markbox Posted June 27, 2023 Posted June 27, 2023 With the prior image and kernel 5.10.110 I was able to run compile.sh and produce the linux-source-legacy-rockchip-rk3588_23.02.0-trunk_all.deb which provided the kernel source in /usr/src/linux-source-5.10.110-rockchip-rk3588.tar.xz. I downloaded the latest img which provides kernel 5.10.160 which booted fine. However, running the same compile.sh process I used previously with success produced the older deb package that contains the 5.10.110 kernel source. There were a couple of errors displayed. My compile.sh command is: ./compile.sh BOARD=orangepi5 BRANCH=legacy BUILD_ONLY=kernel RELEASE=jammy KERNEL_CONFIGURE=no The first error encountered was a prompt for username/password to access https://github.com/morrownr/8821cu-20210118/. I tried creating a github account but those credentials did not work. Pressing Enter bypassed the authentication failure and continued but the kernel failed to build with "[ error ] Kernel was not built". Assuming this error was in part due to not having access to https://github.com/morrownr/8821cu-20210118/. My primary goal is to acquire the kernel 5.10.160 kernel source so that I can build external kernel modules. I did see the leaflet-8 notice. Is the issue I describe above covered by the leaflet-8 notice? or do I need to use different compile.sh options? Perhaps a different BRANCH= value? I tried using the compile.sh menu system but got the same result. 0 Quote
Igor Posted June 28, 2023 Posted June 28, 2023 9 hours ago, markbox said: I tried using the compile.sh menu system but got the same result. Problem you have is not possible to reproduce by using latest source from main branch. Which is the only source that can be maintained. If you are using different sources that the main in main branch, you need to adjust them accordingly. Build framework needs clear instructions and code that builds. IMO its less work supporting our common goal - get this working with latest version. 0 Quote
markbox Posted June 28, 2023 Author Posted June 28, 2023 Understood. I have used this command to clone the main branch: git clone --branch=main https://github.com/armbian/build I then ran ./compile.sh and built the entire image for orangepi5. The log file shows these options were used: # Repeat build: ./compile.sh build BOARD=orangepi5 BRANCH=legacy BUILD_DESKTOP=yes BUILD_MINIMAL=no BUILD_ONLY=kernel DESKTOP_APPGROUPS_SELECTED='browsers desktop_tools editors internet multimedia programming' DESKTOP_ENVIRONMENT=gnome DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base KERNEL_CONFIGURE=no RELEASE=jammy # ARGs: 'PREFER_DOCKER=no' 'ARMBIAN_RELAUNCHED=yes' 'BRANCH=legacy' 'BOARD=orangepi5' 'SET_OWNER_TO_UID=1000' 'BUILD_ONLY=kernel' 'RELEASE=jammy' 'build' After a few hours I ended up with 13 deb packages. None of them are the linux-source-legacy-rockchip-rk3588*deb package I am seeking. I've read the Developer-Guide_Build-Options. What option is needed to build the linux-source deb package? I do see the entire kernel source was downloaded and built in subdirectory cache/sources/linux-kernel-worktree/5.10__rk35xx__arm64/. I could try and manipulate that into what I need. 0 Quote
Werner Posted June 29, 2023 Posted June 29, 2023 Try with ARTIFACT_IGNORE_CACHE=yes and BUILD_KSRC=yes set. 0 Quote
markbox Posted June 30, 2023 Author Posted June 30, 2023 Tried with ARTIFACT_IGNORE_CACHE=yes BUILD_KSRC=yes and compile.sh did not produce the linux-source*deb package. I'll try some more test builds in the morning. Thanks to both of you for the suggestions. 0 Quote
