Zhexue. Posted January 18, 2023 Posted January 18, 2023 Hello all, according to the hints on the ARMBIAN homepage the image "Armbian_23.02.0-trunk_Rpi4b_lunar_edge_6.1.5.img" should work with the Raspi 3. Unfortunately it does not work properly, the system does not want to boot with it.... The name of the image says that it was generated for Raspi4, but -as I said- the homepage says that this image would also be compatible for the other Raspberry systems mentioned there. Can anyone tell me what the reason could be, because I would love to use this ingenious image for the Raspi 3. Best regards from Berlin Z. Matthias 0 Quote
Werner Posted January 18, 2023 Posted January 18, 2023 RPi3 compatibility seemed to got lost with the latest release. Reason unknown. Try older release. Be aware when doing do and upgrading firmware it might ran into unbootable state again. Feel free to do so anyway and report if that is the case. 0 Quote
c0rnelius Posted January 18, 2023 Posted January 18, 2023 (edited) The boot partition is flagged ESP, which the PI3 does not support. Model: Generic MassStorageClass (scsi) Disk /dev/sdd: 32.0GB Sector size (logical/physical): 512B/512B Partition Table: msdos Disk Flags: Number Start End Size Type File system Flags 1 4194kB 273MB 268MB primary fat32 esp 2 273MB 4106MB 3834MB primary ext4 Removing the ESP flag from the boot partition should allow the image to boot on both the RPi3 and RPi4. This can be easily done using gparted. if you are comfortable using the command line: sudo parted /dev/XXX set 1 esp off Edited January 18, 2023 by c0rnelius 1 Quote
Igor Posted January 18, 2023 Posted January 18, 2023 Fixed. Need review. https://github.com/armbian/build/pull/4710 Thanks @c0rnelius! 0 Quote
Zhexue. Posted February 26, 2023 Author Posted February 26, 2023 Thanks @Igor. I would like to check it and give you an feedback. 0 Quote
Zhexue. Posted February 26, 2023 Author Posted February 26, 2023 Hey Igor, Can I take the image for RaspBerry PI4 from this website (https://github.com/armbian/community) for the PI3 board or is there another version somewhere? Kind regards Z. Matthias 0 Quote
Igor Posted February 27, 2023 Posted February 27, 2023 19 hours ago, Zhexue. said: for the PI3 board Yes, it works for pi3 too. Edit: should work. Those images are not tested. 0 Quote
