AZ8 Posted September 26, 2023 Share Posted September 26, 2023 First, I have installed latest Armbian 23.8 Bookworm CLI, boot works fine, I can login Then, I have installed wireguard. As a dependency, wireguard install linux-image-6.1.0-12-rt-armmp After reboot device is unavailable in network (orange LAN LED blinking while green does not, I assume ethternet broken with this kernel) 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted September 26, 2023 Share Posted September 26, 2023 11 minutes ago, AZ8 said: linux-image-6.1.0-12-rt-armmp Looks like Debian stock kernel which obviously won't work with this board. Try installing wireguard with "--no-install-recommends" switch 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted September 26, 2023 Share Posted September 26, 2023 2 hours ago, Werner said: Looks like Debian stock kernel which obviously won't work with this board. Looks more like manually installed kernel, given that kernel is a realtime kernel. Ofcourse that does mean its not our issue as its not our kernel 0 Quote Link to comment Share on other sites More sharing options...
AZ8 Posted September 26, 2023 Author Share Posted September 26, 2023 No, I did not manually installed this kernel, apt installed it as a dependency for wireguard 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted September 26, 2023 Share Posted September 26, 2023 11 minutes ago, AZ8 said: it as a dependency for wireguard Then you need to tell them to fix this. 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted September 26, 2023 Share Posted September 26, 2023 16 minutes ago, AZ8 said: No, I did not manually installed this kernel, apt installed it as a dependency for wireguard You only needed to install wireguard-tools package, and I believe that should be already installed in armbian image. Wireguard on the other hand is a metapackage that also tries to install the kernel modules which are already available in armbian. To revert back to armbian kernel, run "apt-get install --reinstall linux-image-current-sunxi linux-dtb-current-sunxi" 0 Quote Link to comment Share on other sites More sharing options...
