Hello again.And i'm sorry to say this but i was wrong at something.We generally installed rk322x boxes with multitool before.Installing way was as 1-erasing flash 2-burning new image after erasing flash.We were successfull at most boxes but some of them was i think(i rechecked the installation guide and some links at forum) including nand chips.After erasing nand boxes we were losing control of internal memory.After trying these commands at below at multitool command line(4. choice) we are able to see nand again.Anyway,thanks for you for all things and being at here.
mount /dev/mmcblk0p1 /mnt
dd if=/mnt/bsp/legacy-uboot.img of=/dev/rknand0 bs=4M seek=1
dd if=/mnt/bsp/trustos.img of=/dev/rknand0 bs=4M seek=2
sync
exit
Hey vice,
Maybe you can tell me a bit more about the issues after erasing NAND... Actually I also have issues since erasing NAND with system stability...
What were you're experiences and how did you solve the issues?
Bonne nuit @gurzixo (I hope you are enjoying Algarve, I plan to go living there when I retire ;) )
@jock and @gurzixo, unfortunately I think my board is really broke. I tried several times connecting in both Win and Linux, with no success. No connecting sound in Windows, no lights on the board, nothing in rkdevtool.
I've connected the board through a serial adapter and here's what it shows:
00000000	2021-04-14 00:03:50,7881123		PnP Event: Connect	DOWN	0x00000000	5c 00 3f 00 3f 00 5c 00 55 00 53 00 42 00 23 00 56 00 49 00 …	\.?.?.\.U.S.B.#.V.I.…
00000001	2021-04-14 00:03:50,7881718	+0,0000595	IRP_MJ_CREATE - process 11192 (Studio.exe)	DOWN	0x00000000
00000002	2021-04-14 00:03:50,7936970	+0,0055252	IRP_MJ_CREATE	UP	0x00000000
00000019	2021-04-14 00:03:50,7938560	+0,0000047	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_BAUD_RATE	DOWN	0x00000000	00 c2 01 00 	....
00000020	2021-04-14 00:03:50,7947138	+0,0008578	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_BAUD_RATE	UP	0x00000000
00000021	2021-04-14 00:03:50,7947928	+0,0000790	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_CLR_RTS	DOWN	0x00000000
00000022	2021-04-14 00:03:50,7955705	+0,0007777	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_CLR_RTS	UP	0x00000000
00000023	2021-04-14 00:03:50,7955831	+0,0000126	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_CLR_DTR	DOWN	0x00000000
00000024	2021-04-14 00:03:50,7967021	+0,0011190	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_CLR_DTR	UP	0x00000000
00000025	2021-04-14 00:03:50,7967265	+0,0000244	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_LINE_CONTROL	DOWN	0x00000000	00 00 08 	...
00000026	2021-04-14 00:03:50,7967306	+0,0000041	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_LINE_CONTROL	UP	0x00000000
00000027	2021-04-14 00:03:50,7967384	+0,0000078	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_CHARS	DOWN	0x00000000	00 00 00 00 11 13 	......
00000028	2021-04-14 00:03:50,7967409	+0,0000025	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_CHARS	UP	0x00000000
00000029	2021-04-14 00:03:50,7967481	+0,0000072	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_HANDFLOW	DOWN	0x00000000	00 00 00 00 00 00 00 00 6c 86 00 00 9b 21 00 00 	........l....!..
00000030	2021-04-14 00:03:50,7986610	+0,0019129	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_HANDFLOW	UP	0x00000000
00000031	2021-04-14 00:03:50,7986958	+0,0000348	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_TIMEOUTS	DOWN	0x00000000	0a 00 00 00 00 00 00 00 00 00 00 00 0a 00 00 00 2c 01 00 00 	................,...
00000032	2021-04-14 00:03:50,7987003	+0,0000045	IRP_MJ_DEVICECONTROL: IOCTL_SERIAL_SET_TIMEOUTS	UP	0x00000000
00000034	2021-04-14 00:03:50,8784723	+0,0796176	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000036	2021-04-14 00:03:51,0208661	+0,1423369	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	..... ..............…
00000038	2021-04-14 00:03:51,1444437	+0,1235305	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 …	...........@........…
00000040	2021-04-14 00:03:51,2678012	+0,1233120	IRP_MJ_READ	UP	0x00000102	00 00 00 02 00 00 00 00 00 00 00 20 00 00 00 00 00 00 00 00 …	........... ........…
00000042	2021-04-14 00:03:51,4679985	+0,2000952	IRP_MJ_READ	UP	0x00000102	00 00 00 20 00 00 00 04 00 00 00 00 00 00 00 00 04 00 00 04 …	... ................…
00000044	2021-04-14 00:03:51,5452828	+0,0771656	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000046	2021-04-14 00:03:51,6071353	+0,0617905	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000048	2021-04-14 00:03:51,6853533	+0,0780934	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000050	2021-04-14 00:03:51,7004875	+0,0150652	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	..... ..............…
00000052	2021-04-14 00:03:51,7311971	+0,0306849	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000054	2021-04-14 00:03:51,7470364	+0,0157561	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000056	2021-04-14 00:03:51,7626234	+0,0155351	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000058	2021-04-14 00:03:51,7786069	+0,0158684	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000060	2021-04-14 00:03:51,7933081	+0,0145387	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000062	2021-04-14 00:03:51,8084435	+0,0150183	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
00000064	2021-04-14 00:03:51,8706427	+0,0621373	IRP_MJ_READ	UP	0x00000102	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 …	....................…
I gues there's nothing I can do to revive the board... I've learned my lesson about buying boards without SD slot.
15 hours ago, Yeoj Henrie Sayadi said:
I have emmc. I just want to make my ram faster for gaming with overclocked gpu ofc
Bad thing: you tried something that was totally not suited for your board.
If your board still boots, please don't try it again or you overwrite the bootloader.
The update will come via regular apt upgrade when Armbian team will rebuild the APT packages (I don't know the date, maybe it already happened...)
In fact instructions in no case tell to erase flash when you use multitool.
In case of NAND chip (and multitool clearly tells you when the board is equipped with NAND), you must use steP-nand, as stated per instructions :ph34r:
@KSilva
That does not look at all the serial output of the board, but rather some Windows log of some sort.
You are definitely not reading the board serial output correctly.
oh okay the board still boots I guess it is a durable board thank you I just reflash the original android image when it doesn't seem to boot
15 hours ago, Alex83 said:
Hey vice,
With multitool step 4 we did these instructions.Then we could able to find nand chip.Today we are going to install legacy image with multitool without erasing.Jock wrote something about the solution here
but we removed oflag after his commands.
Final commands are here to recover nand chips.
step1   mount /dev/mmcblk0p1 /mnt
step2   dd if=/mnt/bsp/legacy-uboot.img of=/dev/rknand0 bs=4M seek=1
step3   dd if=/mnt/bsp/trustos.img of=/dev/rknand0 bs=4M seek=2
step4    sync
step5     exit
enter after steps
Edited by vice
Page 18
On 1/11/2021 at 11:57 AM, JVMS said:
Good Morning, I have a tv box model r29-5g-v1.2-221, I tried both the distribution of the armbian for the rk322x and the Multitool, and configuring the normal distribution with the dtb rk322x is only the red led on and using the multitool is the flashing orange led. the network card is the sv6256p and the memory is the TYDOGH221644RC 8G + 1g the chip is the rk3229tvbox1.jpegtvbox2.jpegtvbox3.jpeg
hi, i'm now in this forum.  Hope have a nice day, i have the same tv box. ¿Do you have the firmware? It's gonna be really helpful, my machine is blocked and i lost the backup :C
regards!
regards!
No backup firmware here. Bye bye
On 4/14/2021 at 7:56 AM, jock said:
@KSilva
Hi @jock, serial connections are new to me, sorry for that. After searching for a while I managed to connect the board and here is the log. There are some strange characters in there, maybe I'm setting the wrong speed? (set it to 115200)
But it seems that there is no boot.env. At least the board isn't completely dead and is strugling to survive :)
▒!▒                                 ▒▒   ▒P   $          ▒   ▒        ▒ ▒           ▒ ▒            ▒ @       @ ▒@       ▒DDR ^ersion V1.10 20390926
In
600MHz
DDR3
Bus Width=16 Col=11 Bank=8 Row=16 CS=1 Die Bus-W▒dth}16 Size=2048MB
mach:3
OUT
U▒Boot"SPL 2020.10-armbian (Mar 09 2021 - 08:47:40 +0100)
▒ryin▒ to foot fro[j5
I/TC:
I▒TC: Non-secure Yѕ▒s
                     c▒DT!found
I/TC: OP-TEE version: 3.10.0-40-ga1d5c81f (gcc version NIr▒▒▒▒▒▒▒B:9▒F▒▒▒▒sf▒Ɂthe A-profile Architect}re 9.2-2019.12 (arm-9.10))) #6 Wed SY▒16 21:36:15 UTC 2020 arm
I/TC: Primary CPU initializing
M/TC: Not pro▒Yl▒▒▒regi▒n 1: 0x68400000-▒x68600000
I/TC: Primary CPU itching to normal wosld boot
U-Boot 2020.10-armbian (Mar 09 2021 - 08:47:42 +2100)
 Model: GY▒ɥ▒▒Rockchip rk322x TV0box board
DRAM:  2 GiB
MMC>   dwmmc@30000000: 1, dw▒mc@30020000: 0
Loading Environment from EXT4>.. ** File not found /boot/boot.env **
** Unable to read "I▒▒ѽot.env" from mmc0:1 *▒
In:    serial@▒▒30000
Out:$  serial@11030000
Err:   serial@11030000
Model: Gen▒ric ▒k▒▒▒▒▒rk322x TV Box board
Net:   eth▒'*ѡ▒ɹ▒▒▒0200p00
starting ▒SB...
▒us usb@30040000: U*("]
scanning bus usb@30040000 for dmvices... 1 USB Device(s+ fou~d
   ▒   scanning usb fos storage devices... 0 Storage Device(s) found
stopping USB..
s▒arti▒▒M       ▒..
Bus usb@30040▒▒▒▒USB DWC2
▒       scanning usb for storage devices... 0 Storage▒T▒Wk▒▒s) found
Card did not ▒espond to v▒▒▒▒▒▒select!
De▒Z▒▒▒▒▒▒▒▒ݹ▒device
switch to partitions #0, OK
}mc0(▒art 0) is0current devZ▒VH▒Scanning mmc 0:L▒ɩH▒Found UI▒▒сscript /foot/boot.scr
6909 bytY.I▒▒▒▒in 3 ms (946.3 KiB/s)
## ▒▒▒ѥ▒▒▒script at 60100000
Wrong image fosmat0for "source" command
S(▒
   E2%%1▒ continumng...
ethernet@30200000 Waiving for PHY auto negotiation to complete......... TIMEOUT !
Could not▒initialize PHY ethernet@30200p00
missing environment▒variable: pxeuuZVH▒+kͥ▒▒▒enwironment variab▒e: bootfileC!▒▒▒▒٥▒▒▒file: pxelinux.gfg/01-22-cd-24-4e-c6-b5
ethernet@30▒00002 Waiting for P▒Y auto negotiation`to ▒▒
                                                        ▒▒ѕ▒......>. TIMGOUT )
Could not initializm PHY ethernet@30300000
missing envison▒ent ▒X▒+▒▒▒▒ bootfile
Re▒▒▒٥▒▒▒file: pxelinux.cfg/00▒▒▒▒▒j
                                    ethernet@30200000 ▒aiting for PHY auto negotiation to complgte......... TIMEOU▒ !▒
                                      Could not knitialize PHY ethernet@30200000
missing envi▒onment variab▒e: bootfile
Jetheroet`30200000 Waiting ▒K▒PHY auto negotiation to complete......... TIMEOUT !
Cound not initialize PHY ethernet@302p0▒▒j
                                          missing mnvironment variable: bootfile
Retrieving file: pxelinux.cfg/000000
ethernet@30200000 Waiting for PHY auto negotkation to▒▒▒
                                                        ▒▒ѕ.....>▒.. TIMEOUT !
Could nou initialize PHY▒etheroet@30200000
missing0enviro▒[Y▒▒variable> bootfine
Retrieving file: pxe▒Z▒▒cfg/00400
ethernet@30200000 Waiuing0for PhY auto negotiation to complete......... TIMEOUT !
*missing0environment variable: bootfile
Retrieving file: pxeli▒]▒cfg/0000
ethernet@30200000 Waiting for PHY auto negotiation(to complW▒▒........▒U▒▒=UQ▒!
Coul▒r▒сinitiilize PHY ethernet@3020000▒
missing environment variable: bootfile
Retrieving nile: pxelinux.cfg/000
ether▒Y▒0200000 Waiting▒▒K▒PHY X]▒
                                  r▒▒▒ѥ▒ѥ▒▒▒to complete....▒.... TIMEOUT !
Could not initialize PLY ethernet@30200000
▒RetrZYW▒▒file: p▒Y+˫▒cfg/00: bootfile
ethernet@30200000 Waiting for PHY▒auto negotiation t
                                                    ▒▒▒▒ѕ▒......▒. TIMEOUT !
Could not initialize PHY ethernet@30200000
missing environment veriable:`bootfile
Retrievmng file: pxelinu▒i▒▒▒0
ethernet@30200000 Waiting for PHY auto negotietion to c▒
                                                        ▒▒ѕ▒....▒... TIMQ▒E
        j
        Could not initialize PHY ethernet@3020p000
Retrievyng!file: pxelinux.cfg/dYVձѵarm-rk322x-rk322x-box
et▒erne▒▒0200000 Waiting for PHY auto negotkation uo complete......... TIMEOUT !
Could not initialize(PHY ethernet@30200000
missing environment variab|e: bootfilYC!▒▒▒▒٥▒▒▒file: pxelinux▒,▒։▒▒▒ult-arm-rk322x
JCould not(ini▒ialize PHY ethernet@30208400tion to complete......... TIMEOUT !
missi▒g environment variable: bootfile
Retrieving file: pxelinux.kfg/default-arm
ethernet@30:00000 Weit▒ng fK▒PHY auto negotiation to complete......... TIMEOUT !
Could not initialize PHY ethe▒net@30200000
▒issing environment variqble▒R▒▒ә▒▒▒5
                                     Retrieving file: pxelinux.cfg/default
ethesnet@30200000 Waiting gor PHY auto negotiqtion to complete....>.... TIMEOUT Could not initialize(PHY ethernet@30200000
Confio file not found
ethernet@30200000 Wai▒▒▒for PHY auto negotiation"to complYW▒▒........ TIMEOUT !
Could not initialize PHY ethernet@3020▒▒▒j
                                          etherngt@30210000 Waiting for PHY a]▒
        r▒▒▒▒iation to com▒lete......... TIMEOUT`!
Co]▒▒not initialize PHY!mthernetB34200p00
@KSilva that's much better!
The main reason you get a garbled output is because your ground wire is not connected to the right pin on the board, the wire is not thick enough or it is not connected at all.
Serial is veeery easy, you just have receive (RX) and transmit (TX) pins, plus the ground which is the most important wire because it is going to be the referral voltage for both the chatters. One chatter (the PC) is using the TX pin to send characters and the other chatter (the BOX) is receving on the RX pin, and viceversa.
Indeed you found the TX pin of the box, because we are getting some sensible data; maybe you need to swap the other two wires and see if it gets any better.
Anyway, from what I see, this is your current situation: part of the armbian image has been installed correctly, because you can see U-boot v2020.10 booting.
Since u-boot is installed, you should be able to burn the Multitool on a USB stick and place an Armbian image in the images folder.
Plug the USB stick in the OTG port and then turn on the box. You should see something like the following, where two USB devices are detected and one is a storage device:
scanning bus usb@30040000 for dmvices... 2 USB Device(s+ fou~d
   ▒   scanning usb fos storage devices... 1 Storage Device(s) found
If you get zero storage devices, unplug the power and try the other USB port.
Hopefully you should get the multitool up and running, and then install the armbian image from there.
If you need full instructions refer to the first page: you can follow the procedure on how to install on eMMC using sdcard, but just use the USB stick instead.
Notes:
  • You may notice that the message "Scanning bus..." is repeated twice: it is normal, it is a workaround to make USB boot
  • Some USB sticks are not working really well: that's a problem of the u-boot USB code. If you get errors, maybe try with another USB stick. Recent ones seems to work better
  • You should be even able to boot Armbian from USB stick: just decompress the Armbian image and burn it as is on the USB stick
@jockFollowing your advice, I readjusted the connections (it got substantially better) and managed to get a little further. However, there seems to be a problem related to kernel?
Sidenote for future refference to everyone with this board: The OTG port is the one labeled "USB1" that is closest to the Reset button.
I burned multitool on a USB stick and tried first with an armbian image (Armbian_21.02.3_Rk322x-box_buster_legacy_4.4.194) and here is the log:
>▒/▒▒▒▒DDR Version V1.10 20190926
In
I▒:0xFFF
600MHz
DDR3
Bus Width=16 Col=11 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
mach:3
OUT
U-Boot SPL 2020.10-armbian (Mar 09 2021 - 08:47:40 +0100▒
Trying to boot from MMC2
I/TC:
I/TC: Non-secure external DT found
I/TC: Switching console to device: /serial@11030000
I/TC: OP-TEE version: 3.10.0-4▒˶▒"▒c81f (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architgcture 9.2-2019.12▒(arm-9.10))) #6 Wed Sep 16 21:36:15 UTC 2020 arm
I/TC: Primary CPU▒initializing
M/TC: Not protecting region 1: 0x6840▒000-0x68608▒▒j
                                                    I/TC: Primary CPU switching to normal world boot
U-Boot 2020.10-armbian (Mar 09 2021 - 08:47:40 +0100)
*Mo▒YK:▒▒▒ɥ▒▒Rockchip rk322x TV Box b▒ard
DRAM:  2 GiB
MMC:   dwmmc@30000000: 1, dwmmg@300:0000: 0
Loading Environment from EXT4... ** File not found /boot/boot.env **
** Unable to read "/boot/boot.env" from mmc0:1 **
In:    serial@11030000
Out:   serial@11030000
Model: Generic Rockchip rk322x TV Box board
Net:   eth0: ethernet@30280000
starting USB...
Bus usb@30040000: USJ DWC2
scanning bus usb@30040000 for devices... 2 USB Device(s) found
     ` scanning usb for storage devices... 1 Storage Device(s) found
stopping USB..
starting USB...
Bus usb@3004▒▒▒▒▒USB DWC2
scanning bus usb@30040000 for devic▒s... 2 USB Device(s) found
       scanning usb for storage devices..n ▒ Storage Device(s) found
Cart did not respond to voltage select!
Device 0: Vendor: Sony     Rev: 0100 Prod: Storage Media
    ▒      "Type: Removable Hard Disk
            Capacity: 7648.0 MB = 7.4 GB (15663104 x 512)
... is now current device
Scanning usb 0:1...
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
154 bytes read in 5 ms (29.3 KiB/s)
1:      Multitool
Retrieving file: /kernel.img
87192▒▒ѕ́read in 440 ms (18.9 MiB/s)
append: boot=UUID=E111-2625 root=/dev/mmcblk0p2 console=ttyS2,115200 verbose=1 conso|eblank=0
Retrieving file: /rk322x-box.dtb
46636 bytes read in 5 ms (8.9 MiB/s)
## Flattened Device Tree blob at 61f00000
   Booting using the fdt blob at 0x61f00004
   Loading Device Tree to 683f1000, end 683ff62b ... OK
Starting kernel ...
I/TC: Secondary CPU 1 initializi▒g
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU"2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Lin▒x version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-▒▒˥▒▒▒Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47 SMP Thu Apr 9 17:37:46 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (▒RMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000001] Machine model: Generic RK322x TV Box board
[    0.000000] Reserved memory: OVERLAP DETECTED!
[    0.000000] optee_core@68400000 (0x68400000--0x68600000) overlaps with trust@68400000 (0x68400000--0x69200800)
[    0.000000] trust@68400000 (0x68400000--0x69200000) overlaps with optee_shm@68600000 (0x68600000--0x68700000)
[    0.000000] cmq: Reserved 128 MiB at 0xd8▒▒▒▒▒j
                                                  [    0.080020] Memory policy: Data cache writealloc
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PsCI v0.2$function IDs
[    0.000000] psci: MIGRATE_IN▒▒E▒U▒not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @eed94000 s24856 r8192 d24296 u57344
[    0.100000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 518400
[    0.000000] Kernel command line: boot=UUID=E111-2625 root=/dev/mmcblk0p2 console=ttyS2,115200 verbose=1 consoleblank=0
[   ▒z▒▒▒▒▒▒▒PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hasx ta▒▒▒entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[   ▒r▒▒▒▒▒▒▒Memory: 1;15292K/2082816K available (12820K kernel code, 875K rwdata, 3224K rodata,!796K init, 1219K bss, 40452K(reserved, 131072K cma-reserved, 917504K highmem)
[    0.008000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[ $  0>000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xf00000▒B▒▒▒▒j       ▒
[    0.000000]     pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
[    0.000000]     modules : 0xaf000000 - 0xafe00000   (  14 MB)
[    0.000000]       .text : 0xb0008000 - 0xb0c8d53c   (12822 kB)
[    0.000000]       .init : 0xb10a1000 - 0xb1168000   ( 796 kB)
[    0.000000]       .lata : 0xb1168000 - 0xb1242e94 ▒ ( 876 kB)
[    0.000000] ▒r▒́: 0xb1244000 - 0xb1374ee4   (1220 -▒▒H▒+▒r▒▒▒▒▒▒▒SLUB: HWalign=64, Order=0-3, MinObjmcts=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[▒▒r▒▒▒▒▒▒▒     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[▒   0.000023] Switching to timer-based delay loop, resolution 41ns
[    0.001682] Console: colour dummy device 80x30
[    0.001719] Calibrating delay loop (skipped), value calculatet using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001738] pid_max: default: 32768 minimum: 301
[    0.001869] Security Framework initialized
[    0.00188▒] Yama: becoming mindful.
[    0.001961] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001977] Mountpomnt-cache hash table entries: 2048 (order: 1, 8192 bytY▒▒▒[    0.002881] Initializing cgroup subsys io
[    0.002916] Initializing cgroup subsys memory
[    0.002959] Initializing cgroup subsys devices
[ ▒  0.002980] Initializing cgroup subsys freezer
[    0.002997] Initializing cgrou▒ subsys net_cls
[    0.003014] Initi▒lizing cgro]▒subsys perf_event
[    0.003032] Initializing cgroup subsys net_prio
[    0.003062] Initializing cgro]▒subsys pids
[    0.003131] CPU: Testing write buffer coherency: ok
[    0.003181]0ftrace: allocating 41▒20 entries in 123 pages
[    0.082363] /cpus/cpu@f00 missing clock-frequency property
[    0.082397] /cpus/cpu`f▒Nk▒▒ͥ▒▒ clock-frequency property
[    0.082416] /cpus/cpu@f02 missing clock-frequency property
[    0.082436Wz▒▒ͽcpu@f03 missing clock-frequency property
[    0.082448] CPU0: update cpu_capacity 430
[    0.082459] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.082541] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.093832] CPU1: update cpu_capacity 430
[    0.093841] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f8▒
[    0.103340] CPU2: update cpu_capacity 430
[    0.103349] CPU2: threX
                          j▒b▒Ձ2, socket 15, mpidr 80000f02
[    0.112833] CPU3: update cpu_capacity 430
[    0.112841] CPU3: threed -1, cpu 3, socket 15, mpidr 80000f03
[    0.11297Sɽ՝▒сup 4 CPUs
[    0.113016] SMP: Total of 4 processors activatef (192.00 BogoMIPS).
[    0.113024] CPU: All CPU(s) started in SVC mode.
[    0.114575] devtmpfs: initialized
[    0.131999] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.132528] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.132568]▒VW▒hash table entries: 1024 (order: 4, 65536 bytes)▒
        [    0.138682] xor: measuring software checksum speed
[    0.178442]    arm4regs  :  1011.000 MB/sec
[    0.218548]    8regs     :   705.000 MB/sec
[    0.258649]    32regs    :   684.000 MB/sec
[    0.298752]    neon      :  1018.040 MB/sec
[    0.298762] xor: using function: neon (1018.000 MB/sec)
[    0.298800] pinctrl core: initialized pinctrl subsystem
[    0.300411] NET: Registered protocol family 16
[    0.303062] DMA: preallocated 2048 KiB rool for atomic coherent allocations
[    0.314911] cpuidle: using governor ladder
[    0.326925] ,ե▒▒▒▒ using governor menu
[    0.349293] console [pstore-1] enabled
[    0.349306] pstore: Registered ramoops as persisten| store backend
[    0.349318] ramoops: attached 0xf0000@0x62e00000, ecc> 0/0
[    0.352206] hw-breakpoint: found 5 (+1 zeserved) breakpoint and 4 watchpoint registers.
_    0.352226] hw-breakpoint: maximum watchpoint size is▒8"b}tes.
[    0.352435] sip_firmware_init: set rockchip sip versioo v2 failed
[   "0.447822] raid6: in|32x1  gen() ` 133 MB/s
[    0.515916] raid6: int32x1  xor()   131 MB/s
_    0.584135] raid6: int32x2  gen()   1▒6"MB/s
[    0.652422] raid6: int32x2  xor()   137 MB/s
[    0.720567] raid6: int32x4  gen()   163 MB/s
[    0.788833] raid6: int32x4  xor()   137 MB/s
[    0.856978] raid6: int32x8  gen()   166 MB/s
[    0.925239] raid6: int32x8  xor()   113 MB/s
[    0.993390] raid6: neonx1   gen()   382 MB/▒Hx+▒r▒▒▒▒²▒raid6: neonx1   xor()   290 MB/s
[    1.129741] raid6: neonx2   gen()   519 MB/s
[    1.197890] raid6: neonx2   xor()   376 MB/s
[    1.266104] raid6: neonx4   gen()   581 MB/s
[    1.334317] raid6: neonx4   xor()   400 MB/s
[    1.402626] raid6: neonx8   gen()   560 MB/s
[    1.470803] raid6: neonx8   xor()   391 MB/s
[    1.470817] raid6: using algorithm neo▒▒ gen() 581 MB/s
[    1.470827] raid6: .... xor() 400 MB/s, rmw enabled
[    1.470838] raid6: using intx1 recovery algorithm
[    1.471806] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.471829] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.475289] iommu: Adding device 20020000.vpu-service to group 0
_` ▒ 1.475410] iomm▒: Adding device 20030000.rkvdec to group 1
[    1.475507] iommu: Adding device 20050000.vop to group 2
[    1.▒755=9] iommu: Adding device 20070000.iep to group 3
[    1.476138] rk_iommu 20020800.iommu: can't get sclk
[▒▒r▒▒▒▒▒▒▒rk_iommu 20030480.iommu: can't get sc▒▒Hx+$▒r▒▒▒▒ʂ▒rk_iommu 20053f00.*[    1.477140] rk_iommu 20070800.iommu: can't get aclk
[    1.477159] rk_iommu 20070800.iommu: can't get hclk
                                                      [    1.477176] rk_iommu 20070800.iommu: can't get sclk
[    1.477921] SCSI subsystem initialized
[    1.478309] usbcore: registered new interface driver usbfs
[    1.478422] usbcore: registered new interface driver hub
[    1.478547] usbcore: registered new device driver usb
[    1.478749] media: Linux media interface: v0.10
[   !1.478897] Linux video capture interface: v2.00
[    1.479107] pps_core: LinuxPPS API ver. 1 registered
[    L▒▒ʊ▒▒▒pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.479162] PTP clock support registered
[    1.481061] Advanced Linux Sound Architecture Driver Initialized.
[    1.482130] Bluetooth: Core ver 2.21
[    1.482197] NET: Registered protocol family 31
[    1.482211] Bluetooth: HCI device and connection manager(i~itialized
[    1.482232] Bluetooth: HCI socket layer initialized
[    1.482249] Bluetooth: L2CAP socket layer initialized
[    1.482303] Bluetooth: SCO socket layer initialized
[    1.483138] NetLabel: Initializing
                                     [    1.483160] NetLabel:  domain hash size = 128
[    1.483170] NetLabel:  protocols = UNLABELED CIPSOvt
[    1.48324t] NetLabel:  unlabeled traffic allowed by default
[    1.484217] clocksource: Switched to clocksource arch_sys_counter
[    1.580040] NET: Registered protocol family 2
[    1.581020] TCP estcblished hash table entries: 8192 (order: 3, 32768 bytes)
[    1.581135] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
▒    1.581491] TCP: Hash tables configured (established 8192 bind 8192)
[    1.581587] UDP▒hash table entries: 512 (order: 2, 24576 bytes)
[    1.581657] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.581993] NET: Registered protocol family 1
[    1.582667] RPC: Registered named UNIX socket transport module.
[    1.582692] RPC: RegistY▒▒▒▒transport module.
[    1.582702] RPC: Registered tc▒▒ransport module.
[    1.58271▒] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.583558] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.586541] Initialise system trusted keyring
[    1.600784] VFS: Disk quotas d\]▒}▒.6.0
[    1.601087] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.603781] squashfs: vmrsion 4.0 (2009/01/31) Phillip Lougher
[    1.607338] NFS: Registering the id_resolver key type
[    1.607607] Key type id_resolver registered
[    1.607419] Key type id_legacy registered
[    1.607451] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.607545] ntfs: driver 2.1.32 [Flags: R/W].
[    1.608567]$JFS: nTxBlock = 8192, nTxLock = 65536
[    1.618496] SGI XFS with security attributes, no de▒]▒▒▒▒▒▒▒5
        [    1.627407] NET: Registered protocol family 38
[    1.627463] Key type asymmetric registered
[    1.627485] Asymmetric key parser 'x509' registered
[    1.627611] bounce: pool size: 64 pages
[    1.627970] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.628425] io scheduler noop registered
[    1.628458] io scheduler deadline registered
[    1.628547] io scheduler cfq registered (default)
[    1.631619] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    1.636970] rk-▒▒▒▒▒▒20020000.vpu-service: no regulator for vcodec
[    1.637395] rk-vcodec 20020000.vpu-service: probe device
[    1.637813] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    1.639014] rk-vcodec 20020000.vpu-service: could not find power_model node
[    1.639040] rk-vcodec 20020000.vpu-service: init success
[    1.639479] rk-vcodec ▒▒▒▒▒▒▒r▒▒ّ▒▒▒ vcodec regulator not ready, retry
[    1.643535] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.643562] dma-pl330 110f0000.pdma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.644902] rockchip-system-monitor roc{chip-sy▒tem-monitor: system monitor probe
[    1.647156] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ "  1.647933] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq =030, base_baud =01500000) is a 16550A
[    2.716632] console [ttyS2] enabled
[    2.721895] [drm] Initialized drm 1.1.0 20060810
[    2.729017] [drm] Rockchip DRM driver version: v1.0.1
[    2.734346] rockchip-drm display-subsystem: devfreq is not set
[    2.740952] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb4d111b0)
[    2.748710] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.755383] dw▒▒+▒I▒▒▒▒▒▒▒200a0000.hdmi: registered DesignWare HDMI I2C bus dri▒Y▒H▒[    2.763241] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[(   2.774209] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    2.781689] [drm] Supports vblank timestamp caching Rev 2 ▒▒r▒▒r▒▒▒▒Jrj
        [    2.788340] [drm] No driver support for vblank timestamp query.
[    2.794388] rockchip-drm display-subsystem: failed to parse display resources
[    2.801604] rockchip-drm display-subsyste}: No connectors reported ko~nected with modes
[    2.809712] [drm] Cannot find any crtc or sizes - goin▒▒▒▒▒▒68
[  $ 2.838989] Console: switching to colour frame buffer device 128x48
[    2.860631] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.882912] brd: module loaded
[    2.897152] loop: module loaded
[    2.900406] lkdtm: No crash points registered, enable through debugfs
[    2.909522] libphy: Fixed MDIO Bus: probed
[    2.913704] tun: Universal TUN/TAP device driver, 1.6
[    2.918780] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.925324] CAN device driver interface
[  $ 2.937867] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).put? (output).
[    2.943563] rk_gmac-dwmac 30200000.ethernet: RX dulay(0x10).
[    2.949281] rk_gmac-dwmac 30200000.et▒ernet: integrated PHY? (yes).
[    2.955738] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.967789] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.008334] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.013420]  Ring mode enabled
[    3.016M▒▒ DMA HW capability register supported
[    3.021071]  Normal descriptors
[    3.024427]  RX Checksum Offload Engine supported (type 2)
[    3.029928]  TX Checksum insertion supported
[    3.034216]  Wake-Up On Lan supported
[    3.038050] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 22:cd:24:4e:c6:b5
[    3.046516] eth%d: device MAC address 22:cd:24:4e:c6:b5
[    3.051761]  Enable RX Mitigation via HW Watchdog Timer
[    3.072873] libphy: stmmac: probmd
[    3.076338] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.082802] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.088656] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.094506] eth%d: PHY▒R     ▒▒▒▒▒▒▒
                                       с3 IRQ POLL (stmmac-0:03)
[    3.100353] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.106199] eth%d: PHY ID 00100000 at 5 IRQ POLL (stmmac-0:05)
[    3.112044] e▒▒"▒ PHY ID 00000000 at 6 IRQ POLL (st▒mac-0:06+
[    3.117891] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.123737] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.129585] eth%d: PHY ID 00020000 at 9 IRQ POLL (stmmac-0:09)
[    3.135431] eth%f: PHY KD 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.141364] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.147297] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.153230] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.159162] eth%d: PHY ID 00000000 at!14 IRQ POLL (stmmac-0:0e)
[    3.165095] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.171028] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.176961] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.182893] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.188827] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.194760] eth%d: PHY RT▒▒▒▒▒▒▒▒
                                    с20 IRQ POLL (stmmac-0:14)
[    3.200693] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.206625] eth%▒'▒!e▒ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.212558] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.218490] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.224444] eth%d: PHY ID 00000000 at 25▒IRQ POLL (stmmac-0:19)
[    3.230388] eth%d: PHY ID 00000000 at 260IRQ POLL (stmmac-0:1a)
[    3.236328] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    3.242268] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.248216] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.254151] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.260086] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[  ▒ 3.267548] PPP generic driver version 2.4.2
[ 0  3.272390] Itmel at76x USB Wireless LAN Driver 0.17 loading
[    3.278264] usbcore: registered new interface dziver at76c50x-usb
[    3.284572] usbcore: registered new interface driver rtl8187
[    3.290418] usbcore: registered new interface driver rndis_wlan
[    s.296473] usbcorY'▒▒▒▒▒ѕɕ▒▒new interface driver zd1201
[    3▒&▒▒�▒usbcore: registered new interface driver ▒▒�▒▒͉5
                                                           [    3.308528] Rockchip WiFi SYS interface (V1.00) ...
[    3.313608] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.321117] us▒▒K▒▒ registered new interface driver pegasus
[    3.326888] usbcore: registered new interface driver rtl8150
[    3.332656] usbcore: registered new interface driver r8152
[    3.338267] usbcore: registered new interface driver askx
[    3.343770] usbcore: registered new interface driver ax88179_178a
[    3.349966] usbcore: registered new interface driver cdc_ether
[    3.355899] usbcore: registered new interface driver dm9601
▒[    3.&▒▒▒▒▒usbcore: registered new interface driver smsc95xx
[    3.373323] usbcore: registergd ▒YJ▒ѕə▒▒▒▒driver net1080
[    3.379079] usbcore: registered new interface driver rndis_host
[    3.385099] usbcore: registered$new interface driver MOSCHIP usb-ethernet driver
[    3.392649] usbcore: registered new interface driver cdc_ncm
[    3.398408] usbcore: registered new interface driver cdcՉ▒▒5
                                                               [    3.404684] 300400▒0.usb supply vusb_d not found, using dummy regulator
[    3.411441] 30040000.usb supply vusb_a not found, using dummy reV+ѽ▒5
        [    3.431213] dwc2 30040000.usb: DWC OTG Controller
[    3.437026] dwc2 30040000.usb: new USB bus registered, assigned bus number"1
[    3.443147] dwc2 30040000.usb: irq 49, io me▒ 0x30040000
[    3.448835] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.455667] usb ].▒▒r▒݁USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.462910] usb usb1: Product: DWC OTG Controller
[    3.467636] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3.473922] usb usb1: SerialNumber: ▒8040000.usb
[    3.479632] hub 1-0:1.0: USB hub found
[    3.483525] hub 1-0:1.0: 1 port detected
[    3.489204] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.495785] e▒ci-platforo: EHCI generic platform driver
[    3.503567] ehci-platform 30080000.usb:!EHCI Host Controller
[    3.509629] ehci-platform 30080000.usb: new USB bus registered, assigned bu{ number 2
[    3.517807] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    3.532279] ehci-platform 30080000.usb:"USB 2.0 started, EHCI 1.00C▒[    3.538810] usb usb2: New USB device found,▒-▒U▒▒▒▒▒1d6b, idProduct=0002
[    3.5▒MSS▒͉▒usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.552890] usb usb2: Product: EHCI Host Controller
[    3.557790] usb usb2: Manufacturer: Linux 4.4.194-rk362x ehci_hcd
[    3.563900] usb usb2: SerialNumber: 30080000.usb
[    3.569519] hub 2-0:1.0: USB hub found
▒    3.573377] hub 2-0:1.0: 1 port detected
[    3.580257] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.586489} ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    3.594651] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[▒▒r▒▒▒▒▒▒▒ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.0p
[    3.618764] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.625587] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.632834] usb usb3: Product: EHCI Host Controller
[    3.637734] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.643845] usb usb3: SerialNumber: 300c0000.usb
[    3.649441] hub 3-0:1.0: USB hub found
[    3.653295] hub 3-0:1.0: 1 port detected
[    3.660149] ehci-platform 30100000.usb: GHCI Host Controller
[    3.666212] ehci-qlatform 30100000.usb: new USB bus registered, assigned bus number 4
[    3.674384] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.69227▒] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.698780] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    3.705610] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.712857] usb usb4: Product: EHCI Host!Controller
[    3.717756] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.723867] usb usb4: SerialNumber: 30100000>usb
[    3.729492] hub 4-0:1.0: USB hub found
[    3.733358] hub 4-0:1.0: 1 port detected
[    3.738203] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.744463] ohci-platform: OHCI generic platform driver
[    3.750154] ohci-platform 300a0000.usb: Generic Platform OHCI controllY▒H▒[    3.758230] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    3.766385]hck-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    3.832528] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.839364] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.846616] ].,▒͉▒: Product: Generic Platform OHCI controller
[    3.852564] usb usb5: Manufacturer: Linux 4.4.19▒K▒▒&&&▒oh▒i_hcd
[    3.858679] usb usb5: SerialNumber: 300a0000.usb
[    3.864599] hub 5-0:1.0: USB hub founl
[    3.868425] usb 1-1: new high-speed USB device number▒&▒ͥ▒▒▒dwc2
[    3.872341] hub 5-0:1.0: 1 port detected
[    3.873219] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    3.873616] ohci-platfK▒▒300u0000.usb: new USB bus registered, assigned bus number 6
[    3.873859] ohci-platform 300e0000.usb: irq 53, io mem00x300e0000
[    3.932510] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    3.939346] usb usb6: New USB device strings▒ Mfr=3, Product=2, SerialNumber=1
[    3.946592] usb usb6: Product: Generic Platform OHCI controller
[    3.952533] usb usb6: Manufacturer: Linu| 4.4.194-rk322x ohci_hcd
[    3.958647] usb usb6: SerialNumber: 300m0000.usb
[    3.964372] hub 6-0:1.0: USB hub found
[    3.968231] hub 6-0:1.0: 1 port detected
[    3.y73234] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.980433] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.988543] ohci-platform 30120000.usb: irq 55,▒Z
                                                    j▒▒▒0x30120000
[    4.052524] usb usb7: New USB devige found, idVendor=1d6b- idProduct=0001
[    4.059354] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=▒[    4▒L▒SS▒▒usb usb7: Product: Generic Platform OHCI controller
[    4.072553] usb usb7: Manufacturer: Linux 4.4.194-rk322x oh▒녍▒5
        [    4.078671] usb usb7: SerialNumber: 30120000.usb
[    4.084568] hub 7-0:1.0: USB hub found
[    4.088457] hub 7-0:1.0: 1 port detectedM
                                            [    4.093340] usbcore: registered new interface drZW▒▒cdc_acm
[    4.099054] cdc_acm: USB Abstract Contr▒
                                           jodel driver for USB modems and ISDN adapuers
[    4n147188] usbcore: registered new interface driver cdc_wdm
[    4.113210] usbcore: registered new▒Z▒▒ə▒▒▒▒driver"usb-storage
[    4.119402] usbcore: registered new interface driver usbserial
[    4.125360] usbcore: registered new interface driver usbserial_generic
▒[    4.138087] usbcore: registered new interface driver keyspanric
[    4.143827] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    4.1▒1724] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    4.159104] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    4.166481] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    4.173912] usbcore: registered new interface driver option
[    4.179559] usbserial: USB Serial support registered for GSM modem (1-tort)
[    4.187202] usbcore: registered new interface driver oti6858
[    4.193172] usbserial: USB Serial support registered for oti6858
[    4.199328] usbcore: registered new interface driver qcserial
[    4.205160] usbserial: USB Serial support registered for Qualcomm USB modem
[    4.212315] usbcore: registered new interface driver sierra
[    4.217963] usbserial: USB Serial support registered for Sierra USB modem
[    4.225▒08] us▒core: registered new interface driver iforce
[    4.231491] usbcore: regiwtered"new interface driver xpad
[    4.237171] usbcore: registered new interface driver }s▒׫▒▒͍ɕ▒▒5
        [    4.244690] i2c /dev entries driver
[    4.250980] usbcore: registered new interface driver uvcvideo
[    4.256785] USB Video Class driver (1.1.1)
[    4.262783] Boot mode: normal
[    4.26699▒] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    4.275533] device-mapper;`ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    4.284382] Bluetooth: VZ.WW▒▒HCI driver ver 1.5
[    4.289400] Bluetooth: HCI UART drivgr ver 2.3
[    4.293879](Bluetooth: HCI UART protocol H< registered
[    4.299037] Bluetooth: HCI UART protocol$LL registered
[    4.304207] Blueuooth: HCI UA▒▒ɽѽ▒▒▒▒ATH3K registered
[    4.309624] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.316075] Bluetooth: HCI UART protocol BCM registered
[    4.321498] usbcore: registered new interface driver bfusb
[    4/327158] usbcore: registered new interface driver btusb
[    4.33268x] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    4.338997] cpu cpu0: leakage=8
[    4.342203] cpu cpu0: leakage-volt-sel=0
[  0 4.345868]"usb 1-1: New USB device found, idVendor=054c, idProduct=0243
[    4.345877]$usb 1-1: New USB(device strings: Mfr=1, Product=2, SerialNumber=3
[    4.345884] usb 1-1: Product: StK▒▒▒▒Media
[    4.345890] usb 1-1: Manufacturer: Sony
[    4.345896] usb 1-1: SerialNumber: 5A09111621518
[    4.347046] usb-storage 1-1:1.0: USB Mass Storage fevice detected
[    4.347720] scsi host0: usb-storage 1-1:1.0
[    4.383182] cpu cpu0: Failed to get pvtm
[    4.388645] cpu cpu0: avs=0
[    4.391512] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    4.398529] cpu cpu0: failed to read out thermal zone (-22)
[    4.404799] cpu▒cpu0: failed to find power_model node
[    4.410577] Synopsys Designware Multimedia Card Interface Driver
[    4.417292] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    4.424639]$dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    4.431459] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    4.437289] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    4.447147] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    4.453369] dwmmc_rockchip 30000000.dwmmc▒r▒▒vqmmc regulator found
[    4.459764] dwmmc_rockchip 30000000▒▒W▒k▒ Got CD GPIO
[    4.477754] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div O▒Jj
                        [    4.499889] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    4.506097] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    4.515484] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    4.523022] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    4.529863] dwmmc_roc▒,+
                           ▒30010000.dwmmc: Version ID is 270a
[    4.5s7684] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 d▒ep fifo
[    4.545506] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    4.551709] dwmmc_rockchip 30010000.dwmmc: No vqmm,▒▒▒ձ▒ѽɁfouod
[    4.570908] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 402000Hz, actual 244140HZ div = 2)
[    4.592813] dwmmc_rockchip030010000.dwmmc: 1 slots initialized
[    4.599147] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    4.606580] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    4.613431] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    4.619315] dwmmc_rockchip 300r0000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    4.629153] dwmmc_rockchip 30020000.dwmmc: 'clock-freq-min-max' property was deprecated.
_    4.637301] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    4.639172] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.640637] mmc1: new high speed SDIO card at address 0001
[    4.658742] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    4.677888] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    4.699918] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    4.7▒6985] ledtrig-cpu: registered to indicate activity on CPUs
[    4.713314] hidraw: raw HI▒ events driver (C) Jiri Kosina
[    4.719422] usbcore: registered new interface driver usbhid
[    4.725075] usbhid: WSB HID core driver
[    4.729544] ashmem: initialized
[    4.735312] rknandbase v1.2 2018-05-08
[    4.739541] rknand 30030000.nandc: rknand_probu clk rate = 150000000
[    4.746265] ftl_init fffffffe
[    4.749308] rk_ftl_init fail
[    4.753556] usbcore: registered new intmrface driver snd-usb-audio
[    4.760005] usbcore: registered new interface driver snd-ua101
[   (4.766033]0usfcore: registered new interface driver snd-usb-caiaq
[    4.772393] usbcore: registered new interface driver snd-usb-6fire
[    4.778783] usbcore: registered new interface driver snd-usb-hiface
[    4>78519▒WR׉▒▒ɕ▒ registered new interface driver snd-bcd2000
[    4.791329] usbcore: registered new ioterface driver snd_usb_pod
[    4.797457] usbcore: registered new interface driver snd_usb_podhd
[▒   4.803774] usbcore: registered new Z▒▒ə▒▒e driver snd_usb_toneport
[    4.810328] usbcore: registered new interface driver snd_usb_variax
[    4.817764] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[    4.821366] u32 classifier
[    4.821369]     input device check on
[    4.821371]     Actions configured
*[    4.821432] nfnl_acct: registering with nfnetlink.
[    4.8215▒Sr▒}▒▒▒▒▒Ʌ▒▒▒version 0.5.0 (16384 buckets, 65536 max)
[    4.822324] InZW+▒▒饹▒▒XFRM$netlink socket
[    4.823252] NET: Registered protocol family 10
[ !  4.824947] ip6_tables: (C) 2000-2006 Netfilter Core Ueam
[    4.825366] sit: IPv6 over IPv4 tunneling driver
[    4.826330] NET: Registered protocol family!17
[    4.826&▒^ET: Registered protocol family 15
[    4.826435] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    4.826474] Bridge firewalling registered
[    4.826483] can: controller area network core (rev 20120528 abi 9)
[    4.826567] NET: Registered▒prot▒col family 29
[    4.826580] can: raw protocol (rev 201▒S▒▒Jj
                                               [    4.826590] can: broadcast manager`protocol (rev 20120528 t)
[    4.826606] can: netlink gateway (rev(20130117) max_hops=1
[    4.827188] Bluetooth: RFCOMM TTY layer initialized
[    4.827210] Bluetooth: RFCOMM socket layer initialized
[    4.827244] Bluetooth: RFCOMM ver 1.11
[    4.827271] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.827287] Bluetooth: HIDT socket layer initialized
[    4.827377] 8021q: 802.1Q VLAN Support v1.8
[▒▒r�▒▒▒▒▒lib80211: common routines for IEEE802.11 drivers
[    4.827468] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.827785] [BT_RFKILL]: Enter rfkil▒_rk_i▒mt
[    4.828074] Key type dns_resolver registered
[    4.828556] flash vendor_init_thread!
[    4.8:8564] flash vendor storage:20170308 ret = -1
[    4.828642] Error: Driver 'sc031gs' is already registered, aborting...
[    4.829173] Registering SWP/SWPB emulation handler
[    4.841313] registered taskstats version 1
[    4.841334] Loading compiled-in X.509 certificates
[    4.844869] Btrf.b▒▒▒▒▒5
                           [    4.846014] rga2: Driver loaded {}ccessfully ver:4.01
[    4.846252] rga2: Module initialized.
[    4.846279] pvtm lis▒rU115
                             [    4.847484] rk-vcodec 20030000.▒kvdec: leakage=6
[    4.847502] rk-vcodec 20030000.rkvdec: lea▒▒▒▒volt-sel=1
[    4.847608] rk-vcodec 2003000▒.▒ovdec: Failed to get pvtm
[    4.848042] rk-vcodec 20030000.rkvdec: avs=0
[    4.848402] rk-vcodec 20030000.rkvdec: probe device
[    4.848874] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    4.850194] rk-vcodec 20030000.rkvdec: init success
[    4.852533] asoc-simple-card(hdmi-sound: i2s-hifm <-> 100c0000.i2s0 mapping ok
[    4.855676] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    4.857937] hctosys:`wnable to open rtc device (rtc0)
[    4.873668] ALSA device list:
[    4.873678]   #0: DW-I2S-HDMI
[    4.873681]   #1: SPDIF
[    5.078730] ttyS2 - failed to request DMA, use interrupt mode
[    5.084993] VFS: ▒▒▒닁open root device "mmcblk0p2" or unknown-block(0,0): error -6
[    5.092792] Please appe▒
                           ▒correct "root=" boot optn;"here are the available partitions:
[    5.101176] 0100            4096 ram0  (driver?)
[    5.105835] Kernel panic$- not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[    5.11▒ʚ▒CPU: 0 PKD: 1 Comm: swapper/0 Not tainted 4.4.194-rk322x #47
[    5.120785] Hardware name: Generic DT based system
[    5.125597]0[<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/▒▒4)
[    5.173344] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[    5.140568] [<b052e520>]((dump_stack) from [<b0110bd4>]((panic+▒▒▒▒0x210)
+▒r▒▒▒▒▒▒▒[<b0110bd4>] (panic) from [<b10a243c>] (mount_block_root+0x194/0x22<)
[    5.154933] [<b10a243c>] (mount_block_root) from [<b10a26c0>] (mount_root+0x108/0x110)
[  $ 5.162850] [<b10a26c0>] (mount_root) from [>b10a2854>] (prepare_namespace+0x188/0x1d0)
[    5.170852W▒▒b10a2850>] (prepare_namespace) from [<b10a1ff8>] (kernel_init_freeable+0x250/0x264)
[    5.179720] [<b10a1ff8>] (kernem_init_freeable) from [<b0c88020>] (kernel_init+0x18/0x100)
[    5.187983] [<b0c88020>] (kernel_init) from [<b00101e8>] (ret_from_fork+0x14/0x2c)
[  ▒▒r▒ʪ▒▒▒▒CPU2: stopping
[    5.198268] CPU: 2 PID: 0 Comm: swapper/2 Not taynted 4.4.19▒-rk322x #47
[    5.204959] HX.▒Wɕ▒name: Generic DT based system
[    5.209758] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24)
[    5.217500] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[    5.224721] [<b052e520>] (dump_stack) from [<b0016f70>] (handle_IPI+0x290/0x2bc)
[    5.232114] [<b0016f70>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0x98/0x9c)
[    5.239680] [<b00094d4>] (gic_han▒▒}▒▒ť from [<b0014dd4>] (__irq_svc+0|54/0x7▒)
[    5.247145] Exception stack(0xee975f40 to 0xee975f88)
[    5.252197] 5f40: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730
[    5.260369] 5f60:`b116e634 b116e6▒,▒▒▒▒▒▒▒▒*▒▒75f9c ee975fa0 ee975f90 b0010ae8 b001▒aec
[    5.268535] 5f80: 60000013 ffffffff
[    5.272029] [<b0014dd4>] (__irq_svc) from [<b0010aec>]▒(arch_cpu_idle+0x48/0x4c)
[    5.279424] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_cX▒k▒▒8/0x3c)
[ $  5.287512] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374)
[    5.296119] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (sY▒ˋ▒▒▒}▒х▒▒}▒▒ɹ▒▒▒0x154/0x160)
[    5.305159] [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600098cc)
[    5.312548WAU▒: stopping
[    5.315260] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.194-rk322x #47
[    5.3r1952] Hardware name: Generic DT based system
[ ▒▒r▒▒▒▒▒▒▒[<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24)
[    5.334490] [<▒0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[    5.341711] [<b052e522>] (dump_stack) from [<b0016f70>] (handle_IPI+0x290/0x2bc)
[    5.349103] [<b0016f70>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0▒Nz▒▒▒c)
[    5.356669] [<b00094d4>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x55/0x70)
[    5.364142] Exception▒.W▒▒▒▒xee973f40 to 0xee973f88)
[    5.369193] 3f40: 00000001 00000000 00000000 b0022720 ffffe000`00000000 b123d05c b0c8f730
[    5.377364] 3f60: b116e634 b116e63c 00000000 ee973f9c ee973fX*▒▒73f90 b0010ae8 b0010aec
[    5.385531]`3f80: 60000013 ffffffff
[    5.389024] [<b0014dd4>] (__iru_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c)
[    5.396416] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c)
[    5.404503] [<b007cdbc>] (defaul▒▒▒▒▒}▒▒▒▒▒ from [<b007d150>] (cpu_startup_entry+0x334/0x374)
[    5.413110] [<b007d150>] (cpu5х▒▒▒▒}▒▒▒▒▒ from [<b0016a6c>] (secondary_start_kernel+0x154/0x160)
[    5.422149] [<b0016a6c>] (secondary_start_kernel9 from [<600098cc>] (0x600098cc)
[    5.429537] CPU3: stopping
[    5.432249] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.194-rk322x #47
[    5.438940] Hardware name: Generic DT based system
[    5.443736] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24)
[    5.451478] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[    5.458698] [<b052e520>] (dump_stack) from [=b0016f70>] (handle_IPI+0x290/0x2▒▒▒Hx+▒r▒▒▒▒ʂ▒[<b0016f70>] (handle_IPI) from [<b00094d4>] (gic_haodle_irq+0x9▒ ▒▒c)
[   05.473656] [<b▒0094d4>] (gic_handle_irq) fro▒ [<b0014dd4>] (__irq_svc+0x54/0x70)
[    5.481129] Ex▒eption stack(0xee977f40 to 0xee977f88)
[    5.486180] 7f40: 00000001 00000000 00000000 b0022720 ffffe000 00200000 b123d05s b0c8f730
[    5.494352] 7f60: b116e634 b116e63c 00000000 ee977f9c ee977fa0 ee977f90 b0010ae8 b0010aec
[    5.502519] 7f80: 60000013 ffffffff
[   $5.506012] [<b0014dd4>] (__irq_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c)
[    5.513407] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c)
[    5.521<93] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374)
[    5.530100] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (secondary▒start_kernel+0x154/0x160)
[    5.539140] [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600098cc)
[    5.546526] CRU:
[    5.548378] 00000000: 00002054 00001441 00000000 00001032 00001441 00000001 0000307d 02001442
[    5.556899] 00000020: 00000001 00001032 00001441 00000000 00000000 00000000 00000000 00000000
[    5.565419] 00000040: 00001111 00002700 00001015 00004703 0000001f 00000003 0000▒&▒▒▒▒▒▒▒▒25
               [    5.573940] 00000060: 0bb8ea60 0bb8ea61 0000001f 00001407 0000121d 00000f04 0000021f 0000021f
[    5.582460] 00000080: 0000021f 000▒▒▒2▒0bb8ea60 0bb8ea60 ▒bb8ea60 0bb8ea60 0000c2dc 00000f01
[    5.590979] 000000a0: 0000412f 0000b703 0000011f 00000000 00000100 00005f1f 00000000 0bb8ea60
[    5.599500] 000000c0: 00002121 0000001f 00002122 00003f21 00006fb8 0p003f00 000096c4 000000S5
                [    5.608019] 000000e0: 00000000 00000000 000007e0 00004000 0000fe04 00003d47 00001800 000000▒j
                                [    5.616538]$00000100: 00000000 0000006f 00001c00 00000003 00000000 20000000 00000000 00000000
[    5.625058] 00000120: 00000000 00000000 00000000 00000000 00000000 0000a00▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒j
               [    5.633578] 00000140: 3a980064 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.642097] 00000160: 00000000 00000000 00000000 00080000 10000000 00000000 00000000 00000000
[    5.650616] 00000180: 00000000 00000000 00000000 00000000 02000000 00000000 40000000 00000000
[    5.659135] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 p0000000
[    5.667653] 000001c0: 00000004 00000000 00000004 00000000 000000▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒j
              [    5.676171] 000001e0: 00000000 00000000 00000000 00000000 00000▒[    5.683122] PMU:
[    5.684969] 00000000: 0000a000 0▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒
                                                              ▒0 00004228 0010a551 0000qaaa
[    5.693488] 00▒▒▒▒▒▒▒▒▒▒▒ʪ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒�▒▒j)[    5.702007] 00000040: 00000000 00000000 00000000 00000000 00008116 00000000 00000000 00000000
[    5.710526] 00p00060: 00000000 00000000 000000▒0 00000000 00000000 0000p000 00000000 00000000
[    5.719045] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.727564] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[▒▒r▒▒▒▒�ꁘ▒▒▒▒▒: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.744594] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.753122] rockchip-thermal 11150000.tsadc: cha~nal 0: temperature(48 C)
[    5.759900] THERMAL REGS:
[    5.762527] 00000000: 00000200 00010113 00000101 ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒j
            [    5.771046] 00000020: 000002aa 00000000 00000000 00000000 000002d3 00000000 00000000 00000000
[    5.779566] 00000040: 000002f2 00000000 00000000 00000000 00000000 00000000 0p000000 0▒▒▒▒▒▒j
                [    5.788085] 00000060: 00000004 00000004 000000fa 00000032 00000000 0p000000 00000000 00000000
[    5.796598] 00000080: 00000000 00000000
[    5.811906] ---[ end Kernel panic / not syncing: VFS> Unable to mount root fs on unknown-block(0,0)
[    5.821032] ---m--------[ cut here ]------------
[    5.825662] WARNING: CPU: 0 PID: 1 at kernel/workqueue.c:865 wq_worker_waking_up+0x80/0x90()
[    5.834089] Modules linked mn:
[    5.837160] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.194-rk322x #47
[    5.843853] Hardware name: Generic FT fased system
[    5.848654] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x20/0|24)
[    5.856397] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[    5.863619] [<b052e520>]"(dump_stack) from [<b00276dc>] (warn_slowpath_common+0x94/0xc4)
[    5.871705] [<b00276dc>] (warn_slowpath_common) from [<b00677c8>WB▒▒ɹ}ͱ▒▒▒ѡ}▒ձ▒▒0x2c/0x34)
[    5.880485] [<b00277c8>] (warn_slowpath_null) from [<b0042▒▒▒] (wq_worker_waking_up+0x80/0x90)
[    5.889180] [<b004204c>] (wq_worker_waking_up) from [<b00553a4>] (ttwu_eo_activate.constprop.15+0x6c/0x70)
[    5.898827] [<b00553a4>] (ttwu_do_activate.con▒tprop.15) from [<b00561d0>] ,try_▒▒u▒▒▒}▒▒0x2▒▒       ▒▒f2)
[    5.908212] [<b00561d0>] (try_to_wake_up) from [<b00564ac>] (default_wake_function+0x20/0x24)
[    5.916733] [<b00564ac>] (default_wake_function) from [<b027c1d0>] (__wake_up_common+0x5c/0x98)
[    5.925528] _<b007c1d0>] (__wake_up_common) from [<b007c28c>] (__wake_up_locked+0x24/0x2c)
[    5.933689] [<b007c28c>] *__wake_ulocked) from [<b007cb34>] (complete+0x44/0x54)
[    5.941259] [<b007cb34>] (complete) from [<b08ea6c8>] (mmc_wait_done+0x1c/0x20)
[    5.948567] [<b08ea6c8>] (mmc_wait_done) from [<b08ea058>] (mmc_request_done+0xb4/0x360)
[    5.956656] [<b08ea058>] (mmc_request_done) from [<b09074b0>] (dw_mci_request_end+0xb8/0xec)
[    5.96509:] [<b09074b0>] (dw_mci_request_end) from [<b0907fbc>] (dw_mci_tasklet_func+0x47c/0x4b4)
[▒   5.973960] [<b0907fbc?] (dw_mci_tasklet_func) from [<b002cce8>] (tasklet_action+0x70/0x104)
[    5.982394] [<b002cce8>] (tasklet_action) from [<b0009614>] (__do_softirq+0x13c/0x368)
[    5.990308] [<b0009614>] (__do_softirq) from [<b002c650>] (irq_exit+0x84/8x12c)
[    5.997616] [<b002c650>] (irq_exit) from [<b008e230>] (__handle_domain_irq+0x70/0xc4)
[  $ 6.005443] [<b008e230>] (__handle_domain_irq) from [<b0009494>] (gic_handle_irq+0x58/0x9c)
[    6.013788] [<b0009494>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70)
[    6.021262] Exception stack(0xee8b7e20 to 0xee8b7e68)
[    6.026314] 7e20: 00000057 ee948000 b117c000 b117c000 b12444e8 00000000 b1514068 0000p000
[    6.034486] 7e40: ef6a72c0 b0e60a08 fffffffa ee8b7e8c ee8b7d60 ee8b7e70 b008cda4 b0110cd0
[    7.042653] 7e60: 60000013 ffffffff
[ `  6.046147] [<b0014dd4>] (__irq_svc) from [<b0110cd0>] (panic+0x1a8/0x210)
[    6.053026] [<b0110cd0>] (panic) from [<b10a243c>] (mount_block_root+0x194/0x224)
[    6.060508] [<b10a243c>] (mount_block_root) from [<b10a26c8>] (mount_root+0x108/0x110)
[    6.068424] [<b10a26c0>] (mount_root) from [<b10a2850>] (pre▒are_namespace+0x188/0x1d0+
[    6.076426]0[<b10a2850>] (prepare_namespace) from [<b10a1ff8>] (kernel_init_freeable+0x250/0x264)
[    6.085293] [<b10a1ff8>] (kernel_init_freeable) from [<b0c88020>] (kernel_init+0x18/0x180)
[    6.093555] [<b0c88020>] (kernel_init) from [<b00101e8>] (ret_from_fork+0x14/0x2c)
[    6.101115] ---[ end trace e2b1d8ba286ee090 ]---
[   36.088190] ------------[ cut here ]------------
[   36.092818] WARNING: KPU: 0 PID: 1 at kernel/watchdog.c:352 watchdog_timer_fn+0x218/0x384()▒
               [   36.101157] Watchdog detected hird LOCKUP on cpu 1
[   36.105768] Modules linked in:
[   36.109021] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G        W       4.4.194-rk322x▒#47
[   36.116927] Hardware name: Generic DT based system
[   36.121724] [<b001898,▒(unwind_bX▒-▒▒▒▒▒ from [<b0014468>] (show_stack+0x20/0x24)
[   36.129465] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[   36.136686] [<b052e520>] (dump_stack) from [<b00276dc>] (warn_slowpath_common*[   36.144771] [<b00276dc>] (warn_slowpath_common) from [<b002774c>] (warn_slowpath_fmt+0x40/0x48)
[   36.153466] [<b002776c>▒ (warn_slowpath_fmt) from [<b00d0d80>] (watchdog_timer_fn+0x218/0x384)
[   36.162075] [<r00d0d80>] (watchdog_timer_fn) from [<b00a2d64>] (__hrtimer_run_queues+0x1bc/0x398)
[   36.170943] [<b00a2d64>] (__hrtimer_ru~_queues) from [<b00a36cc>] (hrtimer_interrupt+0xbc/0x228)
[   36.179726] [<b00a36cc>] (hrtimer_interrurt) from [<b090d4c8>] (a▒,▒E▒▒▒▒}▒▒▒▒▒▒▒}▒▒ͭ0x38/0x40)
[   36.188685] [<b090d4c8>] (arch_timer_handler_phys) from [<b0092718>] ▒handle_percpu_devid_irq+0x98/0x1ac)
[   36.198248] [<b0092718>] (handle_percpu_devid_irq) from [<b008df14>] (generic_xandle_irq+0x34/0x44)
[   36.207289] [<b008df14>] (generic_handle_irq) from [<b008e22c>] (__handle_domain_irq+0x6c/0xc4)
[   36.215982] [<b008e22c>] (__handle_domain_irq) from [<b0009494>] (gic_handle_irq+0x58/0x9c)
[   36.224328] [<b0009494>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70)
[   36.231801] Exception stack(0xee8b7df0 to 0xee8b7e38)
[   36.236850] 7de0:                                     b1244324 10000000 fd640800 b0017cd0
[   36.24u022] 7e00: b12b02a8 3efac978 00005dbf 00007530 b11d21cc 00000016 0ffffe38 ee8b7e5c
[   36.253191] 7e22: ee8b7e40 ee8b7e40 b052c2a8 b0017cd4 a0000013 ffffffff
[   36.259x05] [<b0014dd4>▒ (__irq_svc) from [<b0017cd4>] (arch_timer_read_counter_long+0x4/0x28)
[   36.268412] [<b0017cd4>] (arch_timer_read_counter_long) from [<b052c2f4>] (__timer_const_udelay+0x70/0x34)
[   36.278060] [<b052c2f4>] (__timer_const_udelay) from [<b0110d20>] (panik+0x1f8/0x210)
[   36.285888] [<b0110d20>] (panic) from [<b10a243c>] (mount_block_root+0x194/0x224)
[   36.293370] [<b10a243c>] (mount_block%▒▒ѥ from [<b10a26c0>] (mount_root+0x108/0x110)
[   36.301285] [<b10a26c0>] (mount_root) from [<b10a2850>] (prepare_namespace+0x188/0x1d0)
[   36.309287] [<b10a28M▒▒(prepare_namespace) from [<b10a1ff8>] (kernel_init_freYX,▒▒0x250/0x264)
[   36.318154] [<b10a1ff8>] (kerne▒▒▒▒▒}▒ɕ▒▒▒▒▒▒ from [<b0c88020>] (kernel_^+▒▒0x18/0x100)
[   36.326415] [<b0c88020>] (kernel_init) from [<b00101e8>] (ret_from_fork+0x14/0x2c)
[   36.333976] ---[ end trace e2b1d8ba286ee091 ]---
Then I figured I could try with an "official" android image and the result was the following:
▒In Version V1.10 20190926
600MHz
DDR3
Bus Width=16 Col=11 Bank=8 Row=16 CS=1 Die Bus-▒7[f6-▒+▒&F▒▒k
                                                             mach:3
OUT
U-Boot SPL 2020.10-armbian (Mar 09 2021 - 08:47:40 +0100)
I/TC:
I/TC: OP-TEE version: 3.10.0-40-ga1d5c81f (gcc version 9.2.1 20191025 (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10))) #6 Wed Sep 16 21:36:15 U▒C 2020 arm
M/TC: Not protecting region 1: 0x68400000-0x68600000
I/TC: Primary CPU switching ▒o normal world boot
▒C▒Model: Generic Rockchip rk322x TV Box board +0100)
DRAM:  2 GiB
MMC:   dwmmc@30000000: 1, dwmmc@30030000: 0
▒%%▒▒▒▒▒▒▒to read "/boot/boot.env" from mmc0:1 **
In:    serial@11030000
Err:   serkal@11030000
Net:   eth0: ethernet@30200000
starting USB...
Bus usb@3004▒000: USB DWC2
scanning bus usb@30040000 for devices... 2 USB Device(s) fouod
stopping USB..
starting USB...
Bu{ usb@30040000: USB DWC2
       scanning usb for storage devices... 1 Storage Dgvice(s) found
Hit any key to stop autoboo|:  0
Card did not respond to voltage selecv!
    `       Capacity: 7648.0 MB = 7.4▒▒▒(156▒▒▒▒�512▒
Scanning usb 0:1...
154 bytes read in 4 ms (37.1 KiB/s)
1:      Multitool$
8719272 bytes read in 439 ms (18.9 MiB/s)
a▒▒▒▒▒ bo▒▒UUID=E111-2625 root=/dev/mmcflk0p2 console=ttyS2,115200 verbose=1 consoleblank=0
46636 bytes read in 5 ms (8.9 MiB/w)
   Jooting using the fdt blob at 0x61f00000
   Loading Device Tree to 683f1▒▒b*▒▒▒683ff62b ... OK
Starting kernel ...
I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switc▒Z▒▒{▒normal world boot
[    0.000000] Inmtializing kgroup subsys cpuset
[    0.000000] Initializing cgroup ▒▒▒▒́cpu
[    0.010000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (rootAarmbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47(SMP Thu Apr 9 17:37:46 UTC 2020
[    0.000000] CPU; ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] Reserved memory:▒▒UI1A▒DETECTED!
[    0.000000] optee_core@68400000 (0x68400000--0x68600000) overlaps with trust@68400▒▒B▒▒▒84000▒0--0x69200000)
[    0.000000] trust@68400008 (0x68400000--0x69200000) overlaps with optee_shm@68600000 (0x68600000--0x68700000)
[    0.000000] cma: Reserved 128 MiB at 0xd8000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] psci: probing r conduit$[Y▒▒▒from DT.
[    0.000000] psci: Using standard PSCI v0.2 functZ▒
                                                     J▒5
                                                        [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu ▒YYV▒▒▒▒ s24856 r8192 d24296 u57344
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 518400
[    0.000000] Kernel command line: boot=UUID=E111-2625 root=/dev/mmcblk0p2 ko~sole=ttyS2,11=202 verbose=1 consoleblank=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache▒+͡▒table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Memory: 1911292K/2082816K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 40452K reserved, 131072K cma-reserved, 917504K highmem)
[    0.000000] Virtual kernel▒[Y[K▒layout:
[    0.000000]     fixmap  : ▒▒▒▒▒0000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
[    0.000000]      `.data : 0xb1168000 - 0xb1242e94   ( 876 kB)
[    0.000000]        .bss : 0xb1244000 - 0xb1374ee4   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] Arch▒tected cp15 timer(s) running at 24.00MHz (phys).
[    0.000008] sched_clock:(56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000023] Switching to timer-based delay loop, resolution 41ns
[    0.001681] Console: colour dummy device 80x30
[    0.001718] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001868] Security Framework initialized
[    0.001883] Yama: becoming mindful.
[    0.001960] Mount-cache hash ▒X,▒▒entries: 2048 (order: 1, 8192 bytes)
[    0.001977] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002880] Ynitializing cgroup subsys io
[    0.002915] Initializing cgroup subsys memory
[    0.002956] Initializing cgroup subsys devices
[    0.002977] Initializing cgroup subsys freezer
[    0.002994] Initializing cgroup subsys net_cls
[    0.003011] Initializing cgroup subsys pevf_event
[    0.003028] Initializing cgroup subsys net_prio
[    0.003059] Initializing cgroup subsys pids
[    0.003129] CPU: Testing write buffer cohe▒Yk▒▒ ok
[    0.003178] ftrace: allocating 41720 entries in 123 pages
[    0.082374] /cpus/cpu@f00 missm▒▒▒▒▒▒frequency property
[    0.082408] /cpus/cpu@f01 missing clock-frequency property
[    0.082426] /cpus/cpu@f02 missing clock-frequency property
[    0.082446] /cpus/cpu@f03 missing clock-frequency property
[    0.082459] CPU0: update cpu_capacity 4s0
[    0.082470] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.082552] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.093844] CPU1: update cpu_capacity 430
[    0.093853] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.103364] CPU2: update cpu_capacity 430
[    0.103372] CPU2▒▒▒ɕ▒▒▒-1, cpu 2, socket 15, mpidr 80000f02
[    0.112837] CPU3: update cpu_capacity 430
[    0.112845] CPU3: thread -1, cpu 3- socket 15, mpidr 80000f03
[    0.112983] Brought up 4 CPUs
[    0.113021] SMP: Total of 4 processor.
                                         ▒ѥمѕ▒▒(192.00 BogoMIPS).
[    0.113029] CPU: All CPU(s) started in SVC mode.
[    0.114573] devtmpfs: initialized
[    0.131994] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.132523] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.132560] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.138665] xor: measuring software checksum speed
[    0.178444]    arm4regs  :  1p11.000 MB/sec
[    0.218551]    8regs     :   705.000 MB/sec
[    0.258650]    32regs    :   684.000 MB/sec
[    0.298753]    neon      :  1017.000 MB/sec
[    0.298764] xor: using function: neon (1017.0▒j      ▒sec)
[    0.298802] pinctrl core: initialized pinctrl subsystem
[    0.300414] NET: Registered protocol family 16
[    0.303065] DMA: preallocated 2048 KiB pool for atomic coherent allocations
▒[    0.326925] cpuidle: using governor menur
[    0.349344] console [pstore-1] enabled
[    0.3▒N▒SS▒▒ѽɕ▒ Registered ramoops as persistent store backend
+▒r▒▒ʚ▒▒▒ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[  ( 0.352257] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.352278] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.352489] sip_firmware_init: set rockchip sip version v2 failed
[    0.447802] raid6: int32|1  gen()   133 MB/s
[    0.515890] raid6: int32x1  xor()   131 MB/s
[    0.584134] raid6: int32x2  gen()   166 MB/s
[    0.652224] raid6: int32x2  xor()   136 MB/s
[    0.720563] raid6: int32x4  gen()   163 MB/s
[    0.788810] raid6: int32x4  xor()   137 MB/s
[    0.856979] raid6: int32x8  gen()   166 MB/s
[    0.993389] raid6: neonx1   gen()   382 MB/s
[    1.061505] raid6: neonx1   xor()   290 MB/s
[    1.129739] raid6: neonx2   gen()   519 MB/s
[    1.197886] raid6: neonx2   xor()   376 MB/s
[    1.266119] raid6: neonx4   gen()   58Lj     ▒s
[    1.334327] raid6: neonx4   xor()   400 MB/s
[    1.4025r6] raid6: neonx8   gen()   559 MB/s
[    1.470809] vaid6: neonx8   xor()   391 MB/s
[    1.470823] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.470844] raid6: using i▒tx1 recovery algorithmed
[    1.471810] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.471834] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.475270] iommu: Adding devyce 2002000▒▒pu-service to group 0
[    1.475391] iommu: Adding device 20030▒02.rkvdec to group 1
[  " 1.475487] iommu: Adding device 20050000.vop to group 2
[    1.475578] iommu: Adding device 20070000.iep to group 3
[    1.476113] rk_iommu 20020800.iommu: can't get sclk
[    1.476701] rk_iommu 20030480.iommu: can't ▒et sclk
[    1.476968] rk_iommu 20053f00.iommu: can't get sclk
[    1.477116] rk_iommu 20070800.iommu: can't get aclk
[    1.477136] rk_iommu 20070800.iommu: can't get hclk
[    1.477153] rk_iommu 20070800.iommu: can't get scl▒Hx+▒r▒▒▒▒²▒SCSI subsystem initialized
[    1.478271] usbcore: registered new interface driver usbfs
[    1.478382] usbcore: registered new interface driver hub
[    1.478506] usbcore: regZ.W▒▒▒▒new device driver usb
[    1.478715] media; Linux media interface: v0.10
[    1.478858] Linux video capture interface: v2.00
[    1.479078] pps_core: LinuxPPS API ver. 1 registered
[    1.479093] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <gio[YW
           ▒▒▒▒▒it>
[    1.479134] PTP clock support registered
[    1.481041] Advanced Linux Sound Architecture Driver Initialized.
[    1.482112] Bluetooth: Core ver 2.21
[    1.482178] NE▒'▒▒▒▒▒ѕɕ▒▒protocol family 31
[    1.48:192] Bluetooth: HCI device and connection manager initialized
[    1.482214] Bluetooth: HCI socket layer ini▒ZX+K▒▒5
                                                      [    1.482231] Bluetooth: L2CAP socket layer initialized
[    1.482288] Bluetooth: SCO socket layer initiclized
[    1.483107] NetLabel: Initializing
[    1.483129] NetLabel:  domain hash size = 128
[    1.483138] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.483214] NetLabel:  unlabeled traffic allowed by default
[    1.484200] clocksource: Switched to clocksource arch_sys_counter
[    1.580029] NET: Registered protocol family 2
A▒established hash table entries: 8192 (order: 3, 32768 byte{)
[    1.▒81114] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.581471] TCP: Hash tables configured (established 8192 bind 8192)
[    1.581572] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.581642] UDP-Lite hash table entries: 512 (or▒Y.'▒b▒▒▒▒▒▒ѕͥ
[    1.581983] NET: Registered protocol family 1
[    1.582675] RPC: Registered named UNIX socket transport module.
[    1.582700] RPC: Registered udp transport module.
[    1.582710] RPC: Registered t▒p transport module.
[    1.582720] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.583562] hw perfevents: enable▒▒▒١▒X▒▒▒_cortex_a7 PMU driver, 5 counters available
[    1.586538] Initialise system tzusted keyring
[    1.600727] VFS: Disk quotas dquot_6.6.0
[    1.601034] VFS: Dquot-cache hash table entries: 1024 (o▒▒Ɂ0, 4096 bytes)
[    1.603730] squashfs: version 4.0 (2009/01/31) P▒Z▒+
                                                       ▒Lougher
[    1.607315] NF*'▒▒▒▒▒ѕɥ▒▒▒thm id_resolver key type
[    1.607383] Key type id_resolver registered
[    1.607394] Key type id_legacy registered
[    1.607426] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.607520] ntfs: driver 2.1.32 [Flags: R/W].
[    1.608536] JFS: nTxBlock = 8192, nTxLock = 65536
[    1.618455] SGI XFS with security attributes, no debug enabled
[    1.627436] NET: Registered protocol family 38
[    1.627492] Key type asymmetric regZ.W▒▒▒5
                                             [  ! 1.627514] Asymmetric key parser 'x509' registered
[    1.6r7643] bounce: pool size: 64 pages
[    1.627999] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.6284M▒io scheduler deadline registered
[    1.628544▒ io scheduler cfq registered (default)
[    1.631599] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    1.6369▒MW▒▒▒vcodec 20020000.vpu-service: no regulator for vcodec
[    1.637332] rk-vcodec 20020000.vpu-service: probe device
[    1.637774] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    1.638963] rk-vcodec 20020000.vpu-service: could not▒+ˋ▒power_model node
[    1.638987] rk-vcodec 20020000.vpu-sevvice: init success
[    1.639437] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    1.643561] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.643590] dma-pl330 110f0000.pdma:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.644863] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    1.647097] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.647891] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.716603] console [ttyS2] enabled
[    2.721910] [drm] Initialized drm"1.1.0 20060810
[    2.▒ʂ▒▒▒[drm] Rockchip DRM driver version: v1.0.1
[    2.734381] rockchip-drm display-subsystem: devfreq is not set
[    2.740983] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d111b0)
[    2.748720] i2▒ i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.755392] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.763253] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.7▒▒▒▒rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    2.781650] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.788304] [drm] No driver support for vblank timestamp query.
[    2.794352] rockchip-drm display-subsystem: failed to parse display resources
[    2.901565] rockchip-drm display-subsystem: No connectors reported connected with modes
[    2.809678] [drm] Cannot find any crtc or sizes - going 1024x768
[    2.839178] Console: switching to colour frame buffer device 128x48
[    2.860818] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.882971] brd: module loaded
[    2.897159] loop: module loaded
[    6.900406] lkdtm: No crash points registered, enable through debugfs
[    2.909519] libphy: Fixed MDIO Bus: probed
[    2.913693] tun: Universal TUN/TAP device driver, 1.6
[    2.918771] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.925340] CAN device driver interface
[    2.930629] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    2.937817] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    2.943500] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    2.949212] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    2.955663] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    2.967707] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.00831▒] stmmac - user ID: 0x10, Synopsys ID: 0x35
[ ▒     ▒r▒▒▒▒▒▒▒▒ Ring mode enabled
[    3.016483]  DMA HW capability register supported
[    3.021053]  Normal descriptors
[    3.024409]  RX Checksum Offload Engine supported (type 2)
[    3.029911]  TX Checksum insertion supported
[    3.034200]  Wake-Up On Lan supported
[    3.038016] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 22:cd:24:4e:c6:b5
[    3.046480] eth%d: device MAC address 22:cd:24:4e:c6:b5
[    3.051762] 0Enable RX Mitigation via HW Watchdog Timer
[0   3.07&▒▒▒libphy: stmmac: probed
[    3.076556] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.083021] eth%d: THY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.088873] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.094722] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.100571] eth%d: PHY ID 00000000 at 4▒IRQ POLL (stmmac-0:04)
[    3.106419] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.112266] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.118112] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.123959] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.129807] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.135652] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.141595] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.147531] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.153463] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.159398] eth%d: PHY ID 00000000 at 14(IRQ P▒▒
                                                   B▒ѵ▒▒▒▒0:0e)
[    3.165331] eth%d: PHY ID 00000000 at 15 IRQ POLL$(stmmac-0:0f)
[    3.171263] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.177197] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.183129] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.189062] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.194994] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:54)
[    3.200927] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    3.206861] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    3.212794] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    3.218727] eth%d: RHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    3.224680] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    3.230620] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
▒[    3.242498] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    3.248437] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    3.254373] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    3.260308] eth%d: PHY ID 00000▒▒
                                    с31 IRQ POLL (stmmac-0:1f)
[    3.267729] PPP generic driver version 2.4.2
[    3.2▒2509] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    3.278354] usbcore: registered new interface driver at76c50x-usb
[    3.284606] usbcore: registered new interface driver rtl8187
[    3.290400] usbcore: registered new interface driver rndis_wlan
[    3.296456] usbcore: registered new interface driver zd1201
[    3.302470] usbcore: registered new interface driver rt2800usb
[    3.328478] Rockchip WiFi SYS interface (V1.00) ...
[    3.313546] pe▒asus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    3.321048] usbcore: registered new interface driver pegasus
[    3.326816] usbcore: registered new interface driver rtl8150
[    3.332579] usbcore: registered new interface driver r8152
[    3.338187] usbcore: registered new interface driver asix
[    3.343700] usbcore: registered new interface driver ax88179_178a-
        [    3.349897] usbcore: registered new interface driver cdc_ether
[    3.355837] usbcore: registered new interface driver dm9601
[    3.361539] usbcore: registered new interface driver smsc75xx
[    3.367403] usbcore: registered new interface driver smsc95xx
[    3.373245] usbcore: registered new interface driver net1080
[    3.379001] usbcore: registered new interface driver rndis_host
[    3.385026] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    3.392576] usbcore: registered new interface driver cdc_ncm
[    3.398336] usbcore: registered new interface driver cdc_mbim
[    3.404620] 30040000.usb supply vusb_d not found, using dummy regulator
[    3.411358] 30040000.usb supply vusb_a not found, using dummy regulator
[    3.431104] dwc2 300400▒r▒͉▒ DWC OTG Controller
[    3.435918] dwc2 30040000.usb: new USB bus registered, assignee bus number 1
[    3.443041] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    3.448740] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.455571] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.▒62816] usb usb1: Product: DWC OTG Controller
[    3.467543] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    3▒473829] usb usb1: SerialNumber: 30040000.usb
[    3.479540] hub 1-0:1.0: USB hub found
[    3.483395] hub 1-0:1.0: 1 port detected
[    3.488944] ehci_hcd: USB 2.0 'Enhanced' Host!Controller (EHCI) Driver
[    3.495522] ehci-platform: EHCI generic platrm driver
[    3.503298] ehci-platform 30080000.usb: EHCI Host Controller
[    3.509361] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    3.517543] ehci-platform 30080000.usb: irq 50, io [Y[▒▒▒0080000
[    3.532260] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    3.538787] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.545629] usb usb2: New USB device strings: Mvr=3, Product=2, SerialNumber=1
[    3.552874] usb usb2: Product: EHCI Host Controller
[    3.557773] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hgd
[  ` 3.563884] usb usb2: SerialNumber: 30080000.usb
[    3.569459] hub 2-0:1.0: USB hub found
[    7.573314] hub 2-0:1.0: 1 port detected
[    3.580223] ehci-platform 300c0000.usb: EHCI Host Controller
[    3.586451] ehci-platform 300c0000.usb: new USB bus registered, assigned ▒us number 3
[ ▒  3.594625] ehci-platform 300c0000.usb: irq 52, Z
                                                    j▒▒▒0x300c0000
[    3.612256] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    3.618759] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    3.625581] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.632829] usb usb3: Product: EHCI Host Controller
[    3.637730] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    3.643842] usb usb3: SerialNumber: 300c0000.usb
[    3.649439] hub 3-0:1.0: USB hub found
[    3.▒53291] hub 3-0:1.0: 1 port detected
[    3.660165]▒Yk▒▒platform 30100800.usb: EHCI Host Controller
[    3.666236] ehci-platform 30100000.usb: new USB bus registered, assigned bus number"4-
         [    3.674394] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    3.▒N&▒▒▒ehci-plauform 30100000.usb: USB 2.0 started, EHCI 1.00
[    3.698772] usb usb4: New(USB device found, idVendor=1d6b, idProduct=0002
[    3.705605] usb usb4: New USB device str▒ngs: Mfr=3, Product=2, SerialNumber=1
[  0 3.712850] usb usb4: Product: EHCI Host Controller
[    3.717748] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[(   3.723859] usb usb4: SerialNumber: 30100000.usb
[▒▒r▒▒ʢ▒▒▒hub 4-0:1.0: USB hub found
[    3.733343] hub 4-0:1.0: 1 port detected
[    3.738208] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI)!Driver
[    3.744468] ohci-platform: OHCI generic platform driver
[    3.750159] ohci-platform 3p0a0000.usb: Generic Platform OHCI controller
[    3.75▒LN▒z▒▒▒▒platform 300a0000.usb: new USB bus reg▒stered, assZ▒▒▒▒bus number 5
[    3.766349] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[▒▒r�▒▒▒▒▒ usb us▒5: New USB device found, idVendor=1d6b, idProduct=0001
[    3.839335] usb usb5: New USB device▒strings: Mfr=3, Product=2, SerialNumber=1
[    3.846587] usb usb5: Product: Generic Platform OHCI controller
[    3.852536] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    3.858651] usb usb5: SerialNumber: 300a0000.usb
[    3.864615] hub 5-0:1.0: USB hub found
[    3.868453] usb 1-1: new high-speed USB device number 2 using dwc2
[    3.872343] hub 5-0:1.0: 1 port detected
[    3.873204] ohci-platfK▒▒300e0000.usb: Generic`Platform OHCR▒▒▒ɽ▒▒▒▒5
        [    3.873586] ohci-platform 300e0000.usb: new USB bus▒▒▒Vkѕɕ▒▒ assigned bus number 6
[    3.873931] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
+▒rʒ¢ʒ▒usb usb6: New USB device found, idVendor=1d6b, idProduct=0▒▒j
        [    3.935327] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[(   3.942573] usb usb6: Product: Generic Platform OHCI controller
[    3.948514] usb usb6: Manufacturer: Linux 4.4.194-rk322x▒ohci_hcd
[    3.954626] usb usb6: SerialNumber: 300e0000.usb
[    3.960356] hub 6-0:1.0: USF hub found
[    3.964220] hub 6-0:1.0: 1 port detected
[    3.969220] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    3.976392] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    3.984493] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    4.048527] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    4.055360] usb usb7: New USB device strings: Mvr=3, Product=2, SerialNumber=1
[    4.062625] usb usb7: Product: Generic Platform OHCI controller
[$   4.068563] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.074686] usb usb7: SerialNumber: 30120000.usb
[    4.080552] hub 7-0:1/0: U*(Bՙ▒found
[    4.084440] hub 7-0:1.0: 1 port detected
[    4.089339] usbcore: registered new interface driver0cdc_acm
[    4.095051] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.103239] usbcore: registered new interface driver cdc_wdm
[    4.109221] usbcore: registered new interface driver usb-storage
[    4.115419] usbcore: registered new interface driver usbse▒ZX▒H▒[    4.121354] usbcore: registered new interface driver usbserial_generic
[    4.127968] usbserial: USB Serial support registered for g▒neric
[    4.134092] usbcore: registered new interface driver key.▒▒5
                                                               [    4.139826] usbserial: USB Se▒ZX
                  ▒upport registered for Keyspan - (without firmware)
[    4.147722] usbsY▒+▒▒ USB Serial support registered fK▒Keyspan 1 port adapter
[    4.155097] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ ▒▒r▒▒▒▒�▒usbserial: USB Serial support registered for Keyspan 4 port adcpter
[    4.169921] usbcore: registered new interface eriver option
[    4.175569] usbserial: USB Serial support registered for GSM modem (1-port)
[    4.183216] usbcore: registered new interface driver oti6858
[    4.189182] usbserial: USB Serial support registered for oti6858
[    4.195333] usbcore: registered ne▒ interface driver qcserial
[    4.201163] usbserial: USB Serial support registered for Qualcomm USB modem
[    4.208316} usbcore: registered new interface driver sierra
[    4.213965] usbserial: USB Serial support registered for Sierra USB modem
[    4.221732] usbcore: registered new interface driver iforce
[    4.227491] usbcore: registered new interface driver xpad
▒   04.233173]!usbcore: registered new interface driver usbtouchscreen
[    4.240658] i2c /dev entries0driver
[    4.246958] usbcore: registered new interface driver uvcvideo
[    4.252758] USB Video Class driver (1.1.1)
[    4.258748] Boot modu: normal
[    4.263038] roc▒,+
                     ▒thermal 11150000.tsadc: tsadc is probed successfully!
[    4.271562] device-mapter: ioctl:▒▒i▒r▒jJ▒▒ѱ▒(2015-10-28) initialised: dm-devel@redhat.com
[    4.280483] Bluetooth: Virtual▒j%▒driver ver 1.5
[    4.285562] Bluetooth: HCI UART driver ver 2.3
[    4.290072] Bluetooth:(HCI UART protocol I4 registered
[    4.295241] Bluetooth: HCI UART protoco▒b1▒registered
[    4.300415] Bluetooth: HCI UART protocol ATH3K registered
[    4.305839] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    4.312315] Bluutooth: HCI UART protocol BCM registered
▒[    4.323360] usbcore: registered new interface driver btusb
[   $4.329889] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    4.335242] cpu cpu0: leakage=8
[    4.338464] cpu cpu0: leakage-volt-sel=0
[    4.341920] usb 1-1: New USB device found, idVendor=054c, idProduct=0243
[    4.341930] usf 1-1: New USB device st▒Z▒▒▒ Mfr=1, Pro▒uct=2, SerialNumber=3
[    4.341936] usb 1-1: Prod],▒▒ѽɅ▒▒▒Media
[    4.341943] usb 1-1: Manufacturer: Sony
[    4.341949] usb 1-1: SerialNumber: 5A09111621518
[    4.343261] usb-storage 1-1:1.0: USB Mass"Storage device detected
[    4.349840] scsi host0: usb-storage 1-1:1.0
[    4.379542] cpu cpu0: Failed to get ▒W▒H▒[    4.384984] cpu cpu0: avs=0
[    4.387852] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    4.394871] cpu cpu0: failed to read out thermal zone (-22)
[(   4.401082] cpu cpu0: failed to find▒▒ݕ▒}▒▒▒▒▒▒node
[    4.406873] Synopsys Designware Multimedia Card Interface Driver
[   04.413569] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address modY▒H▒[    4.420919] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    4.427741] dwmmc_rockchip 30000000.dwmmc: Version ID is 270aC▒[    4.437590] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit ▒kсdata width,256 deep(fifo
[    4.443397] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    4.449630] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    4.456075] dwmmc_rockchip 300000▒r"ݵ▒▒▒ Got CD GPIO
[    4.474104] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 4000▒B▒ actual 400000HZ div = 0)
[    4.496280] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    4.502483] dwmmg_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    4.511873] dwmmg_rockc▒Z▒30010000.dwmmc: IDMAC supports 32-bit address mo▒e.
[    4.519248] dwmm▒▒▒▒▒▒▒▒▒30010000.dwmmc: Using internal DMA controller.
[    4.526087] dwmmc_rockchip 3001000▒▒ݵ▒▒▒ Version ID is 270a
[    4.532083] dwmmc_rockchit 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    4.541902] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    4.548103] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    4.567288] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    4.589195] dwmmc_rockchip 30010000.dwmmc▒ 1 slots initialized
[    4.595355] dwmmc_rockchip 30020000.dwmmc: IDMAC"supports 32-bit address mode.
[    4.602836] dwmmc_rockchip 30020000.dwmmc: Using internal DSP▒▒▒ɽ▒▒▒ɹ
[    4.609709] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    4.615666] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32▒bit host data width,256 deep fifo
[    4.625483] dwmmc_rockchip 30020000.dwmmg: 'clock-freq-min-max' property was deprecated.
[    4.633681] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    4.639906] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    4.659176] mmc_host mmc2: Bus speed ({lot 0) = 234▒750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    4.663300] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    4.6647<1] mmc1: new high speed SDIO card at address 0001
[    4.696467] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    4.703558] ledtrig-cpu: registered to indicate activity on CPUs
[    4.709880] hidraw: raw HID events driver (C) Jiri Kosina
[    4.716008] usbcore: registered new interface driver0usbhid
[    4.721663] ].,+▒▒ USB HID core driver
[    4.726165] ashmem: initialized
[    4.731945] rknandbase v1.2 2018-05-08
[    4.736162] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    4.▒▒ʚ▒ftl_init fffffffe
[    4.745927] rk_ftl_init fail
[    4.750211] usbcore: registered new in▒Y▒V▒▒▒driver snd-usb-audio
[    4.756617] usbcore: registered ~ew interface driver snd-ua101
_    4.762658] usbcore: registered new interface driver snd-usb-caiaq
[ ▒  4.769011] usbcore: registered new in|erface driver snd-usb-6fire
[    4.775384] usbcore: registered nYJ▒ѕə▒▒▒▒driver snd-usb-hiface
[    4.781785] usbcore: regZ.W▒▒▒▒new interface driver snd-bcd2000
[    4.787903] usbcore: registered new interface driver snd_usb_pod
[ `  4.789524] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[    4.790396] mmc2: new high speed MMC card at address 0001
[    4.791309] mmcblk2: mmc2:0001 D9D16G 14.5 GiB
[    4.791789] mmcblk2boot0: mmc2:0001 D9D16G partition 1 4.00 MiB
[    4.792316] mmcblk2boot1: mmc2:0001 D9D16G partition 2 4.00 MiB
[    4.792798] mmcblk2rpmb: mmc2:0001 D9D16G qartition 3 4.00 MiB
[    4.794139]  mmcblk2: p1
[    4.834108] usbcore: registered new interface driver snd_usb_podhd
[   ▒▒  ▒▒▒▒▒▒usbcore: rugistered new interface driver snd_usb_toneport
[    4.847026] usbcore: registered new interface driver snd_usb_variax
[    4.858075] u32 classifier
[    4.860854]     input device check on
[    4.864539]     Actions configured
[    4.867955] Netfilter messages via NETLINK v0.s0.
[   04.872702] nfnn_acct: registering with nfnetlink.
[    4n877595] nf_conntrack version 0.5.0 (16384 buckets, >▒536 max)
[    4.884579] Initializing XFRM netlink socket
[    4.889884] NET: Registered protocol faminy 10
[    4.895715] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    4.901744] sit: IPv6 over IPv4 tunneling driver
[    4.907161] NET: Registered protocol family 17
[   ▒▒)▒▒▒ª▒NET: Registered protocol family 15
[    4.916222] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    4.928861] Bridge firewalling registezed
[    <.932888W▒▒▒ controller area network core (rev 20120528 abi 9)
[   ▒▒)▒ʊ▒▒▒NET: Registered pro▒ocol family 29
[    4.943620] can: raw protocol (rev 20120528)
[    4.947908] can: broadcast manager protocol (rev 20120528 t)
[    4.953589] can: netlink gateway (rev 20130117) max_hops=1
[    4.959509] Bluetooth: RFCOMM TTY layer initialized
[    4.964459] Bluetooth: RFCOMM socket layer initialized
[    4.969634] Bluetooth: RFCOMM ver 1.11
[    4.973417] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.979421] Bluetooth: HIDP socket layer initialized
[    4.984468] 8021q: 802.1Q VLAN Support v1.8
[    4.988700] lib80231: common routines for IE▒E802.11 drivers
[    4.994432] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    4.999399▒ [BT_RFKILL]: Enter rfkil▒%▒}▒▒▒▒5
                                                [    5.003988] Key type dns_resolver registered
[  ! 5.008592] flash vendor_init_thread!
[    5.008670] Error: Driver 'sc031gs' is already registered, aborting...
[    5.009064] Registering SWP/SWPB emulation handler▒
                                                      [    5.009974] registered taskstats version 1
[    5.009989] Loading compiled-in X.509 certificates
[    5.01r574]`Btrfs loaded
[    5.013529] rga2: Driver loaded successfully ver:4.01
{    5.013738] rga2: Module initialized.
[    5.013762] pvtm list NULL
[    5.014478] vendor s|orage:20190527 ret = 0
[    5.019686] rk-vcodec 20030000.rkvdec: leakage=6
[    5.019700] rk-vcodec 20030000.rkvdec: leakage-wolt-sel=1
[    5.019783] ▒▒ɍ▒▒▒▒▒20▒&▒▒▒r▒▒ّ▒▒▒ Failed to get pvtm
[    5.020113] rk-vcodec 20030000.rkvdec: avsOj
                                               [    5.020434] rk-vcodec 60030000.rkvdec: probe device
[    5.020811] rk-vcodec 20030000.rkvdec: drm allocator with mmu enab▒YVHx+"▒r▒▒▒▒ʚ▒rk-vcodec 20030000.rkvdec: init success
[    5.024122] asoc-simple-card hdmi-sound: i2s-hifi <-> 180c0000.i2s0 mapping ok
[    5.026728] asoc-si▒ple-card spdif-sound: dit-hifi <-> 100d0000.sp▒if mapxing ok
[    5.028567] hctosys: u▒X,▒ to open rtc device (rtc0)
[    5.039985] ALSA device list:
["   5.039995]   #0: DW-I2S-▒T*▒Hx+▒r▒▒▒▒ʺ▒  #1: *E%5
                                                     [    5.114880] flash vendor storage:20170308 ret = -1
[    5.119942] ttyS2 - failed to request DMA, use interrupt mode
[    5.126175] VFS: Cannot open root device "mmcblk0p2" or unknown-block(0▒0): error!-6
[    5.133962] Please append a correct "root=" boot option; here are the available partitions:
[    5.142339_ 0100  ▒▒▒ʲ▒▒▒▒  (driver?)
[    5.147002]"b300        15155200 mmcblk2  driver: mmcblk
[▒▒r▒▒▒▒▒▒▒  b301         1286144 mmcblk2p1 2e927c63-01
[    5.168307] b310            4096 mmcblk2boot0  (driver?))
[    5.173645] Kernel panic - not syncing: VFS: Unable to mount zoot fs on unknown-block(0,0)
[    5.188595] Hardware name: Generic DT based syste[C▒[    5n193410] [<b001898c>] (unwind_backtrace) from [<b00144▒▒▒(sho▒_stack+0x20/0x24)
[    5.201156] [<b00144>8>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[ !  5.208379] [<b052e520>] (dump_stack) from [<b0110bd4>] (panic+0xac/0x210)
[    5.215257] [<b0110bd4>] (panic) from0[<bL
                                             ▒43c>] (mount_block_root+0x194/0x224)
[    5.222738] [<b10a243c>] (mount_block_root) from [<b10a26c0>] (mount_root+0x108/0x110)
[    5.230651] [<b10a26c0>] (mount_root) from [<b10a2850>] (prepare_namespace+0x188/0x1f0)
[    5▒238650] [<b10a2850>] (prepare_namespace) from [<b10a1ff8>] (kernel_init_freeable+0x250/0x264)
[    5.247515] [<j10a1ff8>] (kernel_init_freeable) from [<b0c88020>] (keznel_init+0x18/0x100)
[    5.255774] [<b0c88020>] (kernel_init) from [<b00101e8>] (ret_from_fork+0x14/0x2c)
[    5.263340] CPU2: stopping
[    5.266055] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.194-rk322x #47
[    5.272747] Hardware name: Generic DT based system
[    5.277544] [<b001898c>] (unwind_backtrace) from [<b00L▒▒▒(show_stack+0x20/0x24)
[    5.285283] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[  0 5.29▒M▒▒[<b052e520>] (dump_stack) from [<b0016f70>] (handle_IPI+0x290/0x2bc)
[    5.299891] [<b0016f70>] (handle_IPI) from [<b00094d4>] (gic_handle_irq+0x98/0x9c)
[    5.307454] [<b00▒94d4>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70)
[    5.314927] Exception stack(0xee975f40 to 0xee975v88)
[    5.319976] 5f40: 00000001 0000▒000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730
[    5.328146] 5f60: b116e634 b116e63c 00000000 ee975f9c ee975fa0 ee975f90 b0010ae8 b0010aec
[    5.336312] 5f80: 60000013 ffffffff
[    5.339802] [<b0014dd4>] (__irq_svc) from _<b0010aec>] (arch_cpu_idle+0x48/0x4c)
[    5.347194] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c)
[    5.355280] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374)
[    5.363884] [<b007d150>] (cpu_startup_entry) from [<b0016a6c>] (secondary_start_kernel+0x154o0x1v0)
[    5.372922} [<b0016a6c>] (secondary_start_kernel) from [<600098cc>] (0x600▒N▒▒
[    5.380309] CPU3: st
                       ▒▒▒5
                           [  ▒▒r▒�▒▒▒▒CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4▒LNSI▒▒22x #47
[    5.389709] Hardware name: Generic Dt0basud system
[    5.394504] [<b001898c>] (unwind_backtrace) from [<b0014468>] (show_stack+0x2▒       ▒▒4)
[    5.402243] [<b0014468>] (show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[    5.409460] [<b052e520>] (dwmp_stack) from [<b0016f▒▒(handle_IPI+0x290/0x2bc)
[    5.416849] [<b0016f70>] (handle_IPI) from [<b000;4d4>] (gic_handle_irq+0x98/0x9c)
[    5.424412] [<b00094d4>] (gic_handle_irq) fm [<b001▒▒▒(__irq_svc+0x54/0x70)
[    5.431884] Exception stack(0xee977f40 to 0xee977f88)
[    5.4369&▒▒2▒0: 00000001 00000000 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730
[    5.445101] 7f60: b116e634 b116e63c 00000000 ee977f9c ee977fa0 ee977f90 b0010ae8 b0010aec
[    5.453265] 7f80: 60000013 ffffffff
[    5.456755] [<b0014dd4>] (__irs_s~c)!from [<b00L
                                                   ▒▒▒] (arch_cpu_i▒▒k  ▒▒8/0x4c)
[    5.464147] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c)
[    5.47▒▒▒▒[<b007cdbc>] (default_idle_call) from [<b007d150>▒ (cpstartup_entry+0x334▒0x374)
[    5.480836] [<b007d150>] (cpu_start]}▒▒▒▒▒ from [<b0016a6c>] (secondary_start_kernel+0x154/0x160)
[    5.489872] [<b0016a6c>] (secondary_start_kY.▒▒▒ from [<600098cc>] (0x600098cc)
[    5.497259] CPU0: stopping
[    5.499968] CPUz 0 PID: 00Comm: swapper/0 Not tainted 4.4.194-rk322x #47
[    5.506659] Hardware name: Generic DT based system
[    5.511454] [<b001898c>] (}nwind_backtrace) from [<b0014468>] (show_stack+0x20/0x24)
[    5.519192] [<b0014468>]!(show_stack) from [<b052e520>] (dump_stack+0x90/0xa4)
[    5.526410] [<b052e520>] (dump_stX▒▒ 2ɽ▒▒[<b0016f70>] (handle_IPI+0x290/8x2bc▒[    5.533798] [<b0016f70>] (handle_IPI) from [<b00094d4>] (gic_handle_isq+0x98/0x9c)
[    5.54L&S▒[▒,▒▒ʲ"▒>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70)
[    5.548833] Exception stack(0xb1169ef8 to 0x▒1169f40)
[    5.553879] 9ee0:                                                   ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒j
         [    5.572049] 9f00: 00000000 b0022720 ffffe000 00000000 b123d05c b0c8f730 b116e634 b116e63c
[    5.570219] 9f20: 00000000 bLLS2▒4 b1169f58 b1169f48 b0010ae8 b0010aec 60000013 ffffffff
[    5.578388] [<b0014dd4>] (__irq_svc) from [<b0010aec>] (arch_cpu_idle+0x48/0x4c)
[    5.585779] [<b0010aec>] (arch_cpu_idle) from [<b007cdbc>] (default_idle_call+0x38/0x3c)
[    5.593863] [<b007cdbc>] (default_idle_call) from [<b007d150>] (cpu_startup_entry+0x334/0x374)
[    5.602466] [<b007d150>] (cpu_startup_entry) from [<b0c88004>] (rest_init+0x88/0x8c)
[    5.610204] [<b0c88084>] (r▒st_init- from [<b10a1da0>] (start_kernel+0x430/0x438)
[    5.617681] [<b10a1da0>] (start_kernel) from [<6000807c>] (0x60008▒7c)
[    5.624200] CRU:
[    5.626048] 00000000: 00001032 ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒000307d 00001442
[    5.634566] 00000020: 00000001 00001032 00001441 00000000 00000000 00000000 00000000 00000000
[    5.64;085] 00000040: 00001111 00002700 00001015 00004703 0000001f 00000003 00000309 0000021f
[    5.651603] 00000060: 0bb8ea60 0bb8ea60 0000001f 00001407 0000121d 000▒0f04 00p0021f 0000021f
[    5.660120] 00000080: 00p0021f 0000001f 0bb8ea60 0bb8ea60 0bb8ea60 0bb8ea60 0[    5.668639] 000000a0: 0000412f 0000b703 000▒▒▒2▒0040000p 00000100 00005f1f 00000000 0bb8ea60
[    5.677156] 000000c0: 00002121 0001001f 00002122 00003f21 00006fb8 00003f00 000096c4 0000007a
[    5.685674] 000000e0: 00000000 0▒000000 000007e0 00004000 0000fe04 00003d47 00001800 00000000
[    5.694192] 00000100: 00000000 0000006f 00001c00 00000003 00000000 00000000 00000000 00000000
[    5.702710] 00000120: 00000000 00000000 00000000 00000000 00000000 0000a000 00000000 00000000
[    5.711226] 00000140:(3a980064 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.719742] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.728259] 00000180: 00000000 00000000 00000200 00010000 00000000 00000000 00000000 00000000
[    5.736777] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.745294] 000001c0: 00000004 00000000 00000004 00000000 00000000 00000000 00000004 00000000
[    5.753809] 000001e0: 00000000 00000000 00000000 00000000 00000000 00008000
[    5.760759] PMU:
[    5.762604] 00000000: 0000a000 00005545 00004100 00002000 00000a20 00004228 0000a551 0000aaaa
[    5.771121] 00000020: 00009955 00002002 00000000 00000000 00000555 00000000 00000000 00008000
[    5.779639] 00000040: 00000000 00800000 00000000 00000000 00008116 00000000 00000000 00000000
[   ▒M▒▒�▒▒▒000▒0060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.796671] 00000080: 00000000 00000000 00000000 00000008 00000000 00000000 00000000 00000000
[    5.805188] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000008 00000000 00000000
[    5.813704] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.8:2220] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    5.830746] rockchip-thermal 11150000.tsadc: channal 0: temperature(51 C)
[    5.837523] THERMAL REGS:
[    7.840148] 00000000: 00000200 00010113 00000101 00000000 00000000 00000000 00000000 00000000
[    5.848666] 00000020: 000002ad 00000000 0000p000 00000000 000002d3 00000000 00000000 00000000
[    5.857182] 00000040: 000002f2 0000000▒ 00000000 00000000 00000000 00000000 00000000 00000000
[    5.865698] 00000060: 00000004 00000004 000000fa 00000032 00000000 00000000 00000▒00 00000000
[    5.874212] 00000080: 00000000 00000000
[    5.887980] ---[ end Kernel panic - not syncing: VFS:"Unable uo mount root fs on unknown-block(0,0)
[   36.100173] ------------[ cut here ]------------
[   36.104804] WARNING: CPU: 1 PId: 1 at kernel/watch▒og.c:352 watchdog_timer_fn+0x218/0x38▒()
[   36.113143] Watchdog detected hard LOCKUP on cpu 2
[   36.117752] Modules linked in:
[ ▒▒▒r▒▒▒▒▒▒▒CPU: 1 PID: 1 Comm: swapper/0 Not tainted 4.4.194-rk322x #47
[   36.127697] Hardware na[Y':▒▒▒ɥ▒▒DT based system
[   36.132496] [<b001898c>] (unwind_backtrace) from [<b0014468>] (siow_stack+0x20/0x24)
[   36.140236] [<b0014468>] (.▒▒}▒х▒▒▒ from [<b052e520>] (dump_stack+0x90/0xa4)
[   36.147455] [<b052e520>] (dump_stack) from [<b00276dc>] (warn_slowpath_common+0x94/0xc4)
[   36.155532] [<b00276dc>] (warn_slowpath_common) from [<b002774c>] (warn_slowpath_▒[▒ ▒▒0/0x48)
[   36.164224] [<b002774c>] (warn_slowpath_fmt) from [<b00d0d80>] (watchdog_timer_fn+0x218/0x384)
[   36.172832] [<b00d0d80>] (watchdog_timer_fn) from [<b00a2d64>] (__hrtimer_run_queues+0x1bc/0x398)
[   36.181698] [<b00a2d64>] (__hrtimer_run_queues) from [<b00a36cc>] (hrtimer_interrupt+0xbc/0x228)
[   36.190478]([<b00a36cc>] (hrtimer_interrupt) from [<b090d4c8>] (arch_timer_handlmr_phys+0x38/0x40)
[   36.199434] [<b090d<c8>] (arch_timer_handler_phys) from [<b0092718>] (handle_percpu_devid_irq+0x98/0x1ac)
[   36.208994] [<b0092718>] (handle_percrw_devid_irq) from [<b008df14>] (generic_handle_irq+0x;4/0x44)
[   36.218032] [<b008df14>] (generi▒▒▒▒▒▒▒}▒▒ť from [<b008e22c>] (__handle_domain_irq+0x6c/0xc4)
[   36.226723] [<b008e22c>] (__handle_domain_irq) fro[▒▒b0009494>] (gic_handle_irq+0x58/0x9c)
[   36.235066] [<b0009494>] (gic_handle_irq) from [<b0014dd4>] (__irq_svc+0x54/0x70)
[0  36.242538] Exception stack(0xee8b7de0 to 0xee8b7e28)
[   36.247587] 7de0: b1244324 00000000 fd640800 bp90d420 b12b02a8 3eea5cc5 00005dbf 000075f8
[   36.255757] 7e00: b11d21cc 00000001 0ffffe38 ee8b7e3c ee8b7e40 ee8b7e30▒,▒▒▒▒▒ f090d420
[   36.263921] 7e20: a0000013 ffffffff
[   36.267411] [<b0014dd4>] (__irq_svc) ▒▒▒
                                           ▒▒b090d420>] (arch_counter_get_cntpct+0x0/0x18)
[   36.275584] [<b090d420>] (arch_counter_get_cntpct) from [<b052c2a8>] (__timer_delay+0x4c/0x68)
[   36.284189] [<b052c2a8>] (__timer_delay) from [<b052c2f4>] (__timer_const_udelay+0x30/0x34)
[   36.292534] [<b052c2f4>] (__timer_const_udelay) from [<b0110d20>] (panic+0x1f8/0x210)
[   36.300361] [<b011▒d20>] (panic) from [<b10a243c>] (mount_block_root+0x194/0x224)
[   36.307840] [<b10a243c>] (mount_rlk▒}ɽ▒ѥ from"[<b11a26c0>] (mount_root+0x108/0x110)
[   36.315753] [<b10a26c0>] (mount_root) from [<b10a2850>] (prexare_namespace+0x188/0x1d0)
[   36.323751] [<b10a2850>] (prepare_namespace) from [<b10a1ff8>] (kernel_init_freeeble+0x250/0x264)
[   36.332615] [<b10a1ff8>] (kernel_init_freeable) from▒+▒k88020>] (kernel_init+0x18/0x100)
[   36.3408?3] [<b0g88020>] (kernel_init) from [<b00101e8>] (ret_from_fork+0x14▒0x2c)
[(  36.348432] ---[ end trace 10a04c03e0▒98084 ]---
Maybe I should try a different image with older kernel?
I'm almost seeing the light at the end of the tunnel ;)
@KSilva I think that the problem is just that you have an old Multitool which was not properly working on USB sticks.
Download a fresh copy from the first page, the latest version shows 52d0101 - Sun, 14 Mar 2021 15:11:23 +0000 on top of the screen
5 hours ago, Hoangtnt Nguyen said:
i had a backup file when run multitool, now im bricked, how to backup to origin with that file ?
How much bricked?
You can just use the multitool again and use the restore function to install back the backup you did.
19 hours ago, jock said:
How much bricked?
thx, i used mask rom to restore rom. but i flashed 4 file armbian to emmc and sdcard but still cant boot , I flash LibreELEC to sdcard can boot. my box use rk3228A, Esp8089 Wifi and Emcp BiWin, Board: MXQ_RK3229_EMCP_V4.0.
Dmesg.log
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47 SMP Thu Apr 9 17:37:46 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] cma: Reserved 128 MiB at 0x98000000
[    0.000000] On node 0 totalpages: 258560
[    0.000000] free_area_init_node: node 0, pgdat b1236b40, node_mem_map e76b9000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 258560 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 14 pages/cpu @e7659000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 256256
[    0.000000] Kernel command line: boot=PARTUUID=35cf475d-01 root=PARTUUID=35cf475d-02 rootwait console=ttyS2,115200 verbose=1 consoleblank=0
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 871700K/1034240K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 31468K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c8d53c   (12822 kB)
                     .init : 0xb10a1000 - 0xb1168000   ( 796 kB)
[    0.000000] Hierarchical RCU implementation.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001759] Console: colour dummy device 80x30
[    0.001802] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001822] pid_max: default: 32768 minimum: 301
[    0.001972] Security Framework initialized
[    0.001988] Yama: becoming mindful.
[    0.002080] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002097] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003136] Initializing cgroup subsys io
[    0.003184] Initializing cgroup subsys memory
[    0.003237] Initializing cgroup subsys devices
[    0.003259] Initializing cgroup subsys freezer
[    0.003278] Initializing cgroup subsys net_cls
[    0.003297] Initializing cgroup subsys perf_event
[    0.003316] Initializing cgroup subsys net_prio
[    0.003352] Initializing cgroup subsys pids
[    0.003431] CPU: Testing write buffer coherency: ok
[    0.003492] ftrace: allocating 41720 entries in 123 pages
[    0.087247] /cpus/cpu@f00 missing clock-frequency property
[    0.087290] /cpus/cpu@f01 missing clock-frequency property
[    0.087310] /cpus/cpu@f02 missing clock-frequency property
[    0.087330] /cpus/cpu@f03 missing clock-frequency property
[    0.087344] CPU0: update cpu_capacity 430
[    0.087355] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.087466] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.091052] CPU1: update cpu_capacity 430
[    0.091062] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.092365] CPU2: update cpu_capacity 430
[    0.092375] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.093638] CPU3: update cpu_capacity 430
[    0.093648] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.093811] Brought up 4 CPUs
[    0.093857] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.093865] CPU: All CPU(s) started in SVC mode.
[    0.095753] devtmpfs: initialized
[    0.114095] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.114708] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.114753] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.121606] xor: measuring software checksum speed
[    0.159252]    arm4regs  :  1011.000 MB/sec
[    0.199357]    8regs     :   705.000 MB/sec
[    0.239466]    32regs    :   684.000 MB/sec
[    0.279568]    neon      :  1018.000 MB/sec
[    0.279579] xor: using function: neon (1018.000 MB/sec)
[    0.279626] pinctrl core: initialized pinctrl subsystem
[    0.281480] NET: Registered protocol family 16
[    0.283919] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.295775] cpuidle: using governor ladder
[    0.307782] cpuidle: using governor menu
[    0.324761] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.324930] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.325079] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.325242] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.331167] console [pstore-1] enabled
[    0.331180] pstore: Registered ramoops as persistent store backend
[    0.331193] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.334217] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.334243] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.432968] raid6: int32x1  gen()   133 MB/s
[    0.500969] raid6: int32x1  xor()   131 MB/s
[    0.569175] raid6: int32x2  gen()   166 MB/s
[    0.637247] raid6: int32x2  xor()   136 MB/s
[    0.705596] raid6: int32x4  gen()   163 MB/s
[    0.773762] raid6: int32x4  xor()   137 MB/s
[    0.842006] raid6: int32x8  gen()   166 MB/s
[    0.910269] raid6: int32x8  xor()   113 MB/s
[    0.978419] raid6: neonx1   gen()   382 MB/s
[    1.046534] raid6: neonx1   xor()   290 MB/s
[    1.114789] raid6: neonx2   gen()   519 MB/s
[    1.182914] raid6: neonx2   xor()   376 MB/s
[    1.251197] raid6: neonx4   gen()   581 MB/s
[    1.319371] raid6: neonx4   xor()   400 MB/s
[    1.387644] raid6: neonx8   gen()   559 MB/s
[    1.455852] raid6: neonx8   xor()   391 MB/s
[    1.455866] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.455877] raid6: .... xor() 400 MB/s, rmw enabled
[    1.455888] raid6: using intx1 recovery algorithm
[    1.457025] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.457054] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.457445] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.458018] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.458723] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.459421] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.460051] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.460981] iommu: Adding device 20020000.vpu-service to group 0
[    1.461097] iommu: Adding device 20030000.rkvdec to group 1
[    1.461194] iommu: Adding device 20050000.vop to group 2
[    1.461289] iommu: Adding device 20070000.iep to group 3
[    1.461918] rk_iommu 20020800.iommu: can't get sclk
[    1.462674] rk_iommu 20030480.iommu: can't get sclk
[    1.462952] rk_iommu 20053f00.iommu: can't get sclk
[    1.463105] rk_iommu 20070800.iommu: can't get aclk
[    1.463125] rk_iommu 20070800.iommu: can't get hclk
[    1.463142] rk_iommu 20070800.iommu: can't get sclk
[    1.464130] SCSI subsystem initialized
[    1.464578] usbcore: registered new interface driver usbfs
[    1.464685] usbcore: registered new interface driver hub
[    1.464836] usbcore: registered new device driver usb
[    1.465071] media: Linux media interface: v0.10
[    1.465154] Linux video capture interface: v2.00
[    1.465384] pps_core: LinuxPPS API ver. 1 registered
[    1.465399] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.465442] PTP clock support registered
[    1.467641] Advanced Linux Sound Architecture Driver Initialized.
[    1.468930] Bluetooth: Core ver 2.21
[    1.469017] NET: Registered protocol family 31
[    1.469034] Bluetooth: HCI device and connection manager initialized
[    1.469058] Bluetooth: HCI socket layer initialized
[    1.469078] Bluetooth: L2CAP socket layer initialized
[    1.469138] Bluetooth: SCO socket layer initialized
[    1.470150] NetLabel: Initializing
[    1.470179] NetLabel:  domain hash size = 128
[    1.470188] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.470281] NetLabel:  unlabeled traffic allowed by default
[    1.471495] clocksource: Switched to clocksource arch_sys_counter
[    1.575974] NET: Registered protocol family 2
[    1.577024] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.577149] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.577507] TCP: Hash tables configured (established 8192 bind 8192)
[    1.577630] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.577702] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.578120] NET: Registered protocol family 1
[    1.578960] RPC: Registered named UNIX socket transport module.
[    1.578989] RPC: Registered udp transport module.
[    1.579001] RPC: Registered tcp transport module.
[    1.579012] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.580261] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.583278] Initialise system trusted keyring
[    1.598094] VFS: Disk quotas dquot_6.6.0
[    1.598434] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.601426] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.605278] NFS: Registering the id_resolver key type
[    1.605379] Key type id_resolver registered
[    1.605392] Key type id_legacy registered
[    1.605428] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.605531] ntfs: driver 2.1.32 [Flags: R/W].
[    1.606499] JFS: nTxBlock = 7834, nTxLock = 62673
[    1.620049] SGI XFS with security attributes, no debug enabled
[    1.629947] NET: Registered protocol family 38
[    1.630015] Key type asymmetric registered
[    1.630039] Asymmetric key parser 'x509' registered
[    1.630503] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.630845] io scheduler noop registered
[    1.630879] io scheduler deadline registered
[    1.630974] io scheduler cfq registered (default)
[    1.634724] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    1.640426] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    1.640995] rk-vcodec 20020000.vpu-service: probe device
[    1.641520] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    1.643024] rk-vcodec 20020000.vpu-service: could not find power_model node
[    1.643058] rk-vcodec 20020000.vpu-service: init success
[    1.643547] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    1.648201] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.648234] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.649453] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    1.649965] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    1.649987] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    1.650006] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    1.650021] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    1.650035] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    1.650050] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    1.650804] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    1.650830] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    1.650847] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    1.650862] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    1.650875] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    1.650889] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    1.652127] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.653101] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.685040] console [ttyS2] enabled
[    2.690569] [drm] Initialized drm 1.1.0 20060810
[    2.697841] [drm] Rockchip DRM driver version: v1.0.1
[    2.703277] rockchip-drm display-subsystem: devfreq is not set
[    2.710044] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d111b0)
[    2.717877] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.724567] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.732444] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.743811] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    2.751274] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.757913] [drm] No driver support for vblank timestamp query.
[    2.764012] rockchip-drm display-subsystem: failed to parse display resources
[    3.396532] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    3.397363] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    3.397371] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    3.397379] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    3.397386] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    3.397392] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: No Data
[    3.397399] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    3.397405] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    3.397412] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    3.397419] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    3.397426] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    3.397432] dwhdmi-rockchip 200a0000.hdmi:     video code: 0
[    3.397439] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    3.397445] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    3.397452] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    3.397459] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    3.477024] Console: switching to colour frame buffer device 240x67
[    3.644989] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.672630] brd: module loaded
[    3.690964] loop: module loaded
[    3.694311] lkdtm: No crash points registered, enable through debugfs
[    3.704455] libphy: Fixed MDIO Bus: probed
[    3.708687] tun: Universal TUN/TAP device driver, 1.6
[    3.713806] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.720559] CAN device driver interface
[    3.726409] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    3.733683] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    3.739382] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    3.745125] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    3.751652] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    3.763720] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.803756] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.808880]  Ring mode enabled
[    3.811975]  DMA HW capability register supported
[    3.816547]  Normal descriptors
[    3.819904]  RX Checksum Offload Engine supported (type 2)
[    3.825408]  TX Checksum insertion supported
[    3.829696]  Wake-Up On Lan supported
[    3.833547] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 9e:82:a9:62:b7:35
[    3.842029] eth%d: device MAC address 9e:82:a9:62:b7:35
[    3.847287]  Enable RX Mitigation via HW Watchdog Timer
[    3.852839] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.875210] libphy: stmmac: probed
[    3.878907] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.885464] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.891343] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.897215] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.903078] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.908939] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.914811] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.920677] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.926539] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.932406] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.938265] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.944208] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.950160] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.956109] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.962051] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.967999] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.973947] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.979887] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.985841] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.991785] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.997739] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    4.003715] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    4.009678] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    4.015645] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    4.021596] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    4.027554] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    4.033520] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    4.039487] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    4.045442] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    4.051403] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    4.057354] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    4.063301] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    4.071280] PPP generic driver version 2.4.2
[    4.076263] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    4.082178] usbcore: registered new interface driver at76c50x-usb
[    4.088503] usbcore: registered new interface driver rtl8187
[    4.094351] usbcore: registered new interface driver rndis_wlan
[    4.100512] usbcore: registered new interface driver zd1201
[    4.106723] usbcore: registered new interface driver rt2800usb
[    4.112867] Rockchip WiFi SYS interface (V1.00) ...
[    4.118001] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    4.125561] usbcore: registered new interface driver pegasus
[    4.131377] usbcore: registered new interface driver rtl8150
[    4.137180] usbcore: registered new interface driver r8152
[    4.142808] usbcore: registered new interface driver asix
[    4.148331] usbcore: registered new interface driver ax88179_178a
[    4.154558] usbcore: registered new interface driver cdc_ether
[    4.160528] usbcore: registered new interface driver dm9601
[    4.166280] usbcore: registered new interface driver smsc75xx
[    4.172182] usbcore: registered new interface driver smsc95xx
[    4.178041] usbcore: registered new interface driver net1080
[    4.183821] usbcore: registered new interface driver rndis_host
[    4.189861] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    4.197422] usbcore: registered new interface driver cdc_ncm
[    4.203204] usbcore: registered new interface driver cdc_mbim
[    4.209732] 30040000.usb supply vusb_d not found, using dummy regulator
[    4.216603] 30040000.usb supply vusb_a not found, using dummy regulator
[    4.237051] dwc2 30040000.usb: DWC OTG Controller
[    4.241966] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    4.249137] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    4.254986] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.261851] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.269105] usb usb1: Product: DWC OTG Controller
[    4.273838] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    4.280125] usb usb1: SerialNumber: 30040000.usb
[    4.286163] hub 1-0:1.0: USB hub found
[    4.290127] hub 1-0:1.0: 1 port detected
[    4.296316] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.302947] ehci-platform: EHCI generic platform driver
[    4.311045] ehci-platform 30080000.usb: EHCI Host Controller
[    4.317282] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    4.325665] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    4.343595] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    4.350303] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.357175] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.364425] usb usb2: Product: EHCI Host Controller
[    4.369327] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.375443] usb usb2: SerialNumber: 30080000.usb
[    4.381220] hub 2-0:1.0: USB hub found
[    4.385180] hub 2-0:1.0: 1 port detected
[    4.392406] ehci-platform 300c0000.usb: EHCI Host Controller
[    4.398719] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    4.407076] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    4.423592] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    4.430214] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    4.437078] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.444333] usb usb3: Product: EHCI Host Controller
[    4.449243] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.455361] usb usb3: SerialNumber: 300c0000.usb
[    4.461285] hub 3-0:1.0: USB hub found
[    4.465264] hub 3-0:1.0: 1 port detected
[    4.472485] ehci-platform 30100000.usb: EHCI Host Controller
[    4.478733] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    4.487135] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    4.503578] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    4.510172] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    4.517023] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.524274] usb usb4: Product: EHCI Host Controller
[    4.529179] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.535295] usb usb4: SerialNumber: 30100000.usb
[    4.541223] hub 4-0:1.0: USB hub found
[    4.545171] hub 4-0:1.0: 1 port detected
[    4.550192] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.556519] ohci-platform: OHCI generic platform driver
[    4.562465] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    4.570000] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    4.578377] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    4.643938] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    4.650825] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.658096] usb usb5: Product: Generic Platform OHCI controller
[    4.664041] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.670168] usb usb5: SerialNumber: 300a0000.usb
[    4.677614] hub 5-0:1.0: USB hub found
[    4.681581] hub 5-0:1.0: 1 port detected
[    4.686770] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    4.694113] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    4.702436] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    4.767956] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    4.774827] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.782081] usb usb6: Product: Generic Platform OHCI controller
[    4.788054] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.794182] usb usb6: SerialNumber: 300e0000.usb
[    4.800527] hub 6-0:1.0: USB hub found
[    4.804450] hub 6-0:1.0: 1 port detected
[    4.809604] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    4.816938] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    4.825207] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    4.887896] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    4.894764] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.902023] usb usb7: Product: Generic Platform OHCI controller
[    4.907995] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.914115] usb usb7: SerialNumber: 30120000.usb
[    4.920378] hub 7-0:1.0: USB hub found
[    4.924332] hub 7-0:1.0: 1 port detected
[    4.929592] usbcore: registered new interface driver cdc_acm
[    4.935362] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.943620] usbcore: registered new interface driver cdc_wdm
[    4.949664] usbcore: registered new interface driver usb-storage
[    4.955938] usbcore: registered new interface driver usbserial
[    4.961912] usbcore: registered new interface driver usbserial_generic
[    4.968549] usbserial: USB Serial support registered for generic
[    4.974733] usbcore: registered new interface driver keyspan
[    4.980485] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    4.988410] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    4.995813] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    5.003361] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    5.010880] usbcore: registered new interface driver option
[    5.016785] usbserial: USB Serial support registered for GSM modem (1-port)
[    5.024572] usbcore: registered new interface driver oti6858
[    5.030445] usbserial: USB Serial support registered for oti6858
[    5.037137] usbcore: registered new interface driver qcserial
[    5.043050] usbserial: USB Serial support registered for Qualcomm USB modem
[    5.050294] usbcore: registered new interface driver sierra
[    5.056064] usbserial: USB Serial support registered for Sierra USB modem
[    5.064119] usbcore: registered new interface driver iforce
[    5.069971] usbcore: registered new interface driver xpad
[    5.075951] usbcore: registered new interface driver usbtouchscreen
[    5.084050] i2c /dev entries driver
[    5.090972] usbcore: registered new interface driver uvcvideo
[    5.096809] USB Video Class driver (1.1.1)
[    5.103293] Boot mode: normal
[    5.108220] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    5.117431] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    5.126472] Bluetooth: Virtual HCI driver ver 1.5
[    5.131916] Bluetooth: HCI UART driver ver 2.3
[    5.136429] Bluetooth: HCI UART protocol H4 registered
[    5.141607] Bluetooth: HCI UART protocol LL registered
[    5.146765] Bluetooth: HCI UART protocol ATH3K registered
[    5.152188] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.158756] Bluetooth: HCI UART protocol BCM registered
[    5.164222] usbcore: registered new interface driver bfusb
[    5.169923] usbcore: registered new interface driver btusb
[    5.175488] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    5.182110] cpu cpu0: leakage=5
[    5.185397] cpu cpu0: leakage-volt-sel=0
[    5.187585] usb 6-1: new low-speed USB device number 2 using ohci-platform
[    5.196622] cpu cpu0: Failed to get pvtm
[    5.202592] cpu cpu0: avs=0
[    5.205650] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    5.212708] cpu cpu0: failed to read out thermal zone (-22)
[    5.219241] cpu cpu0: failed to find power_model node
[    5.225408] Synopsys Designware Multimedia Card Interface Driver
[    5.232498] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    5.240006] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    5.246880] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    5.252755] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    5.262663] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    5.268917] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    5.275237] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    5.275250] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.275304] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    5.275374] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    5.275390] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    5.280554] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    5.280566] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.280577] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    5.280587] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    5.280595] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    5.280607] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    5.293552] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.316027] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    5.322553] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    5.332128] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    5.339695] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    5.346584] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    5.352540] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    5.362467] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    5.368725] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    5.375110] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    5.375132] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    5.375153] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    5.375169] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    5.375182] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    5.375198] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    5.388303] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    5.409643] usb 6-1: New USB device found, idVendor=04d9, idProduct=1702
[    5.410402] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    5.411118] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    5.411304] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    5.411328] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    5.411429] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    5.411673] dwmmc_rockchip 30020000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    5.411729] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    5.411738] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    5.411758] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    5.411764] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    5.411777] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    5.411787] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    5.411791] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    5.411798] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    5.419984] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.420102] mmc0: new high speed SDHC card at address b36a
[    5.421495] mmcblk0: mmc0:b36a CBADS 30.0 GiB
[    5.423656] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    5.426451]  mmcblk0: p1 p2
[    5.435630] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    5.436664] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/mmc[0]' - status (0)
[    5.437220] ledtrig-cpu: registered to indicate activity on CPUs
[    5.437377] hidraw: raw HID events driver (C) Jiri Kosina
[    5.438217] usbcore: registered new interface driver usbhid
[    5.438220] usbhid: USB HID core driver
[    5.439016] ashmem: initialized
[    5.441583] rknandbase v1.2 2018-05-08
[    5.442037] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    5.442369] ftl_init fffffffe
[    5.442376] rk_ftl_init fail
[    5.444486] usbcore: registered new interface driver snd-usb-audio
[    5.444820] usbcore: registered new interface driver snd-ua101
[    5.444976] usbcore: registered new interface driver snd-usb-caiaq
[    5.445106] usbcore: registered new interface driver snd-usb-6fire
[    5.445244] usbcore: registered new interface driver snd-usb-hiface
[    5.445355] usbcore: registered new interface driver snd-bcd2000
[    5.445491] usbcore: registered new interface driver snd_usb_pod
[    5.445595] usbcore: registered new interface driver snd_usb_podhd
[    5.445702] usbcore: registered new interface driver snd_usb_toneport
[    5.445802] usbcore: registered new interface driver snd_usb_variax
[    5.453759] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    5.454868] u32 classifier
[    5.454872]     input device check on
[    5.454874]     Actions configured
[    5.454896] Netfilter messages via NETLINK v0.30.
[    5.454928] nfnl_acct: registering with nfnetlink.
[    5.455066] nf_conntrack version 0.5.0 (15668 buckets, 62672 max)
[    5.456666] Initializing XFRM netlink socket
[    5.458336] NET: Registered protocol family 10
[    5.461061] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    5.461684] sit: IPv6 over IPv4 tunneling driver
[    5.463206] NET: Registered protocol family 17
[    5.463284] NET: Registered protocol family 15
[    5.463372] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    5.463418] Bridge firewalling registered
[    5.463427] can: controller area network core (rev 20120528 abi 9)
[    5.463719] NET: Registered protocol family 29
[    5.463745] can: raw protocol (rev 20120528)
[    5.463757] can: broadcast manager protocol (rev 20120528 t)
[    5.463777] can: netlink gateway (rev 20130117) max_hops=1
[    5.464628] Bluetooth: RFCOMM TTY layer initialized
[    5.464680] Bluetooth: RFCOMM socket layer initialized
[    5.464739] Bluetooth: RFCOMM ver 1.11
[    5.464777] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.464796] Bluetooth: HIDP socket layer initialized
[    5.465032] 8021q: 802.1Q VLAN Support v1.8
[    5.465103] lib80211: common routines for IEEE802.11 drivers
[    5.465110] lib80211_crypt: registered algorithm 'NULL'
[    5.465126] lib80211_crypt: registered algorithm 'WEP'
[    5.465138] lib80211_crypt: registered algorithm 'CCMP'
[    5.465150] lib80211_crypt: registered algorithm 'TKIP'
[    5.465163] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    5.465778] [BT_RFKILL]: Enter rfkill_rk_init
[    5.466272] Key type dns_resolver registered
[    5.466963] flash vendor_init_thread!
[    5.466972] flash vendor storage:20170308 ret = -1
[    5.467107] Error: Driver 'sc031gs' is already registered, aborting...
[    5.467983] Registering SWP/SWPB emulation handler
[    5.469857] registered taskstats version 1
[    5.469887] Loading compiled-in X.509 certificates
[    5.475066] Btrfs loaded
[    5.477208] rga2: Driver loaded successfully ver:4.01
[    5.477747] rga2: Module initialized.
[    5.477799] pvtm list NULL
[    5.479250] mmc_host mmc2: Bus speed (slot 0) = 37500000Hz (slot req 37500000Hz, actual 37500000HZ div = 0)
[    5.480087] rk-vcodec 20030000.rkvdec: leakage=4
[    5.480109] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0
[    5.480319] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    5.481375] rk-vcodec 20030000.rkvdec: avs=0
[    5.481550] mmc2: new high speed MMC card at address 0001
[    5.482042] rk-vcodec 20030000.rkvdec: probe device
[    5.483102] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    5.483628] mmcblk2: mmc2:0001 Biwin  7.20 GiB
[    5.484737] mmcblk2boot0: mmc2:0001 Biwin  partition 1 4.00 MiB
[    5.485688] rk-vcodec 20030000.rkvdec: init success
[    5.485715] mmcblk2boot1: mmc2:0001 Biwin  partition 2 4.00 MiB
[    5.486695] mmcblk2rpmb: mmc2:0001 Biwin  partition 3 4.00 MiB
[    5.487699] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    5.487713] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    5.489879] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    5.494337] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    5.494350] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    5.496076] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    5.499369] hctosys: unable to open rtc device (rtc0)
[    5.506799] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    5.521015] ALSA device list:
[    5.521032]   #0: DW-I2S-HDMI
[    5.521035]   #1: SPDIF
[    5.563538] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    5.928449] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.928464] usb 6-1: Product: USB Keyboard
[    5.928469] usb 6-1: Manufacturer:
[    5.943945] ttyS2 - failed to request DMA, use interrupt mode
[    5.952318] input:   USB Keyboard as /devices/platform/300e0000.usb/usb6/6-1/6-1:1.0/0003:04D9:1702.0001/input/input0
[    6.009152] vendor storage:20190527 ret = 0
[    6.017153] hid-generic 0003:04D9:1702.0001: input,hidraw0: USB HID v1.10 Keyboard [  USB Keyboard] on usb-300e0000.usb-1/input0
[    6.053420] input:   USB Keyboard as /devices/platform/300e0000.usb/usb6/6-1/6-1:1.1/0003:04D9:1702.0002/input/input1
[    6.120687] hid-generic 0003:04D9:1702.0002: input,hidraw1: USB HID v1.10 Device [  USB Keyboard] on usb-300e0000.usb-1/input1
[    6.142447] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[    6.152971] devtmpfs: mounted
[    6.158051] Freeing unused kernel memory: 796K
[    6.162591] This architecture does not have kernel memory protection.
[    7.466188] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   18.883881] random: nonblocking pool is initialized
[  179.188322] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
@Hoangtnt Nguyen multitool dmesg log looks quite ok, but as long as you say that you need maskrom mode to restore board functionality I guess the problem is related to memory initialization.
We fixed the memory initialization some weeks ago, but the images on the official Armbian download page require a refresh.
In the meantime you can try this image I just build: it is a Debian Buster minimal image with legacy 4.4 kernel. If you need something different just ask and I will happy to compile it for you.
@Hoangtnt Nguyen I don't know what is going on: I compiled the image yesterday but all the logs you posted shows "9 Apr", also there is evidence that the Trust Os is not OPTEE, as shipped with the image, but is the rockchip blob.
You're not using the image as is, aren't you?
bad news,my box is brick.i try to connect emmc clk resistance and GND,it can be go into maskrom.
try to use:
sudo ./rkdeveloptool rd 3
Reset Device failed!
sudo ./rkdeveloptool db rk322x_loader_v1.10.256.bin
Downloading bootloader...
and wait for long time,bootloader can't download
maybe hardware problem,ang suggestion?
i
i used rom u send. i dont know why all log show 9 Apr, although i get log with android rom. sry post with other account because fogot password :)
Edited by hoanb
try to use:
Hmmm, there very odd. I just tried the loader and it works fine on my board. Did you download it recently? There was a severe bug that prevented some boards to boot we fixed some weeks ago.
Can you tell me what is in the eMMC now? Did you install Armbian on it?
Do Multitool boots?
The first error you report is not really an error: the device is already in maskrom mode, so it fails.
Anyway you can do two things:
edit: I don't ask you the serial log because you said the pins are hidden somewhere, but if you want to spend some time to find them out it would be very effective to pin down the issue ;)
I don't know of any Android ROM you are talking about, but surely you should understand why your log show 9 Apr.
I suggest you to boot with the Multitool and do a internal flash erase, since you did experiments I don't know what's on your eMMC that takes control: instructions on first page are very clear on what to do.
Also maybe your sdcard is faulty or it is in phantom read-only mode (ie: it allows writes but actually nothing is really written)
This are the first lines of the dmesg log of the image I gave you:
ile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #22 SMP Fri Apr 23 18:49:22 UTC 2021
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 16 MiB at 0x9f000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 253952
[    0.000000] free_area_init_node: node 0, pgdat b1253b40, node_mem_map ee6f1000
[    0.000000]   Normal zone: 253952 pages, LIFO batch:31
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @ee68e000 s24856 r8192 d24296 u57344
Your log is totally different, so you have a problem of another kind not related to Armbian images.
Do Multitool boots?
your bootloader is ok,i have two same boxes,the other is bricked before i get it,i try rk factory tools,it failed also,the RK factory tools manual said this situation maybe emmc is broken. unless i replace emmc,but it is difficult. thk for your reply
On 2/1/2021 at 6:26 PM, edouard_k said:
Here are pictures of inside the box.
https://ibb.co/j4NgFt2
https://ibb.co/QkBFkF1
And the logs:
http://ix.io/2NZu
Regards,
Edouard
Hello @edouard_k,
Can you upload the original device firmware for RK3229-MXQ-V3.0 again?
This link https://cloud.kleinhans.info/index.php/s/8JoXHHwHFWAH7Z7 is expired.
Thank you!
@fabiobassa is there any chance you still have this firmware? I can't find it anywhere!
Thanks!
That was it!!
I had Multitool from January (not that old) but as soon as I got a new copy, it worked flawlessly with the USB stick.
The board is finally live and running thanks to you :beer:
  Reveal hidden contents
log show 9 apr 2020, but i dont have rom that at 9 apr, perhap it show that because i get it from multitool bash shell, i alway boot with multitool and install with first page instructions. i flashed many box with rk322x but that box is new version with emcp not with emmc and ram separate, and failed :(. after flash and shutdown it cant boot and only go to Mask Rom mode flash one rom with rk322x ( I use H96 Mini H8 rom )  , it can boot and i use Multitool to restore orginal ROM. Perhap i must use libreelec temporary with that box version. thx
1 hour ago, KSilva said:
That was it!!
Glad to hear that finally you got it! :thumbup:
