vortex375 Posted July 31, 2023 Posted July 31, 2023 Hi all, I'm trying to build a NAS using the Penta SATA Hat (https://wiki.radxa.com/Penta_SATA_HAT). I'd like to use ZFS as file system. I got the "supported" Armbian Jammy image from here: https://www.armbian.com/rockpi4/ I installed the kernel headers through armbian-config. However, attempting to install the zfs-dkms package gives me Building for 6.1.30-rockchip64 Module build for kernel 6.1.30-rockchip64 was skipped since the kernel headers for this kernel does not seem to be installed. As you can see, my kernel version is 6.1.30-rockchip64: $ uname -r 6.1.30-rockchip64 However, the installed kernel headers are for 5.15.93-rockchip64: $ apt list --installed | grep linux-headers linux-headers-current-rockchip64/jammy,now 23.02.2 arm64 [installed] $ apt show linux-headers-current-rockchip64 Package: linux-headers-current-rockchip64 Version: 23.02.2 Priority: optional Section: devel Source: linux-5.15.93-rockchip64 Maintainer: Igor Pecovnik <igor.pecovnik@****l.com> Installed-Size: 79.8 MB Provides: armbian-current, linux-headers, linux-headers-armbian Depends: make, gcc, libc6-dev, bison, flex, libssl-dev Homepage: https://www.kernel.org/ Download-Size: 12.0 MB APT-Manual-Installed: yes APT-Sources: http://apt.armbian.com jammy/main arm64 Packages Description: Linux kernel headers for 5.15.93-rockchip64 on arm64 current This package provides kernel header files for 5.15.93-rockchip64 on arm64 . This is useful for people who need to build external modules There seem to be no matching sources for my kernel available. Obviously, I must be missing something. How can I either - downgrade to the kernel for which sources are available in the repo - install the correct sources for 6.1.30-rockchip64 Any help is much appreciated! 0 Quote
Igor Posted August 1, 2023 Posted August 1, 2023 13 hours ago, vortex375 said: Any help is much appreciated! As there is some WIP on our repository side you need to workaround this - make an image with enabled HEADERS and then it will work. 0 Quote
vortex375 Posted August 1, 2023 Author Posted August 1, 2023 Thanks. So you're saying I should try building my own image? I guess using https://github.com/armbian/build. Haven't tried anything like that, but I'll give it a go. 0 Quote
SteamPunkProgrammer Posted February 25, 2024 Posted February 25, 2024 Sorry to necro the thread, but im having the same issue, do you mean I need to compile with the INCLUDE_HEADERS=yes flag? I tried that but still no luck. 0 Quote
SteeMan Posted February 25, 2024 Posted February 25, 2024 1 hour ago, SteamPunkProgrammer said: im having the same issue Please start by explaining the exact issue you are having. Including all versions of the components. 0 Quote
SteamPunkProgrammer Posted February 25, 2024 Posted February 25, 2024 I actually figured it out, i was using jammy on my rockpi4b, went back tried bookworm, and recompiled zfs myself, now its all good! 0 Quote
