WarHawk_AVG Posted November 14, 2023 Share Posted November 14, 2023 diagnostics listing of Orange Pi Zero 2W http://ix.io/4Lwr Not sure if this helps..but the stock build is lacking...plus I am getting 1.0 cpu usage at idle Orange Pi 1.0.0 user-built System too busy for benchmarking: 16:33:21 up 25 min, 3 users, load average: 1.15, 1.03, 0.92 System too busy for benchmarking: 16:33:26 up 25 min, 3 users, load average: 1.14, 1.03, 0.92 System too busy for benchmarking: 16:33:31 up 25 min, 3 users, load average: 1.13, 1.03, 0.93 System too busy for benchmarking: 16:33:36 up 25 min, 3 users, load average: 1.12, 1.03, 0.93 System too busy for benchmarking: 16:33:41 up 25 min, 3 users, load average: 1.11, 1.03, 0.93 Wish there was an official Armbian build...it usually seems much more "complete" 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted November 15, 2023 Share Posted November 15, 2023 Armbian does not support this board. Any image you may find in the web are made by 3rd party. Ask where you got the image from. 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted November 15, 2023 Share Posted November 15, 2023 @WarHawk_AVG As Werner said, we don't support this board. But taking an educated guess, I will suggest you blacklist sprdwl_ng module or if its loading through a service or from /etc/modules then remove the same from there. That will lower your load average. You will lose wifi support though as that module is the wifi driver. 0 Quote Link to comment Share on other sites More sharing options...
sbourouis Posted February 1 Share Posted February 1 (edited) I've installed rolling os build from github of Armbian for Orange Pi 3 zero on the Orange Pi zero 2w and it worked. Both Debian Desktop and Minimal. https://github.com/armbian/os Edited February 1 by sbourouis 1 Quote Link to comment Share on other sites More sharing options...
robertoj Posted February 8 Share Posted February 8 Can you check WiFi, Bluetooth and HDMI? 0 Quote Link to comment Share on other sites More sharing options...
ME_ Posted March 2 Share Posted March 2 (edited) I can confirm, after installing Armbian for Orange Pi 3 zero on the Orange Pi zero 2w that WiFi, Bluetooth and HDMI is working! me@OPIZ2W:~$ DISPLAY=:0 glxinfo -B name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Panfrost (0xffffffff) Device: Mali-G31 (Panfrost) (0xffffffff) Version: 22.3.6 Accelerated: yes Video memory: 3932MB Unified memory: yes Preferred profile: core (0x1) Max core profile version: 3.1 Max compat profile version: 3.1 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.1 OpenGL vendor string: Panfrost OpenGL renderer string: Mali-G31 (Panfrost) OpenGL core profile version string: 3.1 Mesa 22.3.6 OpenGL core profile shading language version string: 1.40 OpenGL core profile context flags: (none) OpenGL version string: 3.1 Mesa 22.3.6 OpenGL shading language version string: 1.40 OpenGL context flags: (none) OpenGL ES profile version string: OpenGL ES 3.1 Mesa 22.3.6 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10 Edited March 2 by ME_ 0 Quote Link to comment Share on other sites More sharing options...
Ariel Posted March 2 Share Posted March 2 can you be kind enough to link the OS you used? tried to follow sbourouis's link (https://github.com/armbian/os) but couldnt find for op zero 3 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted March 2 Share Posted March 2 @Ariel You are looking in the wrong location. Here are where the community rolling releases are: https://github.com/armbian/community 0 Quote Link to comment Share on other sites More sharing options...
ME_ Posted March 2 Share Posted March 2 You’ll find bookworm and jammy Community releases here: https://www.armbian.com/orange-pi-zero-3/ I used bookworm 0 Quote Link to comment Share on other sites More sharing options...
mcyzyk Posted March 7 Share Posted March 7 Darn. One thing I'm seeing is that Audio is not supported in these Community versions. HDMI with no audio -- not useful. 0 Quote Link to comment Share on other sites More sharing options...
Kazymir Posted March 14 Share Posted March 14 If i can, yes there is a little differnce beetwen zero3 and zero2W, the ethernet port, is-it possible to add another eth port inside the dtb for a full compatibility with the zero2w? for the 2W the eth port is directly connect on the processor H618 best regards 0 Quote Link to comment Share on other sites More sharing options...
TRay Posted March 14 Share Posted March 14 Looking on news about kernel 6.8 : https://www.cnx-software.com/2024/03/11/linux-6-8-release-notable-changes-arm-risc-v-mips-architectures/#arm-updates-in-linux-6-8 it was added support for Orange Pi Zero 2W: Quote Arm updates in Linux 6.8 As usual, there were a lot of changes to the Arm architecture: Allwinner Allwinner A100 – RGB LED controller Allwinner H616 – ASoC driver adds SPDIF hardware block Allwinner T113-S3 – Thermal controller New devices Orange Pi Zero 2W single board computer (Allwinner H618) ... 1 Quote Link to comment Share on other sites More sharing options...
thuvasooriya Posted March 23 Share Posted March 23 @TRay So when can we expect a supported build for orangepi zero 2w :) 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted March 23 Share Posted March 23 There are no plans for Armbian to officially support this board. If community members step up to the task, there may a a community maintained version specific to that board. But currently people report success with the zero3 community maintained build working on the zero2w. 0 Quote Link to comment Share on other sites More sharing options...
thuvasooriya Posted March 23 Share Posted March 23 (edited) @SteeMan Thank you for the quick response! sorry for posting without searching through the whole forum, found some interesting builds to test on Orange Pi Zero 3 forum, I'll follow the development there. Thanks again. For those who stumble upon here in the future: Edited March 23 by thuvasooriya added links 0 Quote Link to comment Share on other sites More sharing options...
xberzerker Posted April 18 Share Posted April 18 +1 to opi zero 3 bookworm from link below booting ok on opi zero 2w https://github.com/armbian/community/releases/download/24.5.0-trunk.433/Armbian_community_24.5.0-trunk.433_Orangepizero3_bookworm_current_6.6.28_minimal.img.xz.torrent 0 Quote Link to comment Share on other sites More sharing options...
xberzerker Posted April 18 Share Posted April 18 dang ethernet not found, just like it seems to be mentioned here already. any solutions to that? 0 Quote Link to comment Share on other sites More sharing options...
skm Posted April 29 Share Posted April 29 There are now image download links here: https://www.armbian.com/orange-pi-zero-2w/ Installed fine for me (2GB device), wifi working, ethernet probably not since "ip addr" doesn't show the interface. Also the power button on the expansion board has no effect, but it all looks very promising. 0 Quote Link to comment Share on other sites More sharing options...
ME_ Posted Saturday at 09:27 AM Share Posted Saturday at 09:27 AM (edited) Hi - I installed the latest images but unfortunately the GPU is not accelerated. Somebody has an idea how to use the PANFROST Zitat Vendor: Panfrost (0xffffffff) Device: Mali-G31 (Panfrost) (0xffffffff) Version: 22.3.6 Accelerated: yes Video memory: 3932MB drivers? name of display: :0 display: :0 screen: 0 direct rendering: Yes Extended renderer info (GLX_MESA_query_renderer): Vendor: Mesa/X.org (0xffffffff) Device: llvmpipe (LLVM 15.0.6, 128 bits) (0xffffffff) Version: 22.3.6 Accelerated: no Video memory: 3932MB Unified memory: yes Preferred profile: core (0x1) Max core profile version: 4.5 Max compat profile version: 4.5 Max GLES1 profile version: 1.1 Max GLES[23] profile version: 3.2 OpenGL vendor string: Mesa/X.org OpenGL renderer string: llvmpipe (LLVM 15.0.6, 128 bits) OpenGL core profile version string: 4.5 (Core Profile) Mesa 22.3.6 OpenGL core profile shading language version string: 4.50 OpenGL core profile context flags: (none) OpenGL core profile profile mask: core profile OpenGL version string: 4.5 (Compatibility Profile) Mesa 22.3.6 OpenGL shading language version string: 4.50 OpenGL context flags: (none) OpenGL profile mask: compatibility profile OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.3.6 OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20 Edited Saturday at 10:45 AM by ME_ 0 Quote Link to comment Share on other sites More sharing options...
madeofstown Posted Tuesday at 01:43 PM Share Posted Tuesday at 01:43 PM Forgive me if I am missing something. I have a 1.5GB oPiZ2W and I cannot get it to boot with the community builds or the unofficial builds. No green activity light, just the red power light. No output from HDMI. I've let it sit like this for 15 minutes and still nothing. Is there something else I need to do to get this to boot? I've had no issues with the Debian/Ubuntu images provided by OrangePi. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted Tuesday at 02:53 PM Share Posted Tuesday at 02:53 PM 1 hour ago, madeofstown said: I have a 1.5GB oPiZ2W The issue is the 1.5gb memory. That particular memory configuration isn't currently working. Look back in the threads for the 2w and 3 and you can see a lot of discussion on this topic. 0 Quote Link to comment Share on other sites More sharing options...
madeofstown Posted Tuesday at 03:59 PM Share Posted Tuesday at 03:59 PM I'll take your word for it @SteeMan, thank you. When I search for "orangepi 1.5GB" my post is the only one that comes up. Ill try different combinations but you already gave me my answer. 0 Quote Link to comment Share on other sites More sharing options...
SteeMan Posted Tuesday at 06:11 PM Share Posted Tuesday at 06:11 PM https://forum.armbian.com/topic/29202-orange-pi-zero-3 @madeofstown If you care there was a discussion the last week on this topic in the above thread (the 2w and 3 are similar). 0 Quote Link to comment Share on other sites More sharing options...
ag123 Posted Tuesday at 07:11 PM Share Posted Tuesday at 07:11 PM @madeofstown try out the orange pi zero 3 community images to see if it helps https://www.armbian.com/orange-pi-zero-3/ zero 2w don't have the motorcomm ethernet (requires an extension/expansion board accordingly), that's what I understand it to be. hopes that works still on zero 2w 0 Quote Link to comment Share on other sites More sharing options...
