Quote
Now I run MultiTool, select "Jump Start," and shut down the rk322x.
I burn my Armbian .img to the USB stick with: sudo dd if=/root/Armbian_24.2.5_Rk322x-box_bookworm_current_6.6.22_minimal.img of=/dev/sdb conv=fsync bs=4M status=progress
But when I turn on the power, the blue LED shows init (the same as with MultiTool), but the video doesn't appear again
hahahha  I took my pendrive out of the OTG port and put it in the normal USB, surprise:
Tkys Team ❤️
Hello everyone!
I'm willing to develop a script that automates firmware, u-boot, and ROM compatibility testing with the boards via OTG.
I've thought of a workflow something like this:
1. Download a list of files by type from several different sources.
2. Extract files from pre-built images, ROM, loader, u-boot.
3. Check for duplicate files by size and checksum.
4. Apply and test in stages: ROM, loader, u-boot, kernel, rootfs, network, video.
5. Log what worked and what went wrong.
6. Since this process can take hours, emit a beep when user interaction is needed.
What I need help with from you:
Is this idea feasible?
Will it produce results and facilitate the implementation process on rk322X boards?
Can it be reused and adapted for other boards?
I have little experience with ROMs and ARM firmware, but if it's feasible, I intend to create a public repository for the community to help me with the development.
Thank you for your attention!
I would love to get this or support with the devices I own.
I think we should continue developing Mini-AndroidTV-PCs as easy as possible and give that junk devices a sensful feasible life.😃
@Aroldo Bossoni
The optimal would be understanding the reason why the watchdog triggers, but could be a difficult task without a hint because of the closed source proprietary trust os.
The easiest thing is to provide armbian images with the opensource trust os rather than the proprietary, which is totally feasible because it just requires to swap a file in the armbian build scripts. That would blow the issue away, but unfortunately the proprietary trust os provided DDR scaling and virtual poweroff. The latter is a seldom used feature, but the DDR scaling provided a dramatic improvement in performance and it is hard to give up on that.
Swapping the things at runtime is not savvy: when u-boot updates, the proprietary trust os will be reinstalled overwriting whatever you put in there.
I would be happy with opensource Trust OS and no runtime DDR scaling, but stil having it at a fixed decent rate (660MHz, instead of the default 330MHz), but some boards do not boot at all when they are instructed to boot at 660MHz.
@jock
I didn't know the problem could be the watchdog, nor did I know about the existence of the open-source Trust OS.
Do you think it's feasible to include the open-source Trust OS in this testing process, or does the open-source Trust OS solve all these problems?
My idea wasn't to change it at runtime; my idea is to flash, reboot, test, save the result, repeatedly until all possible combinations are exhausted.
Hello, idk if this the right place to ask, but, I'm really struggling to get a working driver for the sv6256p, I can't find a repository that compiles on kernel 6.X. My question is, where is the driver source that builds for the rk322x uses? I want to compile it on my installation. I already tried moving the driver files from a rk322x build to my installation, but it didn't work.
Posted (edited)
I found a TX box X96 Mini with rk3228 chip and I try to boot with multitool but it is stuck with a red ligh.
I try multitool and multitool2, with no success, can someone tell me what I am doing wrong ?
Thank you
The multitool i used are from here
i used balena etcher to burn the image
I also try to short pins on eMMc (around 45 times...) but nothing works from me.
Now i order a male-male cable on amazon.
edit: added front/left photos
Edited by Francesco Spossati
attach board photo/added details
I've checked performance of my old rk322x-based box (H2O with 1.5G RAM/4G ROM) and compared it with fresh, h618-based. sysbench shows that rk322x is ~20x times slower in CPU (rk322x - 39 events, h618 - 700 events) and 6x times slower in RAM operations (216MB/s vs 1333 MB/s). in threads test rk3222x is just less than 2x times slower (4317 events vs 7563 events).
are these values OK? or maybe something is mistuned?
I think i find where all my trouble start. i can doownload to the box the rk322x_loader_v1.10.238_256.bin but i can't switch to the emmc.
Does anyone have ideas of what to do?
I am a newbie making first steps with Armbian on my random MXQ PRO4 tv-box, huge thanks for everyone who made it possible, I find it to be a great way to improve my Linux skills. I wanted to ask for the help with it's wifi/bt chip marked as MSN8830A. I am currently running Armbian-unofficial_24.11.0-trunk_Rk322x-box_noble_current_6.6.56_xfce_desktop.img.xz from eMMC and apart from wifi/bt everything else works perfect. Will greatly appreciate any advise on prober driver/armbian image that may help with wifi. Attaching the picture showing the chip and board name.
74ea9647-b0c9-44d7-9233-0bdea959de5a.jfif
you may actually want to extract the dtb file on the android side of the tvbox you have just to get the OS to get recognize that chipset (but may not work due to missing driver).The odds for this kind of tv box to have a working wifi chipset is a lottery, most likely you better off not waste that effort and just buy a USB WiFi dongle instead, at least it works far better than a SDIO based wifi chipset like that.
Hello, i have made an account in this forum to ask a few questions on how to install Armbian
Like a user above i have a Mxq pro (Recognized it by the motherboard!) however the one i have has NAND memory, as a question do any kernel versions or modern installs support this besides 4.4?
If not is there any way for me to upgrade my install from Ubunto 18.04.6 to the newer 22, or switch from Ubunto to Debian.
From what i could tell, Armbian is a modification to both of those distros with a different Kernel and a few rewrites, and in theory you can upgrade the Kernel, or the distro, so in theory it should be possible.
Posted (edited)
@Jerry Falken
Unfortunately  you must remain on kernel 4.4.xxx because as many times said newer kernels doesn t support NAND.
About upgrading to newer distros, blacklist kernel update in apt and try doing seguential apt dist upgrades changing repository and starting by a well working distro
I have up to Debian bookworm ( Debian 12 ) but only cli, no desktop
May I ask what the purpose are you using for your tv box ?
Edited by fabiobassa
1 minute ago, fabiobassa said:
About upgrading to newer distros, blacklist kernel update in apt and try doing seguenti apt dist upgrades changing repository and start ing by a well working distro
I've already tried both sudo apt update && sudo apt upgrade.
I can't update because it says that the website linked "apt.armbian,com bionic release" doesn't have a release file.
What commands would i specifically need to run to do what you said (Blacklisting kernel, seguenti (?))
Server, something i can ssh into to run some basic websites on nginx
@Jerry Falken
Quote
well this forum is more oriented on hardware and compiling stuffs rather than generic linux info that you can find every where on the  net so I won't answer on this, google it
12 hours ago, Jerry Falken said:
server, something i can ssh into to run some basic websites on nginx
You can remain also on old distros such as debian 9 stretch minimal without gui but with ssh support to run headless ngix apps.
I don't think you need newer distros to run such easy apps , the important is improve a good firewall and also a fail2ban app to protect your system but, again, those are more generic linux questions rather than support on tvboxes socs
Looks like the tar file is broken. Try unpacking it with one other program and see if you can getting the .IMG file extracted OK.
Also downloading it more times and see if its being OK or the server is having one corupt file.
I have once again returned to this post in need of assistance.
I have recently acquired from my tech wizard father a MXQ Pro 5G 4K TV box, which not even he managed to get working.
According to him, its eMMC.
Attached are photos of the motherboard, i did some looking at previous recent pages, so i have my suspicions, if someone though knows if this is a false print, or a just a freak motherboard please do tell.
The problem itself is that it wont boot to the SD card, sometimes it will boot in sometimes not, but every time it boots if i try to access the files or sd card the Android freezes up.
CPU: According to the print, RK3228A
If any questions about any other components arise, please circle them in a photo because my knowledge on hardware electronics is limited.
