logpath/ is mapped to: /home/gonzalo/.kodi/temp 13:13:49.943 T:547614097408 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin 13:13:49.943 T:547614097408 NOTICE: Local hostname: amlogic 13:13:49.943 T:547614097408 NOTICE: Log File is located: /home/gonzalo/.kodi/temp//kodi.log 13:13:49.943 T:547614097408 NOTICE: ----------------------------------------------------------------------- 13:13:50.019 T:547614097408 NOTICE: load settings... 13:13:50.019 T:547614097408 NOTICE: AML device detected 13:13:50.066 T:547614097408 NOTICE: Found 1 Lists of Devices 13:13:50.067 T:547614097408 NOTICE: Enumerated PULSE devices: 13:13:50.067 T:547614097408 NOTICE: Device 1 13:13:50.067 T:547614097408 NOTICE: m_deviceName : Default 13:13:50.067 T:547614097408 NOTICE: m_displayName : Default 13:13:50.067 T:547614097408 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO) 13:13:50.067 T:547614097408 NOTICE: m_deviceType : AE_DEVTYPE_PCM 13:13:50.067 T:547614097408 NOTICE: m_channels : FL,FR 13:13:50.067 T:547614097408 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000 13:13:50.067 T:547614097408 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT 13:13:50.067 T:547614097408 NOTICE: m_streamTypes : No passthrough capabilities 13:13:50.067 T:547614097408 NOTICE: Device 2 13:13:50.067 T:547614097408 NOTICE: m_deviceName : alsa_output.platform-aml_m8_snd.46.analog-stereo 13:13:50.067 T:547614097408 NOTICE: m_displayName : AML-M8AUDIO Analog Stereo 13:13:50.067 T:547614097408 NOTICE: m_displayNameExtra: Analog Output (PULSEAUDIO) 13:13:50.067 T:547614097408 NOTICE: m_deviceType : AE_DEVTYPE_PCM 13:13:50.067 T:547614097408 NOTICE: m_channels : FL,FR 13:13:50.067 T:547614097408 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000 13:13:50.067 T:547614097408 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT 13:13:50.067 T:547614097408 NOTICE: m_streamTypes : No passthrough capabilities 13:13:50.075 T:547614097408 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml) 13:13:50.075 T:547614097408 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 13:13:50.075 T:547614097408 NOTICE: Default Video Player: VideoPlayer 13:13:50.075 T:547614097408 NOTICE: Default Audio Player: paplayer 13:13:50.076 T:547614097408 NOTICE: Disabled debug logging due to GUI setting. Level 0. 13:13:50.076 T:547614097408 NOTICE: Log level changed to "LOG_LEVEL_NORMAL" 13:13:50.076 T:547614097408 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 13:13:50.076 T:547614097408 NOTICE: Loaded playercorefactory configuration 13:13:50.077 T:547614097408 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 13:13:50.077 T:547614097408 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 13:13:50.091 T:547614097408 NOTICE: Running database version Addons27 13:13:50.165 T:547614097408 NOTICE: ADDONS: Using repository repository.xbmc.org 13:13:50.184 T:547588435920 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 192 ms 13:13:50.229 T:547614097408 ERROR: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq 13:13:50.229 T:547614097408 ERROR: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq 13:13:50.229 T:547614097408 ERROR: AML: no rw on /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor 13:13:50.236 T:547614097408 NOTICE: InitWindowSystem: Using EGL Implementation: amlogic 13:13:50.256 T:547614097408 ERROR: EGL error in InitDisplay: 3003 13:13:50.256 T:547614097408 ERROR: InitWindowSystem: Could not create display 13:13:50.256 T:547614097408 FATAL: CApplication::Create: Unable to init windowing system ############### END LOG FILE ################ ############ END Kodi CRASH LOG ############# I can take dmesg or logcat if helps One more thing, can u upload an overclocked cpu version? i use in my tvbox a fan+heatskin, and it doesnt up more than 30ºC, i think it can go faster Im using a A95X R2 box, with gxl_p212_2g.dtb-A95Xr2-2G-16G dtb and now im at Armbian_5.41.1_S9xxx_Ubuntu_xenial_3.14.29_mate_20180406 p.s: one more thing, i have a rf keyboard like this and works properly on Ubuntu, all the keys do their function but on kodi, none of the keyboards letters works, they does nothing only numbers file works, like an onld T9 keyboard i think it is caused by the remote control interface of kodi, that thinks im using and old keyboard any solution for that? thanks in advance!;)
balbes150 Posted May 8, 2018 Author Posted May 8, 2018 On 5/3/2018 at 10:35 AM, Reddwarf said: I often get this message: Expand Do you run any commands at the same time ? On 5/5/2018 at 6:16 PM, Gonzalo said: Also i have a issue with kodi, i can use the Desktop, and do anything perfectly at 1080p, but when i tried to open kodi at 1080p, it crashed At 720p works good, all fine i also tried several versions of armbian, same result. Crash log: Expand What version of KODI is used and what image is used ? What processor is in the TV box ? On 5/5/2018 at 6:16 PM, Gonzalo said: One more thing, can u upload an overclocked cpu version? i use in my tvbox a fan+heatskin, and it doesnt up more than 30ºC, i think it can go faster Expand To do this, you must build a new version of BL31. On 5/5/2018 at 6:16 PM, Gonzalo said: p.s: one more thing, i have a rf keyboard like this and works properly on Ubuntu, all the keys do their function but on kodi, none of the keyboards letters works, they does nothing only numbers file works, like an onld T9 keyboard i think it is caused by the remote control interface of kodi, that thinks im using and old keyboard any solution for that? thanks in advance!;) Expand Use Libreelec. Armbian is a desktop with A minimal Kodi version.
Reddwarf Posted May 8, 2018 Posted May 8, 2018 On 5/8/2018 at 7:40 AM, balbes150 said: Do you run any commands at the same time ? What version of KODI is used and what image is used ? What processor is in the TV box ? To do this, you must build a new version of BL31. Use Libreelec. Armbian is a desktop with A minimal Kodi version. Expand @balbes150 No I just run "sudo apt-get upgrade" when I get this error. What about overview of the dtb's? I use a Beelink Mini MXIII with 905 cpu.
Moklev Posted May 8, 2018 Posted May 8, 2018 On 5/5/2018 at 12:21 PM, David Markey said: Any way to get the simple iptv client working here with the armbian kodi builds? Expand Have you tried to build it? git clone https://github.com/xbmc/xbmc.git git clone https://github.com/kodi-pvr/pvr.iptvsimple.git cd pvr.iptvsimple && mkdir build && cd build cmake -DADDONS_TO_BUILD=pvr.iptvsimple -DADDON_SRC_PREFIX=../.. -DCMAKE_BUILD_TYPE=Debug -DCMAKE_INSTALL_PREFIX=../../xbmc/addons -DPACKAGE_ZIP=1 ../../xbmc/cmake/addons make
balbes150 Posted May 8, 2018 Author Posted May 8, 2018 Image Armbian upgrade. 3.14_20180507 and 4.16_20180508.Images are in the directory "no-mali". Pay attention. These images do not have libMali. The latest version of Armbian 3.14_20180507 and 4.16_20180508 uses KODI without libMali, so it can run on all s905 and s912 models, but without Appart acceleration.
balbes150 Posted May 8, 2018 Author Posted May 8, 2018 On 5/8/2018 at 8:00 AM, Reddwarf said: What about overview of the dtb's? Expand The dtb file name contains all the necessary information. For which platform, how much RAM, type of network, etc. some have an indication of a particular TV box model. 1
Reddwarf Posted May 11, 2018 Posted May 11, 2018 On 5/8/2018 at 10:34 AM, balbes150 said: The dtb file name contains all the necessary information. For which platform, how much RAM, type of network, etc. some have an indication of a particular TV box model. Expand I found those filenames hard to decode unless you are very familiar with the hardware. Just yesterday I learned the board model of my Mini MXIII, but unless you KNOW that there is no clue in the filename which dtb goes to what tv box. I'm just saying it could be done much more clear, ie a table of known boxes and a reference to which dtb would be of great help.
balbes150 Posted May 11, 2018 Author Posted May 11, 2018 On 5/11/2018 at 6:56 AM, Reddwarf said: I'm just saying it could be done much more clear, ie a table of known boxes and a reference to which dtb would be of great help. Expand Do and everyone will thank you. p.s. All waiting for the "good uncle", just make the whole system, collect a kernel with support for all the hardware, write a good and detailed instructions for each scenario.
Reddwarf Posted May 13, 2018 Posted May 13, 2018 On 5/11/2018 at 9:22 AM, balbes150 said: Do and everyone will thank you. Expand Yeah, I would if I had a clue. Someone must have invented those names, and that someone would be the right person to make an explanation for them. Another question, why are the modules from Android not compatible with Armbian? I'v tried to take some modules from the box's Android and insert into Armbian but the error message says that the module has the wrong format...
Fozzy Posted May 13, 2018 Posted May 13, 2018 @balbes150, hello ! What build is the most suitable for daily use, just install, setup and forget about it for months :) ? 1
Reddwarf Posted May 13, 2018 Posted May 13, 2018 On 5/13/2018 at 8:32 AM, Fozzy said: @balbes150, hello ! What build is the most suitable for daily use, just install, setup and forget about it for months :) ? Expand It might be easier for him to answer if you tell us what hardware you are running and what you intend to use it for...
Fozzy Posted May 13, 2018 Posted May 13, 2018 On 5/13/2018 at 9:02 AM, Reddwarf said: It might be easier for him to answer if you tell us what hardware you are running and what you intend to use it for... Expand and @balbes150 Nexbox A95x 1/8 gb. I want to install server apps on it like owncloud, samba, and turn it on for 24/7. And sometimes watch videos from it. The requirements are: 1. Stable build. 2. HW video acceleration. 3. Working HDMI and usb ports.
Reddwarf Posted May 13, 2018 Posted May 13, 2018 I have managed to run the Mate edition from Mali-5 directory stable on my Mini MXIII and got sound, ethernet and wifi working. If you are gonna watch videos I don't think a server edition will do, I think you need a GUI with X support. I'm not familiar with Nexbox A95 but you could try the same image and find the correct dtb. If it runs I can provide instructions for getting wifi working, but I haven't managed to get Bluetooth working yet. Edit: Only one USB port is working so far but you can connect a powered hub and connect more devices.
