Alexx Posted April 19 Share Posted April 19 Hi @Igor. All the above are 5 commands? 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted April 20 Author Share Posted April 20 On 4/20/2024 at 2:00 AM, Alexx said: All the above are 5 commands? Yes. If you copy and paste everything into the terminal, it should do the job. 0 Quote Link to comment Share on other sites More sharing options...
Robin Palmquist Posted April 30 Share Posted April 30 Would love to see a Radxa Rock 5B version 0 Quote Link to comment Share on other sites More sharing options...
_Rick Posted May 4 Share Posted May 4 (edited) Hi Igor, great work on this HA supervised image for the Edge2 oowow. I install it and all fine, but no access to the usual http:ip:8123 and when I try to list the services or the actual "gdbus introspect --system --dest io.hass.os --object-path /io/hass/os" error: "The name io.hass.os was not provided by any .service files" If I can update or re-install the HA would be nice to know. System: Khadas Edge2 Pro, Install "Armbian_24.2.2_Khadas-edge2_bookworm_legacy_5.10.160.oowow.img.xz" from ooWOW All working fine, I can connect with SSH as usual, can do updates or install; but nothing else for Home Assistant. Any comment is apreciated, have a good one. Richard. Edited May 4 by _Rick 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 5 Author Share Posted May 5 23 hours ago, _Rick said: but nothing else for Home Assistant. Try this image https://github.com/armbian/distribution/releases/download/24.2.2/Armbian_24.2.2_Khadas-edge2_bookworm_vendor_6.1.43-homeassistant_minimal.oowow.img.xz On 4/30/2024 at 7:10 PM, Robin Palmquist said: Radxa Rock 5B version 5b https://github.com/armbian/distribution/releases/download/24.2.2/Armbian_24.2.2_Rock-5b_bookworm_vendor_6.1.43-homeassistant_minimal.img.xz 5c https://github.com/armbian/distribution/releases/download/24.2.2/Armbian_24.2.2_Rock-5c_bookworm_vendor_6.1.43-homeassistant_minimal.img.xz None of those was tested. 0 Quote Link to comment Share on other sites More sharing options...
_Rick Posted May 6 Share Posted May 6 Hi Igor, the image: "Armbian_24.2.2_Khadas-edge2_bookworm_vendor_6.1.43-homeassistant_minimal.oowow.img.xz" work and after few mins I have access as regular HA. There are few warnings: Unsupported system - AppArmor issues : System is unsupported because AppArmor is working incorrectly and add-ons are running in an unprotected and insecure way. Unsupported system - CGroup version: System is unsupported because the wrong version of Docker CGroup is in use. Is it something you can fix in the image and I'll wait or I can upgrade and it will be fixed ? You did a great job man! I'll try to fix it for now, again thank you ! Richard. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 6 Author Share Posted May 6 1 minute ago, _Rick said: Unsupported system - AppArmor issues : System is unsupported because AppArmor is working incorrectly and add-ons are running in an unprotected and insecure way. Unsupported system - CGroup version: System is unsupported because the wrong version of Docker CGroup is in use. This is hard to say as we are talking about non standard Linux kernel. If HA works, IMO you can safely ignore those problems or: 4 minutes ago, _Rick said: Is it something you can fix in the image and I'll wait or I can upgrade and it will be fixed ? New kernel is being developed for several years and it might already be working for this use case. You can try by switching to it (armbian-config -> system -> alternative kernels -> select EDGE 6.8.something), but I give you no warranty that it will work. You might need to start with a new image. If it works well, report back and we will generate images by using that kernel. I know many things in graphical areas are missing there, but for this uses case we don't need HDMI output anyway ... 0 Quote Link to comment Share on other sites More sharing options...
_Rick Posted May 6 Share Posted May 6 Hi Igor, if this can help or you might already know this: AppArmor issues: "The solution: If the AppArmor is not enabled on your host, add this to the Linux kernel boot parameters: apparmor=1 security=apparmor and then reboot your operating system." CGroup version: "The solution: In a supervised installation if you have switched to CGroup v2 you will need to revert what you did. Or you can re-run the supervised installer to fix it. Please be sure to reboot the system after the installation is done. You should never see this issue on Home Assistant OS as all versions of the OS ship with a supported CGroup version." If that help you, have a great one! Richard. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 6 Author Share Posted May 6 22 minutes ago, _Rick said: you might already know this I will look into this when time permits but I don't promise to stick in researching very long. Kernel behind this specific hardware, this image, is developed with a solo purpose - to sell hardware and its dead end. For amateur usage, running desktop and similar toying this is usually enough. Rockchip cares only that hardware features works, everything else is unmaintained. We are looking at possible impossible tasks, weeks of work, which is something I can't afford to do in exchange for compliments. This is not Armbian problem. Try switching to normal mainline kernel (named EDGE, 6.8.y, that should not have those errors and that I know where to look for fixing if warnings will pop up. Also I can predict I will not lost more then few hours). 0 Quote Link to comment Share on other sites More sharing options...
_Rick Posted May 6 Share Posted May 6 Hi Igor, I understand, I agree, this forum is for the Armbian, not the board. Thank you again for your time, for what is working now, it is waaaayyy faster than my Pi3b !!! In any case, a big thank you for your time! Richard. 1 Quote Link to comment Share on other sites More sharing options...
nyok Posted May 8 Share Posted May 8 Tested on Rock5b: Needed to solve apparmor warning : Check that extraargs=systemd.unified_cgroup_hierarchy=0 apparmor=1 security=apparmor in /boot/armbianEnv.txt Then update-initramfs -u reboot 1 Quote Link to comment Share on other sites More sharing options...
Igor Posted May 8 Author Share Posted May 8 4 hours ago, nyok said: Needed to solve apparmor warning Thank you! https://github.com/armbian/os/pull/184 In case anyone can verify if this works / test this assembly, before end of this month, it would be awesome! Edit: tested 0 Quote Link to comment Share on other sites More sharing options...
Travis 90x Posted May 15 Share Posted May 15 (edited) @Igor In the past I edit the supervised installation script (I've updated it now) to skip machine checks: all work fine (HACS too, on X96 max+ S905X3) and at that time debian 12 was not supported by HAOS. Now it is supported (I'm tring with Armbian 24 unofficial inovato-quadra on T95 Max+ with Allwinner H6) but "Unsupported OS" still remain, maybe because of Armbian as >derivate< (?) Log: [supervisor.resolution.evaluations.base] Detected unsupported OS: Armbian-unofficial 24.5.0-trunk bookworm (more-info: https://www.home-assistant.io/more-info/unsupported/os) https://travis90x.altervista.org/home-assistant-supervised-on-armbian-tvbox/ https://github.com/Travis90x/supervised-installer Edited May 15 by Travis 90x 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 13 Author Share Posted June 13 On 5/16/2024 at 12:11 AM, Travis 90x said: Now it is supported (I'm tring with Armbian 24 unofficial inovato-quadra on T95 Max+ with Allwinner H6) but "Unsupported OS" still remain, maybe because of Armbian as >derivate< This part https://github.com/armbian/os/blob/main/userpatches/extensions/ha.sh#L110-L111 is critical. On 5/16/2024 at 12:11 AM, Travis 90x said: I'm tring with Armbian 24 unofficial inovato-quadra on T95 Max+ with Allwinner H6 BTW. This hardware will now be officially supported https://www.armbian.com/inovato-quadra/ and there will be dedicated HA image too. Ofc if image is used on some other hardware there is no warranty that things will work. 0 Quote Link to comment Share on other sites More sharing options...
Home Assistant Posted June 29 Share Posted June 29 I wrote the image to SD card and booted with it. I have a doubt. Should I boot with the switch in SPI or wMMC? I tried in the eMMC position and the server does not boot. Does not get a ip even. 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 29 Author Share Posted June 29 51 minutes ago, Home Assistant said: I wrote the image to SD card and booted with it. I have a doubt. Should I boot with the switch in SPI or wMMC? I tried in the eMMC position and the server does not boot. Does not get a ip even. Nobody knows what you are doing. Which device? 0 Quote Link to comment Share on other sites More sharing options...
Home Assistant Posted June 29 Share Posted June 29 Sorry about that. I had flashed Armbian minimal home assistant package to sd card for installation on Odroid N2+. My doubt is should I keep the switch in SPI or eMMC to boot? Thanks 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted June 30 Author Share Posted June 30 21 hours ago, Home Assistant said: sd card for installation on Odroid N2+ You always proceed with Armbian install instructions. If there are some special hacks, they are described at download pages https://www.armbian.com/odroid-n2/ the rest is generic https://docs.armbian.com/User-Guide_Getting-Started/ All our images works without Hardkernel proprietary SPI boot loader, so choose eMMC. In case you have troubles with HA image, try some other (1st minimal was tested manually) from download page to make sure. Getting IP takes some time, but more then few minutes (big slow SD card). 0 Quote Link to comment Share on other sites More sharing options...
Tera Posted Wednesday at 10:51 AM Share Posted Wednesday at 10:51 AM Hello, I am new in linux enviroment, so plese apologized me if I'll do stupid questions. i got a ondorid N2+ with Armbian 24.2.2 bookworm Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.6.32-current-meson64 Architecture: arm64 and home assistant supervised preinstalled. All works fine and thank you for your great job. Inside home assistant I have installed Nginx plugin and Duckdns to manange communication in SSL with external services (like google assistant). Now I would like to install nginx manager as "normal" container directly outside of Homeassistant and not as homeassistant container: homeassistant/aarch64-addon-nginx_proxy:3.9.0 To do that I prefer to use docker compose (because the manage of parameter it's seem most easy to do). And now the question: It is possible to reverse "configuration" of preinstalled homeassistant to a yaml configuration? If yes, can you help me to find this information to recreating the yaml config? Or, I can manage only nginx manager container with docker compose (plugin) + config.yaml? Some note or advice about that? I hope not in OP. Thank you in advance. 0 Quote Link to comment Share on other sites More sharing options...
