nffs Posted January 30, 2017 Posted January 30, 2017 Hi, I'm trying to set up my Orange PI 2 with very specific resolution. I tried a lot of advices from this forum but still can't force it to work. I've used jernej's U-Boot to see correct parameters for monitor and then recompiled kernel with these params. There is U-Boot output: hdmi_core.c line: {MODE_XXX, 0, 297000000, 0, 2160, 1200, 2266, 46, 40, 20, 1464, 234, 28, 2, 0, 0, 0, 0, 0} hdmi_bsp_sun8iw7.c line: {YYY, 1, 0, 0, 8, 2, 4, 0, 28, 0, 0, 112, 106, 40, 20, 176, 264, 1, 1} script.bin setting: pll_video = 297 My monitor is connected by HDMI cable, I set my mode using "h3disp -m" command and also I tried different params in "[hdmi_para]" section in script.bin, no result.the best result I have now is that I see the image only while U-Boot is working and then blank screen. Also I've tried Odroid-C2(boot.ini custombuilt resolution) and Odroid-XU4(Xrandr custom resolution) no result, only blank screen. There is my kern.log: Jan 26 08:44:20 localhost kernel: [ 0.000000] Booting Linux on physical CPU 0 Jan 26 08:44:20 localhost kernel: [ 0.000000] Initializing cgroup subsys cpuset Jan 26 08:44:20 localhost kernel: [ 0.000000] Initializing cgroup subsys cpu Jan 26 08:44:20 localhost kernel: [ 0.000000] Linux version 3.4.113-sun8i (root@nffs-VirtualBox) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #18 SMP PREEMPT Thu Jan 26 10:34:27 EET 2017 Jan 26 08:44:20 localhost kernel: [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d Jan 26 08:44:20 localhost kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Jan 26 08:44:20 localhost kernel: [ 0.000000] Machine: sun8i Jan 26 08:44:20 localhost kernel: [ 0.000000] cma: CMA: reserved 256 MiB at 50000000 Jan 26 08:44:20 localhost kernel: [ 0.000000] Memory policy: ECC disabled, Data cache writealloc Jan 26 08:44:20 localhost kernel: [ 0.000000] On node 0 totalpages: 262144 Jan 26 08:44:20 localhost kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0a2e600, node_mem_map c0b67000 Jan 26 08:44:20 localhost kernel: [ 0.000000] Normal zone: 1710 pages used for memmap Jan 26 08:44:20 localhost kernel: [ 0.000000] Normal zone: 0 pages reserved Jan 26 08:44:20 localhost kernel: [ 0.000000] Normal zone: 192850 pages, LIFO batch:31 Jan 26 08:44:20 localhost kernel: [ 0.000000] HighMem zone: 594 pages used for memmap Jan 26 08:44:20 localhost kernel: [ 0.000000] HighMem zone: 66990 pages, LIFO batch:15 Jan 26 08:44:20 localhost kernel: [ 0.000000] script_init enter! Jan 26 08:44:20 localhost kernel: [ 0.000000] script_init exit! Jan 26 08:44:20 localhost kernel: [ 0.000000] PERCPU: Embedded 8 pages/cpu @c147d000 s11968 r8192 d12608 u32768 Jan 26 08:44:20 localhost kernel: [ 0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096 Jan 26 08:44:20 localhost kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 Jan 26 08:44:20 localhost kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259840 Jan 26 08:44:20 localhost kernel: [ 0.000000] Kernel command line: root=UUID=58627463-cef4-4387-8562-babc26e2ad38 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 cgroup_enable=memory swapaccount=1 hdmi.audio=EDID:0 disp.screen0_output_mode=1280x720p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 ubootpart=1d0a0ece-01 ubootsource=mmc Jan 26 08:44:20 localhost kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) Jan 26 08:44:20 localhost kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Jan 26 08:44:20 localhost kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Jan 26 08:44:20 localhost kernel: [ 0.000000] allocated 2097152 bytes of page_cgroup Jan 26 08:44:20 localhost kernel: [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups Jan 26 08:44:20 localhost kernel: [ 0.000000] Memory: 1024MB = 1024MB total Jan 26 08:44:20 localhost kernel: [ 0.000000] Memory: 757328k/757328k available, 291248k reserved, 270336K highmem Jan 26 08:44:20 localhost kernel: [ 0.000000] Virtual kernel memory layout: Jan 26 08:44:20 localhost kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) Jan 26 08:44:20 localhost kernel: [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Jan 26 08:44:20 localhost kernel: [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) Jan 26 08:44:20 localhost kernel: [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) Jan 26 08:44:20 localhost kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) Jan 26 08:44:20 localhost kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) Jan 26 08:44:20 localhost kernel: [ 0.000000] .text : 0xc0008000 - 0xc096c534 (9618 kB) Jan 26 08:44:20 localhost kernel: [ 0.000000] .init : 0xc096d000 - 0xc09c1ec0 ( 340 kB) Jan 26 08:44:20 localhost kernel: [ 0.000000] .data : 0xc09c2000 - 0xc0a33450 ( 454 kB) Jan 26 08:44:20 localhost kernel: [ 0.000000] .bss : 0xc0a33c04 - 0xc0b66f88 (1229 kB) Jan 26 08:44:20 localhost kernel: [ 0.000000] Preemptible hierarchical RCU implementation. Jan 26 08:44:20 localhost kernel: [ 0.000000] Additional per-CPU info printed with stalls. Jan 26 08:44:20 localhost kernel: [ 0.000000] NR_IRQS:544 Jan 26 08:44:20 localhost kernel: [ 0.000000] Architected local timer running at 24.00MHz. Jan 26 08:44:20 localhost kernel: [ 0.000000] Switching to timer-based delay loop Jan 26 08:44:20 localhost kernel: [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms Jan 26 08:44:20 localhost kernel: [ 0.000000] Console: colour dummy device 80x30 Jan 26 08:44:20 localhost kernel: [ 0.000000] console [tty1] enabled Jan 26 08:44:20 localhost kernel: [ 0.000267] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000) Jan 26 08:44:20 localhost kernel: [ 0.000291] pid_max: default: 32768 minimum: 301 Jan 26 08:44:20 localhost kernel: [ 0.000455] Security Framework initialized Jan 26 08:44:20 localhost kernel: [ 0.000479] AppArmor: AppArmor disabled by boot time parameter Jan 26 08:44:20 localhost kernel: [ 0.000666] Mount-cache hash table entries: 512 Jan 26 08:44:20 localhost kernel: [ 0.001656] Initializing cgroup subsys cpuacct Jan 26 08:44:20 localhost kernel: [ 0.001671] Initializing cgroup subsys memory Jan 26 08:44:20 localhost kernel: [ 0.001717] Initializing cgroup subsys devices Jan 26 08:44:20 localhost kernel: [ 0.001730] Initializing cgroup subsys freezer Jan 26 08:44:20 localhost kernel: [ 0.001741] Initializing cgroup subsys blkio Jan 26 08:44:20 localhost kernel: [ 0.001764] Initializing cgroup subsys perf_event Jan 26 08:44:20 localhost kernel: [ 0.001849] CPU: Testing write buffer coherency: ok Jan 26 08:44:20 localhost kernel: [ 0.001890] ftrace: allocating 26327 entries in 78 pages Jan 26 08:44:20 localhost kernel: [ 0.030307] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 Jan 26 08:44:20 localhost kernel: [ 0.030324] [sunxi_smp_prepare_cpus] enter Jan 26 08:44:20 localhost kernel: [ 0.030363] Setting up static identity map for 0x406a1858 - 0x406a18b0 Jan 26 08:44:20 localhost kernel: [ 0.031318] CPU1: Booted secondary processor Jan 26 08:44:20 localhost kernel: [ 0.031318] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 Jan 26 08:44:20 localhost kernel: [ 0.031449] CPU2: Booted secondary processor Jan 26 08:44:20 localhost kernel: [ 0.031449] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 Jan 26 08:44:20 localhost kernel: [ 0.040495] CPU3: Booted secondary processor Jan 26 08:44:20 localhost kernel: [ 0.040495] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 Jan 26 08:44:20 localhost kernel: [ 0.040615] Brought up 4 CPUs Jan 26 08:44:20 localhost kernel: [ 0.040615] SMP: Total of 4 processors activated (19200.00 BogoMIPS). Jan 26 08:44:20 localhost kernel: [ 0.040911] devtmpfs: initialized Jan 26 08:44:20 localhost kernel: [ 0.051325] wakeup src cnt is : 2. Jan 26 08:44:20 localhost kernel: [ 0.051338] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 Jan 26 08:44:20 localhost kernel: [ 0.051349] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0 Jan 26 08:44:20 localhost kernel: [ 0.051360] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 Jan 26 08:44:20 localhost kernel: [ 0.051371] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 Jan 26 08:44:20 localhost kernel: [ 0.051381] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8 Jan 26 08:44:20 localhost kernel: [ 0.051392] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 Jan 26 08:44:20 localhost kernel: [ 0.051404] sunxi pm init Jan 26 08:44:20 localhost kernel: [ 0.051552] pinctrl core: initialized pinctrl subsystem Jan 26 08:44:20 localhost kernel: [ 0.061630] NET: Registered protocol family 16 Jan 26 08:44:20 localhost kernel: [ 0.062551] DMA: preallocated 2048 KiB pool for atomic coherent allocations Jan 26 08:44:20 localhost kernel: [ 0.062551] script_sysfs_init success Jan 26 08:44:20 localhost kernel: [ 0.062551] sunxi_dump_init success Jan 26 08:44:20 localhost kernel: [ 0.062551] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl Jan 26 08:44:20 localhost kernel: [ 0.062551] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver Jan 26 08:44:20 localhost kernel: [ 0.062551] plat: add bmp085 device Jan 26 08:44:20 localhost kernel: [ 0.062551] plat: add pcf8591 device Jan 26 08:44:20 localhost kernel: [ 0.062551] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. Jan 26 08:44:20 localhost kernel: [ 0.062551] hw-breakpoint: maximum watchpoint size is 8 bytes. Jan 26 08:44:20 localhost kernel: [ 0.062551] script config pll_video to 297 Mhz Jan 26 08:44:20 localhost kernel: [ 0.062551] script config pll_de to 864 Mhz Jan 26 08:44:20 localhost kernel: [ 0.062551] script config pll_ve to 402 Mhz Jan 26 08:44:20 localhost kernel: [ 0.062551] sunxi_default_clk_init Jan 26 08:44:20 localhost kernel: [ 0.062551] try to set pll6ahb1 to 200000000 Jan 26 08:44:20 localhost kernel: [ 0.062551] try to set ahb clk source to pll6ahb1 Jan 26 08:44:20 localhost kernel: [ 0.062551] set ahb clk source to pll6ahb1 Jan 26 08:44:20 localhost kernel: [ 0.062551] try to set ahb1 to 200000000 Jan 26 08:44:20 localhost kernel: [ 0.062551] try to set apb1 to 100000000 Jan 26 08:44:20 localhost kernel: [ 0.070236] bio: create slab <bio-0> at 0 Jan 26 08:44:20 localhost kernel: [ 0.070315] [ARISC] :sunxi-arisc driver v1.04 Jan 26 08:44:20 localhost kernel: [ 0.091008] [ARISC] :arisc version: [v0.1.58] Jan 26 08:44:20 localhost kernel: [ 0.178130] [ARISC] :sunxi-arisc driver v1.04 startup succeeded Jan 26 08:44:20 localhost kernel: [ 0.180416] SCSI subsystem initialized Jan 26 08:44:20 localhost kernel: [ 0.180621] usbcore: registered new interface driver usbfs Jan 26 08:44:20 localhost kernel: [ 0.180697] usbcore: registered new interface driver hub Jan 26 08:44:20 localhost kernel: [ 0.180722] usbcore: registered new device driver usb Jan 26 08:44:20 localhost kernel: [ 0.180722] twi_chan_cfg()340 - [twi0] has no twi_regulator. Jan 26 08:44:20 localhost kernel: [ 0.180722] twi_chan_cfg()340 - [twi1] has no twi_regulator. Jan 26 08:44:20 localhost kernel: [ 0.180722] twi_chan_cfg()340 - [twi2] has no twi_regulator. Jan 26 08:44:20 localhost kernel: [ 0.180918] Linux video capture interface: v2.00 Jan 26 08:44:20 localhost kernel: [ 0.181160] Advanced Linux Sound Architecture Driver Version 1.0.25. Jan 26 08:44:20 localhost kernel: [ 0.181921] cfg80211: Calling CRDA to update world regulatory domain Jan 26 08:44:20 localhost kernel: [ 0.181977] NetLabel: Initializing Jan 26 08:44:20 localhost kernel: [ 0.181977] NetLabel: domain hash size = 128 Jan 26 08:44:20 localhost kernel: [ 0.181977] NetLabel: protocols = UNLABELED CIPSOv4 Jan 26 08:44:20 localhost kernel: [ 0.181977] NetLabel: unlabeled traffic allowed by default Jan 26 08:44:20 localhost kernel: [ 0.181977] Switching to clocksource arch_sys_counter Jan 26 08:44:20 localhost kernel: [ 0.194541] FS-Cache: Loaded Jan 26 08:44:20 localhost kernel: [ 0.194841] CacheFiles: Loaded Jan 26 08:44:20 localhost kernel: [ 0.206003] NET: Registered protocol family 2 Jan 26 08:44:20 localhost kernel: [ 0.217219] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) Jan 26 08:44:20 localhost kernel: [ 0.217831] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) Jan 26 08:44:20 localhost kernel: [ 0.219594] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) Jan 26 08:44:20 localhost kernel: [ 0.220685] TCP: Hash tables configured (established 131072 bind 65536) Jan 26 08:44:20 localhost kernel: [ 0.220697] TCP: reno registered Jan 26 08:44:20 localhost kernel: [ 0.220712] UDP hash table entries: 512 (order: 2, 16384 bytes) Jan 26 08:44:20 localhost kernel: [ 0.220750] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) Jan 26 08:44:20 localhost kernel: [ 0.221106] NET: Registered protocol family 1 Jan 26 08:44:20 localhost kernel: [ 0.221530] RPC: Registered named UNIX socket transport module. Jan 26 08:44:20 localhost kernel: [ 0.221542] RPC: Registered udp transport module. Jan 26 08:44:20 localhost kernel: [ 0.221551] RPC: Registered tcp transport module. Jan 26 08:44:20 localhost kernel: [ 0.221559] RPC: Registered tcp NFSv4.1 backchannel transport module. Jan 26 08:44:20 localhost kernel: [ 0.221772] Trying to unpack rootfs image as initramfs... Jan 26 08:44:20 localhost kernel: [ 0.501702] Freeing initrd memory: 4380K Jan 26 08:44:20 localhost kernel: [ 0.502217] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available Jan 26 08:44:20 localhost kernel: [ 0.502340] sunxi_reg_init enter Jan 26 08:44:20 localhost kernel: [ 0.503265] audit: initializing netlink socket (disabled) Jan 26 08:44:20 localhost kernel: [ 0.503319] type=2000 audit(0.500:1): initialized Jan 26 08:44:20 localhost kernel: [ 0.504557] highmem bounce pool size: 64 pages Jan 26 08:44:20 localhost kernel: [ 0.505442] squashfs: version 4.0 (2009/01/31) Phillip Lougher Jan 26 08:44:20 localhost kernel: [ 0.505630] misc fatfs initialized Jan 26 08:44:20 localhost kernel: [ 0.505850] NFS: Registering the id_resolver key type Jan 26 08:44:20 localhost kernel: [ 0.506230] nfs4filelayout_init: NFSv4 File Layout Driver Registering... Jan 26 08:44:20 localhost kernel: [ 0.506243] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). Jan 26 08:44:20 localhost kernel: [ 0.506996] NTFS driver 2.1.30 [Flags: R/W]. Jan 26 08:44:20 localhost kernel: [ 0.507295] fuse init (API version 7.18) Jan 26 08:44:20 localhost kernel: [ 0.508054] Btrfs loaded Jan 26 08:44:20 localhost kernel: [ 0.508078] msgmni has been set to 1471 Jan 26 08:44:20 localhost kernel: [ 0.509547] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) Jan 26 08:44:20 localhost kernel: [ 0.509565] io scheduler noop registered Jan 26 08:44:20 localhost kernel: [ 0.509574] io scheduler deadline registered Jan 26 08:44:20 localhost kernel: [ 0.509638] io scheduler cfq registered (default) Jan 26 08:44:20 localhost kernel: [ 0.510142] [DISP]disp_module_init Jan 26 08:44:20 localhost kernel: [ 0.510459] cmdline,init_disp= Jan 26 08:44:20 localhost kernel: [ 0.510491] cmdline,disp= Jan 26 08:44:20 localhost kernel: [ 0.526172] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed! Jan 26 08:44:20 localhost kernel: [ 0.562035] Console: switching to colour frame buffer device 240x67 Jan 26 08:44:20 localhost kernel: [ 0.598746] [DISP]disp_module_init finish Jan 26 08:44:20 localhost kernel: [ 0.598978] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator. Jan 26 08:44:20 localhost kernel: [ 0.599285] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI Jan 26 08:44:20 localhost kernel: [ 0.599301] sw_uart_pm()890 - uart0 clk is already enable Jan 26 08:44:20 localhost kernel: [ 0.599319] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n Jan 26 08:44:20 localhost kernel: [ 0.599457] console [ttyS0] enabled Jan 26 08:44:20 localhost kernel: [ 0.600124] sunxi_cmatest_init enter Jan 26 08:44:20 localhost kernel: [ 0.600169] sunxi_cmatest_init success Jan 26 08:44:20 localhost kernel: [ 0.604412] brd: module loaded Jan 26 08:44:20 localhost kernel: [ 0.608361] loop: module loaded Jan 26 08:44:20 localhost kernel: [ 0.608657] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. Jan 26 08:44:20 localhost kernel: [ 0.608671] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. Jan 26 08:44:20 localhost kernel: [ 0.609260] spi spi0: master is unqueued, this is deprecated Jan 26 08:44:20 localhost kernel: [ 0.609599] tun: Universal TUN/TAP device driver, 1.6 Jan 26 08:44:20 localhost kernel: [ 0.609610] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> Jan 26 08:44:20 localhost kernel: [ 0.610583] PPP generic driver version 2.4.2 Jan 26 08:44:20 localhost kernel: [ 0.610805] PPP BSD Compression module registered Jan 26 08:44:20 localhost kernel: [ 0.610815] PPP Deflate Compression module registered Jan 26 08:44:20 localhost kernel: [ 0.613642] PPP MPPE Compression module registered Jan 26 08:44:20 localhost kernel: [ 0.613661] NET: Registered protocol family 24 Jan 26 08:44:20 localhost kernel: [ 0.613740] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver Jan 26 08:44:20 localhost kernel: [ 0.633847] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver Jan 26 08:44:20 localhost kernel: [ 0.633883] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 Jan 26 08:44:20 localhost kernel: [ 0.634462] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 Jan 26 08:44:20 localhost kernel: [ 0.650040] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 Jan 26 08:44:20 localhost kernel: [ 0.650727] hub 1-0:1.0: USB hub found Jan 26 08:44:20 localhost kernel: [ 0.650752] hub 1-0:1.0: 1 port detected Jan 26 08:44:20 localhost kernel: [ 0.671129] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver Jan 26 08:44:20 localhost kernel: [ 0.671158] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2 Jan 26 08:44:20 localhost kernel: [ 0.671564] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000 Jan 26 08:44:20 localhost kernel: [ 0.690035] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00 Jan 26 08:44:20 localhost kernel: [ 0.690052] ehci_irq: highspeed device connect Jan 26 08:44:20 localhost kernel: [ 0.690568] hub 2-0:1.0: USB hub found Jan 26 08:44:20 localhost kernel: [ 0.690590] hub 2-0:1.0: 1 port detected Jan 26 08:44:20 localhost kernel: [ 0.690953] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver Jan 26 08:44:20 localhost kernel: [ 0.711033] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver Jan 26 08:44:20 localhost kernel: [ 0.711062] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 3 Jan 26 08:44:20 localhost kernel: [ 0.711095] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 Jan 26 08:44:20 localhost kernel: [ 0.774555] hub 3-0:1.0: USB hub found Jan 26 08:44:20 localhost kernel: [ 0.774581] hub 3-0:1.0: 1 port detected Jan 26 08:44:20 localhost kernel: [ 0.794937] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver Jan 26 08:44:20 localhost kernel: [ 0.794966] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 4 Jan 26 08:44:20 localhost kernel: [ 0.794999] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400 Jan 26 08:44:20 localhost kernel: [ 0.854537] hub 4-0:1.0: USB hub found Jan 26 08:44:20 localhost kernel: [ 0.854555] hub 4-0:1.0: 1 port detected Jan 26 08:44:20 localhost kernel: [ 0.854915] Initializing USB Mass Storage driver... Jan 26 08:44:20 localhost kernel: [ 0.855086] usbcore: registered new interface driver usb-storage Jan 26 08:44:20 localhost kernel: [ 0.855097] USB Mass Storage support registered. Jan 26 08:44:20 localhost kernel: [ 0.855152] usbcore: registered new interface driver ums-alauda Jan 26 08:44:20 localhost kernel: [ 0.855199] usbcore: registered new interface driver ums-cypress Jan 26 08:44:20 localhost kernel: [ 0.855246] usbcore: registered new interface driver ums-datafab Jan 26 08:44:20 localhost kernel: [ 0.855290] usbcore: registered new interface driver ums_eneub6250 Jan 26 08:44:20 localhost kernel: [ 0.855335] usbcore: registered new interface driver ums-freecom Jan 26 08:44:20 localhost kernel: [ 0.855381] usbcore: registered new interface driver ums-isd200 Jan 26 08:44:20 localhost kernel: [ 0.855425] usbcore: registered new interface driver ums-jumpshot Jan 26 08:44:20 localhost kernel: [ 0.855470] usbcore: registered new interface driver ums-karma Jan 26 08:44:20 localhost kernel: [ 0.855514] usbcore: registered new interface driver ums-onetouch Jan 26 08:44:20 localhost kernel: [ 0.855574] usbcore: registered new interface driver ums-realtek Jan 26 08:44:20 localhost kernel: [ 0.855622] usbcore: registered new interface driver ums-sddr09 Jan 26 08:44:20 localhost kernel: [ 0.855669] usbcore: registered new interface driver ums-sddr55 Jan 26 08:44:20 localhost kernel: [ 0.855720] usbcore: registered new interface driver ums-usbat Jan 26 08:44:20 localhost kernel: [ 0.855936] uinput result 0 , vmouse_init Jan 26 08:44:20 localhost kernel: [ 0.856557] mousedev: PS/2 mouse device common for all mice Jan 26 08:44:20 localhost kernel: [ 0.856808] sunxikbd_init failed. Jan 26 08:44:20 localhost kernel: [ 0.857319] ls_fetch_sysconfig_para: type err device_used = -1073057456. Jan 26 08:44:20 localhost kernel: [ 0.857331] =========script_get_err============ Jan 26 08:44:20 localhost kernel: [ 0.857339] ltr_init: ls_fetch_sysconfig_para err. Jan 26 08:44:20 localhost kernel: [ 0.857941] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0 Jan 26 08:44:20 localhost kernel: [ 0.857991] i2c /dev entries driver Jan 26 08:44:20 localhost kernel: [ 0.858408] sunxi cedar version 0.1 Jan 26 08:44:20 localhost kernel: [ 0.858451] [cedar]: install start!!! Jan 26 08:44:20 localhost kernel: [ 0.858642] [cedar]: install end!!! Jan 26 08:44:20 localhost kernel: [ 0.858892] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18) Jan 26 08:44:20 localhost kernel: [ 0.859066] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19) Jan 26 08:44:20 localhost kernel: [ 0.859236] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a) Jan 26 08:44:20 localhost kernel: [ 0.859406] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29) Jan 26 08:44:20 localhost kernel: [ 0.859575] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a) Jan 26 08:44:20 localhost kernel: [ 0.859745] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b) Jan 26 08:44:20 localhost kernel: [ 0.859915] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c) Jan 26 08:44:20 localhost kernel: [ 0.860086] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d) Jan 26 08:44:20 localhost kernel: [ 0.860256] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e) Jan 26 08:44:20 localhost kernel: [ 0.860456] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18) Jan 26 08:44:20 localhost kernel: [ 0.860652] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) Jan 26 08:44:20 localhost kernel: [ 0.860849] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a) Jan 26 08:44:20 localhost kernel: [ 0.861045] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29) Jan 26 08:44:20 localhost kernel: [ 0.861241] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a) Jan 26 08:44:20 localhost kernel: [ 0.861436] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b) Jan 26 08:44:20 localhost kernel: [ 0.861632] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c) Jan 26 08:44:20 localhost kernel: [ 0.861827] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d) Jan 26 08:44:20 localhost kernel: [ 0.862022] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e) Jan 26 08:44:20 localhost kernel: [ 0.862038] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0 Jan 26 08:44:20 localhost kernel: [ 0.862214] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf Jan 26 08:44:20 localhost kernel: [ 0.862386] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) Jan 26 08:44:20 localhost kernel: [ 0.862399] wdt_enable, write reg 0xf1c20cb8 val 0x00000000 Jan 26 08:44:20 localhost kernel: [ 0.862409] timeout_to_interv, line 167 Jan 26 08:44:20 localhost kernel: [ 0.862417] interv_to_timeout, line 189 Jan 26 08:44:20 localhost kernel: [ 0.862427] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec Jan 26 08:44:20 localhost kernel: [ 0.862872] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com Jan 26 08:44:20 localhost kernel: [ 0.863084] calibrat: max_cpufreq 1200Mhz Type 0! Jan 26 08:44:20 localhost kernel: [ 0.863407] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Jan 26 2017 at 10:33:43 Jan 26 08:44:20 localhost kernel: [ 0.863444] [mmc]: get mmc0's sdc_power is null! Jan 26 08:44:20 localhost kernel: [ 0.863472] [mmc]: get mmc1's sdc_power is null! Jan 26 08:44:20 localhost kernel: [ 0.863482] [mmc]: get mmc1's 2xmode ok, val = 1 Jan 26 08:44:20 localhost kernel: [ 0.863492] [mmc]: get mmc1's ddrmode ok, val = 1 Jan 26 08:44:20 localhost kernel: [ 0.863509] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2 Jan 26 08:44:20 localhost kernel: [ 0.867058] [mmc]: sdc0 power_supply is null Jan 26 08:44:20 localhost kernel: [ 0.868923] no blue_led, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869136] Registered led device: red_led Jan 26 08:44:20 localhost kernel: [ 0.869240] Registered led device: green_led Jan 26 08:44:20 localhost kernel: [ 0.869256] no led_0, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869264] no led_1, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869271] no led_2, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869278] no led_3, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869285] no led_4, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869292] no led_5, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869299] no led_6, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.869306] no led_7, ignore it! Jan 26 08:44:20 localhost kernel: [ 0.870141] usbcore: registered new interface driver usbhid Jan 26 08:44:20 localhost kernel: [ 0.870151] usbhid: USB HID core driver Jan 26 08:44:20 localhost kernel: [ 0.874184] asoc: sndcodec <-> sunxi-codec mapping ok Jan 26 08:44:20 localhost kernel: [ 0.875297] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly! Jan 26 08:44:20 localhost kernel: [ 0.875491] [I2S]snddaudio cannot find any using configuration for controllers, return directly! Jan 26 08:44:20 localhost kernel: [ 0.875505] [DAUDIO0] driver not init,just return. Jan 26 08:44:20 localhost kernel: [ 0.878673] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok Jan 26 08:44:20 localhost kernel: [ 0.880058] oprofile: using arm/armv7-ca7 Jan 26 08:44:20 localhost kernel: [ 0.880263] u32 classifier Jan 26 08:44:20 localhost kernel: [ 0.880273] Performance counters on Jan 26 08:44:20 localhost kernel: [ 0.880280] input device check on Jan 26 08:44:20 localhost kernel: [ 0.880288] Actions configured Jan 26 08:44:20 localhost kernel: [ 0.880481] IPv4 over IPv4 tunneling driver Jan 26 08:44:20 localhost kernel: [ 0.881151] TCP: bic registered Jan 26 08:44:20 localhost kernel: [ 0.881162] TCP: cubic registered Jan 26 08:44:20 localhost kernel: [ 0.881169] TCP: westwood registered Jan 26 08:44:20 localhost kernel: [ 0.881177] TCP: highspeed registered Jan 26 08:44:20 localhost kernel: [ 0.881185] TCP: hybla registered Jan 26 08:44:20 localhost kernel: [ 0.881192] TCP: htcp registered Jan 26 08:44:20 localhost kernel: [ 0.881199] TCP: vegas registered Jan 26 08:44:20 localhost kernel: [ 0.881207] TCP: veno registered Jan 26 08:44:20 localhost kernel: [ 0.881214] TCP: scalable registered Jan 26 08:44:20 localhost kernel: [ 0.881222] TCP: lp registered Jan 26 08:44:20 localhost kernel: [ 0.881230] TCP: yeah registered Jan 26 08:44:20 localhost kernel: [ 0.881237] TCP: illinois registered Jan 26 08:44:20 localhost kernel: [ 0.881244] Initializing XFRM netlink socket Jan 26 08:44:20 localhost kernel: [ 0.881475] NET: Registered protocol family 10 Jan 26 08:44:20 localhost kernel: [ 0.882666] NET: Registered protocol family 17 Jan 26 08:44:20 localhost kernel: [ 0.882698] NET: Registered protocol family 15 Jan 26 08:44:20 localhost kernel: [ 0.882746] Registering the dns_resolver key type Jan 26 08:44:20 localhost kernel: [ 0.883198] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 Jan 26 08:44:20 localhost kernel: [ 0.883219] ThumbEE CPU extension supported. Jan 26 08:44:20 localhost kernel: [ 0.883242] Registering SWP/SWPB emulation handler Jan 26 08:44:20 localhost kernel: [ 0.883831] registered taskstats version 1 Jan 26 08:44:20 localhost kernel: [ 0.884302] cmdline,disp= Jan 26 08:44:20 localhost kernel: [ 0.884603] [HDMI] power vcc-hdmi-18 Jan 26 08:44:20 localhost kernel: [ 0.915529] cmdline,disp= Jan 26 08:44:20 localhost kernel: [ 0.915838] [DISP] disp_init_tv,line:539:screen 0 do not support TV TYPE! Jan 26 08:44:20 localhost kernel: [ 0.915857] [DISP] bsp_disp_tv_register,line:990:'ptv is null Jan 26 08:44:20 localhost kernel: [ 0.915868] tv registered!! Jan 26 08:44:20 localhost kernel: [ 0.933310] mmc0: new high speed SDHC card at address 1234 Jan 26 08:44:20 localhost kernel: [ 0.933777] mmcblk0: mmc0:1234 SA16G 14.5 GiB Jan 26 08:44:20 localhost kernel: [ 0.935224] mmcblk0: p1 Jan 26 08:44:20 localhost kernel: [ 0.935793] mmcblk mmc0:1234: Card claimed for testing. Jan 26 08:44:20 localhost kernel: [ 0.935809] mmc0:1234: SA16G 14.5 GiB Jan 26 08:44:20 localhost kernel: [ 0.950050] ehci_irq: highspeed device disconnect Jan 26 08:44:20 localhost kernel: [ 0.950082] ohci_irq: fullspeed or lowspeed device connect Jan 26 08:44:20 localhost kernel: [ 1.230042] usb 4-1: new full-speed USB device number 2 using sunxi-ohci Jan 26 08:44:20 localhost kernel: [ 1.466576] generic-usb 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-sunxi-ohci-1/input0 Jan 26 08:44:20 localhost kernel: [ 1.520046] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=10 Jan 26 08:44:20 localhost kernel: [ 1.520653] ths_fetch_sysconfig_para: type err device_used = 1. Jan 26 08:44:20 localhost kernel: [ 1.521978] CPU Budget:corekeeper enabled Jan 26 08:44:20 localhost kernel: [ 1.522203] CPU Budget:Register notifier Jan 26 08:44:20 localhost kernel: [ 1.522216] CPU Budget:register Success Jan 26 08:44:20 localhost kernel: [ 1.522228] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0 Jan 26 08:44:20 localhost kernel: [ 1.525553] [rf_pm]: module power0 name vcc-wifi-33 Jan 26 08:44:20 localhost kernel: [ 1.525571] [rf_pm]: Did not config module_power1 in sys_config Jan 26 08:44:20 localhost kernel: [ 1.525582] [rf_pm]: Did not config module_power2 in sys_config Jan 26 08:44:20 localhost kernel: [ 1.525592] [rf_pm]: Did not config module_power3 in sys_config Jan 26 08:44:20 localhost kernel: [ 1.525602] [rf_pm]: mod has no chip_en gpio Jan 26 08:44:20 localhost kernel: [ 1.525610] [rf_pm]: failed to fetch lpo_use_apclk Jan 26 08:44:20 localhost kernel: [ 1.525618] [rf_pm]: regulator on. Jan 26 08:44:20 localhost kernel: [ 1.525897] [wifi_pm]: set wl_reg_on 1 ! Jan 26 08:44:20 localhost kernel: [ 1.541326] generic-usb 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-sunxi-ohci-1/input1 Jan 26 08:44:20 localhost kernel: [ 1.625937] hci: ERR: sunxi_ehci is null Jan 26 08:44:20 localhost kernel: [ 1.625947] hci: ERR: sunxi_ohci is null Jan 26 08:44:20 localhost kernel: [ 1.627466] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 1.675211] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 1.679322] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 1.725962] [wifi_pm]: wifi gpio init is OK !! Jan 26 08:44:20 localhost kernel: [ 1.726026] [rfkill]: init no bt used in configuration Jan 26 08:44:20 localhost kernel: [ 1.726036] ALSA device list: Jan 26 08:44:20 localhost kernel: [ 1.726044] #0: audiocodec Jan 26 08:44:20 localhost kernel: [ 1.726051] #1: sndhdmi Jan 26 08:44:20 localhost kernel: [ 1.726935] Freeing init memory: 336K Jan 26 08:44:20 localhost kernel: [ 1.738788] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 1.742728] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 1.805835] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 1.809989] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 1.882237] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 2.034314] vmouse_input_dev_open Jan 26 08:44:20 localhost kernel: [ 2.090142] vmouse_input_dev_close Jan 26 08:44:20 localhost kernel: [ 2.873654] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) Jan 26 08:44:20 localhost kernel: [ 5.253605] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro Jan 26 08:44:20 localhost kernel: [ 6.122616] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 6.175191] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 6.179300] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 6.221092] [wifi_pm]: set wl_reg_on 1 ! Jan 26 08:44:20 localhost kernel: [ 6.237461] UMP: UMP device driver loaded Jan 26 08:44:20 localhost kernel: [ 6.238860] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 6.242992] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 6.254423] mali clk: 252 MHz Jan 26 08:44:20 localhost kernel: [ 6.254645] mali clk: 252 MHz Jan 26 08:44:20 localhost kernel: [ 6.256580] Mali: Mali device driver loaded Jan 26 08:44:20 localhost kernel: [ 6.305273] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 6.309389] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 6.382049] [mmc]: sdc1 power_supply is null Jan 26 08:44:20 localhost kernel: [ 8.006836] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS Jan 26 08:44:20 localhost kernel: [ 10.295279] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77) Jan 26 08:44:20 localhost kernel: [ 10.295322] bmp085: probe of 0-0077 failed with error -70 Jan 26 08:44:20 localhost kernel: [ 10.314413] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48) Jan 26 08:44:20 localhost kernel: [ 10.314604] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48) Jan 26 08:44:20 localhost kernel: [ 10.330766] vmouse_input_dev_open Jan 26 08:44:20 localhost kernel: [ 10.380192] vmouse_input_dev_close Jan 26 08:44:20 localhost kernel: [ 11.751671] gmac0: probed Jan 26 08:44:20 localhost kernel: [ 11.752036] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00) Jan 26 08:44:21 localhost kernel: [ 14.750261] PHY: gmac0-0:00 - Link is Up - 100/Full Jan 26 08:44:21 localhost NetworkManager[506]: <info> [1485420261.9201] NetworkManager (version 1.2.2) is starting... Jan 26 08:44:21 localhost NetworkManager[506]: <info> [1485420261.9216] Read config: /etc/NetworkManager/NetworkManager.conf (etc: default-wifi-powersave-on.conf, zz-override-wifi-powersave-off.conf) Jan 26 08:44:21 localhost NetworkManager[506]: <info> [1485420261.9580] manager[0x1a96908]: monitoring kernel firmware directory '/lib/firmware'. Jan 26 08:44:21 localhost NetworkManager[506]: <info> [1485420261.9585] monitoring ifupdown state file '/run/network/ifstate'. Jan 26 08:44:21 localhost NetworkManager[506]: <info> [1485420261.9767] dns-mgr[0x1a9f210]: set resolv-conf-mode: dnsmasq, plugin="dnsmasq" Jan 26 08:44:21 localhost NetworkManager[506]: <info> [1485420261.9770] dns-mgr[0x1a9f210]: using resolv.conf manager 'resolvconf' Jan 26 08:44:22 localhost kernel: [ 16.073469] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536 Jan 26 08:44:23 localhost kernel: [ 16.123419] [drm] Initialized drm 1.1.0 20060810 Jan 26 08:44:23 localhost kernel: [ 16.129669] Mali DRM initialize, driver name: mali_drm, version 2.1 Jan 26 08:44:23 localhost kernel: [ 16.131118] [drm] Initialized mali_drm 2.1.1 20101111 on minor 0 Jan 26 08:44:23 localhost kernel: [ 16.131217] Mali DRM initialize, driver name: mali_drm, version 2.1 Jan 26 08:44:23 localhost kernel: [ 16.131744] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1 Jan 26 08:44:23 localhost NetworkManager[506]: <info> [1485420263.4882] init! Jan 26 08:44:23 localhost NetworkManager[506]: <info> [1485420263.4910] guessed connection type (eth0) = 802-3-ethernet Jan 26 08:44:23 localhost NetworkManager[506]: <info> [1485420263.4914] update_connection_setting_from_if_block: name:eth0, type:802-3-ethernet, id:Ifupdown (eth0), uuid: 681b428f-beaf-8932-dce4-687ed5bae28e Jan 26 08:44:23 localhost NetworkManager[506]: <info> [1485420263.4924] adding eth0 to connections Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4926] adding iface eth0 to eni_ifaces Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4927] autoconnect Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4928] management mode: managed Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4959] devices added (path: /sys/devices/platform/gmac0/net/eth0, iface: eth0) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4964] locking wired connection setting Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4967] devices added (path: /sys/devices/virtual/net/lo, iface: lo) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4968] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4969] devices added (path: /sys/devices/virtual/net/tunl0, iface: tunl0) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4970] device added (path: /sys/devices/virtual/net/tunl0, iface: tunl0): no ifupdown configuration found. Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4971] end _init. Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4972] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-settings-plugin-ifupdown.so) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.4976] settings: loaded plugin keyfile: (c) 2007 - 2015 Red Hat, Inc. To report bugs please use the NetworkManager mailing list. Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.5036] SettingsPlugin-Ofono: init! Jan 26 08:44:24 localhost NetworkManager[506]: <warn> [1485420263.5040] SettingsPlugin-Ofono: file doesn't exist: /var/lib/ofono Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.5041] SettingsPlugin-Ofono: end _init. Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.5042] settings: loaded plugin ofono: (C) 2013-2016 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-settings-plugin-ofono.so) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.5043] (28006704) ... get_connections. Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.5044] (28006704) connections count: 1 Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.5136] SettingsPlugin-Ofono: (28050184) ... get_connections. Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420263.5138] SettingsPlugin-Ofono: (28050184) connections count: 0 Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7121] settings: hostname: using hostnamed Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7123] settings: hostname changed from (none) to "orangepi2" Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7136] Using DHCP client 'dhclient' Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7138] manager: WiFi enabled by radio killswitch; enabled by state file Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7141] manager: WWAN enabled by radio killswitch; enabled by state file Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7143] manager: Networking is enabled by state file Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7147] Loaded device plugin: NMVxlanFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7149] Loaded device plugin: NMVlanFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7153] Loaded device plugin: NMVethFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7155] Loaded device plugin: NMTunFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7157] Loaded device plugin: NMMacvlanFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7160] Loaded device plugin: NMIPTunnelFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7162] Loaded device plugin: NMInfinibandFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7164] Loaded device plugin: NMEthernetFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7166] Loaded device plugin: NMBridgeFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7169] Loaded device plugin: NMBondFactory (internal) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7395] Loaded device plugin: NMWifiFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wifi.so) Jan 26 08:44:24 localhost kernel: [ 17.861859] vmouse_input_dev_open Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.7596] Loaded device plugin: NMAtmManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-adsl.so) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.8359] Loaded device plugin: NMBluezManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-bluetooth.so) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.8592] Loaded device plugin: NMWwanFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wwan.so) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.8641] device (eth0): link connected Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.8796] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/0) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.8974] keyfile: add connection in-memory (9ef71040-de35-4120-8c12-bec9904655f1,"eth0") Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.8999] device (eth0): state change: unmanaged -> unavailable (reason 'connection-assumed') [10 20 41] Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9017] device (eth0): state change: unavailable -> disconnected (reason 'connection-assumed') [20 30 41] Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9088] device (eth0): Activation: starting connection 'eth0' (9ef71040-de35-4120-8c12-bec9904655f1) Jan 26 08:44:24 localhost NetworkManager[506]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9147] manager: (tunl0): new Generic device (/org/freedesktop/NetworkManager/Devices/1) Jan 26 08:44:24 localhost NetworkManager[506]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9174] device (lo): link connected Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9215] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/2) Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9248] manager: NetworkManager state is now CONNECTED_GLOBAL Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9380] urfkill disappeared from the bus Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9411] manager: startup complete Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9415] device (eth0): state change: disconnected -> prepare (reason 'none') [30 40 0] Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9444] policy: set 'eth0' (eth0) as default for IPv4 routing and DNS Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9787] device (eth0): state change: prepare -> config (reason 'none') [40 50 0] Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9799] ofono is now available Jan 26 08:44:24 localhost NetworkManager[506]: <info> [1485420264.9820] device (eth0): state change: config -> ip-config (reason 'none') [50 70 0] Jan 26 08:44:25 localhost NetworkManager[506]: <info> [1485420264.9841] device (eth0): state change: ip-config -> ip-check (reason 'none') [70 80 0] Jan 26 08:44:25 localhost NetworkManager[506]: <error> [1485420264.9888] platform-linux: do-add-ip4-address[2: 192.168.1.152/24]: failure 17 (File exists) Jan 26 08:44:25 localhost NetworkManager[506]: <warn> [1485420264.9896] arping[0x1b01dd0,2]: arping could not be found; no ARPs will be sent Jan 26 08:44:25 localhost NetworkManager[506]: <info> [1485420264.9899] device (eth0): state change: ip-check -> secondaries (reason 'none') [80 90 0] Jan 26 08:44:25 localhost NetworkManager[506]: <warn> [1485420264.9925] failed to enumerate oFono devices: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files Jan 26 08:44:25 localhost NetworkManager[506]: <info> [1485420264.9958] device (eth0): state change: secondaries -> activated (reason 'none') [90 100 0] Jan 26 08:44:25 localhost NetworkManager[506]: <info> [1485420265.0189] device (eth0): Activation: successful, device activated. Jan 26 08:44:26 localhost NetworkManager[506]: <warn> [1485420266.8773] arping[0x1b01dd0,2]: arping could not be found; no ARPs will be sent Jan 26 08:44:29 localhost kernel: [ 22.250059] eth0: no IPv6 routers present Jan 30 07:15:12 localhost NetworkManager[506]: <info> [1485760512.7851] WiFi hardware radio set enabled Jan 30 07:15:12 localhost NetworkManager[506]: <info> [1485760512.7853] WWAN hardware radio set enabled Jan 30 07:45:31 localhost kernel: [ 0.000000] Booting Linux on physical CPU 0 Jan 30 07:45:31 localhost kernel: [ 0.000000] Initializing cgroup subsys cpuset Jan 30 07:45:31 localhost kernel: [ 0.000000] Initializing cgroup subsys cpu Jan 30 07:45:31 localhost kernel: [ 0.000000] Linux version 3.4.113-sun8i (root@nffs-VirtualBox) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.4) ) #4 SMP PREEMPT Mon Jan 30 09:15:40 EET 2017 Jan 30 07:45:31 localhost kernel: [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d Jan 30 07:45:31 localhost kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Jan 30 07:45:31 localhost kernel: [ 0.000000] Machine: sun8i Jan 30 07:45:31 localhost kernel: [ 0.000000] cma: CMA: reserved 256 MiB at 50000000 Jan 30 07:45:31 localhost kernel: [ 0.000000] Memory policy: ECC disabled, Data cache writealloc Jan 30 07:45:31 localhost kernel: [ 0.000000] On node 0 totalpages: 262144 Jan 30 07:45:31 localhost kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0a2e600, node_mem_map c0b67000 Jan 30 07:45:31 localhost kernel: [ 0.000000] Normal zone: 1710 pages used for memmap Jan 30 07:45:31 localhost kernel: [ 0.000000] Normal zone: 0 pages reserved Jan 30 07:45:31 localhost kernel: [ 0.000000] Normal zone: 192850 pages, LIFO batch:31 Jan 30 07:45:31 localhost kernel: [ 0.000000] HighMem zone: 594 pages used for memmap Jan 30 07:45:31 localhost kernel: [ 0.000000] HighMem zone: 66990 pages, LIFO batch:15 Jan 30 07:45:31 localhost kernel: [ 0.000000] script_init enter! Jan 30 07:45:31 localhost kernel: [ 0.000000] script_init exit! Jan 30 07:45:31 localhost kernel: [ 0.000000] PERCPU: Embedded 8 pages/cpu @c147d000 s11968 r8192 d12608 u32768 Jan 30 07:45:31 localhost kernel: [ 0.000000] pcpu-alloc: s11968 r8192 d12608 u32768 alloc=8*4096 Jan 30 07:45:31 localhost kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 Jan 30 07:45:31 localhost kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259840 Jan 30 07:45:31 localhost kernel: [ 0.000000] Kernel command line: root=UUID=58627463-cef4-4387-8562-babc26e2ad38 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 cgroup_enable=memory swapaccount=1 hdmi.audio=EDID:0 disp.screen0_output_mode=2160x1200p90 panic=10 consoleblank=0 enforcing=0 loglevel=1 ubootpart=1d0a0ece-01 ubootsource=mmc Jan 30 07:45:31 localhost kernel: [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) Jan 30 07:45:31 localhost kernel: [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Jan 30 07:45:31 localhost kernel: [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Jan 30 07:45:31 localhost kernel: [ 0.000000] allocated 2097152 bytes of page_cgroup Jan 30 07:45:31 localhost kernel: [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups Jan 30 07:45:31 localhost kernel: [ 0.000000] Memory: 1024MB = 1024MB total Jan 30 07:45:31 localhost kernel: [ 0.000000] Memory: 757328k/757328k available, 291248k reserved, 270336K highmem Jan 30 07:45:31 localhost kernel: [ 0.000000] Virtual kernel memory layout: Jan 30 07:45:31 localhost kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) Jan 30 07:45:31 localhost kernel: [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) Jan 30 07:45:31 localhost kernel: [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) Jan 30 07:45:31 localhost kernel: [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) Jan 30 07:45:31 localhost kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) Jan 30 07:45:31 localhost kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) Jan 30 07:45:31 localhost kernel: [ 0.000000] .text : 0xc0008000 - 0xc096c534 (9618 kB) Jan 30 07:45:31 localhost kernel: [ 0.000000] .init : 0xc096d000 - 0xc09c1ec0 ( 340 kB) Jan 30 07:45:31 localhost kernel: [ 0.000000] .data : 0xc09c2000 - 0xc0a33450 ( 454 kB) Jan 30 07:45:31 localhost kernel: [ 0.000000] .bss : 0xc0a33c04 - 0xc0b66f88 (1229 kB) Jan 30 07:45:31 localhost kernel: [ 0.000000] Preemptible hierarchical RCU implementation. Jan 30 07:45:31 localhost kernel: [ 0.000000] Additional per-CPU info printed with stalls. Jan 30 07:45:31 localhost kernel: [ 0.000000] NR_IRQS:544 Jan 30 07:45:31 localhost kernel: [ 0.000000] Architected local timer running at 24.00MHz. Jan 30 07:45:31 localhost kernel: [ 0.000000] Switching to timer-based delay loop Jan 30 07:45:31 localhost kernel: [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms Jan 30 07:45:31 localhost kernel: [ 0.000000] Console: colour dummy device 80x30 Jan 30 07:45:31 localhost kernel: [ 0.000000] console [tty1] enabled Jan 30 07:45:31 localhost kernel: [ 0.000275] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000) Jan 30 07:45:31 localhost kernel: [ 0.000299] pid_max: default: 32768 minimum: 301 Jan 30 07:45:31 localhost kernel: [ 0.000464] Security Framework initialized Jan 30 07:45:31 localhost kernel: [ 0.000489] AppArmor: AppArmor disabled by boot time parameter Jan 30 07:45:31 localhost kernel: [ 0.000679] Mount-cache hash table entries: 512 Jan 30 07:45:31 localhost kernel: [ 0.001694] Initializing cgroup subsys cpuacct Jan 30 07:45:31 localhost kernel: [ 0.001710] Initializing cgroup subsys memory Jan 30 07:45:31 localhost kernel: [ 0.001757] Initializing cgroup subsys devices Jan 30 07:45:31 localhost kernel: [ 0.001771] Initializing cgroup subsys freezer Jan 30 07:45:31 localhost kernel: [ 0.001783] Initializing cgroup subsys blkio Jan 30 07:45:31 localhost kernel: [ 0.001809] Initializing cgroup subsys perf_event Jan 30 07:45:31 localhost kernel: [ 0.001893] CPU: Testing write buffer coherency: ok Jan 30 07:45:31 localhost kernel: [ 0.001936] ftrace: allocating 26327 entries in 78 pages Jan 30 07:45:31 localhost kernel: [ 0.030344] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 Jan 30 07:45:31 localhost kernel: [ 0.030362] [sunxi_smp_prepare_cpus] enter Jan 30 07:45:31 localhost kernel: [ 0.030404] Setting up static identity map for 0x406a1858 - 0x406a18b0 Jan 30 07:45:31 localhost kernel: [ 0.031423] CPU1: Booted secondary processor Jan 30 07:45:31 localhost kernel: [ 0.031423] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 Jan 30 07:45:31 localhost kernel: [ 0.031556] CPU2: Booted secondary processor Jan 30 07:45:31 localhost kernel: [ 0.031556] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002 Jan 30 07:45:31 localhost kernel: [ 0.040518] CPU3: Booted secondary processor Jan 30 07:45:31 localhost kernel: [ 0.040518] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003 Jan 30 07:45:31 localhost kernel: [ 0.040639] Brought up 4 CPUs Jan 30 07:45:31 localhost kernel: [ 0.040639] SMP: Total of 4 processors activated (19200.00 BogoMIPS). Jan 30 07:45:31 localhost kernel: [ 0.040934] devtmpfs: initialized Jan 30 07:45:31 localhost kernel: [ 0.052407] wakeup src cnt is : 2. Jan 30 07:45:31 localhost kernel: [ 0.052419] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 Jan 30 07:45:31 localhost kernel: [ 0.052430] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x0 Jan 30 07:45:31 localhost kernel: [ 0.052441] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 Jan 30 07:45:31 localhost kernel: [ 0.052453] [exstandby]leave extended_standby_enable_wakeup_src : event 0x800000 Jan 30 07:45:31 localhost kernel: [ 0.052463] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_map 0x8 Jan 30 07:45:31 localhost kernel: [ 0.052474] [exstandby]leave extended_standby_enable_wakeup_src : wakeup_gpio_group 0x40 Jan 30 07:45:31 localhost kernel: [ 0.052486] sunxi pm init Jan 30 07:45:31 localhost kernel: [ 0.052639] pinctrl core: initialized pinctrl subsystem Jan 30 07:45:31 localhost kernel: [ 0.062903] NET: Registered protocol family 16 Jan 30 07:45:31 localhost kernel: [ 0.063869] DMA: preallocated 2048 KiB pool for atomic coherent allocations Jan 30 07:45:31 localhost kernel: [ 0.063869] script_sysfs_init success Jan 30 07:45:31 localhost kernel: [ 0.063869] sunxi_dump_init success Jan 30 07:45:31 localhost kernel: [ 0.063869] gpiochip_add: registered GPIOs 0 to 383 on device: sunxi-pinctrl Jan 30 07:45:31 localhost kernel: [ 0.063869] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver Jan 30 07:45:31 localhost kernel: [ 0.063869] plat: add bmp085 device Jan 30 07:45:31 localhost kernel: [ 0.063869] plat: add pcf8591 device Jan 30 07:45:31 localhost kernel: [ 0.063869] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. Jan 30 07:45:31 localhost kernel: [ 0.063869] hw-breakpoint: maximum watchpoint size is 8 bytes. Jan 30 07:45:31 localhost kernel: [ 0.063869] script config pll_video to 297 Mhz Jan 30 07:45:31 localhost kernel: [ 0.063869] script config pll_de to 864 Mhz Jan 30 07:45:31 localhost kernel: [ 0.063869] script config pll_ve to 402 Mhz Jan 30 07:45:31 localhost kernel: [ 0.063869] sunxi_default_clk_init Jan 30 07:45:31 localhost kernel: [ 0.063869] try to set pll6ahb1 to 200000000 Jan 30 07:45:31 localhost kernel: [ 0.063869] try to set ahb clk source to pll6ahb1 Jan 30 07:45:31 localhost kernel: [ 0.063869] set ahb clk source to pll6ahb1 Jan 30 07:45:31 localhost kernel: [ 0.063869] try to set ahb1 to 200000000 Jan 30 07:45:31 localhost kernel: [ 0.063869] try to set apb1 to 100000000 Jan 30 07:45:31 localhost kernel: [ 0.070241] bio: create slab <bio-0> at 0 Jan 30 07:45:31 localhost kernel: [ 0.070319] [ARISC] :sunxi-arisc driver v1.04 Jan 30 07:45:31 localhost kernel: [ 0.092555] [ARISC] :arisc version: [v0.1.58] Jan 30 07:45:31 localhost kernel: [ 0.185052] [ARISC] :sunxi-arisc driver v1.04 startup succeeded Jan 30 07:45:31 localhost kernel: [ 0.186683] SCSI subsystem initialized Jan 30 07:45:31 localhost kernel: [ 0.186683] usbcore: registered new interface driver usbfs Jan 30 07:45:31 localhost kernel: [ 0.186683] usbcore: registered new interface driver hub Jan 30 07:45:31 localhost kernel: [ 0.186683] usbcore: registered new device driver usb Jan 30 07:45:31 localhost kernel: [ 0.186683] twi_chan_cfg()340 - [twi0] has no twi_regulator. Jan 30 07:45:31 localhost kernel: [ 0.186683] twi_chan_cfg()340 - [twi1] has no twi_regulator. Jan 30 07:45:31 localhost kernel: [ 0.186683] twi_chan_cfg()340 - [twi2] has no twi_regulator. Jan 30 07:45:31 localhost kernel: [ 0.186683] Linux video capture interface: v2.00 Jan 30 07:45:31 localhost kernel: [ 0.186683] Advanced Linux Sound Architecture Driver Version 1.0.25. Jan 30 07:45:31 localhost kernel: [ 0.186683] cfg80211: Calling CRDA to update world regulatory domain Jan 30 07:45:31 localhost kernel: [ 0.190036] NetLabel: Initializing Jan 30 07:45:31 localhost kernel: [ 0.190036] NetLabel: domain hash size = 128 Jan 30 07:45:31 localhost kernel: [ 0.190040] NetLabel: protocols = UNLABELED CIPSOv4 Jan 30 07:45:31 localhost kernel: [ 0.190108] NetLabel: unlabeled traffic allowed by default Jan 30 07:45:31 localhost kernel: [ 0.190464] Switching to clocksource arch_sys_counter Jan 30 07:45:31 localhost kernel: [ 0.204704] FS-Cache: Loaded Jan 30 07:45:31 localhost kernel: [ 0.205003] CacheFiles: Loaded Jan 30 07:45:31 localhost kernel: [ 0.216196] NET: Registered protocol family 2 Jan 30 07:45:31 localhost kernel: [ 0.227406] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) Jan 30 07:45:31 localhost kernel: [ 0.228026] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) Jan 30 07:45:31 localhost kernel: [ 0.229788] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) Jan 30 07:45:31 localhost kernel: [ 0.230876] TCP: Hash tables configured (established 131072 bind 65536) Jan 30 07:45:31 localhost kernel: [ 0.230888] TCP: reno registered Jan 30 07:45:31 localhost kernel: [ 0.230903] UDP hash table entries: 512 (order: 2, 16384 bytes) Jan 30 07:45:31 localhost kernel: [ 0.230941] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) Jan 30 07:45:31 localhost kernel: [ 0.231298] NET: Registered protocol family 1 Jan 30 07:45:31 localhost kernel: [ 0.231730] RPC: Registered named UNIX socket transport module. Jan 30 07:45:31 localhost kernel: [ 0.231742] RPC: Registered udp transport module. Jan 30 07:45:31 localhost kernel: [ 0.231751] RPC: Registered tcp transport module. Jan 30 07:45:31 localhost kernel: [ 0.231759] RPC: Registered tcp NFSv4.1 backchannel transport module. Jan 30 07:45:31 localhost kernel: [ 0.231973] Trying to unpack rootfs image as initramfs... Jan 30 07:45:31 localhost kernel: [ 0.513278] Freeing initrd memory: 4380K Jan 30 07:45:31 localhost kernel: [ 0.513811] hw perfevents: enabled with ARMv7 Cortex_A7 PMU driver, 5 counters available Jan 30 07:45:31 localhost kernel: [ 0.513943] sunxi_reg_init enter Jan 30 07:45:31 localhost kernel: [ 0.514916] audit: initializing netlink socket (disabled) Jan 30 07:45:31 localhost kernel: [ 0.514970] type=2000 audit(0.510:1): initialized Jan 30 07:45:31 localhost kernel: [ 0.516229] highmem bounce pool size: 64 pages Jan 30 07:45:31 localhost kernel: [ 0.517119] squashfs: version 4.0 (2009/01/31) Phillip Lougher Jan 30 07:45:31 localhost kernel: [ 0.517307] misc fatfs initialized Jan 30 07:45:31 localhost kernel: [ 0.517529] NFS: Registering the id_resolver key type Jan 30 07:45:31 localhost kernel: [ 0.517908] nfs4filelayout_init: NFSv4 File Layout Driver Registering... Jan 30 07:45:31 localhost kernel: [ 0.517923] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). Jan 30 07:45:31 localhost kernel: [ 0.518677] NTFS driver 2.1.30 [Flags: R/W]. Jan 30 07:45:31 localhost kernel: [ 0.518982] fuse init (API version 7.18) Jan 30 07:45:31 localhost kernel: [ 0.519744] Btrfs loaded Jan 30 07:45:31 localhost kernel: [ 0.519770] msgmni has been set to 1471 Jan 30 07:45:31 localhost kernel: [ 0.521316] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) Jan 30 07:45:31 localhost kernel: [ 0.521338] io scheduler noop registered Jan 30 07:45:31 localhost kernel: [ 0.521348] io scheduler deadline registered Jan 30 07:45:31 localhost kernel: [ 0.521412] io scheduler cfq registered (default) Jan 30 07:45:31 localhost kernel: [ 0.521839] [DISP]disp_module_init Jan 30 07:45:31 localhost kernel: [ 0.522146] cmdline,init_disp= Jan 30 07:45:31 localhost kernel: [ 0.522177] cmdline,disp= Jan 30 07:45:31 localhost kernel: [ 0.542853] [DISP] Fb_map_kernel_logo,line:932:Fb_map_kernel_logo failed! Jan 30 07:45:31 localhost kernel: [ 0.587775] Console: switching to colour frame buffer device 270x75 Jan 30 07:45:31 localhost kernel: [ 0.633703] [DISP]disp_module_init finish Jan 30 07:45:31 localhost kernel: [ 0.633950] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator. Jan 30 07:45:31 localhost kernel: [ 0.634260] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI Jan 30 07:45:31 localhost kernel: [ 0.634274] sw_uart_pm()890 - uart0 clk is already enable Jan 30 07:45:31 localhost kernel: [ 0.634294] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n Jan 30 07:45:31 localhost kernel: [ 0.634433] console [ttyS0] enabled Jan 30 07:45:31 localhost kernel: [ 0.634997] sunxi_cmatest_init enter Jan 30 07:45:31 localhost kernel: [ 0.635036] sunxi_cmatest_init success Jan 30 07:45:31 localhost kernel: [ 0.639274] brd: module loaded Jan 30 07:45:31 localhost kernel: [ 0.643300] loop: module loaded Jan 30 07:45:31 localhost kernel: [ 0.643605] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator. Jan 30 07:45:31 localhost kernel: [ 0.643619] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator. Jan 30 07:45:31 localhost kernel: [ 0.644238] spi spi0: master is unqueued, this is deprecated Jan 30 07:45:31 localhost kernel: [ 0.644582] tun: Universal TUN/TAP device driver, 1.6 Jan 30 07:45:31 localhost kernel: [ 0.644592] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> Jan 30 07:45:31 localhost kernel: [ 0.645553] PPP generic driver version 2.4.2 Jan 30 07:45:31 localhost kernel: [ 0.645760] PPP BSD Compression module registered Jan 30 07:45:31 localhost kernel: [ 0.645770] PPP Deflate Compression module registered Jan 30 07:45:31 localhost kernel: [ 0.648669] PPP MPPE Compression module registered Jan 30 07:45:31 localhost kernel: [ 0.648688] NET: Registered protocol family 24 Jan 30 07:45:31 localhost kernel: [ 0.648769] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver Jan 30 07:45:31 localhost kernel: [ 0.668881] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver Jan 30 07:45:31 localhost kernel: [ 0.668920] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1 Jan 30 07:45:31 localhost kernel: [ 0.669495] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000 Jan 30 07:45:31 localhost kernel: [ 0.680042] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00 Jan 30 07:45:31 localhost kernel: [ 0.680735] hub 1-0:1.0: USB hub found Jan 30 07:45:31 localhost kernel: [ 0.680760] hub 1-0:1.0: 1 port detected Jan 30 07:45:31 localhost kernel: [ 0.701142] sunxi-ehci sunxi-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver Jan 30 07:45:31 localhost kernel: [ 0.701172] sunxi-ehci sunxi-ehci.2: new USB bus registered, assigned bus number 2 Jan 30 07:45:31 localhost kernel: [ 0.701582] sunxi-ehci sunxi-ehci.2: irq 106, io mem 0xf1c1b000 Jan 30 07:45:31 localhost kernel: [ 0.720036] sunxi-ehci sunxi-ehci.2: USB 0.0 started, EHCI 1.00 Jan 30 07:45:31 localhost kernel: [ 0.720053] ehci_irq: highspeed device connect Jan 30 07:45:31 localhost kernel: [ 0.720591] hub 2-0:1.0: USB hub found Jan 30 07:45:31 localhost kernel: [ 0.720616] hub 2-0:1.0: 1 port detected Jan 30 07:45:31 localhost kernel: [ 0.720986] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver Jan 30 07:45:31 localhost kernel: [ 0.741049] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver Jan 30 07:45:31 localhost kernel: [ 0.741078] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 3 Jan 30 07:45:31 localhost kernel: [ 0.741112] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400 Jan 30 07:45:31 localhost kernel: [ 0.804557] hub 3-0:1.0: USB hub found Jan 30 07:45:31 localhost kernel: [ 0.804583] hub 3-0:1.0: 1 port detected Jan 30 07:45:31 localhost kernel: [ 0.824942] sunxi-ohci sunxi-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver Jan 30 07:45:31 localhost kernel: [ 0.824971] sunxi-ohci sunxi-ohci.2: new USB bus registered, assigned bus number 4 Jan 30 07:45:31 localhost kernel: [ 0.825003] sunxi-ohci sunxi-ohci.2: irq 107, io mem 0xf1c1b400 Jan 30 07:45:31 localhost kernel: [ 0.884541] hub 4-0:1.0: USB hub found Jan 30 07:45:31 localhost kernel: [ 0.884561] hub 4-0:1.0: 1 port detected Jan 30 07:45:31 localhost kernel: [ 0.884932] Initializing USB Mass Storage driver... Jan 30 07:45:31 localhost kernel: [ 0.885112] usbcore: registered new interface driver usb-storage Jan 30 07:45:31 localhost kernel: [ 0.885122] USB Mass Storage support registered. Jan 30 07:45:31 localhost kernel: [ 0.885177] usbcore: registered new interface driver ums-alauda Jan 30 07:45:31 localhost kernel: [ 0.885225] usbcore: registered new interface driver ums-cypress Jan 30 07:45:31 localhost kernel: [ 0.885272] usbcore: registered new interface driver ums-datafab Jan 30 07:45:31 localhost kernel: [ 0.885316] usbcore: registered new interface driver ums_eneub6250 Jan 30 07:45:31 localhost kernel: [ 0.885361] usbcore: registered new interface driver ums-freecom Jan 30 07:45:31 localhost kernel: [ 0.885406] usbcore: registered new interface driver ums-isd200 Jan 30 07:45:31 localhost kernel: [ 0.885453] usbcore: registered new interface driver ums-jumpshot Jan 30 07:45:31 localhost kernel: [ 0.885497] usbcore: registered new interface driver ums-karma Jan 30 07:45:31 localhost kernel: [ 0.885542] usbcore: registered new interface driver ums-onetouch Jan 30 07:45:31 localhost kernel: [ 0.885600] usbcore: registered new interface driver ums-realtek Jan 30 07:45:31 localhost kernel: [ 0.885649] usbcore: registered new interface driver ums-sddr09 Jan 30 07:45:31 localhost kernel: [ 0.885696] usbcore: registered new interface driver ums-sddr55 Jan 30 07:45:31 localhost kernel: [ 0.885748] usbcore: registered new interface driver ums-usbat Jan 30 07:45:31 localhost kernel: [ 0.885970] uinput result 0 , vmouse_init Jan 30 07:45:31 localhost kernel: [ 0.886606] mousedev: PS/2 mouse device common for all mice Jan 30 07:45:31 localhost kernel: [ 0.886859] sunxikbd_init failed. Jan 30 07:45:31 localhost kernel: [ 0.887387] ls_fetch_sysconfig_para: type err device_used = -1073057456. Jan 30 07:45:31 localhost kernel: [ 0.887398] =========script_get_err============ Jan 30 07:45:31 localhost kernel: [ 0.887406] ltr_init: ls_fetch_sysconfig_para err. Jan 30 07:45:31 localhost kernel: [ 0.888020] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0 Jan 30 07:45:31 localhost kernel: [ 0.888071] i2c /dev entries driver Jan 30 07:45:31 localhost kernel: [ 0.888490] sunxi cedar version 0.1 Jan 30 07:45:31 localhost kernel: [ 0.888532] [cedar]: install start!!! Jan 30 07:45:31 localhost kernel: [ 0.888727] [cedar]: install end!!! Jan 30 07:45:31 localhost kernel: [ 0.888981] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x18) Jan 30 07:45:31 localhost kernel: [ 0.889155] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x19) Jan 30 07:45:31 localhost kernel: [ 0.889326] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x1a) Jan 30 07:45:31 localhost kernel: [ 0.889496] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x29) Jan 30 07:45:31 localhost kernel: [ 0.889666] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2a) Jan 30 07:45:31 localhost kernel: [ 0.889835] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x2b) Jan 30 07:45:31 localhost kernel: [ 0.890005] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4c) Jan 30 07:45:31 localhost kernel: [ 0.890200] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4d) Jan 30 07:45:31 localhost kernel: [ 0.890370] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x4e) Jan 30 07:45:31 localhost kernel: [ 0.890571] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18) Jan 30 07:45:31 localhost kernel: [ 0.890768] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19) Jan 30 07:45:31 localhost kernel: [ 0.890964] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1a) Jan 30 07:45:31 localhost kernel: [ 0.891159] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29) Jan 30 07:45:31 localhost kernel: [ 0.891355] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2a) Jan 30 07:45:31 localhost kernel: [ 0.891551] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x2b) Jan 30 07:45:31 localhost kernel: [ 0.891746] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c) Jan 30 07:45:31 localhost kernel: [ 0.891942] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4d) Jan 30 07:45:31 localhost kernel: [ 0.892138] sunxi_i2c_do_xfer()985 - [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4e) Jan 30 07:45:31 localhost kernel: [ 0.892154] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0 Jan 30 07:45:31 localhost kernel: [ 0.892324] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf Jan 30 07:45:31 localhost kernel: [ 0.892479] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0) Jan 30 07:45:31 localhost kernel: [ 0.892492] wdt_enable, write reg 0xf1c20cb8 val 0x00000000 Jan 30 07:45:31 localhost kernel: [ 0.892502] timeout_to_interv, line 167 Jan 30 07:45:31 localhost kernel: [ 0.892511] interv_to_timeout, line 189 Jan 30 07:45:31 localhost kernel: [ 0.892520] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec Jan 30 07:45:31 localhost kernel: [ 0.892965] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com Jan 30 07:45:31 localhost kernel: [ 0.893182] calibrat: max_cpufreq 1200Mhz Type 0! Jan 30 07:45:31 localhost kernel: [ 0.893519] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.111 2015-4-13 15:24) Compiled in Jan 30 2017 at 09:14:31 Jan 30 07:45:31 localhost kernel: [ 0.893555] [mmc]: get mmc0's sdc_power is null! Jan 30 07:45:31 localhost kernel: [ 0.893585] [mmc]: get mmc1's sdc_power is null! Jan 30 07:45:31 localhost kernel: [ 0.893595] [mmc]: get mmc1's 2xmode ok, val = 1 Jan 30 07:45:31 localhost kernel: [ 0.893605] [mmc]: get mmc1's ddrmode ok, val = 1 Jan 30 07:45:31 localhost kernel: [ 0.893623] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2 Jan 30 07:45:31 localhost kernel: [ 0.897168] [mmc]: sdc0 power_supply is null Jan 30 07:45:31 localhost kernel: [ 0.899056] no blue_led, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899274] Registered led device: red_led Jan 30 07:45:31 localhost kernel: [ 0.899380] Registered led device: green_led Jan 30 07:45:31 localhost kernel: [ 0.899397] no led_0, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899404] no led_1, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899412] no led_2, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899419] no led_3, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899426] no led_4, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899433] no led_5, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899440] no led_6, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.899447] no led_7, ignore it! Jan 30 07:45:31 localhost kernel: [ 0.900293] usbcore: registered new interface driver usbhid Jan 30 07:45:31 localhost kernel: [ 0.900303] usbhid: USB HID core driver Jan 30 07:45:31 localhost kernel: [ 0.904415] asoc: sndcodec <-> sunxi-codec mapping ok Jan 30 07:45:31 localhost kernel: [ 0.905571] [DAUDIO]sunxi-daudio cannot find any using configuration for controllers, return directly! Jan 30 07:45:31 localhost kernel: [ 0.905765] [I2S]snddaudio cannot find any using configuration for controllers, return directly! Jan 30 07:45:31 localhost kernel: [ 0.905780] [DAUDIO0] driver not init,just return. Jan 30 07:45:31 localhost kernel: [ 0.909104] asoc: sndhdmi <-> sunxi-hdmiaudio.0 mapping ok Jan 30 07:45:31 localhost kernel: [ 0.910570] oprofile: using arm/armv7-ca7 Jan 30 07:45:31 localhost kernel: [ 0.910787] u32 classifier Jan 30 07:45:31 localhost kernel: [ 0.910796] Performance counters on Jan 30 07:45:31 localhost kernel: [ 0.910804] input device check on Jan 30 07:45:31 localhost kernel: [ 0.910812] Actions configured Jan 30 07:45:31 localhost kernel: [ 0.911005] IPv4 over IPv4 tunneling driver Jan 30 07:45:31 localhost kernel: [ 0.911684] TCP: bic registered Jan 30 07:45:31 localhost kernel: [ 0.911695] TCP: cubic registered Jan 30 07:45:31 localhost kernel: [ 0.911703] TCP: westwood registered Jan 30 07:45:31 localhost kernel: [ 0.911710] TCP: highspeed registered Jan 30 07:45:31 localhost kernel: [ 0.911718] TCP: hybla registered Jan 30 07:45:31 localhost kernel: [ 0.911725] TCP: htcp registered Jan 30 07:45:31 localhost kernel: [ 0.911733] TCP: vegas registered Jan 30 07:45:31 localhost kernel: [ 0.911740] TCP: veno registered Jan 30 07:45:31 localhost kernel: [ 0.911748] TCP: scalable registered Jan 30 07:45:31 localhost kernel: [ 0.911756] TCP: lp registered Jan 30 07:45:31 localhost kernel: [ 0.911764] TCP: yeah registered Jan 30 07:45:31 localhost kernel: [ 0.911771] TCP: illinois registered Jan 30 07:45:31 localhost kernel: [ 0.911779] Initializing XFRM netlink socket Jan 30 07:45:31 localhost kernel: [ 0.912009] NET: Registered protocol family 10 Jan 30 07:45:31 localhost kernel: [ 0.913216] NET: Registered protocol family 17 Jan 30 07:45:31 localhost kernel: [ 0.913247] NET: Registered protocol family 15 Jan 30 07:45:31 localhost kernel: [ 0.913294] Registering the dns_resolver key type Jan 30 07:45:31 localhost kernel: [ 0.913739] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 Jan 30 07:45:31 localhost kernel: [ 0.913762] ThumbEE CPU extension supported. Jan 30 07:45:31 localhost kernel: [ 0.913784] Registering SWP/SWPB emulation handler Jan 30 07:45:31 localhost kernel: [ 0.914383] registered taskstats version 1 Jan 30 07:45:31 localhost kernel: [ 0.914864] cmdline,disp= Jan 30 07:45:31 localhost kernel: [ 0.914903] [HDMI] power vcc-hdmi-18 Jan 30 07:45:31 localhost kernel: [ 0.945850] cmdline,disp= Jan 30 07:45:31 localhost kernel: [ 0.945903] [DISP] disp_init_tv,line:539:screen 0 do not support TV TYPE! Jan 30 07:45:31 localhost kernel: [ 0.945922] [DISP] bsp_disp_tv_register,line:990:'ptv is null Jan 30 07:45:31 localhost kernel: [ 0.945933] tv registered!! Jan 30 07:45:31 localhost kernel: [ 0.963296] mmc0: new high speed SDHC card at address 1234 Jan 30 07:45:31 localhost kernel: [ 0.963777] mmcblk0: mmc0:1234 SA16G 14.5 GiB Jan 30 07:45:31 localhost kernel: [ 0.964999] mmcblk0: p1 Jan 30 07:45:31 localhost kernel: [ 0.965548] mmcblk mmc0:1234: Card claimed for testing. Jan 30 07:45:31 localhost kernel: [ 0.965563] mmc0:1234: SA16G 14.5 GiB Jan 30 07:45:31 localhost kernel: [ 0.980053] ehci_irq: highspeed device disconnect Jan 30 07:45:31 localhost kernel: [ 0.980089] ohci_irq: fullspeed or lowspeed device connect Jan 30 07:45:31 localhost kernel: [ 1.260047] usb 4-1: new full-speed USB device number 2 using sunxi-ohci Jan 30 07:45:31 localhost kernel: [ 1.496750] generic-usb 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-sunxi-ohci-1/input0 Jan 30 07:45:31 localhost kernel: [ 1.550061] [DISP] disp_device_attached_and_enable,line:159:attched ok, mgr0<-->device0, type=4, mode=5 Jan 30 07:45:31 localhost kernel: [ 1.550708] ths_fetch_sysconfig_para: type err device_used = 1. Jan 30 07:45:31 localhost kernel: [ 1.551305] generic-usb 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-sunxi-ohci-1/input1 Jan 30 07:45:31 localhost kernel: [ 1.552107] CPU Budget:corekeeper enabled Jan 30 07:45:31 localhost kernel: [ 1.552337] CPU Budget:Register notifier Jan 30 07:45:31 localhost kernel: [ 1.552351] CPU Budget:register Success Jan 30 07:45:31 localhost kernel: [ 1.552362] sunxi-budget-cooling sunxi-budget-cooling: Cooling device registered: thermal-budget-0 Jan 30 07:45:31 localhost kernel: [ 1.555758] [rf_pm]: module power0 name vcc-wifi-33 Jan 30 07:45:31 localhost kernel: [ 1.555776] [rf_pm]: Did not config module_power1 in sys_config Jan 30 07:45:31 localhost kernel: [ 1.555786] [rf_pm]: Did not config module_power2 in sys_config Jan 30 07:45:31 localhost kernel: [ 1.555796] [rf_pm]: Did not config module_power3 in sys_config Jan 30 07:45:31 localhost kernel: [ 1.555807] [rf_pm]: mod has no chip_en gpio Jan 30 07:45:31 localhost kernel: [ 1.555815] [rf_pm]: failed to fetch lpo_use_apclk Jan 30 07:45:31 localhost kernel: [ 1.555823] [rf_pm]: regulator on. Jan 30 07:45:31 localhost kernel: [ 1.556122] [wifi_pm]: set wl_reg_on 1 ! Jan 30 07:45:31 localhost kernel: [ 1.656161] hci: ERR: sunxi_ehci is null Jan 30 07:45:31 localhost kernel: [ 1.656173] hci: ERR: sunxi_ohci is null Jan 30 07:45:31 localhost kernel: [ 1.657701] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 1.705208] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 1.709330] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 1.756187] [wifi_pm]: wifi gpio init is OK !! Jan 30 07:45:31 localhost kernel: [ 1.756266] [rfkill]: init no bt used in configuration Jan 30 07:45:31 localhost kernel: [ 1.756278] ALSA device list: Jan 30 07:45:31 localhost kernel: [ 1.756286] #0: audiocodec Jan 30 07:45:31 localhost kernel: [ 1.756294] #1: sndhdmi Jan 30 07:45:31 localhost kernel: [ 1.757184] Freeing init memory: 336K Jan 30 07:45:31 localhost kernel: [ 1.768793] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 1.772682] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 1.835787] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 1.839954] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 1.912286] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 2.086595] vmouse_input_dev_open Jan 30 07:45:31 localhost kernel: [ 2.150312] vmouse_input_dev_close Jan 30 07:45:31 localhost kernel: [ 2.717618] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) Jan 30 07:45:31 localhost kernel: [ 5.516994] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 5.565511] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 5.569628] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 5.573645] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro Jan 30 07:45:31 localhost kernel: [ 5.615445] [wifi_pm]: set wl_reg_on 1 ! Jan 30 07:45:31 localhost kernel: [ 5.624533] UMP: UMP device driver loaded Jan 30 07:45:31 localhost kernel: [ 5.628761] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 5.632905] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 5.641380] mali clk: 252 MHz Jan 30 07:45:31 localhost kernel: [ 5.641603] mali clk: 252 MHz Jan 30 07:45:31 localhost kernel: [ 5.643537] Mali: Mali device driver loaded Jan 30 07:45:31 localhost kernel: [ 5.695368] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 5.699480] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 5.772134] [mmc]: sdc1 power_supply is null Jan 30 07:45:31 localhost kernel: [ 7.587134] Adding 131068k swap on /var/swap. Priority:-1 extents:1 across:131068k SS Jan 30 07:45:31 localhost kernel: [ 10.049460] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x77) Jan 30 07:45:31 localhost kernel: [ 10.049497] bmp085: probe of 0-0077 failed with error -70 Jan 30 07:45:31 localhost kernel: [ 10.052460] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x48) Jan 30 07:45:31 localhost kernel: [ 10.052657] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x48, dev addr: 0x48) Jan 30 07:45:31 localhost kernel: [ 10.094528] vmouse_input_dev_open Jan 30 07:45:31 localhost kernel: [ 10.150178] vmouse_input_dev_close Jan 30 07:45:31 localhost kernel: [ 11.314490] gmac0: probed Jan 30 07:45:31 localhost kernel: [ 11.314857] gmac0 gmac0: eth0: eth0: PHY ID 00441400 at 0 IRQ poll (gmac0-0:00) Jan 30 07:45:32 localhost kernel: [ 14.310346] PHY: gmac0-0:00 - Link is Up - 100/Full Jan 30 07:45:34 localhost NetworkManager[555]: <info> [1485762334.1339] NetworkManager (version 1.2.2) is starting... Jan 30 07:45:34 localhost NetworkManager[555]: <info> [1485762334.1386] Read config: /etc/NetworkManager/NetworkManager.conf (etc: default-wifi-powersave-on.conf, zz-override-wifi-powersave-off.conf) Jan 30 07:45:34 localhost NetworkManager[555]: <info> [1485762334.1661] manager[0x705908]: monitoring kernel firmware directory '/lib/firmware'. Jan 30 07:45:34 localhost NetworkManager[555]: <info> [1485762334.1664] monitoring ifupdown state file '/run/network/ifstate'. Jan 30 07:45:34 localhost NetworkManager[555]: <info> [1485762334.1842] dns-mgr[0x70e210]: set resolv-conf-mode: dnsmasq, plugin="dnsmasq" Jan 30 07:45:34 localhost NetworkManager[555]: <info> [1485762334.1844] dns-mgr[0x70e210]: using resolv.conf manager 'resolvconf' Jan 30 07:45:34 localhost kernel: [ 16.079693] [DISP] disp_ioctl,line:1584:para err in disp_ioctl, cmd = 0x0,screen id = 65536 Jan 30 07:45:34 localhost kernel: [ 16.133340] [drm] Initialized drm 1.1.0 20060810 Jan 30 07:45:34 localhost kernel: [ 16.142902] Mali DRM initialize, driver name: mali_drm, version 2.1 Jan 30 07:45:34 localhost kernel: [ 16.143373] [drm] Initialized mali_drm 2.1.1 20101111 on minor 0 Jan 30 07:45:34 localhost kernel: [ 16.143429] Mali DRM initialize, driver name: mali_drm, version 2.1 Jan 30 07:45:34 localhost kernel: [ 16.143818] [drm] Initialized mali_drm 2.1.1 20101111 on minor 1 Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8597] init! Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8620] guessed connection type (eth0) = 802-3-ethernet Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8623] update_connection_setting_from_if_block: name:eth0, type:802-3-ethernet, id:Ifupdown (eth0), uuid: 681b428f-beaf-8932-dce4-687ed5bae28e Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8632] adding eth0 to connections Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8633] adding iface eth0 to eni_ifaces Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8635] autoconnect Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8635] management mode: managed Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8660] devices added (path: /sys/devices/platform/gmac0/net/eth0, iface: eth0) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8664] locking wired connection setting Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8666] devices added (path: /sys/devices/virtual/net/lo, iface: lo) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8667] device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found. Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8668] devices added (path: /sys/devices/virtual/net/tunl0, iface: tunl0) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8668] device added (path: /sys/devices/virtual/net/tunl0, iface: tunl0): no ifupdown configuration found. Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8669] end _init. Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8671] settings: loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-settings-plugin-ifupdown.so) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8674] settings: loaded plugin keyfile: (c) 2007 - 2015 Red Hat, Inc. To report bugs please use the NetworkManager mailing list. Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8714] SettingsPlugin-Ofono: init! Jan 30 07:45:35 localhost NetworkManager[555]: <warn> [1485762334.8718] SettingsPlugin-Ofono: file doesn't exist: /var/lib/ofono Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8719] SettingsPlugin-Ofono: end _init. Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8720] settings: loaded plugin ofono: (C) 2013-2016 Canonical Ltd. To report bugs please use the NetworkManager mailing list. (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-settings-plugin-ofono.so) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8721] (7489840) ... get_connections. Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8721] (7489840) connections count: 1 Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8765] SettingsPlugin-Ofono: (7533832) ... get_connections. Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762334.8766] SettingsPlugin-Ofono: (7533832) connections count: 0 Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9381] settings: hostname: using hostnamed Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9382] settings: hostname changed from (none) to "orangepi2" Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9394] Using DHCP client 'dhclient' Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9397] manager: WiFi enabled by radio killswitch; enabled by state file Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9399] manager: WWAN enabled by radio killswitch; enabled by state file Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9401] manager: Networking is enabled by state file Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9404] Loaded device plugin: NMVxlanFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9407] Loaded device plugin: NMVlanFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9409] Loaded device plugin: NMVethFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9410] Loaded device plugin: NMTunFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9412] Loaded device plugin: NMMacvlanFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9414] Loaded device plugin: NMIPTunnelFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9416] Loaded device plugin: NMInfinibandFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9419] Loaded device plugin: NMEthernetFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9421] Loaded device plugin: NMBridgeFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9422] Loaded device plugin: NMBondFactory (internal) Jan 30 07:45:35 localhost NetworkManager[555]: <info> [1485762335.9806] Loaded device plugin: NMWifiFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wifi.so) Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.0222] Loaded device plugin: NMAtmManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-adsl.so) Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.1917] Loaded device plugin: NMBluezManager (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-bluetooth.so) Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2301] Loaded device plugin: NMWwanFactory (/usr/lib/arm-linux-gnueabihf/NetworkManager/libnm-device-plugin-wwan.so) Jan 30 07:45:36 localhost NetworkManager[555]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2342] device (lo): link connected Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2385] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/0) Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2418] device (eth0): link connected Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2463] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/1) Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2602] keyfile: add connection in-memory (224e76b2-1dc1-469f-a403-ad98ce8fa4d9,"eth0") Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2630] device (eth0): state change: unmanaged -> unavailable (reason 'connection-assumed') [10 20 41] Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2649] device (eth0): state change: unavailable -> disconnected (reason 'connection-assumed') [20 30 41] Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2719] device (eth0): Activation: starting connection 'eth0' (224e76b2-1dc1-469f-a403-ad98ce8fa4d9) Jan 30 07:45:36 localhost NetworkManager[555]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2773] manager: (tunl0): new Generic device (/org/freedesktop/NetworkManager/Devices/2) Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2806] manager: NetworkManager state is now CONNECTED_GLOBAL Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.2948] urfkill disappeared from the bus Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3073] manager: startup complete Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3077] device (eth0): state change: disconnected -> prepare (reason 'none') [30 40 0] Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3112] policy: set 'eth0' (eth0) as default for IPv4 routing and DNS Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3243] device (eth0): state change: prepare -> config (reason 'none') [40 50 0] Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3286] device (eth0): state change: config -> ip-config (reason 'none') [50 70 0] Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3305] device (eth0): state change: ip-config -> ip-check (reason 'none') [70 80 0] Jan 30 07:45:36 localhost NetworkManager[555]: <error> [1485762336.3342] platform-linux: do-add-ip4-address[2: 192.168.1.152/24]: failure 17 (File exists) Jan 30 07:45:36 localhost NetworkManager[555]: <warn> [1485762336.3351] arping[0x772580,2]: arping could not be found; no ARPs will be sent Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3355] device (eth0): state change: ip-check -> secondaries (reason 'none') [80 90 0] Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3375] ofono is now available Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3395] device (eth0): state change: secondaries -> activated (reason 'none') [90 100 0] Jan 30 07:45:36 localhost NetworkManager[555]: <info> [1485762336.3654] device (eth0): Activation: successful, device activated. Jan 30 07:45:36 localhost NetworkManager[555]: <warn> [1485762336.3729] failed to enumerate oFono devices: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files Jan 30 07:45:36 localhost kernel: [ 17.946716] vmouse_input_dev_open Jan 30 07:45:38 localhost NetworkManager[555]: <warn> [1485762338.6796] arping[0x772580,2]: arping could not be found; no ARPs will be sent Jan 30 07:45:40 localhost kernel: [ 21.390065] eth0: no IPv6 routers present Jan 30 07:46:16 localhost NetworkManager[555]: <info> [1485762376.7545] WiFi hardware radio set enabled Jan 30 07:46:16 localhost NetworkManager[555]: <info> [1485762376.7546] WWAN hardware radio set enabled
jernej Posted January 30, 2017 Posted January 30, 2017 Please provide full script.bin & kernel changes. dmesg output shows that script.bin might be misconfigured.
nffs Posted January 31, 2017 Author Posted January 31, 2017 I've replaced HDMI720P_60 mode with my configurations. This is my script.fex and kernel patch
jernej Posted February 1, 2017 Posted February 1, 2017 Regarding the patch: - don't change hdcp_enable variable Why do you want HDMI encryption enabled? It can only bring troubles - you missed few places - it would be better to add new mode instead of changing existing one For proper addition please check this patch: https://github.com/igorpecovnik/lib/blob/master/patch/kernel/sun8i-default/z-0003-add-additional-video-modes.patch Regarding script.fex: - hdcp_enable should be 0 - tv_used should be 0 (if HDMI and TV out are enabled at the same time, artifacts on HDMI might appear) - screen1_output_type and screen1_output_mode should be 0, they are used only for TV out
nffs Posted February 2, 2017 Author Posted February 2, 2017 Thank You for your time and help. It works with latest dev kernel.
jernej Posted February 2, 2017 Posted February 2, 2017 Be aware that simplefb driver in dev version has a lot of limitations - no double buffering, no resolution switching, no power management, no HDMI sound, etc.
nPHYN1T3 Posted July 30, 2017 Posted July 30, 2017 I've been making due but my monitors default resolution is 1600 x 900. I was wondering is there a way to submit this to be included in future builds rather than compiling myself and potentially having it over written by updates?
Igor Posted July 30, 2017 Posted July 30, 2017 Just now, nPHYN1T3 said: I've been making due but my monitors default resolution is 1600 x 900. I was wondering is there a way to submit this to be included in future builds rather than compiling myself and potentially having it over written by updates? The fastest way. Do the math and provide a tested patch - you can use our build tools - and push it to the source. It goes here (H3): https://github.com/armbian/build/tree/master/patch/kernel/sun8i-default
nPHYN1T3 Posted July 31, 2017 Posted July 31, 2017 (edited) I'll have to do some reading this week and give it a go. Thanks for the reply and info. **UPDATE! (read it in Robert Stacks voice) Well I've been reading and on the kernel build page there is a lot of discussion about H3 boards being largely unsupported if almost not at all with 4x kernels. Sifting through fex and patch pages this looks like far too large a time sink than I can deal with for changing resolution. Plus the OP's link to the u-boot file referenced is 404. Maybe over the next few months I'll slowly chip away at things but there seem to be too many problems and specifics for me to wade through. Though I'm not ruling out that the kernel build discussions have given me a possibly over complicated view of things but it's been 15 or so years since I did anything like this and back then it was building BSD kernels for speed of purpose. Comically these tiny dev boards remind me of those days because compiling anything takes days! heh. Edited August 2, 2017 by nPHYN1T3 Update info
