Solution Igor Posted July 28, 2023 Solution Posted July 28, 2023 34 minutes ago, FredK said: Support for bullseye dropped? No, just some bug that prevented its re-creation. As you can see, we have bigger exotics in the pool https://imola.armbian.com/apt/dists/ 0 Quote
FredK Posted July 28, 2023 Author Posted July 28, 2023 Thank you and waiting for the re-creation .... 0 Quote
cypherShrugged Posted July 28, 2023 Posted July 28, 2023 I also got his error today for ' apt-get update': Err:8 http://imola.armbian.com/apt bullseye Release 404 Not Found [IP: 93.103.15.56 80] Reading package lists... Done E: The repository 'http://apt.armbian.com bullseye Release' no longer has a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. 0 Quote
Nelexis Posted July 28, 2023 Posted July 28, 2023 I'm having the same issue. Bullseye missing from here: https://xogium.performanceservers.nl/apt/dists/ and http://armbian.hosthatch.com/apt/dists/ 0 Quote
GuyKhmel Posted September 18, 2023 Posted September 18, 2023 And now... it's Kinetic which is missing 😕 0 Quote
GuyKhmel Posted September 19, 2023 Posted September 19, 2023 @Werner I know, but what should I do then? How can I upgrade to a newer version (without losing data): ❯ cat /etc/os-release PRETTY_NAME="Armbian 23.02.0-trunk Kinetic" NAME="Ubuntu" VERSION_ID="22.10" VERSION="22.10 (Kinetic Kudu)" VERSION_CODENAME=kinetic ID=ubuntu ID_LIKE=debian HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" UBUNTU_CODENAME=kinetic LOGO=ubuntu-logo I ran `sudo apt update & sudo apt dist-upgrade` but nothing would happen 0 Quote
Werner Posted September 19, 2023 Posted September 19, 2023 Non-LTS Ubuntu userspaces are mostly added for fun for the developers to get an idea where upstream development is going. These images were never supported and only meant to be used by enthusiasts who know what they are doing. You can try to upgrade userspace: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-upgrade-distribution-like-focal-to-jammy-or-bullseye-to-bookworm 0 Quote
GuyKhmel Posted September 20, 2023 Posted September 20, 2023 I can't figure out if what I have installed is Ubuntu or Debian; cat /etc/debian_version bookworm/sid Which feels like the latest version indeed - https://www.armbian.com/cubox-i/ But in this case, the source.list is all wrong, no? However - look at the previous ❯ cat /etc/os-release I've pasted, it's Ubuntu there Huh? 0 Quote
Igor Posted September 20, 2023 Posted September 20, 2023 2 hours ago, GuyKhmel said: cat /etc/os-release Ubuntu is Debian based so there must be some leftovers. Download Ubuntu kinetic for PC and check this file. 0 Quote
Gunjan Gupta Posted September 22, 2023 Posted September 22, 2023 On 9/19/2023 at 12:12 PM, GuyKhmel said: what should I do then? How can I upgrade to a newer version (without losing data): edit /etc/apt/source.list and /etc/apt/source.list.d/armbian.list and change kinetic to jammy. Then run "apt-get update && apt-get dist-upgrade" 0 Quote
Christian Schlichtherle Posted June 19, 2024 Posted June 19, 2024 It happened again today, this time it affects bookworm. Apparently, the folder is empty: https://imola.armbian.com/apt/dists/bookworm/ Please fix. 0 Quote
Werner Posted June 19, 2024 Posted June 19, 2024 3 hours ago, Christian Schlichtherle said: Please fix. fixed 0 Quote
