Virgilio Junior Posted Tuesday at 07:42 PM Posted Tuesday at 07:42 PM Quote Now I run MultiTool, select "Jump Start," and shut down the rk322x. I burn my Armbian .img to the USB stick with: sudo dd if=/root/Armbian_24.2.5_Rk322x-box_bookworm_current_6.6.22_minimal.img of=/dev/sdb conv=fsync bs=4M status=progress But when I turn on the power, the blue LED shows init (the same as with MultiTool), but the video doesn't appear again hahahha I took my pendrive out of the OTG port and put it in the normal USB, surprise: Tkys Team ❤️ 0 Quote
Igor Posted Tuesday at 08:15 PM Posted Tuesday at 08:15 PM 22 hours ago, jock said: I see users.armbian.com is serving the certificate for stpete-mirror.armbian.com I had to rebuild server and this was not fixed yet. Temporally location https://stpete-mirror.armbian.com/users.armbian.com/ 0 Quote
jock Posted Tuesday at 09:35 PM Author Posted Tuesday at 09:35 PM 1 hour ago, Igor said: I had to rebuild server and this was not fixed yet. Temporally location https://stpete-mirror.armbian.com/users.armbian.com/ Thanks! For @Victor Picinin the temporary working URl is https://stpete-mirror.armbian.com/users.armbian.com/jock/web/rk322x/armbian/beta/Armbian-unofficial_24.11.0-trunk_Rk322x-box_noble_current_6.6.56_xfce_desktop.img.xz 0 Quote
Aroldo Bossoni Posted 8 hours ago Posted 8 hours ago (edited) Is the repository https://users.armbian.com/jock/web/rk322x/ also offline for you? No need to authorize this post, I've already found the answer, thank you! Edited 6 hours ago by Aroldo Bossoni 0 Quote
Aroldo Bossoni Posted 5 hours ago Posted 5 hours ago Hello everyone! I'm willing to develop a script that automates firmware, u-boot, and ROM compatibility testing with the boards via OTG. I've thought of a workflow something like this: 1. Download a list of files by type from several different sources. 2. Extract files from pre-built images, ROM, loader, u-boot. 3. Check for duplicate files by size and checksum. 4. Apply and test in stages: ROM, loader, u-boot, kernel, rootfs, network, video. 5. Log what worked and what went wrong. 6. Since this process can take hours, emit a beep when user interaction is needed. What I need help with from you: Is this idea feasible? Will it produce results and facilitate the implementation process on rk322X boards? Can it be reused and adapted for other boards? I have little experience with ROMs and ARM firmware, but if it's feasible, I intend to create a public repository for the community to help me with the development. Thank you for your attention! 0 Quote
