Posted (edited)
@jock@fabiobassa @RaptorSDSafter using the legacy kernel and the minimal version it even started to install but this error appeared:
[FAILED] Failed to start Entropy Daemon based on the HAVEGE algorithm.
See 'systemct status haveged.service' for details.
Edited by YanCorote
need help
Posted (edited)
Spoiler
On 3/5/2023 at 7:11 AM, RaptorSDS said:
yes red are UART
please use 3,3V on you ch341 adapter
rx tx should be cross -->  , tx form usb to rx from board , and rx from usb to tx from board , GND to GND
you can not break anything with change of Baud rate , try both and you are fine
the text that run automaticlly on UART is the serial log ,
when nothing or only some unreadable thing is show in putty please change baudrate
than copy the text from putty or other tool and post here for jock ,
also ANdroid will produce a log on UART ( with some diffirence)
many of this serial log also in android terminal demsg log
i dont know the usb port order , for multitool over USB the port is normally irrelevant ,some box need normal USB , some the USB otg , some box hasnt the usb otg
hi, sorry for the late, I have finally linked ch341 programmer to uart ... here is the log
Spoiler
[    5.816610] ehci-platform 30100000.ehci2: irq 98, io mem 0x30100000
[    5.833839] ehci-platform 30100000.ehci2: USB 2.0 started, EHCI 1.00
[    5.834003] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    5.834034] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.834060] usb usb3: Product: EHCI Host Controller
[    5.834084] usb usb3: Manufacturer: Linux 3.10.104 ehci_hcd
[    5.834108] usb usb3: SerialNumber: 30100000.ehci2
[    5.834938] hub 3-0:1.0: USB hub found
[    5.835001] hub 3-0:1.0: 1 port detected
[    5.835783] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.836051] ohci-platform: OHCI generic platform driver
[    5.836292] ohci-platform 300a0000.ohci0: Generic Platform OHCI controller
[    5.836344] ohci-platform 300a0000.ohci0: new USB bus registered, assigned bus number 4
[    5.836427] ohci-platform 300a0000.ohci0: irq 49, io mem 0x300a0000
[    5.896881] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    5.896930] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.896957] usb usb4: Product: Generic Platform OHCI controller
[    5.896981] usb usb4: Manufacturer: Linux 3.10.104 ohci_hcd
[    5.897006] usb usb4: SerialNumber: 300a0000.ohci0
[    5.897911] hub 4-0:1.0: USB hub found
[    5.897956] hub 4-0:1.0: 1 port detected
[    5.898410] ohci-platform 300e0000.ohci1: Generic Platform OHCI controller
[    5.898463] ohci-platform 300e0000.ohci1: new USB bus registered, assigned bus number 5
[    5.898538] ohci-platform 300e0000.ohci1: irq 52, io mem 0x300e0000
[    5.955898] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    5.955947] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.955973] usb usb5: Product: Generic Platform OHCI controller
[    5.955998] usb usb5: Manufacturer: Linux 3.10.104 ohci_hcd
[    5.956023] usb usb5: SerialNumber: 300e0000.ohci1
[    5.956858] hub 5-0:1.0: USB hub found
[    5.956903] hub 5-0:1.0: 1 port detected
[    5.957353] ohci-platform 30120000.ohci2: Generic Platform OHCI controller
[    5.957406] ohci-platform 30120000.ohci2: new USB bus registered, assigned bus number 6
[    5.957486] ohci-platform 30120000.ohci2: irq 99, io mem 0x30120000
[    6.014930] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    6.014972] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.014998] usb usb6: Product: Generic Platform OHCI controller
[    6.015023] usb usb6: Manufacturer: Linux 3.10.104 ohci_hcd
[    6.015046] usb usb6: SerialNumber: 30120000.ohci2
[    6.015890] hub 6-0:1.0: USB hub found
[    6.015934] hub 6-0:1.0: 1 port detected
[    6.016567] usbcore: registered new interface driver cdc_acm
[    6.016589] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    6.016719] usbcore: registered new interface driver usblp
[    6.016814] usbcore: registered new interface driver cdc_wdm
[    6.017043] usbcore: registered new interface driver usb-storage
[    6.017134] usbcore: registered new interface driver ums-alauda
[    6.017218] usbcore: registered new interface driver ums-cypress
[    6.017300] usbcore: registered new interface driver ums-datafab
[    6.017387] usbcore: registered new interface driver ums_eneub6250
[    6.017469] usbcore: registered new interface driver ums-freecom
[    6.017563] usbcore: registered new interface driver ums-isd200
[    6.017644] usbcore: registered new interface driver ums-jumpshot
[    6.017724] usbcore: registered new interface driver ums-karma
[    6.017805] usbcore: registered new interface driver ums-onetouch
[    6.017906] usbcore: registered new interface driver ums-sddr09
[    6.017991] usbcore: registered new interface driver ums-sddr55
[    6.018074] usbcore: registered new interface driver ums-usbat
[    6.018275] usbcore: registered new interface driver usbserial
[    6.018358] usbcore: registered new interface driver usbserial_generic
[    6.018423] usbserial: USB Serial support registered for generic
[    6.018517] usbcore: registered new interface driver option
[    6.018586] usbserial: USB Serial support registered for GSM modem (1-port)
[    6.019014] usbcore: registered new interface driver trancevibrator
[    6.019034] usb20_otg: version 3.10a 21-DEC-2012
[    6.019981] e2680040
[    6.020009] Core Release: 3.10a
[    6.020029] Setting default values for core params
[    6.020327] Using Buffer DMA mode
[    6.020348] Periodic Transfer Interrupt Enhancement - disabled
[    6.020366] Multiprocessor Interrupt Enhancement - disabled
[    6.020386] OTG VER PARAM: 0, OTG VER FLAG: 0
[    6.020404] ^^^^^^^^^^^^^^^^^Device Mode
[    6.020431] Dedicated Tx FIFOs mode
[    6.020465] pcd_init otg_dev = dde4a340
[    6.020878] usb20_otg 30040000.otg: DWC OTG Controller
[    6.020937] usb20_otg 30040000.otg: new USB bus registered, assigned bus number 7
[    6.020995] usb20_otg 30040000.otg: irq 55, io mem 0x00000000
[    6.021118] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[    6.021147] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.021170] usb usb7: Product: DWC OTG Controller
[    6.021194] usb usb7: Manufacturer: Linux 3.10.104 dwc_otg_hcd
[    6.021217] usb usb7: SerialNumber: 30040000.otg
[    6.022158] hub 7-0:1.0: USB hub found
[    6.022201] hub 7-0:1.0: 1 port detected
[    6.022782] usb20_host: version 3.10a 21-DEC-2012
[    6.024776] usbcore: registered new interface driver xpad
[    6.024899] usbcore: registered new interface driver usb_acecad
[    6.025024] usbcore: registered new interface driver aiptek
[    6.025123] usbcore: registered new interface driver gtco
[    6.025222] usbcore: registered new interface driver hanwang
[    6.025319] usbcore: registered new interface driver kbtab
[    6.025448] usbcore: registered new interface driver wacom
[    6.025632] ==gsl_ts_init==
[    6.025713] ret=0
[    6.025780] i2c-core: driver [gslX680] using legacy suspend method
[    6.025803] i2c-core: driver [gslX680] using legacy resume method
[    6.026661] sensor_register_slave:mma8452,id=17
[    6.026685] sensor_register_slave:mma7660,id=18
[    6.026703] sensor_register_slave:gs_mc3230,id=23
[    6.026721] [Gsensor] gsensor_init
[    6.026741] sensor_register_slave:mpu6880_acc,id=24
[    6.026761] sensor_register_slave:mpu6500_acc,id=25
[    6.026780] sensor_register_slave:bma2xx_acc,id=26
[    6.026799] sensor_register_slave:akm8963,id=30
[    6.026818] sensor_register_slave:cm3217,id=51
[    6.026836] sensor_register_slave:cm3218,id=52
[    6.026854] sensor_register_slave:ls_stk3410,id=60
[    6.027547] .. rk pwm remotectl v1.1 init
[    6.027641] #######################################
[    6.027727] ################22222#######################
[    6.027794] ######################3333#################
[    6.027857] ########################4444###############
[    6.027915] #############################555##########
[    6.028277] input: 110b0030.pwm as /devices/110b0030.pwm/input/input0
[    6.028955] remotectl-pwm 110b0030.pwm: Missing psci property in the DT.
[    6.119236] dwc_otg_hcd_suspend, usb device mode
[    6.665475] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[    6.665567] i2c /dev entries driver
[    6.666185] IR NEC protocol handler initialized
[    6.666217] IR RC5(x) protocol handler initialized
[    6.666235] IR RC6 protocol handler initialized
[    6.666253] IR JVC protocol handler initialized
[    6.666269] IR Sony protocol handler initialized
[    6.666287] IR RC5 (streamzap) protocol handler initialized
[    6.666305] IR SANYO protocol handler initialized
[    6.666322] IR MCE Keyboard/mouse protocol handler initialized
[    6.666674] usbcore: registered new interface driver uvcvideo
[    6.666696] USB Video Class driver (1.1.1)
[    6.666719] CamSys driver version: v0.35.0,  CamSys head file version: v0.13.0
[    6.666742] E:camsys_soc_init(36): camsys isn't support soc: 0x32283002!
[    6.667399] not find test_power_init dev node
[    6.667477] i2c-core: driver [bq27320] using legacy suspend method
[    6.667498] i2c-core: driver [bq27320] using legacy resume method
[    6.668818] ===========net_led_probe start===========
[    6.668955] ===========net_led_probe end===========
[    6.669196] ===========remote_led_probe start===========
[    6.669296] ===========remote_led_probe end===========
[    6.669534] ===========suspend_led_probe start===========
[    6.669687] ===========suspend_led_probe end===========
[    6.670077] rockchip_temp_probe,line=384
[    6.670719] tsadc 11150000.tsadc: Missing tsadc_low_temp in the DT.
[    6.729236] tsadc 11150000.tsadc: initialized
[    6.730188] device-mapper: uevent: version 1.0.3
[    6.730727] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    6.731210] Bluetooth: HCI UART driver ver 2.2
[    6.731238] Bluetooth: HCI H4 protocol initialized
[    6.731254] Bluetooth: HCILL protocol initialized
[    6.731273] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    6.731293] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    6.731313] rtk_btusb: Register usb char device interface for BT driver
[    6.731741] usbcore: registered new interface driver rtk_btusb
[    6.732161] cpufreq version 1.0, suspend freq 1008 MHz
[    6.732720] cpuidle: using governor ladder
[    6.732745] cpuidle: using governor menu
[    6.732822] Synopsys Designware Multimedia Card Interface Driver
[    6.732843] MHSC version = Ver 2.00 2015-06-10
[    6.733386] dwmmc_rockchip 30020000.rksdmmc: Version ID is 270a
[    6.733481] dwmmc_rockchip 30020000.rksdmmc: failed to get hpclk_mmc
[    6.733933] dwmmc_rockchip 30020000.rksdmmc: Using internal DMA controller.
[    6.734293] dwmmc_rockchip 30020000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=125000000 [mmc0]
[    6.748979] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[    6.768751] dwmmc_rockchip 30020000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo
[    6.768795] dwmmc_rockchip 30020000.rksdmmc: 1 slots initialized
[    6.769519] dwmmc_rockchip 30000000.rksdmmc: Version ID is 270a
[    6.769614] dwmmc_rockchip 30000000.rksdmmc: failed to get hpclk_mmc
[    6.770070] dwmmc_rockchip 30000000.rksdmmc: Using internal DMA controller.
[    6.770445] dwmmc_rockchip 30000000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1]
[    6.770747] dwmmc_rockchip 30000000.rksdmmc: mmc1: No udbg pinctrl found!
[    6.788335] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
[    6.808166] dwmmc_rockchip 30000000.rksdmmc: DW MMC controller at irq 44, 32 bit host data width, 256 deep fifo
[    6.808242] dwmmc_rockchip 30000000.rksdmmc: 1 slots initialized
[    6.809400] dwmmc_rockchip 30010000.rksdmmc: Version ID is 270a
[    6.809542] dwmmc_rockchip 30010000.rksdmmc: failed to get hpclk_mmc
[    6.810140] dwmmc_rockchip 30010000.rksdmmc: Using internal DMA controller.
[    6.810711] dwmmc_rockchip 30010000.rksdmmc: dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2]
[    6.827718] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[    6.847539] dwmmc_rockchip 30010000.rksdmmc: DW MMC controller at irq 45, 32 bit host data width, 256 deep fifo
[    6.847612] dwmmc_rockchip 30010000.rksdmmc: 1 slots initialized
[    6.848277] leds-gpio power-led.31: pins are not configured from the driver
[    6.849258] hidraw: raw HID events driver (C) Jiri Kosina
[    6.856644] usbcore: registered new interface driver usbhid
[    6.856714] usbhid: USB HID core driver
[    6.857405] ashmem: initialized
[    6.857960] logger: created 256K log 'log_main'
[    6.858454] logger: created 256K log 'log_events'
[    6.858948] logger: created 256K log 'log_radio'
[    6.859435] logger: created 256K log 'log_system'
[    6.861709] rknandbase v1.1 2016-11-08
[    6.862332] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    6.862661] No.1 FLASH ID:2c 64 44 32 a5 0
[    6.863300] ECC:60
[    6.863363] FTL version: 5.0.47 20171120
[    7.103190] Using Buffer DMA mode
[    7.103226] Periodic Transfer Interrupt Enhancement - disabled
[    7.103236] Multiprocessor Interrupt Enhancement - disabled
[    7.103248] OTG VER PARAM: 0, OTG VER FLAG: 0
[    7.103259] ^^^^^^^^^^^^^^^^^^Host Mode
[    7.112384] FtlInit 0
[    7.112707]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    7.113300]      trust: 0x000800000 -- 0x001000000 (8 MB)
[    7.113621]       misc: 0x001000000 -- 0x001400000 (4 MB)
[    7.113916] baseparamer: 0x001400000 -- 0x001500000 (1 MB)
[    7.114214]   resource: 0x001500000 -- 0x002400000 (15 MB)
[    7.114513]     kernel: 0x002400000 -- 0x003000000 (12 MB)
[    7.114800]       boot: 0x003000000 -- 0x003c00000 (12 MB)
[    7.115090]   recovery: 0x003c00000 -- 0x005c00000 (32 MB)
[    7.115392]     backup: 0x005c00000 -- 0x009c00000 (64 MB)
[    7.115713]      cache: 0x009c00000 -- 0x011c00000 (128 MB)
[    7.116017]   metadata: 0x011c00000 -- 0x012c00000 (16 MB)
[    7.116333]     kpanic: 0x012c00000 -- 0x013000000 (4 MB)
[    7.116674]     system: 0x013000000 -- 0x0d3000000 (3072 MB)
[    7.116992]   userdata: 0x0d3000000 -- 0x1d4000000 (4112 MB)
[    7.121738] vendor storage 524b5644,2,2
[    7.124603] vendor storage 524b5644,3,3
[    7.129926] rockchip-spdif 100d0000.spdif: spdif ready.
[    7.152689] Init: Power Port (0)
[    7.152767] 30040000.otg resume, HPRT0:0x1000
[    7.152892] 30040000.otg suspend, HPRT0:0x1000
[    7.152903] rk322x-audio rockchip_audio.28:  rk322x-hifi <-> 100b0000.i2s1 mapping ok
[    7.156962] rockchip-hdmi-i2s rockchip_hdmi_i2s.30:  rk-hdmi-i2s-hifi <-> 100c0000.i2s0 mapping ok
[    7.157911] u32 classifier
[    7.157927]     Actions configured
[    7.157943] Netfilter messages via NETLINK v0.30.
[    7.158032] nf_conntrack version 0.5.0 (15414 buckets, 61656 max)
[    7.158563] ctnetlink v0.93: registering with nfnetlink.
[    7.158662] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    7.158675] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    7.159207] xt_time: kernel timezone is -0000
[    7.159551] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.159772] arp_tables: (C) 2002 David S. Miller
[    7.159839] TCP: cubic registered
[    7.159850] Initializing XFRM netlink socket
[    7.160271] NET: Registered protocol family 10
[    7.161174] mip6: Mobile IPv6
[    7.161235] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    7.161446] sit: IPv6 over IPv4 tunneling driver
[    7.162079] NET: Registered protocol family 17
[    7.162126] NET: Registered protocol family 15
[    7.162334] Bridge firewalling registered
[    7.162362] Ebtables v2.0 registered
[    7.162629] Bluetooth: RFCOMM TTY layer initialized
[    7.162683] Bluetooth: RFCOMM socket layer initialized
[    7.162696] Bluetooth: RFCOMM ver 1.11
[    7.162709] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.162719] Bluetooth: BNEP filters: protocol multicast
[    7.162738] Bluetooth: BNEP socket layer initialized
[    7.162750] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.162765] Bluetooth: HIDP socket layer initialized
[    7.162858] l2tp_core: L2TP core driver, V2.0
[    7.162882] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    7.162892] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    7.163149] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    7.163168] [WLAN_RFKILL]: can't find rockchip,grf property
[    7.163180] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8189fs
[    7.163193] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    7.163204] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[    7.163217] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    7.163291] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 90, flags = 0.
[    7.163339] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 0.
[    7.163352] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    7.163401] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    7.163415] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    7.270445] [WLAN_RFKILL]: wifi shut off power.
[    7.270513] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[    7.270550] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[    7.280433] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    7.280484] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    7.280522] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[    7.280553] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[    7.388598] [WLAN_RFKILL]: wifi turn on power. 90
[    7.388655] mmc2:mmc host rescan start!
[    7.388702] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    7.388876] [BT_RFKILL]: Enter rfkill_rk_init
[    7.389758] Key type dns_resolver registered
[    7.394726] rk322x_suspend_init: pm_ctrbits = 0x11806
[    7.394836] Registering SWP/SWPB emulation handler
[    7.394880] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x9dc00000
[    7.409683] ddrfreq: verion 1.2 20140526
[    7.426062] ddrfreq: normal 600MHz performance 0MHz low_power 0MHz video_1080p 0MHz video_4k 700MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 600MHz video_4k_10b 720MHz
[    7.426090] ddrfreq: auto-freq=0
[    7.426106] ddrfreq: auto-freq-table epmty!
[    7.427757] regulator-dummy: disabling
[    7.428434] pcd_pullup, is_on 0
[    7.428479] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[    7.428479]
[    7.428575] file system registered
[    7.430410] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    7.430435] android_usb gadget: Number of LUNs=2
[    7.430453]  lun0: LUN: removable file: (no medium)
[    7.430471]  lun1: LUN: removable file: (no medium)
[    7.431085] android_usb gadget: android_usb ready
[    7.431216] sensor_init: Probe name sensors
[    7.431258] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[    7.471974] rtc_hym8563 0-0051: hctosys: invalid date/time
[    7.484392] rockchip-spdif-card rockchip_spdif_card.29:  rk-hdmi-spdif-hifi <-> 100d0000.spdif mapping ok
[    7.485640] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-v3.10.92-28033-gae45312', rk_ko_ver is '5', built at '17:38:20', on 'Aug  6 2018'.
[    7.485909] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    7.485933] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    7.485955] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    7.485975] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    7.485998] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    7.486018] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    7.486041] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    7.486061] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    7.486083] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000026
[    7.486103] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000025
[    7.486124] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000024
[    7.486144] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000025
[    7.486166] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000024
[    7.486188] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000025
[    7.486266] mali-utgard 20001000.gpu: freq: 200000000, min_threshold: 0, max_threshold: 70
[    7.486293] mali-utgard 20001000.gpu: freq: 300000000, min_threshold: 61, max_threshold: 85
[    7.486317] mali-utgard 20001000.gpu: freq: 400000000, min_threshold: 73, max_threshold: 100
[    7.486410] mali-utgard 20001000.gpu: initial freq = 200000000
[    7.489299] Mali: Mali device driver loaded
[    7.489965] usbcore: registered new interface driver snd-usb-audio
[    7.489983] ALSA device list:
[    7.489996]   #0: RK_RK322x
[    7.490008]   #1: RK-HDMI-I2S
[    7.490020]   #2: RK-SPDIF-CARD
[    7.490655] Freeing unused kernel memory: 384K (c0def000 - c0e4f000)
[    7.493475] init: init first stage started!
[    7.605007] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 400000Hz, actual 398936HZ div = 47)
[    7.605071] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[    7.631091] dwmmc_rockchip 30010000.rksdmmc: exceeding card's volts
[    7.631529] mmc2 not switch iovel.
[    7.657334] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[    7.657428] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[    7.657449] type=1403 audit(4.780:2): policy loaded auid=4294967295 ses=4294967295
[    7.657786] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2]
[    7.659237] mmc2: new high speed SDIO card at address 0001
[    7.659396] init: (Initializing SELinux non-enforcing took 0.17s.)
[    7.671484] init: init second stage started!
[    7.686232] init: Setting ro.rk.soc=rk3229
[    7.686838] init: property_set("ro.hardware", "rk30board") failed
[    7.695332] init: Running restorecon...
[    7.770816] init: waitpid failed: No child processes
[    7.771627] init: (Loading properties from /default.prop took 0.00s.)
[    7.776666] init: (Parsing /init.environ.rc took 0.00s.)
[    7.777955] init: (Parsing /init.usb.rc took 0.00s.)
[    7.780667] init: (Parsing init.rk30board.bootmode.unknown.rc took 0.00s.)
[    7.783965] init: (Parsing init.rk30board.usb.rc took 0.00s.)
[    7.784196] init: (Parsing init.rk30board.environment.rc took 0.00s.)
[    7.784281] init: could not import file '/init.debug.rc' from 'init.rockchip.rc': No such file or directory
[    7.784321] init: (Parsing init.rockchip.rc took 0.00s.)
[    7.785579] init: (Parsing init.connectivity.rc took 0.00s.)
[    7.785870] init: (Parsing init.box.samba.rc took 0.00s.)
[    7.785960] init: could not import file 'init.rk322x.rc' from '/init.rk30board.rc': No such file or directory
[    7.786245] init: (Parsing init.box.rc took 0.00s.)
[    7.786309] init: could not import file 'init.car.rc' from '/init.rk30board.rc': No such file or directory
[    7.786361] init: could not import file 'init.optee.rc' from '/init.rk30board.rc': No such file or directory
[    7.786404] init: (Parsing /init.rk30board.rc took 0.01s.)
[    7.788418] init: (Parsing /init.usb.configfs.rc took 0.00s.)
[    7.788672] init: (Parsing /init.zygote32.rc took 0.00s.)
[    7.788712] init: (Parsing /init.rc took 0.02s.)
[    7.789727] init: Starting service 'ueventd'...
[    7.792967] type=1400 audit(4.920:3): avc:  denied  { getattr } for  pid=1 comm="init" path="/sys/kernel/debug/tracing/trace_marker" dev="debugfs" ino=73 scontext=u:r:init:s0 tcontext=u:object_r:debugfs_trace_marker:s0 tclass=file permissive=1
[    7.794212] ueventd: ueventd started!
[    7.795338] ueventd: invalid gid 'trace'
[    7.890407] vendor storage:20160801 ret = -1
[    8.052986] ueventd: Coldboot took 0.26s.
[    8.262783] init: Waiting for /dev/.coldboot_done...
[    8.262943] init: Waiting for /dev/.coldboot_done took 0.00s.
[    8.263051] init: /dev/hw_random not found
[    8.263635] keychord: using input dev 110b0030.pwm for fevent
[    8.286147] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory
[    8.286632] pm policy 0 -> 1
[    8.287847] init: /dev/hw_random not found
[    8.288476] rk30xxnand_ko: version magic '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' should be '3.10.104 SMP preempt mod_unload ARMv7 p2v8 '
[    8.288608] init: finit_module for "/rk30xxnand_ko.ko" failed: Exec format error[    8.289804] fs_mgr: Warning: unknown flag resize
[    8.292031] EXT4-fs (rknand_system): Ignoring removed nomblk_io_submit option
[    8.305578] EXT4-fs (rknand_system): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    8.306014] fs_mgr: check_fs(): mount(/dev/block/rknand_system,/system,ext4)=0: Success
[    8.307725] fs_mgr: check_fs(): unmount(/system) succeeded
[    8.307874] fs_mgr: Not running /system/bin/e2fsck on /dev/block/rknand_system (executable not in system image)
[    8.322585] EXT4-fs (rknand_system): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    8.322865] fs_mgr: __mount(source=/dev/block/rknand_system,target=/system,type=ext4)=0
[    8.323419] fs_mgr: check_fs(): mount(/dev/block/rknand_cache,/cache,ext4)=-1: No such file or directory
[    8.327268] fs_mgr: Running /system/bin/e2fsck on /dev/block/rknand_cache
[    8.394145] e2fsck: CANNOT LINK EXECUTABLE "/system/bin/e2fsck": "/system/lib/libext2fs.so" has bad ELF magic
[    8.394145]
[    8.394455] e2fsck: e2fsck terminated by signal 6
[    8.394455]
[    8.403398] EXT4-fs (rknand_cache): warning: maximal mount count reached, running e2fsck is recommended
[    8.405041] EXT4-fs (rknand_cache): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    8.405432] fs_mgr: __mount(source=/dev/block/rknand_cache,target=/cache,type=ext4)=0
[    8.407095] EXT4-fs (rknand_metadata): Ignoring removed nomblk_io_submit option
[    8.412263] EXT4-fs (rknand_metadata): warning: maximal mount count reached, running e2fsck is recommended
[    8.413839] EXT4-fs (rknand_metadata): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    8.414185] fs_mgr: check_fs(): mount(/dev/block/rknand_metadata,/metadata,ext4)=0: Success
[    8.415934] fs_mgr: check_fs(): unmount(/metadata) succeeded
[    8.416107] fs_mgr: Running /system/bin/e2fsck on /dev/block/rknand_metadata
[    8.427841] e2fsck: CANNOT LINK EXECUTABLE "/system/bin/e2fsck": "/system/lib/libext2fs.so" has bad ELF magic
[    8.427841]
[    8.428062] e2fsck: e2fsck terminated by signal 6
[    8.428062]
[    8.437207] EXT4-fs (rknand_metadata): warning: maximal mount count reached, running e2fsck is recommended
[    8.438718] EXT4-fs (rknand_metadata): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    8.439046] fs_mgr: __mount(source=/dev/block/rknand_metadata,target=/metadata,type=ext4)=0
[    8.441662] EXT4-fs (rknand_userdata): Ignoring removed nomblk_io_submit option
[    8.447127] EXT4-fs (rknand_userdata): warning: maximal mount count reached, running e2fsck is recommended
[    8.448932] EXT4-fs (rknand_userdata): mounted filesystem with ordered data mode. Opts: errors=remount-ro,nomblk_io_submit
[    8.449328] fs_mgr: check_fs(): mount(/dev/block/rknand_userdata,/data,ext4)=0: Success
[    8.451159] fs_mgr: check_fs(): unmount(/data) succeeded
[    8.451385] fs_mgr: Running /system/bin/e2fsck on /dev/block/rknand_userdata
[    8.462985] e2fsck: CANNOT LINK EXECUTABLE "/system/bin/e2fsck": "/system/lib/libext2fs.so" has bad ELF magic
[    8.462985]
[    8.463205] e2fsck: e2fsck terminated by signal 6
[    8.463205]
[    8.472876] EXT4-fs (rknand_userdata): warning: maximal mount count reached, running e2fsck is recommended
[    8.474713] EXT4-fs (rknand_userdata): mounted filesystem with ordered data mode. Opts: noauto_da_alloc,discard
[    8.475082] fs_mgr: __mount(source=/dev/block/rknand_userdata,target=/data,type=ext4)=0
init: (Parsing /system/etc/init/atrace.rc took 0.00s.)
[    8.504713] init: (Parsing /system/etc/init/audioserver.rc took 0.00s.)
[    8.506387] init: (Parsing /system/etc/init/bootanim.rc took 0.00s.)
[    8.508518] init: (Parsing /system/etc/init/bootstat.rc took 0.00s.)
[    8.510216] init: (Parsing /system/etc/init/cameraserver.rc took 0.00s.)
[    8.511930] init: (Parsing /system/etc/init/debuggerd.rc took 0.00s.)
[    8.513560] init: (Parsing /system/etc/init/drmserver.rc took 0.00s.)
[    8.515845] init: (Parsing /system/etc/init/dumpstate.rc took 0.00s.)
[    8.517427] init: (Parsing /system/etc/init/gatekeeperd.rc took 0.00s.)
[    8.519159] init: (Parsing /system/etc/init/init-debug.rc took 0.00s.)
[    8.520815] init: (Parsing /system/etc/init/installd.rc took 0.00s.)
[    8.522488] init: (Parsing /system/etc/init/keystore.rc took 0.00s.)
[    8.524101] init: (Parsing /system/etc/init/lmkd.rc took 0.00s.)
[    8.526823] init: (Parsing /system/etc/init/logcatd.rc took 0.00s.)
[    8.528684] init: (Parsing /system/etc/init/logd.rc took 0.00s.)
[    8.530549] init: (Parsing /system/etc/init/mdnsd.rc took 0.00s.)
[    8.532226] init: (Parsing /system/etc/init/mediacodec.rc took 0.00s.)
[    8.533852] init: (Parsing /system/etc/init/mediadrmserver.rc took 0.00s.)
[    8.535450] init: (Parsing /system/etc/init/mediaextractor.rc took 0.00s.)
[    8.537208] init: (Parsing /system/etc/init/mediaserver.rc took 0.00s.)
[    8.538828] init: (Parsing /system/etc/init/mtpd.rc took 0.00s.)
[    8.540463] init: (Parsing /system/etc/init/netd.rc took 0.00s.)
[    8.542099] init: (Parsing /system/etc/init/perfprofd.rc took 0.00s.)
[    8.543687] init: (Parsing /system/etc/init/racoon.rc took 0.00s.)
[    8.545366] init: ignored duplicate definition of service 'ril-daemon'init: (Parsing /system/etc/init/rild.rc took 0.00s.)
[    8.547330] init: (Parsing /system/etc/init/servicemanager.rc took 0.00s.)
[    8.548936] init: (Parsing /system/etc/init/surfaceflinger.rc took 0.00s.)
[    8.550725] init: (Parsing /system/etc/init/uncrypt.rc took 0.00s.)
[    8.552440] init: (Parsing /system/etc/init/vdc.rc took 0.00s.)
[    8.554188] init: (Parsing /system/etc/init/vold.rc took 0.00s.)
[    8.561709] init: property_set("ro.board.platform", "rk322x") failed
[    8.563678] init: property_set("ro.opengles.version", "196609") failed
[    8.564615] init: property_set("ro.rk.screenoff_time", "2147483647") failed
[    8.566069] init: property_set("ro.rk.screenshot_enable", "true") failed
[    8.566863] init: (Loading properties from /system/build.prop took 0.01s.)
[    8.567188] init: (Loading properties from /vendor/build.prop took 0.00s.)
[    8.567343] init: (Loading properties from /factory/factory.prop took 0.00s.)
[    8.567864] fs_mgr: Warning: unknown flag resize
[    8.568394] init: /recovery not specified in fstab
[    8.568778] init: Starting service 'healthd'...
[    8.575896] init: Starting service 'displayd'...
[    8.578656] init: Starting service 'lmkd'...
[    8.580108] binder: 140:140 transaction failed 29189, size 0-0
[    8.581361] init: Starting service 'servicemanager'...
[    8.585295] init: Starting service 'surfaceflinger'...
[    8.587473] init: Starting service 'vold'...
[    8.589129] type=1400 audit(5.730:4): avc:  denied  { getattr } for  pid=141 comm="displayd" path="/vendor" dev="rootfs" ino=6633 scontext=u:r:displayd:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=1
[    8.946498] init: Service 'displayd' (pid 141) killed by signal 6
[    8.946571] init: Service 'displayd' (pid 141) killing any children in process group
[    8.946681] type=1400 audit(6.090:5): avc:  denied  { unlink } for  pid=1 comm="init" name="displayd" dev="tmpfs" ino=3257 scontext=u:r:init:s0 tcontext=u:object_r:socket_device:s0 tclass=sock_file permissive=1
[    8.946962] init: Service 'lmkd' (pid 142) killed by signal 6
[    8.946998] init: Service 'lmkd' (pid 142) killing any children in process group
[    8.947220] init: Service 'servicemanager' (pid 143) killed by signal 6
[    8.947255] init: Service 'servicemanager' (pid 143) killing any children in process group
[    8.947299] init: Service 'healthd' is being killed...
[    8.948212] init: Starting service 'zygote'...
[    8.949656] init: Starting service 'audioserver'...
[    8.951428] init: Starting service 'media'...
[    8.952322] init: Service 'surfaceflinger' is being killed...
[    8.952476] init: do_restart: Service inputflinger not found
[    8.953519] init: Starting service 'drm'...
[    8.955309] init: Starting service 'cameraserver'...
[    8.956174] init: couldn't write 150 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    8.956406] init: Service 'healthd' (pid 140) killed by signal 9
[    8.956448] init: Service 'healthd' (pid 140) killing any children in process group
[    8.956811] init: Service 'surfaceflinger' (pid 144) killed by signal 6
[    8.956860] init: Service 'surfaceflinger' (pid 144) killing any children in process group
[    8.956963] init: Service 'zygote' is being killed...
[    8.957426] init: Service 'vold' (pid 145) killed by signal 6
[    8.957470] init: Service 'vold' (pid 145) killing any children in process group
[    8.957799] init: Service 'zygote' (pid 146) killed by signal 9
[    8.957842] init: Service 'zygote' (pid 146) killing any children in process group
[    8.958061] init: write_file: Unable to open '/sys/android_power/request_state': No such file or directory
[    8.958191] init: write_file: Unable to write to '/sys/power/state': Invalid argument
[    8.958265] init: Service 'audioserver' is being killed...
[    8.958399] init: Service 'cameraserver' is being killed...
[    8.958630] init: Service 'media' is being killed...
[    8.959742] init: Starting service 'netd'...
[    8.960675] init: Service 'audioserver' (pid 147) killed by signal 9
[    8.960722] init: Service 'audioserver' (pid 147) killing any children in process group
[    8.960948] init: Service 'media' (pid 148) killed by signal 9
[    8.960995] init: Service 'media' (pid 148) killing any children in process group
[    8.961196] init: Service 'cameraserver' (pid 150) killed by signal 9
[    8.961243] init: Service 'cameraserver' (pid 150) killing any children in process group
[    8.969968] init: insmod: open("/system/lib/modules/ump.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/mali_kbase.ko") failed: No such file or directoryinit: insmod: open("/system/lib/modules/rk30_mirroring.ko") failed: No such file or directory
[    8.972131] rk29_ipp: version magic '3.0.101+ SMP preempt mod_unload ARMv7 ' should be '3.10.104 SMP preempt mod_unload ARMv7 p2v8 '
[    8.972199] init: finit_module for "/system/lib/modules/rk29-ipp.ko" failed: Exec format errorinit: insmod: open("/system/lib/modules/pvrsrvkm.ko") failed: No such file or directory
[    8.972884] drmboot: module license 'unspecified' taints kernel.
[    8.972901] Disabling lock debugging due to kernel taint
[    8.973377] drm init, 20140910
[    8.973433] ------------[ cut here ]------------
[    8.973456] WARNING: at fs/sysfs/dir.c:530 sysfs_add_one+0x7c/0x9c()
[    8.973468] sysfs: cannot create duplicate filename '/devices/virtual/misc/rknand_sys_storage'
[    8.973480] Modules linked in: drmboot(P+)
[    8.973501] CPU: 1 PID: 1 Comm: init Tainted: P             3.10.104 #1
[    8.973533] [<c0014088>] (unwind_backtrace+0x0/0xe0) from [<c00118cc>] (show_stack+0x10/0x14)
[    8.973559] [<c00118cc>] (show_stack+0x10/0x14) from [<c003f320>] (warn_slowpath_common+0x4c/0x68)
[    8.973580] [<c003f320>] (warn_slowpath_common+0x4c/0x68) from [<c003f3bc>] (warn_slowpath_fmt+0x2c/0x3c)
[    8.973601] [<c003f3bc>] (warn_slowpath_fmt+0x2c/0x3c) from [<c016d22c>] (sysfs_add_one+0x7c/0x9c)
[    8.973626] [<c016d22c>] (sysfs_add_one+0x7c/0x9c) from [<c016d434>] (create_dir+0x5c/0xac)
[    8.973652] [<c016d434>] (create_dir+0x5c/0xac) from [<c016d724>] (sysfs_create_dir+0x80/0xa0)
[    8.973677] [<c016d724>] (sysfs_create_dir+0x80/0xa0) from [<c02a6128>] (kobject_add_internal+0xc8/0x1fc)
[    8.973698] [<c02a6128>] (kobject_add_internal+0xc8/0x1fc) from [<c02a6488>] (kobject_add+0x68/0x8c)
[    8.973722] [<c02a6488>] (kobject_add+0x68/0x8c) from [<c038c374>] (device_add+0xe0/0x364)
[    8.973742] [<c038c374>] (device_add+0xe0/0x364) from [<c038c688>] (device_create_vargs+0x78/0xbc)
[    8.973761] [<c038c688>] (device_create_vargs+0x78/0xbc) from [<c038c6e8>] (device_create+0x1c/0x24)
[    8.973788] [<c038c6e8>] (device_create+0x1c/0x24) from [<c034ac88>] (misc_register.part.0+0x34/0xa0)
[    8.973817] [<c034ac88>] (misc_register.part.0+0x34/0xa0) from [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot])
[    8.973844] [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot]) from [<c00086a4>] (do_one_initcall+0x34/0xc8)
[    8.973867] [<c00086a4>] (do_one_initcall+0x34/0xc8) from [<c09b2b70>] (do_init_module+0x44/0x15c)
[    8.973890] [<c09b2b70>] (do_init_module+0x44/0x15c) from [<c0095728>] (SyS_finit_module+0x6c/0x94)
[    8.973913] [<c0095728>] (SyS_finit_module+0x6c/0x94) from [<c000db00>] (ret_fast_syscall+0x0/0x38)
[    8.973927] ---[ end trace eda3561df640db71 ]---
[    8.973961] ------------[ cut here ]------------
[    8.973995] WARNING: at lib/kobject.c:196 kobject_add_internal+0x19c/0x1fc()
[    8.974008] kobject_add_internal failed for rknand_sys_storage with -EEXIST, don't try to register things with the same name in the same directory.
[    8.974020] Modules linked in: drmboot(P+)
[    8.974042] CPU: 1 PID: 1 Comm: init Tainted: P        W    3.10.104 #1
[    8.974067] [<c0014088>] (unwind_backtrace+0x0/0xe0) from [<c00118cc>] (show_stack+0x10/0x14)
[    8.974089] [<c00118cc>] (show_stack+0x10/0x14) from [<c003f320>] (warn_slowpath_common+0x4c/0x68)
[    8.974110] [<c003f320>] (warn_slowpath_common+0x4c/0x68) from [<c003f3bc>] (warn_slowpath_fmt+0x2c/0x3c)
[    8.974130] [<c003f3bc>] (warn_slowpath_fmt+0x2c/0x3c) from [<c02a61fc>] (kobject_add_internal+0x19c/0x1fc)
[    8.974151] [<c02a61fc>] (kobject_add_internal+0x19c/0x1fc) from [<c02a6488>] (kobject_add+0x68/0x8c)
[    8.974173] [<c02a6488>] (kobject_add+0x68/0x8c) from [<c038c374>] (device_add+0xe0/0x364)
[    8.974192] [<c038c374>] (device_add+0xe0/0x364) from [<c038c688>] (device_create_vargs+0x78/0xbc)
[    8.974212] [<c038c688>] (device_create_vargs+0x78/0xbc) from [<c038c6e8>] (device_create+0x1c/0x24)
[    8.974236] [<c038c6e8>] (device_create+0x1c/0x24) from [<c034ac88>] (misc_register.part.0+0x34/0xa0)
[    8.974264] [<c034ac88>] (misc_register.part.0+0x34/0xa0) from [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot])
[    8.974292] [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot]) from [<c00086a4>] (do_one_initcall+0x34/0xc8)
[    8.974312] [<c00086a4>] (do_one_initcall+0x34/0xc8) from [<c09b2b70>] (do_init_module+0x44/0x15c)
[    8.974335] [<c09b2b70>] (do_init_module+0x44/0x15c) from [<c0095728>] (SyS_finit_module+0x6c/0x94)
[    8.974361] [<c0095728>] (SyS_finit_module+0x6c/0x94) from [<c000db00>] (ret_fast_syscall+0x0/0x38)
[    8.974389] ---[ end trace eda3561df640db72 ]---
[    8.974412] drm init ok
[    8.974780] fs_mgr: Warning: unknown flag resize
[    8.975674] zram: Cannot initialise lz4 compressing backend
[    9.005272] Unable to find swap-space signature
[    9.005393] fs_mgr: swapon failed for /dev/block/zram0
[    9.005717] init: Service 'drm' (pid 149) killed by signal 6
[    9.005754] init: Service 'drm' (pid 149) killing any children in process group
[    9.006001] init: Service 'netd' (pid 151) killed by signal 6
[    9.006037] init: Service 'netd' (pid 151) killing any children in process group
[    9.023561] vcodec_service: No noc aclk reset resource define
[    9.023614] vcodec_service: No noc hclk reset resource define
[    9.023625] vcodec_service: No core reset resource define
[    9.023635] vcodec_service: No cabac reset resource define
[    9.023788] vcodec 20020000.vpu_service: do not have pd_video
[    9.023837] vcodec_service: probe device 20020000.vpu_service
[    9.023911] vcodec_service: checking hw id 0
[    9.025338] vcodec_service: init success
[    9.025556] vcodec_service: No noc aclk reset resource define
[    9.025573] vcodec_service: No noc hclk reset resource define
[    9.025582] vcodec_service: No core reset resource define
[    9.025591] vcodec_service: No cabac reset resource define
[    9.025744] vcodec 20030000.rkvdec: do not have pd_video
[    9.025788] vcodec_service: probe device 20030000.rkvdec
[    9.025880] vcodec_service: checking hw id 6876
[    9.027092] vcodec_service: init success
[    9.031531] init: Starting service 'debuggerd'...
[    9.032484] init: do_start: Service debuggerd64 not found
[    9.033141] init: Starting service 'vold'...
[    9.038045] init: Not bootcharting.
[    9.048260] init: Service 'vold' (pid 157) killed by signal 6
[    9.048322] init: Service 'vold' (pid 157) killing any children in process group
[    9.175890] init: Service 'debuggerd' (pid 156) killed by signal 6
[    9.175998] init: Service 'debuggerd' (pid 156) killing any children in process group
[    9.262470] init: Starting service 'exec 1 (/system/bin/tzdatacheck)'...
[    9.279115] init: Service 'exec 1 (/system/bin/tzdatacheck)' (pid 159) killed by signal 6
[    9.295724] type=1400 audit(6.440:6): avc:  denied  { setattr } for  pid=1 comm="init" name="cifsmanager" dev="rknand_userdata" ino=239522 scontext=u:r:init:s0 tcontext=u:object_r:cifsmanager_exec:s0 tclass=dir permissive=1
[    9.396545] EXT4-fs (rknand_userdata): Unrecognized mount option "background_gc=on" or missing value
[    9.402639] init: (Loading properties from /data/local.prop took 0.00s.)
[    9.644518] init: Starting service 'logd'...
[    9.646943] init: Starting service 'logd-reinit'...
[    9.669774] init: Service 'logd' (pid 160) killed by signal 6
[    9.669882] init: Service 'logd' (pid 160) killing any children in process group
[    9.673540] init: Service 'logd-reinit' (pid 161) killed by signal 6
[    9.674081] init: write_file: Unable to open '/proc/sys/vm/lazy_vfree_tlb_flush_all_threshold': No such file or directory
[    9.678857] init: SELinux: Could not get canonical path for /dev/block/platform/fe330000.sdhci/by-name/ restorecon: No such file or directory.
[    9.680137] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    9.680205] init: write: cannot expand '${ro.serialno}'
[    9.681000] init: using deprecated syntax for specifying property 'ro.product.usbfactory', use ${name} instead
[    9.694299] init: write_file: Unable to write to '/dev/cpuset/foreground/boost/cpus': Permission denied
[    9.696315] init: Starting service 'console'...
[    9.697535] android_usb: already disabled
[    9.698344] init: Starting service 'adbd'...
[    9.699583] init: Service 'adbd' is being killed...
[    9.701320] init: cannot find '/system/bin/update_verifier' (No such file or directory), disabling 'exec 2 (/system/bin/update_verifier)'
[    9.701542] init: cannot find '/system/bin/install-recovery.sh' (No such file or directory), disabling 'flash_recovery'
[    9.702291] init: Starting service 'drmservice'...
[    9.703160] init: cannot find '/system/bin/bplus_helper' (No such file or directory), disabling 'bplus_helper'
[    9.704094] init: Service up_eth0 does not have a SELinux domain defined.
[    9.704198] init: cannot find '/system/bin/rk_store_keybox' (No such file or directory), disabling 'rk_store_keybox'
[    9.704347] init: cannot find '/system/bin/akmd' (No such file or directory), disabling 'akmd'
[    9.704863] init: Starting service 'zygote'...
[    9.706423] init: Starting service 'audioserver'...
[    9.708034] init: Starting service 'cameraserver'...
[    9.708940] init: couldn't write 167 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[    9.709692] init: Starting service 'drm'...
[    9.715856] init: Starting service 'installd'...
[    9.718044] init: Starting service 'keystore'...
[    9.719946] init: Starting service 'mediacodec'...
[    9.722402] init: Starting service 'mediadrm'...
[    9.724073] init: Starting service 'mediaextractor'...
[    9.725599] init: Starting service 'media'...
[    9.727072] init: Starting service 'netd'...
[    9.728590] init: Service 'drm' (pid 168) killed by signal 6
[    9.728689] init: Service 'drm' (pid 168) killing any children in process group
[    9.729828] init: Starting service 'gatekeeperd'...
[    9.830292] init: cannot find '/system/xbin/perfprofd' (No such file or directory), disabling 'perfprofd'
[    9.830685] init: Service 'drmservice' (pid 164) killed by signal 6
[    9.831009] init: Service 'zygote' (pid 165) killed by signal 6
[    9.831073] init: Service 'zygote' (pid 165) killing any children in process group
[    9.831327] init: write_file: Unable to open '/sys/android_power/request_state': No such file or directory
[    9.831524] init: write_file: Unable to write to '/sys/power/state': Invalid argument
[    9.831638] init: Service 'audioserver' is being killed...
[    9.831816] init: Service 'cameraserver' is being killed...
[    9.831973] init: Service 'media' is being killed...
[    9.832131] init: Service 'netd' is being killed...
[    9.832472] init: Service 'audioserver' (pid 166) killed by signal 6
[    9.832537] init: Service 'audioserver' (pid 166) killing any children in process group
[    9.832768] init: Service 'cameraserver' (pid 167) killed by signal 6
[    9.832832] init: Service 'cameraserver' (pid 167) killing any children in process group
[    9.833175] init: Service 'installd' (pid 169) killed by signal 6
[    9.833241] init: Service 'installd' (pid 169) killing any children in process group
[    9.833606] init: Service 'keystore' (pid 170) killed by signal 6
[    9.833670] init: Service 'keystore' (pid 170) killing any children in process group
[    9.833937] init: Service 'mediacodec' (pid 171) killed by signal 6
[    9.834000] init: Service 'mediacodec' (pid 171) killing any children in process group
[    9.834273] init: Service 'mediadrm' (pid 172) killed by signal 6
[    9.834339] init: Service 'mediadrm' (pid 172) killing any children in process group
st   9.834618] init: Service 'mediaextractor' (pCid 1NN3) kT lLlIN byEXsEigCnUalTA BL6E "/sy
  em/b[  i 9.8n/s3h": 46/s4y] siteit/: Service 'imbedliiabmxtrsao"tohra's ( pidb173)  EiLll mnggiac
[    9.834927] init: Service 'media' (pid 174) killed by signal 6
[    9.834988] init: Service 'media' (pid 174) killing any children in process group
[    9.835285] init: Service 'netd' (pid 175) killed by signal 6
[    9.835350] init: Service 'netd' (pid 175) killing any children in process group
[    9.836015] init: Service 'gatekeeperd' (pid 177) killed by signal 6
[    9.836140] init: Service 'gatekeeperd' (pid 177) killing any children in process group
[    9.854842] init: Service 'console' (pid 162) killed by signal 6
[    9.854946] init: Service 'console' (pid 162) killing any children in process group
[   12.810876] init: Starting service 'healthd'...
[   12.813766] init: Starting service 'displayd'...
[   12.816599] init: Starting service 'lmkd'...
[   12.819659] init: Starting service 'servicemanager'...
[   12.822451] binder: 178:178 transaction failed 29189, size 0-0
[   12.822926] init: Starting service 'surfaceflinger'...
[   12.828032] type=1400 audit(10.030:7): avc:  denied  { getattr } for  pid=179 comm="displayd" path="/vendor" dev="rootfs" ino=6633 scontext=u:r:displayd:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=1
[   12.833594] init: Service 'displayd' (pid 179) killed by signal 6
[   12.833717] init: Service 'displayd' (pid 179) killing any children in process group
[   12.833910] type=1400 audit(10.040:8): avc:  denied  { unlink } for  pid=1 comm="init" name="displayd" dev="tmpfs" ino=1467 scontext=u:r:init:s0 tcontext=u:object_r:socket_device:s0 tclass=sock_file permissive=1
[   12.834460] init: Service 'servicemanager' (pid 181) killed by signal 6
[   12.834531] init: Service 'servicemanager' (pid 181) killing any children in process group
[   12.834624] init: Service 'healthd' is being killed...
[   12.834885] init: Service 'surfaceflinger' is being killed...
[   12.835081] init: do_restart: Service inputflinger not found
[   12.835483] init: Service 'healthd' (pid 178) killed by signal 9
[   12.835554] init: Service 'healthd' (pid 178) killing any children in process group
[   12.835830] init: Service 'lmkd' (pid 180) killed by signal 6
[   12.835894] init: Service 'lmkd' (pid 180) killing any children in process group
[   12.839725] init: Service 'surfaceflinger' (pid 182) killed by signal 9
[   12.839800] init: Service 'surfaceflinger' (pid 182) killing any children in process group
[   13.825840] init: Starting service 'console'...
[   13.828762] init: Starting service 'zygote'...
[   13.831563] init: Starting service 'audioserver'...
[   13.835635] init: Starting service 'cameraserver'...
[   13.837346] init: couldn't write 186 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[   13.838834] init: Starting service 'debuggerd'...
CANNOT LINK EXECUTABLE "/system/bin/sh": "/system/lib/libm.so" has bad ELF magic
[   13.842002] init: Starting service 'drm'...
[   13.846017] init: Starting service 'gatekeeperd'...
[   13.848300] init: Starting service 'installd'...
[   13.850699] init: Starting service 'keystore'...
[   13.853074] init: Starting service 'logd'...
[   13.864769] init: Starting service 'mediacodec'...
[   13.867229] init: Starting service 'mediadrm'...
[   13.869539] init: Starting service 'mediaextractor'...
[   13.871768] init: Starting service 'media'...
[   13.874881] init: Starting service 'netd'...
[   13.877679] init: Starting service 'vold'...
[   13.879652] init: Service 'console' (pid 183) killed by signal 6
[   13.880400] init: Service 'console' (pid 183) killing any children in process group
[   13.881653] init: Service 'zygote' (pid 184) killed by signal 6
[   13.882332] init: Service 'zygote' (pid 184) killing any children in process group
[   13.883510] init: write_file: Unable to open '/sys/android_power/request_state': No such file or directory
[   13.883714] init: write_file: Unable to write to '/sys/power/state': Invalid argument
[   13.883841] init: Service 'audioserver' is being killed...
[   13.884007] init: Service 'cameraserver' is being killed...
[   13.884168] init: Service 'media' is being killed...
[   13.884292] init: Service 'netd' is being killed...
[   13.884603] init: Service 'audioserver' (pid 185) killed by signal 6
[   13.884644] init: Service 'audioserver' (pid 185) killing any children in process group
[   13.884895] init: Service 'cameraserver' (pid 186) killed by signal 6
[   13.884940] init: Service 'cameraserver' (pid 186) killing any children in process group
[   13.885143] init: Service 'debuggerd' (pid 187) killed by signal 6
[   13.885186] init: Service 'debuggerd' (pid 187) killing any children in process group
[   13.885416] init: Service 'drm' (pid 189) killed by signal 6
[   13.885468] init: Service 'drm' (pid 189) killing any children in process group
[   13.885683] init: Service 'gatekeeperd' (pid 190) killed by signal 6
[   13.885729] init: Service 'gatekeeperd' (pid 190) killing any children in process group
[   13.886062] init: Service 'installd' (pid 191) killed by signal 6
[   13.886110] init: Service 'installd' (pid 191) killing any children in process group
[   13.886462] init: Service 'keystore' (pid 192) killed by signal 6
[   13.886510] init: Service 'keystore' (pid 192) killing any children in process group
[   13.886777] init: Service 'mediacodec' (pid 195) killed by signal 6
[   13.886835] init: Service 'mediacodec' (pid 195) killing any children in process group
[   13.887143] init: Service 'mediadrm' (pid 196) killed by signal 6
[   13.887204] init: Service 'mediadrm' (pid 196) killing any children in process group
[   13.887478] init: Service 'mediaextractor' (pid 197) killed by signal 6
[   13.887527] init: Service 'mediaextractor' (pid 197) killing any children in process group
[   13.887828] init: Service 'media' (pid 198) killed by signal 6
[   13.887883] init: Service 'media' (pid 198) killing any children in process group
[   13.898708] init: Service 'logd' (pid 194) killed by signal 6
[   13.898758] init: Service 'logd' (pid 194) killing any children in process group
[   13.899168] init: Service 'netd' (pid 199) killed by signal 6
[   13.899209] init: Service 'netd' (pid 199) killing any children in process group
[   13.899537] init: Service 'vold' (pid 200) killed by signal 6
[   13.899578] init: Service 'vold' (pid 200) killing any children in process group
[   13.912435] [otg id chg] last id -1 current id 2
[   17.840901] init: Starting service 'healthd'...
[   17.843765] init: Starting service 'displayd'...
[   17.846537] init: Starting service 'lmkd'...
[   17.849758] init: Starting service 'servicemanager'...
[   17.851735] binder: 201:201 transaction failed 29189, size 0-0
[   17.852898] init: Starting service 'surfaceflinger'...
[   17.859140] type=1400 audit(15.150:9): avc:  denied  { getattr } for  pid=202 comm="displayd" path="/vendor" dev="rootfs" ino=6633 scontext=u:r:displayd:s0 tcontext=u:object_r:rootfs:s0 tclass=lnk_file permissive=1
[   17.862059] init: Service 'displayd' (pid 202) killed by signal 6
[   17.862862] init: Service 'displayd' (pid 202) killing any children in process group
[   17.863507] init: Service 'lmkd' (pid 203) killed by signal 6
[   17.863595] init: Service 'lmkd' (pid 203) killing any children in process group
[   17.865576] init: Service 'surfaceflinger' (pid 205) killed by signal 6
[   17.865677] init: Service 'surfaceflinger' (pid 205) killing any children in process group
[   17.869335] init: Service 'servicemanager' (pid 204) killed by signal 6
[   17.869432] init: Service 'servicemanager' (pid 204) killing any children in process group
[   17.869509] init: Service 'healthd' is being killed...
[   17.869768] init: do_restart: Service inputflinger not found
[   17.871271] init: Service 'healthd' (pid 201) killed by signal 9
[   17.871343] init: Service 'healthd' (pid 201) killing any children in process group
[   18.857356] init: Starting service 'console'...
[   18.860182] init: Starting service 'zygote'...
[   18.863241] init: Starting service 'audioserver'...
[   18.866292] init: Starting service 'cameraserver'...
[   18.869334] init: Starting service 'debuggerd'...
[   18.872558] init: couldn't write 209 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[   18.873845] init: Starting service 'drm'...
[   18.876222] init: Starting service 'gatekeeperd'...
[   18.878802] init: Starting service 'installd'...
[   18.881093] init: Starting service 'keystore'...
[   18.884514] init: Starting service 'logd'...
[   18.887493] init: Starting service 'mediacodec'...
[   18.890676] init: Starting service 'mediadrm'...
[   18.893577] init: Starting service 'mediaextractor'...
[   18.896411] init: Starting service 'media'...
[   18.899390] init: Starting service 'netd'...
[   18.903487] init: Starting service 'vold'...
[   18.907014] init: Service 'console' (pid 206) killed by signal 6
[   18.907793] init: Service 'console' (pid 206) killing any children in process group
[   18.909169] init: Service 'zygote' (pid 207) killed by signal 6
[   18.909900] init: Service 'zygote' (pid 207) killing any children in process group
[   18.911090] init: write_file: Unable to open '/sys/android_power/request_state': No such file or directory
[   18.912410] init: write_file: Unable to write to '/sys/power/state': Invalid argument
[   18.913366] init: Service 'audioserver' is being killed...
[   18.914168] init: Service 'cameraserver' is being killed...
[   18.915084] init: Service 'media' is being killed...
[   18.915846] init: Service 'netd' is being killed...
[   18.916813] init: Service 'audioserver' (pid 208) killed by signal 6
[   18.917542] init: Service 'audioserver' (pid 208) killing any children in process group
[   18.917858] init: Service 'cameraserver' (pid 209) killed by signal 6
[   18.917920] init: Service 'cameraserver' (pid 209) killing any children in process group
[   18.918227] init: Service 'debuggerd' (pid 210) killed by signal 6
[   18.918284] init: Service 'debuggerd' (pid 210) killing any children in process group
[   18.918539] init: Service 'drm' (pid 211) killed by signal 6
[   18.918595] init: Service 'drm' (pid 211) killing any children in process group
[   18.918862] init: Service 'gatekeeperd' (pid 212) killed by signal 6
[   18.918920] init: Service 'gatekeeperd' (pid 212) killing any children in process group
[   18.919268] init: Service 'installd' (pid 213) killed by signal 6
[   18.919337] init: Service 'installd' (pid 213) killing any children in process group
[   18.919745] init: Service 'keystore' (pid 214) killed by signal 6
[   18.919820] init: Service 'keystore' (pid 214) killing any children in process group
[   18.920115] init: Service 'mediacodec' (pid 216) killed by signal 6
[   18.920178] init: Service 'mediacodec' (pid 216) killing any children in process group
[   18.920559] init: Service 'mediadrm' (pid 217) killed by signal 6
[   18.920618] init: Service 'mediadrm' (pid 217) killing any children in process group
[   18.920880] init: Service 'mediaextractor' (pid 218) killed by signal 6
[   18.930998] init: Service 'mediaextractor' (pid 218) killing any children in process group
[   18.931395] init: Service 'logd' (pid 215) killed by signal 6
[   18.931452] init: Service 'logd' (pid 215) killing any children in process group
[   18.931827] init: Service 'media' (pid 219) killed by signal 9
[   18.931873] init: Service 'media' (pid 219) killing any children in process group
[   18.932107] init: Service 'netd' (pid 220) killed by signal 6
[   18.932158] init: Service 'netd' (pid 220) killing any children in process group
[   18.932538] init: Service 'vold' (pid 222) killed by signal 6
[   18.932585] init: Service 'vold' (pid 222) killing any children in process group
[   19.752331] read descriptors
[   19.752448] read descriptors
[   19.752490] read strings
[   19.752602] pcd_pullup, is_on 1
[   22.711727] init: Starting service 'healthd'...
[   22.714707] init: Starting service 'displayd'...
[   22.717422] init: Starting service 'lmkd'...
[   22.720746] init: Starting service 'servicemanager'...
[   22.723276] binder: 227:227 transaction failed 29189, size 0-0
[   22.723824] init: Starting service 'surfaceflinger'...
[   22.731971] init: Service 'displayd' (pid 228) killed by signal 6
[   22.732121] init: Service 'displayd' (pid 228) killing any children in process group
[   22.735856] init: Service 'lmkd' (pid 229) killed by signal 6
[   22.735960] init: Service 'lmkd' (pid 229) killing any children in process group
[   22.736376] init: Service 'surfaceflinger' (pid 231) killed by signal 6
[   22.736443] init: Service 'surfaceflinger' (pid 231) killing any children in process group
[   22.739652] init: Service 'servicemanager' (pid 230) killed by signal 6
[   22.739752] init: Service 'servicemanager' (pid 230) killing any children in process group
[   22.739829] init: Service 'healthd' is being killed...
[   22.740084] init: do_restart: Service inputflinger not found
[   22.741612] init: Service 'healthd' (pid 227) killed by signal 9
[   22.741683] init: Service 'healthd' (pid 227) killing any children in process group
[   23.727598] init: Starting service 'console'...
[   23.730423] init: Starting service 'zygote'...
[   23.733457] init: Starting service 'audioserver'...
[   23.736326] init: Starting service 'cameraserver'...
[   23.739503] init: Starting service 'debuggerd'...
[   23.743374] init: couldn't write 235 to /dev/cpuset/camera-daemon/tasks: No such file or directory
[   23.744271] init: Starting service 'drm'...
[   23.746546] init: Starting service 'gatekeeperd'...
[   23.748964] init: Starting service 'installd'...
[   23.751331] init: Starting service 'keystore'...
[   23.754413] init: Starting service 'logd'...
[   23.756413] init: Starting service 'mediacodec'...
[   23.758520] init: Starting service 'mediadrm'...
[   23.760737] init: Starting service 'mediaextractor'...
[   23.769639] init: Starting service 'media'...
[   23.772252] init: Starting service 'netd'...
[   23.774918] init: Starting service 'vold'...
[   23.776861] init: Service 'console' (pid 232) killed by signal 6
[   23.778147] init: Service 'console' (pid 232) killing any children in process group
[   23.779372] init: Service 'zygote' (pid 233) killed by signal 6
[   23.780041] init: Service 'zygote' (pid 233) killing any children in process group
[   23.781099] init: write_file: Unable to open '/sys/android_power/request_state': No such file or directory
[   23.781290] init: write_file: Unable to write to '/sys/power/state': Invalid argument
[   23.781427] init: Service 'audioserver' is being killed...
[   23.781606] init: Service 'cameraserver' is being killed...
[   23.781802] init: Service 'media' is being killed...
[   23.782105] init: Service 'netd' is being killed...
[   23.782501] init: Service 'audioserver' (pid 234) killed by signal 6
[   23.782557] init: Service 'audioserver' (pid 234) killing any children in process group
[   23.782883] init: Service 'cameraserver' (pid 235) killed by signal 6
[   23.782937] init: Service 'cameraserver' (pid 235) killing any children in process group
[   23.783166] init: Service 'debuggerd' (pid 236) killed by signal 6
[   23.783207] init: Service 'debuggerd' (pid 236) killing any children in process group
[   23.783422] init: Service 'drm' (pid 237) killed by signal 6
[   23.783464] init: Service 'drm' (pid 237) killing any children in process group
[   23.783738] init: Service 'gatekeeperd' (pid 238) killed by signal 6
[   23.783794] init: Service 'gatekeeperd' (pid 238) killing any children in process group
[   23.784085] init: Service 'installd' (pid 239) killed by signal 6
[   23.784136] init: Service 'installd' (pid 239) killing any children in process group
[   23.784430] init: Service 'keystore' (pid 240) killed by signal 6
[   23.784485] init: Service 'keystore' (pid 240) killing any children in process group
[   23.784832] init: Service 'logd' (pid 241) killed by signal 6
[   23.784892] init: Service 'logd' (pid 241) killing any children in process group
[   23.785360] init: Service 'mediacodec' (pid 242) killed by signal 6
[   23.785401] init: Service 'mediacodec' (pid 242) killing any children in process group
[   23.785598] init: Service 'mediadrm' (pid 243) killed by signal 6
[   23.785634] init: Service 'mediadrm' (pid 243) killing any children in process group
[   23.785831] init: Service 'mediaextractor' (pid 244) killed by signal 6
[   23.785875] init: Service 'mediaextractor' (pid 244) killing any children in process group
[   23.786001] init: Service 'media' (pid 245) killed by signal 9
[   23.786036] init: Service 'media' (pid 245) killing any children in process group
[   23.786235] init: Service 'netd' (pid 246) killed by signal 9
[   23.786276] init: Service 'netd' (pid 246) killing any children in process group
[   23.795101] init: Service 'vold' (pid 247) killed by signal 6
[   23.795146] init: Service 'vold' (pid 247) killing any children in process group
[   27.735817] init: Starting service 'healthd'...
[   27.738727] init: Starting service 'displayd'...
[   27.741485] init: Starting service 'lmkd'...
[   27.744461] init: Starting service 'servicemanager'...
[   27.746707] binder: 248:248 transaction failed 29189, size 0-0
[   27.747703] init: Starting service 'surfaceflinger'...
[   27.753854] init: Service 'displayd' (pid 249) killed by signal 6
[   27.753997] init: Service 'displayd' (pid 249) killing any children in process group
[   27.754174] type=1400 audit(25.200:10): avc:  denied  { unlink } for  pid=1 comm="init" name="displayd" dev="tmpfs" ino=8446 scontext=u:r:init:s0 tcontext=u:object_r:socket_device:s0 tclass=sock_file permissive=1
[   27.759046] init: Service 'surfaceflinger' (pid 252) killed by signal 6
[   27.759190] init: Service 'surfaceflinger' (pid 252) killing any children in process group
[   27.761995] init: Service 'lmkd' (pid 250) killed by signal 6
[   27.762070] init: Service 'lmkd' (pid 250) killing any children in process group
[   27.762260] init: critical process 'lmkd' exited 4 times in 4 minutes; rebooting into recovery mode
[   27.764022] SysRq : Emergency Remount R/O
[   27.767023] EXT4-fs (rknand_userdata): re-mounted. Opts: (null)
[   27.771844] EXT4-fs (rknand_metadata): re-mounted. Opts: (null)
[   27.778837] EXT4-fs (rknand_cache): re-mounted. Opts: (null)
[   27.779145] Emergency Remount complete
[   27.866989] cpufreq: cpufreq: reboot set core rate=1008000000, volt=1225000
[   27.867483] dwc_otg_driver_shutdown: disconnect USB host mode
[   27.868458] PortPower off
[   27.868697] rk_battery_charger_detect_cb , battery_charger_detect 6
[   27.870333] rknand_shutdown...
[   27.870638] nand th quited
[   27.947053] rknand_shutdown:OK
[   28.021388] Restarting system with command 'recovery'.
DDR Version V1.06 20170902_dbg
In
300MHz
DDR3
Bus Width=16 Col=11 Bank=8 Row=15 CS=1 Die Bus-Width=16 Size=1024MB
mach:2
OUT
Boot1 Release Time: Nov 27 2017 10:11:34, version: 2.47
ChipType = 0xc, 361
ECC:60
SdmmcInit=0 2
StorageInit ok = 329384
SecureMode = 0
Code check OK! theLoader 0x60000000, 356626
Code check OK! theLoader 0x68400000, 381565
Enter Trust OS
INF TEE-CORE:init_primary_helper:319: Initializing (1.0.1-72-gf230aa2 #2 Fri Sep 29 10:22:10 UTC 2017 arm)
INF TEE-CORE:init_primary_helper:320: Release version: 2.0
INF TEE-CORE:init_teecore:79: teecore inits done
U-Boot 2014.10-RK322X-06-02489-g4e89f4b-dirty (Aug 06 2018 - 17:36:59)
CPU: rk322x
cpu version = 3
CPU's clock information:
    arm pll = 600000000HZ
    periph pll = 600000000HZ
    ddr pll = 600000000HZ
    codec pll = 500000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000060000000(0000000040000000)
Reserve memory for trust os.
dram reserve bank: base = 0x68400000, size = 0x00100000
128 MiB
GIC CPU mask = 0x00000001
rk dma pl330 version: 1.4
remotectl v0.1
pwm freq=0x11e1a3
pwm_freq_nstime=0x355
SdmmcInit = 0 20
SdmmcInit = 2 20
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
can't find dts node for fixed
No pmic detect.
DRAM: dram freq:500MHz
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2018-08-06#2.37
empty serial no.
reboot recover.
no fuel gauge found
no fuel gauge found
can't find power_ctr node for lcdc0
HDMI: no pull up gpio
can't find dts node for deviceinfo
rk_hdmi_register:fail to read deviceinfo
preset hdmi resolution is 1920x1080@60-1,i=10
left = 0, right = 0, top = 0, bottom = 0, overscan = 0
panel->left = 100 , panel->right = 100 ,panel->top = 100, panel->bottom = 100, panel->overscan = 100
preset tve resolution is 720x576@50-1,i=1
Hdmi Devices Not Exist.
can't find dts node for rk312x-tve
SCREEN_TVOUT
rk3036_tve_init:use baseparamer config g_tve_pos = 1
read logo on state from dts [1]
no fuel gauge found
load fdt from resouce.
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
Secure Boot state: 0
kernel   @ 0x62000000 (0x007c6ce8)
ramdisk  @ 0x65bf0000 (0x004c2b30)
bootrk: do_bootm_linux...
   Loading Device Tree to 65600000, end 65614b77 ... OK
Add bank:0000000060000000, 0000000008400000
Add bank:0000000068500000, 0000000037b00000
Starting kernel ...
<hit enter to activate fiq debugger>
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.104 (akrd-52@aike5) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Mon Aug 6 17:39:32 CST 2018
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Rockchip RK3229, model: rockchip,rk3229
[    0.000000] rockchip_uboot_logo_setup: mem: 0x02000000@0x9dc00000, offset:0x00000000
[    0.000000] hdmi init vic is 65541
[    0.000000] cvbs init tve.format is 1
[    0.000000] rockchip_uboot_mem_reserve: reserve 0x02000000@0x9dc00000 for uboot logo
[    0.000000] rockchip_ion_reserve
[    0.000000] ion heap(vmalloc): base(0) size(0) align(0)
[    0.000000] cma: CMA: reserved 16 MiB at 7f000000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] Boot mode: RECOVERY (2) flag: RECOVER (0xc3524203)
[    0.000000] psci: probing function IDs from device-tree
[    0.000000] PERCPU: Embedded 9 pages/cpu @c18ec000 s13440 r8192 d15232 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260864
[    0.000000] Kernel command line: vmalloc=496M psci=enable rockchip_jtag console=ttyFIQ0 androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00004000@0x00004000(trust),0x00002000@0x00008000(misc),0x00000800@0x0000A000(baseparamer),0x00007800@0x0000A800(resource),0x00006000@0x00012000(kernel),0x00006000@0x00018000(boot),0x00010000@0x0001E000(recovery),0x00020000@0x0002E000(backup),0x00040000@0x0004E000(cache),0x00008000@0x0008E000(metadata),0x00002000@0x00096000(kpanic),0x00600000@0x00098000(system),-@0x00698000(userdata) storagemedia=nand uboot_logo=0x02000000@0x9dc00000 loader.timestamp=2018-08-06_17:36:59 hdmi.vic=65541 tve.format=1 SecureBootCheckOk=0
[    0.000000] rockchip jtag enabled
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] allocated 2097152 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Memory: 132MB 891MB = 1023MB total
[    0.000000] Memory: 965292k/965292k available, 82260k reserved, 491516K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0dee7d4   (14234 kB)
[    0.000000]       .init : 0xc0def000 - 0xc0e4f480   ( 386 kB)
[    0.000000]       .data : 0xc0e50000 - 0xc0f809e0   (1219 kB)
[    0.000000]        .bss : 0xc0f809e0 - 0xc10b051c   (1215 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] rk_clk_tree_init start!
[    0.000000] rk_get_uboot_display_flag: uboot_logo_on = 1
[    0.000000] rkclk_init_clks: cnt_parent = 13
[    0.000000] rkclk_init_clks: cnt_rate = 19
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Switching to timer-based delay loop
[    0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns
[    0.000000] process version: 0
[    0.000000] channel:0, lkg:3
[    0.000000] target-temp:95
[    0.000000] channel:2, lkg:3
[    0.000000] target-temp:0
[    0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms
[    3.134673] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    3.134699] pid_max: default: 32768 minimum: 301
[    3.134935] Security Framework initialized
[    3.134966] SELinux:  Initializing.
[    3.135098] Mount-cache hash table entries: 512
[    3.136240] Initializing cgroup subsys debug
[    3.136267] Initializing cgroup subsys memory
[    3.136320] Initializing cgroup subsys freezer
[    3.136382] CPU: Testing write buffer coherency: ok
[    3.136892] /cpus/cpu@0 missing clock-frequency property
[    3.136917] /cpus/cpu@1 missing clock-frequency property
[    3.136937] /cpus/cpu@2 missing clock-frequency property
[    3.136957] /cpus/cpu@3 missing clock-frequency property
[    3.137055] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    3.137099] Setting up static identity map for 0xc09d1ea0 - 0xc09d1ef8
[    3.139503] last_log: 0x7e900000 map to 0xe0804000 and copy to 0xe0886000, size 0x80000 early 0x17d6 (version 3.1)
[    3.212690] CPU1: Booted secondary processor
[    3.212747] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    3.232369] CPU2: Booted secondary processor
[    3.232412] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    3.252106] CPU3: Booted secondary processor
[    3.252150] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    3.252314] Brought up 4 CPUs
[    3.252365] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    3.252380] CPU: All CPU(s) started in SVC mode.
[    3.253791] devtmpfs: initialized
[    3.262322] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    3.263963] pinctrl core: initialized pinctrl subsystem
[    3.264450] regulator-dummy: no parameters
[    3.286545] NET: Registered protocol family 16
[    3.290036] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    3.290875] ion_snapshot: 0x7ea60000 map to 0xe0907000 and copy to 0xc1085b34 (version 0.1)
[    3.291092] Registered FIQ tty driver
[    3.293332] console [ttyFIQ0] enabled
[    3.293745] Registered fiq debugger ttyFIQ0
[    3.296302] syscon 10140000.syscon: regmap [mem 0x10140000-0x10140fff] registered
[    3.296625] syscon 11000000.syscon: regmap [mem 0x11000000-0x11000fff] registered
[    3.296946] syscon 110e0000.syscon: regmap [mem 0x110e0000-0x110e0fff] registered
[    3.297241] syscon 11200000.syscon: regmap [mem 0x11200000-0x112003ff] registered
[    3.297572] syscon 31020000.syscon: regmap [mem 0x31020000-0x31022fff] registered
[    3.304082] rk_iommu 20053f00.vop_mmu: (vop) Enter
[    3.304243] rk_iommu 20053f00.vop_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    3.304272] rk_iommu 20053f00.vop_mmu: (vop) Initialized
[    3.304534] rk_iommu 20020800.vpu_mmu: (vpu) Enter
[    3.304657] rk_iommu 20020800.vpu_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    3.304685] rk_iommu 20020800.vpu_mmu: (vpu) Initialized
[    3.304921] rk_iommu 20070800.iep_mmu: (iep) Enter
[    3.305051] rk_iommu 20070800.iep_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    3.305077] rk_iommu 20070800.iep_mmu: (iep) Initialized
[    3.305327] rk_iommu 20030480.vdec_mmu: (vdec) Enter
[    3.305447] rk_iommu 20030480.vdec_mmu: IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000.
[    3.305475] rk_iommu 20030480.vdec_mmu: (vdec) Initialized
[    3.315135] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    3.315167] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    3.315213] rockchip sip version v1
[    3.315842] rk3368_init_rockchip_pmu_ops: could not find pmu dt node
[    3.386669] bio: create slab <bio-0> at 0
[    3.387745] Rockchip hdmi driver version 2.0
[    3.388293] vccio_1v8: 1800 mV
[    3.388645] vccio_3v3: 3300 mV
[    3.390726] SCSI subsystem initialized
[    3.391128] usbcore: registered new interface driver usbfs
[    3.391246] usbcore: registered new interface driver hub
[    3.391467] usbcore: registered new device driver usb
[    3.395777] rockchip_i2c 11050000.i2c: i2c-0: Rockchip I2C adapter
[    3.396014] media: Linux media interface: v0.10
[    3.396105] Linux video capture interface: v2.00
[    3.396354] pps_core: LinuxPPS API ver. 1 registered
[    3.396374] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    3.396421] PTP clock support registered
[    3.396519] i2c-core: driver [bq24296] using legacy suspend method
[    3.396541] i2c-core: driver [bq24296] using legacy resume method
[    3.398009] Rockchip ion module is successfully loaded (v1.1)
[    3.398384] Advanced Linux Sound Architecture Driver Initialized.
[    3.399203] Bluetooth: Core ver 2.16
[    3.399293] NET: Registered protocol family 31
[    3.399313] Bluetooth: HCI device and connection manager initialized
[    3.399346] Bluetooth: HCI socket layer initialized
[    3.399374] Bluetooth: L2CAP socket layer initialized
[    3.399452] Bluetooth: SCO socket layer initialized
[    3.399902] cfg80211: Calling CRDA to update world regulatory domain
[    3.402891] i2c-core: driver [rk816] using legacy suspend method
[    3.402919] i2c-core: driver [rk816] using legacy resume method
[    3.402984] i2c-core: driver [rk818] using legacy suspend method
[    3.403005] i2c-core: driver [rk818] using legacy resume method
[    3.404342] rockchip-i2s 100c0000.i2s0: i2s0 has no mclk
[    3.407270] Switching to clocksource arch_sys_counter
[    3.446246] rga: Module initialized.
[    3.447058] rga2 20060000.rga: rga ion client create success!
[    3.447375] rga: Driver loaded succesfully
[    3.447694] fb disp policy is box
[    3.447734] uboot-logo-on:1
[    3.447795] rk-fb rockchip-fb: rk fb ion client create success!
[    3.447821] rk-fb rockchip-fb: rockchip framebuffer driver probe
[    3.448403] can't find screen_init node
[    3.448435] rk-screen rk_screen.15: rockchip screen probe success
[    3.450544] rk322x-lcdc 20050000.vop: vop_dev->regs=0xe0930000
[    3.450663] rk322x-lcdc vop0: can't find power_ctr node for lcdc0
[    3.451179] graphics fb0: rockchip framebuffer registerd:fb0
[    3.451909] graphics fb1: rockchip framebuffer registerd:fb1
[    3.452312] graphics fb2: rockchip framebuffer registerd:fb2
[    3.453329] rk322x-lcdc vop0: lcdc0: dclk:297000000>>fps:450
[    3.488666] alloc_buffer:ion_phy_addr=0x10000000
[    3.505826] fb0:phy:10000000>>vir:e093a000>>len:0x1800000
[    3.555813] rk_iommu 20053f00.vop_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x7e995000
[    3.555902] rk322x-lcdc vop0: lcdc0 probe ok, iommu enabled
[    3.559320] NET: Registered protocol family 2
[    3.560587] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    3.560727] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[    3.560830] TCP: Hash tables configured (established 4096 bind 4096)
[    3.560934] TCP: reno registered
[    3.560961] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    3.561004] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    3.561358] NET: Registered protocol family 1
[    3.561901] RPC: Registered named UNIX socket transport module.
[    3.561928] RPC: Registered udp transport module.
[    3.561946] RPC: Registered tcp transport module.
[    3.561964] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.563249] Unpacking initramfs...
[    3.974301] Freeing initrd memory: 4872K (c5bf0000 - c60b2000)
[    3.976214] hw perfevents: enabled with ARMv7_Cortex_A7 PMU driver, 5 counters available
[    3.980757] audit: initializing netlink socket (disabled)
[    3.980863] type=2000 audit(0.850:1): initialized
[    3.982265] bounce pool size: 64 pages
[    3.991730] NFS: Registering the id_resolver key type
[    3.991854] Key type id_resolver registered
[    3.991876] Key type id_legacy registered
[    3.992661] fuse init (API version 7.22)
[    3.993440] msgmni has been set to 966
[    3.994026]
[    3.994026] TEE Core Framework initialization (ver 1:0.1)
[    3.994102] TEE armv7 Driver initialization
[    3.994655] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    3.994687] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    3.995069] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=58)
[    3.998127] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    3.998173] io scheduler noop registered
[    3.998195] io scheduler deadline registered
[    3.998411] io scheduler cfq registered (default)
[    4.001090] HDMI: no pull up gpio
[    4.001924] reset hdmi
[    4.002184] rockchip-hdmiv2 200a0000.hdmi: rockchip hdmiv2 probe success.
[    4.002947] iep: failed to find iep power down clock source.
[    4.003552] iep ion client create success!
[    4.003589] IEP Power ON
[    4.003998] rk_iommu 20070800.iep_mmu: rockchip_iommu_attach_device: Attached new IOMMU with pgtable 0x7ea53000
[    4.004020] IEP Power OFF
[    4.004048] IEP Driver loaded succesfully
[    4.004215] Module initialized.
[    4.005211] rk3036-tve 20053e00.tve: Can not read det_io
[    4.005350] rk3036-tve 20053e00.tve: rockchip,rk322x-tve tv encoder probe ok
[    4.008735] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-2364208
[    4.008788] dma-pl330 110f0000.pdma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    4.009390] vdd_arm: 950 <--> 1400 mV at 1100 mV
[    4.010013] vdd_logic: 1000 <--> 1300 mV at 1200 mV
[    4.010659] rk_serial.c v2.0 2017-06-30
[    4.011231] 11020000.serial: ttyS1 at MMIO 0x11020000 (irq = 88) is a rk29_serial.1
[    4.011719] serial 11020000.serial: membase e23f6000
[    4.018089] loop: module loaded
[    4.018908] zram: Created 1 device(s)
[    4.019180] i2c-core: driver [mpu6050B1] using legacy suspend method
[    4.019203] i2c-core: driver [mpu6050B1] using legacy resume method
[    4.019228] mpu_init: Probe name mpu6050B1
[    4.019541] ak8963_mod_init: Probe name ak8963_mod
[    4.021094] SCSI Media Changer driver v0.25
[    4.021782] tun: Universal TUN/TAP device driver, 1.6
[    4.021817] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.022087] vmac_init.
[    4.023095] stmmac_probe_config_dt: Can not read property: pmu_regulator.
[    4.023125] stmmac_probe_config_dt: clock input/output? (output).
[    4.023146] stmmac_probe_config_dt: TX delay(0x26).
[    4.023167] stmmac_probe_config_dt: RX delay(0x11).
[    4.023188] stmmac_probe_config_dt: internal PHY/external PHY? (internal).
[    4.023360] stmmc_pltfr_init:
[    4.023403] stmmc_pltfr_init: ERROR: Get power-gpio failed.
[    4.023424] stmmc_pltfr_init: ERROR: Get reset-gpio failed.
[    4.023482] stmmc_pltfr_init: init for RMII
[    4.023789] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    4.023809]  Normal descriptors
[    4.023825]  Ring mode enabled
[    4.023842]  DMA HW capability register supported
[    4.023860]  RX Checksum Offload Engine supported (type 2)
[    4.023878]  TX Checksum insertion supported
[    4.023894]  Wake-Up On Lan supported
[    4.023979]  Enable RX Mitigation via HW Watchdog Timer
[    4.024828] PPP generic driver version 2.4.2
[    4.025184] PPP BSD Compression module registered
[    4.025211] PPP Deflate Compression module registered
[    4.025251] PPP MPPE Compression module registered
[    4.025273] NET: Registered protocol family 24
[    4.025330] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    4.025350] CSLIP: code copyright 1989 Regents of the University of California.
[    4.025370] Rockchip WiFi SYS interface (V1.00) ...
[    4.025440]
[    4.025459] =======================================================
[    4.025478] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    4.025495] =======================================================
[    4.025513] Realtek 8188EU USB WiFi driver (Powered by Rockchip) init.
[    4.025533] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    4.025552] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    4.025571] RTW: module init start
[    4.025589] RTW: rtl8188eu v5.2.2_19960.20161226
[    4.025607] RTW: build time: Aug  6 2018 17:38:56
[    4.025779] usbcore: registered new interface driver rtl8188eu
[    4.025799] RTW: module init ret=0
[    4.025816] =======================================================
[    4.025835] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    4.025851] =======================================================
[    4.025872]  WiFi driver (Powered by Rockchip,Ver 5.10.WFD.OOB.64bit) init.
[    4.025891] dhd_module_init: in
[    4.025908] ======== dhd_wlan_init_plat_data ========
[    4.025927] dhd_wlan_init_gpio: GPIO(WL_REG_ON) = -1
[    4.025946] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[    4.025965] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    4.025984] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: rfkill-wlan driver has not Successful initialized
[    4.026004] dhd_wlan_init_gpio: host_oob_irq: -1
[    4.026025] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[    4.026042] dhd_wifi_platform_load: Enter
[    4.026088] Power-up adapter 'DHD generic adapter'
[    4.026169] wifi_platform_set_power = 1
[    4.026190] ======== PULL WL_REG_ON(-1) HIGH! ========
[    4.026211] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    4.026229] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    4.224142] wifi_platform_bus_enumerate device present 1
[    4.224182] ======== Card detection to detect SDIO card! ========
[    4.224203] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    4.224222] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    4.234091] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    4.234127] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    4.234147] sdio: host isn't  initialization successfully.
[    6.201989] failed to power up DHD generic adapter, 0 retry left
[    6.217856] wifi_platform_set_power = 0
[    6.217891] ======== PULL WL_REG_ON(-1) LOW! ========
[    6.217913] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    6.217932] [WLAN_RFKILL]: rockchip_wifi_power: rfkill-wlan driver has not Successful initialized
[    6.217953] wifi_platform_bus_enumerate device present 0
[    6.217971] ======== Card detection to remove SDIO card! ========
[    6.217990] sdio: host isn't  initialization successfully.
[    6.218008] failed to power up DHD generic adapter, max retry reached**
[    6.218065] unregister wifi platform drivers
[    6.218086] wifi_platform_bus_enumerate device present 0
[    6.218102] ======== Card detection to remove SDIO card! ========
[    6.218120] sdio: host isn't  initialization successfully.
[    6.218139] ======== dhd_wlan_deinit_plat_data ========
[    6.218161] dhd_module_init: Failed to load the driver, try cnt 0
[    6.218215] dhd_module_init: Failed to load driver max retry reached**
[    6.218232] dhd_module_init: Exit err=-19
[    6.218253] esp_mem_init enter date Aug  6 2018 17:38:54
[    6.218273] esp_mem_init VERSION [V2.5]
[    6.218344] esp_mem_init complete
[    6.218489] usbcore: registered new interface driver catc
[    6.218585] usbcore: registered new interface driver kaweth
[    6.218607] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    6.218690] usbcore: registered new interface driver pegasus
[    6.218771] usbcore: registered new interface driver rtl8150
[    6.218855] usbcore: registered new interface driver r8152
[    6.218879] hso: drivers/net/usb/hso.c: Option Wireless
[    6.219025] usbcore: registered new interface driver hso
[    6.219145] usbcore: registered new interface driver asix
[    6.219231] usbcore: registered new interface driver ax88179_178a
[    6.219312] usbcore: registered new interface driver cdc_ether
[    6.219395] usbcore: registered new interface driver cdc_eem
[    6.219476] usbcore: registered new interface driver dm9601
[    6.219554] usbcore: registered new interface driver dm9620
[    6.219666] usbcore: registered new interface driver smsc75xx
[    6.219764] usbcore: registered new interface driver smsc95xx
[    6.219849] usbcore: registered new interface driver gl620a
[    6.219930] usbcore: registered new interface driver net1080
[    6.220010] usbcore: registered new interface driver plusb
[    6.220090] usbcore: registered new interface driver rndis_host
[    6.220167] usbcore: registered new interface driver cdc_subset
[    6.220261] usbcore: registered new interface driver zaurus
[    6.220344] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    6.220478] usbcore: registered new interface driver int51x1
[    6.220563] usbcore: registered new interface driver kalmia
[    6.220644] usbcore: registered new interface driver ipheth
[    6.220731] usbcore: registered new interface driver sierra_net
[    6.220817] usbcore: registered new interface driver cx82310_eth
[    6.220931] usbcore: registered new interface driver cdc_ncm
[    6.221018] usbcore: registered new interface driver qmi_wwan
[    6.221100] usbcore: registered new interface driver cdc_mbim
[    6.221121] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.221142] ehci-platform: EHCI generic platform driver
[    6.221814] ehci-platform 30080000.ehci0: EHCI Host Controller
[    6.221889] ehci-platform 30080000.ehci0: new USB bus registered, assigned bus number 1
[    6.222541] ehci-platform 30080000.ehci0: irq 48, io mem 0x30080000
[    6.241344] ehci-platform 30080000.ehci0: USB 2.0 started, EHCI 1.00
[    6.241514] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    6.241544] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.241571] usb usb1: Product: EHCI Host Controller
[    6.241595] usb usb1: Manufacturer: Linux 3.10.104 ehci_hcd
[    6.241619] usb usb1: SerialNumber: 30080000.ehci0
[    6.242621] hub 1-0:1.0: USB hub found
[    6.242669] hub 1-0:1.0: 1 port detected
[    6.243292] ehci-platform 300c0000.ehci1: EHCI Host Controller
[    6.243347] ehci-platform 300c0000.ehci1: new USB bus registered, assigned bus number 2
[    6.243916] ehci-platform 300c0000.ehci1: irq 51, io mem 0x300c0000
[    6.261064] ehci-platform 300c0000.ehci1: USB 2.0 started, EHCI 1.00
[    6.261219] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    6.261245] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.261271] usb usb2: Product: EHCI Host Controller
[    6.261296] usb usb2: Manufacturer: Linux 3.10.104 ehci_hcd
[    6.261317] usb usb2: SerialNumber: 300c0000.ehci1
[    6.262208] hub 2-0:1.0: USB hub found
[    6.262275] hub 2-0:1.0: 1 port detected
[    6.262821] ehci-platform 30100000.ehci2: EHCI Host Controller
[    6.262871] ehci-platform 30100000.ehci2: new USB bus registered, assigned bus number 3
[    6.263452] ehci-platform 30100000.ehci2: irq 98, io mem 0x30100000
[    6.280730] ehci-platform 30100000.ehci2: USB 2.0 started, EHCI 1.00
[    6.280891] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    6.280920] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.280946] usb usb3: Product: EHCI Host Controller
[    6.280969] usb usb3: Manufacturer: Linux 3.10.104 ehci_hcd
[    6.280993] usb usb3: SerialNumber: 30100000.ehci2
[    6.281812] hub 3-0:1.0: USB hub found
[    6.281887] hub 3-0:1.0: 1 port detected
[    6.282663] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    6.282933] ohci-platform: OHCI generic platform driver
[    6.283154] ohci-platform 300a0000.ohci0: Generic Platform OHCI controller
[    6.283206] ohci-platform 300a0000.ohci0: new USB bus registered, assigned bus number 4
[    6.283292] ohci-platform 300a0000.ohci0: irq 49, io mem 0x300a0000
[    6.343782] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    6.343829] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.343857] usb usb4: Product: Generic Platform OHCI controller
[    6.343882] usb usb4: Manufacturer: Linux 3.10.104 ohci_hcd
[    6.343907] usb usb4: SerialNumber: 300a0000.ohci0
[    6.344806] hub 4-0:1.0: USB hub found
[    6.344853] hub 4-0:1.0: 1 port detected
[    6.345297] ohci-platform 300e0000.ohci1: Generic Platform OHCI controller
[    6.345351] ohci-platform 300e0000.ohci1: new USB bus registered, assigned bus number 5
[    6.345430] ohci-platform 300e0000.ohci1: irq 52, io mem 0x300e0000
[    6.402821] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    6.402864] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.402891] usb usb5: Product: Generic Platform OHCI controller
[    6.402914] usb usb5: Manufacturer: Linux 3.10.104 ohci_hcd
[    6.402936] usb usb5: SerialNumber: 300e0000.ohci1
[    6.403755] hub 5-0:1.0: USB hub found
[    6.403799] hub 5-0:1.0: 1 port detected
[    6.404245] ohci-platform 30120000.ohci2: Generic Platform OHCI controller
[    6.404299] ohci-platform 30120000.ohci2: new USB bus registered, assigned bus number 6
[    6.404380] ohci-platform 30120000.ohci2: irq 99, io mem 0x30120000
[    6.461861] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    6.461903] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.461929] usb usb6: Product: Generic Platform OHCI controller
[    6.461951] usb usb6: Manufacturer: Linux 3.10.104 ohci_hcd
[    6.461975] usb usb6: SerialNumber: 30120000.ohci2
[    6.462818] hub 6-0:1.0: USB hub found
[    6.462862] hub 6-0:1.0: 1 port detected
[    6.463492] usbcore: registered new interface driver cdc_acm
[    6.463517] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    6.463653] usbcore: registered new interface driver usblp
[    6.463749] usbcore: registered new interface driver cdc_wdm
[    6.463970] usbcore: registered new interface driver usb-storage
[    6.464057] usbcore: registered new interface driver ums-alauda
[    6.464139] usbcore: registered new interface driver ums-cypress
[    6.464225] usbcore: registered new interface driver ums-datafab
[    6.464310] usbcore: registered new interface driver ums_eneub6250
[    6.464391] usbcore: registered new interface driver ums-freecom
[    6.464473] usbcore: registered new interface driver ums-isd200
[    6.464557] usbcore: registered new interface driver ums-jumpshot
[    6.464637] usbcore: registered new interface driver ums-karma
[    6.464729] usbcore: registered new interface driver ums-onetouch
[    6.464813] usbcore: registered new interface driver ums-sddr09
[    6.464900] usbcore: registered new interface driver ums-sddr55
[    6.464979] usbcore: registered new interface driver ums-usbat
[    6.465192] usbcore: registered new interface driver usbserial
[    6.465279] usbcore: registered new interface driver usbserial_generic
[    6.465343] usbserial: USB Serial support registered for generic
[    6.465435] usbcore: registered new interface driver option
[    6.465507] usbserial: USB Serial support registered for GSM modem (1-port)
[    6.465926] usbcore: registered new interface driver trancevibrator
[    6.465947] usb20_otg: version 3.10a 21-DEC-2012
[    6.466883] e2680040
[    6.466910] Core Release: 3.10a
[    6.466929] Setting default values for core params
[    6.467238] Using Buffer DMA mode
[    6.467261] Periodic Transfer Interrupt Enhancement - disabled
[    6.467281] Multiprocessor Interrupt Enhancement - disabled
[    6.467299] OTG VER PARAM: 0, OTG VER FLAG: 0
[    6.467317] ^^^^^^^^^^^^^^^^^Device Mode
[    6.467344] Dedicated Tx FIFOs mode
[    6.467378] pcd_init otg_dev = dded3500
[    6.467791] usb20_otg 30040000.otg: DWC OTG Controller
[    6.467850] usb20_otg 30040000.otg: new USB bus registered, assigned bus number 7
[    6.467920] usb20_otg 30040000.otg: irq 55, io mem 0x00000000
[    6.468048] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[    6.468075] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    6.468101] usb usb7: Product: DWC OTG Controller
[    6.468125] usb usb7: Manufacturer: Linux 3.10.104 dwc_otg_hcd
[    6.468150] usb usb7: SerialNumber: 30040000.otg
[    6.469078] hub 7-0:1.0: USB hub found
[    6.469122] hub 7-0:1.0: 1 port detected
[    6.469718] usb20_host: version 3.10a 21-DEC-2012
[    6.471723] usbcore: registered new interface driver xpad
[    6.471860] usbcore: registered new interface driver usb_acecad
[    6.471968] usbcore: registered new interface driver aiptek
[    6.472072] usbcore: registered new interface driver gtco
[    6.472172] usbcore: registered new interface driver hanwang
[    6.472273] usbcore: registered new interface driver kbtab
[    6.472401] usbcore: registered new interface driver wacom
[    6.472582] ==gsl_ts_init==
[    6.472650] ret=0
[    6.472713] i2c-core: driver [gslX680] using legacy suspend method
[    6.472735] i2c-core: driver [gslX680] using legacy resume method
[    6.473611] sensor_register_slave:mma8452,id=17
[    6.473637] sensor_register_slave:mma7660,id=18
[    6.473656] sensor_register_slave:gs_mc3230,id=23
[    6.473674] [Gsensor] gsensor_init
[    6.473694] sensor_register_slave:mpu6880_acc,id=24
[    6.473714] sensor_register_slave:mpu6500_acc,id=25
[    6.473734] sensor_register_slave:bma2xx_acc,id=26
[    6.473753] sensor_register_slave:akm8963,id=30
[    6.473773] sensor_register_slave:cm3217,id=51
[    6.473790] sensor_register_slave:cm3218,id=52
[    6.473809] sensor_register_slave:ls_stk3410,id=60
[    6.474486] .. rk pwm remotectl v1.1 init
[    6.474575] #######################################
[    6.474663] ################22222#######################
[    6.474725] ######################3333#################
[    6.474789] ########################4444###############
[    6.474850] #############################555##########
[    6.475213] input: 110b0030.pwm as /devices/110b0030.pwm/input/input0
[    6.475924] remotectl-pwm 110b0030.pwm: Missing psci property in the DT.
[    6.566137] dwc_otg_hcd_suspend, usb device mode
[    7.112328] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0
[    7.112420] i2c /dev entries driver
[    7.113013] IR NEC protocol handler initialized
[    7.113035] IR RC5(x) protocol handler initialized
[    7.113055] IR RC6 protocol handler initialized
[    7.113072] IR JVC protocol handler initialized
[    7.113089] IR Sony protocol handler initialized
[    7.113107] IR RC5 (streamzap) protocol handler initialized
[    7.113123] IR SANYO protocol handler initialized
[    7.113140] IR MCE Keyboard/mouse protocol handler initialized
[    7.113497] usbcore: registered new interface driver uvcvideo
[    7.113532] USB Video Class driver (1.1.1)
[    7.113555] CamSys driver version: v0.35.0,  CamSys head file version: v0.13.0
[    7.113579] E:camsys_soc_init(36): camsys isn't support soc: 0x32283002!
[    7.114242] not find test_power_init dev node
[    7.114323] i2c-core: driver [bq27320] using legacy suspend method
[    7.114344] i2c-core: driver [bq27320] using legacy resume method
[    7.115663] ===========net_led_probe start===========
[    7.115807] ===========net_led_probe end===========
[    7.116051] ===========remote_led_probe start===========
[    7.116158] ===========remote_led_probe end===========
[    7.116390] ===========suspend_led_probe start===========
[    7.116532] ===========suspend_led_probe end===========
[    7.116951] rockchip_temp_probe,line=384
[    7.117560] tsadc 11150000.tsadc: Missing tsadc_low_temp in the DT.
[    7.176143] tsadc 11150000.tsadc: initialized
[    7.177077] device-mapper: uevent: version 1.0.3
[    7.177615] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    7.178074] Bluetooth: HCI UART driver ver 2.2
[    7.178102] Bluetooth: HCI H4 protocol initialized
[    7.178121] Bluetooth: HCILL protocol initialized
[    7.178140] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    7.178159] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    7.178178] rtk_btusb: Register usb char device interface for BT driver
[    7.178579] usbcore: registered new interface driver rtk_btusb
[    7.179005] cpufreq version 1.0, suspend freq 1008 MHz
[    7.179570] cpuidle: using governor ladder
[    7.179595] cpuidle: using governor menu
[    7.179675] Synopsys Designware Multimedia Card Interface Driver
[    7.179697] MHSC version = Ver 2.00 2015-06-10
[    7.180247] dwmmc_rockchip 30020000.rksdmmc: Version ID is 270a
[    7.180341] dwmmc_rockchip 30020000.rksdmmc: failed to get hpclk_mmc
[    7.180807] dwmmc_rockchip 30020000.rksdmmc: Using internal DMA controller.
[    7.181155] dwmmc_rockchip 30020000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=125000000 [mmc0]
[    7.195909] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0]
[    7.215598] dwmmc_rockchip 30020000.rksdmmc: DW MMC controller at irq 46, 32 bit host data width, 256 deep fifo
[    7.215638] dwmmc_rockchip 30020000.rksdmmc: 1 slots initialized
[    7.216436] dwmmc_rockchip 30000000.rksdmmc: Version ID is 270a
[    7.216528] dwmmc_rockchip 30000000.rksdmmc: failed to get hpclk_mmc
[    7.216967] dwmmc_rockchip 30000000.rksdmmc: Using internal DMA controller.
[    7.217333] dwmmc_rockchip 30000000.rksdmmc: dw_mci_init_slot: fmin=400000, fmax=37500000 [mmc1]
[    7.217632] dwmmc_rockchip 30000000.rksdmmc: mmc1: No udbg pinctrl found!
[    7.235219] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc1]
[    7.255090] dwmmc_rockchip 30000000.rksdmmc: DW MMC controller at irq 44, 32 bit host data width, 256 deep fifo
[    7.255166] dwmmc_rockchip 30000000.rksdmmc: 1 slots initialized
[    7.256396] dwmmc_rockchip 30010000.rksdmmc: Version ID is 270a
[    7.256534] dwmmc_rockchip 30010000.rksdmmc: failed to get hpclk_mmc
[    7.257113] dwmmc_rockchip 30010000.rksdmmc: Using internal DMA controller.
[    7.257618] dwmmc_rockchip 30010000.rksdmmc: dw_mci_init_slot: fmin=200000, fmax=37500000 [mmc2]
[    7.274658] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[    7.294446] dwmmc_rockchip 30010000.rksdmmc: DW MMC controller at irq 45, 32 bit host data width, 256 deep fifo
[    7.294516] dwmmc_rockchip 30010000.rksdmmc: 1 slots initialized
[    7.295247] leds-gpio power-led.31: pins are not configured from the driver
[    7.296230] hidraw: raw HID events driver (C) Jiri Kosina
[    7.303525] usbcore: registered new interface driver usbhid
[    7.303594] usbhid: USB HID core driver
[    7.304271] ashmem: initialized
[    7.304826] logger: created 256K log 'log_main'
[    7.305327] logger: created 256K log 'log_events'
[    7.305816] logger: created 256K log 'log_radio'
[    7.306300] logger: created 256K log 'log_system'
[    7.308572] rknandbase v1.1 2016-11-08
[    7.309198] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    7.309523] No.1 FLASH ID:2c 64 44 32 a5 0
[    7.310156] ECC:60
[    7.310221] FTL version: 5.0.47 20171120
[    7.441067] FtlInit 0
[    7.441405]  parameter: 0x000000000 -- 0x000400000 (4 MB)
[    7.441989]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    7.442328]      trust: 0x000800000 -- 0x001000000 (8 MB)
[    7.442617]       misc: 0x001000000 -- 0x001400000 (4 MB)
[    7.442913] baseparamer: 0x001400000 -- 0x001500000 (1 MB)
[    7.443202]   resource: 0x001500000 -- 0x002400000 (15 MB)
[    7.443490]     kernel: 0x002400000 -- 0x003000000 (12 MB)
[    7.443787]       boot: 0x003000000 -- 0x003c00000 (12 MB)
[    7.444095]   recovery: 0x003c00000 -- 0x005c00000 (32 MB)
[    7.444394]     backup: 0x005c00000 -- 0x009c00000 (64 MB)
[    7.444695]      cache: 0x009c00000 -- 0x011c00000 (128 MB)
[    7.445010]   metadata: 0x011c00000 -- 0x012c00000 (16 MB)
[    7.445335]     kpanic: 0x012c00000 -- 0x013000000 (4 MB)
[    7.445649]     system: 0x013000000 -- 0x0d3000000 (3072 MB)
[    7.445958]   userdata: 0x0d3000000 -- 0x1d4000000 (4112 MB)
[    7.450721] vendor storage 524b5644,2,2
[    7.453598] vendor storage 524b5644,3,3
[    7.458955] rockchip-spdif 100d0000.spdif: spdif ready.
[    7.550114] Using Buffer DMA mode
[    7.550147] Periodic Transfer Interrupt Enhancement - disabled
[    7.550158] Multiprocessor Interrupt Enhancement - disabled
[    7.550170] OTG VER PARAM: 0, OTG VER FLAG: 0
[    7.550181] ^^^^^^^^^^^^^^^^^^Host Mode
[    7.551968] rk322x-audio rockchip_audio.28:  rk322x-hifi <-> 100b0000.i2s1 mapping ok
[    7.556070] rockchip-hdmi-i2s rockchip_hdmi_i2s.30:  rk-hdmi-i2s-hifi <-> 100c0000.i2s0 mapping ok
[    7.557013] u32 classifier
[    7.557032]     Actions configured
[    7.557047] Netfilter messages via NETLINK v0.30.
[    7.557137] nf_conntrack version 0.5.0 (15414 buckets, 61656 max)
[    7.557664] ctnetlink v0.93: registering with nfnetlink.
[    7.557763] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    7.557775] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    7.558314] xt_time: kernel timezone is -0000
[    7.558654] ip_tables: (C) 2000-2006 Netfilter Core Team
[    7.558886] arp_tables: (C) 2002 David S. Miller
[    7.558949] TCP: cubic registered
[    7.558959] Initializing XFRM netlink socket
[    7.559381] NET: Registered protocol family 10
[    7.560366] mip6: Mobile IPv6
[    7.560417] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    7.560631] sit: IPv6 over IPv4 tunneling driver
[    7.561256] NET: Registered protocol family 17
[    7.561302] NET: Registered protocol family 15
[    7.561406] Bridge firewalling registered
[    7.561427] Ebtables v2.0 registered
[    7.561725] Bluetooth: RFCOMM TTY layer initialized
[    7.561779] Bluetooth: RFCOMM socket layer initialized
[    7.561791] Bluetooth: RFCOMM ver 1.11
[    7.561802] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.561811] Bluetooth: BNEP filters: protocol multicast
[    7.561829] Bluetooth: BNEP socket layer initialized
[    7.561840] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    7.561856] Bluetooth: HIDP socket layer initialized
[    7.561957] l2tp_core: L2TP core driver, V2.0
[    7.561980] l2tp_ppp: PPPoL2TP kernel driver, V2.0
[    7.561990] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    7.562247] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    7.562266] [WLAN_RFKILL]: can't find rockchip,grf property
[    7.562279] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = rtl8189fs
[    7.562291] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    7.562303] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control.
[    7.562318] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    7.562393] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 90, flags = 0.
[    7.562439] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 28, flags = 0.
[    7.562453] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    7.562508] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    7.562521] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    7.599301] Init: Power Port (0)
[    7.599374] 30040000.otg resume, HPRT0:0x1000
[    7.599499] 30040000.otg suspend, HPRT0:0x1000
[    7.668179] [WLAN_RFKILL]: wifi shut off power.
[    7.668245] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 0
[    7.668276] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[    7.678162] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    7.678214] [BT_RFKILL]: rfkill_get_bt_power_state: rfkill-bt driver has not Successful initialized
[    7.678251] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: 1
[    7.678280] [WLAN_RFKILL]: rockchip_wifi_ref_voltage: wifi io reference voltage control is disabled.
[    7.786262] [WLAN_RFKILL]: wifi turn on power. 90
[    7.786313] mmc2:mmc host rescan start!
[    7.786361] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    7.786535] [BT_RFKILL]: Enter rfkill_rk_init
[    7.787336] Key type dns_resolver registered
[    7.792267] rk322x_suspend_init: pm_ctrbits = 0x11806
[    7.792373] Registering SWP/SWPB emulation handler
[    7.792418] rockchip_uboot_mem_late_init: Freeing uboot logo memory: 0x02000000@0x9dc00000
[    7.807232] ddrfreq: verion 1.2 20140526
[    7.846130] ddrfreq: normal 600MHz performance 0MHz low_power 0MHz video_1080p 0MHz video_4k 700MHz dualview 0MHz idle 0MHz suspend 0MHz reboot 600MHz video_4k_10b 720MHz
[    7.846251] ddrfreq: auto-freq=0
[    7.846271] ddrfreq: auto-freq-table epmty!
[    7.847742] regulator-dummy: disabling
[    7.848185] pcd_pullup, is_on 0
[    7.848221] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[    7.848221]
[    7.848265] WARN::dwc_otg_handle_mode_mismatch_intr:69: Mode Mismatch Interrupt: currently in Host mode
[    7.848265]
[    7.848407] file system registered
[    7.850192] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    7.850215] android_usb gadget: Number of LUNs=2
[    7.850234]  lun0: LUN: removable file: (no medium)
[    7.850252]  lun1: LUN: removable file: (no medium)
[    7.850849] android_usb gadget: android_usb ready
[    7.850976] sensor_init: Probe name sensors
[    7.851017] sensor-dev.c v1.4 add angle calculation support between two gsensors 2013-09-01
[    7.899127] rtc_hym8563 0-0051: hctosys: invalid date/time
[    7.913547] rockchip-spdif-card rockchip_spdif_card.29:  rk-hdmi-spdif-hifi <-> 100d0000.spdif mapping ok
[    7.915855] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 414; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is '-v3.10.92-28033-gae45312', rk_ko_ver is '5', built at '17:38:20', on 'Aug  6 2018'.
[    7.916356] mali-utgard 20001000.gpu: mali_platform_device->num_resources = 13
[    7.916407] mali-utgard 20001000.gpu: resource[0].start = 0x0x20001000
[    7.916446] mali-utgard 20001000.gpu: resource[1].start = 0x0x20000000
[    7.916485] mali-utgard 20001000.gpu: resource[2].start = 0x0x20003000
[    7.916524] mali-utgard 20001000.gpu: resource[3].start = 0x0x20008000
[    7.916562] mali-utgard 20001000.gpu: resource[4].start = 0x0x20004000
[    7.916603] mali-utgard 20001000.gpu: resource[5].start = 0x0x2000a000
[    7.916642] mali-utgard 20001000.gpu: resource[6].start = 0x0x20005000
[    7.916682] mali-utgard 20001000.gpu: resource[7].start = 0x0x00000026
[    7.916719] mali-utgard 20001000.gpu: resource[8].start = 0x0x00000025
[    7.916757] mali-utgard 20001000.gpu: resource[9].start = 0x0x00000024
[    7.916796] mali-utgard 20001000.gpu: resource[10].start = 0x0x00000025
[    7.916836] mali-utgard 20001000.gpu: resource[11].start = 0x0x00000024
[    7.916876] mali-utgard 20001000.gpu: resource[12].start = 0x0x00000025
[    7.917003] mali-utgard 20001000.gpu: freq: 200000000, min_threshold: 0, max_threshold: 70
[    7.917051] mali-utgard 20001000.gpu: freq: 300000000, min_threshold: 61, max_threshold: 85
[    7.917096] mali-utgard 20001000.gpu: freq: 400000000, min_threshold: 73, max_threshold: 100
[    7.917245] mali-utgard 20001000.gpu: initial freq = 200000000
[    7.921731] Mali: Mali device driver loaded
[    7.923054] usbcore: registered new interface driver snd-usb-audio
[    7.923091] ALSA device list:
[    7.923118]   #0: RK_RK322x
[    7.923146]   #1: RK-HDMI-I2S
[    7.923172]   #2: RK-SPDIF-CARD
[    7.924550] Freeing unused kernel memory: 384K (c0def000 - c0e4f000)
[    7.930152] init: init first stage started!
[    8.002798] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 400000Hz, actual 398936HZ div = 47)
[    8.002865] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc2]
[    8.028616] dwmmc_rockchip 30010000.rksdmmc: exceeding card's volts
[    8.028990] mmc2 not switch iovel.
[    8.052949] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[    8.053027] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc2]
[    8.053314] rk_sdmmc: BOOT Bus speed=37500000Hz,Bus width=4bits.[mmc2]
[    8.054826] mmc2: new high speed SDIO card at address 0001
[    8.183332] type=1403 audit(5.120:2): policy loaded auid=4294967295 ses=4294967295
[    8.185387] init: (Initializing SELinux non-enforcing took 0.26s.)
[    8.200256] init: init second stage started!
[    8.214667] init: Setting ro.rk.soc=rk3229
[    8.215212] init: property_set("ro.hardware", "rk30board") failed
[    8.223761] init: Running restorecon...
[    8.288108] vendor storage:20160801 ret = -1
[    8.312205] init: waitpid failed: No child processes
[    8.313478] init: property_set("ro.board.platform", "rk322x") failed
[    8.314201] init: property_set("ro.opengles.version", "196609") failed
[    8.314538] init: property_set("ro.rk.screenoff_time", "2147483647") failed
[    8.315059] init: property_set("ro.rk.screenshot_enable", "true") failed
[    8.315339] init: (Loading properties from /default.prop took 0.00s.)
[    8.317987] init: (Parsing /init.bootmode.unknown.rc took 0.00s.)
[    8.318109] init: could not import file '/init.recovery.rk30board.rc' from '/init.rc': No such file or directory
[    8.318149] init: (Parsing /init.rc took 0.00s.)
[    8.318492] init: Starting service 'ueventd'...
[    8.319191] init: Starting service 'healthd'...
[    8.320004] init: Waiting for /dev/.coldboot_done...
[    8.323074] ueventd: ueventd started!
[    8.324104] type=1400 audit(5.260:3): avc:  denied  { mknod } for  pid=118 comm="healthd" capability=27  scontext=u:r:healthd:s0 tcontext=u:r:healthd:s0 tclass=capability permissive=1
[    8.324229] ueventd: invalid gid 'trace'
[    8.324298] type=1400 audit(5.260:4): avc:  denied  { write } for  pid=118 comm="healthd" name="__kmsg__" dev="tmpfs" ino=6888 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    8.324352] type=1400 audit(5.260:5): avc:  denied  { open } for  pid=118 comm="healthd" path="/dev/__kmsg__" dev="tmpfs" ino=6888 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    8.324432] type=1400 audit(5.260:6): avc:  denied  { unlink } for  pid=118 comm="healthd" name="__kmsg__" dev="tmpfs" ino=6888 scontext=u:r:healthd:s0 tcontext=u:object_r:device:s0 tclass=chr_file permissive=1
[    8.324463] healthd: No battery devices found
[    8.324622] healthd: battery l=100 v=0 t=42.4 h=2 st=2 chg=a
[    8.589976] ueventd: Coldboot took 0.27s.
[    8.599192] init: Waiting for /dev/.coldboot_done took 0.28s.
[    8.599333] init: /dev/hw_random not found
[    8.602400] init: /dev/hw_random not found
[    8.609953] init: write_file: Unable to open '/config/usb_gadget/g1/os_desc/b_vendor_code': No such file or directory
[    8.610176] init: write_file: Unable to open '/config/usb_gadget/g1/os_desc/qw_sign': No such file or directory
[    8.611569] android_usb: already disabled
[    8.613047] init: property 'ro.serialno' doesn't exist while expanding '${ro.serialno}'
[    8.613149] init: write: cannot expand '${ro.serialno}'
[    8.613793] drmboot: module license 'unspecified' taints kernel.
[    8.613828] Disabling lock debugging due to kernel taint
[    8.614623] drm init, 20140910
[    8.614716] ------------[ cut here ]------------
[    8.614757] WARNING: at fs/sysfs/dir.c:530 sysfs_add_one+0x7c/0x9c()
[    8.614780] sysfs: cannot create duplicate filename '/devices/virtual/misc/rknand_sys_storage'
[    8.614801] Modules linked in: drmboot(P+)
[    8.614838] CPU: 0 PID: 1 Comm: init Tainted: P             3.10.104 #1
[    8.614892] [<c0014088>] (unwind_backtrace+0x0/0xe0) from [<c00118cc>] (show_stack+0x10/0x14)
[    8.614940] [<c00118cc>] (show_stack+0x10/0x14) from [<c003f320>] (warn_slowpath_common+0x4c/0x68)
[    8.614983] [<c003f320>] (warn_slowpath_common+0x4c/0x68) from [<c003f3bc>] (warn_slowpath_fmt+0x2c/0x3c)
[    8.615023] [<c003f3bc>] (warn_slowpath_fmt+0x2c/0x3c) from [<c016d22c>] (sysfs_add_one+0x7c/0x9c)
[    8.615065] [<c016d22c>] (sysfs_add_one+0x7c/0x9c) from [<c016d434>] (create_dir+0x5c/0xac)
[    8.615100] [<c016d434>] (create_dir+0x5c/0xac) from [<c016d724>] (sysfs_create_dir+0x80/0xa0)
[    8.615144] [<c016d724>] (sysfs_create_dir+0x80/0xa0) from [<c02a6128>] (kobject_add_internal+0xc8/0x1fc)
[    8.615186] [<c02a6128>] (kobject_add_internal+0xc8/0x1fc) from [<c02a6488>] (kobject_add+0x68/0x8c)
[    8.615228] [<c02a6488>] (kobject_add+0x68/0x8c) from [<c038c374>] (device_add+0xe0/0x364)
[    8.615269] [<c038c374>] (device_add+0xe0/0x364) from [<c038c688>] (device_create_vargs+0x78/0xbc)
[    8.615307] [<c038c688>] (device_create_vargs+0x78/0xbc) from [<c038c6e8>] (device_create+0x1c/0x24)
[    8.615351] [<c038c6e8>] (device_create+0x1c/0x24) from [<c034ac88>] (misc_register.part.0+0x34/0xa0)
[    8.615409] [<c034ac88>] (misc_register.part.0+0x34/0xa0) from [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot])
[    8.615461] [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot]) from [<c00086a4>] (do_one_initcall+0x34/0xc8)
[    8.615504] [<c00086a4>] (do_one_initcall+0x34/0xc8) from [<c09b2b70>] (do_init_module+0x44/0x15c)
6c  d   8ny6 15t59da] a <wc0e95728>]  (loyoSk_fiinng tfo_rm oGduTe+!x28__>bi]onic_o pe(n_tzSyS_dfinit_atod: clou+0dxn6'ct 0xi94)
  /0x94) from [<c000db00>] (ret_fasSt_artsnga r+e0cxo0v/r0x38)
[ y   8.(61p5620] ---d e1n2d5 )t oac e hefuc J1an  1 4f05:8008:c05d21ae  --1-
 8.615648] ------------[ cut here ]-b-oo--tmode = unkn--------
[ w n
 8.615674] WARNING: at lib/kobject.c:196 kobject_add_internal+0x19c/0x1fc()
[    8.615696] kobject_addrecoveryn teilensayslt feaimled for rtkabande# _s
y==s==_s==t==o==r===a==g=e= ==ith= =-==E=
a[ l  8_s6d15vf1a8]t  /odeuv/esl lionkedckin:m mdcrmlko0otp(1 0Pme nacmk/ in nandthues er am0e d
  [2 / s y s8te6m1 5ex48]4 CP 😕 0 PIDv/ b1 Cocmkm/:r kinain Tain_seds:te mP 0
c    3 /cache ext 4 /  d3.10.10ev#/bl1o
 /[r  n a nd.61_784] [ch<ec0001
blo[ck / r 8.na1n58d2_3u] se<rc0at1a1 80ccox0k//0xken0) fromnd_c0e0t1a1d8actc> ]0(show  _5 /datastext4k+/0x10/0x1e4v)
]   6 /cushow_etatk+ /x10d/0x1ev)/ flocok/ r[k<c0an3df3_20>] (usatrn _0sl
o  w7 p/caustom texth_common+/dxe4v//0xl6o8ck
f320> ] 8  /radi(cal_wapdn_alowte epat4h_/cdoemvm/onlo0xckc/0x/r8k)n frndm_ [r<acd00cf3lc>_ (warda_tslo w0path_fm  9 /mtis+c mtd x2cis/0x3 0)
    10  /8u.6b15o903t  m[<tcd0 0u3fb3bc>]o ot w0ar
_s lo 1w1 p/cahartgeh mtd _fmtc+h0arg2c /00x
c)   12 /rfesrource ommt [d<c02a6 refsc>ur c(keo b0ject_a  d13d_ /ipanramteteerr mnad +0axr1a9me/0exr f0c)
[   14  /b oo t 8mtd b.6o1t5902]
[<  c150 /r2ecaovery m61fc>] (k rbejeccotv_ardyd 0int
r  16 /backup mtdnal+0x19c/0x1fc) from [<c02a6488>] (kobject_add+0x68/0 bxackup 80)
[    8 .61598 1]1 7 </t02us6t 88t>d t(krosjt 0ct_
dd+  018x /68ba/se0paramerx8 mt dfbrosme[par0ame8r374>]0(
 vic e_add+ 0x1e0/0x93 /t)m
                           p ramd[s   8.61a60d17s]k[0<c0
c
te_var (device_adI:dIn0teer/nal3SD_4)O Orom T[<:c038 /c68nt/i] t(erenial__crdea
      gs+0xE7xt/erxbal)SD
                         [R OOT 8:.6160 5/mn [/<ex0t8erna8l_s8>d]
_ead cmdevince
[    8.616093] [<c038c6e8>] (device_create+0x1c/0x24) from [<c034ac88>] (misc_register.part.0+0x34/0xa0)
[    8.616141] [<c034ac88>] (misc_register.part.0+0x34/0xa0) from [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot])
[    8.616189] [<bf0030ac>] (StorageSysDataInit+0xac/0xdc [drmboot]) from [<c00086a4>] (do_one_initcall+0x34/0xc8)
[    8.616229] [<c00086a4>] (do_one_initcall+0x34/0xc8) from [<c09b2b70>] (do_init_module+0x44/0x15c)
[    8.616269] [<c09b2b70>] (do_init_module+0x44/0x15c) from [<c0095728>] (SyS_finit_module+0x6c/0x94)
[    8.616314] [<c0095728>] (SyS_finit_module+0x6c/0x94) from [<c000db00>] (ret_fast_syscall+0x0/0x38)
[    8.616341] ---[ end trace efc14f5808cd21af ]---
[    8.616367] drm init ok
[    8.617108] rk30xxnand_ko: version magic '3.10.0 SMP preempt mod_unload ARMv7 p2v8 ' should be '3.10.104 SMP preempt mod_unload ARMv7 p2v8 '
[    8.617248] init: finit_module for "/rk30xxnand_ko.ko" failed: Exec format errorinit: insmod: open("/rk29-ipp.ko") failed: No such file or directoryinit: (Loading properties from /system/build.prop took 0.00s.)
[    8.618086] init: (Loading properties from /vendor/build.prop took 0.00s.)
[    8.618186] init: (Loading properties from /factory/factory.prop took 0.00s.)
[    8.618589] fs_mgr: Warning: unknown flag resize
[    8.618950] init: /recovery not specified in fstab
[    8.620970] init: Starting service 'recovery'...
[    8.622314] init: Starting service 'adbd'...
[    8.628084] init: Starting service 'console'...
[    8.645887] fs_mgr: Warning: unknown flag resize
[    8.655785] EXT4-fs (rknand_cache): warning: maximal mount count reached, running e2fsck is recommended
[    8.657101] EXT4-fs (rknand_cache): mounted filesystem with ordered data mode. Opts: (null)
[    8.659735] fs_mgr: Warning: unknown flag resize
=== start void dumpCmdArgs(int, char **):235 ===
argv[0] =  /sbin/recovery.
(void setFlashPoint():223) sdcard is /dev/block/mmcblk0.
emmc_point is /dev/block/mmcblk1
locale is [en_US]
stage is []
reason is [(null)]
cannot find/open a drm device: No such file or directory
fb0 reports (possibly inaccurate):
  vi.bits_per_pixel = 16
  vi.red.offset   =  11   .length =   5
  vi.green.offset =   5   .length =   6
  vi.blue.offset  =   0   .length =   5
  fi.line_length = 3840
framebuffer: 0 (1920 x 1080)
[    8.698680] rk322x-lcdc vop0: blank mode:0
[    8.731724] rk322x-lcdc vop0: intr post buf empty!
[    8.731762] rk322x-lcdc vop0: intr post buf empty!
          erasing_text: en_US (45 x 19 @ 600)
[    8.771103] rk322x-lcdc vop0: intr post buf empty!
[    8.771169] rk322x-lcdc vop0: intr post buf empty!
       no_command_text: en_US (82 x 19 @ 600)
            error_text: en_US (33 x 19 @ 600)
[    8.810454] rk322x-lcdc vop0: intr post buf empty!
[    8.810521] rk322x-lcdc vop0: intr post buf empty!
[    8.849817] rk322x-lcdc vop0: intr post buf empty!
[    8.849885] rk322x-lcdc vop0: intr post buf empty!
[    8.889177] rk322x-lcdc vop0: intr post buf empty!
[    8.889255] rk322x-lcdc vop0: intr post buf empty!
       installing_text: en_US (151 x 19 @ 600)
[    9.098879] EXT4-fs (rknand_metadata): warning: maximal mount count reached, running e2fsck is recommended
[    9.099928] EXT4-fs (rknand_metadata): mounted filesystem with ordered data mode. Optbs:o (onultl)m
ode = unknown
Command: "/sbin/recovery"
[    9.100750] type=1400 audit(6.050:7): avc:  denied  { open } for  pid=125 comm="recovery" path="/dev/__properties__/u:object_r:secruroeboot._drolp:ik0." d.eva="tmivpfes" inob=68d36e s0cont
pdarolvpik:.vms.i0sa.a tcmas.=feilter permisfsiuvet1:seecuare7boot_
1da lvi devnieldc  {p gota.ttrh }e hfor d 5pid0=
 dalv5i .vomm.="xr2eoovety-Xmasth6="m/
sdalevck.rebmoohe_pproap:xs0r" deev8="r
mpfs" ino=d6836 saconltiex.tvm.:re:apemiverny:fs0 tcroet=ext12uk:ob
pctd_r:secualrviek.vomt._erapps:s0 trtsisz=ef1ilm
 edarmiik.ivme.ap1pi
                    m    9efo0rm009=] ztype
14d0alvik .udm.us(e.j0t50:r9):oavile: =dtrnuied
                                                 { odaln i} .for.  peadpg1r25w cothl=imrito=192very
texl" ik.vvm".imagempfds" ex2no=t6-X37s s6con                                                      dal"vpka.hm=."stadcvk/__tprrpceet-fesle_=/ud:tbaject_nr/pproaee_p.ropxts
   datlvi=uv:m.:imcagveery:s0ex2oatt-Xxmx==:4omj
dalt_vr:k.pvp.oheaprtop:s0 tcltasts=lfilza piorn=i0ss.iv7e=1
[    9.101065] type=140r0 oa.cdoinf(g6.0en0a:l10):.avrem otdecioetd o { fgaelasttr } for  pid=125 comm="recrovoery" pbuihld".fdiegv/_p_prrpeittieA_n_r/u:idb/rec32_2:px_obo_p/rok3:2sx_ oxev=o"t7.1pf/N"HGi4o7K6/akr7 dsco-t0e80=61:74:0rucsorvere:sbug/ttoenttekxt=su:
 ject_r:pppoepm.depxoopt:.b0o tt=veass=firle ifye-pmiosfilve=1
  p9.101m.dex]optt.peb1-4t00 audispee(-6pr0o0fi11)
cpmavce:o pd.eninsda l { openin}e fpor etp-in=ly25
es__/upm.bjecxo_pt.:cg-sdetx_prop:pt=" peeed=-"rmopifse
p"m.dex opto.=i68s38 -scbontoott=intr:rpereot-ornyl:s0ytc
stmxdt=xu:pobjsecat_redct-gtappk=spreop:
 p m.tdexopc.lnssys=-illib permirs=sivee=1d
pm.d e o9.t0.1o27c5] dt-dpe=exo00t aupdiet(6.0
eni                                           5ro0.rk12s):ca=vkc: 22d
=ro.r5k scosmte"mraeco.vetrableytU"I= pfaalsteh
_prop:rk/.syprtopembtares_vo/u:objicei_c:oc=tsrgts
      s0" drev.=Matsspft"oraigo=68=8 slsoent
 tcrk.hxdtiu_enrabelceove=yr:ue
   ron.rk.flteht_=nu:obbljecettrr:ect
grot._rk.homeop:ase0 bclaasss=e=ilt tp:er/miwsw.gvo=o
gle.com/webhp?client={CID}&amp;source=android-home
ro.rk.def_brightness=200
ro.rk.screenoff_time=2147483647
ro.rk.screenshot_enable=true
ro.rk.LowBatteryBrightness=true
ro.rk.install_non_market_apps=false
ro.sf.hwrotation=0
ro.sf.lcd_density=240
ro.sf.fakerotation=false
ro.sf.lcdc_composer=0
ro.adb.secure=0
ro.com.google.gmsversion=7.1_r9
ro.com.android.dataroaming=true
ro.com.widevine.cachesize=16777216
ro.boot.noril=true
ro.boot.console=ttyFIQ0
ro.boot.selinux=permissive
ro.boot.hardware=rk30board
ro.hdmi.device_type=4
ro.hwui.path_cache_size=32
ro.hwui.layer_cache_size=48
ro.hwui.texture_cache_size=72
ro.hwui.disable_scissor_opt=true
ro.hwui.gradient_cache_size=1
ro.hwui.r_buffer_cache_size=8
ro.hwui.drop_shadow_cache_size=6
ro.hwui.text_large_cache_width=2048
ro.hwui.text_small_cache_width=1024
ro.hwui.text_large_cache_height=1024
ro.hwui.text_small_cache_height=1024
ro.hwui.texture_cache_flushrate=0.4
ro.wifi.channels=
ro.allow.mock.location=0
ro.audio.monitorOrientation=true
ro.board.platform=rk322x
ro.build.id=NHG47K
ro.build.date=2018▒?08▒?06▒?星期一 17:40:06 CST
ro.build.date.utc=1533548406
ro.build.host=aike5
ro.build.tags=test-keys
ro.build.type=userdebug
ro.build.user=akrd-52
ro.build.flavor=rk322x_box-userdebug
ro.build.display.id=MXQ-4K eng.akrd-52.20180806.174006
ro.build.product=rk322x_box
ro.build.version.sdk=25
ro.build.version.base_os=
ro.build.version.release=7.1.2
ro.build.version.codename=REL
ro.build.version.incremental=eng.akrd-52.20180806.174006
ro.build.version.preview_sdk=0
ro.build.version.all_codenames=REL
ro.build.version.security_patch=2017-04-05
ro.build.description=rk322x_box-userdebug 7.1.2 NHG47K eng.akrd-52.20180806.174006 test-keys
ro.build.characteristics=box
ro.media.maxmem=2147483648
ro.rksdk.version=RK30_ANDROID7.1.2-SDK-v1.00.00
ro.udisk.visible=true
ro.secure=1
ro.target.product=box
ro.tether.denied=false
ro.zygote=zygote32
ro.carrier=unknown
ro.default.size=100
ro.factory.tool=0
ro.factory.hasGPS=false
ro.factory.hasUMS=false
ro.factory.without_battery=false
ro.factory.storage_suppntfs=true
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.cpu.abilist=armeabi-v7a,armeabi
ro.product.cpu.abilist32=armeabi-v7a,armeabi
ro.product.cpu.abilist64=
ro.product.name=rk322x_box
ro.product.board=rk30sdk
ro.product.brand=Android
ro.product.model=MXQPRO
ro.product.device=rk322x_box
ro.product.usbfactory=rockchip_usb
ro.product.manufacturer=rockchip
ro.product.first_api_level=23
ro.support.lossless.bitstream=true
ro.baseband=unknown
ro.bootmode=unknown
ro.hardware=rk30board
ro.opengles.version=196609
ro.revision=0
ro.safemode.disabled=true
ro.bootimage.build.date=2018▒?08▒?06▒?星期一 17:40:06 CST
ro.bootimage.build.date.utc=1533548406
ro.bootimage.build.fingerprint=Android/rk322x_box/rk322x_box:7.1.2/NHG47K/akrd-508061740:userdebug/test-keys
ro.bootloader=unknown
ro.debuggable=1
ro.setupwizard.mode=OPTIONAL
ro.setupwizard.require_network=any
ro.enable_boot_charger_mode=0
sf.power.control=8847360
init.svc.adbd=running
init.svc.console=running
init.svc.healthd=running
init.svc.ueventd=running
init.svc.recovery=running
rild.libargs=-d /dev/ttyACM0
rild.libpath=/system/lib64/libril-rk29-dataonly.so
wifi.interface=wlan0
wifi.supplicant_scan_interval=15
camera2.portability.force_api=1
persist.tegra.nvmmlite=1
persist.enable.3g.dongle=true
testing.mediascanner.skiplist=/mnt/shell/emulated/Android/
keyguard.no_require_sim=true
ExternalSD_ROOT=/mnt/external_sd
InternalSD_ROOT=/mnt/internal_sd
UserVolumeLabel=RockChip
security.perf_harden=1
debug.nfc.se=false
debug.nfc.fw_download=false
debug.hwui.render_dirty_regions=false
debug.atrace.tags.enableflags=0
net.bt.name=Android
net.change=net.bt.name
sys.hwc.enable=1
sys.hwc.compose_policy=6
sys.usb.controller=fe800000.dwc3
sys.rkadb.root=0
sys.status.hidebar_enable=false
sys.wallpaper.rgb565=0
sys.resolution.changed=false
persist.sys.ui.hw=true
persist.sys.usb.config=mtp,adb
persist.sys.boot.check=false
persist.sys.media.avsync=true
persist.sys.dalvik.vm.lib.2=libart.so
persist.sys.country=PT
persist.sys.language=pt
persist.sys.timezone=
persist.sys.strictmode.visual=false
ro.ril.ecclist=112,911
ril.function.dataonly=1
sys.usb.config=adb
sys.usb.configfs=1
Supported API: 3
I:Saving locale "en_US"
[    9.122706] fs_mgr: Warning: unknown flag resize
Join led thread error!
[   13.614118] vop_isr: 285 callbacks suppressed
[   13.614193] rk322x-lcdc vop0: intr post buf empty!
[   13.614243] rk322x-lcdc vop0: intr post buf empty!
[   13.653464] rk322x-lcdc vop0: intr post buf empty!
[   13.653533] rk322x-lcdc vop0: intr post buf empty!
[   13.692821] rk322x-lcdc vop0: intr post buf empty!
[   13.692896] rk322x-lcdc vop0: intr post buf empty!
[   13.732183] rk322x-lcdc vop0: intr post buf empty!
[   13.732250] rk322x-lcdc vop0: intr post buf empty!
[   13.771542] rk322x-lcdc vop0: intr post buf empty!
[   13.771609] rk322x-lcdc vop0: intr post buf empty!
[   14.399515] [otg id chg] last id -1 current id 2
[   18.573462] vop_isr: 281 callbacks suppressed
[   18.573520] rk322x-lcdc vop0: intr post buf empty!
[   18.573574] rk322x-lcdc vop0: intr post buf empty!
[   18.610020] read descriptors
[   18.610128] read descriptors
[   18.610169] read strings
[   18.610284] pcd_pullup, is_on 1
[   18.612861] rk322x-lcdc vop0: intr post buf empty!
[   18.614549] init: write_file: Unable to write to '/config/usb_gadget/g1/UDC': No such device
[   18.652207] rk322x-lcdc vop0: intr post buf empty!
[   18.652303] rk322x-lcdc vop0: intr post buf empty!
[   18.691543] rk322x-lcdc vop0: intr post buf empty!
[   18.691617] rk322x-lcdc vop0: intr post buf empty!
[   18.730900] rk322x-lcdc vop0: intr post buf empty!
[   18.730971] rk322x-lcdc vop0: intr post buf empty!
[   18.770261] rk322x-lcdc vop0: intr post buf empty!
[   23.532823] vop_isr: 277 callbacks suppressed
[   23.532885] rk322x-lcdc vop0: intr post buf empty!
[   23.532942] rk322x-lcdc vop0: intr post buf empty!
[   23.572183] rk322x-lcdc vop0: intr post buf empty!
[   23.572253] rk322x-lcdc vop0: intr post buf empty!
[   23.611538] rk322x-lcdc vop0: intr post buf empty!
[   23.611605] rk322x-lcdc vop0: intr post buf empty!
[   23.650903] rk322x-lcdc vop0: intr post buf empty!
[   23.650970] rk322x-lcdc vop0: intr post buf empty!
[   23.690264] rk322x-lcdc vop0: intr post buf empty!
[   23.690331] rk322x-lcdc vop0: intr post buf empty!
[   28.492185] vop_isr: 268 callbacks suppressed
[   28.492244] rk322x-lcdc vop0: intr post buf empty!
[   28.492297] rk322x-lcdc vop0: intr post buf empty!
[   28.531544] rk322x-lcdc vop0: intr post buf empty!
[   28.531612] rk322x-lcdc vop0: intr post buf empty!
[   28.570905] rk322x-lcdc vop0: intr post buf empty!
[   28.570973] rk322x-lcdc vop0: intr post buf empty!
[   28.610263] rk322x-lcdc vop0: intr post buf empty!
[   28.610330] rk322x-lcdc vop0: intr post buf empty!
[   28.649619] rk322x-lcdc vop0: intr post buf empty!
[   28.649689] rk322x-lcdc vop0: intr post buf empty!
[   33.451540] vop_isr: 274 callbacks suppressed
[   33.451597] rk322x-lcdc vop0: intr post buf empty!
[   33.451648] rk322x-lcdc vop0: intr post buf empty!
[   33.490902] rk322x-lcdc vop0: intr post buf empty!
[   33.490973] rk322x-lcdc vop0: intr post buf empty!
[   33.530264] rk322x-lcdc vop0: intr post buf empty!
[   33.530331] rk322x-lcdc vop0: intr post buf empty!
[   33.569619] rk322x-lcdc vop0: intr post buf empty!
[   33.569692] rk322x-lcdc vop0: intr post buf empty!
[   33.608983] rk322x-lcdc vop0: intr post buf empty!
[   33.609050] rk322x-lcdc vop0: intr post buf empty!
[   38.410904] vop_isr: 281 callbacks suppressed
[   38.410961] rk322x-lcdc vop0: intr post buf empty!
[   38.411016] rk322x-lcdc vop0: intr post buf empty!
[   38.450262] rk322x-lcdc vop0: intr post buf empty!
[   38.450331] rk322x-lcdc vop0: intr post buf empty!
[   38.489619] rk322x-lcdc vop0: intr post buf empty!
[   38.489691] rk322x-lcdc vop0: intr post buf empty!
[   38.528982] rk322x-lcdc vop0: intr post buf empty!
[   38.529052] rk322x-lcdc vop0: intr post buf empty!
[   38.568343] rk322x-lcdc vop0: intr post buf empty!
[   38.568410] rk322x-lcdc vop0: intr post buf empty!
[   43.370262] vop_isr: 280 callbacks suppressed
[   43.370318] rk322x-lcdc vop0: intr post buf empty!
[   43.370370] rk322x-lcdc vop0: intr post buf empty!
[   43.409619] rk322x-lcdc vop0: intr post buf empty!
[   43.409691] rk322x-lcdc vop0: intr post buf empty!
[   43.448982] rk322x-lcdc vop0: intr post buf empty!
[   43.449051] rk322x-lcdc vop0: intr post buf empty!
[   43.488343] rk322x-lcdc vop0: intr post buf empty!
[   43.488411] rk322x-lcdc vop0: intr post buf empty!
[   43.527698] rk322x-lcdc vop0: intr post buf empty!
where is the problem?
Edited by n3o
insert into spoliler section
Posted (edited)
Ok guys, Hi.
So I have managed to connect box Q96MAX 4k Ultra HD, board MXQ_R2B_LP3_V2.62_220225 via maskrom mode, made EMMC backup, erased it.
btw thanks @MattWestB for your photos of  pins https://github.com/MattWestb/R29-MXQ-LP3-V2.3-00908
Anyway,
Box boots armbian legacy from SD card, I have managed to connect to it via SSH, device specs.
Detected board features:                                                             │
                                                           │ Chip type: RK3228A/B - Serial: URKW46025 00000000032b0c                              │
                                                           │ CPU Leakage: 0x04 - Logic Leakage: 0x04                                              │
                                                           │ Internal flash: eMMC        │
                                                           │ Wifi device: unknown - Device ID: 02d0:4334
EDIT2:
installed RDP client, can connect to device via RDP...HDMI NO Output
ok so thanks to this post https://github.com/MattWestb/R29-MXQ-LP3-V2.3-00908/blob/main/README.md  armbian parameters set to emmc-hs200, ddr3-660 and led-config2, led started to work.
@MattWestB can you please comment how you fixed your box HDMI and wifi?:)
EDIT:
ok so ARMBIAN non legacy boots too, but same problems with WIFI and HDMI no video.
dmesg gives a lot of errors
[    0.003538] CPU: Testing write buffer coherency: ok
[    0.004292] /cpus/cpu@f00 missing clock-frequency property
[    0.004358] /cpus/cpu@f01 missing clock-frequency property
[    0.004391] /cpus/cpu@f02 missing clock-frequency property
[    0.004424] /cpus/cpu@f03 missing clock-frequency property
[    0.004446] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    2.029717] inno-hdmi-phy 12030000.hdmi-phy: error -ENXIO: IRQ index 0 not found
[    2.030102] inno-hdmi-phy 12030000.hdmi-phy: phy_flag is: 0
[    2.033084] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb127c87c)
[    2.033274] dwhdmi-rockchip 200a0000.hdmi: supply avdd-0v9 not found, using dummy regulator
[    2.033657] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    2.033677] dwhdmi-rockchip 200a0000.hdmi: supply avdd-1v8 not found, using dummy regulator
[    2.034239] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy2)
[    2.035607] mmc2: new high speed MMC card at address 0001
[    2.035736] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.037470] mmcblk2: mmc2:0001 Q2J95T 7.28 GiB
[    2.039082] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb1280568)
[    3.603319] rockchip-pinctrl pinctrl: unable to find group for node reset-key
[   15.966192] brcmfmac: brcmf_fw_alloc_request: Unknown chip BCM43342/0
[   16.859644] systemd[1]: Starting Armbian memory supported logging...
[   17.040253] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[   17.091210] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   17.099828] brcmfmac: brcmf_ops_sdio_probe: F2 error, probe failed -19...
[   17.144754] systemd[1]: Finished Raise network interfaces.
[   45.622143] hdmi-audio-codec hdmi-audio-codec.2.auto: Only one simultaneous stream supported!
[   45.652339] hdmi-audio-codec hdmi-audio-codec.2.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22
[   45.676365]  100c0000.i2s0-i2s-hifi: ASoC: error at __soc_pcm_open on 100c0000.i2s0-i2s-hifi: -22
 i attach log here pls help with wifi/hdmi :)
dmesg.log
Edited by sadp
@sadp Your wifi chip is not supported by the brcmfmac driver; there is a patch for rockchip64 family but not for rk322x.
I will make a Pull Request to add the patch for rk322x but have to be patient, wait a couple of weeks and it will be probably available for edge 6.4 kernel. You are on current 6.1 right now, so perhaps you may want to switch when the new kernel will be available.
About the missing HDMI, it is a known problem for all R29 boards; @Hudson FAS gently offered to send me a board of such kind for me to inspect and try to fix the issue, so patience here too.
5 hours ago, n3o said:
done... what can You tell me about the issue?
Actually I don't remember your issue (the last post was 3 months ago), but I see @RaptorSDS was already in contact with you.
device no more boot and load into recovery mode
vor 18 Stunden schrieb n3o:
looks like android has many false setting or broke
ok, I want install armbian but also multiboot doesn't worked very well... what step I should do? I think that is unuseful make a backup of a Android system damaged, so how I can make the bootloader upgrade described here https://forum.armbian.com/topic/12656-csc-armbian-for-rk322x-tv-boxes/?do=findComment&comment=121103 ?
2. For the bootloader file, I have a file named rk322x_loader_v1.10.256.bin but I don't remember where I have download it, can You tell me if I should download the updated file from here https://github.com/ilmich/rkflashtool/tree/master/bin ? and what file ?
3. After this, in first post isn't explained difference between images here https://imola.armbian.com/dl/rk322x-box/archive/ , so what is the difference between bookworm and jammy? and what are the differences between <<standard (without nothing added)>>, xfce, minimal and wm?
It's explained only current, edge and legacy
vor 30 Minuten schrieb n3o:
but now you can see why it is not work , and also interact with armbian without HDMI if HDMI doesnt work
@n3o
Quote
migh tI ask you how much skill have you not only on linux but in general on pc's ?
Quote
What EXACTLY you mean by this ?
Posted (edited)
Hi,
got the same board as
TV box different brand:
MXQ PRO 4K 5G
Bought recently, so probably all got the same board ;)
MultiTool works fine, can flash and erase via SSH
Problem is that no image for rk322x box works, no working HDMI.
Only when I boot it with LAN plugged in - yellow Led blinks - but no IP is assigned.
Edit:
Or it does work but there is no SSH enabled in armbian ?
I dont rly need HDMI and GPU at all, just wonna reach ssh :(
it doesnt get IP from DHCP ...
dmesg.multitool.log
Edited by ego worker
how can I make this? In putty the last lines automatically appear, it's not SSH. What should I do ? Can You tell me from the log posted what bootloader file flash?
I'm a java developer, sadly not always it's possible found a complete course from A to Z (for example, in linux, a course that cover vmlinuz, disk partition, boot (bios and uefi), virtual machine, dsa network config, ecc ecc) ... so I have fragmentated concepts ... to this add that I'm not a system administrator so it's easy forgotten also the basis. In electronic instead I don't know nothing (this is related to the UART problem).
2 hours ago, RaptorSDS said:
bookworm is Debian 12
jammy is Ubuntu 22.04
what do You recommend me? and what about <<standard (without nothing added)>>, xfce, minimal and wm ?
vor 2 Minuten schrieb n3o:
it's not SSH
its better its a serial console , you can interact with linux over tty Serial connect (you have with this now with UART) , when multitool is running like in a ssh session
ssh is a forwarde serial console over ip (more or less)
when you run headless ( without gui) linux do the same a serial console is than also forwarde to HDMI (more or less)
vor 5 Minuten schrieb n3o:
both have same source , both use same tools and programm
Debian has philosophy "no close source" but your are able to install them when need
Ubuntu is from start with close source software but that makes its sometime bigger and more complex
both can use xcfe and other gui  ( some of the image files already have xfce active) , when you only need server go with minimal
so I should just insert microsd with multitool and I can start procedure of @jock ? What bootloader file should I load?
in the first post, at section "Quick installation instructions on NAND" at point 2 is written "Burn the Multitool on an SD card; once done, place the Armbian legacy kernel image in images folder of the SD card FAT partition"... it's possible use only legacy kernel?
ok, I'll try bookworm
Posted (edited)
Ok, I have atached to UART, and looks like armbian boots
but no HDMI, no IP from LAN
edit: Ok Lan and SSH started to work after first login ;) nice
any solution for not working HDMI ?
edit2:
Legacy 4.4 works (noHDMI),
mainline doesnt, kernel panic (currentkernel.txt)
Booting Linux.txt
CurrentKernel.txt
@RaptorSDS can You help me?
vor 29 Minuten schrieb n3o:
i can not hep by flash any other bootloader or make nand work with newer kernel ,  i dont understand why only kernel that make no sense , flash legay armbian and go on with the box , else put legacy image on the box and than show the log
we can look why maybe the box dont boot full to armbian
you can save also android because maybe we need dts/dtb or anything else and extract it out of image file
What do You mean for "i dont understand why only kernel that make no sense" ?
here https://imola.armbian.com/dl/rk322x-box/archive/ there are only current version, so where are the legacy images?
actually the box don't boot to stock android and I'm searching what image load
you mean load android image? what are dts/dtb ?
please guys dont mix topix
thanks @ego worker for post link
@n3o
vor 19 Stunden schrieb n3o:
that  why i was wonder , kernel is a part of linux but  some  like Android sometime have that as a seperate partion or like rasberry you can update kernel only
also you talk about bootloader upgrade and i am was confuse about what you want and your knowloge about flashing this box with linux
vor 1 Stunde schrieb n3o:
no save android
dts/dtb are config file for kernel--> tell kernel where to look at for lan or wich memory or clock to use for hdmi and so on
i thinks easy step are on page 1 when your box is nand than follow the step with a legacy armbian image and have fun with this box
@sadp I using my box headless and by not connecting the HDMI its not running so warm (i doing the same with my RK3318 box that is having HDMI working OK last time i was looking) and i using local comport for the initial config and then SSH so no need for desktop for my.
Also i running Zigbee and Thred RCP and WiFi is only making problems so i only using Eth for not getting interference with my 802.15.4 mesh networks.
Only real problems beside the box is very easy running hot is that the USB implementation is nerving if one device is having problems and the system is disconnecting it the system must being repowered for the system finding it and its the same for the RK3318 box so its one RK thing that is not working very well.
My firs problem was that the box was not liking the bootloader but i was finding one working one and flashing it to the eMCC and after that i have no problem installing armbian on the internal storage and can booting SD and USB storage for testing other armbian builds so its very good only the box is only having 8G internal flash so i have mounting the SD-card as docker data so HA supervised have enough storage for installing and working OK.
On 8/4/2023 at 6:31 PM, ego worker said:
https://armbian.hosthatch.com/archive/rk322x-box/archive/ here are legacy
c.d.
I have extracted 4 dtb files, 3 looks fine, all references to rk3229, none is able to run Multitool ;(
so, it's impossible update bootloader?
I want install the most recent image of armbian with gui (so I don't want android) and in first post is written that it's necessary update bootloader "For fearless and bold people who are having issues when (re)booting images, there is the chance to upgrade the bootloader on NAND".
So I prefer update bootloader and after that install the most recent image. For the bootloader I should use one of the 2 files here https://github.com/ilmich/rkflashtool/tree/master/bin but now reading the steps on the first post I have discovered that only legacy armbian image can be used. Now, the new question is: what is the difference between bullseye and jammy? Jammy isn't available with gui?
I'm not very expert about linux and flashing, I know only that bootloader is such a bios ...
no save android
ok, where I can find this file (and how to reach destination if android no more boot)? What is the path? When I install the armbian image to make restore I have just copy and paste the files?
Posted (edited)
vor 16 Stunden schrieb n3o:
Yes correct --> NAND install = legacy armbian
but you can boot latest Armbian from SD card or USB and ignore NAND complete
Bootloader update only possible with male - male USB cable and rktool outside of the box
there are 3 bootloader
1. open ones ,  SD-Card , USB and NAND boot allow , boot SD-CARD/USB also if there a OS in NAND or install Armbian legacy to nand
2. open ones  , SD-Card USB Boot  NAND boot allow but boot NAND first , there you can try the new point in Multitool "Jump start " that always redirect boot to SD-Card   or install Armbian legacy to nand
3 close ones (rare ones), that the ones with probleme where you have to update bootloader
Please !!! do the simple steps first , simple install legacy to nand and try it --> flash multitool on SD-card , put image file in the folder , start multitool , save android , clean nand and install(flash) armbian to nand
or flash image file on sd-card and boot armbian legacy or  newest
we do need them only when all other failed  , RK322x have some already inside armbian , many work with many diffirent setups and hardware already no need to do 10 step ahead
please simple first !!!!
please dont do this 10 steps ahead , i only want to say make a backup of android its good to have one also if corrupt .
Edited by RaptorSDS
Hello, I'm trying to install Armbian on "T9 Android 9.0 TV Box DDR3 RAM 32GB ROM RK3318": https://www.amazon.com/gp/product/B07GPCJSRR/
Tried booting from SD card using Armbian_23.5.1_Rk3318-box_jammy_current_6.1.30_minimal.img.xz (SHA 24ad44c3402b7f38c45a20d8abd2e69a3486e89108730481b066e3978e962e9f) and Armbian_23.5.1_Rk3318-box_jammy_current_6.1.30.img.xz (SHA f4d066a65f7483d7afb41c4b16899abdb9dda1d30c3f30eb67806e734f7a482c). Boot log from Armbian_23.5.1_Rk3318-box_jammy_current_6.1.30.img.xz:
Spoiler
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2023.08.06 09:46:24 =~=~=~=~=~=~=~=~=~=~=~=
�DDR version 1.15 20190428
In
DDR3
333MHz
Bus Width=32 Col=11 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=4096MB
ddrconfig:3
OUT
Boot1 Release Time: Sep 7 2018 15:49:55, version: 2.49
ChipType = 0x11, 193
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=29820MB
FwPartOffset=2000 , 2000
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29819MB
FwPartOffset=2000 , 0
StorageInit ok = 56900
Raw SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit ret = 0, SecureMode = 0
GPT 0x337a9e0 signature is wrong
LoadTrust Addr:0x4000
LoadTrust Addr:0x4400
LoadTrust Addr:0x4800
LoadTrust Addr:0x4c00
LoadTrust Addr:0x5000
LoadTrust Addr:0x5400
LoadTrust Addr:0x5800
LoadTrust Addr:0x5c00
Addr:0x4000 No find trust.img!
LoadTrustBL error:-3
Raw SecureMode = 0
GPT part: 0, name: uboot, start:0x4000, size:0x2000
GPT part: 1, name: trust, start:0x6000, size:0x2000
GPT part: 2, name: misc, start:0x8000, size:0x2000
GPT part: 3, name: baseparameter, start:0xa000, size:0x800
GPT part: 4, name: resource, start:0xa800, size:0x8000
GPT part: 5, name: kernel, start:0x12800, size:0x10000
GPT part: 6, name: dtb, start:0x22800, size:0x2000
GPT part: 7, name: dtbo, start:0x24800, size:0x2000
GPT part: 8, name: logo, start:0x26800, size:0x8000
GPT part: 9, name: vbmeta, start:0x2e800, size:0x800
GPT part: 10, name: boot, start:0x2f000, size:0x10000
GPT part: 11, name: recovery, start:0x3f000, size:0x20000
GPT part: 12, name: backup, start:0x5f000, size:0x8000
GPT part: 13, name: cache, start:0x67000, size:0x80000
GPT part: 14, name: system, start:0xe7000, size:0x400000
GPT part: 15, name: metadata, start:0x4e7000, size:0x8000
GPT part: 16, name: vendor, start:0x4ef000, size:0x60000
GPT part: 17, name: oem, start:0x54f000, size:0x320000
GPT part: 18, name: frp, start:0x86f000, size:0x400
GPT part: 19, name: security, start:0x86f400, size:0x1000
GPT part: 20, name: userdata, start:0x870400, size:0x31cdbdf
find partition:uboot OK. first_lba:0x4000.
find partition:trust OK. first_lba:0x6000.
LoadTrust Addr:0x6000
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xc1d10
RunBL31 0x10000
NOTICE: BL31: v1.3(release):0e7a845e
NOTICE: BL31: Built : 16:24:22, Apr 29 2019
NOTICE: BL31:Rockchip release version: v1.3
INFO: ARM GICv2 driver initialized
INFO: Using opteed sec cpu_context!
INFO: boot cpu mask: 1
INFO: plat_rockchip_pmu_init: pd status 0xe
INFO: BL31: Initializing runtime services
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-194-g646eecc5 #61 Wed Dec 5 06:31:51 UTC 2018 aarch64)
INF [0x0] TEE-CORE:init_primary_helper:338: Release version: 1.4
INF [0x0] TEE-CORE:init_teecore:83: teecore inits done
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-02229-g9061290-dirty (Mar 24 2022 - 15:41:05 +0800)
PreSerial: 2
DRAM: 4 GiB
Relocation Offset is: fcc04000
Using default environment
rksdmmc@ff500000: 1, rksdmmc@ff520000: 0
Buswidth = 1, clock: 0
Buswidth = 1, clock: 400000
Sending CMD0
Sending CMD8
Sending CMD55
Sending CMD41
Sending CMD55
Sending CMD41
Sending CMD2
Sending CMD3
Sending CMD9
Sending CMD7
Sending CMD55
Sending CMD51
Sending CMD6
Sending CMD6
Sending CMD55
Sending CMD6
Buswidth = 4, clock: 400000
Sending CMD55
Sending CMD13
Buswidth = 4, clock: 50000000
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
RKPARM: Invalid parameter part table
switch to partitions #0, OK
mmc1 is current device
Sending CMD16
Sending CMD18
Sending CMD12
do_rkimg_test found IDB in SDcard
Boot from SDcard
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
get part misc fail -1
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
init_resource_list: failed to get boot part, ret=-1
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
init_resource_list: failed to get resource part, ret=-1
DTB: rk-kernel.dtb
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Can't find file:rk-kernel.dtb
init_kernel_dtb dtb in resource read fail
In: serial
Out: serial
Err: serial
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD16
Sending CMD18
Sending CMD12
CLK: apll 400000000 Hz
dpll 664000000 Hz
cpll 1200000000 Hz
gpll 491009999 Hz
npll 600000000 Hz
armclk 600000000 Hz
aclk_bus 150000000 Hz
hclk_bus 75000000 Hz
pclk_bus 75000000 Hz
aclk_peri 150000000 Hz
hclk_peri 75000000 Hz
pclk_peri 75000000 Hz
Net: Net Initialization Skipped
No ethernet found.
Hit any key to stop autoboot: 0
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
android_bootloader_boot_flow Could not find misc partition
MMC: block number 0xecdfe6b2 exceeds max(0x3a3d800)
failed to read ca head from misc
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
ANDROID: reboot reason: "(none)"
get share memory, arg0=0x0 arg1=0x9e08000 arg2=0x3f8000 arg3=0x1
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Could not find security partition
rkss_read_patition_tables fail ! ret: -1.Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
rkss_read_patition_tables fail ! ret: -1.ERR [0x0] TEE-CORE:ree_fs_open:1488: tee file not exists
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
rkss_read_patition_tables fail ! ret: -1.tee_fs_open : error. A54E481B8B69424182B83ACF16E99E2A/.01000000/lock_state/meta.0ERR [0x0] TEE-CORE:create_tee_file:1420: Failed to create new meta file
ERR [0x0] TEE-CORE:ree_fs_open:1497: Failed to open TEE file
lib/avb/libavb_user/avb_ops_user.c: init lock state error
Error determining whether device is unlocked.
read_is_device_unlocked() ops returned that device is UNLOCKED
Sending CMD16
Sending CMD17
Sending CMD16
Sending CMD18
Sending CMD12
Could not find "misc" partition
avb_ab_flow.c:99: ERROR: Error reading A/B metadata.
avb_ab_flow.c:178: ERROR: I/O error while loading A/B metadata.
Can not load metadata
Android boot failed, error -1.
AVB boot failed and enter rockusb or fastboot!
RKUSB: LUN 0, dev 1, hwpart 0, sector 0x0, count 0x3a3d800
Multitool boots successfully though (multitool.img.xz SHA a4f369fa06076212d6f46c10355c6163f147c70b19abf4e36ea7cf3363d01467), multitool boot log:
Spoiler
In
DDR3
333MHz
ddrconfig:3
OUT
mmc2:cmd19,100
SdmmcInit=2 0
BootCapSize=2000
UserCapSize=29820MB
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=29819MB
StorageInit ok = 61762
Raw SecureMode = 0
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xacc6c
RunBL31 0x10000
NOTICE: BL31: v1.3(release):f947c7e
NOTICE: BL31: Built : 10:31:25, Nov 1 2020
NOTICE: BL31: initializing secure efuse
NOTICE: BL31: initializing non-secure efuse
NOTICE: BL31: enabling efuse clock
U-Boot 2021.07-armbian (Nov 13 2021 - 11:25:20 +0000)
Model: Rockchip RK3318 BOX
DRAM: 4 GiB
MMC: mmc@ff500000: 1, mmc@ff520000: 0, dwmmc@ff5f0000: 3
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial@ff130000
Out: serial@ff130000
Err: serial@ff130000
Net: eth1: ethernet@ff550000
Scanning mmc 1:2...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
169 bytes read in 7 ms (23.4 KiB/s)
1: Multitool
Retrieving file: /kernel.img
15949832 bytes read in 697 ms (21.8 MiB/s)
append: boot=UUID=E2B5-C028 root=PARTUUID=7379cc53-03 rootwait console=ttyS2,115200 verbose=1 consoleblank=0
Retrieving file: /rk3318-box.dtb
71886 bytes read in 8 ms (8.6 MiB/s)
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
ERROR: reserving fdt memory region failed (addr=0 size=0)
Using Device Tree in place at 0000000001f00000, end 0000000001f148cd
Starting kernel ...
Is booting from SD card not supported? Do I need to write the image to eMMC?
Thanks in advance for any pointers!
