Hello Igor,
I am using vanilla 4.4 for labomo-r1
it seems zram module is missing. Do you intend to compile the kernel with this option, please?
gr@bpi:~$ sudo modprobe -Rf zram
modprobe: FATAL: Module zram not found.
On raspbian, kernel 3.18.x-4.1.x, there is a kernel module "zram" useful for embedded systems... working fine (also using on my x86 laptop)
https://wiki.gentoo.org/wiki/Zram
Nice week-end,
Regards,
Guillaume
I already found and build a kernel ... Will be inside next build. Over and out ;)
Thanks!
Igor,
Thanks it is fine with http://mirror.igorpecovnik.com/test/linux-image-next-sunxi_4.5_armhf.deb
gr@bpi:~$ cat /proc/version
Linux version 4.2.3-sunxi (root@kitchen) (gcc version 4.8.2 (Ubuntu/Linaro 4.8.2-16ubuntu4) ) #16 SMP Fri Oct 9 23:08:18 CEST 2015
gr@bpi:~$ lsmod
zram                   17790  2
lz4_compress            3201  1 zram
gr@bpi:~$ swapon -s
Filename                                Type            Size    Used    Priority
/home2/swap                             file            4999996 0       -1
/dev/zram0                              partition       256980  0       5
/dev/zram1                              partition       256980  0       5
ok, now testing... compiling thunderbird 42b1 on my "labomo-r1" FTTH home router :)
Edit : Igor, this is an awesome piece of work! :-)
Edit 2 : I am not sure if it is really useful here
CONFIG_CLEANCACHE=y
CONFIG_FRONTSWAP=y
Edit 3 :
compared to :
- (arm) Raspbian : zsmalloc seems to be missing
- (x86-amd64) Ubuntu 14.04 : the same as armbian : modules zram + lz4_compress
pi@pi ~ $ lsmod
zram                   20112  0
lz4_compress            3100  1 zram
zsmalloc               10430  1 zram
pi@pi ~ $ cat /proc/version
Linux version 4.1.10-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #820 SMP PREEMPT Sun Oct 4 16:26:51 BST 2015
Edit 4:
zsmalloc is probably useful : allocate small object to reduce memory fragmentation
http://lwn.net/Articles/477067/
zsmalloc is builtin, so ok
gr@bpi:~$ sudo modprobe --show-depends zram
insmod /lib/modules/4.2.3-sunxi/kernel/lib/lz4/lz4_compress.ko
insmod /lib/modules/4.2.3-sunxi/kernel/drivers/block/zram/zram.ko
gr@bpi:~$ sudo modprobe --show-depends -v zsmalloc
builtin zsmalloc
