How can I change usb-disk driver "UAS" to "usb-storage" ?
Go to solution Solved by TheOWL,
I run "armbianmonitor -u" and I got this https://paste.armbian.com/bapohonaja
My SBC is orangepi zero 2, and I tried to use it as a NAS.
But sometime the system hangup because I push to much file in my usb-disk. And I G**gle about it. Somebody said because usb driver is "UAS".
So I use command "lsusb -t" and bingo, my usb driver is "uas":
>: lsusb
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp. JMS567 SATA 6Gb/s bridge
>: lsusb -t
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M
I tried "/etc/modprobe.d/disable_uas.conf" with "options usb-storage quirks=152d:0562:u" and "update-alternatives -u" and reboot but failed.
I tried "/boot/armbianEnv.txt" with "usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x152d:0x0562:u" and "update-alternatives -u" and reboot but failed.
Still "uas" there!
Is that posible to change "uas" driver to "usb-storage"?
You are aware that this command has noting to do with boot stuff? Maybe update-initramfs -u is what you are looking for after adjusting such things...
@Werner "update-alternatives -u" is a typing mistake...... I check .bash_history file and I'm quite sure I'm using "update-initramfs -u"......
root@orangepizero2:/etc/modprobe.d# update-initramfs -u
update-initramfs: Generating /boot/initrd.img-4.9.318-sun50iw9
update-initramfs: Converting to u-boot format
After I change everything in /etc/modprobe.d/ , I will "update-initramfs -u" and reboot.
Or eachtime I modify /boot/armbianEnv.txt, I will "update-initramfs -u" and reboot, too.
"uas" still in "lsusb -t"......
@ning Do you mean write "blacklist uas" into /etc/modprobe.d/blacklist-orangepizero2.conf, and "update-initramfs -u" and reboot? Yes, I tried it .
Echo from "lsusb" and "lsusb -t":
root@orangepizero2:/boot# lsusb
root@orangepizero2:/boot# lsusb -t
Echo from "cat /boot/armbianEnv.txt"
root@orangepizero2:/boot# cat armbianEnv.txt
verbosity=1
console=serial
disp_mode=1080p60
fb0_width=1280
fb0_height=720
rootdev=UUID=bb376e29-2786-497f-97de-2a9dbcb6b443
rootfstype=ext4
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x152d:0x0562:u,0x1d6b:0x0001:u,0x1d6b:0x0002:u
Echo from "cat /proc/cmdline":
root@orangepizero2:/boot# cat /proc/cmdline
root=UUID=bb376e29-2786-497f-97de-2a9dbcb6b443 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=f85e630b-01 disp_reserve=3686400,0x7bf4fcc0
That's all what I get here...
Edited by TheOWL
  • Solution
OK, I change boot.cmd, add "usb-storage.quirks=0x152d:0x0562:u,0x1d6b:0x0002:u" to the cmd file, and recompile boot.scr. And I got "usb-storage" in my usb disk now.
It's a solution for me...
I had same problem with RTL9210 based NVME enclosure. But I could not find one of them boot.cmd or boot.scr.
So I did it old fashion way like on Raspbian OS and added usb-storage.quirks parameter into /boot/firmware/cmdline.txt and after reboot UAS driver was replaced with basic usb one.
Note: I tried to edit /boot/armbianEnv.txt but it did not work.
Edited by technik007_cz
