J.Ayuso Posted January 29, 2024 Posted January 29, 2024 (edited) Hi, where can I find kernel headers for RPi5 jammy? linux-headers-6.1.68.current-bcm2712 ? This version of Armbian is really usefull because it is the only one that can run a version of ROS natively on a RPi5, but I need the headers to build drivers Thanks Edited January 29, 2024 by J.Ayuso 0 Quote
jmaus Posted January 29, 2024 Posted January 29, 2024 I was about to ask/write the same here. I am also in need of the corresponding kernel headers for the 6.1.68.current-bcm2712 kernel distributed with Armbian for RaspberryPi5. In addition, I just recognized that kernel reinstallation also does not work because the kernel image package also seems to be missing in the apt repositories as it seems. See here: # apt reinstall linux-image-current-bcm2712 Reading package lists... Done Building dependency tree... Done Reading state information... Done Reinstallation of linux-image-current-bcm2712 is not possible, it cannot be downloaded. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Thus, would be great if some armbian dev (perhaps the maintainer – @viraniac – of the RaspberryPi5 port, see https://www.armbian.com/rpi5b/) can have a look and provide the necessary packages... 0 Quote
Werner Posted January 29, 2024 Posted January 29, 2024 Oddly there are no bcm2712 packages whatsoever in stable repo. At least not on my mirror. However there are current and edge packages in beta including headers. 13236 ./pool/main/l/linux-headers-current-bcm2712/linux-headers-current-bcm2712_24.2.0-trunk.480_arm64__6.6.13-S374f-D719f-P0000-Cb2aaH4168-HK01ba-Vc222-B4d80-R448a.deb 25531 ./pool/main/l/linux-6.6.13/linux-image-current-bcm2712_24.2.0-trunk.480_arm64__6.6.13-S374f-D719f-P0000-Cb2aaH4168-HK01ba-Vc222-B4d80-R448a.deb 120 ./pool/main/l/linux-dtb-current-bcm2712/linux-dtb-current-bcm2712_24.2.0-trunk.480_arm64__6.6.13-S374f-D719f-P0000-Cb2aaH4168-HK01ba-Vc222-B4d80-R448a.deb 0 Quote
jmaus Posted January 29, 2024 Posted January 29, 2024 Yes, indeed. I just checked that myself as well. Newer experimental Armbian (v24, edge, current) contains the corresponding header and image deb files for the RaspberryPi5. However, not the latest stable version. Furthermore, the stable version for the RaspberryPi4 seems to be affected as well. Also there I can't install the corresponding linux-headers package patching the currently running kernel version. See: # apt install linux-headers-$(uname -r) Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package linux-headers-6.1.68-current-bcm2711 E: Couldn't find any package by glob 'linux-headers-6.1.68-current-bcm2711' And the same applies for the linux-image package: # apt reinstall linux-image-current-bcm2711 Reading package lists... Done Building dependency tree... Done Reading state information... Done Reinstallation of linux-image-current-bcm2711 is not possible, it cannot be downloaded. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Hopefully some Armbian dev can fix that ASAP so that the corresponding linux-headers and linux-image packages for the RaspberryPi5 and RaspberryPi4 are available in the apt repositories. 0 Quote
Igor Posted January 30, 2024 Posted January 30, 2024 12 hours ago, jmaus said: Hopefully some Armbian dev can fix that ASAP so that the corresponding linux-headers and linux-image packages for the RaspberryPi5 and RaspberryPi4 are available in the apt repositories. 6.1.74 current and 6.6.13 edge are going to be available on stable repository shortly after this is done: https://github.com/armbian/os/actions/runs/7708966983 1 Quote
jmaus Posted January 31, 2024 Posted January 31, 2024 Absolute awesome. Thank you @Igor for the fast response. Now all the kernel and kernel headers are there and I can compile additional kernel modules. Highly appreciated! 2 Quote
J.Ayuso Posted January 31, 2024 Author Posted January 31, 2024 Sorry, I don't understand the solution. Where are the kernel header for linux-headers-6.1.68.current-bcm2712 ? 0 Quote
Igor Posted January 31, 2024 Posted January 31, 2024 8 hours ago, J.Ayuso said: Where are the kernel header for linux-headers-6.1.68.current-bcm2712 ? Make an apt update + upgrade. Kernel + header combo exists for 6.1.74 and it should be there for future versions. 0 Quote
J.Ayuso Posted February 1, 2024 Author Posted February 1, 2024 Thank you for the response. On my PI 5, after udate + upgrade, when I request sudo apt install linux-headers-$(uname -r) I get the same message for the new kernel: Unable to locate package linux-headers-6.1.74-current-bmc2712. 0 Quote
Igor Posted February 2, 2024 Posted February 2, 2024 12 hours ago, J.Ayuso said: Unable to locate package linux-headers-6.1.74-current-bmc2712. Follow instructions armbian-config -> software -> install headers This is the package name: # apt search linux-headers-current-bcm2712 Sorting... Done Full Text Search... Done linux-headers-current-bcm2712/jammy 23.11.3 arm64 Armbian Linux current headers 6.1.74-current-bcm2712 0 Quote
J.Ayuso Posted February 2, 2024 Author Posted February 2, 2024 Thank you so much for your support! I can compile drivers now. 1 Quote
