ebin-dev Posted January 31 Author Posted January 31 On 1/30/2025 at 12:15 PM, kantantana said: But still, iperf3 says barely 200mbit/s, this is on the 1gbit interface. Another laptop towards same server, on same lan same switch gets 950mbit/s. Since only one of your laptops is affected by the reduced transfer speed I would rather search for any issues there (update NIC driver, check NIC configuration, exclude cable/connection issues, etc.). 0 Quote
kantantana Posted January 31 Posted January 31 I did the tests on helios64, from 2 different laptops and one desktop, between the desktops and laptops I always get 950mbit/s, it is only helios64 which gets close to 200mbit/s to any of them. They are all on the same switch and same lan. Even worse, for helios64 with iperf3 -u (udp) I get barely 1mbit/s. I did another test today, this time checked cpufreq-info helios was on 480Mhz so maybe it was too slow to increase freq? So I did dd if=/dev/zero of=/dev/null bs=1M and let it run, it was burning 1 cpu core, helios went to 1.2Ghz, did the iperf3 test and same results, barely 200Mbit/s. ethtool does say 1000 full duplex on that interface. Also tried the ethtool -k tso gso gro on and so on, no difference. The 2.5gbit/tests I did with a cable from the helios directly to an odroid h4+ which also has a 2.5gbit port, no switch inbetween at all, that test failed stability and the link was resetting on the helios64. btw this is the sha256sum a538d69ca94b31fdf91d047ec7c54970465f7d008081738baaaa5fc09be97e94 of the dtb /lib/linux-image-6.12.11-current-rockchip64/rockchip/rk3399-kobol-helios64.dtb Im using taken from this thread 0 Quote
ebin-dev Posted January 31 Author Posted January 31 (edited) On 1/31/2025 at 3:26 PM, kantantana said: I did another test today, this time checked cpufreq-info helios was on 480Mhz so maybe it was too slow to increase freq? So I did dd if=/dev/zero of=/dev/null bs=1M and let it run, it was burning 1 cpu core, helios went to 1.2Ghz, did the iperf3 test and same results, barely 200Mbit/s. ethtool does say 1000 full duplex on that interface. Also tried the ethtool -k tso gso gro on and so on, no difference. I have only checked the performance of the 2.5G interface with linux 6.12.10 - not the 1G interface. Could you check if the issue remains if you use linux 6.6.74 ? (install with 'dpkg -i linux*'; replace the dtb with the one attached; execute 'update-initramfs -u'; reboot) Edit: The 2.5G interface needs the hardware fix in order to operate reliably in mode 2500baseT/Full too: during ethernet handshaking 1G speeds could be established transiently. I think that this might have happened during the test with odroid h4+. Edit: You mentioned that helios went to 1.2GHz during the transfer. If the load is handled by a little core that may be the reason for the reduced transfer speed. A big core should be assigned to it. Therefore, the following code in /etc/rc.local is very helpful in this context (it also configures the ondemand governor and makes it responsive) [armbian-hardware-optimization is disabled on my system]: cd /sys/devices/system/cpu/cpufreq for cpufreqpolicy in 0 4 ; do echo 1 > policy${cpufreqpolicy}/ondemand/io_is_busy echo 25 > policy${cpufreqpolicy}/ondemand/up_threshold echo 10 > policy${cpufreqpolicy}/ondemand/sampling_down_factor echo $(cat policy${cpufreqpolicy}/cpuinfo_transition_latency) > policy${cpufreqpolicy}/ondemand/sampling_rate done for i in $(awk -F":" "/ahci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 10 > /proc/irq/$i/smp_affinity done for i in $(awk -F":" "/xhci/ {print \$1}" < /proc/interrupts | sed 's/\ //g'); do echo 20 > /proc/irq/$i/smp_affinity done exit 0 While transferring data to/from Helios64 some processes are involved such as iperf3 - or netatalk in my case. Those processes should also be executed on a big core. If iperf3 tests are performed or if helios64 is mounted as a remote drive I call the following script that assigns a big core and a preferred io scheduling class to those processes (to be adapted to your needs). This helps to make your nas_processes faster (kudos to @tkaiser) . # cat /usr/local/bin/make_nas_processes_faster.sh #!/bin/sh -e for i in `pgrep "afpd|cnid|iperf3|netatalk"` ; do ionice -c1 -p $i ; taskset -c -p 4 $i; done # >/dev/null 2>&1 rk3399-kobol-helios64.dtb-6.6.xx-L2-hs400-opp Edited February 5 by ebin-dev 0 Quote
prahal Posted February 1 Posted February 1 The 2.5Gbps hardware issue is when operating in 1Gbps mode only (2.5Gbps was always fine hardware wise) https://blog.kobol.io/2020/11/13/helios64-2-5g-ethernet-issue/ 0 Quote
kantantana Posted February 2 Posted February 2 Checked the previous kernel as instructed, there is no difference, its not a regression. Setting affinity does raise it to 380Mbit/s. However, I did play with running dd if zero of to null, simultaneously with iperf3, and dd hogging 1 cpu is making it lose half of throughput, pointing to the problem being with the cpu scheduling or whatever and not with interface/driver code? Anyway, I found its good enough for now, I can achieve 800Mbit/s, but only sometimes and only if run taskset 1,2,3 iperf3, and not even every time of those 1,2,3 sometimes it has to be 4,5,6, but even the 1,2,3 times happen on retries (so it looks like 600Mbit and then 250 and then 600 again!?) And so, after many more tests, I noticed the times when I get 800Mbit/s, and other times 120Mbit/s... Becuase if I set performance governor, its then more often I can end up in reproducing 800Mbit/s, with iperf3 -A 5, or 4, but not 3 or 2... so its only the fast cpus which can give good results, the others are even if performance governor and at 1.42Ghz, still suck at 260Mbit/s Also, only with iperf3 -A 5 (affinity), I can get 0 packet-retry, other options I guess when the process is moved from cpu 0 to 1, is when retries happen, or when ondemand governor is on, if on slow cpus, retries happen when it switches freq? 0 Quote
ebin-dev Posted February 3 Author Posted February 3 (edited) 11 hours ago, kantantana said: Checked the previous kernel as instructed, there is no difference, its not a regression. Setting affinity does raise it to 380Mbit/s. However, I did play with running dd if zero of to null, simultaneously with iperf3, and dd hogging 1 cpu is making it lose half of throughput, pointing to the problem being with the cpu scheduling or whatever and not with interface/driver code? Thanks for testing. I think that the load distribution is indeed essential to get good transfer speeds and it seems that the scheduler needs some help to do it right. With the settings posted before the load on cpus0-3 is below 20% and the load on cpus4-5 is between 60% and 80% while downloading a 2GB file from Helios64 to a client with effectively 280MByte/s (on linux 6.6.74, ondemand governor, ext4 FS, transfer with netatalk 4.1.1). But Helios64 only has to access a single 4TB SSD formatted to ext4 in this case. You could try to move your sata load to cpu5 ('echo 20' for the ahci interrupt) and the network load to cpu4 ('echo 10' for the xhci interrupt) and see if that helps (cpu5 is usually less frequently occupied compared to cpu4). # cat /etc/default/cpufrequtils ENABLE=true MIN_SPEED=600000 MAX_SPEED=1800000 GOVERNOR=ondemand Edited February 3 by ebin-dev 0 Quote
kantantana Posted February 3 Posted February 3 More observations and progress, I get 50MB/s when doing a dd if=fileFromNfs of=/dev/null bs=1M on non-helios, and helios is the one exporting the file over nfs (from zfs). But, when pinning the nfsd process to core 4 and other sysctl changes, I get 70Mb/s, yet not every time. Other observations, with governor performance it is more stable, and higher speeds, ondemand governor introduces retries and trasmission errors, overall even a steady read of 2GB is still slower than having it run with performance governor. The other change suggested by R1 after I asked it to compare this dtb settings concerning rtl8211e was a slight adjust ment of rx_delay and tx_delay values, to 0x23, which can be done with an overlay. I can be imagining after running so many tests, but the retry counts with iperf3 is not happening as often, and if pinning iperf3 to 4 or 5, even with ondemand it is more stable and get close to 900Mbit/s. This is added to my rc.local now echo 32768 > /sys/class/net/end0/queues/rx-0/rps_flow_cnt echo 32768 > /proc/sys/net/core/rps_sock_flow_entries for i in `pgrep "nfsd"` ; do ionice -c1 -p $i ; taskset -c -p 4 $i; done 0 Quote
snakekick Posted February 26 Posted February 26 Hello @prahal, sorry if I'm annoying. 25.2 is out, did it work out that you could bring in your fixes? many thanks 0 Quote
prahal Posted March 6 Posted March 6 On 2/26/2025 at 7:37 PM, snakekick said: sorry if I'm annoying. 25.2 is out, did it work out that you could bring in your fixes? I landed the restoration of the eMMC hs400 support and the fix for the helios64-heartbeat-led.service that I had broken in a previous commit. The upped voltages are not in. Though these upped voltage seems to help a lot of people, they are not the endgame. Ie I tried setting all the CPU b voltages to max 1.2, and I believe I can still crash the CPUs b with my test case... Also, I am onboarding on another board maintenance. Fixed an issue with a PL2303 USB serial adapter that it did not support 1.5Mbps but only 1.2Mbps.... In the meantime, I nailed down an issue on edge 6.14 that might also affect other version but not tested yet. I fixed it locally by setting the startup time for HDD rail a and rail b to have them not start at the same time by the kernel. Ie the upstream Linux kernel have the HDD rails defined, and it seems it restarts them when the kernel load thus draining too many amps on my board and I repeatedly had: Internal error: synchronous external abort: 0000000096000210 [#1] PREEMPT SMP (...) [ 3.890774] Call trace: [ 3.891012] rockchip_pcie_rd_conf+0xf4/0x1e8 (P) [ 3.891461] pci_bus_read_config_dword+0x7c/0xdc [ 3.891906] pci_bus_generic_read_dev_vendor_id+0x34/0x1b4 [ 3.892428] pci_scan_single_device+0xa0/0x108 [ 3.892857] pci_scan_slot+0x68/0x1c4 [ 3.893216] pci_scan_child_bus_extend+0x44/0x2cc [ 3.893668] pci_scan_bridge_extend+0x320/0x60c [ 3.894104] pci_scan_child_bus_extend+0x1b8/0x2cc [ 3.894564] pci_scan_root_bus_bridge+0x64/0xe4 [ 3.895000] pci_host_probe+0x30/0x108 [ 3.895367] rockchip_pcie_probe+0x43c/0x5e4 [ 3.895777] platform_probe+0x68/0xdc I cannot reproduce this PCIe failure after adding the 10 seconds delay that Kobol devs put in the u-boot between rail a and rail b startup. Though, 10 seconds seems a lot, but I have no clue why the Kobol team chose such a huge value. 2 Quote
snakekick Posted March 7 Posted March 7 Hello @prahal with your voltage fix I have an uptime of 158 days. Without, maybe 3-4 days if it boots at all. Your other fixes are also great. But they don't have the same impact by far. Even if the voltage is not a 100% fix in your eyes, for most people it is a game changer and enables operation in the first place, so I am surprised that you see so little priority there. Please don't get me wrong, I'm very grateful for the fix, I just think it should be implemented first, as I think stable operation is more important than how an LED flashes 1 Quote
BipBip1981 Posted March 9 Posted March 9 Hi, I agree with Snakekick, the voltage patch is for me the best thing for the helios64 run stable. Maybe it's not a perfect solution but: "It is better to have a good solution in time than a perfect one too late." 2 Quote
Alex T Posted April 1 Posted April 1 If the spec is correct the voltage accuracy of the PSU is ±5% and the output ripples is 120mVpp which is rather high for a good PSU. There are 2 condensers soldered to the HDD power cord to compensate for that and guard the HDD drives (kind of ugly, yet a cheap solution), but isn't it too much for the components of the PCB? https://wiki.kobol.io/helios64/files/psu/YHY_12V_PSU_Specification.pdf 0 Quote
prahal Posted April 1 Posted April 1 6 hours ago, Alex T said: If the spec is correct the voltage accuracy of the PSU is ±5% and the output ripples is 120mVpp which is rather high for a good PSU. There are 2 condensers soldered to the HDD power cord to compensate for that and guard the HDD drives (kind of ugly, yet a cheap solution), but isn't it too much for the components of the PCB? https://wiki.kobol.io/helios64/files/psu/YHY_12V_PSU_Specification.pdf Thanks, @Alex T, for your hindsights. Would plugging an ATX power supply instead of the original external power supply help sort this out? What kind of ATX PSU would be required? I had measured the voltage on the board with a voltmeter and got a little above 12V fine, but I believe to phase out transient voltage drops an oscilloscope is required (I got a portable oscilloscope a few months ago). Also, I have a test case (attached cpufreq-switching-2.c) that always crashes the big CPUs (even when I set a 5 milliseconds delay between transitions, with #define TRANSITION_DELAY 5000). I believe if the power supply is at fault, I should be able to see small voltage drops on the 12V rail on the board with the oscilloscope? cpufreq-switching-2.c 0 Quote
TDCroPower Posted May 14 Posted May 14 my bookworm installation is now over 1 year ago, has there been any further optimization in that time that should be adopted? Which setup combination is currently the most stable? Armbian 23.08.0-trunk Bookworm with Linux 6.6.8-edge-rockchip64 user@helios64:~# uname -a Linux helios64 6.6.8-edge-rockchip64 #1 SMP PREEMPT Wed Dec 20 16:02:07 UTC 2023 aarch64 GNU/Linux I have been successfully connecting my Helios64 to a 2.5G Unifi switch for some time now and recently noticed that it kept interrupting the transfer when transferring files via 1G client. I then deactivated the scatter/gather offloading option, but did not yet adjust the /etc/rc.local as described here... 0 Quote
greg396 Posted May 24 Posted May 24 Is there a way to copy the system from sda1 [M2-Sata SSD (2280)] to emmc (uboot) from the running system without losing the configuration? If it's possible, how can I do this including configuring the changes? What is the maximum size for the M2-Sata SSD (2280)? https://wiki.kobol.io/helios64/m2/ 0 Quote
BipBip1981 Posted August 18 Posted August 18 (edited) Hi, I continue to use file rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp on the last Helios64: v25.8.1 for Helios64 running Armbian Linux 6.12.42-current-rockchip64 Without this file, i have crash or problem with ciffer orperation (Luks and another program...) With this file, all it's Okok. Have a good day. Edited August 18 by BipBip1981 1 Quote
TDCroPower Posted August 18 Posted August 18 @BipBip1981 did you perform a clean install or update? I'm still using the following combination and am considering updating... 23.08.0-trunk Bookworm with Linux 6.6.8 I've had repeated connection problems over the last few months, which meant I couldn't access it via smb and all my backup jobs went wrong. However, it has been running stably again for some time now, which is very strange. 0 Quote
BipBip1981 Posted August 18 Posted August 18 Hi, Today i upgrade to Armbian Trixie my Helios64 with upgrade from bookworn to trixie, not clean install All seen to be Okok only with use of rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp file inside of original rk3399-kobol-helios64.dtb Only problems for moment are: - fancontrol not seen to work lm75 module... service crash... i will investigate soon if i have the time. - apt show warning with SHA1 checksum or anything i can't investigate for the moment 0 Quote
BipBip1981 Posted August 18 Posted August 18 (edited) For information, fancontrol, deamon or service systemd crash but work just with run fancontrol from shell in root. Seen to be a privileges problem like systemd log... i look this soon and post here my workaround Edited August 18 by BipBip1981 0 Quote
ebin-dev Posted August 19 Author Posted August 19 With linux 6.12 the optimizations in /etc/rc.local do not apply anymore since some configuration options have vanished. So if you like to have a stable 2.5Gbit/s network connection without timeouts, linux-6.6 is still recommended (bookworm and trixie). You can build it yourself using an Armbian snapshot (from Dec. 2024) or download a recent linux-6.6.100 from here. 0 Quote
BipBip1981 Posted August 20 Posted August 20 (edited) Hi, my feedback for fancontrol service here : for 2.5Gbits, i don't use. for rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp, same has i writed up: "It is better to have a good solution in time than a perfect one too late.", my helios64 going to the trash without this workaround. Edited August 20 by BipBip1981 0 Quote
greg396 Posted August 20 Posted August 20 https://forum.armbian.com/topic/30074-helios64-armbian-2308-bookworm-issues-solved/page/11/#findComment-224260 Quote With linux 6.12 the optimizations in /etc/rc.local do not apply anymore since some configuration options have vanished. wow, that's a bummer... how can I check if this happens also to my configuration? 0 Quote
snakekick Posted September 26 Posted September 26 This is my current uptime, with a running smb, torrent server, and 4 docker containers. It's a shame that the voltage fix never seems to be “officially” adopted. A system hardly needs to be any more stable than this 0 Quote
SteeMan Posted September 26 Posted September 26 2 hours ago, snakekick said: It's a shame that the voltage fix never seems to be “officially” adopted No one has ever submitted this for inclusion in Armbian. This is a community supported board. If anyone were to submit this as a PR it would almost certainly be included as the approval process for community supported boards is a low bar, basically that it doesn't break the build. 0 Quote
anmaped Posted September 28 Posted September 28 (edited) @ebin-dev not sure with your cpufreq settings as it should be 40000 otherwise the regulator cannot ramp-up the voltage so quickly. regulator@40 { compatible = "silergy,syr827"; reg = <0x40>; fcs,suspend-voltage-selector = <0x01>; pinctrl-names = "default"; pinctrl-0 = <0x83>; regulator-name = "vdd_cpu_b"; regulator-min-microvolt = <0xadf34>; regulator-max-microvolt = <0x16e360>; regulator-ramp-delay = <0x9c40>; regulator-always-on; regulator-boot-on; vin-supply = <0x82>; phandle = <0x0e>; regulator-state-mem { regulator-off-in-suspend; }; }; I have been using Helios64 for few years without any issues (four years ago, when I detected instability, I disabled the a72 cluster and continue only with updates, without any problems). Now that I have upgraded my network to 10 Gbits, I am experiencing problems with the 2.5 Gbits network card, which I did not use previously (link https://forum.armbian.com/topic/43858-helios-64-network-issues-with-armbian-2453-on-kernel-6639-frequent-disconnects/#findComment-225220 ). My theory is that the instability also affects USB 3.0 and RTL8156, causing crashes and triggering the watchdog. I also tried connecting an active switch to type C with an external RTL8156BG, and the watchdog was also triggered (some transmission errors, not many, but some). So I can confirm that with the a72 cluster and the 2.5 Gbit network card disabled, you have an extremely stable NAS (now with kernel 6.12.44). Does anyone have a damaged or non-functioning helios64 motherboard they can send? Edited September 28 by anmaped 0 Quote
anmaped Posted September 28 Posted September 28 To maintain changes between different kernel versions, you can use overlays. I did this by following some dts changes from @ebin-dev. Add this line user_overlays=rockchip-rk3399-op1-opp rockchip-rk3399-l2-cache to /boot/armbianEnv.txt Copy the dtbo files to /boot/overlay-user (mkdir -p /boot/overlay-user if the folder does not exist). rockchip-rk3399-l2-cache.dtborockchip-rk3399-op1-opp.dtborockchip-rk3399-op1-opp.dtsrockchip-rk3399-l2-cache.dts 1 Quote
ebin-dev Posted September 29 Author Posted September 29 (edited) On 9/28/2025 at 5:20 PM, anmaped said: @ebin-dev not sure with your cpufreq settings as it should be 40000 otherwise the regulator cannot ramp-up the voltage so quickly. Thanks for your comments. I did not touch the regulator@40 values at all - only the opp frequencies in line with suggestions from @prahal and some cache settings. cpufreq sampling_rates were changed to about 40000 (depending on the cluster) for kernels 6.6 by a script in /etc/rc.local. The script does not apply anymore in linux 6.12. Instead of disabling the A72 cluster altogether, reducing the burden on the CPUs during data transfers helps to substantially reduce crashes and avoids triggering the watchdog timer. P.S.: I bought a Rock-5B in October 2022 and I finally migrated everything to it. Edited September 29 by ebin-dev 0 Quote
TDCroPower Posted September 30 Posted September 30 @ebin-dev could you perhaps update your post 1 and post your latest instructions and upload the files there? That would make it much easier to find the stable files. 0 Quote
Trillien Posted October 24 Posted October 24 @BipBip1981, can you please share again your feedback on fancontrol running on Trixie ? The site can't display the image. 0 Quote
BipBip1981 Posted October 30 Posted October 30 Hi, my feedback with rk3399-kobol-helios64.dtb-6.12.xx-L2-hs400-opp and agressif fancontrol setting like this: # Helios64 PWM Fan Control Configuration # Temp source : /dev/thermal-cpu INTERVAL=10 FCTEMPS=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=/sys/devices/virtual/thermal/thermal_zone0/hwmon0/temp1_input /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=/sys/devices/virtual/thermal/thermal_zone0/hwmon0/temp1_input MINTEMP=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=30 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=30 MAXTEMP=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=50 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=50 MINSTART=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=20 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=20 MINSTOP=/sys/devices/platform/p6-fan/hwmon/hwmon6/pwm1=20 /sys/devices/platform/p7-fan/hwmon/hwmon5/pwm1=20 MINPWM=20 is: All it's Okok Without the tunning file DTB and Fancontrol, the nighmare restart. Today, update, original DTB file restore and CRASH when Luks begin to unciffer my DDs Il restore DTB file and my fancontrol setting and: Return to Okok situation. To conclude, i use my helios without problem when this files is installed. My helios64 always crash if i return to original setting after a update. 0 Quote
