TheOWL Posted April 29, 2023 Share Posted April 29, 2023 I run "armbianmonitor -u" and I got this : https://paste.armbian.com/bapohonaja My SBC is orangepi zero 2, and I tried to use it as a NAS. But sometime the system hangup because I push to much file in my usb-disk. And I G**gle about it. Somebody said because usb driver is "UAS". So I use command "lsusb -t" and bingo, my usb driver is "uas": ``` >: lsusb Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 002: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp. JMS567 SATA 6Gb/s bridge Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub >: lsusb -t /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M ``` I tried "/etc/modprobe.d/disable_uas.conf" with "options usb-storage quirks=152d:0562:u" and "update-alternatives -u" and reboot but failed. I tried "/boot/armbianEnv.txt" with "usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x152d:0x0562:u" and "update-alternatives -u" and reboot but failed. Still "uas" there! Is that posible to change "uas" driver to "usb-storage"? 0 Quote Link to comment Share on other sites More sharing options...
ning Posted April 29, 2023 Share Posted April 29, 2023 blacklist uas 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 30, 2023 Share Posted April 30, 2023 8 hours ago, TheOWL said: update-alternatives -u You are aware that this command has noting to do with boot stuff? Maybe update-initramfs -u is what you are looking for after adjusting such things... 0 Quote Link to comment Share on other sites More sharing options...
TheOWL Posted April 30, 2023 Author Share Posted April 30, 2023 @Werner "update-alternatives -u" is a typing mistake...... I check .bash_history file and I'm quite sure I'm using "update-initramfs -u"...... =========================== root@orangepizero2:/etc/modprobe.d# update-initramfs -u update-initramfs: Generating /boot/initrd.img-4.9.318-sun50iw9 update-initramfs: Converting to u-boot format =========================== After I change everything in /etc/modprobe.d/ , I will "update-initramfs -u" and reboot. Or eachtime I modify /boot/armbianEnv.txt, I will "update-initramfs -u" and reboot, too. "uas" still in "lsusb -t"...... @ning Do you mean write "blacklist uas" into /etc/modprobe.d/blacklist-orangepizero2.conf, and "update-initramfs -u" and reboot? Yes, I tried it . 0 Quote Link to comment Share on other sites More sharing options...
TheOWL Posted April 30, 2023 Author Share Posted April 30, 2023 (edited) Echo from "lsusb" and "lsusb -t": =================================== root@orangepizero2:/boot# lsusb Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub Bus 001 Device 002: ID 152d:0562 JMicron Technology Corp. / JMicron USA Technology Corp. JMS567 SATA 6Gb/s bridge Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub root@orangepizero2:/boot# lsusb -t /: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M /: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M /: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M /: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=uas, 480M =================================== Echo from "cat /boot/armbianEnv.txt" =================================== root@orangepizero2:/boot# cat armbianEnv.txt verbosity=1 console=serial disp_mode=1080p60 fb0_width=1280 fb0_height=720 rootdev=UUID=bb376e29-2786-497f-97de-2a9dbcb6b443 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u,0x152d:0x0562:u,0x1d6b:0x0001:u,0x1d6b:0x0002:u =================================== Echo from "cat /proc/cmdline": =================================== root@orangepizero2:/boot# cat /proc/cmdline root=UUID=bb376e29-2786-497f-97de-2a9dbcb6b443 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=f85e630b-01 disp_reserve=3686400,0x7bf4fcc0 =================================== That's all what I get here... Edited April 30, 2023 by TheOWL 0 Quote Link to comment Share on other sites More sharing options...
Solution TheOWL Posted April 30, 2023 Author Solution Share Posted April 30, 2023 OK, I change boot.cmd, add "usb-storage.quirks=0x152d:0x0562:u,0x1d6b:0x0002:u" to the cmd file, and recompile boot.scr. And I got "usb-storage" in my usb disk now. It's a solution for me... 0 Quote Link to comment Share on other sites More sharing options...
technik007_cz Posted January 8 Share Posted January 8 (edited) I had same problem with RTL9210 based NVME enclosure. But I could not find one of them boot.cmd or boot.scr. So I did it old fashion way like on Raspbian OS and added usb-storage.quirks parameter into /boot/firmware/cmdline.txt and after reboot UAS driver was replaced with basic usb one. Note: I tried to edit /boot/armbianEnv.txt but it did not work. Edited January 9 by technik007_cz 0 Quote Link to comment Share on other sites More sharing options...
