Hi all!
I have browsing the forum quite while but I did not a solution for my problem. I have bought the OP Zero from DX.com and it came with an expansion board which has two additional USB ports, a 3.5 mm AV socket and a built in microphone. And now I would like to use the audio socket as audio output and I want to use its microphone as well. But I headed some problems and I cannot use its audio features .
I am using this kernel: Armbian_5.24_Orangepizero_Ubuntu_xenial_dev_4.9.4
I think there is no audio driver installed on this system.
here are some other debug info:
aplay: device_list:268: no soundcards found...
arecord: device_list:268: no soundcards found...
!!All Loaded Modules
Module
ccm
evdev
xradio_wlan
mac80211
cfg80211
rfkill
sun8i_ths
cpufreq_dt
uio_pdrv_genirq
thermal_sys
gpio_keys
uio
Could you please someone help me how to configure the Orange Pi Zero on board audio?
Do I need to install any audio driver? If yes, how?
If you need any additional information feel free to ask.
Thank you!
Kernel 4.8.4. You are using developing kernel for which we don't provide any end user support. It's meant for developers and testing. On the download page, there is a big red sign: Warning: nightly downloads are automated untested builds and no end user support is provided for them!
If you want audio and microphone with this kernel and addon, which is not officially supported yet, you need to write a driver. There is nothing like "install a driver".
http://linux-sunxi.org/Linux_mainlining_effort / here you can see how far things are developed
You will have more success with old kernel 3.4.113 ... but even there you might need to play with board configuration (/boot/script.bin) switches. Microphone or audio might be disabled on this board, since by default it doesn't have audio connector.
Thank you for your fast response! Unfortunately I have ingnored that red sign... Maybe I will try other kernel if I will be in trouble with the driver.
Thanks again!
Thanks again!
I did try a "official" image from http://www.orangepi.org/downloadresources/ :
Raspbian Server - updated: 2017-05-05
which links to http://www.orangepi.org/downloadresources/orangepizero/2017-05-05/orangepizero_e7c74a532b47c34968b5098.html
Original release date was 2016-11-24 with version 0.8.0 ( Raspbian_server_For_zero_H2+_V0_1 )
Its has (as told to me) a "horrible outdated  kernel(
uname -r : 3.4.39)", but has a working audio-driver for the analog and the (not inclueded) HDMI-Connector:
root@OrangePI:~# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: audiocodec [audiocodec], device 0: SUNXI-CODEC sndcodec-0 []
  Subdevices: 0/1
  Subdevice #0: subdevice #0
card 1: sndhdmi [sndhdmi], device 0: SUNXI-HDMIAUDIO sndhdmi-0 []
  Subdevices: 1/1
see also
As all of our images in download section with a label "legacy kernel" which contains kernel 3.4.113 with 100+ fixes on top of horribly outdated 3.4.39, found in stock builds. There is another DEV kernel (currently 4.13), which we are talking about here and that one lacks some basic functions.
It is possible that certain features are disabled in board config in our image for Opi Zero. If there is no audio connector on board, this feature might be disabled ... but it can be simple enable back.
Its fine to read that the kernel 3.4.114 has so much fixes, but with my OPi Zero and the USB/Audio-Expansionboard (plus case) - for me - its getting hotter than the stock kernel 3.4.39.
The new kernel from the mainline does not getting so hot like the legacy kernel with fixes.
So I will hope & bid for 2 things / possibilities:
1.) include the dynamic cpu-switching like in mainline to the legacy kernel
or
2.) include/enable the audio-feature (like in the stock kernel) to the mainline kernel.
I think in future much more people will request this feature (for the mainline kernel) , because on eBay they sell the OPi Zero + USB/Audio-Board + Case as a kit:
http://www.ebay.co.uk/itm/3-in-1-Orange-Pi-Zero-512MB-Development-Board-Expansion-Board-Black-Case-Kit/142329429602
Judging by the scientific method and using an external temperature meter? We invested hundreds of hours into optimising those things (check h3consumtion tool for going deeper with this), while board maker hasn't done anything at all. I am wondering how this is possible since so far we could only find people saying it's running cooler with Armbian than with stock image. There are some troubles with Zero rev. 1.4 and in general this board heat dispersion is bad.
Mainline kernel is not ready yet but close. There is no way to speed up the process if you rely on few amateurs doing this.
Its was a finger-feeling and not a external temperature meter, but I think I found "my problem".
First after yor message I did use the internal temperature meter named
cat /sys/devices/virtual/thermal/thermal_zone0/temp
cat /sys/devices/virtual/thermal/thermal_zone1/temp (not available at Mainline Kernel)
So I did try Stock-, Legacy- and Mainline-Kernel:
Stock Kernel
Linux OrangePI 3.4.39 #2 SMP PREEMPT Mon Nov 21 16:23:11 CST 2016 armv7l GNU/Linux
idle 66-67 degree Celsius
SanDisk Ultra SDHC 16GB Class 10
Legacy Kernel
Linux orangepizero 3.4.113-sun8i #18 SMP PREEMPT Thu Jun 15 02:16:06 CEST 2017 armv7l armv7l armv7l GNU/Linux
idle 62-67 degree Celsius
Kingston SDHC 8GB Class 4
Mainline Kernel
Linux orangepizero 4.11.12-sun8i #1 SMP Wed Aug 23 15:21:32 CEST 2017 armv7l armv7l armv7l GNU/Linux
idle 54-58 degree Celsius
As I didnt got a third "SanDisk Ultra SDHC 16GB Class 10" I used a "Kingston SDHC 8GB Class 4" for the Legacy-Kernel.
Above we can see that there isnt much difference between Stock and Legacy-Kernel here (in the end 67 degree idle), BUT
I must admit that the OPi Zero is getting hotter around the Class 4 Kingston Card against the Class 10 SanDisk Ultra.
So my finger-feeling could belong to a hotter MicroSD-Cards rather than to the complete system which is measured from the internal temperature-sensor.
I have to check if the Legacy-Kernel would be running cooler if I flash it on the Class 10 Sandisk Ultra.
Do you got informations about different temperatures with different MicroSD Cards?
I did got this as a problem on my mind.
Iam very pleased with the work from the armbian-teams - also for the OPi Zero.
I understand to esteem the hard work here while not getting informations from the maker-companys of the boards.
For me you are all very cool doing support for single-board-computers which have lost their manufacturer-support sometimes after an initial release.
I know the v1.4 doenst seems the best revision of the board in meaning of heat - but I does come with the kit to me :(
If there is the legacy working for me (with a newer MicroSD Card) then there is no problem for me to wait for a great mainline-kernel.
And if there will be audio included I will be very happy.
The "few amateurs" be certain to do a great job!
2 hours ago, Dmitry_ said:
Has the current mainline Armbian 5.36 kernel 4.13.16 no audio drivers too?
Both kernels have audio drivers and on both kernels, audio is disabled by default because there is no audio connector.
You can enable it by yourself :)
armbian-config -> System -> Hardware: select analog-audio with the space-key
then SAVE and exit armbian-config and reboot
Did work for me :)
I've figured out the problem. If I use out-of-the box 5.35 then I have sound. If I run `apt upgrade`  then it updates to 5.36 and the sound does not work there. By the way the `README.sun8i-h3-overlays` file has no words "sound" or "audio" in it. It was not strait forward to figure out that is "audio-codec" is for sound. I've search for this for this words and found nothing. I think you should put them there.
I have
ARMBIAN 5.37.171221 nightly Ubuntu 16.04.3 LTS 4.14.8-sunxi
Linux orangepizero 4.14.8-sunxi #58 SMP Thu Dec 21 09:27:04 CET 2017 armv7l armv7l armv7l GNU/Linux
and audio
root@orangepizero:~# aplay -l
card 0: Codec [H3 Audio Codec], device 0: CDC PCM Codec-0 []
  Subdevices: 1/1
you only have to use the command "armbian-config" and use the menu as I did wrote before :)
Then it might be some other thing I've changed. This is my login screen:
Welcome to ARMBIAN 5.36 user-built Ubuntu 16.04.3 LTS 4.13.16-sunxi
System load:   0.64 0.16 0.05      Up time:       0 min
Memory usage:  13 % of 240MB      IP:            10.0.1.1
CPU temp:      29°C
Usage of /:    9% of 15G
This is my armbianEnv.txt:
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun8i-h3
overlays=analog-codec i2c0 spi-spidev uart1 uart2 usbhost2 usbhost3
rootdev=UUID=ebe9dacf-124f-486c-b6c1-08749e209374
rootfstype=ext4
param_spidev_spi_bus=1
param_spidev_max_freq=32000000
This is my /etc/modules:
g_serial
fbtft_device
fbtft_device is defined in /etc/modprobe.d/fbtft_device.conf
options fbtft_device name=tm022hdh26 buswidth=8 rotate=270 gpios=reset:7,dc:2,led:6 fps=10 busnum=1 width=240 height=320
I have X.org and Qt5 installed and some Python3 libraries. And I also upgraded from 5.35 to 5.36.  I think that's all I've changed, as far as I can remember. I also have a RTL8188CUS wi-fi dongle which worked out of the box on the mainline release. When I run `ls -lah /dev/snd` I get
total 0
drwxr-xr-x  2 root root       60 Feb 11  2016 .
drwxr-xr-x 13 root root      14K Feb 11  2016 ..
crw-rw----  1 root audio 116, 33 Feb 11  2016 timer
total 0
You got "ARMBIAN 5.36 user-built"  and I got "ARMBIAN 5.37.171221 nightly"
my "ls -lah /dev/snd"
root@orangepizero:/boot# ls -lah /dev/snd
total 0
drwxr-xr-x  3 root root      140 Dec 26 13:07 .
drwxr-xr-x 13 root root      14K Dec 26 13:07 ..
drwxr-xr-x  2 root root       60 Dec 26 13:07 by-path
crw-rw----  1 root audio 116,  0 Dec 26 13:07 controlC0
crw-rw----  1 root audio 116, 24 Dec 26 13:07 pcmC0D0c
crw-rw----  1 root audio 116, 16 Dec 26 13:07 pcmC0D0p
crw-rw----  1 root audio 116, 33 Dec 26 13:07 timer
there is something missing in your ARMBIAN build :(
Could you try the nightly-version: https://dl.armbian.com/orangepizero/nightly/Armbian_5.34.171121_Orangepizero_Ubuntu_xenial_next_4.13.14.7z
and update it to 5.37 via apt update & upgrade?
Your other files doesnt show something special.
I got only 2 usbhosts active (and cir for infrared):
overlays=analog-codec cir usbhost2 usbhost3
On my/this Opi Zero does run my InterNetradio via node.js/NodeRed/NodeRed_dashboard/mpg123/mplayer :)
SO sound is working in the nightly :)
Hi, I have a similar problem on my OPi zero. I have
overlays=analog-codec is set but nothing happens, not the silghtest hint what might go wrong in dmesg.
But when I do
sudo modprobe sun8i-codec-analog
sudo modprobe sun4i-codec
I get
jgeisler@orangepizero:~$ aplay -l
  Subdevices: 1/1
and
jgeisler@orangepizero:~$ dmesg|tail
[  142.801380] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
That looks promising, though I have not yet soldered a jack to the pins to see if the audio actually works. What does that tell me? What is going wrong with the overlay?
11 hours ago, jgeisler said:
But when I do
I get
  Subdevices: 1/1
Looks like the overlay is OK, but you only did miss a automatic modprobe
(dont know if activating a overlay also enables some modprobe)
You could  insert the commands in /etc/rc.local or try to put the 2 modules in /etc/modules?
sun4i_codec
sun8i_codec_analog
My demsg is also showing only this one mapping line for the codec, but lsmod shows me for the codec-modules (without manual modprobe):
root@orangepizero:~# lsmod
Module                  Size  Used by
sun4i_codec            32768  3
sun8i_codec_analog     24576  1
Yay, it works. I get audio. Loading the modules via /etc/modules is a good solution.
Now I just wonder, what the overlay does. Looking at this source code sun8i-h3-analog-codec.dts, I don't see anything that might load a driver. I thought that is what overlays do: load and configure drivers. Maybe this overlay is incomplete?
On 12/26/2017 at 4:36 PM, guidol said:
I have
and audio
  Subdevices: 1/1
I have Armbian 5.38
I connected pin 8 and 2 (also 7 and 2) in single header of Orange PI Zero.  When I execute the command u mentioned above (aplay -l) I get the same results. BTW Master and PCM channels are not in Alsamixer and there was no file called .asoundrc. So I created a one.
pcm.!default{
    type hw
    card 0
ctl.!default{
    type hw
    card 0
But when I execute speaker-test I get no sound but this.
speaker-test 1.1.3
Playback device is default
Stream parameters are 48000Hz, S16_LE, 1 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 256 to 262144
Period size range from 128 to 32768
Using max buffer size 262144
Periods = 4
I tried to play a music using  aplay song.mp3 but I got,
aplay: set_params:1299: Sample format non available
Available formats:
- S16_LE
- S32_LE
So how can I sort this out? :(
Thank you :)
35 minutes ago, VihangaA said:
I have Armbian 5.38
Thank you :)
M OPi Zero is now at
ARMBIAN 5.44.180510 nightly Ubuntu 16.04.4 LTS 4.14.40-sunxi
Linux orangepizero 4.14.40-sunxi #155 SMP Sat May 12 11:12:46 CEST 2018 armv7l armv7l armv7l GNU/Linux
aplay -l shows
  Subdevices: 1/1
Your .asoundrc should be in your homedirectory  (mostly then edited as ~/.asoundrc ) or you could place the same entrys in /etc/asound.conf
I also didnt get a sound from teh speaker-test, but when I do some "espeak 'Hello' 2>/dev/null" (you have to install espeak with a"apt install espeak")
I do hear the voice (the soundsystem is in the first time in "sleep"-mode but you should hear the second try)
Pin 2 is GND and Pin 7 is LINEOUT-Right and Pin 8 is LINEOUT-Left
You also need an amplified speaker, because the signal is only at Line-Out-Level.
for playing a .mp3 install mpg123 (via "apt install mpg123") and then play the .mp3 with
mpg123 song.mp3
In my alsamixer the correct ones for the volume are:
"Line Out"  and
"DAC"
aplay -l shows
   Subdevices: 1/1
mpg123 song.mp3
"Line Out"  and
"DAC"
Now it works! Thank you very much! :)  :) I had to create asound.conf file. Also connected an amplifier to speaker.
Hi Everybody. I just bought the OrangePi Zero (v1.5) with extension module. I'm wondering howto have line out and mic working. I have following setup and it doesn't work.
Welcome to ARMBIAN 5.65 stable Debian GNU/Linux 9 (stretch) 4.14.78-sunxi
System load:   0.08 0.02 0.01   Up time:       20:51 hours
Memory usage:  12 % of 493MB    IP:            192.168.1.18
CPU temp:      39°C
Usage of /:    31% of 7.1G
Is somebody available to share the most important info to succeed?
Many thanks, Sergio
Edited by SergioAiello
I just find the clue: from alsamixer GUI 1) <TAB> key to select the proper view and 2) ";" to toggle the mic to "capture". In the past two days I played a lot with alsamixer command but just yesterday got by chance this tricky sequence (also because the FX keys as suggested by alsamixer help do work for me).
(to marine1988) The mic works ... pretty well!
REPLY
I have successfully make the zero play with the extension via 3.5 audio jack :)
1. open armbian-config and check into the analogue
2. reboot and check aplay -l shows, it shoud be
aplay -l shows
  Subdevices: 1/1
3.  create file .asoundrc in home directory
put this in
pcm.!default{
    type hw
    card 0
ctl.!default{
    type hw
    card 0
4. type alsamixer and make sure that the M and O like this
5. speaker-test -twav -c2 -Dhw:0
and the sound plays
Front Left
Front Right
