Hi @lifeform,
Im trying do the same for Tp-link usb WiFi dongle drivers, but without succes becouse the @balbes150 armbian image I used does not have headers.
I see you are trying with another aproach, could you please let me know which repo are you using and Wich are the main steps you are doing?
Thanks a lot
23 minutes ago, Doroteo said:
Hi @lifeform,
What driver/chip do you want to build? Your better off getting the correct kernel source from https://github.com/150balbes/Amlogic_s905-kernel (or armbian build) if its a popular driver not enabled in the current /boot/config.
Search these forum threads for build instructions.
lord @balbes150 after try two images for ki pro, I am in need of some suggestions for you from my ignorance.
1.- Images have worked well, but frist, permissions aren't fine in the system, 1023 user and group in different places.
2.- Second and more important, trying to android stock or coreelec return neither emmc or sdcard have worked nicely. network in general was a nightmare, eth0 and wifi, i have had search for armbian image with 3.14.x kernel and flash dualboot and start image, after that network have started work nicely with android stock, no tested coreelec.
i suggest come back some 3.14.x images and post please, to avoid headaches.
i'll like use armbian with 3.14.x with web browser for netflix and kodi with full graphic acceleration.
thank you for your time y effort.
The driver is for TL-WN823N, in the Tp-Link web site you can download driver sources and instrucctions for compile in linux with headers
Hello guys !
Recently I launched ubuntu from sd card on my s905w (x96 mini). Everything works ok exept ethernet. It doesn't work both on server and desktop version of rom. When I asked balbes about that problem, he told me, that I have to configure dtb (or choose the right dtb). I looked through the forum for guide but found nothing. Although I did change dtb path in boot.ini from default to "meson-gxm-khadas-vim2.dtb" and then "meson-gxl-s905w-p281.dtb". None of that solved ethernet problem. Also I don't get the dfference between "dtb" and "dtb-5.2.1-aml-g12", cause the have the same files. Can someone help me with this ? At least link to guide or post ?
Hi everyone, I'm new here and I need the image: Armbian_5.37_S9xxx_Ubuntu_xenial_3.14.29_mate_20171226.img.xz
or another with kernel 3.14.29 for the S9XXX if anyone can download it, I really appreciate it. I've searched the web a lot and haven't found it. Thanks!!!
Hello everyone, my TV box is NEXBOX A95X S905X 1G/8G - Android 7.1, kernel 3.14.29. What is the best option to use for this model? I have tried some, but to no avail
Don't know but this post might help determining the board type (dtb to use):
https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x-ver-544/?do=findComment&comment=66212
If not, you'll have to try every dtb and be patient - even though the screen isn't
working, ethernet and usb might be - see
https://forum.armbian.com/topic/2419-armbian-for-amlogic-s905-and-s905x-ver-544/?do=findComment&comment=58673
HI everyone,
I looking for this file :
Armbian_5.37_S9xxx_Debian_stretch
 If someone has it...
Thanks in advance
Hi , can anyone provide me the link to download Armbian bionic image with kernel 3.14. I have seen that image earlier at the ydisk link which @balbes150 provided but seems he has removed it now .
I've uploaded it to megashares - https://mega.nz/#!0jxX1KBD!iws8Ojo_zJ5K7SllQ7c7xphP8SAbanMP6YypqnMnbbM
File details - Armbian_5.44_S9xxx_Ubuntu_bionic_3.14.29_mate_20180601.img.xz - 706438108 bytes, md5sum 8ee5fe48fbd0a255915b696bda170cf
2 hours ago, dbsharpe said:
Carreguei-o no megashares - https://mega.nz/#!0jxX1KBD!iws8Ojo_zJ5K7SllQ7c7xphP8SAbanMP6YypqnMnbbM
Detalhes do arquivo - Armbian_5.44_S9xxx_Ubuntu_bionic_3.14.29_mx2015605d8
Hello dbsharpe, thanks for making img available. Already able to install on Nexbox A95x S905X, it was not necessary to create dtb.img; Now I bought the X96 mini and wanted to put Armbian_5.37_S9xxx_Debian_stretch_4.20 But I can't find it anywhere ...
Sorry, I only use Ubuntu and had downloaded debian by mistake.
If your looking for 4.20.x kernel files only, I'd get on from yadi.sk and extract the relevant files from /boot & root:/lib/modules/4.20* and put them on your working environment.
Hello dbsharpe,
Do you have ubuntu 12 for Armbian
Looking to purchase new amolgic tv box will be installing armbian desktop logging in remotely  i will need wifi to work.
Are there any s905xxx or s912 tv boxes anyone could recommend that has wifi working .
Thanks: for your help
The main browsers are really slow! Both firefox and chromium. And also other webkit-based ones.
I did truly expect much better from the arm 64-bit 4-core.
Is anyone else experiencing this? Any tricks to improve performance?
On 8/26/2019 at 12:10 AM, Doroteo said:
Hi @lifeform,
Thanks a lot
sorry.. i just saw your reply. the repo is state at above https://github.com/kelebek333/rtl8188fu
is this what you mean? if you mean repo for debian i just used default
have you solved with this?
Hi, is there a way to re-install the proper bootloader (or whatever changes) after trying for example coreelec or older libreelecbuilds from card when armbian is installed on internal? I had the card from armbian install still available, so I could do a reinstall on emmc via armbian config. Is there a simple way to copy just the part coreelec or other systems "destroy"? Or is there even a simple way to change the boot-thing on the cards from the old one to the newer one working with armbian and the kodi 19 testing builds?
By the way, Armbian_5.98_Aml-g12_Ubuntu_bionic_dev_5.4.0-rc4_desktop_20191025.img.xz works nice on the testing x96mini 2/16 s905w p281 box.
If you ran coreelec, you need to restore the regular Android firmware via USB Burn Tool and then re-activate the universal multi-boot.
Only this will allow Armbian and Libreelec to work correctly.
..okay-maybe not the ideal way, but I had no android for the box here..so for me worked pretty well booting the armbian from card with pressed recovery button and just re-copying the system to emmc via armbian-config again..also 19 alpha Libreelec builds boot/work again as expected, but neither coreelec nor official built images boot, like it should be..
Just installed Armbian_5.99_Aml-g12_Ubuntu_bionic_dev_5.4.0-rc6_desktop_20191010.img.xz (is the timestamp 1010 correct or should it be 1110?!). No issues so far on my x96 mini p281 s905w 2/16 test box.
Hi there,
I've a problem, I've installed armbian 5.77 and now I want to upgrade to a most recent version,
if I try to boon from SD card the MXQ freezes on S905x logo,
Is there any alternative way to upgrade?
Can anyone provide me Armbian_5.41.1_S9xxx_Ubuntu_xenial_3.14.29_mate_20180421.img version image? Or any other image which has ssv6051 Wifi module.
I am looking for an image which has ssv6051 Wifi module. Looks like there are other folks here looking for that as well. Can some provide a download link?
Thanks
Rajesh
