How to disable ipv6
Go to solution Solved by MichaIng,
Hello.
I faced with a problem, I can't disable ipv6 completely on Armbian 23.05.1. Orange Pi PC.
Tried to use armbian-config to disable ipv6 in Network menu, but no luck, apps can use it at the moment
netstat -tulpn | grep :::    gives me
udp6       0      0 :::53                   :::*                                1134/pihole-FTL
udp6       0      0 :::111                  :::*                                1/init
Thanks in advance.
8 часов назад, TRS-80 сказал:
I disable it at my router (which is running OpenWrt).
My ISP doesn't provide ipv6. And also I user ip6tables and configured default policies on Armbian:
ip6tables -P INPUT DROP
ip6tables -P OUTPUT DROP
ip6tables -P FORWARD DROP
But I can't find out how to disable it completely.
I tried to add these lines to sysctl
net.ipv6.conf.all.disable_ipv6=1
net.ipv6.conf.default.disable_ipv6=1
net.ipv6.conf.lo.disable_ipv6=1
not working!
Next idea is to disable ipv6 via grub. But there is no /etc/default/grub file on Armbian.
Edited by Zarif2000
01.09.2023 в 19:38, hexdump сказал:
i think "ipv6.disable=1" added to the kernel cmdline should work
Can you provide step-by-step guide please? Should I edit /boot/armbianEnv.txt ?
Edited by Zarif2000
  • Solution
sudo sed -i '/^extraargs=/$/ ipv6.disable=1/' /boot/armbianEnv.txt
Respectively add ipv6.disable=1 to the end of the "extraargs" line, separated with a space from other possible values.
However, this disables IPv6 support completely kernel-wise, which some software has problems with. E.g. the default Apache2 config on Debian comes with a vhost which dynamically binds to IPv4 and/or IPv6 addresses based on whether it is active on the interface or not. This syntax requires the kernel to at least understand IPv6, otherwise the webserver fails to start. So it is generally safer to only disable IPv6 on all interfaces, but keeping the kernel module active:
echo -e 'net.ipv6.conf.all.disable_ipv6=1\nnet.ipv6.conf.default.disable_ipv6=1' | tee /etc/sysctl.d/disable_ipv6.conf
sudo sysctl -p /etc/sysctl.d/disable_ipv6.conf
EDIT: Ah, now I see you basically tried this already. As this is universally functional on all Linux distros, it must actually work. Not sure how exactly to tried it, which exact command or config file? E.g. using the sysctl command itself is not boot-persistent, hence the config file.
Edited by MichaIng
31.08.2023 в 09:33, Zarif2000 сказал:
As I was telling earlier, I used sysctl file.
12.09.2023 в 19:37, MichaIng сказал:
Sounds logical. And as far as I don't want to face with strange errors in a future, I'll let ipv6 in normal state.
