WarHawk_AVG Posted November 14, 2023 Posted November 14, 2023 diagnostics listing of Orange Pi Zero 2W http://ix.io/4Lwr Not sure if this helps..but the stock build is lacking...plus I am getting 1.0 cpu usage at idle Orange Pi 1.0.0 user-built System too busy for benchmarking: 16:33:21 up 25 min, 3 users, load average: 1.15, 1.03, 0.92 System too busy for benchmarking: 16:33:26 up 25 min, 3 users, load average: 1.14, 1.03, 0.92 System too busy for benchmarking: 16:33:31 up 25 min, 3 users, load average: 1.13, 1.03, 0.93 System too busy for benchmarking: 16:33:36 up 25 min, 3 users, load average: 1.12, 1.03, 0.93 System too busy for benchmarking: 16:33:41 up 25 min, 3 users, load average: 1.11, 1.03, 0.93 Wish there was an official Armbian build...it usually seems much more "complete" 0 Quote
Werner Posted November 15, 2023 Posted November 15, 2023 Armbian does not support this board. Any image you may find in the web are made by 3rd party. Ask where you got the image from. 0 Quote
Gunjan Gupta Posted November 15, 2023 Posted November 15, 2023 @WarHawk_AVG As Werner said, we don't support this board. But taking an educated guess, I will suggest you blacklist sprdwl_ng module or if its loading through a service or from /etc/modules then remove the same from there. That will lower your load average. You will lose wifi support though as that module is the wifi driver. 0 Quote
sbourouis Posted February 1, 2024 Posted February 1, 2024 (edited) I've installed rolling os build from github of Armbian for Orange Pi 3 zero on the Orange Pi zero 2w and it worked. Both Debian Desktop and Minimal. https://github.com/armbian/os Edited February 1, 2024 by sbourouis 1 Quote
robertoj Posted February 8, 2024 Posted February 8, 2024 Can you check WiFi, Bluetooth and HDMI? 0 Quote
ME_ Posted March 2, 2024 Posted March 2, 2024 (edited) I can confirm, after installing Armbian for Orange Pi 3 zero on the Orange Pi zero 2w that WiFi, Bluetooth and HDMI is working! me@OPIZ2W:~$ DISPLAY=:0 glxinfo -B name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Panfrost (0xffffffff) Device: Mali-G31 (Panfrost) (0xffffffff) Version: 22.3.6 Accelerated: yes Video memory: 3932MB Unified memory: yes Preferred profile: core (0x1) Max core profile version: 3.1 Max compat profile version: 3.1 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.1 OpenGL vendor string: Panfrost OpenGL renderer string: Mali-G31 (Panfrost) OpenGL core profile version string: 3.1 Mesa 22.3.6 OpenGL core profile shading language version string: 1.40 OpenGL core profile context flags: (none) OpenGL version string: 3.1 Mesa 22.3.6 OpenGL shading language version string: 1.40 OpenGL context flags: (none) OpenGL ES profile version string: OpenGL ES 3.1 Mesa 22.3.6 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10 Edited March 2, 2024 by ME_ 0 Quote
Ariel Posted March 2, 2024 Posted March 2, 2024 can you be kind enough to link the OS you used? tried to follow sbourouis's link (https://github.com/armbian/os) but couldnt find for op zero 3 0 Quote
SteeMan Posted March 2, 2024 Posted March 2, 2024 @Ariel You are looking in the wrong location. Here are where the community rolling releases are: https://github.com/armbian/community 0 Quote
ME_ Posted March 2, 2024 Posted March 2, 2024 You’ll find bookworm and jammy Community releases here: https://www.armbian.com/orange-pi-zero-3/ I used bookworm 0 Quote
mcyzyk Posted March 7, 2024 Posted March 7, 2024 Darn. One thing I'm seeing is that Audio is not supported in these Community versions. HDMI with no audio -- not useful. 0 Quote
Kazymir Posted March 14, 2024 Posted March 14, 2024 If i can, yes there is a little differnce beetwen zero3 and zero2W, the ethernet port, is-it possible to add another eth port inside the dtb for a full compatibility with the zero2w? for the 2W the eth port is directly connect on the processor H618 best regards 0 Quote
TRay Posted March 14, 2024 Posted March 14, 2024 Looking on news about kernel 6.8 : https://www.cnx-software.com/2024/03/11/linux-6-8-release-notable-changes-arm-risc-v-mips-architectures/#arm-updates-in-linux-6-8 it was added support for Orange Pi Zero 2W: Quote Arm updates in Linux 6.8 As usual, there were a lot of changes to the Arm architecture: Allwinner Allwinner A100 – RGB LED controller Allwinner H616 – ASoC driver adds SPDIF hardware block Allwinner T113-S3 – Thermal controller New devices Orange Pi Zero 2W single board computer (Allwinner H618) ... 1 Quote
thuvasooriya Posted March 23, 2024 Posted March 23, 2024 @TRay So when can we expect a supported build for orangepi zero 2w :) 0 Quote
SteeMan Posted March 23, 2024 Posted March 23, 2024 There are no plans for Armbian to officially support this board. If community members step up to the task, there may a a community maintained version specific to that board. But currently people report success with the zero3 community maintained build working on the zero2w. 0 Quote
thuvasooriya Posted March 23, 2024 Posted March 23, 2024 (edited) @SteeMan Thank you for the quick response! sorry for posting without searching through the whole forum, found some interesting builds to test on Orange Pi Zero 3 forum, I'll follow the development there. Thanks again. For those who stumble upon here in the future: Edited March 23, 2024 by thuvasooriya added links 0 Quote
xberzerker Posted April 18, 2024 Posted April 18, 2024 +1 to opi zero 3 bookworm from link below booting ok on opi zero 2w https://github.com/armbian/community/releases/download/24.5.0-trunk.433/Armbian_community_24.5.0-trunk.433_Orangepizero3_bookworm_current_6.6.28_minimal.img.xz.torrent 0 Quote
xberzerker Posted April 18, 2024 Posted April 18, 2024 dang ethernet not found, just like it seems to be mentioned here already. any solutions to that? 0 Quote
skm Posted April 29, 2024 Posted April 29, 2024 There are now image download links here: https://www.armbian.com/orange-pi-zero-2w/ Installed fine for me (2GB device), wifi working, ethernet probably not since "ip addr" doesn't show the interface. Also the power button on the expansion board has no effect, but it all looks very promising. 0 Quote
ME_ Posted May 11, 2024 Posted May 11, 2024 (edited) Hi - I installed the latest images but unfortunately the GPU is not accelerated. Somebody has an idea how to use the PANFROST Zitat Vendor: Panfrost (0xffffffff) Device: Mali-G31 (Panfrost) (0xffffffff) Version: 22.3.6 Accelerated: yes Video memory: 3932MB drivers? name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Mesa/X.org (0xffffffff) Device: llvmpipe (LLVM 15.0.6, 128 bits) (0xffffffff) Version: 22.3.6 Accelerated: no Video memory: 3932MB Unified memory: yes Preferred profile: core (0x1) Max core profile version: 4.5 Max compat profile version: 4.5 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.2 OpenGL vendor string: Mesa/X.org OpenGL renderer string: llvmpipe (LLVM 15.0.6, 128 bits) OpenGL core profile version string: 4.5 (Core Profile) Mesa 22.3.6 OpenGL core profile shading language version string: 4.50 OpenGL core profile context flags: (none) OpenGL core profile profile mask: core profile OpenGL version string: 4.5 (Compatibility Profile) Mesa 22.3.6 OpenGL shading language version string: 4.50 OpenGL context flags: (none) OpenGL profile mask: compatibility profile OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.3.6 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20 Edited May 11, 2024 by ME_ 0 Quote
madeofstown Posted May 14, 2024 Posted May 14, 2024 Forgive me if I am missing something. I have a 1.5GB oPiZ2W and I cannot get it to boot with the community builds or the unofficial builds. No green activity light, just the red power light. No output from HDMI. I've let it sit like this for 15 minutes and still nothing. Is there something else I need to do to get this to boot? I've had no issues with the Debian/Ubuntu images provided by OrangePi. 0 Quote
SteeMan Posted May 14, 2024 Posted May 14, 2024 1 hour ago, madeofstown said: I have a 1.5GB oPiZ2W The issue is the 1.5gb memory. That particular memory configuration isn't currently working. Look back in the threads for the 2w and 3 and you can see a lot of discussion on this topic. 0 Quote
madeofstown Posted May 14, 2024 Posted May 14, 2024 I'll take your word for it @SteeMan, thank you. When I search for "orangepi 1.5GB" my post is the only one that comes up. Ill try different combinations but you already gave me my answer. 0 Quote
SteeMan Posted May 14, 2024 Posted May 14, 2024 https://forum.armbian.com/topic/29202-orange-pi-zero-3 @madeofstown If you care there was a discussion the last week on this topic in the above thread (the 2w and 3 are similar). 0 Quote
ag123 Posted May 14, 2024 Posted May 14, 2024 @madeofstown try out the orange pi zero 3 community images to see if it helps https://www.armbian.com/orange-pi-zero-3/ zero 2w don't have the motorcomm ethernet (requires an extension/expansion board accordingly), that's what I understand it to be. hopes that works still on zero 2w 0 Quote
madeofstown Posted May 20, 2024 Posted May 20, 2024 (edited) @ag123 Thank you. I was able to apply that patch and now Armbian is running on my OPIZ2W 1.5GB! One more question. I have a LoRa/GNSS hat that requires the use of Serial 0 for communication with the GNSS model. How would I go about disabling Armbian debug outputing to that? I would rather not have to use bodge wires. `gpioinfo` shows me that the 2 pins are used by the kernel. Do I need to recompile the kernel to change this? Seems like a lot of the hats/shields that use Serial need to use Serial0... So I'm thinking there must be a simple way to get it working in Armbian. Edited May 20, 2024 by madeofstown 0 Quote
ag123 Posted May 20, 2024 Posted May 20, 2024 @madeofstown I'd guess it is good to leave the default serial uart console running there as otherwise if things goofs, you may have no means to login onto the board. with the serial console, you can connect a usb-uart serial dongle and login to Armbian on the board. but if you insist you can nevertheless try going into /usr/lib/systemd/system look for those *getty* (e.g. ls *getty*), it would be one of those services. but that for debug output I'm not sure about that though, a google search I'd guess would get some leads e.g. https://superuser.com/questions/351387/how-to-stop-kernel-messages-from-flooding-my-console https://wiki.archlinux.org/title/working_with_the_serial_console I'd suggest to browse that same Orange Pi Zero 3 thread and figure out how to use a different serial uart port, there are probably more than a single uart port available on Orange Pi Zero 2W or Orange Pi Zero 3. using a different serial comm (uart) port is the correct solution in your case and you won't need to be bothered about console messages as they won't be there. 0 Quote
madeofstown Posted May 20, 2024 Posted May 20, 2024 Using a different UART is not really practical with a hat/shield designed to use UART0... It would be better for the system to use one that isn't commonly required by hats/shields to be the debug interface. I'll keep looking around. 0 Quote
garbo Posted May 21, 2024 Posted May 21, 2024 Hi, I am new here but been playing with the opi zero 2w for a bit with the zero 3 image. So happy to now see 2w images have appeared. I have the expansion board and was hoping to get the ethernet port working at some point. I mainly want to use this device to run headless and be able to shut it down when I push one of the buttons on the expansion board. Is this possible with any of the current images? 0 Quote
mcyzyk Posted June 4, 2024 Posted June 4, 2024 That Community Version of Ubuntu Jammy is working really well for me on this device Orange Pi Zero 2W. With one exception: No sound card found. Maybe these are clues on how to bake this in to next Community Version Ubuntu Jammy update, not sure?: https://forum.armbian.com/topic/37718-sound-on-h616h618-socs/#comment-188117 https://forum.armbian.com/topic/40625-armbian-build-pr-sound-allwinner-h616-h618-socs/#comment-193609 0 Quote
Werner Posted June 4, 2024 Posted June 4, 2024 1 minute ago, mcyzyk said: With one exception: No sound card found. Try this: https://github.com/armbian/build/pull/6694#pullrequestreview-2096146300 0 Quote
