pisach Posted May 28, 2018 Posted May 28, 2018 On 4/8/2017 at 5:16 PM, tkaiser said: With latest commits nand-sata-install should also be much more reliable when running on a system with typical services installed. See at the end of http://sprunge.us/FGOD  Requires the following of course the next few weeks: wget -O- "https://raw.githubusercontent.com/igorpecovnik/lib/master/scripts/nand-sata-install/usr/lib/nand-sata-install/nand-sata-install.sh" >/usr/sbin/nand-sata-install Hi tkaiser, I'm trying to run X96 mini from eMMC. I followed the general instructions: su - (enter passwd root) ./install.sh or nand_sata_install But after reboot (without SD card) nothing happened, blank screen, no boot at all. I managed to recover the main Android image from a backup and the devices started to boot again. Then I downloaded the script from here and started it. They were quite a lot errors, but on the end it said "Shut down". After the shutdown the LED turned to red (from blue)...forever :-) After multiple attempts to recover it, I connected to the UART port and I saw these messages: BL2 Built : 14:59:36, Aug 9 2017. gxl ge8c6a83 - xiaobo.gu@droid12 set vdd cpu_a to 1120 mv set vdd cpu_b to 1050 mv set vddee to 1000 mv Board ID = 2 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0+1 @ 912MHz - FAIL DDR4 chl: Rank0+1 @ 1008MHz - FAIL DDR init failed... Reset... GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 122007 I have a feeling that from that point the device is unbrickable..but I have two more :-) The question is what I did wrong with the install on eMMC? Thank you!
MeJune Posted May 28, 2018 Posted May 28, 2018 Hello I have tested Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515.img. I can not use wifi network. I tried to use command "modprobe wifi_dummy" as it used to work with previous versions, but this image was not successful. Have tested with the version Armbian_5.44_S9xxx_Debain_stretch_3.14.29_xfce.img and not as successful. Can anyone tell me how to solve this problem? Thanks in advance
pisach Posted May 28, 2018 Posted May 28, 2018 1 minute ago, chaijate said: I have tested Armbian_5.44_S9xxx_Ubuntu_xenial_3.14.29_mate_20180515.img. I can not use wifi network. I tried to use command "modprobe wifi_dummy" as it used to work with previous versions, but this image was not successful. Have tested with the version Armbian_5.44_S9xxx_Debain_stretch_3.14.29_xfce.img and not as successful. Can anyone tell me how to solve this problem? Thanks in advance what is the model of the TV box?
MeJune Posted May 28, 2018 Posted May 28, 2018 2 minutes ago, pisach said: what is the model of the TV box? mecool M8S pro Amlogic S912 (3/32GB)
pisach Posted May 28, 2018 Posted May 28, 2018 mecool M8S pro has SV6051 WiFi. You need to do the following: ln -s /lib/firmware /usr/lib/firmware modprobe ssv6051 add ssv6051 in /etc/modules reboot
MeJune Posted May 28, 2018 Posted May 28, 2018 @pisach Thank you very much. This will return home to test the machine at home. There is another question, I have a searh package in synaptic, which is very long time. Do you know this problem? Thank again.
balbes150 Posted May 28, 2018 Author Posted May 28, 2018 2 hours ago, pisach said: I have a feeling that from that point the device is unbrickable..but I have two more :-) The question is what I did wrong with the install on eMMC? On TV boxes can not use the official script nand-sata-install. It is not working properly and destroys the system. You have destroyed the u-boot and now, to restore, you have to close the contacts on the eMMC chip, that would block not the correct u-boot. In my images there is no NAND-sata-install script. This is actually a symbolic link to the script /root/install.sh. 3 hours ago, Reddwarf said: So a 450 is a Mail-5 GPU? I'm having problems with the images, no matter what version I run from Mali5 directory it gets more and more sluggish and eventually freezes after some 10-15 minutes. Where should I look for error messages or other signs of what goes south? mali-5 mali-6 mali-7 , this is the libMali library version. All these versions are designed for Mali-450.
balbes150 Posted May 28, 2018 Author Posted May 28, 2018 On 5/26/2018 at 1:46 PM, KimLee said: Does anyone have an idea to help me to use the Kernel 4.16.1 please ? Select the correct dtb file.
balbes150 Posted May 28, 2018 Author Posted May 28, 2018 15 hours ago, Marco345 said: Does anybody anyone have any idea? This version does not support eMMC.
pisach Posted May 28, 2018 Posted May 28, 2018 12 minutes ago, balbes150 said: you have to close the contacts on the eMMC chip Hi bables150, yes, I had doubts and bad feelings before to run the script :-) Is there some how-to reset the eMMC chip? Here is the board: https://cdn-images-1.medium.com/max/1600/1*NJSv0Fu6wfB4qFjrTTjmFg.png The eMMC chip seems to not have exposed any pins. They're some interesting connectors on the right side of the NAND, below the UART, but I don't know.... Thank you!
Reddwarf Posted May 28, 2018 Posted May 28, 2018 21 minutes ago, balbes150 said: mali-5 mali-6 mali-7 , this is the libMali library version. All these versions are designed for Mali-450. Ah thanks a lot Any idea what to look for with reg. to system slowing down and freezing or is this a known issue?
balbes150 Posted May 28, 2018 Author Posted May 28, 2018 37 minutes ago, pisach said: The eMMC chip seems to not have exposed any pins. They're some interesting connectors on the right side of the NAND, below the UART, but I don't know.... Look for information on the brand of the chip (if you're lucky) or ask the supplier. 35 minutes ago, Reddwarf said: Ah thanks a lot Any idea what to look for with reg. to system slowing down and freezing or is this a known issue? There can be many reasons, from incorrect dtb to banal overheating.
pisach Posted May 28, 2018 Posted May 28, 2018 2 minutes ago, balbes150 said: Look for information on the brand of the chip (if you're lucky) or ask the supplier. Actually I'm more interested how to run this box from the eMMC. Why if doesn't work on TV boxes? Is there a separate how-to for TV boxes? The rest works just fine, I'm very satisfied...again thanks!
Reddwarf Posted May 28, 2018 Posted May 28, 2018 41 minutes ago, balbes150 said: Look for information on the brand of the chip (if you're lucky) or ask the supplier. There can be many reasons, from incorrect dtb to banal overheating. Overheating maybe, I think I have the correct dtb, is there a gadget I can install that shows temp. cpu load etc?
balbes150 Posted May 28, 2018 Author Posted May 28, 2018 34 minutes ago, pisach said: Is there a separate how-to for TV boxes?
pisach Posted May 28, 2018 Posted May 28, 2018 3 minutes ago, balbes150 said: This is what I used in the beginning: su - (enter passwd root) ./install.sh or nand_sata_install but it didn't do anything. After the end of the script, I stopped the box, removed the card and it didn't boot, just blank screen. After that I managed to restore from backup.
MeJune Posted May 28, 2018 Posted May 28, 2018 5 hours ago, pisach said: mecool M8S pro has SV6051 WiFi. You need to do the following: ln -s /lib/firmware /usr/lib/firmware modprobe ssv6051 add ssv6051 in /etc/modules reboot Unsuccess ~~~~ It's not work. I searched the M8S Pro wifi chipset from the internet. It is labeled as WiFi Chip: QCA9377.http://www.fn-link.com/a-b-g-n-ac-wi-fi-bt-module/8223a-sr.html
jeanrhum Posted May 28, 2018 Posted May 28, 2018 2 hours ago, Reddwarf said: Overheating maybe, I think I have the correct dtb, is there a gadget I can install that shows temp. cpu load etc? You should use armbianmonitor command (look at the doc for the options, i don't remeber them) or directly run: cat /sys/class/thermal/thermal_zone*/temp
balbes150 Posted May 28, 2018 Author Posted May 28, 2018 34 minutes ago, chaijate said: It is labeled as WiFi Chip: QCA9377. modprobe wlan
MeJune Posted May 28, 2018 Posted May 28, 2018 17 minutes ago, balbes150 said: modprobe wlan  Thank you very much 21 minutes ago, balbes150 said: modprobe wlan  It's work ..... thank you very much @balbes150. You are exellent!
pisach Posted May 28, 2018 Posted May 28, 2018 9 hours ago, balbes150 said: Look for information on the brand of the chip (if you're lucky) or ask the supplier.  There can be many reasons, from incorrect dtb to banal overheating. After I shorter some pins I managed to get to U-boot from the UART. A'm not very familiar with U-boot. Could you tell me what is the fastest way to recover the device from here? U-Boot 2015.01-g2d1a155-dirty (Oct 08 2017 - 12:02:50) aarch64-none-elf-gcc (crosstool-NG linaro-1.13.1-4.8-2013.11 - Linaro GCC 2013.10) 4.8.3 20131111 (prerelease) GNU ld (crosstool-NG linaro-1.13.1-4.8-2013.11 - Linaro GCC 2013.10) 2.23.2.20130610 Linaro 2013.10-4 Thanks!
pisach Posted May 28, 2018 Posted May 28, 2018 1 hour ago, pisach said: Could you tell me what is the fastest way to recover the device from here?  He, fixed! I used "Burn Card Maker" with which I burned a stock FW on SD card and somehow it flashed the TV box. Now I can go to bed :-)
MeJune Posted May 29, 2018 Posted May 29, 2018 @balbes150 sorry again. Yesterday i used the "modprobe wlan" command, which it works. But after I added the wlan into file /etc/modules and reboot again. I Can't see any wifi anymore. I tried to help myself. But it was not successful. Do you have any recommendations for this?
balbes150 Posted May 29, 2018 Author Posted May 29, 2018 13 minutes ago, chaijate said: sorry again. Yesterday i used the "modprobe wlan" command, which it works. But after I added the wlan into file /etc/modules and reboot again. I Can't see any wifi anymore. I tried to help myself. But it was not successful. Do you have any recommendations for this? Look at the topic on the link, the user describes a similar problem and its solution.
pisach Posted May 29, 2018 Posted May 29, 2018 (edited) On 5/28/2018 at 1:32 PM, balbes150 said:  Hi, it's again me. From my point if view the install.sh script doesn't work..at least for my device. Here is the output from the script: root@amlogic:~# ./install.sh Start copy system for DATA partition. Formatting DATA partition... umount: /dev/data: not mounted /dev/data contains a ext4 file system last mounted on /data on Thu Jan 1 00:00:10 2015 Suggestion: Use Linux kernel >= 3.18 for improved stability of the metadata and journal checksum features. e2fsck 1.43.4 (31-Jan-2017) /dev/data: clean, 11/767040 files, 74788/3066368 blocks done. Copying ROOTFS. Copy BIN Copy BOOT Create DEV ... ... Copy VAR Copy fstab ******************************************* Done copy ROOTFS ******************************************* Writing new kernel image... 65536+0 records in 65536+0 records out 33554432 bytes (34 MB, 32 MiB) copied, 0.78898 s, 42.5 MB/s writing boot image config in bootimg.cfg extracting kernel in zImage extracting ramdisk in initrd.img reading kernel from /boot/zImage Writing Boot Image /dev/boot reading ramdisk from /boot/initrd.img-3.14.29 Writing Boot Image /dev/boot done. Writing new dtb ... done. Write env bootargs ******************************************* Complete copy OS to eMMC parted DATA ******************************************* root@amlogic:~# Here is the boot: Spoiler BL2 Built : 11:04:41, Jan 26 2018. gxl g034b32c - xingyu.chen@droid12-sz set vcck to 1120 mv set vddee to 1070 mv Board ID = 2 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0 16bit @ 792MHz bist_test rank: 0 20 00 40 3d 1c 5e 24 00 48 40 1b 65 35 35 35 34 34 34 34 34 34 35 35 35 590 Rank0: 2048MB(auto)-2T-11 AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x0002c600 Load bl33 from eMMC, src: 0x00050200, des: 0x01000000, size: 0x00065e00 NOTICE: BL3-1: v1.0(release):35dd647 NOTICE: BL3-1: Built : 15:20:30, Feb 7 2018 [BL31]: GXL CPU setup! NOTICE: BL31: BL33 decompress pass mpu_config_enable:ok [Image: gxl_v1.1.3243-377db0f 2017-09-07 11:28:58 qiufang.dai@droid07] OPS=0xa4 6 2b b9 5f 9b 22 35 59 c8 9e e9 69 [0.401203 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast U-Boot 2015.01-gd4767ac-dirty (Mar 02 2018 - 09:52:42) DRAM: 2 GiB Relocation Offset is: 76eb3000 register usb cfg[0][1] = 0000000077f5aa08 [CANVAS]canvas init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000073eb36b0 aml_priv->desc_buf = 0x0000000073eb59d0 SDIO Port B: 0, SDIO Port C: 1 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 init_part() 293: PART_TYPE_AML [mmc_init] mmc init success dtb magic edfe0dd0 Amlogic multi-dtb tool Single dtb detected start dts,buffer=0000000073eb8200,dt_addr=0000000073eb8200 Amlogic multi-dtb tool Single dtb detected parts: 11 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: instaboot 0000000020000000 1 07: boot 0000000002000000 1 08: system 0000000040000000 1 09: cache 0000000020000000 2 10: data ffffffffffffffff 4 init_part() 293: PART_TYPE_AML eMMC/TSD partition table have been checked OK! check pattern success mmc env offset: 0x27400000 In: serial Out: serial Err: serial reboot_mode=cold_boot [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-917: calc 9123433c, store 9123433c _verify_dtb_checksum()-917: calc 9123433c, store 9123433c dtb_read()-1039: total valid 2 dtb_read()-1106: do nothing Amlogic multi-dtb tool Single dtb detected vpu: clk_level in dts: 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) vpu: vpu_clk_gate_init_off vpp: vpp_init hpd_state=0 cvbs performance type = 6, table = 0 Net: dwmac.c9410000amlkey_init() enter! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 Start read misc partition datas! info->attemp_times = 0 info->active_slot = 0 info->slot_info[0].bootable = 1 info->slot_info[0].online = 1 info->slot_info[1].bootable = 0 info->slot_info[1].online = 0 info->attemp_times = 0 attemp_times = 0 active slot = 0 wipe_data=successful wipe_cache=successful upgrade_step=0 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x7d851000 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x7d851000 [CANVAS]addr=0x7d851000 width=3840, height=2160 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet gpio: pin GPIOAO_2 (gpio 102) value is 1 saradc - saradc sub-system Usage: saradc saradc open <channel> - open a SARADC channel saradc close - close the SARADC saradc getval - get the value in current channel saradc test - test the SARADC by channel-7 saradc get_in_range <min> <max> - return 0 if current value in the range of current channel InUsbBurn noSof Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** card out emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 Err imgread(L252):Fmt unsupported!genFmt 0x0 != 0x3 InUsbBurn noSof emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 [MSG]mmcinfo failed! emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 emmc/sd response timeout, cmd1, status=0x1ff2800 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 0 ** ee_gate_off ... ## Booting Android Image at 0x01080000 ... reloc_addr =73f383d0 copy done Kernel command line: buildvariant=userdebug load dtb from 0x1000000 ...... Amlogic multi-dtb tool Single dtb detected Uncompressing Kernel Image ... OK kernel loaded at 0x01080000, end = 0x021dd470 Loading Ramdisk to 73974000, end 73ea0252 ... OK Loading Device Tree to 000000001fff3000, end 000000001ffffef6 ... OK signature: fdt_instaboot: no instaboot image Starting kernel ... uboot time: 5934040 us domain-0 init dvfs: 4 It seems it doesn't see the boot partition on the eMMC. Are the any other steps? Thanks! Edited May 31, 2018 by Tido added spoiler
balbes150 Posted May 30, 2018 Author Posted May 30, 2018 9 hours ago, pisach said: It seems it doesn't see the boot partition on the eMMC. Are the any other steps? The script works correctly. All data is written to the eMMC without errors. When launched from the eMMC, the new kernel is loaded without errors and started. The reason is dtb data. This is the behavior I see when dtb data is incorrect (the kernel cannot start correctly). What dtb is used when starting from SD card ?
pisach Posted May 30, 2018 Posted May 30, 2018 22 minutes ago, balbes150 said: What dtb is used when starting from SD card ? I didn't modify anything. It's running fine from the SD card and I expected everything to be copied on the eMMC and to work in the same way from here. The tv box installed with gxl_p212_2g.dtb. Should I somehow reinstall it on the eMMC? Thanks!
balbes150 Posted May 30, 2018 Author Posted May 30, 2018 49 minutes ago, pisach said: I didn't modify anything. It's running fine from the SD card and I expected everything to be copied on the eMMC and to work in the same way from here. The tv box installed with gxl_p212_2g.dtb. Should I somehow reinstall it on the eMMC? Show system startup log from external media
MeJune Posted May 30, 2018 Posted May 30, 2018 22 hours ago, balbes150 said: Look at the topic on the link, the user describes a similar problem and its solution. Thank you very much.
pisach Posted May 30, 2018 Posted May 30, 2018 (edited) On 5/30/2018 at 9:29 AM, balbes150 said: Show system startup log from external media Spoiler root@amlogic:~# reboot [58149.573980@0] reboot: Restarting system(systemd-shutdow) bl31 reboot reason: 0xd bl31 reboot reason: 0x1 system cmd 1. GXL:BL1:9ac50e:bb16dc;FEAT:ADFC318C:0;POC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0; TE: 105985 BL2 Built : 11:04:41, Jan 26 2018. gxl g034b32c - xingyu.chen@droid12-sz set vcck to 1120 mv set vddee to 1070 mv Board ID = 2 CPU clk: 1200MHz DQS-corr enabled DDR scramble enabled DDR3 chl: Rank0 16bit @ 792MHz bist_test rank: 0 1f 00 3f 3a 1a 5b 23 00 47 3f 1c 62 35 35 35 34 34 34 33 33 33 33 33 33 601 Rank0: 2048MB(auto)-2T-11 AddrBus test pass! -s Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000 New fip structure! Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600 Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x0002c600 Load bl33 from eMMC, src: 0x00050200, des: 0x01000000, size: 0x00065e00 NOTICE: BL3-1: v1.0(release):35dd647 NOTICE: BL3-1: Built : 15:20:30, Feb 7 2018 [BL31]: GXL CPU setup! NOTICE: BL31: BL33 decompress pass mpu_config_enable:ok [Image: gxl_v1.1.3243-377db0f 2017-09-07 11:28:58 qiufang.dai@droid07] OPS=0xa4 6 2b b9 5f 9b 22 35 59 c8 9e e9 69 [0.383751 Inits done] secure task start! high task start! low task start! ERROR: Error initializing runtime service opteed_fast U-Boot 2015.01-gd4767ac-dirty (Mar 02 2018 - 09:52:42) DRAM: 2 GiB Relocation Offset is: 76eb3000 register usb cfg[0][1] = 0000000077f5aa08 [CANVAS]canvas init boot_device_flag : 1 Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc. init bus_cycle=6, bus_timing=7, system=5.0ns reset failed get_chip_type and ret:fffffffe get_chip_type and ret:fffffffe chip detect failed and ret:fffffffe nandphy_init failed and ret=0xfffffff1 MMC: aml_priv->desc_buf = 0x0000000073eb36b0 aml_priv->desc_buf = 0x0000000073eb59d0 SDIO Port B: 0, SDIO Port C: 1 emmc/sd response timeout, cmd8, status=0x1ff2800 emmc/sd response timeout, cmd55, status=0x1ff2800 init_part() 293: PART_TYPE_AML [mmc_init] mmc init success dtb magic 5f4c4d41 Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p281 variant: 2g dtb 0 soc: gxl plat: p281 vari: 1g dtb 1 soc: gxl plat: p281 vari: 2g Find match dtb: 1 start dts,buffer=0000000073eb8200,dt_addr=0000000073ec3200 Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p281 variant: 2g dtb 0 soc: gxl plat: p281 vari: 1g dtb 1 soc: gxl plat: p281 vari: 2g Find match dtb: 1 parts: 10 00: logo 0000000002000000 1 01: recovery 0000000002000000 1 02: rsv 0000000000800000 1 03: tee 0000000000800000 1 04: crypt 0000000002000000 1 05: misc 0000000002000000 1 06: boot 0000000002000000 1 07: system 0000000080000000 1 08: cache 0000000020000000 2 09: data ffffffffffffffff 4 init_part() 293: PART_TYPE_AML eMMC/TSD partition table have been checked OK! check pattern success mmc env offset: 0x27400000 In: serial Out: serial Err: serial reboot_mode=normal [store]To run cmd[emmc dtb_read 0x1000000 0x40000] _verify_dtb_checksum()-917: calc bfc59c13, store bfc59c13 _verify_dtb_checksum()-917: calc bfc59c13, store bfc59c13 dtb_read()-1039: total valid 2 dtb_read()-1106: do nothing Amlogic multi-dtb tool Multi dtb detected Multi dtb tool version: v2 . Support 2 dtbs. aml_dt soc: gxl platform: p281 variant: 2g dtb 0 soc: gxl plat: p281 vari: 1g dtb 1 soc: gxl plat: p281 vari: 2g Find match dtb: 1 vpu: clk_level in dts: 7 vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300) vpu: vpu_clk_gate_init_off vpp: vpp_init hpd_state=0 cvbs performance type = 6, table = 0 Net: dwmac.c9410000amlkey_init() enter! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 Start read misc partition datas! info->attemp_times = 0 info->active_slot = 0 info->slot_info[0].bootable = 1 info->slot_info[0].online = 1 info->slot_info[1].bootable = 0 info->slot_info[1].online = 0 info->attemp_times = 0 attemp_times = 0 active slot = 0 wipe_data=successful wipe_cache=successful upgrade_step=0 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x7f851000 [OSD]load fb addr from dts [OSD]fb_addr for logo: 0x7f851000 [CANVAS]addr=0x7f851000 width=3840, height=2160 amlkey_init() enter! amlkey_init() 71: already init! [EFUSE_MSG]keynum is 4 [BL31]: tee size: 0 [KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet [KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet gpio: pin GPIOAO_2 (gpio 102) value is 1 saradc - saradc sub-system Usage: saradc saradc open <channel> - open a SARADC channel saradc close - close the SARADC saradc getval - get the value in current channel saradc test - test the SARADC by channel-7 saradc get_in_range <min> <max> - return 0 if current value in the range of current channel Hit Enter or space or Ctrl+C key to stop autoboot -- : 0 (Re)start USB... USB0: USB3.0 XHCI init start Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found ** Bad device usb 0 ** ** Bad device usb 1 ** ** Bad device usb 2 ** ** Bad device usb 3 ** card in init_part() 278: PART_TYPE_DOS [mmc_init] mmc init success Device: SDIO Port B Manufacturer ID: 74 OEM: 4a60 Name: USDU1 Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 7.3 GiB mmc clock: 40000000 Bus Width: 4-bit reading s905_autoscript 1745 bytes read in 4 ms (425.8 KiB/s) ## Executing script at 01020000 reading zImage 17663600 bytes read in 966 ms (17.4 MiB/s) reading uInitrd 4450610 bytes read in 248 ms (17.1 MiB/s) reading uEnv.ini 179 bytes read in 4 ms (43 KiB/s) reading dtb.img 40695 bytes read in 7 ms (5.5 MiB/s) [rsvmem] get fdtaddr NULL! rsvmem - reserve memory Usage: rsvmem check - check reserved memory rsvmem dump - dump reserved memory rsvmem check failed ## Loading init Ramdisk from Legacy Image at 13000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 4450546 Bytes = 4.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK load dtb from 0x1000000 ...... Amlogic multi-dtb tool Single dtb detected ## Flattened Device Tree blob at 01000000 Booting using the fdt blob at 0x1000000 Loading Ramdisk to 73a62000, end 73ea08f2 ... OK Loading Device Tree to 000000001fff3000, end 000000001ffffef6 ... OK fdt_instaboot: no instaboot image Starting kernel ... uboot time: 4425441 us domain-0 init dvfs: 4 [ 0.000000@0] Initializing cgroup subsys cpuset [ 0.000000@0] Initializing cgroup subsys cpu [ 0.000000@0] Initializing cgroup subsys cpuacct [ 0.000000@0] Linux version 3.14.29-amlogics905x-gf29b82a-dirty (root@user-VirtualBox) (gcc version 6.4.1 20171012 (Linaro GCC 6.4-2017.11) ) #133 SMP PREEMPT Wed May 16 16:56:54 MSK 2018 [ 0.000000@0] CPU: AArch64 Processor [410fd034] revision 4 [ 0.000000@0] no prop version_code [ 0.000000@0] fdt Reserved memory table: [ 0.000000@0] linux,meson-fb: 0x000000007d100000 - 0x000000007f100000 (32 MiB) [ 0.000000@0] linux,di: 0x000000007b300000 - 0x000000007d100000 (30 MiB) [ 0.000000@0] DI: DI reserved memory: created CMA memory pool at 0x000000007b300000, size 30 MiB [ 0.000000@0] linux,ion-dev: 0x0000000078300000 - 0x000000007b300000 (48 MiB) [ 0.000000@0] linux,vdin1_cma: 0x0000000077000000 - 0x0000000078000000 (16 MiB) [ 0.000000@0] cma: Reserved 16 MiB at 77000000, total cma pages:4096 [ 0.000000@0] linux,ppmgr: 0x0000000078300000 - 0x0000000078300000 (0 MiB) [ 0.000000@0] linux,codec_mm_cma: 0x0000000067800000 - 0x0000000073800000 (192 MiB) [ 0.000000@0] cma: Reserved 192 MiB at 67800000, total cma pages:53248 [ 0.000000@0] linux,picdec: 0x0000000078300000 - 0x0000000078300000 (0 MiB) [ 0.000000@0] Reserved memory: incorrect alignment of CMA region [ 0.000000@0] linux,codec_mm_reserved: 0x0000000063700000 - 0x0000000067800000 (65 MiB) [ 0.000000@0] fdt Reserved memory total: 387 MiB [ 0.000000@0] cma: Reserved 8 MiB at 76800000, total cma pages:55296 [ 0.000000@0] psci: probing function IDs from device-tree [ 0.000000@0] PERCPU: Embedded 13 pages/cpu @ffffffc07829b000 s20608 r8192 d24448 u53248 [ 0.000000@0] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 499976 [ 0.000000@0] Kernel command line: root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 mac=${mac} [ 0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes) [ 0.000000@0] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes) [ 0.000000@0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.000000@0] Memory: 1599440K/2043904K available (10994K kernel code, 981K rwdata, 4028K rodata, 1236K init, 4557K bss, 444464K reserved) [ 0.000000@0] Virtual kernel memory layout: [ 0.000000@0] vmalloc : 0xffffff8000000000 - 0xffffff8040000000 ( 1024 MB) [ 0.000000@0] vmemmap : 0xffffff8040010000 - 0xffffff8042b0d800 ( 42 MB) [ 0.000000@0] modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB) [ 0.000000@0] memory : 0xffffffc000000000 - 0xffffffc07d100000 ( 2001 MB) [ 0.000000@0] .init : 0xffffffc001f2d000 - 0xffffffc002062080 ( 1237 kB) [ 0.000000@0] .text : 0xffffffc001080000 - 0xffffffc001f2caf4 ( 15027 kB) [ 0.000000@0] .data : 0xffffffc002063000 - 0xffffffc002158670 ( 982 kB) [ 0.000000@0] PM: Registered nosave memory: [mem 0x01080000-0x01f2bfff] [ 0.000000@0] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000@0] arch_multi_cluster:0 [ 0.000000@0] Preemptible hierarchical RCU implementation. [ 0.000000@0] RCU debugfs-based tracing is enabled. [ 0.000000@0] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4. [ 0.000000@0] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000@0] NR_IRQS:64 nr_irqs:64 0 [ 0.000000@0] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000004@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns [ 0.000031@0] meson_bc_timer: mclk->mux_reg =ffffff800000c990,mclk->reg =ffffff800000e994 [ 0.000362@0] Console: colour dummy device 80x25 [ 0.000920@0] console [tty0] enabled [ 0.004224@0] allocated 8388608 bytes of page_cgroup [ 0.004238@0] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.004266@0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.004291@0] pid_max: default: 32768 minimum: 301 [ 0.004451@0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.004469@0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes) [ 0.009819@0] Initializing cgroup subsys memory [ 0.009916@0] Initializing cgroup subsys devices [ 0.009931@0] Initializing cgroup subsys freezer [ 0.009944@0] Initializing cgroup subsys blkio [ 0.009956@0] Initializing cgroup subsys perf_event [ 0.010018@0] ftrace: allocating 36702 entries in 144 pages [ 0.048639@0] /cpus/cpu@0: Missing clock-frequency property [ 0.048672@0] /cpus/cpu@1: Missing clock-frequency property [ 0.048687@0] /cpus/cpu@2: Missing clock-frequency property [ 0.048702@0] /cpus/cpu@3: Missing clock-frequency property [ 0.048717@0] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available [ 0.088295@0] Meson chip version = RevD (21:D - A4:0) [ 0.108369@1] CPU1: Booted secondary processor [ 0.128362@2] CPU2: Booted secondary processor [ 0.148370@3] CPU3: Booted secondary processor [ 0.148442@0] Brought up 4 CPUs [ 0.148485@0] SMP: Total of 4 processors activated. [ 0.149021@0] devtmpfs: initialized [ 0.154772@0] sched: registering cpufreq notifiers for scale-invariant loads [ 0.154863@0] instabooting: 0 [ 0.165002@0] cma: cma_init_reserved_areas, use_cma_first:1 [ 0.165127@0] xor: measuring software checksum speed [ 0.258241@0] 8regs : 2292.000 MB/sec [ 0.358245@0] 8regs_prefetch: 2041.200 MB/sec [ 0.458274@0] 32regs : 2811.200 MB/sec [ 0.558302@0] 32regs_prefetch: 2370.800 MB/sec [ 0.558313@0] xor: using function: 32regs (2811.200 MB/sec) [ 0.558332@0] pinctrl core: initialized pinctrl subsystem [ 0.558965@0] regulator-dummy: no parameters [ 0.559738@0] NET: Registered protocol family 16 [ 0.561605@0] cpuidle: using governor menu [ 0.561846@0] aml_vdac_init: module init [ 0.562007@0] register canvas platform driver [ 0.562085@0] register rdma platform driver [ 0.562898@0] vdso: 2 pages (1 code, 1 data) at base ffffffc00206c000 [ 0.562951@0] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.563342@0] DMA: preallocated 256 KiB pool for atomic allocations [ 0.565009@0] software IO TLB [mem 0x61400000-0x61800000] (4MB) mapped at [ffffffc061400000-ffffffc0617fffff] [ 0.565028@0] Serial: AMBA PL011 UART driver [ 0.565628@0] aml_i2c version: 20140813 [ 0.565865@0] i2c-core: driver [pmu4] using legacy resume method [ 0.565946@0] codec_mm:codec_mm_module_init [ 0.566170@0] aml_watch_point_probe, in [ 0.566541@0] gxbb_mpll_clk: register mpll_clk_out0 success done [ 0.566563@0] gxbb_mpll_clk: register mpll_clk_out1 success done [ 0.566578@0] gxbb_mpll_clk: register mpll_clk_out2 success done [ 0.566788@0] clk_sys: register PLL sys_pll success done [ 0.566809@0] gxl_clk: [ xtal ] ->clockrate: 24000000Hz [ 0.566821@0] gxl_clk: [ 32Khz ] ->clockrate: 32000Hz [ 0.566832@0] gxl_clk: [ clk81 ] ->clockrate: 166666666Hz [ 0.566843@0] gxl_clk: [ fixed_pll ] ->clockrate: 2000000000Hz [ 0.566855@0] gxl_clk: [ fclk_div2 ] ->clockrate: 1000000000Hz [ 0.566867@0] gxl_clk: [ fclk_div3 ] ->clockrate: 666666666Hz [ 0.566878@0] gxl_clk: [ fclk_div4 ] ->clockrate: 500000000Hz [ 0.566889@0] gxl_clk: [ fclk_div5 ] ->clockrate: 400000000Hz [ 0.566901@0] gxl_clk: [ fclk_div7 ] ->clockrate: 285714285Hz [ 0.566938@0] gxl_clk: clock initialization complete [ 0.567131@0] clkmsr: Gxl msr_clk_reg0=ffffff800005c75c,msr_clk_reg2=ffffff800005e764 [ 0.569772@0] aml_iomap: amlogic iomap probe done [ 0.570313@0] pinmux-gxl c1109880.pinmux: Init pinux probe! [ 0.571528@0] pinmux-gxl c1109880.pinmux: Probed amlogic pinctrl driver [ 0.572004@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb8) [ 0.572038@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb8) [ 0.572230@0] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0x0/0xb8) [ 0.572256@0] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0x0/0xb8) [ 0.574554@0] dvfs [scpi_dvfs_get_opps] - buf.opp[0].freq_hz = 100000000 [ 0.574569@0] dvfs [scpi_dvfs_get_opps] - buf.opp[1].freq_hz = 250000000 [ 0.574581@0] dvfs [scpi_dvfs_get_opps] - buf.opp[2].freq_hz = 500000000 [ 0.574594@0] dvfs [scpi_dvfs_get_opps] - buf.opp[3].freq_hz = 667000000 [ 0.574606@0] dvfs [scpi_dvfs_get_opps] - buf.opp[4].freq_hz = 1000000000 [ 0.574618@0] dvfs [scpi_dvfs_get_opps] - buf.opp[5].freq_hz = 1200000000 [ 0.574630@0] dvfs [scpi_dvfs_get_opps] - new count 6, max_freq 1200000000 [ 0.576781@0] codec_mm has 2 memory regions [ 0.576836@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_cma ok [ 0.576858@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_reserved ok [ 0.576979@0] codec_mm has 2 memory regions [ 0.577000@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_cma ok [ 0.577021@0] codec_mm codec_mm.18: assigned reserved memory node linux,codec_mm_reserved ok [ 0.579235@0] vpu: driver version: v03 [ 0.579281@0] vpu: load vpu_clk: 666667000Hz(7) [ 0.579378@0] vpu: vpu_probe OK [ 0.580957@0] tv_vout: tvout_probe [ 0.580980@0] tv_vout: chrdev devno 266338304 for disp [ 0.580992@0] vout_notify: vout_register_server [ 0.581002@0] tv_vout: register tv module server ok [ 0.581301@0] tv_vout: create cdev tv [ 0.581320@0] tv_vout: tvout_probe OK [ 0.581938@0] canvas_probe reg=00000000c8838000,size=400 [ 0.581974@0] canvas maped reg_base =ffffff800007e000 [ 0.585936@0] rdma_probe [ 0.865773@0] bio: create slab <bio-0> at 0 [ 1.029124@0] raid6: int64x1 490 MB/s [ 1.199141@0] raid6: int64x2 717 MB/s [ 1.369192@0] raid6: int64x4 1038 MB/s [ 1.539289@0] raid6: int64x8 1198 MB/s [ 1.709359@0] raid6: neonx1 768 MB/s [ 1.879405@0] raid6: neonx2 1242 MB/s [ 2.049457@0] raid6: neonx4 1598 MB/s [ 2.219507@0] raid6: neonx8 1692 MB/s [ 2.219517@0] raid6: using algorithm neonx8 (1692 MB/s) [ 2.219529@0] raid6: using intx1 recovery algorithm [ 2.220395@0] SCSI subsystem initialized [ 2.220972@0] usbcore: registered new interface driver usbfs [ 2.221081@0] usbcore: registered new interface driver hub [ 2.221205@0] usbcore: registered new device driver usb [ 2.222173@0] i2c-gpio i2c_gpio.38: using pins 172 (SDA) and 173 (SCL) [ 2.222328@0] media: Linux media interface: v0.10 [ 2.222420@0] Linux video capture interface: v2.00 [ 2.222685@0] pps_core: LinuxPPS API ver. 1 registered [ 2.222699@0] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 2.222776@0] PTP clock support registered [ 2.223367@0] hdmitx: system: amhdmitx_init [ 2.223382@0] hdmitx: system: Ver: 2014May6 [ 2.223573@0] hdmitx: system: amhdmitx_probe [ 2.223952@0] hdmitx: system: not find match init-data [ 2.223971@0] hdmitx hpd irq = 89 [ 2.224588@0] hdmitx20: Mapped PHY: 0xc0800000 [ 2.224611@0] hdmitx20: Mapped PHY: 0xc1104400 [ 2.224638@0] hdmitx20: Mapped PHY: 0xc8100000 [ 2.224649@0] hdmitx20: Mapped PHY: 0xc8834000 [ 2.224661@0] hdmitx20: Mapped PHY: 0xc883a000 [ 2.224671@0] hdmitx20: Mapped PHY: 0xc883c000 [ 2.224686@0] hdmitx20: Mapped PHY: 0xd0100000 [ 2.224697@0] hdmitx20: Mapped PHY: 0xda83a000 [ 2.224961@0] avmute set to 1 [ 2.225449@0] vout_serve: no matched vout_init mode [ 2.225558@0] vinfo: error: invalid vinfo. current vmode is not supported [ 2.225755@0] vout_serve: create_vout_fops OK [ 2.225767@0] vout_serve: create vout attribute OK [ 2.225777@0] vout_serve: meson_vout_probe OK [ 2.225982@0] logo: logo_init [ 2.226342@0] Advanced Linux Sound Architecture Driver Initialized. [ 2.228069@0] Switched to clocksource arch_sys_counter [ 2.244116@0] FS-Cache: Loaded [ 2.244482@0] CacheFiles: Loaded [ 2.255806@0] NET: Registered protocol family 2 [ 2.256306@0] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 2.256437@0] TCP bind hash table entries: 16384 (order: 6, 262144 bytes) [ 2.256693@0] TCP: Hash tables configured (established 16384 bind 16384) [ 2.256798@0] TCP: reno registered [ 2.256815@0] UDP hash table entries: 1024 (order: 3, 32768 bytes) [ 2.256867@0] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes) [ 2.257103@0] NET: Registered protocol family 1 [ 2.257410@0] RPC: Registered named UNIX socket transport module. [ 2.257426@0] RPC: Registered udp transport module. [ 2.257437@0] RPC: Registered tcp transport module. [ 2.257446@0] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 2.257668@0] aml_wifi wifi.33: [wifi_dev_probe] no power_on_pin2 [ 2.257684@0] aml_wifi wifi.33: [wifi_dev_probe] set pwm as 32k output [ 2.257744@0] aml_wifi wifi.33: [wifi_dev_probe] dhd_static_buf setup [ 2.257824@0] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem: WIFI MEM Allocated [ 2.257841@0] aml_wifi wifi.33: [wifi_dev_probe] interrupt_pin=241 [ 2.257856@0] aml_wifi wifi.33: [wifi_dev_probe] irq_num=100, irq_trigger_type=1 [ 2.257871@0] aml_wifi wifi.33: [wifi_dev_probe] power_on_pin=240 [ 2.257884@0] aml_wifi wifi.33: [wifi_dev_probe] clock_32k_pin=0 [ 2.258403@0] aml_wifi wifi.33: [wifi_setup_dt] wifi_setup_dt [ 2.258456@0] aml_wifi wifi.33: [wifi_setup_dt] interrupt_pin(241) [ 2.258478@0] aml_wifi wifi.33: [wifi_setup_dt] power_on_pin(240) [ 2.258805@0] Unpacking initramfs... [ 2.440102@2] Freeing initrd memory: 4344K (ffffffc073a62000 - ffffffc073ea0000) [ 2.442811@0] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 2.442949@0] audit: initializing netlink subsys (disabled) [ 2.443007@0] audit: type=2000 audit(2.420:1): initialized [ 2.443948@0] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 2.451107@0] VFS: Disk quotas dquot_6.5.2 [ 2.451358@0] Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 2.453332@0] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.454673@0] NFS: Registering the id_resolver key type [ 2.454729@0] Key type id_resolver registered [ 2.454740@0] Key type id_legacy registered [ 2.454757@0] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 2.455296@0] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 2.455753@0] ROMFS MTD (C) 2007 Red Hat, Inc. [ 2.456123@0] fuse init (API version 7.22) [ 2.456781@0] msgmni has been set to 3564 [ 2.458156@0] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 2.458270@0] io scheduler noop registered (default) [ 2.458284@0] io scheduler deadline registered [ 2.458319@0] io scheduler cfq registered [ 2.530886@0] meson-rng c8834000.rng: hwrng registered [ 2.531231@0] [drm] Initialized drm 1.1.0 20060810 [ 2.531298@0] mali-utgard d00c0000.mali: max pp is 3 [ 2.531312@0] mali-utgard d00c0000.mali: set min pp to default 1 [ 2.531325@0] mali-utgard d00c0000.mali: min pp is 1 [ 2.531338@0] mali-utgard d00c0000.mali: set min clk default to 0 [ 2.531350@0] mali-utgard d00c0000.mali: min clk is 0 [ 2.531380@0] mali-utgard d00c0000.mali: hiu io source 0xffffff80001de000 [ 2.531400@0] mali-utgard d00c0000.mali: hiu io source 0xffffff80001fe000 [ 2.531415@0] mali-utgard d00c0000.mali: num of pp used most of time 3 [ 2.531428@0] mali-utgard d00c0000.mali: clock dvfs table size is 7 [ 2.531442@0] mali-utgard d00c0000.mali: max clk set 5 [ 2.531453@0] mali-utgard d00c0000.mali: max clk is 5 [ 2.531465@0] mali-utgard d00c0000.mali: turbo clk set to 6 [ 2.531477@0] mali-utgard d00c0000.mali: turbo clk is 6 [ 2.531489@0] mali-utgard d00c0000.mali: default clk is 3 [ 2.531575@0] mali-utgard d00c0000.mali: ====================0==================== [ 2.531575@0] clk_freq= 125000000, clk_parent=fclk_div4, voltage=1150, keep_count=5, threshod=<30 250>, clk_sample=125 [ 2.531609@0] mali-utgard d00c0000.mali: ====================1==================== [ 2.531609@0] clk_freq= 285000000, clk_parent=fclk_div7, voltage=1150, keep_count=5, threshod=<100 250>, clk_sample=285 [ 2.531641@0] mali-utgard d00c0000.mali: ====================2==================== [ 2.531641@0] clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_count=3, threshod=<168 250>, clk_sample=400 [ 2.531673@0] mali-utgard d00c0000.mali: ====================3==================== [ 2.531673@0] clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_count=2, threshod=<190 250>, clk_sample=500 [ 2.531705@0] mali-utgard d00c0000.mali: ====================4==================== [ 2.531705@0] clk_freq= 666000000, clk_parent=fclk_div3, voltage=1150, keep_count=1, threshod=<177 250>, clk_sample=666 [ 2.531737@0] mali-utgard d00c0000.mali: ====================5==================== [ 2.531737@0] clk_freq= 744000000, clk_parent= gp0_pll, voltage=1150, keep_count=1, threshod=<213 255>, clk_sample=744 [ 2.531769@0] mali-utgard d00c0000.mali: ====================6==================== [ 2.531769@0] clk_freq= 744000000, clk_parent= gp0_pll, voltage=1150, keep_count=1, threshod=<213 255>, clk_sample=744 [ 2.533913@2] gpu cooling register okay with err=0 [ 2.534068@2] gpu core cooling register okay with err=0 I hope this will be enough. Thanks! Edited June 2, 2018 by Tido @pisach, please use SPOILER
