As already done with other topics this will be the start of a new thread collecting more information over time.
Since we had a lot of annoying discussions recently regarding Wi-Fi on Orange Pi Zero and in general I thought let's give it a try a few days ago. I did some preparations in the meantime (monitoring 24/7 Wi-Fi throughput in 2.4 GHz band for example) and then started to test in a not too crowded environment here.
As a start some quick Wi-Fi tests with a random 'quality' USB Wi-Fi dongle and 3 different Wi-Fi chipsets that can be found an a few boards Armbian supports:
  • RTL8192CU (used on a lot of cheap USB dongles and even on Lamobo R1)
  • Ampak AP6212 (based on Broadcom's BCM43438 module also used on RPi 3 and Zero W, nearly all Wi-Fi equipped NanoPi and Banana Pi)
  • RealTek RTL8723BS (used on Pine64+ and on CHIP for example)
  • RealTek 8189FTV (used on the more recent Wi-Fi equipped Orange Pi)
The usual Wi-Fi performance 'benchmark' results available here and there most of the time ignore a lot of important bits, eg.
  • Environment (Wi-Fi means shared media so in crowded areas with a lot of other Wi-Fis around you fight for free slots on the media, even USB3 peripherals or microwave ovens happily interfere with your Wi-Fi performance)
  • Environment (yeah, again: This time aerial/antenna used, position of antenna in relation to AP, distance, free sight or not, walls/stuff that filter or reflect signals)
  • Settings (Wi-Fi powermanagement enabled or not? Which cpufreq governor used? Performance results can vary based on at which clockspeed CPU cores run)
So for the test I chose to let all boards run with performance governor and Wi-Fi powermanagement disabled. All are equipped with the same el cheapo Xunlong aerial (sent with all Orange Pi that are Wi-Fi capable). Position of antenna is always the same, distance from AP (Fritzbox 7390) to board approx 50 cm, AP in cabinet (20mm MDF). Almost same environmental conditions (due to some testing delays I could not guarantee that Wi-Fi channel utilization was always the same but since I let a constant iperf3 monitoring run for the last couple of days I chose time slots where maximum throughput seemed to be possible).
Also no Ethernet connected (since it's easy to f*ck up performance tests in this scenario when wired and wireless interfaces of both device and router/AP are somehow all connected since some kernels then send packets over the wrong interface) and Wi-Fi connection established the usual way (nmtui --> 'Activate connection' --> done) with /etc/network/interfaces being empty (to let network-manager control all devices for smooth networking).
Now the results:
NanoPi Air with el cheapo Xunlong aerial, AP6212 module, Kernel 3.4.113, no BT configured: 39 Mbits/sec and 188 retransmits on average. Full log: http://sprunge.us/aPXb
tk@nanopiair:~$ iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120
Connecting to host 192.168.83.146, port 5201
[  4] local 192.168.83.167 port 52874 connected to 192.168.83.146 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec  4.48 MBytes  37.5 Mbits/sec   10   83.4 KBytes
[  4]   1.00-2.00   sec  4.44 MBytes  37.2 Mbits/sec    0   96.2 KBytes
[  4]   2.00-3.00   sec  4.26 MBytes  35.7 Mbits/sec    0    100 KBytes
[  4]   3.00-4.00   sec  4.53 MBytes  38.0 Mbits/sec    0    100 KBytes
[  4]   4.00-5.00   sec  4.47 MBytes  37.5 Mbits/sec    0    103 KBytes
[  4]   5.00-6.00   sec  4.49 MBytes  37.7 Mbits/sec    0    109 KBytes
[  4]   6.00-7.00   sec  4.21 MBytes  35.3 Mbits/sec    0    116 KBytes
[  4]   7.00-8.00   sec  4.33 MBytes  36.3 Mbits/sec    0    133 KBytes
[  4]   8.00-9.00   sec  4.25 MBytes  35.6 Mbits/sec    0    165 KBytes
[  4]   9.00-10.00  sec  4.30 MBytes  36.1 Mbits/sec    0    214 KBytes
[  4]  10.00-11.00  sec  5.01 MBytes  42.0 Mbits/sec    0    281 KBytes
[  4]  11.00-12.00  sec  4.82 MBytes  40.4 Mbits/sec    0    372 KBytes
[  4]  12.00-13.00  sec  5.17 MBytes  43.3 Mbits/sec    0    489 KBytes
[  4]  13.00-14.00  sec  4.34 MBytes  36.4 Mbits/sec    0    631 KBytes
[  4]  14.00-15.00  sec  5.25 MBytes  44.1 Mbits/sec    0    805 KBytes
[  4]  15.00-16.00  sec  4.76 MBytes  39.9 Mbits/sec   10    648 KBytes
[  4]  16.00-17.00  sec  4.81 MBytes  40.3 Mbits/sec    0    732 KBytes
[  4]  17.00-18.00  sec  4.62 MBytes  38.7 Mbits/sec    0    795 KBytes
[  4]  18.00-19.00  sec  4.74 MBytes  39.8 Mbits/sec    0    840 KBytes
[  4]  19.00-20.00  sec  4.55 MBytes  38.2 Mbits/sec    0    868 KBytes
[  4]  20.00-21.00  sec  4.86 MBytes  40.8 Mbits/sec    0    885 KBytes
[  4]  21.00-22.00  sec  5.24 MBytes  43.8 Mbits/sec    0    894 KBytes
[  4]  22.00-23.00  sec  4.85 MBytes  40.8 Mbits/sec    0    895 KBytes
[  4]  23.00-24.00  sec  4.74 MBytes  39.7 Mbits/sec    0    895 KBytes
[  4]  24.00-25.00  sec  4.40 MBytes  36.9 Mbits/sec    0    897 KBytes
[  4]  25.00-26.00  sec  5.26 MBytes  44.1 Mbits/sec    0    904 KBytes
[  4]  26.00-27.00  sec  5.05 MBytes  42.4 Mbits/sec   10    641 KBytes
[  4]  27.00-28.00  sec  4.73 MBytes  39.6 Mbits/sec    0    725 KBytes
[  4]  28.00-29.00  sec  4.95 MBytes  41.5 Mbits/sec    0    793 KBytes
[  4]  29.00-30.00  sec  4.56 MBytes  38.3 Mbits/sec    0    844 KBytes
[  4]  30.00-31.00  sec  4.69 MBytes  39.3 Mbits/sec    1    628 KBytes
[  4]  31.00-32.00  sec  4.75 MBytes  39.8 Mbits/sec    0    669 KBytes
[  4]  32.00-33.00  sec  4.52 MBytes  37.9 Mbits/sec   14    346 KBytes
[  4]  33.00-34.00  sec  4.47 MBytes  37.5 Mbits/sec   10    270 KBytes
[  4]  34.00-35.00  sec  4.72 MBytes  39.6 Mbits/sec    0    290 KBytes
[  4]  35.00-36.00  sec  4.94 MBytes  41.5 Mbits/sec    0    300 KBytes
[  4]  36.00-37.00  sec  4.81 MBytes  40.4 Mbits/sec    0    303 KBytes
[  4]  37.00-38.00  sec  4.58 MBytes  38.5 Mbits/sec    0    303 KBytes
[  4]  38.00-39.00  sec  4.86 MBytes  40.7 Mbits/sec    0    303 KBytes
[  4]  39.00-40.00  sec  4.75 MBytes  39.8 Mbits/sec   10    249 KBytes
[  4]  40.00-41.00  sec  4.27 MBytes  35.9 Mbits/sec    0    277 KBytes
[  4]  41.00-42.00  sec  4.83 MBytes  40.5 Mbits/sec    0    294 KBytes
[  4]  42.00-43.00  sec  4.49 MBytes  37.7 Mbits/sec    2    164 KBytes
[  4]  43.00-44.00  sec  4.41 MBytes  37.0 Mbits/sec    0    175 KBytes
[  4]  44.00-45.00  sec  4.55 MBytes  38.1 Mbits/sec    0    180 KBytes
[  4]  45.00-46.00  sec  4.72 MBytes  39.6 Mbits/sec    0    180 KBytes
[  4]  46.00-47.00  sec  4.78 MBytes  40.1 Mbits/sec    0    180 KBytes
[  4]  47.00-48.00  sec  4.74 MBytes  39.7 Mbits/sec   10    130 KBytes
[  4]  48.00-49.00  sec  4.90 MBytes  41.1 Mbits/sec    0    158 KBytes
[  4]  49.00-50.00  sec  4.39 MBytes  36.9 Mbits/sec    0    174 KBytes
[  4]  50.00-51.00  sec  4.66 MBytes  39.1 Mbits/sec   20   99.0 KBytes
[  4]  51.00-52.00  sec  4.44 MBytes  37.2 Mbits/sec    0    107 KBytes
[  4]  52.00-53.00  sec  4.49 MBytes  37.7 Mbits/sec    0    109 KBytes
[  4]  53.00-54.00  sec  4.59 MBytes  38.5 Mbits/sec   10   86.3 KBytes
[  4]  54.00-55.00  sec  2.02 MBytes  16.9 Mbits/sec    0    100 KBytes
[  4]  55.00-56.01  sec  4.08 MBytes  34.0 Mbits/sec    0    107 KBytes
[  4]  56.01-57.00  sec  4.43 MBytes  37.4 Mbits/sec    0    109 KBytes
[  4]  57.00-58.00  sec  4.41 MBytes  37.0 Mbits/sec    0    109 KBytes
[  4]  58.00-59.00  sec  4.69 MBytes  39.3 Mbits/sec    0    110 KBytes
[  4]  59.00-60.00  sec  4.29 MBytes  36.0 Mbits/sec    0    117 KBytes
[  4]  60.00-61.00  sec  4.91 MBytes  41.2 Mbits/sec    0    133 KBytes
[  4]  61.00-62.00  sec  4.28 MBytes  35.9 Mbits/sec   10    113 KBytes
[  4]  62.00-63.00  sec  4.23 MBytes  35.5 Mbits/sec    0    137 KBytes
[  4]  63.00-64.03  sec  4.95 MBytes  40.4 Mbits/sec    0    153 KBytes
[  4]  64.03-65.00  sec  4.45 MBytes  38.4 Mbits/sec    0    158 KBytes
[  4]  65.00-66.00  sec  4.00 MBytes  33.6 Mbits/sec   10    126 KBytes
[  4]  66.00-67.00  sec  4.47 MBytes  37.5 Mbits/sec    0    146 KBytes
[  4]  67.00-68.00  sec  4.37 MBytes  36.7 Mbits/sec    0    156 KBytes
[  4]  68.00-69.00  sec  4.69 MBytes  39.4 Mbits/sec    0    158 KBytes
[  4]  69.00-70.00  sec  4.21 MBytes  35.3 Mbits/sec    0    158 KBytes
[  4]  70.00-71.00  sec  4.91 MBytes  41.2 Mbits/sec    0    158 KBytes
[  4]  71.00-72.00  sec  4.44 MBytes  37.3 Mbits/sec    1    123 KBytes
[  4]  72.00-73.00  sec  3.99 MBytes  33.5 Mbits/sec    9    102 KBytes
[  4]  73.00-74.00  sec  4.50 MBytes  37.8 Mbits/sec    0    107 KBytes
[  4]  74.00-75.00  sec  4.04 MBytes  33.9 Mbits/sec    0    107 KBytes
[  4]  75.00-76.00  sec  4.41 MBytes  37.0 Mbits/sec    3   89.1 KBytes
[  4]  76.00-77.00  sec  4.75 MBytes  39.8 Mbits/sec    0    102 KBytes
[  4]  77.00-78.00  sec  4.53 MBytes  38.0 Mbits/sec    0    107 KBytes
[  4]  78.00-79.00  sec  4.78 MBytes  40.1 Mbits/sec    0    107 KBytes
[  4]  79.00-80.00  sec  4.92 MBytes  41.2 Mbits/sec    0    109 KBytes
[  4]  80.00-81.00  sec  4.84 MBytes  40.6 Mbits/sec    1   84.8 KBytes
[  4]  81.00-82.00  sec  3.96 MBytes  33.2 Mbits/sec    0    100 KBytes
[  4]  82.00-83.00  sec  4.78 MBytes  40.1 Mbits/sec    0    107 KBytes
[  4]  83.00-84.00  sec  4.14 MBytes  34.8 Mbits/sec    0    109 KBytes
[  4]  84.00-85.00  sec  4.46 MBytes  37.4 Mbits/sec    0    109 KBytes
[  4]  85.00-86.00  sec  4.43 MBytes  37.2 Mbits/sec    0    110 KBytes
[  4]  86.00-87.00  sec  4.74 MBytes  39.8 Mbits/sec    0    116 KBytes
[  4]  87.00-88.00  sec  4.95 MBytes  41.5 Mbits/sec    0    132 KBytes
[  4]  88.00-89.00  sec  4.41 MBytes  37.0 Mbits/sec    0    158 KBytes
[  4]  89.00-90.00  sec  4.26 MBytes  35.8 Mbits/sec    0    198 KBytes
[  4]  90.00-91.00  sec  4.63 MBytes  38.9 Mbits/sec    9    174 KBytes
[  4]  91.00-92.00  sec  4.33 MBytes  36.4 Mbits/sec    0    202 KBytes
[  4]  92.00-93.00  sec  4.84 MBytes  40.6 Mbits/sec    0    216 KBytes
[  4]  93.00-94.00  sec  4.47 MBytes  37.5 Mbits/sec    9    168 KBytes
[  4]  94.00-95.00  sec  4.42 MBytes  37.1 Mbits/sec    1    126 KBytes
[  4]  95.00-96.00  sec  4.66 MBytes  39.1 Mbits/sec    0    143 KBytes
[  4]  96.00-97.00  sec  4.14 MBytes  34.7 Mbits/sec    0    150 KBytes
[  4]  97.00-98.00  sec  4.53 MBytes  38.0 Mbits/sec    9    124 KBytes
[  4]  98.00-99.00  sec  4.49 MBytes  37.7 Mbits/sec    0    141 KBytes
[  4]  99.00-100.00 sec  4.45 MBytes  37.3 Mbits/sec    9    113 KBytes
[  4] 100.00-101.00 sec  4.80 MBytes  40.3 Mbits/sec    0    120 KBytes
[  4] 101.00-102.00 sec  4.76 MBytes  40.0 Mbits/sec    0    122 KBytes
[  4] 102.00-103.00 sec  4.76 MBytes  39.9 Mbits/sec    0    122 KBytes
[  4] 103.00-104.00 sec  4.08 MBytes  34.2 Mbits/sec    0    123 KBytes
[  4] 104.00-105.00 sec  4.78 MBytes  40.1 Mbits/sec    0    130 KBytes
[  4] 105.00-106.00 sec  4.48 MBytes  37.6 Mbits/sec    0    146 KBytes
[  4] 106.00-107.00 sec  4.82 MBytes  40.5 Mbits/sec    0    173 KBytes
[  4] 107.00-108.00 sec  4.34 MBytes  36.4 Mbits/sec    0    214 KBytes
[  4] 108.00-109.00 sec  4.33 MBytes  36.3 Mbits/sec    0    273 KBytes
[  4] 109.00-110.00 sec  4.72 MBytes  39.6 Mbits/sec    0    352 KBytes
[  4] 110.00-111.00 sec  4.70 MBytes  39.5 Mbits/sec    0    457 KBytes
[  4] 111.00-112.00 sec  4.79 MBytes  40.2 Mbits/sec   10    369 KBytes
[  4] 112.00-113.00 sec  4.58 MBytes  38.4 Mbits/sec    0    413 KBytes
[  4] 113.00-114.00 sec  4.72 MBytes  39.6 Mbits/sec    0    438 KBytes
[  4] 114.00-115.00 sec  4.81 MBytes  40.4 Mbits/sec    0    455 KBytes
[  4] 115.00-116.00 sec  4.45 MBytes  37.3 Mbits/sec    0    461 KBytes
[  4] 116.00-117.00 sec  4.85 MBytes  40.7 Mbits/sec    0    462 KBytes
[  4] 117.00-118.00 sec  4.82 MBytes  40.4 Mbits/sec    1    324 KBytes
[  4] 118.00-119.00 sec  4.49 MBytes  37.7 Mbits/sec    0    379 KBytes
[  4] 119.00-120.00 sec  4.91 MBytes  41.2 Mbits/sec    0    419 KBytes
[  4]   0.00-120.00 sec   549 MBytes  38.3 Mbits/sec  189             sender
[  4]   0.00-120.00 sec   548 MBytes  38.3 Mbits/sec                  receiver
iperf Done.
Reverse mode, remote host 192.168.83.146 is sending
[  4] local 192.168.83.167 port 52876 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  4.55 MBytes  38.2 Mbits/sec
[  4]   1.00-2.00   sec  5.03 MBytes  42.2 Mbits/sec
[  4]   2.00-3.00   sec  4.96 MBytes  41.6 Mbits/sec
[  4]   3.00-4.00   sec  4.96 MBytes  41.6 Mbits/sec
[  4]   4.00-5.00   sec  4.76 MBytes  39.9 Mbits/sec
[  4]   5.00-6.00   sec  4.90 MBytes  41.1 Mbits/sec
[  4]   6.00-7.00   sec  5.11 MBytes  42.9 Mbits/sec
[  4]   7.00-8.00   sec  3.29 MBytes  27.6 Mbits/sec
[  4]   8.00-9.00   sec  4.92 MBytes  41.3 Mbits/sec
[  4]   9.00-10.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  11.00-12.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  12.00-13.00  sec  4.80 MBytes  40.2 Mbits/sec
[  4]  13.00-14.00  sec  4.72 MBytes  39.6 Mbits/sec
[  4]  14.00-15.00  sec  4.88 MBytes  40.9 Mbits/sec
[  4]  15.00-16.00  sec  4.79 MBytes  40.2 Mbits/sec
[  4]  16.00-17.00  sec  4.88 MBytes  41.0 Mbits/sec
[  4]  17.00-18.00  sec  2.11 MBytes  17.7 Mbits/sec
[  4]  18.00-19.00  sec  4.55 MBytes  38.1 Mbits/sec
[  4]  19.00-20.00  sec  4.81 MBytes  40.4 Mbits/sec
[  4]  20.00-21.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  21.00-22.00  sec  5.01 MBytes  42.0 Mbits/sec
[  4]  22.00-23.00  sec  3.07 MBytes  25.8 Mbits/sec
[  4]  23.00-24.00  sec  4.75 MBytes  39.8 Mbits/sec
[  4]  24.00-25.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  25.00-26.00  sec  4.75 MBytes  39.8 Mbits/sec
[  4]  26.00-27.00  sec  3.06 MBytes  25.7 Mbits/sec
[  4]  27.00-28.00  sec  4.61 MBytes  38.7 Mbits/sec
[  4]  28.00-29.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  29.00-30.00  sec  4.92 MBytes  41.3 Mbits/sec
[  4]  30.00-31.00  sec  4.99 MBytes  41.9 Mbits/sec
[  4]  31.00-32.00  sec  4.87 MBytes  40.9 Mbits/sec
[  4]  32.00-33.00  sec  4.93 MBytes  41.3 Mbits/sec
[  4]  33.00-34.00  sec  5.04 MBytes  42.3 Mbits/sec
[  4]  34.00-35.00  sec  4.78 MBytes  40.1 Mbits/sec
[  4]  35.00-36.00  sec  4.95 MBytes  41.6 Mbits/sec
[  4]  36.00-37.00  sec  4.74 MBytes  39.8 Mbits/sec
[  4]  37.00-38.00  sec  4.65 MBytes  39.0 Mbits/sec
[  4]  38.00-39.00  sec  4.82 MBytes  40.4 Mbits/sec
[  4]  39.00-40.00  sec  4.80 MBytes  40.3 Mbits/sec
[  4]  40.00-41.00  sec  4.98 MBytes  41.8 Mbits/sec
[  4]  41.00-42.00  sec  4.34 MBytes  36.4 Mbits/sec
[  4]  42.00-43.00  sec  5.46 MBytes  45.8 Mbits/sec
[  4]  43.00-44.00  sec  2.89 MBytes  24.3 Mbits/sec
[  4]  44.00-45.00  sec  4.54 MBytes  38.1 Mbits/sec
[  4]  45.00-46.00  sec  3.20 MBytes  26.8 Mbits/sec
[  4]  46.00-47.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  47.00-48.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  48.00-49.00  sec  4.37 MBytes  36.6 Mbits/sec
[  4]  49.00-50.00  sec  4.64 MBytes  38.9 Mbits/sec
[  4]  50.00-51.00  sec  4.65 MBytes  39.0 Mbits/sec
[  4]  51.00-52.00  sec  4.71 MBytes  39.5 Mbits/sec
[  4]  52.00-53.00  sec  4.58 MBytes  38.5 Mbits/sec
[  4]  53.00-54.00  sec  4.74 MBytes  39.8 Mbits/sec
[  4]  54.00-55.00  sec  4.72 MBytes  39.6 Mbits/sec
[  4]  55.00-56.00  sec  4.44 MBytes  37.3 Mbits/sec
[  4]  56.00-57.00  sec  5.02 MBytes  42.1 Mbits/sec
[  4]  57.00-58.00  sec  4.60 MBytes  38.6 Mbits/sec
[  4]  58.00-59.00  sec  4.28 MBytes  35.9 Mbits/sec
[  4]  59.00-60.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  60.00-61.00  sec  5.03 MBytes  42.1 Mbits/sec
[  4]  61.00-62.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  62.00-63.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  63.00-64.00  sec  4.47 MBytes  37.5 Mbits/sec
[  4]  64.00-65.00  sec  4.67 MBytes  39.2 Mbits/sec
[  4]  65.00-66.00  sec  4.71 MBytes  39.5 Mbits/sec
[  4]  66.00-67.00  sec  4.85 MBytes  40.7 Mbits/sec
[  4]  67.00-68.00  sec  4.81 MBytes  40.3 Mbits/sec
[  4]  68.00-69.00  sec  4.71 MBytes  39.5 Mbits/sec
[  4]  69.00-70.00  sec  4.57 MBytes  38.3 Mbits/sec
[  4]  70.00-71.00  sec  4.61 MBytes  38.7 Mbits/sec
[  4]  71.00-72.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  72.00-73.00  sec  4.92 MBytes  41.3 Mbits/sec
[  4]  73.00-74.00  sec  4.98 MBytes  41.8 Mbits/sec
[  4]  74.00-75.00  sec  4.69 MBytes  39.3 Mbits/sec
[  4]  75.00-76.00  sec  5.01 MBytes  42.0 Mbits/sec
[  4]  76.00-77.00  sec  4.45 MBytes  37.4 Mbits/sec
[  4]  77.00-78.00  sec  4.64 MBytes  38.9 Mbits/sec
[  4]  78.00-79.00  sec  4.77 MBytes  40.0 Mbits/sec
[  4]  79.00-80.00  sec  4.71 MBytes  39.5 Mbits/sec
[  4]  80.00-81.00  sec  4.81 MBytes  40.4 Mbits/sec
[  4]  81.00-82.00  sec  4.80 MBytes  40.3 Mbits/sec
[  4]  82.00-83.00  sec  4.67 MBytes  39.2 Mbits/sec
[  4]  83.00-84.00  sec  4.85 MBytes  40.7 Mbits/sec
[  4]  84.00-85.00  sec  5.11 MBytes  42.9 Mbits/sec
[  4]  85.00-86.00  sec  4.96 MBytes  41.6 Mbits/sec
[  4]  86.00-87.00  sec  4.96 MBytes  41.6 Mbits/sec
[  4]  87.00-88.00  sec  4.66 MBytes  39.0 Mbits/sec
[  4]  88.00-89.00  sec  4.92 MBytes  41.3 Mbits/sec
[  4]  89.00-90.00  sec  4.99 MBytes  41.9 Mbits/sec
[  4]  90.00-91.00  sec  5.11 MBytes  42.9 Mbits/sec
[  4]  91.00-92.00  sec  5.00 MBytes  42.0 Mbits/sec
[  4]  92.00-93.00  sec  5.00 MBytes  42.0 Mbits/sec
[  4]  93.00-94.00  sec  5.23 MBytes  43.9 Mbits/sec
[  4]  94.00-95.00  sec  5.24 MBytes  43.9 Mbits/sec
[  4]  95.00-96.00  sec  5.11 MBytes  42.9 Mbits/sec
[  4]  96.00-97.00  sec  5.07 MBytes  42.5 Mbits/sec
[  4]  97.00-98.00  sec  5.16 MBytes  43.3 Mbits/sec
[  4]  98.00-99.00  sec  5.17 MBytes  43.3 Mbits/sec
[  4]  99.00-100.00 sec  5.14 MBytes  43.1 Mbits/sec
[  4] 100.00-101.00 sec  5.08 MBytes  42.6 Mbits/sec
[  4] 101.00-102.00 sec  5.07 MBytes  42.5 Mbits/sec
[  4] 102.00-103.00 sec  5.12 MBytes  43.0 Mbits/sec
[  4] 103.00-104.00 sec  5.32 MBytes  44.6 Mbits/sec
[  4] 104.00-105.00 sec  4.81 MBytes  40.3 Mbits/sec
[  4] 105.00-106.00 sec  5.02 MBytes  42.1 Mbits/sec
[  4] 106.00-107.00 sec  5.02 MBytes  42.1 Mbits/sec
[  4] 107.00-108.00 sec  5.25 MBytes  44.1 Mbits/sec
[  4] 108.00-109.00 sec  3.59 MBytes  30.2 Mbits/sec
[  4] 109.00-110.00 sec  5.00 MBytes  42.0 Mbits/sec
[  4] 110.00-111.00 sec  5.01 MBytes  42.0 Mbits/sec
[  4] 111.00-112.00 sec  5.24 MBytes  43.9 Mbits/sec
[  4] 112.00-113.00 sec  5.10 MBytes  42.8 Mbits/sec
[  4] 113.00-114.00 sec  4.81 MBytes  40.4 Mbits/sec
[  4] 114.00-115.00 sec  3.92 MBytes  32.9 Mbits/sec
[  4] 115.00-116.00 sec  3.97 MBytes  33.3 Mbits/sec
[  4] 116.00-117.00 sec  4.80 MBytes  40.3 Mbits/sec
[  4] 117.00-118.00 sec  5.01 MBytes  42.0 Mbits/sec
[  4] 118.00-119.00 sec  4.99 MBytes  41.8 Mbits/sec
[  4] 119.00-120.00 sec  5.20 MBytes  43.6 Mbits/sec
[  4]   0.00-120.00 sec   574 MBytes  40.1 Mbits/sec  187             sender
[  4]   0.00-120.00 sec   571 MBytes  39.9 Mbits/sec                  receiver
iperf Done.
tk@nanopiair:~$ ping 192.168.83.146
PING 192.168.83.146 (192.168.83.146) 56(84) bytes of data.
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=3.39 ms
64 bytes from 192.168.83.146: icmp_seq=2 ttl=64 time=3.04 ms
64 bytes from 192.168.83.146: icmp_seq=3 ttl=64 time=3.27 ms
64 bytes from 192.168.83.146: icmp_seq=4 ttl=64 time=2.98 ms
64 bytes from 192.168.83.146: icmp_seq=5 ttl=64 time=2.94 ms
64 bytes from 192.168.83.146: icmp_seq=6 ttl=64 time=2.99 ms
64 bytes from 192.168.83.146: icmp_seq=7 ttl=64 time=3.22 ms
64 bytes from 192.168.83.146: icmp_seq=8 ttl=64 time=3.23 ms
^C
--- 192.168.83.146 ping statistics ---
8 packets transmitted, 8 received, 0% packet loss, time 7011ms
rtt min/avg/max/mdev = 2.941/3.136/3.392/0.163 ms
root@nanopiair:~# iwconfig wlan0
wlan0     IEEE 802.11  ESSID:"Snort-Honeynet"
          Mode:Managed  Frequency:2.472 GHz  Access Point: BC:05:43:BE:C1:E7
          Bit Rate=65 Mb/s   Tx-Power:32 dBm
          Retry min limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=5/5  Signal level=-27 dBm  Noise level=-91 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:198  Invalid misc:0   Missed beacon:0
root@nanopiair:~# nmcli dev wifi list
*  SSID                     MODE   CHAN  RATE       SIGNAL  BARS  SECURITY
*  Snort-Honeynet           Infra  13    54 Mbit/s  92      ▂▄▆█  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  75      ▂▄▆_  WPA1 WPA2
   EasyBox-116D28           Infra  5     54 Mbit/s  54      ▂▄__  WPA1 WPA2
   CubaLibre                Infra  11    54 Mbit/s  50      ▂▄__  WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  47      ▂▄__  WPA1 WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  35      ▂▄__  WPA1 WPA2
   EasyBox-188632           Infra  10    54 Mbit/s  29      ▂___  WPA1 WPA2
   DIRECT-1LC460 Series     Infra  10    54 Mbit/s  27      ▂___  WPA2
   WLAN-341381              Infra  11    54 Mbit/s  27      ▂___  WPA2
   FRITZ!Box 7490           Infra  6     54 Mbit/s  22      ▂___  WPA2
   OSA Alpenraum intern     Infra  6     54 Mbit/s  20      ▂___  WPA1 WPA2
   WLAN-872870              Infra  11    54 Mbit/s  20      ▂___  WPA2
   OSAs Gästenetzwerk       Infra  6     54 Mbit/s  19      ▂___  WPA1 WPA2
   FRITZ!Box 7490           Infra  1     54 Mbit/s  15      ▂___  WPA2
   WLAN-983298              Infra  11    54 Mbit/s  12      ▂___  WPA2
   o2-WLAN85                Infra  4     54 Mbit/s  10      ▂___  WPA2
   o2-WLAN91                Infra  5     54 Mbit/s  9       ▂___  WPA2
Pine64+ with same el cheapo Xunlong aerial, RTL8723BS module, Kernel 3.10.104, no BT configured: 39 Mbits/sec and 58 retransmits on average. Full log: http://sprunge.us/EffO
root@pine64:/home/tk# iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120
[  4] local 192.168.83.86 port 46265 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  5.43 MBytes  45.5 Mbits/sec    0    318 KBytes
[  4]   1.00-2.00   sec  5.36 MBytes  44.9 Mbits/sec    0    359 KBytes
[  4]   2.00-3.00   sec  5.23 MBytes  43.9 Mbits/sec    0    380 KBytes
[  4]   3.00-4.00   sec  5.01 MBytes  42.0 Mbits/sec    0    387 KBytes
[  4]   4.00-5.00   sec  5.40 MBytes  45.2 Mbits/sec    2    272 KBytes
[  4]   5.00-6.00   sec  5.34 MBytes  44.8 Mbits/sec    0    320 KBytes
[  4]   6.00-7.00   sec  5.29 MBytes  44.4 Mbits/sec    1    250 KBytes
[  4]   7.00-8.00   sec  5.32 MBytes  44.6 Mbits/sec    0    269 KBytes
[  4]   8.00-9.00   sec  4.84 MBytes  40.6 Mbits/sec    0    279 KBytes
[  4]   9.00-10.00  sec  5.12 MBytes  42.9 Mbits/sec    0    281 KBytes
[  4]  10.00-11.00  sec  5.20 MBytes  43.6 Mbits/sec    0    281 KBytes
[  4]  11.00-12.00  sec  5.07 MBytes  42.5 Mbits/sec    0    281 KBytes
[  4]  12.00-13.00  sec  4.87 MBytes  40.8 Mbits/sec    0    287 KBytes
[  4]  13.00-14.00  sec  4.81 MBytes  40.4 Mbits/sec    0    298 KBytes
[  4]  14.00-15.00  sec  4.99 MBytes  41.9 Mbits/sec    0    321 KBytes
[  4]  15.00-16.00  sec  4.85 MBytes  40.7 Mbits/sec    0    348 KBytes
[  4]  16.00-17.00  sec  4.79 MBytes  40.2 Mbits/sec    0    383 KBytes
[  4]  17.00-18.00  sec  5.04 MBytes  42.3 Mbits/sec    0    404 KBytes
[  4]  18.00-19.00  sec  4.49 MBytes  37.7 Mbits/sec    0    419 KBytes
[  4]  19.00-20.00  sec  3.45 MBytes  28.9 Mbits/sec    0    450 KBytes
[  4]  20.00-21.00  sec  4.74 MBytes  39.8 Mbits/sec    0    505 KBytes
[  4]  21.00-22.00  sec  4.47 MBytes  37.5 Mbits/sec    0    505 KBytes
[  4]  22.00-23.00  sec  4.78 MBytes  40.1 Mbits/sec    0    505 KBytes
[  4]  23.00-24.00  sec  4.47 MBytes  37.5 Mbits/sec    0    505 KBytes
[  4]  24.00-25.00  sec  4.86 MBytes  40.7 Mbits/sec    0    505 KBytes
[  4]  25.00-26.00  sec  4.83 MBytes  40.6 Mbits/sec    0    505 KBytes
[  4]  26.00-27.00  sec  4.82 MBytes  40.4 Mbits/sec    0    505 KBytes
[  4]  27.00-28.00  sec  4.48 MBytes  37.6 Mbits/sec    0    505 KBytes
[  4]  28.00-29.00  sec  4.81 MBytes  40.3 Mbits/sec    0    508 KBytes
[  4]  29.00-30.00  sec  4.88 MBytes  40.9 Mbits/sec    0    508 KBytes
[  4]  30.00-31.00  sec  4.88 MBytes  40.9 Mbits/sec    0    508 KBytes
[  4]  31.00-32.00  sec  4.60 MBytes  38.6 Mbits/sec    1    300 KBytes
[  4]  32.00-33.00  sec  4.53 MBytes  38.0 Mbits/sec    0    339 KBytes
[  4]  33.00-34.00  sec  4.83 MBytes  40.5 Mbits/sec    0    359 KBytes
[  4]  34.00-35.00  sec  4.87 MBytes  40.9 Mbits/sec    0    365 KBytes
[  4]  35.00-36.00  sec  4.65 MBytes  39.0 Mbits/sec    0    378 KBytes
[  4]  36.00-37.00  sec  4.50 MBytes  37.8 Mbits/sec    0    390 KBytes
[  4]  37.00-38.00  sec  4.50 MBytes  37.7 Mbits/sec    0    392 KBytes
[  4]  38.00-39.00  sec  4.52 MBytes  37.9 Mbits/sec    0    392 KBytes
[  4]  39.00-40.00  sec  4.53 MBytes  38.0 Mbits/sec    0    396 KBytes
[  4]  40.00-41.00  sec  4.38 MBytes  36.8 Mbits/sec    1    305 KBytes
[  4]  41.00-42.00  sec  4.46 MBytes  37.4 Mbits/sec    1    239 KBytes
[  4]  42.00-43.00  sec  4.66 MBytes  39.1 Mbits/sec    1    184 KBytes
[  4]  43.00-44.00  sec  4.48 MBytes  37.6 Mbits/sec    0    201 KBytes
[  4]  44.00-45.00  sec  4.48 MBytes  37.6 Mbits/sec    0    209 KBytes
[  4]  45.00-46.00  sec  4.48 MBytes  37.6 Mbits/sec    0    212 KBytes
[  4]  46.00-47.00  sec  4.62 MBytes  38.7 Mbits/sec    0    212 KBytes
[  4]  47.00-48.00  sec  4.55 MBytes  38.1 Mbits/sec    0    212 KBytes
[  4]  48.00-49.00  sec  4.44 MBytes  37.2 Mbits/sec    0    218 KBytes
[  4]  49.00-50.00  sec  4.55 MBytes  38.2 Mbits/sec    0    230 KBytes
[  4]  50.00-51.00  sec  4.46 MBytes  37.4 Mbits/sec    0    255 KBytes
[  4]  51.00-52.00  sec  4.60 MBytes  38.6 Mbits/sec    1    209 KBytes
[  4]  52.00-53.00  sec  4.45 MBytes  37.4 Mbits/sec    0    239 KBytes
[  4]  53.00-54.00  sec  4.54 MBytes  38.1 Mbits/sec    0    256 KBytes
[  4]  54.00-55.00  sec  4.54 MBytes  38.1 Mbits/sec    0    263 KBytes
[  4]  55.00-56.00  sec  4.86 MBytes  40.8 Mbits/sec    0    264 KBytes
[  4]  56.00-57.00  sec  4.43 MBytes  37.2 Mbits/sec    0    264 KBytes
[  4]  57.00-58.00  sec  4.46 MBytes  37.4 Mbits/sec    0    266 KBytes
[  4]  58.00-59.00  sec  4.72 MBytes  39.6 Mbits/sec    0    272 KBytes
[  4]  59.00-60.00  sec  4.67 MBytes  39.1 Mbits/sec    0    286 KBytes
[  4]  60.00-61.00  sec  4.37 MBytes  36.7 Mbits/sec    0    311 KBytes
[  4]  61.00-62.00  sec  4.62 MBytes  38.7 Mbits/sec    0    348 KBytes
[  4]  62.00-63.00  sec  4.79 MBytes  40.2 Mbits/sec    0    400 KBytes
[  4]  63.00-64.00  sec  4.57 MBytes  38.3 Mbits/sec    0    471 KBytes
[  4]  64.00-65.00  sec  4.90 MBytes  41.1 Mbits/sec    0    535 KBytes
[  4]  65.00-66.00  sec  4.70 MBytes  39.4 Mbits/sec    0    560 KBytes
[  4]  66.00-67.00  sec  4.32 MBytes  36.2 Mbits/sec    1    334 KBytes
[  4]  67.00-68.00  sec  4.89 MBytes  41.0 Mbits/sec    0    383 KBytes
[  4]  68.00-69.00  sec  4.35 MBytes  36.5 Mbits/sec    0    416 KBytes
[  4]  69.00-70.00  sec  4.49 MBytes  37.6 Mbits/sec    0    436 KBytes
[  4]  70.00-71.00  sec  4.59 MBytes  38.5 Mbits/sec    0    448 KBytes
[  4]  71.00-72.00  sec  4.41 MBytes  37.0 Mbits/sec    0    452 KBytes
[  4]  72.00-73.00  sec  4.14 MBytes  34.7 Mbits/sec    0    454 KBytes
[  4]  73.00-74.00  sec  4.61 MBytes  38.6 Mbits/sec    1    356 KBytes
[  4]  74.00-75.00  sec  4.61 MBytes  38.7 Mbits/sec    0    399 KBytes
[  4]  75.00-76.00  sec  4.27 MBytes  35.8 Mbits/sec    0    427 KBytes
[  4]  76.00-77.00  sec  4.50 MBytes  37.8 Mbits/sec    1    318 KBytes
[  4]  77.00-78.00  sec  4.40 MBytes  36.9 Mbits/sec    1    242 KBytes
[  4]  78.00-79.00  sec  4.44 MBytes  37.2 Mbits/sec    1    192 KBytes
[  4]  79.00-80.00  sec  4.42 MBytes  37.1 Mbits/sec    2    109 KBytes
[  4]  80.00-81.00  sec  4.22 MBytes  35.4 Mbits/sec    0    122 KBytes
[  4]  81.00-82.00  sec  4.74 MBytes  39.7 Mbits/sec    0    127 KBytes
[  4]  82.00-83.00  sec  4.31 MBytes  36.2 Mbits/sec    0    133 KBytes
[  4]  83.00-84.00  sec  4.78 MBytes  40.1 Mbits/sec    0    141 KBytes
[  4]  84.00-85.00  sec  3.89 MBytes  32.6 Mbits/sec    0    150 KBytes
[  4]  85.00-86.00  sec  4.59 MBytes  38.5 Mbits/sec    0    157 KBytes
[  4]  86.00-87.00  sec  4.09 MBytes  34.3 Mbits/sec    0    164 KBytes
[  4]  87.00-88.00  sec  4.43 MBytes  37.1 Mbits/sec    0    187 KBytes
[  4]  88.00-89.00  sec  4.59 MBytes  38.5 Mbits/sec    0    233 KBytes
[  4]  89.00-90.00  sec  4.50 MBytes  37.8 Mbits/sec    0    300 KBytes
[  4]  90.00-91.00  sec  4.36 MBytes  36.6 Mbits/sec    0    385 KBytes
[  4]  91.00-92.00  sec  4.50 MBytes  37.7 Mbits/sec    0    475 KBytes
[  4]  92.00-93.00  sec  4.26 MBytes  35.8 Mbits/sec    1    341 KBytes
[  4]  93.00-94.00  sec  4.59 MBytes  38.5 Mbits/sec    0    380 KBytes
[  4]  94.00-95.00  sec  4.36 MBytes  36.6 Mbits/sec    0    403 KBytes
[  4]  95.00-96.00  sec  4.67 MBytes  39.1 Mbits/sec    1    305 KBytes
[  4]  96.00-97.00  sec  4.53 MBytes  38.0 Mbits/sec    0    328 KBytes
[  4]  97.00-98.00  sec  4.27 MBytes  35.8 Mbits/sec    0    342 KBytes
[  4]  98.00-99.00  sec  4.89 MBytes  40.9 Mbits/sec    0    348 KBytes
[  4]  99.00-100.00 sec  4.14 MBytes  34.7 Mbits/sec    0    348 KBytes
[  4] 100.00-101.00 sec  4.34 MBytes  36.4 Mbits/sec    1    270 KBytes
[  4] 101.00-102.00 sec  4.54 MBytes  38.1 Mbits/sec    0    308 KBytes
[  4] 102.00-103.00 sec  4.37 MBytes  36.6 Mbits/sec    0    331 KBytes
[  4] 103.00-104.00 sec  4.13 MBytes  34.6 Mbits/sec    0    344 KBytes
[  4] 104.00-105.00 sec  4.18 MBytes  35.1 Mbits/sec    0    348 KBytes
[  4] 105.00-106.00 sec  4.76 MBytes  39.9 Mbits/sec    0    348 KBytes
[  4] 106.00-107.00 sec  4.49 MBytes  37.6 Mbits/sec    0    348 KBytes
[  4] 107.00-108.00 sec  4.27 MBytes  35.8 Mbits/sec    0    351 KBytes
[  4] 108.00-109.00 sec  4.77 MBytes  40.0 Mbits/sec    0    361 KBytes
[  4] 109.00-110.00 sec  4.31 MBytes  36.1 Mbits/sec    0    379 KBytes
[  4] 110.00-111.00 sec  4.42 MBytes  37.1 Mbits/sec    1    284 KBytes
[  4] 111.00-112.00 sec  4.43 MBytes  37.1 Mbits/sec    2    160 KBytes
[  4] 112.00-113.00 sec  4.26 MBytes  35.8 Mbits/sec    0    177 KBytes
[  4] 113.00-114.00 sec  4.52 MBytes  37.9 Mbits/sec    0    185 KBytes
[  4] 114.00-115.00 sec  4.04 MBytes  33.9 Mbits/sec    0    187 KBytes
[  4] 115.00-116.00 sec  4.49 MBytes  37.6 Mbits/sec    0    187 KBytes
[  4] 116.00-117.00 sec  4.55 MBytes  38.2 Mbits/sec    0    188 KBytes
[  4] 117.00-118.00 sec  4.60 MBytes  38.6 Mbits/sec    1    140 KBytes
[  4] 118.00-119.00 sec  4.34 MBytes  36.4 Mbits/sec    0    168 KBytes
[  4] 119.00-120.00 sec  4.53 MBytes  38.0 Mbits/sec    0    184 KBytes
[  4]   0.00-120.00 sec   552 MBytes  38.6 Mbits/sec   22             sender
[  4]   0.00-120.00 sec   551 MBytes  38.5 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.83.86 port 46267 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  4.86 MBytes  40.8 Mbits/sec
[  4]   1.00-2.00   sec  4.75 MBytes  39.9 Mbits/sec
[  4]   2.00-3.00   sec  4.77 MBytes  40.0 Mbits/sec
[  4]   3.00-4.00   sec  4.87 MBytes  40.9 Mbits/sec
[  4]   4.00-5.00   sec  4.86 MBytes  40.8 Mbits/sec
[  4]   5.00-6.00   sec  4.72 MBytes  39.6 Mbits/sec
[  4]   6.00-7.00   sec  4.79 MBytes  40.2 Mbits/sec
[  4]   7.00-8.00   sec  4.87 MBytes  40.9 Mbits/sec
[  4]   8.00-9.00   sec  4.75 MBytes  39.8 Mbits/sec
[  4]   9.00-10.00  sec  4.83 MBytes  40.5 Mbits/sec
[  4]  10.00-11.00  sec  4.92 MBytes  41.3 Mbits/sec
[  4]  11.00-12.00  sec  4.79 MBytes  40.2 Mbits/sec
[  4]  12.00-13.00  sec  4.81 MBytes  40.3 Mbits/sec
[  4]  13.00-14.00  sec  4.87 MBytes  40.9 Mbits/sec
[  4]  14.00-15.00  sec  4.93 MBytes  41.4 Mbits/sec
[  4]  15.00-16.00  sec  4.91 MBytes  41.1 Mbits/sec
[  4]  16.00-17.00  sec  4.98 MBytes  41.8 Mbits/sec
[  4]  17.00-18.00  sec  4.89 MBytes  41.1 Mbits/sec
[  4]  18.00-19.00  sec  4.95 MBytes  41.5 Mbits/sec
[  4]  19.00-20.00  sec  4.88 MBytes  40.9 Mbits/sec
[  4]  20.00-21.00  sec  4.96 MBytes  41.6 Mbits/sec
[  4]  21.00-22.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  22.00-23.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  23.00-24.00  sec  4.82 MBytes  40.4 Mbits/sec
[  4]  24.00-25.00  sec  4.76 MBytes  39.9 Mbits/sec
[  4]  25.00-26.00  sec  4.93 MBytes  41.3 Mbits/sec
[  4]  26.00-27.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  27.00-28.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  28.00-29.00  sec  5.02 MBytes  42.1 Mbits/sec
[  4]  29.00-30.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  31.00-32.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  32.00-33.00  sec  4.99 MBytes  41.8 Mbits/sec
[  4]  33.00-34.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  34.00-35.00  sec  4.95 MBytes  41.5 Mbits/sec
[  4]  35.00-36.00  sec  5.01 MBytes  42.0 Mbits/sec
[  4]  36.00-37.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  37.00-38.00  sec  4.54 MBytes  38.1 Mbits/sec
[  4]  38.00-39.00  sec  4.94 MBytes  41.5 Mbits/sec
[  4]  39.00-40.00  sec  5.07 MBytes  42.5 Mbits/sec
[  4]  40.00-41.00  sec  5.00 MBytes  41.9 Mbits/sec
[  4]  41.00-42.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  42.00-43.00  sec  4.95 MBytes  41.5 Mbits/sec
[  4]  43.00-44.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  44.00-45.00  sec  5.00 MBytes  41.9 Mbits/sec
[  4]  45.00-46.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  46.00-47.00  sec  4.91 MBytes  41.1 Mbits/sec
[  4]  47.00-48.00  sec  4.98 MBytes  41.8 Mbits/sec
[  4]  48.00-49.00  sec  4.96 MBytes  41.6 Mbits/sec
[  4]  49.00-50.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  50.00-51.00  sec  5.00 MBytes  41.9 Mbits/sec
[  4]  51.00-52.00  sec  4.91 MBytes  41.1 Mbits/sec
[  4]  52.00-53.00  sec  4.63 MBytes  38.8 Mbits/sec
[  4]  53.00-54.00  sec  4.78 MBytes  40.1 Mbits/sec
[  4]  54.00-55.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  55.00-56.00  sec  4.91 MBytes  41.1 Mbits/sec
[  4]  56.00-57.00  sec  4.99 MBytes  41.9 Mbits/sec
[  4]  57.00-58.00  sec  4.78 MBytes  40.1 Mbits/sec
[  4]  58.00-59.00  sec  4.95 MBytes  41.5 Mbits/sec
[  4]  59.00-60.00  sec  5.05 MBytes  42.3 Mbits/sec
[  4]  60.00-61.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  61.00-62.00  sec  5.02 MBytes  42.1 Mbits/sec
[  4]  62.00-63.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  63.00-64.00  sec  4.97 MBytes  41.7 Mbits/sec
[  4]  64.00-65.00  sec  5.01 MBytes  42.0 Mbits/sec
[  4]  65.00-66.00  sec  5.12 MBytes  42.9 Mbits/sec
[  4]  66.00-67.00  sec  4.38 MBytes  36.8 Mbits/sec
[  4]  67.00-68.00  sec  5.47 MBytes  45.9 Mbits/sec
[  4]  68.00-69.00  sec  4.94 MBytes  41.5 Mbits/sec
[  4]  69.00-70.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  70.00-71.00  sec  4.99 MBytes  41.9 Mbits/sec
[  4]  71.00-72.00  sec  5.09 MBytes  42.7 Mbits/sec
[  4]  72.00-73.00  sec  5.05 MBytes  42.4 Mbits/sec
[  4]  73.00-74.00  sec  4.99 MBytes  41.9 Mbits/sec
[  4]  74.00-75.00  sec  5.05 MBytes  42.4 Mbits/sec
[  4]  75.00-76.00  sec  4.97 MBytes  41.7 Mbits/sec
[  4]  76.00-77.00  sec  4.97 MBytes  41.7 Mbits/sec
[  4]  77.00-78.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  78.00-79.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  79.00-80.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  80.00-81.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  81.00-82.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  82.00-83.00  sec  4.87 MBytes  40.8 Mbits/sec
[  4]  83.00-84.00  sec  4.86 MBytes  40.7 Mbits/sec
[  4]  84.00-85.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  85.00-86.00  sec  4.92 MBytes  41.3 Mbits/sec
[  4]  86.00-87.00  sec  5.04 MBytes  42.3 Mbits/sec
[  4]  88.00-89.00  sec  4.97 MBytes  41.7 Mbits/sec
[  4]  89.00-90.00  sec  4.95 MBytes  41.6 Mbits/sec
[  4]  90.00-91.00  sec  4.95 MBytes  41.5 Mbits/sec
[  4]  91.00-92.00  sec  4.93 MBytes  41.4 Mbits/sec
[  4]  92.00-93.00  sec  4.57 MBytes  38.3 Mbits/sec
[  4]  93.00-94.00  sec  4.04 MBytes  33.9 Mbits/sec
[  4]  94.00-95.00  sec  4.06 MBytes  34.0 Mbits/sec
[  4]  95.00-96.00  sec  4.16 MBytes  34.9 Mbits/sec
[  4]  96.00-97.00  sec  4.24 MBytes  35.6 Mbits/sec
[  4]  97.00-98.00  sec  4.22 MBytes  35.4 Mbits/sec
[  4]  98.00-99.00  sec  4.28 MBytes  35.9 Mbits/sec
[  4]  99.00-100.00 sec  4.12 MBytes  34.5 Mbits/sec
[  4] 100.00-101.00 sec  4.06 MBytes  34.1 Mbits/sec
[  4] 101.00-102.00 sec  4.16 MBytes  34.9 Mbits/sec
[  4] 102.00-103.00 sec  4.06 MBytes  34.1 Mbits/sec
[  4] 103.00-104.00 sec  4.07 MBytes  34.2 Mbits/sec
[  4] 104.00-105.00 sec  4.03 MBytes  33.8 Mbits/sec
[  4] 105.00-106.00 sec  4.16 MBytes  34.9 Mbits/sec
[  4] 106.00-107.00 sec  4.09 MBytes  34.3 Mbits/sec
[  4] 107.00-108.00 sec  4.16 MBytes  34.9 Mbits/sec
[  4] 108.00-109.00 sec  4.13 MBytes  34.7 Mbits/sec
[  4] 109.00-110.00 sec  4.16 MBytes  34.9 Mbits/sec
[  4] 110.00-111.00 sec  4.02 MBytes  33.7 Mbits/sec
[  4] 111.00-112.00 sec  4.03 MBytes  33.8 Mbits/sec
[  4] 112.00-113.00 sec  3.94 MBytes  33.0 Mbits/sec
[  4] 113.00-114.00 sec  4.10 MBytes  34.4 Mbits/sec
[  4] 114.00-115.00 sec  4.07 MBytes  34.1 Mbits/sec
[  4] 115.00-116.00 sec  3.43 MBytes  28.8 Mbits/sec
[  4] 116.00-117.00 sec  4.29 MBytes  36.0 Mbits/sec
[  4] 117.00-118.00 sec  4.03 MBytes  33.8 Mbits/sec
[  4] 118.00-119.00 sec  4.09 MBytes  34.3 Mbits/sec
[  4] 119.00-120.00 sec  4.14 MBytes  34.8 Mbits/sec
[  4]   0.00-120.00 sec   571 MBytes  39.9 Mbits/sec   94             sender
[  4]   0.00-120.00 sec   568 MBytes  39.7 Mbits/sec                  receiver
iperf Done.
root@pine64:/home/tk# ping 192.168.83.146
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=3.50 ms
64 bytes from 192.168.83.146: icmp_seq=2 ttl=64 time=4.41 ms
64 bytes from 192.168.83.146: icmp_seq=3 ttl=64 time=1.99 ms
64 bytes from 192.168.83.146: icmp_seq=4 ttl=64 time=3.18 ms
64 bytes from 192.168.83.146: icmp_seq=5 ttl=64 time=2.10 ms
64 bytes from 192.168.83.146: icmp_seq=6 ttl=64 time=1301 ms
64 bytes from 192.168.83.146: icmp_seq=7 ttl=64 time=295 ms
64 bytes from 192.168.83.146: icmp_seq=8 ttl=64 time=2.40 ms
64 bytes from 192.168.83.146: icmp_seq=9 ttl=64 time=2.62 ms
^C
9 packets transmitted, 9 received, 0% packet loss, time 8016ms
rtt min/avg/max/mdev = 1.993/179.716/1301.719/407.045 ms, pipe 2
root@pine64:/home/tk# iwconfig wlan0
wlan0     IEEE 802.11bgn  ESSID:"Snort-Honeynet"  Nickname:"<WIFI@REALTEK>"
          Bit Rate:65 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Link Quality=81/100  Signal level=-45 dBm  Noise level=0 dBm
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
root@pine64:/home/tk# nmcli dev wifi list
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  55      ▂▄__  WPA1 WPA2
   EasyBox-116D28           Infra  5     54 Mbit/s  49      ▂▄__  WPA1 WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  49      ▂▄__  WPA1 WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  45      ▂▄__  WPA1 WPA2
   CubaLibre                Infra  11    54 Mbit/s  45      ▂▄__  WPA2
   WLAN-3C3379              Infra  11    54 Mbit/s  15      ▂___  WPA2
*  Snort-Honeynet           Infra  13    54 Mbit/s  75      ▂▄▆_  WPA2
   EasyBox-290502           Infra  10    54 Mbit/s  9       ▂___  WPA1 WPA2
   --                       Infra  6     54 Mbit/s  44      ▂▄__  WPA2
Segmentation fault
Orange Pi Lite, RTL8189FTV module, Kernel 3.4.113: 41.5 Mbits/sec and 50 retransmits on average. Full log: http://sprunge.us/dWJV
root@orangepilite:~# echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
root@orangepilite:~# iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120
[  4] local 192.168.83.98 port 55218 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  1.52 MBytes  12.7 Mbits/sec    1   94.7 KBytes
[  4]   1.00-2.00   sec  82.0 KBytes   672 Kbits/sec    2   65.0 KBytes
[  4]   2.00-3.00   sec  4.86 MBytes  40.7 Mbits/sec    0   89.1 KBytes
[  4]   3.00-4.00   sec  4.91 MBytes  41.1 Mbits/sec    0    107 KBytes
[  4]   4.00-5.00   sec  5.28 MBytes  44.3 Mbits/sec    0    126 KBytes
[  4]   5.00-6.00   sec  4.93 MBytes  41.4 Mbits/sec    0    140 KBytes
[  4]   6.00-7.00   sec  5.23 MBytes  43.8 Mbits/sec    0    154 KBytes
[  4]   7.00-8.00   sec  5.23 MBytes  43.8 Mbits/sec    0    165 KBytes
[  4]   8.00-9.00   sec  5.13 MBytes  43.0 Mbits/sec    0    178 KBytes
[  4]   9.00-10.00  sec  5.18 MBytes  43.5 Mbits/sec    0    188 KBytes
[  4]  10.00-11.00  sec  5.14 MBytes  43.1 Mbits/sec    0    199 KBytes
[  4]  11.00-12.00  sec  5.30 MBytes  44.5 Mbits/sec    0    233 KBytes
[  4]  12.00-13.00  sec  5.34 MBytes  44.8 Mbits/sec    0    311 KBytes
[  4]  13.00-14.00  sec  4.99 MBytes  41.9 Mbits/sec    0    409 KBytes
[  4]  14.00-15.00  sec  4.46 MBytes  37.4 Mbits/sec    1    355 KBytes
[  4]  15.00-16.00  sec  5.08 MBytes  42.6 Mbits/sec    0    407 KBytes
[  4]  16.00-17.00  sec  4.80 MBytes  40.2 Mbits/sec    0    444 KBytes
[  4]  17.00-18.00  sec  4.92 MBytes  41.3 Mbits/sec    0    465 KBytes
[  4]  18.00-19.00  sec  4.97 MBytes  41.7 Mbits/sec    0    478 KBytes
[  4]  19.00-20.00  sec  4.93 MBytes  41.4 Mbits/sec    0    482 KBytes
[  4]  20.00-21.00  sec  5.14 MBytes  43.1 Mbits/sec    0    482 KBytes
[  4]  21.00-22.00  sec  5.09 MBytes  42.7 Mbits/sec    0    482 KBytes
[  4]  22.00-23.00  sec  5.22 MBytes  43.8 Mbits/sec    0    486 KBytes
[  4]  23.00-24.00  sec  4.93 MBytes  41.3 Mbits/sec    0    496 KBytes
[  4]  24.00-25.00  sec  5.23 MBytes  43.9 Mbits/sec    0    516 KBytes
[  4]  25.00-26.00  sec  4.93 MBytes  41.4 Mbits/sec    0    547 KBytes
[  4]  26.00-27.00  sec  5.23 MBytes  43.9 Mbits/sec    0    595 KBytes
[  4]  27.00-28.00  sec  5.37 MBytes  45.1 Mbits/sec    0    665 KBytes
[  4]  28.00-29.00  sec  4.96 MBytes  41.6 Mbits/sec    0    754 KBytes
[  4]  29.00-30.00  sec  5.92 MBytes  49.7 Mbits/sec    0    875 KBytes
[  4]  30.00-31.00  sec  5.04 MBytes  42.3 Mbits/sec    0   1020 KBytes
[  4]  31.00-32.00  sec  5.07 MBytes  42.5 Mbits/sec    0   1.17 MBytes
[  4]  32.00-33.00  sec  5.38 MBytes  45.2 Mbits/sec    0   1.37 MBytes
[  4]  33.00-34.00  sec  5.36 MBytes  44.9 Mbits/sec    0   1.59 MBytes
[  4]  34.00-35.00  sec  4.85 MBytes  40.7 Mbits/sec    0   1.87 MBytes
[  4]  35.00-36.00  sec  5.45 MBytes  45.8 Mbits/sec    0   1.06 MBytes
[  4]  36.00-37.00  sec  5.18 MBytes  43.5 Mbits/sec    1   1014 KBytes
[  4]  37.00-38.00  sec  5.51 MBytes  46.2 Mbits/sec    0   1.06 MBytes
[  4]  38.00-39.00  sec  5.39 MBytes  45.2 Mbits/sec    0   1.11 MBytes
[  4]  39.00-40.00  sec  5.22 MBytes  43.8 Mbits/sec    0   1.15 MBytes
[  4]  40.00-41.00  sec  4.44 MBytes  37.3 Mbits/sec    0   1.17 MBytes
[  4]  41.00-42.00  sec  5.21 MBytes  43.7 Mbits/sec    0   1.18 MBytes
[  4]  42.00-43.00  sec  5.30 MBytes  44.4 Mbits/sec    0   1.19 MBytes
[  4]  43.00-44.00  sec  5.20 MBytes  43.6 Mbits/sec    0   1.19 MBytes
[  4]  44.00-45.00  sec  5.20 MBytes  43.6 Mbits/sec    0   1.19 MBytes
[  4]  45.00-46.00  sec  5.18 MBytes  43.5 Mbits/sec    0   1.19 MBytes
[  4]  46.00-47.00  sec  5.31 MBytes  44.6 Mbits/sec    0   1.20 MBytes
[  4]  47.00-48.00  sec  5.25 MBytes  44.1 Mbits/sec    0   1.22 MBytes
[  4]  48.00-49.00  sec  5.23 MBytes  43.9 Mbits/sec    0   1.25 MBytes
[  4]  49.00-50.00  sec  5.33 MBytes  44.7 Mbits/sec    0   1.30 MBytes
[  4]  50.00-51.00  sec  5.25 MBytes  44.1 Mbits/sec    0   1.36 MBytes
[  4]  51.00-52.00  sec  2.68 MBytes  22.5 Mbits/sec    0   1.44 MBytes
[  4]  52.00-53.00  sec  5.35 MBytes  44.9 Mbits/sec    0   1.56 MBytes
[  4]  53.00-54.00  sec  5.18 MBytes  43.5 Mbits/sec    0   1.70 MBytes
[  4]  54.00-55.00  sec  5.19 MBytes  43.5 Mbits/sec    0   1.86 MBytes
[  4]  55.00-56.00  sec  5.26 MBytes  44.1 Mbits/sec    0   1.00 MBytes
[  4]  56.00-57.00  sec  4.41 MBytes  36.9 Mbits/sec    0   1.45 MBytes
[  4]  57.00-58.00  sec  5.31 MBytes  44.5 Mbits/sec    0   1.58 MBytes
[  4]  58.00-59.00  sec  6.07 MBytes  50.9 Mbits/sec    0   1.69 MBytes
[  4]  59.00-60.00  sec  5.29 MBytes  44.4 Mbits/sec    0   1.77 MBytes
[  4]  60.00-61.00  sec  4.47 MBytes  37.5 Mbits/sec    0   1.83 MBytes
[  4]  61.00-62.00  sec  5.25 MBytes  44.1 Mbits/sec    0   1.87 MBytes
[  4]  62.00-63.00  sec  5.24 MBytes  43.9 Mbits/sec    0   1.90 MBytes
[  4]  63.00-64.00  sec  5.30 MBytes  44.5 Mbits/sec    0   1.92 MBytes
[  4]  64.00-65.00  sec  5.29 MBytes  44.4 Mbits/sec    0   1.93 MBytes
[  4]  65.00-66.00  sec  4.45 MBytes  37.3 Mbits/sec    0    823 KBytes
[  4]  66.00-67.00  sec  5.34 MBytes  44.8 Mbits/sec    0   1.43 MBytes
[  4]  67.00-68.00  sec  5.21 MBytes  43.7 Mbits/sec    0   1.56 MBytes
[  4]  68.00-69.00  sec  5.28 MBytes  44.3 Mbits/sec    0   1.67 MBytes
[  4]  69.00-70.00  sec  5.25 MBytes  44.0 Mbits/sec    0   1.76 MBytes
[  4]  70.00-71.00  sec  5.28 MBytes  44.3 Mbits/sec    0   1.82 MBytes
[  4]  71.00-72.00  sec  5.23 MBytes  43.9 Mbits/sec    0   1.87 MBytes
[  4]  72.00-73.00  sec  5.29 MBytes  44.4 Mbits/sec    0   1.90 MBytes
[  4]  73.00-74.00  sec  5.35 MBytes  44.9 Mbits/sec    0   1.92 MBytes
[  4]  74.00-75.00  sec  5.19 MBytes  43.5 Mbits/sec    0   1.93 MBytes
[  4]  75.00-76.00  sec  5.23 MBytes  43.9 Mbits/sec    0   1.35 MBytes
[  4]  76.00-77.00  sec  4.35 MBytes  36.5 Mbits/sec    0   1.43 MBytes
[  4]  77.00-78.00  sec  5.37 MBytes  45.0 Mbits/sec    0   1.51 MBytes
[  4]  78.00-79.00  sec  5.26 MBytes  44.2 Mbits/sec    0   1.56 MBytes
[  4]  79.00-80.00  sec  5.23 MBytes  43.8 Mbits/sec    0   1.60 MBytes
[  4]  80.00-81.00  sec  5.23 MBytes  43.8 Mbits/sec    0   1.62 MBytes
[  4]  81.00-82.00  sec  5.57 MBytes  46.8 Mbits/sec    0   1.63 MBytes
[  4]  82.00-83.00  sec  4.95 MBytes  41.5 Mbits/sec    0   1.64 MBytes
[  4]  83.00-84.00  sec  5.61 MBytes  47.1 Mbits/sec    0   1.64 MBytes
[  4]  84.00-85.00  sec  4.31 MBytes  36.1 Mbits/sec    0   1.64 MBytes
[  4]  85.00-86.00  sec  6.06 MBytes  50.8 Mbits/sec    0   1.64 MBytes
[  4]  86.00-87.00  sec  4.25 MBytes  35.7 Mbits/sec    0   1.65 MBytes
[  4]  87.00-88.00  sec  5.77 MBytes  48.4 Mbits/sec    0   1.67 MBytes
[  4]  88.00-89.00  sec  5.01 MBytes  42.0 Mbits/sec    0   1.70 MBytes
[  4]  89.00-90.00  sec  4.81 MBytes  40.4 Mbits/sec    0   1.74 MBytes
[  4]  90.00-91.00  sec  5.54 MBytes  46.5 Mbits/sec    0   1.81 MBytes
[  4]  91.00-92.00  sec  4.72 MBytes  39.6 Mbits/sec    0   1.88 MBytes
[  4]  92.00-93.00  sec  5.65 MBytes  47.4 Mbits/sec    0    885 KBytes
[  4]  93.00-94.00  sec  4.58 MBytes  38.5 Mbits/sec    0   1.43 MBytes
[  4]  94.00-95.00  sec  6.12 MBytes  51.2 Mbits/sec    0   1.57 MBytes
[  4]  95.00-96.00  sec  5.09 MBytes  42.7 Mbits/sec    0   1.68 MBytes
[  4]  96.00-97.00  sec  4.21 MBytes  35.4 Mbits/sec    0   1.76 MBytes
[  4]  97.00-98.00  sec  6.05 MBytes  50.8 Mbits/sec    0   1.82 MBytes
[  4]  98.00-99.00  sec  4.25 MBytes  35.7 Mbits/sec    0   1.87 MBytes
[  4]  99.00-100.00 sec  6.02 MBytes  50.5 Mbits/sec    0   1.90 MBytes
[  4] 100.00-101.00 sec  4.37 MBytes  36.6 Mbits/sec    0   1.92 MBytes
[  4] 101.00-102.00 sec  5.06 MBytes  42.4 Mbits/sec    0   1.93 MBytes
[  4] 102.00-103.00 sec  5.65 MBytes  47.4 Mbits/sec    0   1.01 MBytes
[  4] 103.00-104.00 sec  5.19 MBytes  43.5 Mbits/sec    0   1.42 MBytes
[  4] 104.00-105.00 sec  4.79 MBytes  40.2 Mbits/sec    0   1.49 MBytes
[  4] 105.00-106.00 sec  5.53 MBytes  46.4 Mbits/sec    0   1.55 MBytes
[  4] 106.00-107.00 sec  5.36 MBytes  44.9 Mbits/sec    0   1.60 MBytes
[  4] 107.00-108.00 sec  5.40 MBytes  45.3 Mbits/sec    0   1.62 MBytes
[  4] 108.00-109.00 sec  4.81 MBytes  40.4 Mbits/sec    0   1.64 MBytes
[  4] 109.00-110.00 sec  5.61 MBytes  47.1 Mbits/sec    0   1.64 MBytes
[  4] 110.00-111.00 sec  5.00 MBytes  42.0 Mbits/sec    0   1.64 MBytes
[  4] 111.00-112.00 sec  4.70 MBytes  39.4 Mbits/sec    0   1.64 MBytes
[  4] 112.00-113.00 sec  3.94 MBytes  33.0 Mbits/sec    0   1.65 MBytes
[  4] 113.00-114.00 sec  6.01 MBytes  50.4 Mbits/sec    0   1.65 MBytes
[  4] 114.00-115.00 sec  5.03 MBytes  42.2 Mbits/sec    0   1.67 MBytes
[  4] 115.00-116.00 sec  4.06 MBytes  34.0 Mbits/sec    0   1.69 MBytes
[  4] 116.00-117.00 sec  5.70 MBytes  47.8 Mbits/sec    0   1.73 MBytes
[  4] 117.00-118.00 sec  4.88 MBytes  40.9 Mbits/sec    0   1.80 MBytes
[  4] 118.00-119.00 sec  5.12 MBytes  42.9 Mbits/sec    0   1.87 MBytes
[  4] 119.00-120.00 sec  5.70 MBytes  47.7 Mbits/sec    0    993 KBytes
[  4]   0.00-120.00 sec   607 MBytes  42.4 Mbits/sec    5             sender
[  4]   0.00-120.00 sec   605 MBytes  42.3 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.83.98 port 55220 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  4.76 MBytes  40.0 Mbits/sec
[  4]   1.00-2.00   sec  4.58 MBytes  38.4 Mbits/sec
[  4]   2.00-3.00   sec  4.70 MBytes  39.4 Mbits/sec
[  4]   3.00-4.00   sec  4.77 MBytes  40.0 Mbits/sec
[  4]   4.00-5.00   sec  4.90 MBytes  41.1 Mbits/sec
[  4]   5.00-6.00   sec  4.87 MBytes  40.8 Mbits/sec
[  4]   6.00-7.00   sec  4.84 MBytes  40.6 Mbits/sec
[  4]   9.00-10.00  sec  4.98 MBytes  41.7 Mbits/sec
[  4]  10.00-11.00  sec  4.82 MBytes  40.5 Mbits/sec
[  4]  11.00-12.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  12.00-13.00  sec  4.92 MBytes  41.3 Mbits/sec
[  4]  14.00-15.00  sec  4.70 MBytes  39.4 Mbits/sec
[  4]  15.00-16.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  16.00-17.00  sec  4.99 MBytes  41.8 Mbits/sec
[  4]  17.00-18.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  18.00-19.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  19.00-20.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  20.00-21.00  sec  4.95 MBytes  41.6 Mbits/sec
[  4]  21.00-22.00  sec  4.81 MBytes  40.4 Mbits/sec
[  4]  22.00-23.00  sec  5.00 MBytes  41.9 Mbits/sec
[  4]  23.00-24.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  24.00-25.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  25.00-26.00  sec  4.99 MBytes  41.9 Mbits/sec
[  4]  27.00-28.00  sec  4.88 MBytes  40.9 Mbits/sec
[  4]  28.00-29.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  29.00-30.00  sec  4.93 MBytes  41.3 Mbits/sec
[  4]  31.00-32.00  sec  4.92 MBytes  41.3 Mbits/sec
[  4]  32.00-33.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  33.00-34.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  34.00-35.00  sec  4.92 MBytes  41.2 Mbits/sec
[  4]  35.00-36.00  sec  4.77 MBytes  40.0 Mbits/sec
[  4]  36.00-37.00  sec  4.87 MBytes  40.8 Mbits/sec
[  4]  37.00-38.00  sec  5.00 MBytes  41.9 Mbits/sec
[  4]  38.00-39.00  sec  4.78 MBytes  40.1 Mbits/sec
[  4]  39.00-40.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  40.00-41.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  41.00-42.00  sec  4.93 MBytes  41.4 Mbits/sec
[  4]  42.00-43.00  sec  4.80 MBytes  40.3 Mbits/sec
[  4]  43.00-44.00  sec  4.94 MBytes  41.4 Mbits/sec
[  4]  44.00-45.00  sec  4.98 MBytes  41.8 Mbits/sec
[  4]  45.00-46.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  46.00-47.00  sec  4.87 MBytes  40.9 Mbits/sec
[  4]  47.00-48.00  sec  4.82 MBytes  40.4 Mbits/sec
[  4]  48.00-49.00  sec  4.86 MBytes  40.8 Mbits/sec
[  4]  49.00-50.00  sec  4.83 MBytes  40.5 Mbits/sec
[  4]  50.00-51.00  sec  4.86 MBytes  40.7 Mbits/sec
[  4]  51.00-52.00  sec  5.01 MBytes  42.0 Mbits/sec
[  4]  52.00-53.00  sec  4.98 MBytes  41.8 Mbits/sec
[  4]  53.00-54.00  sec  4.82 MBytes  40.4 Mbits/sec
[  4]  54.00-55.00  sec  4.82 MBytes  40.5 Mbits/sec
[  4]  55.00-56.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  56.00-57.00  sec  4.93 MBytes  41.3 Mbits/sec
[  4]  57.00-58.00  sec  4.85 MBytes  40.7 Mbits/sec
[  4]  58.00-59.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  59.00-60.00  sec  5.01 MBytes  42.0 Mbits/sec
[  4]  60.00-61.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  61.00-62.00  sec  4.77 MBytes  40.0 Mbits/sec
[  4]  62.00-63.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  63.00-64.00  sec  4.79 MBytes  40.2 Mbits/sec
[  4]  64.00-65.00  sec  4.95 MBytes  41.5 Mbits/sec
[  4]  65.00-66.00  sec  4.88 MBytes  41.0 Mbits/sec
[  4]  67.00-68.00  sec  4.79 MBytes  40.2 Mbits/sec
[  4]  68.00-69.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  69.00-70.00  sec  4.88 MBytes  41.0 Mbits/sec
[  4]  70.00-71.00  sec  4.84 MBytes  40.6 Mbits/sec
[  4]  71.00-72.00  sec  4.82 MBytes  40.4 Mbits/sec
[  4]  72.00-73.00  sec  4.82 MBytes  40.5 Mbits/sec
[  4]  73.00-74.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  74.00-75.00  sec  4.78 MBytes  40.1 Mbits/sec
[  4]  75.00-76.00  sec  4.86 MBytes  40.8 Mbits/sec
[  4]  76.00-77.00  sec  4.95 MBytes  41.6 Mbits/sec
[  4]  77.00-78.00  sec  5.07 MBytes  42.5 Mbits/sec
[  4]  78.00-79.00  sec  4.87 MBytes  40.8 Mbits/sec
[  4]  79.00-80.00  sec  4.89 MBytes  41.1 Mbits/sec
[  4]  80.00-81.00  sec  5.04 MBytes  42.3 Mbits/sec
[  4]  81.00-82.00  sec  4.69 MBytes  39.3 Mbits/sec
[  4]  82.00-83.00  sec  5.10 MBytes  42.7 Mbits/sec
[  4]  83.00-84.00  sec  5.01 MBytes  42.0 Mbits/sec
[  4]  84.00-85.00  sec  4.87 MBytes  40.8 Mbits/sec
[  4]  86.00-87.00  sec  4.59 MBytes  38.5 Mbits/sec
[  4]  87.00-88.00  sec  5.04 MBytes  42.3 Mbits/sec
[  4]  88.00-89.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  89.00-90.00  sec  4.86 MBytes  40.8 Mbits/sec
[  4]  90.00-91.00  sec  4.95 MBytes  41.6 Mbits/sec
[  4]  91.00-92.00  sec  4.88 MBytes  40.9 Mbits/sec
[  4]  92.00-93.00  sec  4.83 MBytes  40.5 Mbits/sec
[  4]  93.00-94.00  sec  4.93 MBytes  41.4 Mbits/sec
[  4]  94.00-95.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  95.00-96.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  96.00-97.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  97.00-98.00  sec  4.96 MBytes  41.6 Mbits/sec
[  4]  98.00-99.00  sec  4.80 MBytes  40.3 Mbits/sec
[  4]  99.00-100.00 sec  4.91 MBytes  41.2 Mbits/sec
[  4] 100.00-101.00 sec  4.76 MBytes  39.9 Mbits/sec
[  4] 101.00-102.00 sec  4.81 MBytes  40.4 Mbits/sec
[  4] 102.00-103.00 sec  4.92 MBytes  41.3 Mbits/sec
[  4] 103.00-104.00 sec  4.88 MBytes  41.0 Mbits/sec
[  4] 104.00-105.00 sec  4.96 MBytes  41.6 Mbits/sec
[  4] 105.00-106.00 sec  4.96 MBytes  41.6 Mbits/sec
[  4] 106.00-107.00 sec  4.76 MBytes  39.9 Mbits/sec
[  4] 107.00-108.00 sec  4.90 MBytes  41.1 Mbits/sec
[  4] 108.00-109.00 sec  4.96 MBytes  41.6 Mbits/sec
[  4] 109.00-110.00 sec  4.86 MBytes  40.7 Mbits/sec
[  4] 110.00-111.00 sec  4.96 MBytes  41.6 Mbits/sec
[  4] 111.00-112.00 sec  4.90 MBytes  41.1 Mbits/sec
[  4] 112.00-113.00 sec  4.86 MBytes  40.7 Mbits/sec
[  4] 113.00-114.00 sec  4.84 MBytes  40.6 Mbits/sec
[  4] 114.00-115.00 sec  4.83 MBytes  40.5 Mbits/sec
[  4] 115.00-116.00 sec  4.97 MBytes  41.7 Mbits/sec
[  4] 116.00-117.00 sec  4.83 MBytes  40.5 Mbits/sec
[  4] 118.00-119.00 sec  4.93 MBytes  41.3 Mbits/sec
[  4] 119.00-120.00 sec  4.90 MBytes  41.1 Mbits/sec
[  4]   0.00-120.00 sec   589 MBytes  41.2 Mbits/sec   95             sender
[  4]   0.00-120.00 sec   587 MBytes  41.0 Mbits/sec                  receiver
iperf Done.
root@orangepilite:~# ping 192.168.83.146
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=2.18 ms
64 bytes from 192.168.83.146: icmp_seq=2 ttl=64 time=3.38 ms
64 bytes from 192.168.83.146: icmp_seq=3 ttl=64 time=1.93 ms
64 bytes from 192.168.83.146: icmp_seq=4 ttl=64 time=1.69 ms
64 bytes from 192.168.83.146: icmp_seq=5 ttl=64 time=1.75 ms
64 bytes from 192.168.83.146: icmp_seq=6 ttl=64 time=1.72 ms
64 bytes from 192.168.83.146: icmp_seq=7 ttl=64 time=1.71 ms
64 bytes from 192.168.83.146: icmp_seq=8 ttl=64 time=2.45 ms
64 bytes from 192.168.83.146: icmp_seq=9 ttl=64 time=3.61 ms
64 bytes from 192.168.83.146: icmp_seq=10 ttl=64 time=1.69 ms
^C
10 packets transmitted, 10 received, 0% packet loss, time 9014ms
rtt min/avg/max/mdev = 1.692/2.216/3.619/0.689 ms
root@orangepilite:~# iwconfig wlan0
          Link Quality=78/100  Signal level=100/100  Noise level=0/100
root@orangepilite:~# nmcli dev wifi list
   WLAN-872870              Infra  11    54 Mbit/s  100     ▂▄▆█  WPA2
*  Snort-Honeynet           Infra  13    54 Mbit/s  93      ▂▄▆█  WPA2
   EasyBox-116D28           Infra  5     54 Mbit/s  74      ▂▄▆_  WPA1 WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  64      ▂▄▆_  WPA1 WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  54      ▂▄__  WPA1 WPA2
   --                       Infra  6     54 Mbit/s  49      ▂▄__  WPA2
   CubaLibre                Infra  11    54 Mbit/s  47      ▂▄__  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  45      ▂▄__  WPA1 WPA2
   WLAN-341381              Infra  11    54 Mbit/s  44      ▂▄__  WPA2
   OSAs Gästenetzwerk       Infra  6     54 Mbit/s  32      ▂▄__  WPA1 WPA2
   FRITZ!Box 7490           Infra  1     54 Mbit/s  30      ▂___  WPA2
   UBNT2                    Infra  3     54 Mbit/s  30      ▂___
   OSA Alpenraum intern     Infra  6     54 Mbit/s  29      ▂___  WPA1 WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  27      ▂___  WPA1 WPA2
   Hasenhirn01              Infra  1     54 Mbit/s  27      ▂___  WPA2
ODROID-C2 with TP-Link TL-WN823N dongle, RTL8192CU module, kernel 3.14.79: 77 Mbits/sec and 73 retransmits on average. Full log: http://sprunge.us/Njhi
root@odroidc2:~# iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120
[  4] local 192.168.83.127 port 35363 connected to 192.168.83.146 port 5201
[  4]   0.00-1.02   sec  5.46 MBytes  45.0 Mbits/sec    0    223 KBytes
[  4]   1.02-2.01   sec  7.11 MBytes  60.3 Mbits/sec    0    291 KBytes
[  4]   2.01-3.01   sec  9.07 MBytes  75.8 Mbits/sec    0    334 KBytes
[  4]   3.01-4.01   sec  7.98 MBytes  67.1 Mbits/sec    0    354 KBytes
[  4]   4.01-5.00   sec  9.35 MBytes  78.6 Mbits/sec    0    379 KBytes
[  4]   5.00-6.02   sec  9.07 MBytes  75.2 Mbits/sec    0    396 KBytes
[  4]   6.02-7.01   sec  9.30 MBytes  78.8 Mbits/sec    0    406 KBytes
[  4]   7.01-8.01   sec  9.04 MBytes  75.8 Mbits/sec    2    212 KBytes
[  4]   8.01-9.01   sec  9.33 MBytes  78.3 Mbits/sec    0    233 KBytes
[  4]   9.01-10.01  sec  9.37 MBytes  78.1 Mbits/sec    0    245 KBytes
[  4]  10.01-11.01  sec  8.02 MBytes  67.7 Mbits/sec    2    134 KBytes
[  4]  11.01-12.01  sec  8.74 MBytes  73.2 Mbits/sec    0    147 KBytes
[  4]  12.01-13.01  sec  7.98 MBytes  67.0 Mbits/sec    1    110 KBytes
[  4]  13.01-14.01  sec  8.56 MBytes  71.8 Mbits/sec    1   94.7 KBytes
[  4]  14.01-15.01  sec  7.91 MBytes  66.4 Mbits/sec    1   86.3 KBytes
[  4]  15.01-16.02  sec  7.22 MBytes  60.0 Mbits/sec    0    100 KBytes
[  4]  16.02-17.01  sec  8.44 MBytes  71.5 Mbits/sec    0    116 KBytes
[  4]  17.01-18.01  sec  8.71 MBytes  73.0 Mbits/sec    0    129 KBytes
[  4]  18.01-19.01  sec  8.26 MBytes  69.3 Mbits/sec    1    103 KBytes
[  4]  19.01-20.00  sec  8.69 MBytes  73.3 Mbits/sec    0    123 KBytes
[  4]  20.00-21.01  sec  8.52 MBytes  71.0 Mbits/sec    1   99.0 KBytes
[  4]  21.01-22.01  sec  8.31 MBytes  69.8 Mbits/sec    1   80.6 KBytes
[  4]  22.01-23.01  sec  7.60 MBytes  63.7 Mbits/sec    0   97.6 KBytes
[  4]  23.01-24.01  sec  8.21 MBytes  68.9 Mbits/sec    1   83.4 KBytes
[  4]  24.01-25.02  sec  7.70 MBytes  63.9 Mbits/sec    0    100 KBytes
[  4]  25.02-26.01  sec  7.26 MBytes  61.5 Mbits/sec    1   89.1 KBytes
[  4]  26.01-27.01  sec  7.79 MBytes  65.4 Mbits/sec    1   77.8 KBytes
[  4]  27.01-28.01  sec  7.48 MBytes  62.7 Mbits/sec    0   96.2 KBytes
[  4]  28.01-29.00  sec  7.90 MBytes  66.6 Mbits/sec    0    112 KBytes
[  4]  29.00-30.00  sec  8.20 MBytes  68.5 Mbits/sec    0    127 KBytes
[  4]  30.00-31.01  sec  7.97 MBytes  66.2 Mbits/sec    0    140 KBytes
[  4]  31.01-32.01  sec  8.07 MBytes  68.3 Mbits/sec    0    150 KBytes
[  4]  32.01-33.02  sec  8.77 MBytes  72.8 Mbits/sec    1    127 KBytes
[  4]  33.02-34.01  sec  8.25 MBytes  69.8 Mbits/sec    1    105 KBytes
[  4]  34.01-35.02  sec  7.90 MBytes  65.7 Mbits/sec    0    119 KBytes
[  4]  35.02-36.01  sec  8.62 MBytes  73.1 Mbits/sec    1    100 KBytes
[  4]  36.01-37.00  sec  8.55 MBytes  72.1 Mbits/sec    0    116 KBytes
[  4]  37.00-38.01  sec  8.54 MBytes  71.3 Mbits/sec    0    123 KBytes
[  4]  38.01-39.01  sec  8.90 MBytes  74.6 Mbits/sec    0    136 KBytes
[  4]  39.01-40.01  sec  8.40 MBytes  70.0 Mbits/sec    0    144 KBytes
[  4]  40.01-41.01  sec  8.82 MBytes  74.4 Mbits/sec    0    154 KBytes
[  4]  41.01-42.01  sec  9.34 MBytes  78.4 Mbits/sec    0    163 KBytes
[  4]  42.01-43.01  sec  9.13 MBytes  76.6 Mbits/sec    0    170 KBytes
[  4]  43.01-44.01  sec  9.07 MBytes  76.0 Mbits/sec    0    177 KBytes
[  4]  44.01-45.02  sec  9.27 MBytes  76.9 Mbits/sec    0    218 KBytes
[  4]  45.02-46.01  sec  9.18 MBytes  77.7 Mbits/sec    0    274 KBytes
[  4]  46.01-47.01  sec  8.99 MBytes  75.5 Mbits/sec    0    334 KBytes
[  4]  47.01-48.01  sec  10.0 MBytes  83.8 Mbits/sec    0    403 KBytes
[  4]  48.01-49.01  sec  9.28 MBytes  78.3 Mbits/sec    1    303 KBytes
[  4]  49.01-50.01  sec  10.1 MBytes  84.6 Mbits/sec    1    245 KBytes
[  4]  50.01-51.02  sec  9.37 MBytes  77.8 Mbits/sec    0    266 KBytes
[  4]  51.02-52.01  sec  9.50 MBytes  80.6 Mbits/sec    0    276 KBytes
[  4]  52.01-53.01  sec  9.10 MBytes  76.3 Mbits/sec    1    198 KBytes
[  4]  53.01-54.01  sec  9.09 MBytes  76.3 Mbits/sec    1    163 KBytes
[  4]  54.01-55.01  sec  9.28 MBytes  77.8 Mbits/sec    0    173 KBytes
[  4]  55.01-56.02  sec  8.37 MBytes  69.5 Mbits/sec    1    137 KBytes
[  4]  56.02-57.01  sec  8.81 MBytes  74.7 Mbits/sec    0    146 KBytes
[  4]  57.01-58.01  sec  9.17 MBytes  76.9 Mbits/sec    0    151 KBytes
[  4]  58.01-59.00  sec  8.66 MBytes  72.8 Mbits/sec    0    160 KBytes
[  4]  59.00-60.01  sec  9.14 MBytes  76.5 Mbits/sec    0    167 KBytes
[  4]  60.01-61.01  sec  8.54 MBytes  71.6 Mbits/sec    0    174 KBytes
[  4]  61.01-62.00  sec  9.06 MBytes  76.1 Mbits/sec    1    141 KBytes
[  4]  62.00-63.01  sec  8.59 MBytes  72.0 Mbits/sec    1    117 KBytes
[  4]  63.01-64.03  sec  7.68 MBytes  63.1 Mbits/sec    2   73.5 KBytes
[  4]  64.03-65.02  sec  7.97 MBytes  67.6 Mbits/sec    0   93.3 KBytes
[  4]  65.02-66.02  sec  8.71 MBytes  72.8 Mbits/sec    1   82.0 KBytes
[  4]  66.02-67.01  sec  8.30 MBytes  70.5 Mbits/sec    0   99.0 KBytes
[  4]  67.01-68.01  sec  8.88 MBytes  73.9 Mbits/sec    0    115 KBytes
[  4]  68.01-69.01  sec  8.84 MBytes  74.3 Mbits/sec    0    127 KBytes
[  4]  69.01-70.01  sec  8.66 MBytes  73.2 Mbits/sec    0    139 KBytes
[  4]  70.01-71.02  sec  8.48 MBytes  70.4 Mbits/sec    0    148 KBytes
[  4]  71.02-72.01  sec  9.68 MBytes  82.0 Mbits/sec    0    158 KBytes
[  4]  72.01-73.03  sec  8.80 MBytes  72.4 Mbits/sec    1    136 KBytes
[  4]  73.03-74.02  sec  8.27 MBytes  70.1 Mbits/sec    0    151 KBytes
[  4]  74.02-75.02  sec  8.75 MBytes  73.4 Mbits/sec    0    158 KBytes
[  4]  75.02-76.02  sec  8.56 MBytes  71.8 Mbits/sec    1    117 KBytes
[  4]  76.02-77.02  sec  8.79 MBytes  73.7 Mbits/sec    1    100 KBytes
[  4]  77.02-78.03  sec  8.93 MBytes  74.2 Mbits/sec    0    115 KBytes
[  4]  78.03-79.02  sec  8.39 MBytes  70.4 Mbits/sec    0    126 KBytes
[  4]  79.02-80.01  sec  7.95 MBytes  67.7 Mbits/sec    0    136 KBytes
[  4]  80.01-81.00  sec  8.38 MBytes  70.8 Mbits/sec    0    146 KBytes
[  4]  81.00-82.02  sec  8.47 MBytes  70.1 Mbits/sec    1    117 KBytes
[  4]  82.02-83.00  sec  8.04 MBytes  68.2 Mbits/sec    1   99.0 KBytes
[  4]  83.00-84.01  sec  8.24 MBytes  68.5 Mbits/sec    0    113 KBytes
[  4]  84.01-85.00  sec  7.86 MBytes  66.7 Mbits/sec    1   99.0 KBytes
[  4]  85.00-86.01  sec  8.37 MBytes  69.6 Mbits/sec    1   83.4 KBytes
[  4]  86.01-87.02  sec  8.40 MBytes  70.1 Mbits/sec    0    102 KBytes
[  4]  87.02-88.02  sec  8.38 MBytes  69.8 Mbits/sec    0    116 KBytes
[  4]  88.02-89.02  sec  8.26 MBytes  69.9 Mbits/sec    1    102 KBytes
[  4]  89.02-90.02  sec  8.50 MBytes  71.3 Mbits/sec    1   83.4 KBytes
[  4]  90.02-91.00  sec  7.87 MBytes  66.8 Mbits/sec    0    100 KBytes
[  4]  91.00-92.03  sec  7.28 MBytes  59.8 Mbits/sec    0    115 KBytes
[  4]  92.03-93.00  sec  7.17 MBytes  61.6 Mbits/sec    1   96.2 KBytes
[  4]  93.00-94.03  sec  7.86 MBytes  64.5 Mbits/sec    0    113 KBytes
[  4]  94.03-95.00  sec  7.44 MBytes  63.7 Mbits/sec    0    122 KBytes
[  4]  95.00-96.02  sec  7.77 MBytes  64.4 Mbits/sec    0    133 KBytes
[  4]  96.02-97.02  sec  7.94 MBytes  66.2 Mbits/sec    1    115 KBytes
[  4]  97.02-98.02  sec  6.88 MBytes  58.0 Mbits/sec    0    129 KBytes
[  4]  98.02-99.02  sec  7.30 MBytes  61.3 Mbits/sec    0    136 KBytes
[  4]  99.02-100.02 sec  7.12 MBytes  59.8 Mbits/sec    0    140 KBytes
[  4] 100.02-101.02 sec  7.12 MBytes  59.8 Mbits/sec    0    151 KBytes
[  4] 101.02-102.00 sec  8.27 MBytes  70.2 Mbits/sec    1    120 KBytes
[  4] 102.00-103.02 sec  8.15 MBytes  67.7 Mbits/sec    0    141 KBytes
[  4] 103.02-104.01 sec  8.54 MBytes  72.4 Mbits/sec    1    112 KBytes
[  4] 104.01-105.02 sec  8.27 MBytes  68.7 Mbits/sec    0    123 KBytes
[  4] 105.02-106.01 sec  7.66 MBytes  64.6 Mbits/sec    1   96.2 KBytes
[  4] 106.01-107.03 sec  8.35 MBytes  69.0 Mbits/sec    0    117 KBytes
[  4] 107.03-108.02 sec  8.78 MBytes  74.1 Mbits/sec    0    129 KBytes
[  4] 108.02-109.01 sec  8.63 MBytes  73.1 Mbits/sec    0    133 KBytes
[  4] 109.01-110.02 sec  8.55 MBytes  71.4 Mbits/sec    1    116 KBytes
[  4] 110.02-111.01 sec  8.67 MBytes  72.8 Mbits/sec    0    127 KBytes
[  4] 111.01-112.02 sec  8.80 MBytes  73.7 Mbits/sec    1   97.6 KBytes
[  4] 112.02-113.01 sec  8.79 MBytes  74.0 Mbits/sec    1   84.8 KBytes
[  4] 113.01-114.00 sec  8.29 MBytes  70.3 Mbits/sec    1   72.1 KBytes
[  4] 114.00-115.02 sec  7.57 MBytes  62.6 Mbits/sec    0   90.5 KBytes
[  4] 115.02-116.00 sec  8.20 MBytes  69.9 Mbits/sec    0    106 KBytes
[  4] 116.00-117.01 sec  8.58 MBytes  71.5 Mbits/sec    1   90.5 KBytes
[  4] 117.01-118.01 sec  8.56 MBytes  71.8 Mbits/sec    0    106 KBytes
[  4] 118.01-119.00 sec  8.72 MBytes  73.5 Mbits/sec    0    119 KBytes
[  4] 119.00-120.03 sec  8.66 MBytes  71.0 Mbits/sec    0    130 KBytes
[  4]   0.00-120.03 sec  1011 MBytes  70.6 Mbits/sec   45             sender
[  4]   0.00-120.03 sec  1010 MBytes  70.6 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.83.127 port 35365 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  9.08 MBytes  76.2 Mbits/sec
[  4]   1.00-2.00   sec  9.23 MBytes  77.4 Mbits/sec
[  4]   2.00-3.00   sec  10.2 MBytes  85.3 Mbits/sec
[  4]   3.00-4.00   sec  10.2 MBytes  85.8 Mbits/sec
[  4]   4.00-5.00   sec  10.0 MBytes  84.2 Mbits/sec
[  4]   5.00-6.00   sec  9.97 MBytes  83.6 Mbits/sec
[  4]   6.00-7.00   sec  10.5 MBytes  88.1 Mbits/sec
[  4]   7.00-8.00   sec  10.2 MBytes  84.9 Mbits/sec
[  4]   8.00-9.00   sec  9.64 MBytes  81.2 Mbits/sec
[  4]   9.00-10.00  sec  10.1 MBytes  84.9 Mbits/sec
[  4]  10.00-11.00  sec  10.1 MBytes  85.0 Mbits/sec
[  4]  11.00-12.00  sec  9.98 MBytes  83.7 Mbits/sec
[  4]  12.00-13.00  sec  10.1 MBytes  85.0 Mbits/sec
[  4]  13.00-14.00  sec  9.91 MBytes  83.2 Mbits/sec
[  4]  14.00-15.00  sec  9.34 MBytes  78.3 Mbits/sec
[  4]  15.00-16.00  sec  10.1 MBytes  84.5 Mbits/sec
[  4]  16.00-17.00  sec  10.1 MBytes  84.7 Mbits/sec
[  4]  17.00-18.00  sec  10.1 MBytes  85.1 Mbits/sec
[  4]  18.00-19.00  sec  10.2 MBytes  85.8 Mbits/sec
[  4]  19.00-20.00  sec  10.2 MBytes  85.7 Mbits/sec
[  4]  20.00-21.00  sec  9.96 MBytes  83.5 Mbits/sec
[  4]  21.00-22.00  sec  10.0 MBytes  84.1 Mbits/sec
[  4]  22.00-23.00  sec  9.76 MBytes  81.9 Mbits/sec
[  4]  23.00-24.00  sec  10.1 MBytes  84.9 Mbits/sec
[  4]  24.00-25.00  sec  10.1 MBytes  84.7 Mbits/sec
[  4]  25.00-26.00  sec  10.2 MBytes  85.3 Mbits/sec
[  4]  26.00-27.00  sec  9.52 MBytes  79.8 Mbits/sec
[  4]  27.00-28.00  sec  7.02 MBytes  58.9 Mbits/sec
[  4]  28.00-29.00  sec  10.6 MBytes  88.9 Mbits/sec
[  4]  29.00-30.00  sec  10.2 MBytes  85.9 Mbits/sec
[  4]  30.00-31.00  sec  10.4 MBytes  87.2 Mbits/sec
[  4]  31.00-32.00  sec  9.99 MBytes  83.8 Mbits/sec
[  4]  32.00-33.00  sec  10.2 MBytes  85.5 Mbits/sec
[  4]  33.00-34.00  sec  10.2 MBytes  86.0 Mbits/sec
[  4]  34.00-35.00  sec  9.39 MBytes  78.7 Mbits/sec
[  4]  35.00-36.01  sec  9.26 MBytes  76.7 Mbits/sec
[  4]  36.01-37.00  sec  10.3 MBytes  87.8 Mbits/sec
[  4]  37.00-38.00  sec  10.1 MBytes  85.1 Mbits/sec
[  4]  38.00-39.00  sec  9.70 MBytes  81.4 Mbits/sec
[  4]  39.00-40.00  sec  9.26 MBytes  77.7 Mbits/sec
[  4]  40.00-41.00  sec  10.3 MBytes  86.4 Mbits/sec
[  4]  41.00-42.00  sec  10.2 MBytes  86.0 Mbits/sec
[  4]  42.00-43.00  sec  9.55 MBytes  80.1 Mbits/sec
[  4]  43.00-44.00  sec  10.4 MBytes  86.9 Mbits/sec
[  4]  44.00-45.00  sec  9.73 MBytes  81.6 Mbits/sec
[  4]  45.00-46.00  sec  9.92 MBytes  83.2 Mbits/sec
[  4]  46.00-47.00  sec  9.85 MBytes  82.4 Mbits/sec
[  4]  47.00-48.00  sec  9.69 MBytes  81.5 Mbits/sec
[  4]  48.00-49.00  sec  9.57 MBytes  80.3 Mbits/sec
[  4]  49.00-50.00  sec  9.69 MBytes  81.3 Mbits/sec
[  4]  50.00-51.00  sec  9.84 MBytes  82.6 Mbits/sec
[  4]  51.00-52.00  sec  9.85 MBytes  82.6 Mbits/sec
[  4]  52.00-53.00  sec  10.5 MBytes  88.1 Mbits/sec
[  4]  53.00-54.00  sec  9.74 MBytes  81.9 Mbits/sec
[  4]  54.00-55.00  sec  9.70 MBytes  81.3 Mbits/sec
[  4]  55.00-56.00  sec  10.1 MBytes  84.6 Mbits/sec
[  4]  56.00-57.00  sec  10.7 MBytes  89.8 Mbits/sec
[  4]  57.00-58.00  sec  9.63 MBytes  80.8 Mbits/sec
[  4]  58.00-59.00  sec  10.2 MBytes  85.2 Mbits/sec
[  4]  59.00-60.01  sec  9.89 MBytes  82.3 Mbits/sec
[  4]  60.01-61.00  sec  10.4 MBytes  87.9 Mbits/sec
[  4]  61.00-62.00  sec  10.8 MBytes  90.5 Mbits/sec
[  4]  62.00-63.00  sec  10.3 MBytes  86.6 Mbits/sec
[  4]  63.00-64.00  sec  9.71 MBytes  81.7 Mbits/sec
[  4]  64.00-65.00  sec  9.78 MBytes  81.7 Mbits/sec
[  4]  65.00-66.00  sec  9.58 MBytes  80.7 Mbits/sec
[  4]  66.00-67.00  sec  9.78 MBytes  82.1 Mbits/sec
[  4]  67.00-68.00  sec  9.94 MBytes  83.3 Mbits/sec
[  4]  68.00-69.00  sec  9.61 MBytes  80.6 Mbits/sec
[  4]  69.00-70.00  sec  10.5 MBytes  88.3 Mbits/sec
[  4]  70.00-71.00  sec  10.1 MBytes  84.4 Mbits/sec
[  4]  71.00-72.00  sec  10.3 MBytes  86.3 Mbits/sec
[  4]  72.00-73.00  sec  10.2 MBytes  85.7 Mbits/sec
[  4]  73.00-74.00  sec  9.87 MBytes  82.9 Mbits/sec
[  4]  74.00-75.00  sec  10.1 MBytes  84.9 Mbits/sec
[  4]  75.00-76.00  sec  9.99 MBytes  83.9 Mbits/sec
[  4]  76.00-77.00  sec  9.44 MBytes  79.2 Mbits/sec
[  4]  77.00-78.00  sec  10.1 MBytes  84.8 Mbits/sec
[  4]  78.00-79.00  sec  9.87 MBytes  83.0 Mbits/sec
[  4]  79.00-80.00  sec  10.3 MBytes  86.1 Mbits/sec
[  4]  80.00-81.00  sec  9.76 MBytes  81.9 Mbits/sec
[  4]  81.00-82.00  sec  10.1 MBytes  84.8 Mbits/sec
[  4]  82.00-83.00  sec  10.2 MBytes  85.5 Mbits/sec
[  4]  83.00-84.00  sec  10.4 MBytes  87.0 Mbits/sec
[  4]  84.00-85.00  sec  10.1 MBytes  85.0 Mbits/sec
[  4]  85.00-86.00  sec  10.1 MBytes  84.8 Mbits/sec
[  4]  86.00-87.00  sec  9.69 MBytes  81.0 Mbits/sec
[  4]  87.00-88.00  sec  10.0 MBytes  84.6 Mbits/sec
[  4]  88.00-89.01  sec  9.67 MBytes  80.5 Mbits/sec
[  4]  89.01-90.00  sec  9.64 MBytes  81.5 Mbits/sec
[  4]  90.00-91.00  sec  10.2 MBytes  85.7 Mbits/sec
[  4]  91.00-92.00  sec  9.80 MBytes  82.2 Mbits/sec
[  4]  92.00-93.00  sec  9.58 MBytes  80.3 Mbits/sec
[  4]  93.00-94.00  sec  10.5 MBytes  87.7 Mbits/sec
[  4]  94.00-95.00  sec  10.1 MBytes  84.9 Mbits/sec
[  4]  95.00-96.00  sec  9.86 MBytes  82.7 Mbits/sec
[  4]  96.00-97.00  sec  9.98 MBytes  83.7 Mbits/sec
[  4]  97.00-98.00  sec  9.72 MBytes  81.5 Mbits/sec
[  4]  98.00-99.00  sec  10.5 MBytes  88.2 Mbits/sec
[  4]  99.00-100.00 sec  10.3 MBytes  86.8 Mbits/sec
[  4] 100.00-101.00 sec  9.75 MBytes  81.8 Mbits/sec
[  4] 101.00-102.00 sec  9.57 MBytes  80.2 Mbits/sec
[  4] 102.00-103.00 sec  10.2 MBytes  85.3 Mbits/sec
[  4] 103.00-104.00 sec  9.77 MBytes  81.9 Mbits/sec
[  4] 104.00-105.00 sec  9.89 MBytes  83.0 Mbits/sec
[  4] 105.00-106.00 sec  10.1 MBytes  84.7 Mbits/sec
[  4] 106.00-107.00 sec  10.1 MBytes  84.7 Mbits/sec
[  4] 107.00-108.00 sec  10.2 MBytes  85.4 Mbits/sec
[  4] 108.00-109.01 sec  10.0 MBytes  83.8 Mbits/sec
[  4] 109.01-110.00 sec  9.72 MBytes  82.0 Mbits/sec
[  4] 110.00-111.00 sec  10.1 MBytes  84.7 Mbits/sec
[  4] 111.00-112.00 sec  10.1 MBytes  84.6 Mbits/sec
[  4] 112.00-113.00 sec  9.88 MBytes  82.9 Mbits/sec
[  4] 113.00-114.00 sec  10.8 MBytes  90.9 Mbits/sec
[  4] 114.00-115.00 sec  9.88 MBytes  82.9 Mbits/sec
[  4] 115.00-116.00 sec  9.65 MBytes  81.0 Mbits/sec
[  4] 116.00-117.00 sec  10.2 MBytes  85.7 Mbits/sec
[  4] 117.00-118.00 sec  10.3 MBytes  86.6 Mbits/sec
[  4] 118.00-119.00 sec  10.2 MBytes  85.2 Mbits/sec
[  4] 119.00-120.00 sec  10.4 MBytes  87.1 Mbits/sec
[  4]   0.00-120.00 sec  1.17 GBytes  83.9 Mbits/sec  101             sender
[  4]   0.00-120.00 sec  1.17 GBytes  83.7 Mbits/sec                  receiver
iperf Done.
root@odroidc2:~# ping 192.168.83.146
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=4.53 ms
64 bytes from 192.168.83.146: icmp_seq=2 ttl=64 time=3.92 ms
64 bytes from 192.168.83.146: icmp_seq=3 ttl=64 time=17.3 ms
64 bytes from 192.168.83.146: icmp_seq=4 ttl=64 time=5.89 ms
64 bytes from 192.168.83.146: icmp_seq=5 ttl=64 time=7.37 ms
64 bytes from 192.168.83.146: icmp_seq=6 ttl=64 time=8.54 ms
64 bytes from 192.168.83.146: icmp_seq=7 ttl=64 time=5.88 ms
64 bytes from 192.168.83.146: icmp_seq=8 ttl=64 time=5.95 ms
64 bytes from 192.168.83.146: icmp_seq=9 ttl=64 time=5.84 ms
^C
9 packets transmitted, 9 received, 0% packet loss, time 8135ms
rtt min/avg/max/mdev = 3.926/7.259/17.384/3.804 ms
root@odroidc2:~# iwconfig wlan0
          Bit Rate:130 Mb/s   Sensitivity:0/0
          Link Quality=100/100  Signal level=-45 dBm  Noise level=0 dBm
root@odroidc2:~# nmcli dev wifi list
*  Snort-Honeynet           Infra  13    2 Mbit/s   100     ▂▄▆█  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     44 Mbit/s  65      ▂▄▆_  WPA1 WPA2
   EasyBox-116D28           Infra  5     16 Mbit/s  65      ▂▄▆_  WPA1 WPA2
   CubaLibre                Infra  11    44 Mbit/s  59      ▂▄▆_  WPA2
   DISTORTEDPEOPLE          Infra  9     44 Mbit/s  50      ▂▄__  WPA1 WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     16 Mbit/s  44      ▂▄__  WPA1 WPA2
   DIRECT-1LC460 Series     Infra  10    54 Mbit/s  44      ▂▄__  WPA2
   WLAN-341381              Infra  11    16 Mbit/s  44      ▂▄__  WPA2
   Wonder Woman             Infra  1     44 Mbit/s  30      ▂___  WPA1 WPA2
How to interpret the results?
  • The test setup is stupid for any real world consideration (if distance between device and AP is just 50 cm then use a cable instead! ;) ) But this set of tests was about identifying the maximum you can get under perfect or at least pretty good conditions (no interference, rather good signal/noise ratio and so on)
  • All 3 onboard Wi-Fi chips perform identical. This is due to single antenna 2.4 GHz Wi-Fi: 65Mbps bit rate resulting in ~40 Mbit/sec TCP/IP throughput with ideal/good/identical environmental conditions
  • The only reason the TP-Link Wi-Fi dongle could outperform the onboard Wi-Fi chips is called MIMO. This is available with 802.11n and makes use of more than one antenna (2 in this dongle's case). Now we're talking about 130 Mbps bit rate resulting in almost 80 Mbit/sec TCP/IP throughput
Next steps:
Let's have a look how worse environmental conditions affect performance. This means increasing distance between AP and device, put a few walls in between, use a more crappy antenna. To save some time I will continue the testing solely with the TP-Link Wi-Fi dongle (connected to the ODROID but here the board doesn't matter at all, it's just about the driver variant/version used) and Orange Pi Lite since this is the cheapest 'general purpose Wi-Fi' enabled board Armbian supports and the same chip is also used on OPi PC Plus and OPi Plus 2E (which are both also priced very competitively for their feature set).
But I will add also results from Raspberry Zero W if this board ever arrives (if not I'll take RPi 3 instead, both use same BCM43438 chip that is also contained in Ampak's AP6212 which is the solution present on most Wi-Fi enabled Armbian boards)
Small update: Tried two more locations within the same building with OPi Lite and the other board with RTL8192CU MIMO dongle:
Location 1: 4 meters away, 2 walls in between, wall angle approx. 30°
Orange Pi Lite: 33 Mbits/sec on average
Connecting to host 192.168.83.146, port 5201
[  4] local 192.168.83.98 port 58680 connected to 192.168.83.146 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec  2.97 MBytes  24.9 Mbits/sec    4   33.9 KBytes
[  4]   1.00-2.00   sec  2.97 MBytes  24.9 Mbits/sec    0   58.0 KBytes
[  4]   2.00-3.00   sec  3.80 MBytes  31.9 Mbits/sec    0   79.2 KBytes
[  4]   3.00-4.00   sec  3.92 MBytes  32.9 Mbits/sec    0   96.2 KBytes
[  4]   4.00-5.00   sec  4.03 MBytes  33.8 Mbits/sec    0    110 KBytes
[  4]   5.00-6.00   sec  3.80 MBytes  31.9 Mbits/sec    0    119 KBytes
[  4]   6.00-7.00   sec  3.84 MBytes  32.2 Mbits/sec    0    127 KBytes
[  4]   7.00-8.00   sec  4.04 MBytes  33.8 Mbits/sec    0    134 KBytes
[  4]   8.00-9.00   sec  3.93 MBytes  32.9 Mbits/sec    0    151 KBytes
[  4]   9.00-10.00  sec  4.24 MBytes  35.6 Mbits/sec    0    219 KBytes
[  4]  10.00-11.00  sec  4.01 MBytes  33.7 Mbits/sec    0    308 KBytes
[  4]  11.00-12.00  sec  4.12 MBytes  34.6 Mbits/sec    0    426 KBytes
[  4]  12.00-13.00  sec  3.42 MBytes  28.7 Mbits/sec    1    348 KBytes
[  4]  13.00-14.00  sec  3.95 MBytes  33.1 Mbits/sec    0    387 KBytes
[  4]  14.00-15.00  sec  3.82 MBytes  32.1 Mbits/sec    0    413 KBytes
[  4]  15.00-16.00  sec  3.70 MBytes  31.1 Mbits/sec    0    427 KBytes
[  4]  16.00-17.00  sec  3.96 MBytes  33.3 Mbits/sec    0    433 KBytes
[  4]  17.00-18.00  sec  4.27 MBytes  35.8 Mbits/sec    0    433 KBytes
[  4]  18.00-19.00  sec  3.54 MBytes  29.7 Mbits/sec    0    433 KBytes
[  4]  19.00-20.00  sec  3.81 MBytes  31.9 Mbits/sec    0    436 KBytes
[  4]  20.00-21.00  sec  4.15 MBytes  34.8 Mbits/sec    0    444 KBytes
[  4]  21.00-22.00  sec  3.83 MBytes  32.1 Mbits/sec    0    460 KBytes
[  4]  22.00-23.00  sec  3.93 MBytes  33.0 Mbits/sec    1    372 KBytes
[  4]  23.00-24.00  sec  4.23 MBytes  35.5 Mbits/sec    0    411 KBytes
[  4]  24.00-25.00  sec  4.05 MBytes  33.9 Mbits/sec    0    438 KBytes
[  4]  25.00-26.00  sec  4.09 MBytes  34.3 Mbits/sec    0    452 KBytes
[  4]  26.00-27.00  sec  4.29 MBytes  36.0 Mbits/sec    0    458 KBytes
[  4]  27.00-28.00  sec  4.00 MBytes  33.5 Mbits/sec    0    460 KBytes
[  4]  28.00-29.00  sec  4.00 MBytes  33.6 Mbits/sec    0    460 KBytes
[  4]  29.00-30.00  sec  4.03 MBytes  33.8 Mbits/sec    0    461 KBytes
[  4]  30.00-31.00  sec  4.05 MBytes  33.9 Mbits/sec    0    469 KBytes
[  4]  31.00-32.00  sec  4.21 MBytes  35.3 Mbits/sec    0    485 KBytes
[  4]  32.00-33.00  sec  3.75 MBytes  31.4 Mbits/sec    0    513 KBytes
[  4]  33.00-34.00  sec  4.28 MBytes  35.9 Mbits/sec    0    556 KBytes
[  4]  34.00-35.00  sec  3.75 MBytes  31.5 Mbits/sec    0    618 KBytes
[  4]  35.00-36.00  sec  4.37 MBytes  36.6 Mbits/sec    0    700 KBytes
[  4]  36.00-37.00  sec  4.33 MBytes  36.3 Mbits/sec    0    809 KBytes
[  4]  37.00-38.00  sec  4.17 MBytes  35.0 Mbits/sec    0    942 KBytes
[  4]  38.00-39.00  sec  4.23 MBytes  35.5 Mbits/sec    0   1.08 MBytes
[  4]  39.00-40.00  sec  4.18 MBytes  35.1 Mbits/sec    0   1.27 MBytes
[  4]  40.00-41.00  sec  4.47 MBytes  37.5 Mbits/sec    0   1.49 MBytes
[  4]  41.00-42.00  sec  3.62 MBytes  30.3 Mbits/sec    0   1.75 MBytes
[  4]  42.00-43.00  sec  4.36 MBytes  36.6 Mbits/sec    0   1.03 MBytes
[  4]  43.00-44.00  sec  4.37 MBytes  36.7 Mbits/sec    0   1.37 MBytes
[  4]  44.00-45.00  sec  3.49 MBytes  29.2 Mbits/sec    0   1.51 MBytes
[  4]  45.00-46.00  sec  4.40 MBytes  36.9 Mbits/sec    0   1.63 MBytes
[  4]  46.00-47.00  sec  3.59 MBytes  30.1 Mbits/sec    0   1.72 MBytes
[  4]  47.00-48.00  sec  4.50 MBytes  37.7 Mbits/sec    0   1.80 MBytes
[  4]  48.00-49.00  sec  3.62 MBytes  30.4 Mbits/sec    0   1.85 MBytes
[  4]  49.00-50.00  sec  3.48 MBytes  29.2 Mbits/sec    0   1.89 MBytes
[  4]  50.00-51.00  sec  4.37 MBytes  36.7 Mbits/sec    0   1.91 MBytes
[  4]  51.00-52.00  sec  3.52 MBytes  29.5 Mbits/sec    0   1.93 MBytes
[  4]  52.00-53.00  sec  4.56 MBytes  38.2 Mbits/sec    0    949 KBytes
[  4]  53.00-54.00  sec  3.54 MBytes  29.7 Mbits/sec    0   1.39 MBytes
[  4]  54.00-55.00  sec  4.44 MBytes  37.3 Mbits/sec    0   1.48 MBytes
[  4]  55.00-56.00  sec  3.52 MBytes  29.5 Mbits/sec    0   1.54 MBytes
[  4]  56.00-57.00  sec  3.51 MBytes  29.5 Mbits/sec    0   1.58 MBytes
[  4]  57.00-58.00  sec  4.37 MBytes  36.7 Mbits/sec    0   1.61 MBytes
[  4]  58.00-59.00  sec  4.41 MBytes  37.0 Mbits/sec    0   1.63 MBytes
[  4]  59.00-60.00  sec  3.44 MBytes  28.9 Mbits/sec    0   1.64 MBytes
[  4]  60.00-61.00  sec  4.40 MBytes  36.9 Mbits/sec    0   1.64 MBytes
[  4]  61.00-62.00  sec  3.59 MBytes  30.1 Mbits/sec    0   1.64 MBytes
[  4]  62.00-63.00  sec  4.42 MBytes  37.1 Mbits/sec    0   1.64 MBytes
[  4]  63.00-64.00  sec  4.46 MBytes  37.4 Mbits/sec    0   1.65 MBytes
[  4]  64.00-65.00  sec  3.52 MBytes  29.5 Mbits/sec    0   1.66 MBytes
[  4]  65.00-66.00  sec  3.53 MBytes  29.6 Mbits/sec    0   1.68 MBytes
[  4]  66.00-67.00  sec  4.41 MBytes  37.0 Mbits/sec    0   1.72 MBytes
[  4]  67.00-68.00  sec  3.57 MBytes  29.9 Mbits/sec    0   1.77 MBytes
[  4]  68.00-69.00  sec  4.44 MBytes  37.3 Mbits/sec    0   1.84 MBytes
[  4]  69.00-70.00  sec  3.59 MBytes  30.1 Mbits/sec    0   1.64 MBytes
[  4]  70.00-71.00  sec  4.41 MBytes  37.0 Mbits/sec    0   1.35 MBytes
[  4]  71.00-72.00  sec  2.72 MBytes  22.8 Mbits/sec    1   1.17 MBytes
[  4]  72.00-73.00  sec  3.88 MBytes  32.5 Mbits/sec    1    783 KBytes
[  4]  73.00-74.00  sec  4.76 MBytes  39.9 Mbits/sec    0    795 KBytes
[  4]  74.00-75.00  sec  4.37 MBytes  36.6 Mbits/sec    0    841 KBytes
[  4]  75.00-76.00  sec  4.36 MBytes  36.6 Mbits/sec    0    871 KBytes
[  4]  76.00-77.00  sec  3.49 MBytes  29.2 Mbits/sec    0    889 KBytes
[  4]  77.00-78.00  sec  4.41 MBytes  37.0 Mbits/sec    0    899 KBytes
[  4]  78.00-79.00  sec  3.55 MBytes  29.8 Mbits/sec    0    901 KBytes
[  4]  79.00-80.00  sec  4.49 MBytes  37.6 Mbits/sec    0    901 KBytes
[  4]  80.00-81.00  sec  4.51 MBytes  37.8 Mbits/sec    0    902 KBytes
[  4]  81.00-82.00  sec  3.54 MBytes  29.7 Mbits/sec    0    908 KBytes
[  4]  82.00-83.00  sec  4.43 MBytes  37.2 Mbits/sec    0    921 KBytes
[  4]  83.00-84.00  sec  2.68 MBytes  22.5 Mbits/sec    0    939 KBytes
[  4]  84.00-85.00  sec  3.53 MBytes  29.6 Mbits/sec    0    981 KBytes
[  4]  85.00-86.00  sec  4.47 MBytes  37.5 Mbits/sec    0   1.01 MBytes
[  4]  86.00-87.00  sec  3.47 MBytes  29.1 Mbits/sec    0   1.09 MBytes
[  4]  87.00-88.00  sec  4.41 MBytes  37.0 Mbits/sec    0   1.18 MBytes
[  4]  88.00-89.00  sec  4.39 MBytes  36.8 Mbits/sec    0   1.30 MBytes
[  4]  89.00-90.00  sec  3.54 MBytes  29.7 Mbits/sec    0   1.46 MBytes
[  4]  90.00-91.00  sec  4.37 MBytes  36.6 Mbits/sec    0   1.64 MBytes
[  4]  91.00-92.00  sec  4.35 MBytes  36.5 Mbits/sec    0   1.85 MBytes
[  4]  92.00-93.00  sec  4.33 MBytes  36.3 Mbits/sec    0    861 KBytes
[  4]  93.00-94.00  sec  3.51 MBytes  29.4 Mbits/sec    0   1.41 MBytes
[  4]  94.00-95.00  sec  4.42 MBytes  37.1 Mbits/sec    0   1.54 MBytes
[  4]  95.00-96.00  sec  3.56 MBytes  29.8 Mbits/sec    0   1.66 MBytes
[  4]  96.00-97.00  sec  4.35 MBytes  36.5 Mbits/sec    0   1.75 MBytes
[  4]  97.00-98.00  sec  4.42 MBytes  37.1 Mbits/sec    0   1.81 MBytes
[  4]  98.00-99.00  sec  4.34 MBytes  36.4 Mbits/sec    0   1.86 MBytes
[  4]  99.00-100.00 sec  3.50 MBytes  29.3 Mbits/sec    0   1.89 MBytes
[  4] 100.00-101.00 sec  4.40 MBytes  36.9 Mbits/sec    0   1.92 MBytes
[  4] 101.00-102.00 sec  4.47 MBytes  37.5 Mbits/sec    0   1.93 MBytes
[  4] 102.00-103.00 sec  3.50 MBytes  29.4 Mbits/sec    0   1.93 MBytes
[  4] 103.00-104.00 sec  4.37 MBytes  36.7 Mbits/sec    0   1.09 MBytes
[  4] 104.00-105.00 sec  3.93 MBytes  33.0 Mbits/sec    1    990 KBytes
[  4] 105.00-106.00 sec  4.57 MBytes  38.4 Mbits/sec    0   1.04 MBytes
[  4] 106.00-107.00 sec  3.56 MBytes  29.9 Mbits/sec    0   1.08 MBytes
[  4] 107.00-108.00 sec  4.36 MBytes  36.6 Mbits/sec    0   1.12 MBytes
[  4] 108.00-109.00 sec  3.52 MBytes  29.5 Mbits/sec    0   1.14 MBytes
[  4] 109.00-110.00 sec  4.39 MBytes  36.8 Mbits/sec    0   1.15 MBytes
[  4] 110.00-111.00 sec  4.45 MBytes  37.2 Mbits/sec    0   1.15 MBytes
[  4] 111.00-112.00 sec  3.54 MBytes  29.8 Mbits/sec    0   1.15 MBytes
[  4] 112.00-113.00 sec  3.50 MBytes  29.4 Mbits/sec    0   1.15 MBytes
[  4] 113.00-114.00 sec  4.42 MBytes  37.1 Mbits/sec    0   1.16 MBytes
[  4] 114.00-115.00 sec  4.41 MBytes  37.0 Mbits/sec    0   1.17 MBytes
[  4] 115.00-116.00 sec  3.50 MBytes  29.4 Mbits/sec    0   1.19 MBytes
[  4] 116.00-117.00 sec  4.36 MBytes  36.6 Mbits/sec    0   1.22 MBytes
[  4] 117.00-118.00 sec  3.58 MBytes  30.0 Mbits/sec    0   1.27 MBytes
[  4] 118.00-119.00 sec  4.34 MBytes  36.4 Mbits/sec    0   1.34 MBytes
[  4] 119.00-120.00 sec  2.70 MBytes  22.6 Mbits/sec    0   1.42 MBytes
[  4]   0.00-120.00 sec   478 MBytes  33.4 Mbits/sec    9             sender
[  4]   0.00-120.00 sec   478 MBytes  33.4 Mbits/sec                  receiver
iperf Done.
Reverse mode, remote host 192.168.83.146 is sending
[  4] local 192.168.83.98 port 58682 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  3.25 MBytes  27.3 Mbits/sec
[  4]   1.00-2.00   sec  3.62 MBytes  30.4 Mbits/sec
[  4]   2.00-3.00   sec  3.64 MBytes  30.5 Mbits/sec
[  4]   3.00-4.00   sec  3.50 MBytes  29.3 Mbits/sec
[  4]   4.00-5.00   sec  3.64 MBytes  30.5 Mbits/sec
[  4]   5.00-6.00   sec  3.69 MBytes  30.9 Mbits/sec
[  4]   6.00-7.00   sec  3.19 MBytes  26.8 Mbits/sec
[  4]   7.00-8.00   sec  3.92 MBytes  32.9 Mbits/sec
[  4]   8.00-9.00   sec  4.12 MBytes  34.6 Mbits/sec
[  4]   9.00-10.00  sec  4.04 MBytes  33.9 Mbits/sec
[  4]  10.00-11.00  sec  3.89 MBytes  32.6 Mbits/sec
[  4]  11.00-12.00  sec  3.83 MBytes  32.1 Mbits/sec
[  4]  12.00-13.00  sec  4.18 MBytes  35.1 Mbits/sec
[  4]  13.00-14.00  sec  3.77 MBytes  31.6 Mbits/sec
[  4]  14.00-15.00  sec  4.09 MBytes  34.3 Mbits/sec
[  4]  15.00-16.00  sec  3.77 MBytes  31.6 Mbits/sec
[  4]  16.00-17.00  sec  3.98 MBytes  33.4 Mbits/sec
[  4]  17.00-18.00  sec  4.02 MBytes  33.7 Mbits/sec
[  4]  18.00-19.00  sec  3.86 MBytes  32.4 Mbits/sec
[  4]  19.00-20.00  sec  3.90 MBytes  32.7 Mbits/sec
[  4]  20.00-21.00  sec  4.08 MBytes  34.2 Mbits/sec
[  4]  21.00-22.00  sec  3.72 MBytes  31.2 Mbits/sec
[  4]  22.00-23.00  sec  3.84 MBytes  32.2 Mbits/sec
[  4]  23.00-24.00  sec  3.62 MBytes  30.4 Mbits/sec
[  4]  24.00-25.00  sec  3.65 MBytes  30.6 Mbits/sec
[  4]  25.00-26.00  sec  3.10 MBytes  26.0 Mbits/sec
[  4]  26.00-27.00  sec  3.14 MBytes  26.4 Mbits/sec
[  4]  27.00-28.00  sec  3.65 MBytes  30.6 Mbits/sec
[  4]  28.00-29.00  sec  4.08 MBytes  34.2 Mbits/sec
[  4]  29.00-30.00  sec  3.18 MBytes  26.7 Mbits/sec
[  4]  30.00-31.00  sec  2.92 MBytes  24.5 Mbits/sec
[  4]  31.00-32.00  sec  3.87 MBytes  32.5 Mbits/sec
[  4]  32.00-33.00  sec  3.71 MBytes  31.1 Mbits/sec
[  4]  33.00-34.00  sec  3.67 MBytes  30.8 Mbits/sec
[  4]  34.00-35.00  sec  3.94 MBytes  33.1 Mbits/sec
[  4]  35.00-36.00  sec  4.02 MBytes  33.7 Mbits/sec
[  4]  36.00-37.00  sec  3.94 MBytes  33.0 Mbits/sec
[  4]  37.00-38.00  sec  3.97 MBytes  33.3 Mbits/sec
[  4]  38.00-39.00  sec  4.26 MBytes  35.8 Mbits/sec
[  4]  39.00-40.00  sec  3.90 MBytes  32.7 Mbits/sec
[  4]  40.00-41.00  sec  4.09 MBytes  34.3 Mbits/sec
[  4]  41.00-42.00  sec  4.14 MBytes  34.8 Mbits/sec
[  4]  42.00-43.00  sec  3.77 MBytes  31.6 Mbits/sec
[  4]  43.00-44.00  sec  4.28 MBytes  35.9 Mbits/sec
[  4]  44.00-45.00  sec  4.30 MBytes  36.0 Mbits/sec
[  4]  45.00-46.00  sec  3.98 MBytes  33.4 Mbits/sec
[  4]  46.00-47.00  sec  3.85 MBytes  32.3 Mbits/sec
[  4]  47.00-48.00  sec  3.90 MBytes  32.7 Mbits/sec
[  4]  48.00-49.00  sec  4.30 MBytes  36.0 Mbits/sec
[  4]  49.00-50.00  sec  3.87 MBytes  32.4 Mbits/sec
[  4]  50.00-51.00  sec  3.75 MBytes  31.5 Mbits/sec
[  4]  51.00-52.00  sec  3.92 MBytes  32.9 Mbits/sec
[  4]  52.00-53.00  sec  3.93 MBytes  33.0 Mbits/sec
[  4]  53.00-54.00  sec  3.94 MBytes  33.0 Mbits/sec
[  4]  54.00-55.00  sec  4.16 MBytes  34.9 Mbits/sec
[  4]  55.00-56.00  sec  4.05 MBytes  34.0 Mbits/sec
[  4]  56.00-57.00  sec  3.90 MBytes  32.7 Mbits/sec
[  4]  57.00-58.00  sec  4.12 MBytes  34.6 Mbits/sec
[  4]  58.00-59.00  sec  4.04 MBytes  33.9 Mbits/sec
[  4]  59.00-60.00  sec  4.24 MBytes  35.6 Mbits/sec
[  4]  60.00-61.00  sec  3.97 MBytes  33.3 Mbits/sec
[  4]  61.00-62.00  sec  4.21 MBytes  35.3 Mbits/sec
[  4]  62.00-63.00  sec  4.03 MBytes  33.8 Mbits/sec
[  4]  63.00-64.00  sec  3.62 MBytes  30.4 Mbits/sec
[  4]  64.00-65.00  sec  4.24 MBytes  35.5 Mbits/sec
[  4]  65.00-66.00  sec  4.01 MBytes  33.7 Mbits/sec
[  4]  66.00-67.00  sec  4.09 MBytes  34.3 Mbits/sec
[  4]  67.00-68.00  sec  3.54 MBytes  29.7 Mbits/sec
[  4]  68.00-69.00  sec  4.18 MBytes  35.1 Mbits/sec
[  4]  69.00-70.00  sec  3.12 MBytes  26.1 Mbits/sec
[  4]  70.00-71.00  sec  3.03 MBytes  25.4 Mbits/sec
[  4]  71.00-72.00  sec  3.82 MBytes  32.0 Mbits/sec
[  4]  72.00-73.00  sec  3.81 MBytes  32.0 Mbits/sec
[  4]  73.00-74.00  sec  4.05 MBytes  34.0 Mbits/sec
[  4]  74.00-75.00  sec  3.75 MBytes  31.5 Mbits/sec
[  4]  75.00-76.00  sec  4.11 MBytes  34.5 Mbits/sec
[  4]  76.00-77.00  sec  3.92 MBytes  32.9 Mbits/sec
[  4]  77.00-78.00  sec  4.28 MBytes  35.9 Mbits/sec
[  4]  78.00-79.00  sec  4.22 MBytes  35.4 Mbits/sec
[  4]  79.00-80.00  sec  4.01 MBytes  33.7 Mbits/sec
[  4]  80.00-81.00  sec  3.82 MBytes  32.1 Mbits/sec
[  4]  81.00-82.00  sec  4.14 MBytes  34.7 Mbits/sec
[  4]  82.00-83.00  sec  4.37 MBytes  36.7 Mbits/sec
[  4]  83.00-84.00  sec  3.90 MBytes  32.7 Mbits/sec
[  4]  84.00-85.00  sec  4.03 MBytes  33.8 Mbits/sec
[  4]  85.00-86.00  sec  4.02 MBytes  33.7 Mbits/sec
[  4]  86.00-87.00  sec  3.77 MBytes  31.6 Mbits/sec
[  4]  87.00-88.00  sec  3.88 MBytes  32.6 Mbits/sec
[  4]  88.00-89.00  sec  3.89 MBytes  32.7 Mbits/sec
[  4]  89.00-90.00  sec  3.83 MBytes  32.1 Mbits/sec
[  4]  90.00-91.00  sec  3.95 MBytes  33.1 Mbits/sec
[  4]  91.00-92.00  sec  3.88 MBytes  32.5 Mbits/sec
[  4]  92.00-93.00  sec  3.75 MBytes  31.4 Mbits/sec
[  4]  93.00-94.00  sec  3.90 MBytes  32.7 Mbits/sec
[  4]  94.00-95.00  sec  3.88 MBytes  32.6 Mbits/sec
[  4]  95.00-96.00  sec  4.08 MBytes  34.2 Mbits/sec
[  4]  96.00-97.00  sec  3.95 MBytes  33.2 Mbits/sec
[  4]  97.00-98.00  sec  3.84 MBytes  32.2 Mbits/sec
[  4]  98.00-99.00  sec  3.97 MBytes  33.3 Mbits/sec
[  4]  99.00-100.00 sec  4.11 MBytes  34.4 Mbits/sec
[  4] 100.00-101.00 sec  3.86 MBytes  32.4 Mbits/sec
[  4] 101.00-102.00 sec  3.85 MBytes  32.3 Mbits/sec
[  4] 102.00-103.00 sec  3.60 MBytes  30.2 Mbits/sec
[  4] 103.00-104.00 sec  3.93 MBytes  32.9 Mbits/sec
[  4] 104.00-105.00 sec  3.98 MBytes  33.4 Mbits/sec
[  4] 105.00-106.00 sec  3.78 MBytes  31.7 Mbits/sec
[  4] 106.00-107.00 sec  3.95 MBytes  33.1 Mbits/sec
[  4] 107.00-108.00 sec  3.84 MBytes  32.2 Mbits/sec
[  4] 108.00-109.00 sec  3.94 MBytes  33.0 Mbits/sec
[  4] 109.00-110.00 sec  3.75 MBytes  31.5 Mbits/sec
[  4] 110.00-111.00 sec  4.08 MBytes  34.2 Mbits/sec
[  4] 111.00-112.00 sec  3.58 MBytes  30.0 Mbits/sec
[  4] 112.00-113.00 sec  3.71 MBytes  31.1 Mbits/sec
[  4] 113.00-114.00 sec  4.04 MBytes  33.8 Mbits/sec
[  4] 114.00-115.00 sec  3.95 MBytes  33.2 Mbits/sec
[  4] 115.00-116.00 sec  3.89 MBytes  32.6 Mbits/sec
[  4] 116.00-117.00 sec  3.75 MBytes  31.4 Mbits/sec
[  4] 117.00-118.00 sec  3.48 MBytes  29.2 Mbits/sec
[  4] 118.00-119.00 sec  4.03 MBytes  33.8 Mbits/sec
[  4] 119.00-120.00 sec  3.74 MBytes  31.4 Mbits/sec
[  4]   0.00-120.00 sec   467 MBytes  32.7 Mbits/sec  114             sender
[  4]   0.00-120.00 sec   465 MBytes  32.5 Mbits/sec                  receiver
iperf Done.
          Mode:Managed  Frequency:2.472 GHz  Access Point: BC:05:43:BE:C1:E7
          Power Management:off
          Link Quality=66/100  Signal level=76/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
*  SSID                     MODE   CHAN  RATE       SIGNAL  BARS  SECURITY
   CubaLibre                Infra  11    54 Mbit/s  62      ▂▄▆_  WPA2
*  Snort-Honeynet           Infra  13    54 Mbit/s  61      ▂▄▆_  WPA2
   CubaLibre                Infra  11    54 Mbit/s  44      ▂▄__  WPA1 WPA2
   EasyBox-116D28           Infra  5     54 Mbit/s  40      ▂▄__  WPA1 WPA2
   o2-WLAN91                Infra  5     54 Mbit/s  37      ▂▄__  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  34      ▂▄__  WPA1 WPA2
   WLAN-872870              Infra  11    54 Mbit/s  32      ▂▄__  WPA2
   Villa Rosina             Infra  3     54 Mbit/s  30      ▂___  WPA1 WPA2
   --                       Infra  6     54 Mbit/s  30      ▂___  WPA2
   OSA Alpenraum intern     Infra  6     54 Mbit/s  30      ▂___  WPA1 WPA2
   o2-WLAN09                Infra  8     54 Mbit/s  30      ▂___  WPA2
   WLAN-983298              Infra  11    54 Mbit/s  30      ▂___  WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  29      ▂___  WPA1 WPA2
   FRITZ!Box 7490           Infra  1     54 Mbit/s  27      ▂___  WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  27      ▂___  WPA1 WPA2
   Telekom_FON              Infra  11    54 Mbit/s  27      ▂___
   OSAs Gästenetzwerk       Infra  6     54 Mbit/s  24      ▂___  WPA1 WPA2
   o2-WLAN30                Infra  13    54 Mbit/s  24      ▂___  WPA2
ODROID-C2 with MIMO USB dongle: 51 Mbits/sec on average
[  4] local 192.168.83.127 port 33581 connected to 192.168.83.146 port 5201
[  4]   0.00-1.01   sec  3.41 MBytes  28.2 Mbits/sec   11   63.6 KBytes
[  4]   1.01-2.00   sec  4.61 MBytes  39.1 Mbits/sec    0   84.8 KBytes
[  4]   2.00-3.01   sec  4.01 MBytes  33.3 Mbits/sec    0   93.3 KBytes
[  4]   3.01-4.02   sec  5.38 MBytes  45.0 Mbits/sec    0    105 KBytes
[  4]   4.02-5.00   sec  4.48 MBytes  38.2 Mbits/sec    0    112 KBytes
[  4]   5.00-6.00   sec  5.23 MBytes  43.8 Mbits/sec    0    120 KBytes
[  4]   6.00-7.01   sec  4.75 MBytes  39.4 Mbits/sec    0    127 KBytes
[  4]   7.01-8.00   sec  4.18 MBytes  35.5 Mbits/sec    0    132 KBytes
[  4]   8.00-9.02   sec  5.22 MBytes  43.1 Mbits/sec    0    170 KBytes
[  4]   9.02-10.01  sec  5.20 MBytes  43.7 Mbits/sec    0    209 KBytes
[  4]  10.01-11.02  sec  4.59 MBytes  38.2 Mbits/sec    0    235 KBytes
[  4]  11.02-12.01  sec  4.16 MBytes  35.5 Mbits/sec    0    243 KBytes
[  4]  12.01-13.02  sec  4.27 MBytes  35.3 Mbits/sec    0    243 KBytes
[  4]  13.02-14.00  sec  5.03 MBytes  43.2 Mbits/sec    0    243 KBytes
[  4]  14.00-15.02  sec  4.67 MBytes  38.3 Mbits/sec    0    249 KBytes
[  4]  15.02-16.01  sec  6.00 MBytes  50.9 Mbits/sec    1    218 KBytes
[  4]  16.01-17.01  sec  5.16 MBytes  43.3 Mbits/sec    0    243 KBytes
[  4]  17.01-18.02  sec  4.71 MBytes  39.1 Mbits/sec    0    243 KBytes
[  4]  18.02-19.01  sec  5.50 MBytes  46.6 Mbits/sec    1    177 KBytes
[  4]  19.01-20.00  sec  5.49 MBytes  46.6 Mbits/sec    1    141 KBytes
[  4]  20.00-21.01  sec  5.19 MBytes  43.2 Mbits/sec    0    151 KBytes
[  4]  21.01-22.01  sec  5.13 MBytes  42.9 Mbits/sec    0    154 KBytes
[  4]  22.01-23.00  sec  5.42 MBytes  46.0 Mbits/sec    0    154 KBytes
[  4]  23.00-24.01  sec  5.38 MBytes  44.6 Mbits/sec    0    154 KBytes
[  4]  24.01-25.02  sec  5.52 MBytes  46.2 Mbits/sec    0    160 KBytes
[  4]  25.02-26.02  sec  5.40 MBytes  45.0 Mbits/sec    2   99.0 KBytes
[  4]  26.02-27.01  sec  4.91 MBytes  41.6 Mbits/sec    0    107 KBytes
[  4]  27.01-28.02  sec  4.41 MBytes  36.6 Mbits/sec    0    112 KBytes
[  4]  28.02-29.01  sec  5.08 MBytes  43.2 Mbits/sec    0    120 KBytes
[  4]  29.01-30.02  sec  4.88 MBytes  40.3 Mbits/sec    0    127 KBytes
[  4]  30.02-31.02  sec  5.20 MBytes  43.7 Mbits/sec    0    134 KBytes
[  4]  31.02-32.02  sec  5.14 MBytes  43.2 Mbits/sec    0    141 KBytes
[  4]  32.02-33.02  sec  5.61 MBytes  47.3 Mbits/sec    0    150 KBytes
[  4]  33.02-34.02  sec  6.08 MBytes  50.6 Mbits/sec    0    182 KBytes
[  4]  34.02-35.01  sec  5.15 MBytes  43.6 Mbits/sec    0    229 KBytes
[  4]  35.01-36.01  sec  5.50 MBytes  46.1 Mbits/sec    0    288 KBytes
[  4]  36.01-37.01  sec  4.85 MBytes  40.7 Mbits/sec    0    334 KBytes
[  4]  37.01-38.00  sec  5.76 MBytes  48.8 Mbits/sec    0    354 KBytes
[  4]  38.00-39.01  sec  5.92 MBytes  49.2 Mbits/sec    0    359 KBytes
[  4]  39.01-40.01  sec  5.24 MBytes  44.2 Mbits/sec    0    372 KBytes
[  4]  40.01-41.01  sec  5.87 MBytes  48.9 Mbits/sec    0    383 KBytes
[  4]  41.01-42.02  sec  6.23 MBytes  51.8 Mbits/sec    0    387 KBytes
[  4]  42.02-43.01  sec  5.10 MBytes  43.4 Mbits/sec    0    387 KBytes
[  4]  43.01-44.01  sec  5.56 MBytes  46.4 Mbits/sec    0    392 KBytes
[  4]  44.01-45.01  sec  5.44 MBytes  45.6 Mbits/sec    0    392 KBytes
[  4]  45.01-46.01  sec  5.35 MBytes  44.9 Mbits/sec    0    393 KBytes
[  4]  46.01-47.01  sec  5.52 MBytes  46.3 Mbits/sec    1    286 KBytes
[  4]  47.01-48.02  sec  5.55 MBytes  46.1 Mbits/sec    0    315 KBytes
[  4]  48.02-49.02  sec  5.65 MBytes  47.8 Mbits/sec    0    339 KBytes
[  4]  49.02-50.01  sec  5.82 MBytes  48.9 Mbits/sec    0    346 KBytes
[  4]  50.01-51.00  sec  5.13 MBytes  43.5 Mbits/sec    0    358 KBytes
[  4]  51.00-52.01  sec  5.34 MBytes  44.4 Mbits/sec    0    366 KBytes
[  4]  52.01-53.02  sec  5.38 MBytes  44.7 Mbits/sec    0    373 KBytes
[  4]  53.02-54.01  sec  6.14 MBytes  52.3 Mbits/sec    0    376 KBytes
[  4]  54.01-55.02  sec  5.09 MBytes  42.0 Mbits/sec    0    376 KBytes
[  4]  55.02-56.01  sec  5.23 MBytes  44.3 Mbits/sec    0    379 KBytes
[  4]  56.01-57.01  sec  5.11 MBytes  42.9 Mbits/sec    0    383 KBytes
[  4]  57.01-58.01  sec  5.20 MBytes  43.6 Mbits/sec    0    383 KBytes
[  4]  58.01-59.01  sec  5.64 MBytes  47.3 Mbits/sec    0    389 KBytes
[  4]  59.01-60.02  sec  5.54 MBytes  46.0 Mbits/sec    1    276 KBytes
[  4]  60.02-61.01  sec  5.57 MBytes  47.2 Mbits/sec    0    294 KBytes
[  4]  61.01-62.01  sec  5.40 MBytes  45.3 Mbits/sec    0    311 KBytes
[  4]  62.01-63.02  sec  5.06 MBytes  42.0 Mbits/sec    0    325 KBytes
[  4]  63.02-64.00  sec  5.65 MBytes  48.3 Mbits/sec    0    338 KBytes
[  4]  64.00-65.01  sec  5.70 MBytes  47.4 Mbits/sec    0    345 KBytes
[  4]  65.01-66.00  sec  5.45 MBytes  46.2 Mbits/sec    0    351 KBytes
[  4]  66.00-67.00  sec  5.05 MBytes  42.4 Mbits/sec    0    358 KBytes
[  4]  67.00-68.01  sec  5.71 MBytes  47.5 Mbits/sec    0    358 KBytes
[  4]  68.01-69.00  sec  5.24 MBytes  44.4 Mbits/sec    0    358 KBytes
[  4]  69.00-70.01  sec  5.74 MBytes  47.6 Mbits/sec    0    365 KBytes
[  4]  70.01-71.01  sec  5.36 MBytes  44.9 Mbits/sec    0    373 KBytes
[  4]  71.01-72.00  sec  5.09 MBytes  43.1 Mbits/sec    0    373 KBytes
[  4]  72.00-73.00  sec  5.30 MBytes  44.5 Mbits/sec    0    373 KBytes
[  4]  73.00-74.00  sec  5.82 MBytes  48.8 Mbits/sec    0    390 KBytes
[  4]  74.00-75.01  sec  5.93 MBytes  49.3 Mbits/sec    0    399 KBytes
[  4]  75.01-76.01  sec  4.52 MBytes  37.9 Mbits/sec    1    279 KBytes
[  4]  76.01-77.01  sec  4.62 MBytes  38.7 Mbits/sec    0    280 KBytes
[  4]  77.01-78.00  sec  5.74 MBytes  48.6 Mbits/sec    0    300 KBytes
[  4]  78.00-79.00  sec  5.41 MBytes  45.4 Mbits/sec    0    308 KBytes
[  4]  79.00-80.00  sec  4.70 MBytes  39.4 Mbits/sec    0    308 KBytes
[  4]  80.00-81.00  sec  4.62 MBytes  38.8 Mbits/sec    0    308 KBytes
[  4]  81.00-82.00  sec  5.11 MBytes  42.8 Mbits/sec    0    308 KBytes
[  4]  82.00-83.00  sec  5.17 MBytes  43.4 Mbits/sec    1    216 KBytes
[  4]  83.00-84.00  sec  5.29 MBytes  44.3 Mbits/sec    0    222 KBytes
[  4]  84.00-85.00  sec  4.92 MBytes  41.3 Mbits/sec    0    230 KBytes
[  4]  85.00-86.00  sec  5.39 MBytes  45.2 Mbits/sec    0    259 KBytes
[  4]  86.00-87.00  sec  5.30 MBytes  44.5 Mbits/sec    1    202 KBytes
[  4]  87.00-88.00  sec  5.87 MBytes  49.3 Mbits/sec    0    216 KBytes
[  4]  88.00-89.01  sec  5.44 MBytes  45.5 Mbits/sec    0    221 KBytes
[  4]  89.01-90.00  sec  5.42 MBytes  45.7 Mbits/sec    0    221 KBytes
[  4]  90.00-91.00  sec  5.80 MBytes  48.5 Mbits/sec    0    221 KBytes
[  4]  91.00-92.00  sec  5.72 MBytes  48.0 Mbits/sec    0    223 KBytes
[  4]  92.00-93.00  sec  5.32 MBytes  44.6 Mbits/sec    1    161 KBytes
[  4]  93.00-94.01  sec  5.49 MBytes  45.7 Mbits/sec    0    195 KBytes
[  4]  94.01-95.00  sec  5.23 MBytes  44.2 Mbits/sec    0    215 KBytes
[  4]  95.00-96.01  sec  5.63 MBytes  46.8 Mbits/sec    0    228 KBytes
[  4]  96.01-97.00  sec  4.91 MBytes  41.6 Mbits/sec    0    232 KBytes
[  4]  97.00-98.00  sec  5.69 MBytes  47.7 Mbits/sec    0    232 KBytes
[  4]  98.00-99.00  sec  5.66 MBytes  47.5 Mbits/sec    0    232 KBytes
[  4]  99.00-100.00 sec  5.46 MBytes  45.8 Mbits/sec    1    168 KBytes
[  4] 100.00-101.01 sec  5.29 MBytes  44.1 Mbits/sec    0    202 KBytes
[  4] 101.01-102.01 sec  4.52 MBytes  38.1 Mbits/sec    0    221 KBytes
[  4] 102.01-103.00 sec  5.61 MBytes  47.1 Mbits/sec    0    232 KBytes
[  4] 103.00-104.01 sec  5.34 MBytes  44.3 Mbits/sec    0    235 KBytes
[  4] 104.01-105.00 sec  5.41 MBytes  45.9 Mbits/sec    0    235 KBytes
[  4] 105.00-106.01 sec  6.04 MBytes  50.2 Mbits/sec    1    189 KBytes
[  4] 106.01-107.00 sec  5.44 MBytes  46.1 Mbits/sec    0    215 KBytes
[  4] 107.00-108.00 sec  5.64 MBytes  47.3 Mbits/sec    0    229 KBytes
[  4] 108.00-109.00 sec  5.36 MBytes  45.0 Mbits/sec    0    235 KBytes
[  4] 109.00-110.00 sec  4.84 MBytes  40.6 Mbits/sec    1    187 KBytes
[  4] 110.00-111.00 sec  5.75 MBytes  48.2 Mbits/sec    0    214 KBytes
[  4] 111.00-112.00 sec  5.35 MBytes  44.8 Mbits/sec    0    229 KBytes
[  4] 112.00-113.00 sec  5.09 MBytes  42.7 Mbits/sec    1    164 KBytes
[  4] 113.00-114.00 sec  4.99 MBytes  41.9 Mbits/sec    0    197 KBytes
[  4] 114.00-115.00 sec  5.39 MBytes  45.2 Mbits/sec    0    218 KBytes
[  4] 115.00-116.00 sec  6.00 MBytes  50.3 Mbits/sec    0    230 KBytes
[  4] 116.00-117.00 sec  5.32 MBytes  44.7 Mbits/sec    0    235 KBytes
[  4] 117.00-118.01 sec  5.48 MBytes  45.7 Mbits/sec    0    235 KBytes
[  4] 118.01-119.00 sec  4.45 MBytes  37.6 Mbits/sec    0    235 KBytes
[  4] 119.00-120.01 sec  5.75 MBytes  47.8 Mbits/sec    0    239 KBytes
[  4]   0.00-120.01 sec   633 MBytes  44.3 Mbits/sec   26             sender
[  4]   0.00-120.01 sec   633 MBytes  44.2 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.83.127 port 33583 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  6.87 MBytes  57.6 Mbits/sec
[  4]   1.00-2.00   sec  6.31 MBytes  52.9 Mbits/sec
[  4]   2.00-3.00   sec  6.68 MBytes  55.9 Mbits/sec
[  4]   3.00-4.00   sec  6.61 MBytes  55.4 Mbits/sec
[  4]   4.00-5.00   sec  6.58 MBytes  55.3 Mbits/sec
[  4]   5.00-6.00   sec  6.51 MBytes  54.6 Mbits/sec
[  4]   6.00-7.00   sec  7.58 MBytes  63.6 Mbits/sec
[  4]   7.00-8.00   sec  6.75 MBytes  56.7 Mbits/sec
[  4]   8.00-9.00   sec  6.58 MBytes  55.2 Mbits/sec
[  4]   9.00-10.00  sec  6.91 MBytes  57.8 Mbits/sec
[  4]  10.00-11.00  sec  6.90 MBytes  58.0 Mbits/sec
[  4]  11.00-12.00  sec  6.80 MBytes  57.0 Mbits/sec
[  4]  12.00-13.00  sec  6.60 MBytes  55.3 Mbits/sec
[  4]  13.00-14.01  sec  6.30 MBytes  52.6 Mbits/sec
[  4]  14.01-15.00  sec  6.75 MBytes  56.9 Mbits/sec
[  4]  15.00-16.00  sec  7.17 MBytes  60.2 Mbits/sec
[  4]  16.00-17.00  sec  6.64 MBytes  55.6 Mbits/sec
[  4]  17.00-18.00  sec  6.28 MBytes  52.7 Mbits/sec
[  4]  18.00-19.00  sec  6.29 MBytes  52.6 Mbits/sec
[  4]  19.00-20.00  sec  6.32 MBytes  53.1 Mbits/sec
[  4]  20.00-21.00  sec  7.35 MBytes  61.5 Mbits/sec
[  4]  21.00-22.00  sec  6.89 MBytes  57.9 Mbits/sec
[  4]  22.00-23.00  sec  7.03 MBytes  59.0 Mbits/sec
[  4]  23.00-24.00  sec  7.16 MBytes  60.0 Mbits/sec
[  4]  24.00-25.00  sec  6.81 MBytes  57.2 Mbits/sec
[  4]  25.00-26.00  sec  7.04 MBytes  58.9 Mbits/sec
[  4]  26.00-27.00  sec  6.95 MBytes  58.3 Mbits/sec
[  4]  27.00-28.00  sec  7.22 MBytes  60.6 Mbits/sec
[  4]  28.00-29.00  sec  7.04 MBytes  59.2 Mbits/sec
[  4]  29.00-30.00  sec  6.43 MBytes  53.9 Mbits/sec
[  4]  30.00-31.00  sec  6.74 MBytes  56.7 Mbits/sec
[  4]  31.00-32.00  sec  7.00 MBytes  58.8 Mbits/sec
[  4]  32.00-33.00  sec  6.40 MBytes  53.6 Mbits/sec
[  4]  33.00-34.00  sec  6.92 MBytes  58.2 Mbits/sec
[  4]  34.00-35.00  sec  7.66 MBytes  64.1 Mbits/sec
[  4]  35.00-36.00  sec  6.61 MBytes  55.6 Mbits/sec
[  4]  36.00-37.00  sec  7.27 MBytes  61.0 Mbits/sec
[  4]  37.00-38.00  sec  7.07 MBytes  59.2 Mbits/sec
[  4]  38.00-39.00  sec  7.27 MBytes  61.0 Mbits/sec
[  4]  39.00-40.00  sec  7.06 MBytes  59.2 Mbits/sec
[  4]  40.00-41.00  sec  7.15 MBytes  60.0 Mbits/sec
[  4]  41.00-42.00  sec  7.00 MBytes  58.8 Mbits/sec
[  4]  42.00-43.01  sec  7.62 MBytes  63.5 Mbits/sec
[  4]  43.01-44.00  sec  7.37 MBytes  62.2 Mbits/sec
[  4]  44.00-45.00  sec  6.86 MBytes  57.5 Mbits/sec
[  4]  45.00-46.00  sec  6.87 MBytes  57.7 Mbits/sec
[  4]  46.00-47.00  sec  7.16 MBytes  60.0 Mbits/sec
[  4]  47.00-48.00  sec  7.64 MBytes  64.2 Mbits/sec
[  4]  48.00-49.00  sec  7.19 MBytes  60.3 Mbits/sec
[  4]  49.00-50.00  sec  6.67 MBytes  55.9 Mbits/sec
[  4]  50.00-51.01  sec  6.27 MBytes  52.2 Mbits/sec
[  4]  51.01-52.00  sec  4.16 MBytes  35.1 Mbits/sec
[  4]  52.00-53.00  sec  7.24 MBytes  60.6 Mbits/sec
[  4]  53.00-54.00  sec  5.04 MBytes  42.3 Mbits/sec
[  4]  54.00-55.00  sec  5.94 MBytes  49.9 Mbits/sec
[  4]  55.00-56.00  sec  4.66 MBytes  39.1 Mbits/sec
[  4]  56.00-57.00  sec  3.45 MBytes  28.9 Mbits/sec
[  4]  57.00-58.00  sec  3.73 MBytes  31.4 Mbits/sec
[  4]  58.00-59.00  sec  6.45 MBytes  54.1 Mbits/sec
[  4]  59.00-60.00  sec  7.04 MBytes  58.9 Mbits/sec
[  4]  60.00-61.00  sec  7.52 MBytes  63.1 Mbits/sec
[  4]  61.00-62.00  sec  7.31 MBytes  61.3 Mbits/sec
[  4]  62.00-63.01  sec  6.65 MBytes  55.5 Mbits/sec
[  4]  63.01-64.01  sec  7.25 MBytes  60.8 Mbits/sec
[  4]  64.01-65.00  sec  6.96 MBytes  58.8 Mbits/sec
[  4]  65.00-66.00  sec  7.65 MBytes  64.3 Mbits/sec
[  4]  66.00-67.00  sec  6.72 MBytes  56.1 Mbits/sec
[  4]  67.00-68.00  sec  5.25 MBytes  44.2 Mbits/sec
[  4]  68.00-69.00  sec  7.00 MBytes  58.7 Mbits/sec
[  4]  69.00-70.00  sec  6.92 MBytes  58.1 Mbits/sec
[  4]  70.00-71.00  sec  7.18 MBytes  60.3 Mbits/sec
[  4]  71.00-72.00  sec  6.73 MBytes  56.3 Mbits/sec
[  4]  72.00-73.00  sec  6.24 MBytes  52.5 Mbits/sec
[  4]  73.00-74.00  sec  7.01 MBytes  58.8 Mbits/sec
[  4]  74.00-75.00  sec  6.89 MBytes  57.9 Mbits/sec
[  4]  75.00-76.00  sec  7.39 MBytes  62.0 Mbits/sec
[  4]  76.00-77.00  sec  7.24 MBytes  60.7 Mbits/sec
[  4]  77.00-78.00  sec  6.95 MBytes  58.3 Mbits/sec
[  4]  78.00-79.01  sec  6.89 MBytes  57.6 Mbits/sec
[  4]  79.01-80.00  sec  6.43 MBytes  54.2 Mbits/sec
[  4]  80.00-81.00  sec  6.82 MBytes  57.2 Mbits/sec
[  4]  81.00-82.00  sec  6.97 MBytes  58.5 Mbits/sec
[  4]  82.00-83.00  sec  5.94 MBytes  49.8 Mbits/sec
[  4]  83.00-84.00  sec  5.13 MBytes  43.0 Mbits/sec
[  4]  84.00-85.00  sec  6.18 MBytes  51.8 Mbits/sec
[  4]  85.00-86.01  sec  7.56 MBytes  62.7 Mbits/sec
[  4]  86.01-87.00  sec  7.59 MBytes  64.4 Mbits/sec
[  4]  87.00-88.00  sec  7.31 MBytes  61.3 Mbits/sec
[  4]  88.00-89.00  sec  7.12 MBytes  59.8 Mbits/sec
[  4]  89.00-90.01  sec  7.15 MBytes  59.6 Mbits/sec
[  4]  90.01-91.00  sec  7.35 MBytes  61.9 Mbits/sec
[  4]  91.00-92.00  sec  7.53 MBytes  63.2 Mbits/sec
[  4]  92.00-93.00  sec  7.22 MBytes  60.6 Mbits/sec
[  4]  93.00-94.00  sec  7.80 MBytes  65.5 Mbits/sec
[  4]  94.00-95.00  sec  7.35 MBytes  61.7 Mbits/sec
[  4]  95.00-96.00  sec  7.34 MBytes  61.4 Mbits/sec
[  4]  96.00-97.00  sec  7.12 MBytes  59.8 Mbits/sec
[  4]  97.00-98.00  sec  7.06 MBytes  59.3 Mbits/sec
[  4]  98.00-99.00  sec  7.01 MBytes  58.7 Mbits/sec
[  4]  99.00-100.00 sec  6.91 MBytes  58.0 Mbits/sec
[  4] 100.00-101.00 sec  7.32 MBytes  61.5 Mbits/sec
[  4] 101.00-102.00 sec  7.13 MBytes  59.8 Mbits/sec
[  4] 102.00-103.01 sec  7.20 MBytes  60.1 Mbits/sec
[  4] 103.01-104.00 sec  7.21 MBytes  60.8 Mbits/sec
[  4] 104.00-105.00 sec  6.87 MBytes  57.6 Mbits/sec
[  4] 105.00-106.00 sec  7.22 MBytes  60.5 Mbits/sec
[  4] 106.00-107.00 sec  7.45 MBytes  62.3 Mbits/sec
[  4] 107.00-108.00 sec  6.98 MBytes  58.7 Mbits/sec
[  4] 108.00-109.00 sec  7.14 MBytes  60.0 Mbits/sec
[  4] 109.00-110.00 sec  6.99 MBytes  58.7 Mbits/sec
[  4] 110.00-111.00 sec  7.36 MBytes  61.6 Mbits/sec
[  4] 111.00-112.00 sec  6.91 MBytes  57.9 Mbits/sec
[  4] 112.00-113.00 sec  7.29 MBytes  61.3 Mbits/sec
[  4] 113.00-114.00 sec  7.10 MBytes  59.4 Mbits/sec
[  4] 114.00-115.00 sec  7.33 MBytes  61.6 Mbits/sec
[  4] 115.00-116.00 sec  6.93 MBytes  58.1 Mbits/sec
[  4] 116.00-117.01 sec  6.80 MBytes  56.3 Mbits/sec
[  4] 117.01-118.00 sec  6.80 MBytes  57.7 Mbits/sec
[  4] 118.00-119.00 sec  7.39 MBytes  62.1 Mbits/sec
[  4] 119.00-120.00 sec  7.11 MBytes  59.7 Mbits/sec
[  4]   0.00-120.00 sec   823 MBytes  57.5 Mbits/sec  163             sender
[  4]   0.00-120.00 sec   820 MBytes  57.4 Mbits/sec                  receiver
iperf Done.
wlan0     IEEE 802.11bgn  ESSID:"Snort-Honeynet"  Nickname:"<WIFI@REALTEK>"
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Link Quality=100/100  Signal level=-62 dBm  Noise level=0 dBm
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
   CubaLibre                Infra  11    44 Mbit/s  50      ▂▄__  WPA2
   CubaLibre                Infra  11    44 Mbit/s  45      ▂▄__  WPA1 WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     44 Mbit/s  44      ▂▄__  WPA1 WPA2
   OSAs Gästenetzwerk       Infra  6     16 Mbit/s  40      ▂▄__  WPA1 WPA2
   OSA Alpenraum intern     Infra  6     16 Mbit/s  40      ▂▄__  WPA1 WPA2
   EasyBox-116D28           Infra  5     16 Mbit/s  35      ▂▄__  WPA1 WPA2
   WLAN-872870              Infra  11    16 Mbit/s  30      ▂___  WPA2
   almtrieb                 Infra  1     44 Mbit/s  29      ▂___  WPA1 WPA2
   WLAN-A64344              Infra  1     16 Mbit/s  29      ▂___  WPA2
   o2-WLAN91                Infra  5     44 Mbit/s  29      ▂___  WPA2
   DISTORTEDPEOPLE          Infra  9     44 Mbit/s  17      ▂___  WPA1 WPA2
   FRITZ!Box 7362 SL        Infra  1     16 Mbit/s  15      ▂___  WPA2
   --                       Infra  6     16 Mbit/s  15      ▂___  WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     16 Mbit/s  15      ▂___  WPA1 WPA2
   o2-WLAN09                Infra  8     44 Mbit/s  9       ▂___  WPA2
   FRITZ!Box WLAN 3270      Infra  9     44 Mbit/s  9       ▂___  WPA1 WPA2
Location 2: 5 meters away, 2 walls in between, different direction compared to prior location.
Orange Pi Lite: 23,5 Mbits/sec on average:
root@orangepilite:~# iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120
[  4] local 192.168.83.98 port 35675 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  1.29 MBytes  10.9 Mbits/sec    0   97.6 KBytes
[  4]   1.00-2.00   sec  2.32 MBytes  19.4 Mbits/sec    0    205 KBytes
[  4]   2.00-3.00   sec  3.10 MBytes  26.0 Mbits/sec    0    345 KBytes
[  4]   3.00-4.00   sec  3.14 MBytes  26.4 Mbits/sec    0    479 KBytes
[  4]   4.00-5.00   sec  3.48 MBytes  29.2 Mbits/sec    0    634 KBytes
[  4]   5.00-6.00   sec  2.84 MBytes  23.9 Mbits/sec    0    775 KBytes
[  4]   6.00-7.00   sec  3.24 MBytes  27.2 Mbits/sec    0    915 KBytes
[  4]   7.00-8.00   sec  2.46 MBytes  20.7 Mbits/sec    0   1.01 MBytes
[  4]   8.00-9.00   sec  2.66 MBytes  22.3 Mbits/sec    0   1.14 MBytes
[  4]   9.00-10.00  sec  2.65 MBytes  22.2 Mbits/sec    1   1.12 MBytes
[  4]  10.00-11.00  sec  3.18 MBytes  26.7 Mbits/sec    0    942 KBytes
[  4]  11.00-12.00  sec  2.65 MBytes  22.3 Mbits/sec    0   1.02 MBytes
[  4]  12.00-13.00  sec  2.65 MBytes  22.3 Mbits/sec    0   1.09 MBytes
[  4]  13.00-14.00  sec  3.26 MBytes  27.4 Mbits/sec    0   1.15 MBytes
[  4]  14.00-15.00  sec  3.24 MBytes  27.2 Mbits/sec    0   1.19 MBytes
[  4]  15.00-16.00  sec  3.33 MBytes  27.9 Mbits/sec    0   1.22 MBytes
[  4]  16.00-17.00  sec  2.62 MBytes  21.9 Mbits/sec    0   1.23 MBytes
[  4]  17.00-18.00  sec  3.33 MBytes  28.0 Mbits/sec    0   1.24 MBytes
[  4]  18.00-19.00  sec  2.92 MBytes  24.5 Mbits/sec    0   1.24 MBytes
[  4]  19.00-20.00  sec  3.37 MBytes  28.3 Mbits/sec    0   1.24 MBytes
[  4]  20.00-21.00  sec  3.42 MBytes  28.7 Mbits/sec    0   1.24 MBytes
[  4]  21.00-22.00  sec  3.87 MBytes  32.5 Mbits/sec    0   1.25 MBytes
[  4]  22.00-23.00  sec  3.31 MBytes  27.8 Mbits/sec    0   1.27 MBytes
[  4]  23.00-24.00  sec  3.44 MBytes  28.8 Mbits/sec    0   1.30 MBytes
[  4]  24.00-25.00  sec  3.35 MBytes  28.1 Mbits/sec    0   1.34 MBytes
[  4]  25.00-26.00  sec  3.36 MBytes  28.2 Mbits/sec    0   1.39 MBytes
[  4]  26.00-27.00  sec  3.41 MBytes  28.6 Mbits/sec    0   1.48 MBytes
[  4]  27.00-28.00  sec  2.53 MBytes  21.2 Mbits/sec    0   1.58 MBytes
[  4]  28.00-29.00  sec  3.57 MBytes  30.0 Mbits/sec    0   1.72 MBytes
[  4]  29.00-30.00  sec  3.58 MBytes  30.1 Mbits/sec    0   1.86 MBytes
[  4]  30.00-31.00  sec  2.77 MBytes  23.2 Mbits/sec    0   1021 KBytes
[  4]  31.00-32.00  sec  2.75 MBytes  23.0 Mbits/sec    0   1.32 MBytes
[  4]  32.00-33.00  sec  3.73 MBytes  31.3 Mbits/sec    0   1.45 MBytes
[  4]  33.00-34.00  sec  2.65 MBytes  22.3 Mbits/sec    0   1.58 MBytes
[  4]  34.00-35.00  sec  3.79 MBytes  31.8 Mbits/sec    0   1.69 MBytes
[  4]  35.00-36.00  sec  3.52 MBytes  29.5 Mbits/sec    0   1.77 MBytes
[  4]  36.00-37.00  sec  2.74 MBytes  23.0 Mbits/sec    0   1.83 MBytes
[  4]  37.00-38.00  sec  3.56 MBytes  29.9 Mbits/sec    0   1.87 MBytes
[  4]  38.00-39.00  sec  2.70 MBytes  22.6 Mbits/sec    1   1.74 MBytes
[  4]  39.00-40.00  sec  4.33 MBytes  36.3 Mbits/sec    0   1.29 MBytes
[  4]  40.00-41.00  sec  1.76 MBytes  14.8 Mbits/sec    0   1.36 MBytes
[  4]  41.00-42.00  sec  3.51 MBytes  29.5 Mbits/sec    0   1.43 MBytes
[  4]  42.00-43.00  sec  3.57 MBytes  30.0 Mbits/sec    0   1.47 MBytes
[  4]  43.00-44.00  sec  3.66 MBytes  30.7 Mbits/sec    0   1.51 MBytes
[  4]  44.00-45.00  sec  3.64 MBytes  30.5 Mbits/sec    0   1.52 MBytes
[  4]  45.00-46.00  sec  3.58 MBytes  30.1 Mbits/sec    0   1.53 MBytes
[  4]  46.00-47.00  sec  3.61 MBytes  30.2 Mbits/sec    0   1.53 MBytes
[  4]  47.00-48.00  sec  2.74 MBytes  23.1 Mbits/sec    0   1.53 MBytes
[  4]  48.00-49.00  sec  3.74 MBytes  31.3 Mbits/sec    0   1.53 MBytes
[  4]  49.00-50.00  sec  3.00 MBytes  25.2 Mbits/sec    1   1.12 MBytes
[  4]  50.00-51.00  sec  3.58 MBytes  30.0 Mbits/sec    0   1.23 MBytes
[  4]  51.00-52.00  sec  3.68 MBytes  30.9 Mbits/sec    0   1.33 MBytes
[  4]  52.00-53.00  sec  2.86 MBytes  24.0 Mbits/sec    0   1.40 MBytes
[  4]  53.00-54.00  sec  3.58 MBytes  30.1 Mbits/sec    0   1.46 MBytes
[  4]  54.00-55.00  sec  2.79 MBytes  23.4 Mbits/sec    0   1.49 MBytes
[  4]  55.00-56.00  sec  3.75 MBytes  31.5 Mbits/sec    0   1.52 MBytes
[  4]  56.00-57.00  sec  3.56 MBytes  29.9 Mbits/sec    0   1.53 MBytes
[  4]  57.00-58.00  sec  2.72 MBytes  22.8 Mbits/sec    0   1.53 MBytes
[  4]  58.00-59.00  sec  3.60 MBytes  30.2 Mbits/sec    0   1.53 MBytes
[  4]  59.00-60.00  sec  3.54 MBytes  29.7 Mbits/sec    0   1.53 MBytes
[  4]  60.00-61.00  sec  2.71 MBytes  22.7 Mbits/sec    0   1.54 MBytes
[  4]  61.00-62.00  sec  3.57 MBytes  29.9 Mbits/sec    0   1.55 MBytes
[  4]  62.00-63.00  sec  3.62 MBytes  30.3 Mbits/sec    0   1.56 MBytes
[  4]  63.00-64.00  sec  2.66 MBytes  22.3 Mbits/sec    0   1.59 MBytes
[  4]  64.00-65.00  sec  3.55 MBytes  29.8 Mbits/sec    0   1.64 MBytes
[  4]  65.00-66.00  sec  3.64 MBytes  30.6 Mbits/sec    0   1.70 MBytes
[  4]  66.00-67.00  sec  3.53 MBytes  29.6 Mbits/sec    0   1.79 MBytes
[  4]  67.00-68.00  sec  2.65 MBytes  22.2 Mbits/sec    0   1.89 MBytes
[  4]  68.00-69.00  sec  3.49 MBytes  29.3 Mbits/sec    0    772 KBytes
[  4]  69.00-70.00  sec  3.62 MBytes  30.4 Mbits/sec    0   1.36 MBytes
[  4]  70.00-71.00  sec  3.61 MBytes  30.3 Mbits/sec    0   1.47 MBytes
[  4]  71.00-72.00  sec  2.64 MBytes  22.2 Mbits/sec    0   1.60 MBytes
[  4]  72.00-73.00  sec  3.80 MBytes  31.9 Mbits/sec    0   1.70 MBytes
[  4]  73.00-74.00  sec  2.64 MBytes  22.2 Mbits/sec    0   1.78 MBytes
[  4]  74.00-75.00  sec  3.50 MBytes  29.3 Mbits/sec    0   1.84 MBytes
[  4]  75.00-76.00  sec  3.73 MBytes  31.3 Mbits/sec    0   1.88 MBytes
[  4]  76.00-77.00  sec  2.72 MBytes  22.8 Mbits/sec    0   1.91 MBytes
[  4]  77.00-78.00  sec  3.57 MBytes  29.9 Mbits/sec    0   1.93 MBytes
[  4]  78.00-79.00  sec  3.59 MBytes  30.1 Mbits/sec    0    624 KBytes
[  4]  79.00-80.00  sec  2.58 MBytes  21.7 Mbits/sec    0   1.36 MBytes
[  4]  80.00-81.00  sec  3.77 MBytes  31.6 Mbits/sec    0   1.43 MBytes
[  4]  81.00-82.00  sec  3.09 MBytes  26.0 Mbits/sec    1   1.03 MBytes
[  4]  82.00-83.00  sec  3.63 MBytes  30.4 Mbits/sec    0   1.10 MBytes
[  4]  83.00-84.00  sec  3.52 MBytes  29.5 Mbits/sec    0   1.15 MBytes
[  4]  84.00-85.00  sec  2.70 MBytes  22.6 Mbits/sec    0   1.19 MBytes
[  4]  85.00-86.00  sec  3.61 MBytes  30.2 Mbits/sec    0   1.22 MBytes
[  4]  86.00-87.00  sec  3.94 MBytes  33.1 Mbits/sec    1    889 KBytes
[  4]  87.00-88.00  sec  2.86 MBytes  24.0 Mbits/sec    0    950 KBytes
[  4]  88.00-89.00  sec  3.58 MBytes  30.1 Mbits/sec    0   1000 KBytes
[  4]  89.00-90.00  sec  2.71 MBytes  22.7 Mbits/sec    0   1.01 MBytes
[  4]  90.00-91.00  sec  3.56 MBytes  29.9 Mbits/sec    0   1.03 MBytes
[  4]  91.00-92.00  sec  3.58 MBytes  30.0 Mbits/sec    0   1.04 MBytes
[  4]  92.00-93.00  sec  2.63 MBytes  22.0 Mbits/sec    0   1.04 MBytes
[  4]  93.00-94.00  sec  3.77 MBytes  31.6 Mbits/sec    0   1.04 MBytes
[  4]  94.00-95.00  sec  3.53 MBytes  29.6 Mbits/sec    0   1.04 MBytes
[  4]  95.00-96.00  sec  3.46 MBytes  29.0 Mbits/sec    0   1.05 MBytes
[  4]  96.00-97.00  sec  3.70 MBytes  31.0 Mbits/sec    0   1.06 MBytes
[  4]  97.00-98.00  sec  2.73 MBytes  22.9 Mbits/sec    0   1.08 MBytes
[  4]  98.00-99.00  sec  3.52 MBytes  29.6 Mbits/sec    0   1.11 MBytes
[  4]  99.00-100.00 sec  3.47 MBytes  29.1 Mbits/sec    0   1.17 MBytes
[  4] 100.00-101.00 sec  2.63 MBytes  22.1 Mbits/sec    0   1.23 MBytes
[  4] 101.00-102.00 sec  4.42 MBytes  37.1 Mbits/sec    0   1.33 MBytes
[  4] 102.00-103.00 sec  2.77 MBytes  23.3 Mbits/sec    0   1.45 MBytes
[  4] 103.00-104.00 sec  3.63 MBytes  30.5 Mbits/sec    0   1.59 MBytes
[  4] 104.00-105.00 sec  1.90 MBytes  15.9 Mbits/sec    1   1.18 MBytes
[  4] 105.00-106.00 sec  4.95 MBytes  41.5 Mbits/sec    0   1.27 MBytes
[  4] 106.00-107.00 sec  3.54 MBytes  29.7 Mbits/sec    0   1.39 MBytes
[  4] 107.00-108.00 sec  3.61 MBytes  30.2 Mbits/sec    0   1.48 MBytes
[  4] 108.00-109.00 sec  3.55 MBytes  29.8 Mbits/sec    0   1.55 MBytes
[  4] 109.00-110.00 sec  3.01 MBytes  25.3 Mbits/sec    1   1.10 MBytes
[  4] 110.00-111.00 sec  2.60 MBytes  21.8 Mbits/sec    0   1.17 MBytes
[  4] 111.00-112.00 sec  3.60 MBytes  30.2 Mbits/sec    0   1.23 MBytes
[  4] 112.00-113.00 sec  3.59 MBytes  30.1 Mbits/sec    0   1.28 MBytes
[  4] 113.00-114.00 sec  3.53 MBytes  29.6 Mbits/sec    0   1.31 MBytes
[  4] 114.00-115.00 sec  3.57 MBytes  29.9 Mbits/sec    0   1.33 MBytes
[  4] 115.00-116.00 sec  3.53 MBytes  29.6 Mbits/sec    0   1.34 MBytes
[  4] 116.00-117.00 sec  3.50 MBytes  29.3 Mbits/sec    0   1.34 MBytes
[  4] 117.00-118.00 sec  3.51 MBytes  29.4 Mbits/sec    0   1.34 MBytes
[  4] 118.00-119.00 sec  2.64 MBytes  22.2 Mbits/sec    0   1.34 MBytes
[  4] 119.00-120.00 sec  3.84 MBytes  32.2 Mbits/sec    1    977 KBytes
[  4]   0.00-120.00 sec   391 MBytes  27.4 Mbits/sec    8             sender
[  4]   0.00-120.00 sec   390 MBytes  27.3 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.83.98 port 35677 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  2.03 MBytes  17.0 Mbits/sec
[  4]   1.00-2.00   sec  1.97 MBytes  16.5 Mbits/sec
[  4]   2.00-3.00   sec  2.00 MBytes  16.8 Mbits/sec
[  4]   3.00-4.00   sec  2.32 MBytes  19.5 Mbits/sec
[  4]   4.00-5.00   sec  2.29 MBytes  19.2 Mbits/sec
[  4]   5.00-6.00   sec  1.93 MBytes  16.2 Mbits/sec
[  4]   6.00-7.00   sec  2.23 MBytes  18.7 Mbits/sec
[  4]   7.00-8.00   sec  2.06 MBytes  17.2 Mbits/sec
[  4]   8.00-9.00   sec  2.44 MBytes  20.5 Mbits/sec
[  4]   9.00-10.00  sec  2.02 MBytes  17.0 Mbits/sec
[  4]  10.00-11.00  sec  2.56 MBytes  21.5 Mbits/sec
[  4]  11.00-12.00  sec  2.70 MBytes  22.6 Mbits/sec
[  4]  12.00-13.00  sec  2.23 MBytes  18.7 Mbits/sec
[  4]  13.00-14.00  sec  2.39 MBytes  20.1 Mbits/sec
[  4]  14.00-15.00  sec  2.50 MBytes  20.9 Mbits/sec
[  4]  15.00-16.00  sec  2.30 MBytes  19.3 Mbits/sec
[  4]  16.00-17.00  sec  2.60 MBytes  21.8 Mbits/sec
[  4]  17.00-18.00  sec  2.58 MBytes  21.6 Mbits/sec
[  4]  18.00-19.00  sec  2.48 MBytes  20.8 Mbits/sec
[  4]  19.00-20.00  sec  2.42 MBytes  20.3 Mbits/sec
[  4]  20.00-21.00  sec  2.62 MBytes  22.0 Mbits/sec
[  4]  21.00-22.00  sec  1.83 MBytes  15.3 Mbits/sec
[  4]  22.00-23.00  sec  1.70 MBytes  14.3 Mbits/sec
[  4]  23.00-24.00  sec  2.57 MBytes  21.6 Mbits/sec
[  4]  24.00-25.00  sec  2.42 MBytes  20.3 Mbits/sec
[  4]  25.00-26.00  sec  2.32 MBytes  19.4 Mbits/sec
[  4]  26.00-27.00  sec  2.42 MBytes  20.3 Mbits/sec
[  4]  27.00-28.00  sec  2.33 MBytes  19.5 Mbits/sec
[  4]  28.00-29.00  sec  1.59 MBytes  13.3 Mbits/sec
[  4]  29.00-30.00  sec   718 KBytes  5.88 Mbits/sec
[  4]  30.00-31.00  sec  2.52 MBytes  21.2 Mbits/sec
[  4]  31.00-32.00  sec  2.26 MBytes  19.0 Mbits/sec
[  4]  32.00-33.00  sec  2.34 MBytes  19.6 Mbits/sec
[  4]  33.00-34.00  sec  2.54 MBytes  21.3 Mbits/sec
[  4]  34.00-35.00  sec  2.45 MBytes  20.5 Mbits/sec
[  4]  35.00-36.00  sec  2.48 MBytes  20.8 Mbits/sec
[  4]  36.00-37.00  sec  2.73 MBytes  22.9 Mbits/sec
[  4]  37.00-38.00  sec  2.30 MBytes  19.3 Mbits/sec
[  4]  38.00-39.00  sec  2.35 MBytes  19.7 Mbits/sec
[  4]  39.00-40.00  sec  2.32 MBytes  19.5 Mbits/sec
[  4]  40.00-41.00  sec  2.52 MBytes  21.1 Mbits/sec
[  4]  41.00-42.00  sec  2.57 MBytes  21.5 Mbits/sec
[  4]  42.00-43.00  sec  2.63 MBytes  22.0 Mbits/sec
[  4]  43.00-44.00  sec  2.43 MBytes  20.4 Mbits/sec
[  4]  44.00-45.00  sec  2.32 MBytes  19.5 Mbits/sec
[  4]  45.00-46.00  sec  2.42 MBytes  20.3 Mbits/sec
[  4]  46.00-47.00  sec  1.94 MBytes  16.2 Mbits/sec
[  4]  47.00-48.00  sec  2.45 MBytes  20.5 Mbits/sec
[  4]  48.00-49.00  sec  2.76 MBytes  23.2 Mbits/sec
[  4]  49.00-50.00  sec  2.42 MBytes  20.3 Mbits/sec
[  4]  50.00-51.00  sec  2.15 MBytes  18.1 Mbits/sec
[  4]  51.00-52.00  sec  2.34 MBytes  19.6 Mbits/sec
[  4]  52.00-53.00  sec  2.27 MBytes  19.0 Mbits/sec
[  4]  53.00-54.00  sec  2.26 MBytes  18.9 Mbits/sec
[  4]  54.00-55.00  sec  2.36 MBytes  19.8 Mbits/sec
[  4]  55.00-56.00  sec  2.57 MBytes  21.5 Mbits/sec
[  4]  56.00-57.00  sec  2.50 MBytes  21.0 Mbits/sec
[  4]  57.00-58.00  sec  2.64 MBytes  22.1 Mbits/sec
[  4]  58.00-59.00  sec  2.40 MBytes  20.1 Mbits/sec
[  4]  59.00-60.00  sec  2.35 MBytes  19.8 Mbits/sec
[  4]  60.00-61.00  sec  2.36 MBytes  19.8 Mbits/sec
[  4]  61.00-62.00  sec  2.46 MBytes  20.6 Mbits/sec
[  4]  62.00-63.00  sec  2.49 MBytes  20.9 Mbits/sec
[  4]  63.00-64.00  sec  2.25 MBytes  18.9 Mbits/sec
[  4]  64.00-65.00  sec  2.44 MBytes  20.4 Mbits/sec
[  4]  65.00-66.00  sec  2.42 MBytes  20.3 Mbits/sec
[  4]  66.00-67.00  sec  2.33 MBytes  19.5 Mbits/sec
[  4]  67.00-68.00  sec  2.51 MBytes  21.1 Mbits/sec
[  4]  68.00-69.00  sec  2.39 MBytes  20.1 Mbits/sec
[  4]  69.00-70.00  sec  2.43 MBytes  20.4 Mbits/sec
[  4]  70.00-71.00  sec  2.62 MBytes  22.0 Mbits/sec
[  4]  71.00-72.00  sec  2.51 MBytes  21.0 Mbits/sec
[  4]  72.00-73.00  sec  2.34 MBytes  19.6 Mbits/sec
[  4]  73.00-74.00  sec  2.30 MBytes  19.3 Mbits/sec
[  4]  74.00-75.00  sec  2.21 MBytes  18.5 Mbits/sec
[  4]  75.00-76.00  sec  2.44 MBytes  20.5 Mbits/sec
[  4]  76.00-77.00  sec  2.33 MBytes  19.5 Mbits/sec
[  4]  77.00-78.00  sec  2.59 MBytes  21.7 Mbits/sec
[  4]  78.00-79.00  sec  2.61 MBytes  21.9 Mbits/sec
[  4]  79.00-80.00  sec  2.46 MBytes  20.7 Mbits/sec
[  4]  80.00-81.00  sec  2.54 MBytes  21.3 Mbits/sec
[  4]  81.00-82.00  sec  2.45 MBytes  20.6 Mbits/sec
[  4]  82.00-83.00  sec  2.50 MBytes  21.0 Mbits/sec
[  4]  83.00-84.00  sec  2.43 MBytes  20.4 Mbits/sec
[  4]  84.00-85.00  sec  2.66 MBytes  22.3 Mbits/sec
[  4]  85.00-86.00  sec  2.45 MBytes  20.5 Mbits/sec
[  4]  86.00-87.00  sec  2.53 MBytes  21.2 Mbits/sec
[  4]  87.00-88.00  sec  2.61 MBytes  21.9 Mbits/sec
[  4]  88.00-89.00  sec  2.41 MBytes  20.2 Mbits/sec
[  4]  89.00-90.00  sec  2.26 MBytes  19.0 Mbits/sec
[  4]  90.00-91.00  sec  2.32 MBytes  19.5 Mbits/sec
[  4]  91.00-92.00  sec  2.57 MBytes  21.6 Mbits/sec
[  4]  92.00-93.00  sec  2.56 MBytes  21.5 Mbits/sec
[  4]  93.00-94.00  sec  2.28 MBytes  19.1 Mbits/sec
[  4]  94.00-95.00  sec  2.16 MBytes  18.1 Mbits/sec
[  4]  95.00-96.00  sec  2.54 MBytes  21.3 Mbits/sec
[  4]  96.00-97.00  sec  2.42 MBytes  20.3 Mbits/sec
[  4]  97.00-98.00  sec  2.19 MBytes  18.4 Mbits/sec
[  4]  98.00-99.00  sec  1.25 MBytes  10.5 Mbits/sec
[  4]  99.00-100.00 sec  2.60 MBytes  21.8 Mbits/sec
[  4] 100.00-101.00 sec  2.38 MBytes  19.9 Mbits/sec
[  4] 101.00-102.00 sec  2.33 MBytes  19.5 Mbits/sec
[  4] 102.00-103.00 sec  2.19 MBytes  18.4 Mbits/sec
[  4] 103.00-104.00 sec  2.29 MBytes  19.2 Mbits/sec
[  4] 104.00-105.00 sec  2.40 MBytes  20.2 Mbits/sec
[  4] 105.00-106.00 sec  2.41 MBytes  20.2 Mbits/sec
[  4] 106.00-107.00 sec  2.35 MBytes  19.7 Mbits/sec
[  4] 107.00-108.00 sec  2.44 MBytes  20.5 Mbits/sec
[  4] 108.00-109.00 sec  2.52 MBytes  21.1 Mbits/sec
[  4] 109.00-110.00 sec  2.36 MBytes  19.8 Mbits/sec
[  4] 110.00-111.00 sec  2.06 MBytes  17.3 Mbits/sec
[  4] 111.00-112.00 sec  2.67 MBytes  22.4 Mbits/sec
[  4] 112.00-113.00 sec  1.81 MBytes  15.2 Mbits/sec
[  4] 113.00-114.00 sec  1.65 MBytes  13.8 Mbits/sec
[  4] 114.00-115.00 sec  1.74 MBytes  14.6 Mbits/sec
[  4] 115.00-116.00 sec  2.00 MBytes  16.7 Mbits/sec
[  4] 116.00-117.00 sec  2.13 MBytes  17.9 Mbits/sec
[  4] 117.00-118.00 sec  2.06 MBytes  17.3 Mbits/sec
[  4] 118.00-119.00 sec  2.03 MBytes  17.1 Mbits/sec
[  4] 119.00-120.00 sec  2.12 MBytes  17.8 Mbits/sec
[  4]   0.00-120.00 sec   282 MBytes  19.7 Mbits/sec  139             sender
[  4]   0.00-120.00 sec   280 MBytes  19.6 Mbits/sec                  receiver
iperf Done.
root@orangepilite:~# iwconfig wlan0
          Bit Rate:65 Mb/s   Sensitivity:0/0
          Link Quality=60/100  Signal level=69/100  Noise level=0/100
root@orangepilite:~# nmcli dev wifi list
   EasyBox-116D28           Infra  5     54 Mbit/s  64      ▂▄▆_  WPA1 WPA2
*  Snort-Honeynet           Infra  13    54 Mbit/s  53      ▂▄__  WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  52      ▂▄__  WPA1 WPA2
   EasyBox-188632           Infra  10    54 Mbit/s  50      ▂▄__  WPA1 WPA2
   WLAN-341381              Infra  11    54 Mbit/s  49      ▂▄__  WPA2
   Wonder Woman             Infra  1     54 Mbit/s  47      ▂▄__  WPA1 WPA2
   FRITZ!Box 7490           Infra  11    54 Mbit/s  47      ▂▄__  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  45      ▂▄__  WPA1 WPA2
   OSAs Gästenetzwerk       Infra  6     54 Mbit/s  45      ▂▄__  WPA1 WPA2
   --                       Infra  1     54 Mbit/s  44      ▂▄__
   UBNT2                    Infra  3     54 Mbit/s  44      ▂▄__
   iPhone                   Infra  11    54 Mbit/s  44      ▂▄__  WPA2
   WLAN-3C3379              Infra  11    54 Mbit/s  44      ▂▄__  WPA2
   FRITZ!Box 7490           Infra  1     54 Mbit/s  40      ▂▄__  WPA2
   Horst                    Infra  7     54 Mbit/s  40      ▂▄__  WPA1 WPA2
   Bonnie&Clyde             Infra  11    54 Mbit/s  40      ▂▄__  WPA2
   CubaLibre                Infra  11    54 Mbit/s  40      ▂▄__  WPA2
   11-Dominik               Infra  1     54 Mbit/s  37      ▂▄__  WPA1 WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  37      ▂▄__  WPA1 WPA2
   EasyBox-257398           Infra  11    54 Mbit/s  37      ▂▄__  WPA1 WPA2
   Eichkatzenkind           Infra  5     54 Mbit/s  34      ▂▄__  WPA2
   Eichkatze                Infra  11    54 Mbit/s  34      ▂▄__  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  30      ▂___  WPA1 WPA2
   Vodafone Homespot        Infra  1     54 Mbit/s  30      ▂___
   Wireless1                Infra  5     54 Mbit/s  30      ▂___  WPA1 WPA2
   Fallibilismus            Infra  7     54 Mbit/s  30      ▂___  WPA1 WPA2
   David                    Infra  11    54 Mbit/s  30      ▂___  WPA1
   OSA Alpenraum intern     Infra  6     54 Mbit/s  27      ▂___  WPA1 WPA2
   --                       Infra  6     54 Mbit/s  24      ▂___  WPA2
   Wireless1                Infra  12    54 Mbit/s  24      ▂___  WPA1 WPA2
ODROID-C2 with MIMO USB dongle: 31.4 Mbits/sec on average
root@odroidc2:~# iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120
[  4] local 192.168.83.127 port 60388 connected to 192.168.83.146 port 5201
[  4]   0.00-1.01   sec  2.72 MBytes  22.6 Mbits/sec    5   52.3 KBytes
[  4]   1.01-2.01   sec  2.45 MBytes  20.5 Mbits/sec    0   65.0 KBytes
[  4]   2.01-3.01   sec  3.74 MBytes  31.4 Mbits/sec    1   69.3 KBytes
[  4]   3.01-4.01   sec  4.35 MBytes  36.7 Mbits/sec    0   86.3 KBytes
[  4]   4.01-5.01   sec  4.32 MBytes  36.4 Mbits/sec    0    102 KBytes
[  4]   5.01-6.01   sec  4.16 MBytes  34.6 Mbits/sec    0    115 KBytes
[  4]   6.01-7.01   sec  4.63 MBytes  38.9 Mbits/sec    0    127 KBytes
[  4]   7.01-8.02   sec  4.35 MBytes  36.1 Mbits/sec    0    137 KBytes
[  4]   8.02-9.01   sec  3.17 MBytes  27.0 Mbits/sec    0    144 KBytes
[  4]   9.01-10.00  sec  3.96 MBytes  33.6 Mbits/sec    0    151 KBytes
[  4]  10.00-11.01  sec  4.69 MBytes  38.8 Mbits/sec    0    165 KBytes
[  4]  11.01-12.02  sec  4.48 MBytes  37.2 Mbits/sec    0    225 KBytes
[  4]  12.02-13.01  sec  4.21 MBytes  35.7 Mbits/sec    0    287 KBytes
[  4]  13.01-14.01  sec  4.82 MBytes  40.4 Mbits/sec    0    329 KBytes
[  4]  14.01-15.01  sec  4.63 MBytes  38.9 Mbits/sec    0    345 KBytes
[  4]  15.01-16.01  sec  5.22 MBytes  43.8 Mbits/sec    0    363 KBytes
[  4]  16.01-17.01  sec  4.52 MBytes  37.9 Mbits/sec    0    378 KBytes
[  4]  17.01-18.01  sec  4.64 MBytes  38.9 Mbits/sec    0    392 KBytes
[  4]  18.01-19.01  sec  4.11 MBytes  34.5 Mbits/sec    0    392 KBytes
[  4]  19.01-20.01  sec  4.12 MBytes  34.6 Mbits/sec    0    392 KBytes
[  4]  20.01-21.01  sec  5.18 MBytes  43.5 Mbits/sec    0    395 KBytes
[  4]  21.01-22.01  sec  5.01 MBytes  42.1 Mbits/sec    0    406 KBytes
[  4]  22.01-23.01  sec  4.20 MBytes  35.2 Mbits/sec    0    406 KBytes
[  4]  23.01-24.01  sec  3.87 MBytes  32.4 Mbits/sec    1    301 KBytes
[  4]  24.01-25.01  sec  4.28 MBytes  35.9 Mbits/sec    0    324 KBytes
[  4]  25.01-26.01  sec  4.02 MBytes  33.7 Mbits/sec    0    338 KBytes
[  4]  26.01-27.01  sec  4.38 MBytes  36.7 Mbits/sec    1    255 KBytes
[  4]  27.01-28.01  sec  3.85 MBytes  32.3 Mbits/sec    0    266 KBytes
[  4]  28.01-29.02  sec  4.65 MBytes  38.6 Mbits/sec    0    280 KBytes
[  4]  29.02-30.01  sec  4.17 MBytes  35.3 Mbits/sec    0    286 KBytes
[  4]  30.01-31.02  sec  4.55 MBytes  37.8 Mbits/sec    0    287 KBytes
[  4]  31.02-32.01  sec  4.20 MBytes  35.6 Mbits/sec    0    287 KBytes
[  4]  32.01-33.02  sec  4.63 MBytes  38.4 Mbits/sec    0    291 KBytes
[  4]  33.02-34.01  sec  4.71 MBytes  39.9 Mbits/sec    0    298 KBytes
[  4]  34.01-35.01  sec  4.84 MBytes  40.6 Mbits/sec    0    314 KBytes
[  4]  35.01-36.01  sec  5.20 MBytes  43.6 Mbits/sec    0    339 KBytes
[  4]  36.01-37.01  sec  4.98 MBytes  41.8 Mbits/sec    0    359 KBytes
[  4]  37.01-38.02  sec  4.70 MBytes  39.0 Mbits/sec    0    369 KBytes
[  4]  38.02-39.02  sec  4.82 MBytes  40.8 Mbits/sec    0    396 KBytes
[  4]  39.02-40.01  sec  4.39 MBytes  36.9 Mbits/sec    0    403 KBytes
[  4]  40.01-41.01  sec  5.09 MBytes  42.7 Mbits/sec    0    409 KBytes
[  4]  41.01-42.01  sec  4.64 MBytes  39.0 Mbits/sec    0    410 KBytes
[  4]  42.01-43.01  sec  4.91 MBytes  41.3 Mbits/sec    1    287 KBytes
[  4]  43.01-44.01  sec  4.26 MBytes  35.7 Mbits/sec    0    288 KBytes
[  4]  44.01-45.02  sec  3.71 MBytes  30.8 Mbits/sec    0    288 KBytes
[  4]  45.02-46.01  sec  4.01 MBytes  34.0 Mbits/sec    0    293 KBytes
[  4]  46.01-47.02  sec  5.39 MBytes  44.8 Mbits/sec    0    366 KBytes
[  4]  47.02-48.00  sec  5.22 MBytes  44.8 Mbits/sec    1    269 KBytes
[  4]  48.00-49.01  sec  4.26 MBytes  35.3 Mbits/sec    0    272 KBytes
[  4]  49.01-50.01  sec  4.17 MBytes  35.0 Mbits/sec    0    288 KBytes
[  4]  50.01-51.02  sec  5.36 MBytes  44.6 Mbits/sec    0    310 KBytes
[  4]  51.02-52.00  sec  4.99 MBytes  42.8 Mbits/sec    0    315 KBytes
[  4]  52.00-53.01  sec  4.94 MBytes  40.9 Mbits/sec    0    317 KBytes
[  4]  53.01-54.01  sec  4.96 MBytes  41.6 Mbits/sec    0    318 KBytes
[  4]  54.01-55.01  sec  4.75 MBytes  39.8 Mbits/sec    0    321 KBytes
[  4]  55.01-56.01  sec  4.42 MBytes  37.4 Mbits/sec    0    331 KBytes
[  4]  56.01-57.01  sec  4.46 MBytes  37.1 Mbits/sec    0    352 KBytes
[  4]  57.01-58.01  sec  4.70 MBytes  39.4 Mbits/sec    0    362 KBytes
[  4]  58.01-59.01  sec  4.68 MBytes  39.3 Mbits/sec    0    390 KBytes
[  4]  59.01-60.01  sec  4.28 MBytes  35.9 Mbits/sec    0    413 KBytes
[  4]  60.01-61.00  sec  3.92 MBytes  33.3 Mbits/sec    1    290 KBytes
[  4]  61.00-62.01  sec  4.06 MBytes  33.7 Mbits/sec    0    301 KBytes
[  4]  62.01-63.03  sec  4.85 MBytes  40.2 Mbits/sec    0    329 KBytes
[  4]  63.03-64.01  sec  4.08 MBytes  34.6 Mbits/sec    0    344 KBytes
[  4]  64.01-65.00  sec  4.11 MBytes  35.0 Mbits/sec    0    345 KBytes
[  4]  65.00-66.02  sec  4.68 MBytes  38.4 Mbits/sec    0    366 KBytes
[  4]  66.02-67.01  sec  4.92 MBytes  41.7 Mbits/sec    0    373 KBytes
[  4]  67.01-68.02  sec  4.28 MBytes  35.6 Mbits/sec    0    376 KBytes
[  4]  68.02-69.02  sec  4.31 MBytes  36.2 Mbits/sec    0    378 KBytes
[  4]  69.02-70.01  sec  3.33 MBytes  28.2 Mbits/sec    0    386 KBytes
[  4]  70.01-71.02  sec  4.49 MBytes  37.3 Mbits/sec    0    386 KBytes
[  4]  71.02-72.02  sec  4.70 MBytes  39.4 Mbits/sec    0    396 KBytes
[  4]  72.02-73.01  sec  4.32 MBytes  36.7 Mbits/sec    0    413 KBytes
[  4]  73.01-74.02  sec  4.42 MBytes  36.6 Mbits/sec    0    426 KBytes
[  4]  74.02-75.01  sec  4.43 MBytes  37.5 Mbits/sec    0    426 KBytes
[  4]  75.01-76.01  sec  4.69 MBytes  39.3 Mbits/sec    0    428 KBytes
[  4]  76.01-77.00  sec  4.80 MBytes  40.6 Mbits/sec    0    428 KBytes
[  4]  77.00-78.01  sec  4.72 MBytes  39.6 Mbits/sec    0    430 KBytes
[  4]  78.01-79.01  sec  4.34 MBytes  36.1 Mbits/sec    0    433 KBytes
[  4]  79.01-80.01  sec  5.23 MBytes  44.2 Mbits/sec    0    458 KBytes
[  4]  80.01-81.01  sec  3.73 MBytes  31.0 Mbits/sec    0    458 KBytes
[  4]  81.01-82.02  sec  3.78 MBytes  31.4 Mbits/sec    0    458 KBytes
[  4]  82.02-83.02  sec  4.77 MBytes  40.2 Mbits/sec    0    458 KBytes
[  4]  83.02-84.01  sec  3.64 MBytes  30.7 Mbits/sec    0    458 KBytes
[  4]  84.01-85.01  sec  3.97 MBytes  33.3 Mbits/sec    0    458 KBytes
[  4]  85.01-86.01  sec  4.08 MBytes  34.2 Mbits/sec    0    458 KBytes
[  4]  86.01-87.01  sec  4.00 MBytes  33.5 Mbits/sec    0    458 KBytes
[  4]  87.01-88.01  sec  3.90 MBytes  32.7 Mbits/sec    0    458 KBytes
[  4]  88.01-89.02  sec  4.35 MBytes  36.1 Mbits/sec    0    458 KBytes
[  4]  89.02-90.01  sec  4.70 MBytes  39.8 Mbits/sec    0    458 KBytes
[  4]  90.01-91.00  sec  4.50 MBytes  38.1 Mbits/sec    0    458 KBytes
[  4]  91.00-92.01  sec  4.61 MBytes  38.4 Mbits/sec    0    458 KBytes
[  4]  92.01-93.01  sec  4.59 MBytes  38.5 Mbits/sec    0    462 KBytes
[  4]  93.01-94.01  sec  4.61 MBytes  38.6 Mbits/sec    0    462 KBytes
[  4]  94.01-95.01  sec  5.12 MBytes  43.0 Mbits/sec    0    469 KBytes
[  4]  95.01-96.01  sec  4.77 MBytes  40.0 Mbits/sec    0    477 KBytes
[  4]  96.01-97.01  sec  4.55 MBytes  38.2 Mbits/sec    0    477 KBytes
[  4]  97.01-98.00  sec  4.88 MBytes  41.4 Mbits/sec    0    479 KBytes
[  4]  98.00-99.01  sec  4.55 MBytes  37.7 Mbits/sec    0    479 KBytes
[  4]  99.01-100.01 sec  4.52 MBytes  37.9 Mbits/sec    0    479 KBytes
[  4] 100.01-101.01 sec  4.43 MBytes  37.1 Mbits/sec    0    479 KBytes
[  4] 101.01-102.01 sec  4.37 MBytes  36.7 Mbits/sec    0    485 KBytes
[  4] 102.01-103.02 sec  5.21 MBytes  43.7 Mbits/sec    0    485 KBytes
[  4] 103.02-104.01 sec  4.75 MBytes  39.8 Mbits/sec    0    495 KBytes
[  4] 104.01-105.01 sec  4.31 MBytes  36.3 Mbits/sec    0    495 KBytes
[  4] 105.01-106.02 sec  4.67 MBytes  38.6 Mbits/sec    0    495 KBytes
[  4] 106.02-107.01 sec  5.02 MBytes  42.8 Mbits/sec    1    349 KBytes
[  4] 107.01-108.01 sec  4.65 MBytes  38.8 Mbits/sec    0    361 KBytes
[  4] 108.01-109.02 sec  4.76 MBytes  39.5 Mbits/sec    0    392 KBytes
[  4] 109.02-110.01 sec  3.73 MBytes  31.6 Mbits/sec    0    392 KBytes
[  4] 110.01-111.00 sec  4.26 MBytes  36.1 Mbits/sec    0    392 KBytes
[  4] 111.00-112.01 sec  3.72 MBytes  30.9 Mbits/sec    0    392 KBytes
[  4] 112.01-113.01 sec  3.81 MBytes  31.9 Mbits/sec    0    392 KBytes
[  4] 113.01-114.02 sec  4.25 MBytes  35.4 Mbits/sec    0    392 KBytes
[  4] 114.02-115.01 sec  4.16 MBytes  35.2 Mbits/sec    0    414 KBytes
[  4] 115.01-116.01 sec  4.25 MBytes  35.7 Mbits/sec    0    414 KBytes
[  4] 116.01-117.01 sec  4.41 MBytes  37.0 Mbits/sec    0    414 KBytes
[  4] 117.01-118.01 sec  3.09 MBytes  25.9 Mbits/sec    0    414 KBytes
[  4] 118.01-119.01 sec  3.27 MBytes  27.5 Mbits/sec    0    417 KBytes
[  4] 119.01-120.02 sec  3.30 MBytes  27.4 Mbits/sec    0    417 KBytes
[  4]   0.00-120.02 sec   528 MBytes  36.9 Mbits/sec   12             sender
[  4]   0.00-120.02 sec   527 MBytes  36.8 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.83.127 port 60390 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  2.73 MBytes  22.9 Mbits/sec
[  4]   1.00-2.01   sec  2.70 MBytes  22.3 Mbits/sec
[  4]   2.01-3.00   sec  2.49 MBytes  21.1 Mbits/sec
[  4]   3.00-4.00   sec  2.52 MBytes  21.2 Mbits/sec
[  4]   4.00-5.01   sec  1.90 MBytes  15.7 Mbits/sec
[  4]   5.01-6.01   sec  2.91 MBytes  24.5 Mbits/sec
[  4]   6.01-7.01   sec  2.16 MBytes  18.0 Mbits/sec
[  4]   7.01-8.01   sec  1.58 MBytes  13.2 Mbits/sec
[  4]   8.01-9.01   sec  2.40 MBytes  20.1 Mbits/sec
[  4]   9.01-10.00  sec  2.30 MBytes  19.5 Mbits/sec
[  4]  10.00-11.00  sec  2.78 MBytes  23.4 Mbits/sec
[  4]  11.00-12.00  sec  2.77 MBytes  23.2 Mbits/sec
[  4]  12.00-13.00  sec  3.00 MBytes  25.1 Mbits/sec
[  4]  13.00-14.00  sec  3.16 MBytes  26.6 Mbits/sec
[  4]  14.00-15.00  sec  3.18 MBytes  26.7 Mbits/sec
[  4]  15.00-16.00  sec  3.04 MBytes  25.5 Mbits/sec
[  4]  16.00-17.00  sec  2.32 MBytes  19.5 Mbits/sec
[  4]  17.00-18.00  sec  2.84 MBytes  23.8 Mbits/sec
[  4]  18.00-19.00  sec  3.06 MBytes  25.7 Mbits/sec
[  4]  19.00-20.00  sec  3.07 MBytes  25.7 Mbits/sec
[  4]  20.00-21.00  sec  2.90 MBytes  24.4 Mbits/sec
[  4]  21.00-22.00  sec  2.82 MBytes  23.6 Mbits/sec
[  4]  22.00-23.00  sec  3.14 MBytes  26.4 Mbits/sec
[  4]  23.00-24.00  sec  2.94 MBytes  24.6 Mbits/sec
[  4]  24.00-25.00  sec  1.94 MBytes  16.3 Mbits/sec
[  4]  25.00-26.00  sec  3.16 MBytes  26.5 Mbits/sec
[  4]  26.00-27.00  sec  3.20 MBytes  26.9 Mbits/sec
[  4]  27.00-28.00  sec  3.07 MBytes  25.8 Mbits/sec
[  4]  28.00-29.00  sec  3.26 MBytes  27.4 Mbits/sec
[  4]  29.00-30.01  sec  3.27 MBytes  27.2 Mbits/sec
[  4]  30.01-31.00  sec  2.93 MBytes  24.8 Mbits/sec
[  4]  31.00-32.00  sec  3.11 MBytes  26.1 Mbits/sec
[  4]  32.00-33.01  sec  2.95 MBytes  24.4 Mbits/sec
[  4]  33.01-34.02  sec  2.52 MBytes  21.0 Mbits/sec
[  4]  34.02-35.00  sec  3.77 MBytes  32.1 Mbits/sec
[  4]  35.00-36.00  sec  3.50 MBytes  29.4 Mbits/sec
[  4]  36.00-37.00  sec  3.06 MBytes  25.7 Mbits/sec
[  4]  37.00-38.01  sec  3.24 MBytes  26.8 Mbits/sec
[  4]  38.01-39.00  sec  3.22 MBytes  27.3 Mbits/sec
[  4]  39.00-40.00  sec  3.03 MBytes  25.4 Mbits/sec
[  4]  40.00-41.00  sec  2.70 MBytes  22.6 Mbits/sec
[  4]  41.00-42.00  sec  3.24 MBytes  27.3 Mbits/sec
[  4]  42.00-43.01  sec  3.00 MBytes  25.0 Mbits/sec
[  4]  43.01-44.00  sec  2.97 MBytes  25.0 Mbits/sec
[  4]  44.00-45.00  sec  2.87 MBytes  24.1 Mbits/sec
[  4]  45.00-46.00  sec  3.46 MBytes  29.0 Mbits/sec
[  4]  46.00-47.01  sec  3.39 MBytes  28.1 Mbits/sec
[  4]  47.01-48.01  sec  2.20 MBytes  18.5 Mbits/sec
[  4]  48.01-49.00  sec  3.13 MBytes  26.5 Mbits/sec
[  4]  49.00-50.00  sec  3.07 MBytes  25.7 Mbits/sec
[  4]  50.00-51.00  sec  3.31 MBytes  27.7 Mbits/sec
[  4]  51.00-52.00  sec  3.23 MBytes  27.2 Mbits/sec
[  4]  52.00-53.00  sec  3.29 MBytes  27.6 Mbits/sec
[  4]  53.00-54.00  sec  3.25 MBytes  27.2 Mbits/sec
[  4]  54.00-55.00  sec  2.84 MBytes  23.8 Mbits/sec
[  4]  55.00-56.00  sec  3.09 MBytes  25.9 Mbits/sec
[  4]  56.00-57.00  sec  3.29 MBytes  27.6 Mbits/sec
[  4]  57.00-58.01  sec  3.45 MBytes  28.8 Mbits/sec
[  4]  58.01-59.00  sec  3.45 MBytes  29.0 Mbits/sec
[  4]  59.00-60.01  sec  3.25 MBytes  27.0 Mbits/sec
[  4]  60.01-61.00  sec  3.02 MBytes  25.6 Mbits/sec
[  4]  61.00-62.00  sec  3.42 MBytes  28.7 Mbits/sec
[  4]  62.00-63.00  sec  3.50 MBytes  29.4 Mbits/sec
[  4]  63.00-64.00  sec  3.35 MBytes  28.1 Mbits/sec
[  4]  64.00-65.00  sec  3.17 MBytes  26.6 Mbits/sec
[  4]  65.00-66.00  sec  3.22 MBytes  27.1 Mbits/sec
[  4]  66.00-67.00  sec  3.51 MBytes  29.4 Mbits/sec
[  4]  67.00-68.00  sec  3.43 MBytes  28.7 Mbits/sec
[  4]  68.00-69.01  sec  3.23 MBytes  27.0 Mbits/sec
[  4]  69.01-70.00  sec  3.07 MBytes  25.9 Mbits/sec
[  4]  70.00-71.00  sec  3.11 MBytes  26.1 Mbits/sec
[  4]  71.00-72.00  sec  3.42 MBytes  28.7 Mbits/sec
[  4]  72.00-73.00  sec  3.17 MBytes  26.6 Mbits/sec
[  4]  73.00-74.00  sec  2.99 MBytes  25.1 Mbits/sec
[  4]  74.00-75.00  sec  3.22 MBytes  27.0 Mbits/sec
[  4]  75.00-76.00  sec  3.15 MBytes  26.5 Mbits/sec
[  4]  76.00-77.01  sec  3.23 MBytes  27.0 Mbits/sec
[  4]  77.01-78.00  sec  3.03 MBytes  25.5 Mbits/sec
[  4]  78.00-79.00  sec  3.25 MBytes  27.3 Mbits/sec
[  4]  79.00-80.00  sec  3.13 MBytes  26.2 Mbits/sec
[  4]  80.00-81.00  sec  3.26 MBytes  27.3 Mbits/sec
[  4]  81.00-82.01  sec  2.76 MBytes  22.9 Mbits/sec
[  4]  82.01-83.00  sec  2.76 MBytes  23.5 Mbits/sec
[  4]  83.00-84.00  sec  3.15 MBytes  26.4 Mbits/sec
[  4]  84.00-85.00  sec  3.00 MBytes  25.2 Mbits/sec
[  4]  85.00-86.00  sec  3.29 MBytes  27.6 Mbits/sec
[  4]  86.00-87.00  sec  3.27 MBytes  27.4 Mbits/sec
[  4]  87.00-88.00  sec  3.22 MBytes  26.9 Mbits/sec
[  4]  88.00-89.00  sec  3.26 MBytes  27.4 Mbits/sec
[  4]  89.00-90.00  sec  3.06 MBytes  25.6 Mbits/sec
[  4]  90.00-91.00  sec  3.26 MBytes  27.5 Mbits/sec
[  4]  91.00-92.00  sec  3.30 MBytes  27.7 Mbits/sec
[  4]  92.00-93.00  sec  3.33 MBytes  27.9 Mbits/sec
[  4]  93.00-94.00  sec  3.33 MBytes  27.9 Mbits/sec
[  4]  94.00-95.00  sec  3.03 MBytes  25.4 Mbits/sec
[  4]  95.00-96.00  sec  3.22 MBytes  27.0 Mbits/sec
[  4]  96.00-97.00  sec  3.46 MBytes  29.0 Mbits/sec
[  4]  97.00-98.00  sec  3.30 MBytes  27.7 Mbits/sec
[  4]  98.00-99.00  sec  3.29 MBytes  27.7 Mbits/sec
[  4]  99.00-100.00 sec  3.33 MBytes  27.9 Mbits/sec
[  4] 100.00-101.01 sec  3.18 MBytes  26.7 Mbits/sec
[  4] 101.01-102.01 sec  3.01 MBytes  25.2 Mbits/sec
[  4] 102.01-103.00 sec  3.19 MBytes  26.9 Mbits/sec
[  4] 103.00-104.00 sec  3.22 MBytes  27.0 Mbits/sec
[  4] 104.00-105.00 sec  3.25 MBytes  27.3 Mbits/sec
[  4] 105.00-106.00 sec  3.52 MBytes  29.6 Mbits/sec
[  4] 106.00-107.00 sec  3.26 MBytes  27.3 Mbits/sec
[  4] 107.00-108.00 sec  3.41 MBytes  28.7 Mbits/sec
[  4] 108.00-109.00 sec  3.11 MBytes  26.0 Mbits/sec
[  4] 109.00-110.00 sec  3.11 MBytes  26.1 Mbits/sec
[  4] 110.00-111.00 sec  3.38 MBytes  28.3 Mbits/sec
[  4] 111.00-112.00 sec  3.15 MBytes  26.4 Mbits/sec
[  4] 112.00-113.00 sec  3.23 MBytes  27.2 Mbits/sec
[  4] 113.00-114.00 sec  3.33 MBytes  28.0 Mbits/sec
[  4] 114.00-115.00 sec  3.07 MBytes  25.7 Mbits/sec
[  4] 115.00-116.00 sec  3.17 MBytes  26.6 Mbits/sec
[  4] 116.00-117.00 sec  3.16 MBytes  26.5 Mbits/sec
[  4] 117.00-118.01 sec  3.18 MBytes  26.6 Mbits/sec
[  4] 118.01-119.00 sec  3.22 MBytes  27.2 Mbits/sec
[  4] 119.00-120.00 sec  3.37 MBytes  28.3 Mbits/sec
[  4]   0.00-120.00 sec   372 MBytes  26.0 Mbits/sec   80             sender
[  4]   0.00-120.00 sec   370 MBytes  25.9 Mbits/sec                  receiver
iperf Done.
root@odroidc2:~# iwconfig wlan0
          Bit Rate:130 Mb/s   Sensitivity:0/0
          Link Quality=100/100  Signal level=-59 dBm  Noise level=0 dBm
root@odroidc2:~# nmcli dev wifi list
*  Snort-Honeynet           Infra  13    2 Mbit/s   100     ▂▄▆█  WPA2
   FRITZ!Box 7490           Infra  11    16 Mbit/s  65      ▂▄▆_  WPA2
   DISTORTEDPEOPLE          Infra  9     44 Mbit/s  59      ▂▄▆_  WPA1 WPA2
   EasyBox-116D28           Infra  5     16 Mbit/s  55      ▂▄__  WPA1 WPA2
   Wonder Woman             Infra  1     44 Mbit/s  49      ▂▄__  WPA1 WPA2
   --                       Infra  6     16 Mbit/s  49      ▂▄__  WPA2
   DIRECT-1LC460 Series     Infra  10    54 Mbit/s  49      ▂▄__  WPA2
   WLAN-3C3379              Infra  11    16 Mbit/s  49      ▂▄__  WPA2
   UBNT2                    Infra  3     54 Mbit/s  47      ▂▄__
   EasyBox-188632           Infra  10    44 Mbit/s  47      ▂▄__  WPA1 WPA2
   WLAN-341381              Infra  11    16 Mbit/s  47      ▂▄__  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     44 Mbit/s  45      ▂▄__  WPA1 WPA2
   --                       Infra  1     8 Mbit/s   45      ▂▄__
   DISTORTEDPEOPLE_EXT      Infra  9     16 Mbit/s  45      ▂▄__  WPA1 WPA2
   EasyBox-290502           Infra  10    44 Mbit/s  44      ▂▄__  WPA1 WPA2
   Wolf 7360                Infra  11    16 Mbit/s  44      ▂▄__  WPA1 WPA2
   Eichkatzenkind           Infra  5     44 Mbit/s  30      ▂___  WPA2
   o2-WLAN85                Infra  4     44 Mbit/s  29      ▂___  WPA2
   Fallibilismus            Infra  7     44 Mbit/s  29      ▂___  WPA1 WPA2
   ArcorWirelessLANGaby     Infra  6     54 Mbit/s  19      ▂___  WPA1
   OSA Alpenraum intern     Infra  6     16 Mbit/s  17      ▂___  WPA1 WPA2
   OSAs Gästenetzwerk       Infra  6     16 Mbit/s  17      ▂___  WPA1 WPA2
   Kiki                     Infra  11    44 Mbit/s  15      ▂___  WPA1 WPA2
EDIT: Silly me forgot to disable Wi-Fi powermanagement. Will redo all tests now and update results in a few minutes.
I wanted to test with RPi Zero W but since the board is still not here I'm testing with RPi 3 now (uses same Wi-Fi/BT chip and also a small onboard antenna). I upgraded the kernel to latest available version 4.9.13-v7+ and applied all other updates. Some log output here.
All tests were done as above, I simply put the Raspberry in the 3 different rooms at exactly the same position and fired up the same set of tests again:
RPi 3 being 50cm away from AP: 37.4Mbits/s on average and over 3000 retransmits when testing in RX direction.
root@raspberrypi:/home/pi# iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120
Connecting to host 192.168.83.146, port 5201
[  4] local 192.168.83.191 port 36712 connected to 192.168.83.146 port 5201
iperf3: print_interval_results error: interval_results is NULL
iperf3: iperf_print_intermediate error: interval_results is NULL
[ ID] Interval           Transfer     Bandwidth       Retr
[  4]   0.00-0.00   sec  0.00 Bytes   nan bits/sec    0             sender
[  4]   0.00-0.00   sec  0.00 Bytes   nan bits/sec                  receiver
iperf3: error - the server has terminated
[  4] local 192.168.83.191 port 36716 connected to 192.168.83.146 port 5201
[ ID] Interval           Transfer     Bandwidth       Retr  Cwnd
[  4]   0.00-1.00   sec  4.49 MBytes  37.7 Mbits/sec    0    107 KBytes
[  4]   1.00-2.00   sec  4.41 MBytes  37.0 Mbits/sec    0    116 KBytes
[  4]   2.00-3.00   sec  4.52 MBytes  37.9 Mbits/sec    0    127 KBytes
[  4]   3.00-4.00   sec  4.36 MBytes  36.5 Mbits/sec    0    134 KBytes
[  4]   4.00-5.00   sec  4.60 MBytes  38.6 Mbits/sec    1   99.0 KBytes
[  4]   5.00-6.00   sec  4.16 MBytes  34.9 Mbits/sec    0    123 KBytes
[  4]   6.00-7.00   sec  4.41 MBytes  37.0 Mbits/sec    0    123 KBytes
[  4]   7.00-8.00   sec  4.60 MBytes  38.6 Mbits/sec    0    141 KBytes
[  4]   8.00-9.00   sec  4.25 MBytes  35.7 Mbits/sec    0    141 KBytes
[  4]   9.00-10.00  sec  4.27 MBytes  35.8 Mbits/sec    0    141 KBytes
[  4]  10.00-11.00  sec  4.25 MBytes  35.7 Mbits/sec    0    141 KBytes
[  4]  11.00-12.00  sec  4.24 MBytes  35.6 Mbits/sec    0    151 KBytes
[  4]  12.00-13.00  sec  4.33 MBytes  36.3 Mbits/sec    0    151 KBytes
[  4]  13.00-14.00  sec  4.52 MBytes  37.9 Mbits/sec    0    151 KBytes
[  4]  14.00-15.00  sec  4.48 MBytes  37.6 Mbits/sec    1    107 KBytes
[  4]  15.00-16.00  sec  4.41 MBytes  37.0 Mbits/sec    0    129 KBytes
[  4]  16.00-17.00  sec  4.29 MBytes  36.0 Mbits/sec    0    144 KBytes
[  4]  17.00-18.00  sec  4.44 MBytes  37.3 Mbits/sec    0    148 KBytes
[  4]  18.00-19.00  sec  4.56 MBytes  38.3 Mbits/sec    0    148 KBytes
[  4]  19.00-20.00  sec  4.33 MBytes  36.3 Mbits/sec    0    148 KBytes
[  4]  20.00-21.00  sec  4.31 MBytes  36.1 Mbits/sec    0    148 KBytes
[  4]  21.00-22.00  sec  4.54 MBytes  38.1 Mbits/sec    0    148 KBytes
[  4]  22.00-23.00  sec  4.36 MBytes  36.6 Mbits/sec    1    109 KBytes
[  4]  23.00-24.00  sec  4.41 MBytes  37.0 Mbits/sec    0    122 KBytes
[  4]  24.00-25.00  sec  4.42 MBytes  37.1 Mbits/sec    0    124 KBytes
[  4]  25.00-26.00  sec  4.42 MBytes  37.1 Mbits/sec    0    126 KBytes
[  4]  26.00-27.00  sec  4.49 MBytes  37.6 Mbits/sec    0    126 KBytes
[  4]  27.00-28.00  sec  4.46 MBytes  37.4 Mbits/sec    0    129 KBytes
[  4]  28.00-29.00  sec  4.35 MBytes  36.5 Mbits/sec    0    143 KBytes
[  4]  29.00-30.00  sec  4.54 MBytes  38.1 Mbits/sec    0    153 KBytes
[  4]  30.00-31.00  sec  4.55 MBytes  38.2 Mbits/sec    0    153 KBytes
[  4]  31.00-32.00  sec  4.47 MBytes  37.5 Mbits/sec    0    226 KBytes
[  4]  32.00-33.00  sec  4.46 MBytes  37.4 Mbits/sec    0    226 KBytes
[  4]  33.00-34.00  sec  4.32 MBytes  36.2 Mbits/sec    0    226 KBytes
[  4]  34.00-35.00  sec  4.48 MBytes  37.6 Mbits/sec    0    226 KBytes
[  4]  35.00-36.00  sec  4.49 MBytes  37.6 Mbits/sec    0    226 KBytes
[  4]  36.00-37.00  sec  4.20 MBytes  35.3 Mbits/sec    0    226 KBytes
[  4]  37.00-38.00  sec  4.30 MBytes  36.1 Mbits/sec    0    226 KBytes
[  4]  38.00-39.00  sec  4.31 MBytes  36.1 Mbits/sec    0    226 KBytes
[  4]  39.00-40.00  sec  4.36 MBytes  36.6 Mbits/sec    0    226 KBytes
[  4]  40.00-41.00  sec  4.55 MBytes  38.2 Mbits/sec    0    226 KBytes
[  4]  41.00-42.00  sec  4.70 MBytes  39.4 Mbits/sec    0    226 KBytes
[  4]  42.00-43.00  sec  4.34 MBytes  36.4 Mbits/sec    0    226 KBytes
[  4]  43.00-44.00  sec  4.37 MBytes  36.7 Mbits/sec    0    226 KBytes
[  4]  44.00-45.00  sec  4.35 MBytes  36.5 Mbits/sec    0    226 KBytes
[  4]  45.00-46.00  sec  4.36 MBytes  36.6 Mbits/sec    0    226 KBytes
[  4]  46.00-47.00  sec  4.33 MBytes  36.3 Mbits/sec    1    158 KBytes
[  4]  47.00-48.00  sec  4.57 MBytes  38.4 Mbits/sec    0    158 KBytes
[  4]  48.00-49.00  sec  4.53 MBytes  38.0 Mbits/sec    0    205 KBytes
[  4]  49.00-50.00  sec  4.21 MBytes  35.4 Mbits/sec    0    215 KBytes
[  4]  50.00-51.00  sec  4.38 MBytes  36.8 Mbits/sec    0    215 KBytes
[  4]  51.00-52.00  sec  4.20 MBytes  35.2 Mbits/sec    0    215 KBytes
[  4]  52.00-53.00  sec  4.28 MBytes  35.9 Mbits/sec    0    215 KBytes
[  4]  53.00-54.00  sec  4.28 MBytes  35.9 Mbits/sec    0    215 KBytes
[  4]  54.00-55.00  sec  4.29 MBytes  36.0 Mbits/sec    0    215 KBytes
[  4]  55.00-56.00  sec  4.55 MBytes  38.2 Mbits/sec    1    150 KBytes
[  4]  56.00-57.00  sec  4.52 MBytes  37.9 Mbits/sec    0    167 KBytes
[  4]  57.00-58.00  sec  4.36 MBytes  36.6 Mbits/sec    0    167 KBytes
[  4]  58.00-59.00  sec  4.49 MBytes  37.6 Mbits/sec    0    167 KBytes
[  4]  59.00-60.00  sec  4.53 MBytes  38.0 Mbits/sec    0    167 KBytes
[  4]  60.00-61.00  sec  4.48 MBytes  37.5 Mbits/sec    0    180 KBytes
[  4]  61.00-62.00  sec  4.41 MBytes  37.0 Mbits/sec    0    180 KBytes
[  4]  62.00-63.00  sec  4.23 MBytes  35.5 Mbits/sec    0    180 KBytes
[  4]  63.00-64.00  sec  4.48 MBytes  37.6 Mbits/sec    0    180 KBytes
[  4]  64.00-65.00  sec  4.46 MBytes  37.4 Mbits/sec    0    180 KBytes
[  4]  65.00-66.00  sec  4.36 MBytes  36.5 Mbits/sec    1    124 KBytes
[  4]  66.00-67.00  sec  4.47 MBytes  37.5 Mbits/sec    0    140 KBytes
[  4]  67.00-68.00  sec  4.15 MBytes  34.8 Mbits/sec    0    146 KBytes
[  4]  68.00-69.00  sec  4.28 MBytes  35.9 Mbits/sec    0    148 KBytes
[  4]  69.00-70.00  sec  4.44 MBytes  37.3 Mbits/sec    0    148 KBytes
[  4]  70.00-71.00  sec  4.46 MBytes  37.4 Mbits/sec    0    148 KBytes
[  4]  71.00-72.00  sec  4.17 MBytes  34.9 Mbits/sec    0    157 KBytes
[  4]  72.00-73.00  sec  4.45 MBytes  37.3 Mbits/sec    0    157 KBytes
[  4]  73.00-74.00  sec  4.43 MBytes  37.1 Mbits/sec    0    157 KBytes
[  4]  74.00-75.00  sec  4.58 MBytes  38.4 Mbits/sec    0    157 KBytes
[  4]  75.00-76.00  sec  4.31 MBytes  36.2 Mbits/sec    0    157 KBytes
[  4]  76.00-77.00  sec  4.58 MBytes  38.4 Mbits/sec    0    157 KBytes
[  4]  77.00-78.00  sec  4.45 MBytes  37.3 Mbits/sec    0    157 KBytes
[  4]  78.00-79.00  sec  4.28 MBytes  35.9 Mbits/sec    1    112 KBytes
[  4]  79.00-80.00  sec  4.62 MBytes  38.8 Mbits/sec    0    113 KBytes
[  4]  80.00-81.00  sec  2.30 MBytes  19.3 Mbits/sec    0    141 KBytes
[  4]  81.00-82.00  sec  3.95 MBytes  33.1 Mbits/sec    0    141 KBytes
[  4]  82.00-83.00  sec  4.68 MBytes  39.3 Mbits/sec    1    100 KBytes
[  4]  83.00-84.00  sec  4.84 MBytes  40.6 Mbits/sec    0    115 KBytes
[  4]  84.00-85.00  sec  3.87 MBytes  32.5 Mbits/sec    0    120 KBytes
[  4]  85.00-86.00  sec  4.51 MBytes  37.9 Mbits/sec    1   94.7 KBytes
[  4]  86.00-87.00  sec  4.83 MBytes  40.5 Mbits/sec    0    109 KBytes
[  4]  87.00-88.00  sec  4.24 MBytes  35.5 Mbits/sec    0    119 KBytes
[  4]  88.00-89.00  sec  4.35 MBytes  36.5 Mbits/sec    0    120 KBytes
[  4]  89.00-90.00  sec  4.35 MBytes  36.5 Mbits/sec    0    120 KBytes
[  4]  90.00-91.00  sec  4.47 MBytes  37.5 Mbits/sec    0    120 KBytes
[  4]  91.00-92.00  sec  4.58 MBytes  38.4 Mbits/sec    0    123 KBytes
[  4]  92.00-93.00  sec  4.47 MBytes  37.5 Mbits/sec    0    134 KBytes
[  4]  93.00-94.00  sec  4.41 MBytes  37.0 Mbits/sec    0    156 KBytes
[  4]  94.00-95.00  sec  4.29 MBytes  36.0 Mbits/sec    0    156 KBytes
[  4]  95.00-96.00  sec  4.08 MBytes  34.2 Mbits/sec    0    156 KBytes
[  4]  96.00-97.00  sec  4.16 MBytes  34.9 Mbits/sec    0    156 KBytes
[  4]  97.00-98.00  sec  3.99 MBytes  33.5 Mbits/sec    0    156 KBytes
[  4]  98.00-99.00  sec  3.49 MBytes  29.2 Mbits/sec    9    109 KBytes
[  4]  99.00-100.00 sec  3.95 MBytes  33.2 Mbits/sec    0    120 KBytes
[  4] 100.00-101.00 sec  4.19 MBytes  35.1 Mbits/sec    0    136 KBytes
[  4] 101.00-102.00 sec  4.05 MBytes  34.0 Mbits/sec    0    154 KBytes
[  4] 102.00-103.00 sec  4.45 MBytes  37.4 Mbits/sec    0    154 KBytes
[  4] 103.00-104.00 sec  4.56 MBytes  38.3 Mbits/sec    0    156 KBytes
[  4] 104.00-105.00 sec  4.34 MBytes  36.4 Mbits/sec    0    157 KBytes
[  4] 105.00-106.00 sec  4.00 MBytes  33.5 Mbits/sec    0    157 KBytes
[  4] 106.00-107.00 sec  4.45 MBytes  37.3 Mbits/sec    0    157 KBytes
[  4] 107.00-108.00 sec  4.17 MBytes  35.0 Mbits/sec    0    160 KBytes
[  4] 108.00-109.00 sec  4.18 MBytes  35.1 Mbits/sec    1    113 KBytes
[  4] 109.00-110.00 sec  4.28 MBytes  35.9 Mbits/sec    0    134 KBytes
[  4] 110.00-111.00 sec  4.28 MBytes  35.9 Mbits/sec    0    153 KBytes
[  4] 111.00-112.00 sec  4.19 MBytes  35.1 Mbits/sec    0    153 KBytes
[  4] 112.00-113.00 sec  3.90 MBytes  32.7 Mbits/sec    1    106 KBytes
[  4] 113.00-114.00 sec  4.28 MBytes  35.9 Mbits/sec    0    116 KBytes
[  4] 114.00-115.00 sec  4.26 MBytes  35.7 Mbits/sec    0    127 KBytes
[  4] 115.00-116.00 sec  4.30 MBytes  36.0 Mbits/sec    0    127 KBytes
[  4] 116.00-117.00 sec  4.48 MBytes  37.6 Mbits/sec    0    127 KBytes
[  4] 117.00-118.00 sec  4.46 MBytes  37.4 Mbits/sec    0    129 KBytes
[  4] 118.00-119.00 sec  4.31 MBytes  36.2 Mbits/sec    0    132 KBytes
[  4] 119.00-120.00 sec  4.46 MBytes  37.4 Mbits/sec    0    139 KBytes
[  4]   0.00-120.00 sec   522 MBytes  36.5 Mbits/sec   20             sender
[  4]   0.00-120.00 sec   522 MBytes  36.5 Mbits/sec                  receiver
iperf Done.
Reverse mode, remote host 192.168.83.146 is sending
[  4] local 192.168.83.191 port 36720 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  4.37 MBytes  36.7 Mbits/sec
[  4]   1.00-2.00   sec  4.77 MBytes  40.0 Mbits/sec
[  4]   2.00-3.00   sec  4.71 MBytes  39.5 Mbits/sec
[  4]   3.00-4.00   sec  4.89 MBytes  41.1 Mbits/sec
[  4]   4.00-5.00   sec  4.77 MBytes  40.0 Mbits/sec
[  4]   5.00-6.00   sec  4.99 MBytes  41.9 Mbits/sec
[  4]   6.00-7.00   sec  4.88 MBytes  41.0 Mbits/sec
[  4]   7.00-8.00   sec  4.91 MBytes  41.2 Mbits/sec
[  4]   8.00-9.00   sec  4.78 MBytes  40.1 Mbits/sec
[  4]   9.00-10.00  sec  4.99 MBytes  41.9 Mbits/sec
[  4]  10.00-11.00  sec  4.38 MBytes  36.7 Mbits/sec
[  4]  11.00-12.00  sec  4.70 MBytes  39.4 Mbits/sec
[  4]  12.00-13.00  sec  2.61 MBytes  21.9 Mbits/sec
[  4]  13.00-14.00  sec  4.86 MBytes  40.8 Mbits/sec
[  4]  14.00-15.00  sec  4.61 MBytes  38.7 Mbits/sec
[  4]  15.00-16.00  sec  4.80 MBytes  40.3 Mbits/sec
[  4]  16.00-17.00  sec  4.81 MBytes  40.4 Mbits/sec
[  4]  17.00-18.00  sec  4.71 MBytes  39.5 Mbits/sec
[  4]  18.00-19.00  sec  4.57 MBytes  38.3 Mbits/sec
[  4]  19.00-20.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  20.00-21.00  sec  4.75 MBytes  39.9 Mbits/sec
[  4]  22.00-23.00  sec  4.70 MBytes  39.4 Mbits/sec
[  4]  23.00-24.00  sec  4.72 MBytes  39.6 Mbits/sec
[  4]  24.00-25.00  sec  4.74 MBytes  39.8 Mbits/sec
[  4]  25.00-26.00  sec  4.14 MBytes  34.8 Mbits/sec
[  4]  26.00-27.00  sec  5.00 MBytes  42.0 Mbits/sec
[  4]  27.00-28.00  sec  4.36 MBytes  36.6 Mbits/sec
[  4]  28.00-29.00  sec  4.79 MBytes  40.2 Mbits/sec
[  4]  29.00-30.00  sec  4.20 MBytes  35.3 Mbits/sec
[  4]  30.00-31.00  sec  4.67 MBytes  39.2 Mbits/sec
[  4]  31.00-32.00  sec  4.77 MBytes  40.0 Mbits/sec
[  4]  32.00-33.00  sec  4.33 MBytes  36.3 Mbits/sec
[  4]  33.00-34.00  sec  4.25 MBytes  35.7 Mbits/sec
[  4]  34.00-35.00  sec  4.50 MBytes  37.7 Mbits/sec
[  4]  35.00-36.00  sec  4.55 MBytes  38.2 Mbits/sec
[  4]  36.00-37.00  sec  4.66 MBytes  39.1 Mbits/sec
[  4]  37.00-38.00  sec  4.96 MBytes  41.6 Mbits/sec
[  4]  38.00-39.00  sec  5.04 MBytes  42.3 Mbits/sec
[  4]  39.00-40.00  sec  4.47 MBytes  37.5 Mbits/sec
[  4]  40.00-41.00  sec  4.50 MBytes  37.7 Mbits/sec
[  4]  41.00-42.00  sec  3.82 MBytes  32.1 Mbits/sec
[  4]  42.00-43.00  sec  4.62 MBytes  38.7 Mbits/sec
[  4]  43.00-44.00  sec  4.75 MBytes  39.8 Mbits/sec
[  4]  44.00-45.00  sec  4.54 MBytes  38.1 Mbits/sec
[  4]  45.00-46.00  sec  4.55 MBytes  38.2 Mbits/sec
[  4]  46.00-47.00  sec  4.79 MBytes  40.2 Mbits/sec
[  4]  47.00-48.00  sec  4.64 MBytes  38.9 Mbits/sec
[  4]  48.00-49.00  sec  4.81 MBytes  40.4 Mbits/sec
[  4]  49.00-50.00  sec  4.79 MBytes  40.2 Mbits/sec
[  4]  50.00-51.00  sec  4.65 MBytes  39.0 Mbits/sec
[  4]  51.00-52.00  sec  4.69 MBytes  39.4 Mbits/sec
[  4]  52.00-53.00  sec  4.54 MBytes  38.1 Mbits/sec
[  4]  53.00-54.00  sec  4.90 MBytes  41.1 Mbits/sec
[  4]  54.00-55.00  sec  4.30 MBytes  36.1 Mbits/sec
[  4]  55.00-56.00  sec  2.28 MBytes  19.1 Mbits/sec
[  4]  56.00-57.00  sec  2.97 MBytes  24.9 Mbits/sec
[  4]  57.00-58.00  sec  4.66 MBytes  39.1 Mbits/sec
[  4]  58.00-59.00  sec  4.56 MBytes  38.3 Mbits/sec
[  4]  59.00-60.00  sec  4.54 MBytes  38.1 Mbits/sec
[  4]  60.00-61.00  sec  4.73 MBytes  39.7 Mbits/sec
[  4]  61.00-62.00  sec  4.75 MBytes  39.9 Mbits/sec
[  4]  62.00-63.00  sec  4.80 MBytes  40.2 Mbits/sec
[  4]  63.00-64.00  sec  4.58 MBytes  38.4 Mbits/sec
[  4]  64.00-65.00  sec  4.71 MBytes  39.5 Mbits/sec
[  4]  65.00-66.00  sec  4.80 MBytes  40.3 Mbits/sec
[  4]  66.00-67.00  sec  4.53 MBytes  38.0 Mbits/sec
[  4]  67.00-68.00  sec  4.91 MBytes  41.2 Mbits/sec
[  4]  68.00-69.00  sec  4.80 MBytes  40.2 Mbits/sec
[  4]  69.00-70.00  sec  4.99 MBytes  41.8 Mbits/sec
[  4]  70.00-71.00  sec  4.65 MBytes  39.0 Mbits/sec
[  4]  71.00-72.00  sec  4.43 MBytes  37.2 Mbits/sec
[  4]  72.00-73.00  sec  5.03 MBytes  42.2 Mbits/sec
[  4]  73.00-74.00  sec  4.70 MBytes  39.4 Mbits/sec
[  4]  74.00-75.00  sec  4.48 MBytes  37.5 Mbits/sec
[  4]  75.00-76.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  76.00-77.00  sec  4.81 MBytes  40.3 Mbits/sec
[  4]  77.00-78.00  sec  4.87 MBytes  40.9 Mbits/sec
[  4]  78.00-79.00  sec  4.85 MBytes  40.7 Mbits/sec
[  4]  79.00-80.00  sec  4.78 MBytes  40.1 Mbits/sec
[  4]  80.00-81.00  sec  1.66 MBytes  13.9 Mbits/sec
[  4]  81.00-82.00  sec  4.55 MBytes  38.2 Mbits/sec
[  4]  82.00-83.00  sec  4.16 MBytes  34.9 Mbits/sec
[  4]  83.00-84.00  sec  4.20 MBytes  35.3 Mbits/sec
[  4]  85.00-86.00  sec  4.87 MBytes  40.8 Mbits/sec
[  4]  86.00-87.00  sec  3.59 MBytes  30.1 Mbits/sec
[  4]  87.00-88.00  sec  4.46 MBytes  37.4 Mbits/sec
[  4]  88.00-89.00  sec  4.49 MBytes  37.6 Mbits/sec
[  4]  89.00-90.00  sec  4.53 MBytes  38.0 Mbits/sec
[  4]  90.00-91.00  sec  4.54 MBytes  38.1 Mbits/sec
[  4]  91.00-92.00  sec  4.59 MBytes  38.5 Mbits/sec
[  4]  92.00-93.00  sec  4.38 MBytes  36.7 Mbits/sec
[  4]  93.00-94.00  sec  4.74 MBytes  39.8 Mbits/sec
[  4]  94.00-95.00  sec  4.67 MBytes  39.2 Mbits/sec
[  4]  95.00-96.00  sec  4.70 MBytes  39.5 Mbits/sec
[  4]  96.00-97.00  sec  4.61 MBytes  38.7 Mbits/sec
[  4]  97.00-98.00  sec  4.89 MBytes  41.0 Mbits/sec
[  4]  98.00-99.00  sec  4.62 MBytes  38.8 Mbits/sec
[  4]  99.00-100.00 sec  4.87 MBytes  40.8 Mbits/sec
[  4] 100.00-101.00 sec  4.11 MBytes  34.5 Mbits/sec
[  4] 101.00-102.00 sec  4.76 MBytes  39.9 Mbits/sec
[  4] 102.00-103.00 sec  4.60 MBytes  38.6 Mbits/sec
[  4] 103.00-104.00 sec  4.61 MBytes  38.7 Mbits/sec
[  4] 104.00-105.00 sec  3.32 MBytes  27.8 Mbits/sec
[  4] 105.00-106.00 sec  4.36 MBytes  36.6 Mbits/sec
[  4] 106.00-107.00 sec  4.89 MBytes  41.0 Mbits/sec
[  4] 107.00-108.00 sec  4.92 MBytes  41.2 Mbits/sec
[  4] 108.00-109.00 sec  4.70 MBytes  39.4 Mbits/sec
[  4] 109.00-110.00 sec  4.49 MBytes  37.7 Mbits/sec
[  4] 110.00-111.00 sec  4.67 MBytes  39.2 Mbits/sec
[  4] 111.00-112.00 sec  4.76 MBytes  39.9 Mbits/sec
[  4] 112.00-113.00 sec  4.75 MBytes  39.9 Mbits/sec
[  4] 113.00-114.00 sec  4.86 MBytes  40.7 Mbits/sec
[  4] 114.00-115.00 sec  4.44 MBytes  37.2 Mbits/sec
[  4] 115.00-116.00 sec  4.57 MBytes  38.3 Mbits/sec
[  4] 116.00-117.00 sec  4.64 MBytes  38.9 Mbits/sec
[  4] 117.00-118.00 sec  4.74 MBytes  39.8 Mbits/sec
[  4] 118.00-119.00 sec  3.12 MBytes  26.2 Mbits/sec
[  4] 119.00-120.00 sec  4.90 MBytes  41.1 Mbits/sec
[  4]   0.00-120.00 sec   549 MBytes  38.4 Mbits/sec  3025             sender
[  4]   0.00-120.00 sec   547 MBytes  38.2 Mbits/sec                  receiver
iperf Done.
root@raspberrypi:/home/pi# ping 192.168.83.146
PING 192.168.83.146 (192.168.83.146) 56(84) bytes of data.
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=2.86 ms
64 bytes from 192.168.83.146: icmp_seq=2 ttl=64 time=5.16 ms
64 bytes from 192.168.83.146: icmp_seq=3 ttl=64 time=5.33 ms
64 bytes from 192.168.83.146: icmp_seq=4 ttl=64 time=5.54 ms
64 bytes from 192.168.83.146: icmp_seq=5 ttl=64 time=6.41 ms
64 bytes from 192.168.83.146: icmp_seq=6 ttl=64 time=4.80 ms
64 bytes from 192.168.83.146: icmp_seq=7 ttl=64 time=4.77 ms
64 bytes from 192.168.83.146: icmp_seq=8 ttl=64 time=6.14 ms
64 bytes from 192.168.83.146: icmp_seq=9 ttl=64 time=7.45 ms
^C
--- 192.168.83.146 ping statistics ---
9 packets transmitted, 9 received, 0% packet loss, time 8012ms
rtt min/avg/max/mdev = 2.861/5.387/7.450/1.206 ms
root@raspberrypi:/home/pi# ^C
root@raspberrypi:/home/pi# iwconfig wlan0
wlan0     IEEE 802.11  ESSID:"Snort-Honeynet"
          Mode:Managed  Frequency:2.472 GHz  Access Point: BC:05:43:BE:C1:E7
          Bit Rate=65 Mb/s   Tx-Power=31 dBm
          Retry short limit:7   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:on
          Link Quality=70/70  Signal level=-37 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
root@raspberrypi:/home/pi# nmcli dev wifi list
*  SSID                     MODUS  CHAN  RATE       SIGNAL  BARS  SICHERHEIT
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  79      ▂▄▆_  WPA1 WPA2
   EasyBox-116D28           Infra  5     54 Mbit/s  55      ▂▄__  WPA1 WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  47      ▂▄__  WPA1 WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  35      ▂▄__  WPA1 WPA2
   CubaLibre                Infra  11    54 Mbit/s  32      ▂▄__  WPA2
*  Snort-Honeynet           Infra  13    54 Mbit/s  83      ▂▄▆█  WPA2
   WLAN-341381              Infra  11    54 Mbit/s  17      ▂___  WPA2
   WLAN-872870              Infra  11    54 Mbit/s  22      ▂___  WPA2
   OSAs Gästenetzwerk       Infra  6     54 Mbit/s  15      ▂___  WPA1 WPA2
   OSA Alpenraum intern     Infra  6     54 Mbit/s  14      ▂___  WPA1 WPA2
   FRITZ!Box 7490           Infra  1     54 Mbit/s  19      ▂___  WPA2
   Wonder Woman             Infra  6     54 Mbit/s  10      ▂___  WPA1 WPA2
   UBNT2                    Infra  3     54 Mbit/s  7       ▂___  --
Location 1: 4 meters away, 2 walls in between, wall angle approx. 30°: 10.4Mbits/s on average, a lot of retransmits and already ICMP packet losses.
[  4] local 192.168.83.191 port 58526 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  53.7 KBytes   440 Kbits/sec    8   5.66 KBytes
[  4]   1.00-2.00   sec  0.00 Bytes  0.00 bits/sec    1   1.41 KBytes
[  4]   2.00-3.00   sec   740 KBytes  6.06 Mbits/sec   25   28.3 KBytes
[  4]   3.00-4.00   sec   766 KBytes  6.28 Mbits/sec    5   28.3 KBytes
[  4]   4.00-5.00   sec   718 KBytes  5.88 Mbits/sec   13   7.07 KBytes
[  4]   5.00-6.00   sec   735 KBytes  6.02 Mbits/sec   34   7.07 KBytes
[  4]   6.00-7.00   sec  1007 KBytes  8.25 Mbits/sec   11   18.4 KBytes
[  4]   7.00-8.00   sec  1.64 MBytes  13.7 Mbits/sec   23   17.0 KBytes
[  4]   8.00-9.00   sec   286 KBytes  2.34 Mbits/sec   10   15.6 KBytes
[  4]   9.00-10.00  sec   404 KBytes  3.31 Mbits/sec    2   17.0 KBytes
[  4]  10.00-11.00  sec   378 KBytes  3.09 Mbits/sec   11   18.4 KBytes
[  4]  11.00-12.00  sec   841 KBytes  6.89 Mbits/sec    2   35.4 KBytes
[  4]  12.00-13.00  sec  1.19 MBytes  10.0 Mbits/sec    0   56.6 KBytes
[  4]  13.00-14.00  sec  1.51 MBytes  12.6 Mbits/sec   19   33.9 KBytes
[  4]  14.00-15.00  sec  1.42 MBytes  11.9 Mbits/sec   13   35.4 KBytes
[  4]  15.00-16.00  sec  1.44 MBytes  12.0 Mbits/sec   13   36.8 KBytes
[  4]  16.00-17.00  sec  1.49 MBytes  12.5 Mbits/sec    4   52.3 KBytes
[  4]  17.00-18.00  sec  1.50 MBytes  12.6 Mbits/sec    0   69.3 KBytes
[  4]  18.00-19.00  sec  1.36 MBytes  11.4 Mbits/sec   14   29.7 KBytes
[  4]  19.00-20.00  sec   387 KBytes  3.17 Mbits/sec   15   15.6 KBytes
[  4]  20.00-21.00  sec  1.02 MBytes  8.58 Mbits/sec   14   19.8 KBytes
[  4]  21.00-22.00  sec   154 KBytes  1.26 Mbits/sec   18   11.3 KBytes
[  4]  22.00-23.00  sec   266 KBytes  2.18 Mbits/sec   10   7.07 KBytes
[  4]  23.00-24.00  sec   956 KBytes  7.84 Mbits/sec   11   15.6 KBytes
[  4]  24.00-25.00  sec   897 KBytes  7.34 Mbits/sec   10   21.2 KBytes
[  4]  25.00-26.00  sec   655 KBytes  5.36 Mbits/sec   12   9.90 KBytes
[  4]  26.00-27.00  sec   928 KBytes  7.60 Mbits/sec   16   1.41 KBytes
[  4]  27.00-28.00  sec   314 KBytes  2.57 Mbits/sec   20   11.3 KBytes
[  4]  28.00-29.00  sec  0.00 Bytes  0.00 bits/sec    9   1.41 KBytes
[  4]  29.00-30.00  sec  1.26 MBytes  10.6 Mbits/sec    7   39.6 KBytes
[  4]  30.00-31.00  sec  1.43 MBytes  12.0 Mbits/sec    2   39.6 KBytes
[  4]  31.00-32.00  sec  1.25 MBytes  10.5 Mbits/sec   21   15.6 KBytes
[  4]  32.00-33.00  sec  1001 KBytes  8.20 Mbits/sec    3   38.2 KBytes
[  4]  33.00-34.00  sec  1.03 MBytes  8.64 Mbits/sec    5   29.7 KBytes
[  4]  34.00-35.00  sec   321 KBytes  2.63 Mbits/sec   19   15.6 KBytes
[  4]  35.00-36.00  sec   588 KBytes  4.82 Mbits/sec   10   19.8 KBytes
[  4]  36.00-37.00  sec   809 KBytes  6.62 Mbits/sec   17   14.1 KBytes
[  4]  37.00-38.00  sec  1.47 MBytes  12.4 Mbits/sec   13   26.9 KBytes
[  4]  38.00-39.00  sec   861 KBytes  7.05 Mbits/sec   21   22.6 KBytes
[  4]  39.00-40.00  sec   846 KBytes  6.93 Mbits/sec   15   32.5 KBytes
[  4]  40.00-41.00  sec  1.44 MBytes  12.1 Mbits/sec    0   56.6 KBytes
[  4]  41.00-42.00  sec   626 KBytes  5.13 Mbits/sec   21   36.8 KBytes
[  4]  42.00-43.00  sec  1.62 MBytes  13.6 Mbits/sec   24   32.5 KBytes
[  4]  43.00-44.00  sec   693 KBytes  5.68 Mbits/sec   35   17.0 KBytes
[  4]  44.00-45.00  sec  1.51 MBytes  12.7 Mbits/sec   14   32.5 KBytes
[  4]  45.00-46.00  sec  1.58 MBytes  13.2 Mbits/sec   15   39.6 KBytes
[  4]  46.00-47.00  sec  1.68 MBytes  14.1 Mbits/sec   35   14.1 KBytes
[  4]  47.00-48.00  sec  1.09 MBytes  9.15 Mbits/sec   15   1.41 KBytes
[  4]  48.00-49.00  sec   471 KBytes  3.86 Mbits/sec    8   21.2 KBytes
[  4]  49.00-50.00  sec   163 KBytes  1.33 Mbits/sec   15   1.41 KBytes
[  4]  50.00-51.00  sec   570 KBytes  4.67 Mbits/sec   13   18.4 KBytes
[  4]  51.00-52.00  sec   585 KBytes  4.80 Mbits/sec    7   22.6 KBytes
[  4]  52.00-53.00  sec   257 KBytes  2.11 Mbits/sec   10   15.6 KBytes
[  4]  53.00-54.00  sec   474 KBytes  3.88 Mbits/sec   16   9.90 KBytes
[  4]  54.00-55.00  sec   156 KBytes  1.27 Mbits/sec   13   8.48 KBytes
[  4]  55.00-56.00  sec   591 KBytes  4.84 Mbits/sec   13   1.41 KBytes
[  4]  56.00-57.00  sec  1.87 MBytes  15.7 Mbits/sec   17   26.9 KBytes
[  4]  57.00-58.00  sec   209 KBytes  1.71 Mbits/sec   10   7.07 KBytes
[  4]  58.00-59.00  sec  1.33 MBytes  11.2 Mbits/sec   24   24.0 KBytes
[  4]  59.00-60.00  sec  1.73 MBytes  14.5 Mbits/sec   20   21.2 KBytes
[  4]  60.00-61.00  sec  2.06 MBytes  17.3 Mbits/sec   17   29.7 KBytes
[  4]  61.00-62.00  sec  2.01 MBytes  16.8 Mbits/sec   30   24.0 KBytes
[  4]  62.00-63.00  sec   608 KBytes  4.98 Mbits/sec   10   29.7 KBytes
[  4]  63.00-64.00  sec  52.3 KBytes   428 Kbits/sec   10   2.83 KBytes
[  4]  64.00-65.00  sec   742 KBytes  6.09 Mbits/sec   22   25.5 KBytes
[  4]  65.00-66.00  sec  1.11 MBytes  9.29 Mbits/sec   28   22.6 KBytes
[  4]  66.00-67.00  sec  2.01 MBytes  16.8 Mbits/sec   20   22.6 KBytes
[  4]  67.00-68.00  sec   592 KBytes  4.85 Mbits/sec   14   8.48 KBytes
[  4]  68.00-69.00  sec   153 KBytes  1.25 Mbits/sec    4   1.41 KBytes
[  4]  69.00-70.00  sec   209 KBytes  1.72 Mbits/sec   13   11.3 KBytes
[  4]  70.00-71.00  sec  1004 KBytes  8.23 Mbits/sec    0   60.8 KBytes
[  4]  71.00-72.00  sec  1.27 MBytes  10.7 Mbits/sec    0   94.7 KBytes
[  4]  72.00-73.00  sec  1.93 MBytes  16.2 Mbits/sec   14   31.1 KBytes
[  4]  73.00-74.00  sec  1.57 MBytes  13.2 Mbits/sec   11   36.8 KBytes
[  4]  74.00-75.00  sec  1.62 MBytes  13.6 Mbits/sec   12   24.0 KBytes
[  4]  75.00-76.00  sec  65.0 KBytes   533 Kbits/sec    2   2.83 KBytes
[  4]  76.00-77.00  sec  0.00 Bytes  0.00 bits/sec    1   1.41 KBytes
[  4]  77.00-78.00  sec  0.00 Bytes  0.00 bits/sec    1   1.41 KBytes
[  4]  78.00-79.00  sec   547 KBytes  4.49 Mbits/sec   19   21.2 KBytes
[  4]  79.00-80.00  sec  1008 KBytes  8.26 Mbits/sec   20   24.0 KBytes
[  4]  80.00-81.00  sec  1.26 MBytes  10.6 Mbits/sec   22   21.2 KBytes
[  4]  81.00-82.00  sec   284 KBytes  2.33 Mbits/sec    5   19.8 KBytes
[  4]  82.00-83.00  sec   741 KBytes  6.07 Mbits/sec    9   1.41 KBytes
[  4]  83.00-84.00  sec   892 KBytes  7.31 Mbits/sec   10   41.0 KBytes
[  4]  84.00-85.00  sec  1.05 MBytes  8.82 Mbits/sec    0   56.6 KBytes
[  4]  85.00-86.00  sec   810 KBytes  6.64 Mbits/sec   27   14.1 KBytes
[  4]  86.00-87.00  sec   670 KBytes  5.49 Mbits/sec    8   29.7 KBytes
[  4]  87.00-88.00  sec  1.11 MBytes  9.28 Mbits/sec    0   49.5 KBytes
[  4]  88.00-89.00  sec  1.44 MBytes  12.1 Mbits/sec    4   49.5 KBytes
[  4]  89.00-90.00  sec  1.55 MBytes  13.0 Mbits/sec    0   67.9 KBytes
[  4]  90.00-91.00  sec  1.45 MBytes  12.2 Mbits/sec   16   25.5 KBytes
[  4]  91.00-92.00  sec   338 KBytes  2.77 Mbits/sec   15   8.48 KBytes
[  4]  92.00-93.00  sec  1018 KBytes  8.34 Mbits/sec   23   24.0 KBytes
[  4]  93.00-94.00  sec   906 KBytes  7.43 Mbits/sec   16   12.7 KBytes
[  4]  94.00-95.00  sec  1.00 MBytes  8.41 Mbits/sec    0   41.0 KBytes
[  4]  95.00-96.00  sec  1.05 MBytes  8.80 Mbits/sec    8   2.83 KBytes
[  4]  96.00-97.00  sec   930 KBytes  7.62 Mbits/sec   26   25.5 KBytes
[  4]  97.00-98.00  sec  1.07 MBytes  8.99 Mbits/sec    8   29.7 KBytes
[  4]  98.00-99.00  sec  1011 KBytes  8.28 Mbits/sec   10   21.2 KBytes
[  4]  99.00-100.00 sec   621 KBytes  5.08 Mbits/sec   11   17.0 KBytes
[  4] 100.00-101.00 sec  1.06 MBytes  8.88 Mbits/sec    1   41.0 KBytes
[  4] 101.00-102.00 sec   870 KBytes  7.12 Mbits/sec   19   1.41 KBytes
[  4] 102.00-103.00 sec   850 KBytes  6.96 Mbits/sec   13   28.3 KBytes
[  4] 103.00-104.00 sec   290 KBytes  2.37 Mbits/sec    6   17.0 KBytes
[  4] 104.00-105.00 sec  0.00 Bytes  0.00 bits/sec    3   8.48 KBytes
[  4] 105.00-106.00 sec   468 KBytes  3.84 Mbits/sec   10   12.7 KBytes
[  4] 106.00-107.00 sec  1.13 MBytes  9.49 Mbits/sec   14   25.5 KBytes
[  4] 107.00-108.00 sec   294 KBytes  2.41 Mbits/sec   13   12.7 KBytes
[  4] 108.00-109.00 sec   263 KBytes  2.15 Mbits/sec   17   11.3 KBytes
[  4] 109.00-110.00 sec   536 KBytes  4.39 Mbits/sec   10   22.6 KBytes
[  4] 110.00-111.00 sec   406 KBytes  3.32 Mbits/sec   11   8.48 KBytes
[  4] 111.00-112.00 sec   198 KBytes  1.62 Mbits/sec    3   15.6 KBytes
[  4] 112.00-113.00 sec   602 KBytes  4.94 Mbits/sec   13   17.0 KBytes
[  4] 113.00-114.00 sec  1.63 MBytes  13.7 Mbits/sec   22   31.1 KBytes
[  4] 114.00-115.00 sec   214 KBytes  1.75 Mbits/sec    8   1.41 KBytes
[  4] 115.00-116.00 sec   133 KBytes  1.09 Mbits/sec   26   7.07 KBytes
[  4] 116.00-117.00 sec   655 KBytes  5.37 Mbits/sec    1   29.7 KBytes
[  4] 117.00-118.00 sec  1.09 MBytes  9.13 Mbits/sec    0   50.9 KBytes
[  4] 118.00-119.00 sec   861 KBytes  7.05 Mbits/sec    0   60.8 KBytes
[  4] 119.00-120.00 sec   930 KBytes  7.62 Mbits/sec    0   70.7 KBytes
[  4]   0.00-120.00 sec   102 MBytes  7.12 Mbits/sec  1457             sender
[  4]   0.00-120.00 sec   102 MBytes  7.11 Mbits/sec                  receiver
iperf Done.
[  4] local 192.168.83.191 port 58530 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  1.78 MBytes  14.9 Mbits/sec
[  4]   1.00-2.00   sec  1.13 MBytes  9.44 Mbits/sec
[  4]   2.00-3.00   sec  1.69 MBytes  14.2 Mbits/sec
[  4]   3.00-4.00   sec  1.67 MBytes  14.0 Mbits/sec
[  4]   4.00-5.00   sec  1.71 MBytes  14.3 Mbits/sec
[  4]   5.00-6.00   sec  1.69 MBytes  14.2 Mbits/sec
[  4]   6.00-7.00   sec  1.77 MBytes  14.9 Mbits/sec
[  4]   7.00-8.00   sec  1.79 MBytes  15.0 Mbits/sec
[  4]   8.00-9.00   sec  1.89 MBytes  15.8 Mbits/sec
[  4]   9.00-10.00  sec  1.76 MBytes  14.8 Mbits/sec
[  4]  10.00-11.00  sec  1.74 MBytes  14.6 Mbits/sec
[  4]  11.00-12.00  sec  1.86 MBytes  15.6 Mbits/sec
[  4]  12.00-13.00  sec  1.46 MBytes  12.2 Mbits/sec
[  4]  13.00-14.00  sec  1.71 MBytes  14.3 Mbits/sec
[  4]  14.00-15.00  sec  1.89 MBytes  15.9 Mbits/sec
[  4]  15.00-16.00  sec  1.75 MBytes  14.7 Mbits/sec
[  4]  16.00-17.00  sec  1.85 MBytes  15.5 Mbits/sec
[  4]  17.00-18.00  sec  1.79 MBytes  15.0 Mbits/sec
[  4]  18.00-19.00  sec  1.16 MBytes  9.70 Mbits/sec
[  4]  19.00-20.00  sec  1.89 MBytes  15.8 Mbits/sec
[  4]  20.00-21.00  sec  1.84 MBytes  15.4 Mbits/sec
[  4]  21.00-22.00  sec  1.99 MBytes  16.7 Mbits/sec
[  4]  22.00-23.00  sec  1.87 MBytes  15.7 Mbits/sec
[  4]  23.00-24.00  sec  1.93 MBytes  16.2 Mbits/sec
[  4]  24.00-25.00  sec  1.80 MBytes  15.1 Mbits/sec
[  4]  25.00-26.00  sec  1.94 MBytes  16.3 Mbits/sec
[  4]  26.00-27.00  sec  1.82 MBytes  15.2 Mbits/sec
[  4]  27.00-28.00  sec  1.91 MBytes  16.0 Mbits/sec
[  4]  28.00-29.00  sec  1.96 MBytes  16.4 Mbits/sec
[  4]  29.00-30.00  sec   314 KBytes  2.57 Mbits/sec
[  4]  30.00-31.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  31.00-32.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  32.00-33.00  sec  1.31 MBytes  11.0 Mbits/sec
[  4]  33.00-34.00  sec   602 KBytes  4.93 Mbits/sec
[  4]  34.00-35.00  sec  1.74 MBytes  14.6 Mbits/sec
[  4]  35.00-36.00  sec  1.92 MBytes  16.1 Mbits/sec
[  4]  36.00-37.00  sec  1.88 MBytes  15.8 Mbits/sec
[  4]  37.00-38.00  sec  1.96 MBytes  16.4 Mbits/sec
[  4]  38.00-39.00  sec  1.82 MBytes  15.3 Mbits/sec
[  4]  39.00-40.00  sec  1.80 MBytes  15.1 Mbits/sec
[  4]  40.00-41.00  sec  1.74 MBytes  14.6 Mbits/sec
[  4]  41.00-42.00  sec  1.99 MBytes  16.7 Mbits/sec
[  4]  42.00-43.00  sec  1.86 MBytes  15.6 Mbits/sec
[  4]  43.00-44.00  sec  1.90 MBytes  15.9 Mbits/sec
[  4]  44.00-45.00  sec  1.83 MBytes  15.3 Mbits/sec
[  4]  45.00-46.00  sec  1.86 MBytes  15.6 Mbits/sec
[  4]  46.00-47.00  sec  1.80 MBytes  15.1 Mbits/sec
[  4]  47.00-48.00  sec  1.90 MBytes  16.0 Mbits/sec
[  4]  48.00-49.00  sec  1.82 MBytes  15.3 Mbits/sec
[  4]  49.00-50.00  sec  1.19 MBytes  10.0 Mbits/sec
[  4]  50.00-51.00  sec  1.27 MBytes  10.7 Mbits/sec
[  4]  51.00-52.00  sec  1.81 MBytes  15.2 Mbits/sec
[  4]  52.00-53.00  sec  1.77 MBytes  14.9 Mbits/sec
[  4]  53.00-54.00  sec  1.84 MBytes  15.4 Mbits/sec
[  4]  54.00-55.00  sec  1.07 MBytes  8.95 Mbits/sec
[  4]  55.00-56.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  56.00-57.00  sec  1.80 MBytes  15.1 Mbits/sec
[  4]  57.00-58.00  sec  1.85 MBytes  15.5 Mbits/sec
[  4]  58.00-59.00  sec  1.84 MBytes  15.5 Mbits/sec
[  4]  59.00-60.00  sec  1.91 MBytes  16.0 Mbits/sec
[  4]  60.00-61.00  sec  1.79 MBytes  15.0 Mbits/sec
[  4]  61.00-62.00  sec  1.82 MBytes  15.3 Mbits/sec
[  4]  62.00-63.00  sec   851 KBytes  6.97 Mbits/sec
[  4]  63.00-64.00  sec  1.17 MBytes  9.83 Mbits/sec
[  4]  64.00-65.00  sec  1.92 MBytes  16.1 Mbits/sec
[  4]  65.00-66.00  sec  1.84 MBytes  15.4 Mbits/sec
[  4]  66.00-67.00  sec  1.81 MBytes  15.2 Mbits/sec
[  4]  67.00-68.00  sec  1.86 MBytes  15.6 Mbits/sec
[  4]  68.00-69.00  sec  1.84 MBytes  15.4 Mbits/sec
[  4]  69.00-70.00  sec  1.92 MBytes  16.1 Mbits/sec
[  4]  70.00-71.00  sec   983 KBytes  8.05 Mbits/sec
[  4]  71.00-72.00  sec  1.40 MBytes  11.8 Mbits/sec
[  4]  72.00-73.00  sec  1.63 MBytes  13.7 Mbits/sec
[  4]  73.00-74.00  sec  1.80 MBytes  15.1 Mbits/sec
[  4]  74.00-75.00  sec  1.97 MBytes  16.5 Mbits/sec
[  4]  75.00-76.00  sec  1.69 MBytes  14.2 Mbits/sec
[  4]  76.00-77.00  sec  1.80 MBytes  15.1 Mbits/sec
[  4]  77.00-78.00  sec   540 KBytes  4.42 Mbits/sec
[  4]  78.00-79.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  79.00-80.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  80.00-81.00  sec  1.73 MBytes  14.5 Mbits/sec
[  4]  81.00-82.00  sec  1.31 MBytes  11.0 Mbits/sec
[  4]  82.00-83.00  sec  1.78 MBytes  14.9 Mbits/sec
[  4]  83.00-84.00  sec  1.84 MBytes  15.5 Mbits/sec
[  4]  84.00-85.00  sec  1.81 MBytes  15.2 Mbits/sec
[  4]  85.00-86.00  sec  1.74 MBytes  14.6 Mbits/sec
[  4]  86.00-87.00  sec  1.73 MBytes  14.5 Mbits/sec
[  4]  87.00-88.00  sec  1.80 MBytes  15.1 Mbits/sec
[  4]  88.00-89.00  sec  1.65 MBytes  13.8 Mbits/sec
[  4]  89.00-90.00  sec  1.81 MBytes  15.2 Mbits/sec
[  4]  90.00-91.00  sec  1.78 MBytes  15.0 Mbits/sec
[  4]  91.00-92.00  sec  1.91 MBytes  16.0 Mbits/sec
[  4]  92.00-93.00  sec  1.84 MBytes  15.5 Mbits/sec
[  4]  93.00-94.00  sec  1.72 MBytes  14.4 Mbits/sec
[  4]  94.00-95.00  sec  1.82 MBytes  15.3 Mbits/sec
[  4]  95.00-96.00  sec  1.32 MBytes  11.1 Mbits/sec
[  4]  96.00-97.00  sec  1.08 MBytes  9.06 Mbits/sec
[  4]  97.00-98.00  sec  1.58 MBytes  13.3 Mbits/sec
[  4]  98.00-99.00  sec  1.21 MBytes  10.2 Mbits/sec
[  4]  99.00-100.00 sec  1.29 MBytes  10.8 Mbits/sec
[  4] 100.00-101.00 sec  1.21 MBytes  10.1 Mbits/sec
[  4] 101.00-102.00 sec  1.44 MBytes  12.1 Mbits/sec
[  4] 102.00-103.00 sec  1.68 MBytes  14.1 Mbits/sec
[  4] 103.00-104.00 sec  1.56 MBytes  13.1 Mbits/sec
[  4] 104.00-105.00 sec  1.38 MBytes  11.6 Mbits/sec
[  4] 105.00-106.00 sec  1.86 MBytes  15.6 Mbits/sec
[  4] 106.00-107.00 sec  1.81 MBytes  15.2 Mbits/sec
[  4] 107.00-108.00 sec  1.76 MBytes  14.8 Mbits/sec
[  4] 108.00-109.00 sec  1.89 MBytes  15.9 Mbits/sec
[  4] 109.00-110.00 sec   809 KBytes  6.62 Mbits/sec
[  4] 110.00-111.00 sec  2.42 MBytes  20.3 Mbits/sec
[  4] 111.00-112.00 sec  1.70 MBytes  14.3 Mbits/sec
[  4] 112.00-113.00 sec  1.78 MBytes  15.0 Mbits/sec
[  4] 113.00-114.00 sec  1.88 MBytes  15.8 Mbits/sec
[  4] 114.00-115.00 sec  1.44 MBytes  12.1 Mbits/sec
[  4] 115.00-116.00 sec  1.66 MBytes  13.9 Mbits/sec
[  4] 116.00-117.00 sec  1.90 MBytes  15.9 Mbits/sec
[  4] 117.00-118.00 sec  1.82 MBytes  15.3 Mbits/sec
[  4] 118.00-119.00 sec  1.79 MBytes  15.0 Mbits/sec
[  4] 119.00-120.00 sec  1.75 MBytes  14.7 Mbits/sec
[  4]   0.00-120.00 sec   195 MBytes  13.7 Mbits/sec  6386             sender
[  4]   0.00-120.00 sec   193 MBytes  13.5 Mbits/sec                  receiver
iperf Done.
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=2.69 ms
64 bytes from 192.168.83.146: icmp_seq=2 ttl=64 time=5.29 ms
64 bytes from 192.168.83.146: icmp_seq=3 ttl=64 time=12.6 ms
64 bytes from 192.168.83.146: icmp_seq=4 ttl=64 time=5.78 ms
64 bytes from 192.168.83.146: icmp_seq=5 ttl=64 time=6.55 ms
64 bytes from 192.168.83.146: icmp_seq=6 ttl=64 time=5.51 ms
64 bytes from 192.168.83.146: icmp_seq=8 ttl=64 time=440 ms
64 bytes from 192.168.83.146: icmp_seq=9 ttl=64 time=4.98 ms
64 bytes from 192.168.83.146: icmp_seq=10 ttl=64 time=5.09 ms
^C
10 packets transmitted, 9 received, 10% packet loss, time 9065ms
rtt min/avg/max/mdev = 2.691/54.315/440.248/136.471 ms
          Bit Rate=26 Mb/s   Tx-Power=31 dBm
          Encryption key:off
          Power Management:on
          Link Quality=38/70  Signal level=-72 dBm
          Tx excessive retries:2278  Invalid misc:0   Missed beacon:0
   CubaLibre                Infra  11    54 Mbit/s  59      ▂▄▆_  WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  29      ▂___  WPA1 WPA2
   o2-WLAN91                Infra  5     54 Mbit/s  29      ▂___  WPA2
   WLAN-A64344              Infra  1     54 Mbit/s  19      ▂___  WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  24      ▂___  WPA1 WPA2
   Villa Rosina             Infra  3     54 Mbit/s  20      ▂___  WPA1 WPA2
   WLAN-983298              Infra  11    54 Mbit/s  20      ▂___  WPA2
   OSAs Gästenetzwerk       Infra  6     54 Mbit/s  19      ▂___  WPA1 WPA2
   EasyBox-55E358           Infra  1     54 Mbit/s  17      ▂___  WPA1 WPA2
   CubaLibre                Infra  11    54 Mbit/s  25      ▂___  WPA1 WPA2
   WLAN-872870              Infra  11    54 Mbit/s  20      ▂___  WPA2
   Eichkater                Infra  5     54 Mbit/s  19      ▂___  WPA1 WPA2
   FRITZ!Box WLAN 3270      Infra  9     54 Mbit/s  5       ____  WPA1 WPA2
   WLAN-341381              Infra  11    54 Mbit/s  24      ▂___  WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  14      ▂___  WPA1 WPA2
   --                       Infra  6     54 Mbit/s  15      ▂___  WPA2
*  Snort-Honeynet           Infra  13    54 Mbit/s  49      ▂▄__  WPA2
   Schneeflittchen          Infra  5     54 Mbit/s  20      ▂___  WPA1 WPA2
   Telekom_FON              Infra  11    54 Mbit/s  12      ▂___  --
   EasyBox-251239           Infra  1     54 Mbit/s  5       ____  WPA1 WPA2
   almtrieb                 Infra  1     54 Mbit/s  20      ▂___  WPA1 WPA2
   FRITZ!Box 7490           Infra  1     54 Mbit/s  15      ▂___  WPA2
   Monika                   Infra  2     54 Mbit/s  12      ▂___  WPA2
   Talman                   Infra  1     54 Mbit/s  10      ▂___  WPA1 WPA2
   EasyBox-116D28           Infra  5     54 Mbit/s  17      ▂___  WPA1 WPA2
Location 2: 5 meters away, 2 walls in between, different direction compared to prior location: 6Mbits/s on average, a lot of retransmits and working remotely over SSH felt pretty sluggish.
[  4] local 192.168.83.191 port 40324 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec   796 KBytes  6.52 Mbits/sec    0   74.9 KBytes
[  4]   1.00-2.00   sec   778 KBytes  6.37 Mbits/sec    0   93.3 KBytes
[  4]   2.00-3.00   sec   967 KBytes  7.92 Mbits/sec    0    117 KBytes
[  4]   3.00-4.00   sec   710 KBytes  5.82 Mbits/sec    1   94.7 KBytes
[  4]   4.00-5.00   sec   492 KBytes  4.03 Mbits/sec    0    110 KBytes
[  4]   5.00-6.00   sec   665 KBytes  5.44 Mbits/sec    0    119 KBytes
[  4]   6.00-7.00   sec   667 KBytes  5.47 Mbits/sec    0    120 KBytes
[  4]   7.00-8.00   sec   740 KBytes  6.06 Mbits/sec    0    120 KBytes
[  4]   8.00-9.00   sec   839 KBytes  6.87 Mbits/sec    0    122 KBytes
[  4]   9.00-10.00  sec   749 KBytes  6.14 Mbits/sec    0    126 KBytes
[  4]  10.00-11.00  sec   792 KBytes  6.49 Mbits/sec    0    129 KBytes
[  4]  11.00-12.00  sec   817 KBytes  6.70 Mbits/sec    0    163 KBytes
[  4]  12.00-13.00  sec   707 KBytes  5.79 Mbits/sec    0    181 KBytes
[  4]  13.00-14.00  sec   833 KBytes  6.82 Mbits/sec    2    164 KBytes
[  4]  14.00-15.00  sec   609 KBytes  4.99 Mbits/sec    0    177 KBytes
[  4]  15.00-16.00  sec   608 KBytes  4.98 Mbits/sec    0    205 KBytes
[  4]  16.00-17.00  sec   611 KBytes  5.00 Mbits/sec    0    215 KBytes
[  4]  17.00-18.00  sec   814 KBytes  6.67 Mbits/sec    2    164 KBytes
[  4]  18.00-19.00  sec   765 KBytes  6.27 Mbits/sec    0    175 KBytes
[  4]  19.00-20.00  sec   455 KBytes  3.73 Mbits/sec    0    175 KBytes
[  4]  20.00-21.00  sec   607 KBytes  4.97 Mbits/sec    0    181 KBytes
[  4]  21.00-22.00  sec   457 KBytes  3.74 Mbits/sec    0    182 KBytes
[  4]  22.00-23.00  sec   611 KBytes  5.00 Mbits/sec    0    185 KBytes
[  4]  23.00-24.00  sec   764 KBytes  6.26 Mbits/sec    0    191 KBytes
[  4]  24.00-25.00  sec   608 KBytes  4.98 Mbits/sec    6    139 KBytes
[  4]  25.00-26.00  sec   609 KBytes  4.99 Mbits/sec    0    161 KBytes
[  4]  26.00-27.00  sec   607 KBytes  4.97 Mbits/sec    0    181 KBytes
[  4]  27.00-28.00  sec   455 KBytes  3.73 Mbits/sec    0    184 KBytes
[  4]  28.00-29.00  sec   762 KBytes  6.24 Mbits/sec    0    195 KBytes
[  4]  29.00-30.00  sec   513 KBytes  4.20 Mbits/sec   10   96.2 KBytes
[  4]  30.00-31.00  sec   672 KBytes  5.50 Mbits/sec    2   73.5 KBytes
[  4]  31.00-32.00  sec   621 KBytes  5.09 Mbits/sec    0   84.8 KBytes
[  4]  32.00-33.00  sec   778 KBytes  6.37 Mbits/sec    2   66.5 KBytes
[  4]  33.00-34.00  sec   761 KBytes  6.23 Mbits/sec    0   72.1 KBytes
[  4]  34.00-35.00  sec   611 KBytes  5.00 Mbits/sec    0   76.4 KBytes
[  4]  35.00-36.00  sec   612 KBytes  5.02 Mbits/sec    0   82.0 KBytes
[  4]  36.00-37.00  sec   617 KBytes  5.05 Mbits/sec    0   83.4 KBytes
[  4]  37.00-38.00  sec   607 KBytes  4.97 Mbits/sec    0   87.7 KBytes
[  4]  38.00-39.00  sec   458 KBytes  3.75 Mbits/sec    0   93.3 KBytes
[  4]  39.00-40.00  sec   611 KBytes  5.00 Mbits/sec    0    117 KBytes
[  4]  40.00-41.00  sec   608 KBytes  4.98 Mbits/sec    0    158 KBytes
[  4]  41.00-42.00  sec   457 KBytes  3.74 Mbits/sec    0    201 KBytes
[  4]  42.00-43.00  sec   455 KBytes  3.73 Mbits/sec    0    201 KBytes
[  4]  43.00-44.00  sec   694 KBytes  5.69 Mbits/sec    0    331 KBytes
[  4]  44.00-45.00  sec   669 KBytes  5.48 Mbits/sec    4    230 KBytes
[  4]  45.00-46.00  sec   663 KBytes  5.43 Mbits/sec    0    230 KBytes
[  4]  46.00-47.00  sec   665 KBytes  5.44 Mbits/sec    0    230 KBytes
[  4]  47.00-48.00  sec   885 KBytes  7.25 Mbits/sec    0    255 KBytes
[  4]  48.00-49.00  sec   663 KBytes  5.43 Mbits/sec    0    257 KBytes
[  4]  49.00-50.00  sec   443 KBytes  3.62 Mbits/sec    0    257 KBytes
[  4]  50.00-51.00  sec   682 KBytes  5.58 Mbits/sec    0    257 KBytes
[  4]  51.00-52.00  sec   450 KBytes  3.68 Mbits/sec    0    257 KBytes
[  4]  52.00-53.00  sec   443 KBytes  3.63 Mbits/sec    0    257 KBytes
[  4]  53.00-54.00  sec   884 KBytes  7.24 Mbits/sec    0    324 KBytes
[  4]  54.00-55.00  sec   884 KBytes  7.24 Mbits/sec    0    327 KBytes
[  4]  55.00-56.00  sec   670 KBytes  5.49 Mbits/sec    0    327 KBytes
[  4]  56.00-57.00  sec   885 KBytes  7.25 Mbits/sec    0    327 KBytes
[  4]  57.00-58.00  sec   744 KBytes  6.09 Mbits/sec    9    158 KBytes
[  4]  58.00-59.00  sec   884 KBytes  7.24 Mbits/sec    0    165 KBytes
[  4]  59.00-60.00  sec  1.09 MBytes  9.12 Mbits/sec    0    165 KBytes
[  4]  60.00-61.00  sec   665 KBytes  5.44 Mbits/sec    0    165 KBytes
[  4]  61.00-62.00  sec   663 KBytes  5.43 Mbits/sec    0    185 KBytes
[  4]  62.00-63.00  sec   885 KBytes  7.25 Mbits/sec    0    185 KBytes
[  4]  63.00-64.00  sec   665 KBytes  5.44 Mbits/sec    0    192 KBytes
[  4]  64.00-65.00  sec  1.08 MBytes  9.05 Mbits/sec    0    192 KBytes
[  4]  65.00-66.00  sec   677 KBytes  5.55 Mbits/sec    0    209 KBytes
[  4]  66.00-67.00  sec   662 KBytes  5.42 Mbits/sec    0    209 KBytes
[  4]  67.00-68.00  sec   662 KBytes  5.42 Mbits/sec    0    209 KBytes
[  4]  68.00-69.00  sec   455 KBytes  3.73 Mbits/sec    0    209 KBytes
[  4]  69.00-70.00  sec   665 KBytes  5.44 Mbits/sec    0    209 KBytes
[  4]  70.00-71.00  sec   884 KBytes  7.24 Mbits/sec    0    209 KBytes
[  4]  71.00-72.00  sec   889 KBytes  7.29 Mbits/sec    0    209 KBytes
[  4]  72.00-73.00  sec   666 KBytes  5.46 Mbits/sec    0    209 KBytes
[  4]  73.00-74.00  sec   441 KBytes  3.61 Mbits/sec    0    209 KBytes
[  4]  74.00-75.00  sec   666 KBytes  5.46 Mbits/sec    0    327 KBytes
[  4]  75.00-76.00  sec   441 KBytes  3.61 Mbits/sec    0    327 KBytes
[  4]  76.00-77.00  sec   665 KBytes  5.45 Mbits/sec    0    327 KBytes
[  4]  77.00-78.00  sec   665 KBytes  5.44 Mbits/sec    0    327 KBytes
[  4]  78.00-79.00  sec   885 KBytes  7.25 Mbits/sec    0    327 KBytes
[  4]  79.00-80.00  sec   447 KBytes  3.66 Mbits/sec    0    327 KBytes
[  4]  80.00-81.00  sec   885 KBytes  7.25 Mbits/sec    0    327 KBytes
[  4]  81.00-82.00  sec   676 KBytes  5.54 Mbits/sec    6    228 KBytes
[  4]  82.00-83.00  sec   662 KBytes  5.42 Mbits/sec    0    228 KBytes
[  4]  83.00-84.00  sec   889 KBytes  7.29 Mbits/sec    0    228 KBytes
[  4]  84.00-85.00  sec   749 KBytes  6.14 Mbits/sec    9    110 KBytes
[  4]  85.00-86.00  sec   680 KBytes  5.57 Mbits/sec    0    119 KBytes
[  4]  86.00-87.00  sec   682 KBytes  5.58 Mbits/sec    0    120 KBytes
[  4]  87.00-88.00  sec   665 KBytes  5.45 Mbits/sec    0    133 KBytes
[  4]  88.00-89.00  sec   665 KBytes  5.44 Mbits/sec    0    134 KBytes
[  4]  89.00-90.00  sec   884 KBytes  7.24 Mbits/sec    0    134 KBytes
[  4]  90.00-91.00  sec   884 KBytes  7.24 Mbits/sec    0    136 KBytes
[  4]  91.00-92.00  sec   444 KBytes  3.64 Mbits/sec    0    136 KBytes
[  4]  92.00-93.00  sec   663 KBytes  5.43 Mbits/sec    0    136 KBytes
[  4]  93.00-94.00  sec   665 KBytes  5.44 Mbits/sec    0    187 KBytes
[  4]  94.00-95.00  sec  1.08 MBytes  9.09 Mbits/sec    0    187 KBytes
[  4]  95.00-96.00  sec   663 KBytes  5.43 Mbits/sec    0    187 KBytes
[  4]  96.00-97.00  sec   675 KBytes  5.53 Mbits/sec    0    187 KBytes
[  4]  97.00-98.00  sec   468 KBytes  3.83 Mbits/sec    0    187 KBytes
[  4]  98.00-99.00  sec   885 KBytes  7.25 Mbits/sec    0    187 KBytes
[  4]  99.00-100.00 sec   885 KBytes  7.25 Mbits/sec    0    187 KBytes
[  4] 100.00-101.00 sec   892 KBytes  7.31 Mbits/sec    0    212 KBytes
[  4] 101.00-102.00 sec   741 KBytes  6.07 Mbits/sec    2    225 KBytes
[  4] 102.00-103.00 sec   885 KBytes  7.25 Mbits/sec    0    225 KBytes
[  4] 103.00-104.00 sec   884 KBytes  7.24 Mbits/sec    0    225 KBytes
[  4] 104.00-105.00 sec   884 KBytes  7.24 Mbits/sec    0    225 KBytes
[  4] 105.00-106.00 sec  1.08 MBytes  9.07 Mbits/sec    0    291 KBytes
[  4] 106.00-107.00 sec   686 KBytes  5.62 Mbits/sec    2    204 KBytes
[  4] 107.00-108.00 sec   885 KBytes  7.25 Mbits/sec    0    204 KBytes
[  4] 108.00-109.00 sec   665 KBytes  5.44 Mbits/sec    2    151 KBytes
[  4] 109.00-110.00 sec   730 KBytes  5.98 Mbits/sec    2    115 KBytes
[  4] 110.00-111.00 sec   679 KBytes  5.56 Mbits/sec    0    124 KBytes
[  4] 111.00-112.00 sec   902 KBytes  7.39 Mbits/sec    0    127 KBytes
[  4] 112.00-113.00 sec   687 KBytes  5.63 Mbits/sec    0    127 KBytes
[  4] 113.00-114.00 sec   665 KBytes  5.44 Mbits/sec    0    127 KBytes
[  4] 114.00-115.00 sec   673 KBytes  5.51 Mbits/sec    0    127 KBytes
[  4] 115.00-116.00 sec   887 KBytes  7.26 Mbits/sec    1   90.5 KBytes
[  4] 116.00-117.00 sec   723 KBytes  5.92 Mbits/sec    2   50.9 KBytes
[  4] 117.00-118.00 sec   889 KBytes  7.29 Mbits/sec    3   42.4 KBytes
[  4] 118.00-119.00 sec   885 KBytes  7.25 Mbits/sec    2   36.8 KBytes
[  4] 119.00-120.00 sec   665 KBytes  5.44 Mbits/sec    0   49.5 KBytes
[  4]   0.00-120.00 sec  83.1 MBytes  5.81 Mbits/sec   69             sender
[  4]   0.00-120.00 sec  82.7 MBytes  5.78 Mbits/sec                  receiver
iperf Done.
iperf3: error - unable to receive control message: Connection reset by peer
root@raspberrypi:/home/pi# iperf3 -R -c 192.168.83.146 -t 120
[  4] local 192.168.83.191 port 40330 connected to 192.168.83.146 port 5201
[  4]   0.00-1.00   sec  1.01 MBytes  8.50 Mbits/sec
[  4]   1.00-2.00   sec   930 KBytes  7.62 Mbits/sec
[  4]   2.00-3.00   sec   536 KBytes  4.39 Mbits/sec
[  4]   3.00-4.00   sec   642 KBytes  5.26 Mbits/sec
[  4]   4.00-5.00   sec   860 KBytes  7.04 Mbits/sec
[  4]   5.00-6.00   sec   812 KBytes  6.65 Mbits/sec
[  4]   6.00-7.00   sec   662 KBytes  5.42 Mbits/sec
[  4]   7.00-8.00   sec   897 KBytes  7.34 Mbits/sec
[  4]   8.00-9.00   sec   885 KBytes  7.25 Mbits/sec
[  4]   9.00-10.00  sec   713 KBytes  5.84 Mbits/sec
[  4]  10.00-11.00  sec   977 KBytes  8.00 Mbits/sec
[  4]  11.00-12.00  sec   509 KBytes  4.17 Mbits/sec
[  4]  12.00-13.00  sec   744 KBytes  6.10 Mbits/sec
[  4]  13.00-14.00  sec   475 KBytes  3.89 Mbits/sec
[  4]  14.00-15.00  sec   399 KBytes  3.27 Mbits/sec
[  4]  15.00-16.00  sec   984 KBytes  8.06 Mbits/sec
[  4]  16.00-17.00  sec   618 KBytes  5.06 Mbits/sec
[  4]  17.00-18.00  sec   922 KBytes  7.55 Mbits/sec
[  4]  18.00-19.00  sec  1.23 MBytes  10.3 Mbits/sec
[  4]  19.00-20.00  sec   921 KBytes  7.54 Mbits/sec
[  4]  20.00-21.00  sec   454 KBytes  3.72 Mbits/sec
[  4]  21.00-22.00  sec   540 KBytes  4.43 Mbits/sec
[  4]  22.00-23.00  sec   703 KBytes  5.76 Mbits/sec
[  4]  23.00-24.00  sec   508 KBytes  4.16 Mbits/sec
[  4]  24.00-25.00  sec   714 KBytes  5.85 Mbits/sec
[  4]  25.00-26.00  sec   622 KBytes  5.10 Mbits/sec
[  4]  26.00-27.00  sec   829 KBytes  6.79 Mbits/sec
[  4]  27.00-28.00  sec  1014 KBytes  8.31 Mbits/sec
[  4]  28.00-29.00  sec   672 KBytes  5.50 Mbits/sec
[  4]  29.00-30.00  sec  62.2 KBytes   509 Kbits/sec
[  4]  30.00-31.00  sec   889 KBytes  7.29 Mbits/sec
[  4]  32.00-33.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  33.00-34.00  sec   625 KBytes  5.13 Mbits/sec
[  4]  34.00-35.00  sec  1.00 MBytes  8.42 Mbits/sec
[  4]  35.00-36.00  sec  1.11 MBytes  9.29 Mbits/sec
[  4]  36.00-37.00  sec   836 KBytes  6.85 Mbits/sec
[  4]  37.00-38.00  sec   419 KBytes  3.43 Mbits/sec
[  4]  38.00-39.00  sec   491 KBytes  4.02 Mbits/sec
[  4]  39.00-40.00  sec   839 KBytes  6.87 Mbits/sec
[  4]  40.00-41.00  sec  1.02 MBytes  8.57 Mbits/sec
[  4]  41.00-42.00  sec   952 KBytes  7.80 Mbits/sec
[  4]  42.00-43.00  sec  1.05 MBytes  8.84 Mbits/sec
[  4]  43.00-44.00  sec   839 KBytes  6.87 Mbits/sec
[  4]  44.00-45.00  sec   798 KBytes  6.53 Mbits/sec
[  4]  45.00-46.00  sec  1.04 MBytes  8.76 Mbits/sec
[  4]  46.00-47.00  sec   814 KBytes  6.67 Mbits/sec
[  4]  47.00-48.00  sec   673 KBytes  5.51 Mbits/sec
[  4]  48.00-49.00  sec   383 KBytes  3.14 Mbits/sec
[  4]  49.00-50.00  sec   805 KBytes  6.59 Mbits/sec
[  4]  50.00-51.00  sec  31.1 KBytes   255 Kbits/sec
[  4]  51.00-52.00  sec   479 KBytes  3.92 Mbits/sec
[  4]  52.00-53.00  sec   293 KBytes  2.40 Mbits/sec
[  4]  53.00-54.00  sec   263 KBytes  2.15 Mbits/sec
[  4]  54.00-55.00  sec  1.38 MBytes  11.6 Mbits/sec
[  4]  55.00-56.00  sec  1.01 MBytes  8.48 Mbits/sec
[  4]  56.00-57.00  sec   858 KBytes  7.03 Mbits/sec
[  4]  57.00-58.00  sec   911 KBytes  7.46 Mbits/sec
[  4]  58.00-59.00  sec   926 KBytes  7.59 Mbits/sec
[  4]  59.00-60.00  sec  0.00 Bytes  0.00 bits/sec
[  4]  60.00-61.00  sec   943 KBytes  7.73 Mbits/sec
[  4]  61.00-62.00  sec   638 KBytes  5.23 Mbits/sec
[  4]  62.00-63.00  sec   119 KBytes   972 Kbits/sec
[  4]  63.00-64.00  sec  1.06 MBytes  8.94 Mbits/sec
[  4]  64.00-65.00  sec   830 KBytes  6.80 Mbits/sec
[  4]  65.00-66.00  sec  1012 KBytes  8.29 Mbits/sec
[  4]  66.00-67.00  sec  1.06 MBytes  8.87 Mbits/sec
[  4]  67.00-68.00  sec   868 KBytes  7.11 Mbits/sec
[  4]  68.00-69.00  sec   577 KBytes  4.73 Mbits/sec
[  4]  69.00-70.00  sec   949 KBytes  7.77 Mbits/sec
[  4]  70.00-71.00  sec   301 KBytes  2.47 Mbits/sec
[  4]  71.00-72.00  sec   895 KBytes  7.34 Mbits/sec
[  4]  72.00-73.00  sec   370 KBytes  3.03 Mbits/sec
[  4]  73.00-74.00  sec  1.06 MBytes  8.86 Mbits/sec
[  4]  74.00-75.00  sec   973 KBytes  7.97 Mbits/sec
[  4]  75.00-76.00  sec   772 KBytes  6.32 Mbits/sec
[  4]  76.00-77.00  sec   853 KBytes  6.99 Mbits/sec
[  4]  77.00-78.00  sec   877 KBytes  7.18 Mbits/sec
[  4]  78.00-79.00  sec   957 KBytes  7.84 Mbits/sec
[  4]  79.00-80.00  sec   793 KBytes  6.50 Mbits/sec
[  4]  80.00-81.00  sec   591 KBytes  4.84 Mbits/sec
[  4]  81.00-82.00  sec  1.41 KBytes  11.6 Kbits/sec
[  4]  82.00-83.00  sec  1.06 MBytes  8.88 Mbits/sec
[  4]  83.00-84.00  sec  1.28 MBytes  10.8 Mbits/sec
[  4]  84.00-85.00  sec   895 KBytes  7.33 Mbits/sec
[  4]  85.00-86.00  sec   888 KBytes  7.27 Mbits/sec
[  4]  86.00-87.00  sec   749 KBytes  6.14 Mbits/sec
[  4]  87.00-88.00  sec   738 KBytes  6.05 Mbits/sec
[  4]  88.00-89.00  sec   632 KBytes  5.18 Mbits/sec
[  4]  89.00-90.00  sec   764 KBytes  6.26 Mbits/sec
[  4]  90.00-91.00  sec  1.09 MBytes  9.17 Mbits/sec
[  4]  91.00-92.00  sec  1.06 MBytes  8.90 Mbits/sec
[  4]  92.00-93.00  sec   962 KBytes  7.88 Mbits/sec
[  4]  93.00-94.00  sec   932 KBytes  7.63 Mbits/sec
[  4]  94.00-95.00  sec   867 KBytes  7.10 Mbits/sec
[  4]  95.00-96.00  sec   773 KBytes  6.34 Mbits/sec
[  4]  96.00-97.00  sec   747 KBytes  6.12 Mbits/sec
[  4]  97.00-98.00  sec   280 KBytes  2.29 Mbits/sec
[  4]  98.00-99.00  sec   823 KBytes  6.75 Mbits/sec
[  4]  99.00-100.00 sec   748 KBytes  6.13 Mbits/sec
[  4] 100.00-101.00 sec   184 KBytes  1.51 Mbits/sec
[  4] 101.00-102.00 sec  12.7 KBytes   104 Kbits/sec
[  4] 102.00-103.00 sec  1.22 MBytes  10.3 Mbits/sec
[  4] 103.00-104.00 sec   899 KBytes  7.37 Mbits/sec
[  4] 104.00-105.00 sec   602 KBytes  4.94 Mbits/sec
[  4] 105.00-106.00 sec   854 KBytes  7.00 Mbits/sec
[  4] 106.00-107.00 sec   758 KBytes  6.21 Mbits/sec
[  4] 107.00-108.00 sec   713 KBytes  5.84 Mbits/sec
[  4] 108.00-109.00 sec   993 KBytes  8.13 Mbits/sec
[  4] 109.00-110.00 sec   731 KBytes  5.99 Mbits/sec
[  4] 110.00-111.00 sec  1.08 MBytes  9.09 Mbits/sec
[  4] 111.00-112.00 sec   882 KBytes  7.23 Mbits/sec
[  4] 112.00-113.00 sec   693 KBytes  5.68 Mbits/sec
[  4] 113.00-114.00 sec  1011 KBytes  8.28 Mbits/sec
[  4] 114.00-115.00 sec   950 KBytes  7.78 Mbits/sec
[  4] 115.00-116.00 sec   638 KBytes  5.22 Mbits/sec
[  4] 116.00-117.00 sec   854 KBytes  7.00 Mbits/sec
[  4] 117.00-118.00 sec  0.00 Bytes  0.00 bits/sec
[  4] 118.00-119.00 sec  0.00 Bytes  0.00 bits/sec
[  4] 119.00-120.00 sec  0.00 Bytes  0.00 bits/sec
[  4]   0.00-120.00 sec  89.4 MBytes  6.25 Mbits/sec  4027             sender
[  4]   0.00-120.00 sec  86.9 MBytes  6.07 Mbits/sec                  receiver
iperf Done.
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=3.04 ms
64 bytes from 192.168.83.146: icmp_seq=2 ttl=64 time=5.66 ms
64 bytes from 192.168.83.146: icmp_seq=3 ttl=64 time=5.16 ms
64 bytes from 192.168.83.146: icmp_seq=4 ttl=64 time=4.96 ms
64 bytes from 192.168.83.146: icmp_seq=5 ttl=64 time=44.3 ms
64 bytes from 192.168.83.146: icmp_seq=6 ttl=64 time=5.54 ms
64 bytes from 192.168.83.146: icmp_seq=7 ttl=64 time=4.94 ms
64 bytes from 192.168.83.146: icmp_seq=8 ttl=64 time=5.76 ms
64 bytes from 192.168.83.146: icmp_seq=9 ttl=64 time=6.99 ms
64 bytes from 192.168.83.146: icmp_seq=10 ttl=64 time=4.96 ms
10 packets transmitted, 10 received, 0% packet loss, time 9012ms
rtt min/avg/max/mdev = 3.046/9.136/44.311/11.762 ms
^Croot@raspberrypi:/home/piiwconfig wlan0
          Bit Rate=19.5 Mb/s   Tx-Power=31 dBm
          Encryption key:off
          Power Management:on
          Link Quality=34/70  Signal level=-76 dBm
          Tx excessive retries:637  Invalid misc:0   Missed beacon:0
   EasyBox-116D28        Infra  5     54 Mbit/s  60      ▂▄▆_  WPA1 WPA2
   DISTORTEDPEOPLE       Infra  9     54 Mbit/s  45      ▂▄__  WPA1 WPA2
   Wonder Woman          Infra  6     54 Mbit/s  39      ▂▄__  WPA1 WPA2
   FRITZ!Box 7490        Infra  1     54 Mbit/s  29      ▂___  WPA2
   Fallibilismus         Infra  7     54 Mbit/s  22      ▂___  WPA1 WPA2
   DIRECT-1LC460 Series  Infra  10    54 Mbit/s  24      ▂___  WPA2
   o2-WLAN85             Infra  4     54 Mbit/s  20      ▂___  WPA2
   UBNT2                 Infra  3     54 Mbit/s  29      ▂___  --
   --                    Infra  6     54 Mbit/s  25      ▂___  WPA2
*  Snort-Honeynet        Infra  13    54 Mbit/s  45      ▂▄__  WPA2
   WLAN-336972           Infra  6     54 Mbit/s  19      ▂___  WPA2
   Eichkatzenkind        Infra  5     54 Mbit/s  14      ▂___  WPA2
   EasyBox-188632        Infra  10    54 Mbit/s  24      ▂___  WPA1 WPA2
   WLAN-ABD446           Infra  9     54 Mbit/s  15      ▂___  WPA2
   --                    Infra  1     54 Mbit/s  29      ▂___  --
   Hasenhirn01           Infra  1     54 Mbit/s  9       ▂___  WPA2
Now repeating the test with RPi 3 at all 3 locations again. I tested first with powermanagement disabled just to realize that not that much changed. So I decided to write a small script to automatically test through 60 second iperf3 iterations in each direction (TX/RX) with enabled and later disabled powermanagement. This will be repeated 4 times each and end result will simply be used as an average value:
Next to AP:
powermanagement on:  39.22 Mbits/sec
powermanagement off: 39.26 Mbits/sec
4 hours ago (see above): 37.4 Mbits/sec
Location 1:
powermanagement on:  20.17 Mbits/sec
powermanagement off: 22.72 Mbits/sec
4 hours ago (see above): 10.4 Mbits/sec
Location 2:
powermanagement on:  12.14 Mbits/sec
powermanagement off: 11.89 Mbits/sec
4 hours ago (see above): 6 Mbits/sec
So for whatever reasons results do not vary that much depending on powermanagement being enabled or disabled. But the numbers with enabled powermanagement from a few hours ago were a lot lower if tested in remote rooms. I thought what might have been different and two things came to my mind:
  • different board placement affecting efficiency of RPi 3's onboard antenna
  • a DECT handset lying just in between RPi and AP in location 2
So I put the handset back and re-tested:
Location 2 with DECT handset next to RPi 3:
powermanagement on:  12.02 Mbits/sec
powermanagement off: 11.74 Mbits/sec
Obviously other influences are responsible for the drastic change in numbers or powermanagement settings work somehow differently.
Bash script to test this (tested in Raspbian but should work with any recent Armbian installation too):
#!/bin/bash
Test() {
	iwconfig wlan0 power $1
	sleep 5
	iperf3 -c 192.168.83.146 -t 60 | egrep "sender|receiver" >>${tmpdir}/$1.txt
	sleep 5
	iperf3 -R -c 192.168.83.146 -t 60 | egrep "sender|receiver" >>${tmpdir}/$1.txt
	iwconfig wlan0
} # Test
tmpdir=$(mktemp -d /tmp/check-wifi.XXXXXX)
for i in on off on off on off on off ; do
	Test $i
done
unset LANG
on_average=$(awk 'BEGIN {FS = " "} ; {sum+=$7} END {printf ("%0.2f",sum/16)}' ${tmpdir}/on.txt)
off_average=$(awk 'BEGIN {FS = " "} ; {sum+=$7} END {printf ("%0.2f",sum/16)}' ${tmpdir}/off.txt)
echo -e "powermanagement on:  ${on_average} Mbits/sec\npowermanagement off: ${off_average} Mbits/sec\n"
echo -e "powermanagement on:  ${on_average} Mbits/sec"
cat ${tmpdir}/on.txt
echo "powermanagement off: ${off_average} Mbits/sec"
cat ${tmpdir}/off.txt
rm -rf ${tmpdir}
Just to check the above thoughts I tested with the script on OPi Lite again. Only in 'Location 2' where results from yesterday were 23.5 Mbits/sec on average. Now the script reports
powermanagement on:  24.59 Mbits/sec
powermanagement off: 27.04 Mbits/sec
In fact powermanagement can not be enabled with legacy 8189fs driver (see messages below) so the difference is just result variation. And the same can be seen also from script output below since sometimes bandwidth drops down to even just 8.x Mbits/sec. So as expected the environment matters a lot, a single neighbor with a Wi-Fi active on same or nearby channels can ruin bandwidth/performance anytime:
root@orangepilite:~# echo performance > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
root@orangepilite:~# ./test-wifi.sh
Error for wireless request "Set Power Management" (8B2C) :
    SET failed on device wlan0 ; Operation not permitted.
wlan0     IEEE 802.11bgn  ESSID:"Snort-Honeynet"  Nickname:"<WIFI@REALTEK>"
          Bit Rate:65 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Power Management:off
          Link Quality=68/100  Signal level=76/100  Noise level=0/100
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
          Link Quality=67/100  Signal level=76/100  Noise level=0/100
          Link Quality=67/100  Signal level=75/100  Noise level=0/100
          Link Quality=66/100  Signal level=75/100  Noise level=0/100
          Link Quality=66/100  Signal level=76/100  Noise level=0/100
[  4]   0.00-60.00  sec   228 MBytes  31.8 Mbits/sec    5             sender
[  4]   0.00-60.00  sec   226 MBytes  31.6 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   194 MBytes  27.1 Mbits/sec   77             sender
[  4]   0.00-60.00  sec   191 MBytes  26.8 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   243 MBytes  33.9 Mbits/sec    3             sender
[  4]   0.00-60.00  sec   242 MBytes  33.9 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   191 MBytes  26.7 Mbits/sec   65             sender
[  4]   0.00-60.00  sec   189 MBytes  26.4 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   235 MBytes  32.9 Mbits/sec    1             sender
[  4]   0.00-60.00  sec   235 MBytes  32.9 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   177 MBytes  24.8 Mbits/sec   69             sender
[  4]   0.00-60.00  sec   175 MBytes  24.4 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  85.9 MBytes  12.0 Mbits/sec  185             sender
[  4]   0.00-60.00  sec  83.6 MBytes  11.7 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  59.7 MBytes  8.35 Mbits/sec   35             sender
[  4]   0.00-60.00  sec  58.1 MBytes  8.12 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   237 MBytes  33.1 Mbits/sec    4             sender
[  4]   0.00-60.00  sec   236 MBytes  33.0 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   188 MBytes  26.3 Mbits/sec   72             sender
[  4]   0.00-60.00  sec   186 MBytes  25.9 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   242 MBytes  33.8 Mbits/sec    9             sender
[  4]   0.00-60.00  sec   241 MBytes  33.7 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   195 MBytes  27.2 Mbits/sec   71             sender
[  4]   0.00-60.00  sec   192 MBytes  26.8 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   213 MBytes  29.7 Mbits/sec    8             sender
[  4]   0.00-60.00  sec   212 MBytes  29.6 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  62.2 MBytes  8.69 Mbits/sec   40             sender
[  4]   0.00-60.00  sec  59.9 MBytes  8.37 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   234 MBytes  32.7 Mbits/sec    5             sender
[  4]   0.00-60.00  sec   233 MBytes  32.5 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   185 MBytes  25.8 Mbits/sec   62             sender
[  4]   0.00-60.00  sec   182 MBytes  25.5 Mbits/sec                  receiver
Time to stop for today. I got notification from buyzero.de that my Zero W is ready to be shipped so next try is then with new Raspberry Zero's onboard Wi-Fi (according to RPi folks antenna should be better than the one on RPi 3 but to be honest: I don't expect good results in locations 1 and 2 as well since no U.FL connector ready for a real antenna is on the PCB)
Next round of tests in 'location 3' (still 5m away from AP with 2 walls in between, 1 m next to 'location 2' but with less troublesome stuff between devices and AP). I use the script from above to see whether enabling/disabling Wi-Fi powermanagement does change anything (or is possible at all). Obviously enabling/disabling on RPi 3 has no effect (brcmfmac driver), with RTL8189FTV and RTL8192CU is was not possible (same error message from iwconfig: 'Error for wireless request "Set Power Management" (8B2C) : SET failed on device wlan0 ; Operation not permitted.'), only with AP6212 (using legacy kernel dhd module) there were huge differences in performance.
I chose two rounds of tests at different times of the day. The first ran was shortly after midnight and the 2nd run started at 10:00 in the morning. This time I tried to find optimal antenna position but obviously that did not work that great with the TL-WN823N dongle (I have to admit that I slightly changed antenna positions between 1st and 2nd run, also not the best idea).
Software settings remained the same to before (so you can check dmesg output and so on above) and boards were tested one at a time (test execution lasts ~20 minutes which is also bad since environmental conditions between different test runs can change in between since for example the neighbour next to me transfers 15 min large amounts of data in his Wi-Fi interfering with mine and ruining performance in my network)
Results as follows, on the left nightly results as averaged iperf3 throughput numbers followed by those from now.
NanoPi Air, AP6212 module, external small vertical aerial:
powermanagement on:  5.53 / 5.16 Mbits/sec
powermanagement off: 30.14 / 14.66 Mbits/sec
Orange Pi Lite, RTL8189FTV module, external small vertical aerial:
powermanagement on:  30.47 / 32.41 Mbits/sec
powermanagement off: 30.57 / 32.56 Mbits/sec
ODROID-C2 with TP-Link MIMO TL-WN823N dongle, RTL8192CU module, upright position:
powermanagement on:  34.90 / 48.51 Mbits/sec
powermanagement off: 35.34 / 49.27 Mbits/sec
RPi 3, BCM43438 module, onboard antenna oriented obviously properly:
powermanagement on:  35.42 / 25.59 Mbits/sec
powermanagement off: 34.56 / 25.13 Mbits/sec
How to interpret the results?
  • Powermanagement on/off matters at least with AP6212. With the other implementations there was no difference and numbers for on/off are just result variation. Further investigation needed whether it's just not possible adjusting PM settings with iwconfig or if it's not possible at all
  • Environmental conditions matter at lot. Between the two test runs nothing regarding software/settings has changed, it was just different time of the day and slightly moving around antennas/boards. IMO it's already pretty obvious that this sort of 'performance' testing in real-world environments is too stupid to be continued since numbers depend highly on stuff you can't control.
When RPi Zero W arrives I will add it to the test setup and move the whole setup to 'location 4' (will have to ask my neighbour to host the cardboard box with the 5 SBC inside). And then I might rewrite the testing script so that I can test through each board every 60 seconds to minimize external temporary influences.
Also interesting whether performance of TL-WN823N dongle improves when operated horizontally and not upright (Edit: nope). Same with Raspberries and their onboard antenna but here it seems upright position is better (at least when comparing the average 30 Mbits/sec from this test with the results from yesterday with RPi 3 just lying randomly around: 6 and 12 Mbits/sec)
Finally testing 'location 4': 11m away from my AP in neighbour's flat with 3 walls and some chimneys in between.
powermanagement on:  2.38 Mbits/sec
powermanagement off: 3.46 Mbits/sec
powermanagement on:  4.90 Mbits/sec
powermanagement off: 4.49 Mbits/sec
ODROID-C2 with TP-Link MIMO TL-WN823N dongle, RTL8192CU module, horizontal position and antenna oriented towards AP:
powermanagement on:  18.43 Mbits/sec
powermanagement off: 18.99 Mbits/sec
powermanagement on:  3.88 Mbits/sec
powermanagement off: 4.02 Mbits/sec
Some notes:
1) Still 'powermanagement on/off' has no meaning except for NanoPi Air since for the other boards it's just an example for result variation (to remember to never trust any 'benchmark' numbers you find on the net)
2) RPi 3 lost connection to AP in between (automagically re-established by network-manager a few minutes ago). That's the 'valley' left to the middle of this RX/TX graph (green are signals emitted from Fritzbox AP, blue are signals received and 'foreign' signals):
Bildschirmfoto%202017-03-09%20um%2012.08
3) Interestingly the difference between enabled/disabled powermanagement doesn't matter that much any more with AP6212 in this scenario (I guess I'll have to compare ping roundtrip times to get the full picture?)
4) Cheap OPi Lite with RTL8189FTV is the best single antenna performer here. But results differed a lot, there were some periods of time where 60 second average iperf3 numbers exceeded 13 Mbits/sec:
[  4]   0.00-60.00  sec  20.6 MBytes  2.89 Mbits/sec    0             sender
[  4]   0.00-60.00  sec  20.1 MBytes  2.80 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  19.5 MBytes  2.73 Mbits/sec  244             sender
[  4]   0.00-60.00  sec  17.3 MBytes  2.42 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  38.2 MBytes  5.34 Mbits/sec    0             sender
[  4]   0.00-60.00  sec  37.5 MBytes  5.25 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  16.9 MBytes  2.36 Mbits/sec  384             sender
[  4]   0.00-60.00  sec  14.7 MBytes  2.06 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  59.4 MBytes  8.31 Mbits/sec    0             sender
[  4]   0.00-60.00  sec  59.4 MBytes  8.31 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  16.6 MBytes  2.32 Mbits/sec  360             sender
[  4]   0.00-60.00  sec  14.0 MBytes  1.96 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  97.8 MBytes  13.7 Mbits/sec    4             sender
[  4]   0.00-60.00  sec  96.8 MBytes  13.5 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  16.8 MBytes  2.35 Mbits/sec  338             sender
[  4]   0.00-60.00  sec  14.6 MBytes  2.05 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  27.1 MBytes  3.79 Mbits/sec    0             sender
[  4]   0.00-60.00  sec  26.4 MBytes  3.70 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  16.8 MBytes  2.34 Mbits/sec  467             sender
[  4]   0.00-60.00  sec  14.5 MBytes  2.03 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  49.8 MBytes  6.96 Mbits/sec    0             sender
[  4]   0.00-60.00  sec  48.5 MBytes  6.78 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  16.0 MBytes  2.24 Mbits/sec  364             sender
[  4]   0.00-60.00  sec  14.2 MBytes  1.99 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  53.6 MBytes  7.50 Mbits/sec    0             sender
[  4]   0.00-60.00  sec  52.6 MBytes  7.35 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  20.5 MBytes  2.86 Mbits/sec  257             sender
[  4]   0.00-60.00  sec  17.9 MBytes  2.51 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  55.1 MBytes  7.70 Mbits/sec    0             sender
[  4]   0.00-60.00  sec  54.2 MBytes  7.58 Mbits/sec                  receiver
[  4]   0.00-60.00  sec  24.2 MBytes  3.38 Mbits/sec  337             sender
[  4]   0.00-60.00  sec  22.3 MBytes  3.12 Mbits/sec                  receiver
5) The winner is the TL-WN823N USB dongle since... 2x2 MIMO is useable here. Two antennas instead of one greatly improve performance in this scenario. Please note that this requires an 802.11n capable AP that also features at least the same count of antennas!
Edit: As outlined in 3) above I tried to test ping roundtrip times with AP6212 and Wi-Fi powermanagement enabled/disabled. First try from location 4 (neighbour) with active PM and 120 seconds ping:
rtt min/avg/max/mdev = 16.347/102.990/321.107/67.430 ms
Then NanoPi Air disappeared from the net and never reconnected back. So I put the boards back to my home and tried it in 'location 1' with NanoPi Air again. First numbers are with PM on, second off:
rtt min/avg/max/mdev = 3.566/77.707/342.230/44.283 ms
rtt min/avg/max/mdev = 1.902/3.780/32.376/4.540 ms
So obviously for doing anything interactive over Wi-Fi (eg SSH) PM disabled is a great idea (average ping times 4 ms vs. 78 ms!). I tested then with RPi 3 (same Wi-Fi module but here mainline kernel driver and not dhd) with PM on/off. Here only minimum roundtrip times increased with enabled PM but also 5% packet loss occured:
rtt min/avg/max/mdev = 4.682/55.697/409.561/97.636 ms
rtt min/avg/max/mdev = 1.653/59.969/493.176/65.494 ms
And another small update regarding the test setup. AP is a Fritzbox 7390 with latest firmware in a not so ideal location (mounted vertically in a wooden cabinet approx.  50 cm above the floor and 30cm next to another Fritzbox used as DSL modem and DECT basestation). The AP is configured to allow '100%' TX power (but based on the results above I would assume it's trying to play 'green' from time to time). The host all tests are running against is a virtualized Ubuntu running 'iperf3 -s' and the ESXi host is connected through GBit Ethernet to one of the Fritzbox' GBit LAN ports.
The AP is configured to allow 802.11n/g (no 802.11b!) in 2.4GHz band and to choose best channel possible (always 13 since least utilized compared to the other ones):
Bildschirmfoto%202017-03-09%20um%2013.06
So while this is a pretty 'normal'/real-world setup it's also not suited to do reasonable testing. I might need a lab environment where external influences can be minimized or at least controlled (not possible at all here) and a less intelligent AP too. But hey, why bother? Single antenna 2.4GHz Wi-Fi in crowded areas was already known as almost broken before and the few tests just verified well known facts.
From an Armbian (software) point of view we know that drivers/settings for onboard Wi-Fis that can be found on the boards we support seem to fit. Also maximum performance possible is defined by physical limitations (65Mbps bit rate on all boards with single antenna 2.4GHz Wi-Fi define ~40 Mbits/sec with TCP/IP max, theoretically 130Mbps on Lamobo R1 should show better results but reality looks different there). Real-world performance does not depend on driver/settings but obviously on physical/environmental conditions (type/orientation/position of antenna, utilization of Wi-Fi channels due to interference caused by other Wi-Fi devices or  stuff like DECT, microwave ovens, USB3 peripherals near the device/AP)
So what to look into next (real question since I still feel being a Wi-Fi noob):
  • powermanagement settings?
  • TX power settings (regulatory domain stuff, real power available)?
  • recommendations for capable USB dongles that work out of the box (mine does with Armbian)?
  • what did I miss?
In the meantime my Zero W arrived and it took me only 1 hour to set up Raspbian headlessly on the device:
Quick Wi-Fi test made in 'location 1' using the well known script from above (still not showing differences regarding powermanagement since this also has no effect on the Zero W -- it's still just result variation):
RPi 3 (kernel 4.9.13-v7+):
powermanagement on:  23.36 Mbits/sec
powermanagement off: 22.54 Mbits/sec
RPi Zero W (kernel 4.4.50+):
powermanagement on:  28.54 Mbits/sec
powermanagement off: 27.68 Mbits/sec
RPi Zero W (after kernel upgrade to 4.9.13-v7+):
powermanagement on:  24.58 Mbits/sec
powermanagement off: 25.49 Mbits/sec
So throughput is the same or at least not lower (tests done all at different hours so not comparable since uncontrolled environment) and that's also a good reason to not further waste time with RPi tests. To my surprise onboard aerials of both WiFi equipped RPi work quite well but can't overcome 2.4GHz single antenna limitations of course. For some numbers with more antennas, 5GHz too and also 802.11ac see here for example: https://netbeez.net/2016/06/01/iperf-wifi-comparison-on-raspberry-pi-raspberry-pi-3-vs-asus-vs-hawking-vs-linksys-vs-tp-link/
I did some tests with the NEO Air in the recent days, borrowing the antenna from an OPi Zero. Since I experienced some serious lag while typing over ssh, one of the first moves was putting the thing line of sight to the router. This helped a little, but not much.
Now I have been playing with iperf and several different setups. I have a second antenna that came with an OPi One. It's the same model that comes with the Zero, but seemed to double the performance. I saw a jump from 10 MBit/s to 20 MBit/s.
Then I tried putting an old harddisk behind the antenna as as some sort of makeshift reflector (varying the distance as well). In one case it seemed to boost the signal, iperf went from something around 20 MBit/s to 30 MBit/s. Also, placing the HDD between the antenna and the router significantly decreased the signal.
Orienting the antenna differently also had an effect. At one point performance even went down to 1 MBit/s. That's when I realised the u.FL-connector was no longer properly connected.
So here is my takeaway: While they might do the job, OPi's stock antennas may vary in quality. I guess there is no quality check at the end of the assembly line. Also, it is very easy to screw up things. The consumer mindset -- plug it in in and expect it to work flawlessly -- is certainly not the right approach here.
The good news is: To a certain degree you can improve things by optimizing the antenna. I see a bright future for tinfoil reflectors and cantennas. . .
:P
Boring details: There are more than 50 Wifis in the 2,4 GHz band visible at my place, so none of this qualifies as a science experiment. When using iperf, distance to the router was apr. 4 metres through air and a brick wall. Above ratios came from iperf's default mode. Reverse operation (iperf3 -R) makes roughly a +10 MBit/s difference.
Maybe that was just 'casual benchmarking': you benchmark A, but actually measure B, and conclude you've measured C?
I exchanged the cheap Xunlong antenna on OPi Lite now with a much larger one and repeated the 2 tests from above: 50 cm next to the AP througput increased from 41.5 Mbits/sec to 44.8 Mbits/sec (so antenna seems to be 'better') and then I repeated test with 'location 4' at my neighbour's place, 11m away. With Xunlong antenna I got this a few hours ago:
When I tested now again with the larger antenna, numbers were worse. So I decided to repeat the test one more time and then once again. These are the results of these 3 running within one hour:
powermanagement on:  3.27 Mbits/sec
powermanagement off: 3.03 Mbits/sec
powermanagement on:  5.21 Mbits/sec
powermanagement off: 5.71 Mbits/sec
powermanagement on:  8.08 Mbits/sec
powermanagement off: 7.55 Mbits/sec
Nothing I would have under my control changed so we're talking about external influences (maybe his TV set, maybe something else, who knows). 2.4GHz single antenna Wi-Fi is a shit show in crowded areas anyway (I collected here 139 Wi-Fi networks and only 14 of them are in the 5 GHz band) so why bother? But if you're interested in improving things it's a good idea to monitor at least 'iwconfig' output in parallel and always check 'Bit Rate' and the 3 metrics from 'Link Quality' line. Sample output:
          Link Quality=65/100  Signal level=64/100  Noise level=0/100
I already thought about writing a daemon parsing this data together with iperf3 performance numbers to feed into RPi-Monitor but without a controlled environment it's not worth the efforts. If you're looking for Wi-Fi performance forget about onboard, single antenna Wi-Fi in 2.4 GHz band. It's that simple. :)
BTW: At work we consider everything below 100 Mbits/sec as broken. But customers carrying around MacBooks expect wireless to be as fast as wired connections and Apple eases this due to early adoption of new Wi-Fi standards, 5GHz support and putting enough antennas into MacBooks so that MIMO and 'antenna diversity' do work.
Hi
The channel used in the 2.4 GHz band is important.
High speed WIFI modes are normally impossible on channels close to the band borders like
1 or 13 because the spectrum of the signal would be out of band.
Depending on the drivers used on both sides this can lead to errors of interpretation.
10 minutes ago, Ford Prefect said:
High speed WIFI modes are normally impossible on channels close to the band borders like 1 or 13 because the spectrum of the signal would be out of band.
Huh? Care to elaborate on that? What are you referring to with 'out of band'?
Common knowledge (most AP owners unfortunately aren't aware of) is to use only 1, 6 and 11 where 1-11 are allowed or 1, 5, 9 and 13 where 12/13 are also allowed. The band is 2.4-2.5 GHz, channel width is 22MHz and interferences are well known. That's the reason channel 1 is specified at 2412 MHz and will therefore interfere with channel 2 and 3 (so any AP choosing channel 3 for example is set up moronically to interfere with both Wi-Fis on channel 1 and 5/6):
1440px-2.4_GHz_Wi-Fi_channels_(802.11b,g
In my environement with totally overcrowded 2.4Ghz band (counted 139 networks within 48 hours) channel 13 is the only reasonable choice (AP's 'auto channel' settings checks every few hours and constantly remains at this channel due to least polluted).
Some details/explanations:
This depends may depend on HW capabilities and driver settings - either HT40+ and HT40- can be used on all channels, so additional channel will be either lower or higher than primary channel.
Edit:
# ht_capab: HT capabilities (list of flags)
# LDPC coding capability: [LDPC] = supported
# Supported channel width set: [HT40-] = both 20 MHz and 40 MHz with secondary
#	channel below the primary channel; [HT40+] = both 20 MHz and 40 MHz
#	with secondary channel above the primary channel
#	(20 MHz only if neither is set)
#	Note: There are limits on which channels can be used with HT40- and
#	HT40+. Following table shows the channels that may be available for
#	HT40- and HT40+ use per IEEE 802.11n Annex J:
#	freq		HT40-		HT40+
#	2.4 GHz		5-13		1-7 (1-9 in Europe/Japan)
#	5 GHz		40,48,56,64	36,44,52,60
#	(depending on the location, not all of these channels may be available
#	for use)
#	Please note that 40 MHz channels may switch their primary and secondary
#	channels if needed or creation of 40 MHz channel maybe rejected based
#	on overlapping BSSes. These changes are done automatically when hostapd
#	is setting up the 40 MHz channel.
HT40 with 2.4GHz band in 2017? Seriously?
50 minutes ago, zador.blood.stained said:
I'm assuming this is what @Ford Prefect meant by "high speed Wi-Fi modes".
Well, HT40 with 2.4GHz band in 2017 means normally quite the opposite: less performance for Wi-Fi users at least when there's more than 2-3 Wi-Fi networks in the same location. I dropped the idea already years ago but anyway, let's give it a try again:
While I consider HT40 with 2.4GHz highly antisocial (see below) I just forced my AP to behave antisocial and enforced HT40 now. Direct result: my AP is now interfering with 9 channels (4-12) instead of only 3 (11-13, see a few posts above). Now I (my AP) disturbs a lot more other Wi-Fis compared to before when it was configured to behave social (allowing HT40 only when this is the only 2.4GHz Wi-Fi available and doing a fallback to HT20 as soon as other Wi-Fis nearby are detected):
Bildschirmfoto%202017-03-11%20um%2013.20
As expected nothing changed with NanoPi Air and Raspberry Pi (AP6212/BCM43438 Wi-Fi/BT is not HT40 capable for obvious reasons: Wi-Fi would badly interfere with BT functionality) and also as expected enforcing HT40 on the AP led to much lower performance since now the AP chose channel 6 which is way more utilized here than channel 13 used before. So enforcing a so called 'High speed WIFI mode' on the AP leads to low speed Wi-Fi on devices in reality. So far so 'great'.
With OrangePi Lite's RTL8189FTV I was able to make use of HT40. PHY data rate is now reported as 150Mbps instead of 65Mbps before ('Great! Twice as much!') so let's have a look what the difference is in reality (since it's still crappy single antenna 2.4GHz Wi-Fi without MIMO):
With HT40 enabled under ideal conditions (50cm away from AP, rather large antenna) I get ~54 Mbits/sec on average with iperf3 and the following ping roundtrip times: 1.752/10.919/899.372/81.537 ms (min/avg/max/mdev)
Responsibly allowing the AP to only use HT20 (and back at least utilized channel 13) using same setup I get ~43 Mbits/sec on average with iperf3 and the following ping roundtrip times: 1.483/7.695/646.101/58.739 ms (min/avg/max/mdev).
So by behaving antisocial and destroying everyone else's Wi-Fi performance around (interfering with 9 channels now) I get a laughable 'stream performance' increase of approx 25 percent (not 100% as doubling the PHY rate would suggest!) while decreasing latency by the same amount (as expected). So if my application depends on low latency I get worse performance than before by choosing 'wider' bandwidth.
All of the above is the reason responsible admins and AP firmwares don't allow HT40 in 2.4GHz any longer (or allow it only if no other Wi-Fi utilizing the same channels is around). Since 'responsibility' means accepting that Wi-Fi uses a shared medium everyone has to compete for. If people would stop to use wrong settings (HT40 or all the intermediate channels apart from 1/6/11 or 1/5/9/13) then in crowded areas Wi-Fi performance could double for all users. Wi-Fi performance seems to be more related to knowledge of AP owners and Wi-Fi users in general and social behaviour than 'drivers' or other stuff we (Armbian) could make a difference :(
Details:
HT40:
          Mode:Managed  Frequency:2.437 GHz  Access Point: BC:05:43:BE:C1:E7
          Bit Rate:150 Mb/s   Sensitivity:0/0
          Link Quality=83/100  Signal level=100/100  Noise level=0/100
Bildschirmfoto%202017-03-11%20um%2013.59
powermanagement on:  53.73 Mbits/sec
powermanagement off: 53.76 Mbits/sec
[  4]   0.00-60.00  sec   459 MBytes  64.2 Mbits/sec    8             sender
[  4]   0.00-60.00  sec   458 MBytes  64.1 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   337 MBytes  47.1 Mbits/sec   46             sender
[  4]   0.00-60.00  sec   334 MBytes  46.7 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   423 MBytes  59.2 Mbits/sec    7             sender
[  4]   0.00-60.00  sec   422 MBytes  59.0 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   319 MBytes  44.6 Mbits/sec   54             sender
[  4]   0.00-60.00  sec   317 MBytes  44.3 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   406 MBytes  56.7 Mbits/sec    7             sender
[  4]   0.00-60.00  sec   404 MBytes  56.5 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   367 MBytes  51.4 Mbits/sec   44             sender
[  4]   0.00-60.00  sec   365 MBytes  51.0 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   417 MBytes  58.2 Mbits/sec   10             sender
[  4]   0.00-60.00  sec   415 MBytes  58.0 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   354 MBytes  49.5 Mbits/sec   50             sender
[  4]   0.00-60.00  sec   351 MBytes  49.1 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   446 MBytes  62.3 Mbits/sec    3             sender
[  4]   0.00-60.00  sec   445 MBytes  62.3 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   333 MBytes  46.5 Mbits/sec   76             sender
[  4]   0.00-60.00  sec   330 MBytes  46.1 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   431 MBytes  60.3 Mbits/sec    5             sender
[  4]   0.00-60.00  sec   430 MBytes  60.1 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   328 MBytes  45.9 Mbits/sec   71             sender
[  4]   0.00-60.00  sec   325 MBytes  45.5 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   422 MBytes  59.0 Mbits/sec    1             sender
[  4]   0.00-60.00  sec   338 MBytes  47.2 Mbits/sec   42             sender
[  4]   0.00-60.00  sec   336 MBytes  46.9 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   459 MBytes  64.2 Mbits/sec   13             sender
[  4]   0.00-60.00  sec   459 MBytes  64.1 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   326 MBytes  45.5 Mbits/sec   61             sender
[  4]   0.00-60.00  sec   323 MBytes  45.2 Mbits/sec                  receiver
root@orangepilite:~# ping -c 120 192.168.83.146
PING 192.168.83.146 (192.168.83.146) 56(84) bytes of data.
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=2.65 ms
64 bytes from 192.168.83.146: icmp_seq=120 ttl=64 time=2.08 ms
--- 192.168.83.146 ping statistics ---
120 packets transmitted, 120 received, 0% packet loss, time 119156ms
rtt min/avg/max/mdev = 1.752/10.919/899.372/81.537 ms
HT20:
          Mode:Managed  Frequency:2.472 GHz  Access Point: BC:05:43:BE:C1:E7
          Link Quality=78/100  Signal level=100/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
Bildschirmfoto%202017-03-11%20um%2014.06
powermanagement on:  42.29 Mbits/sec
powermanagement off: 43.72 Mbits/sec
[  4]   0.00-60.00  sec   229 MBytes  32.1 Mbits/sec    9             sender
[  4]   0.00-60.00  sec   227 MBytes  31.8 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   306 MBytes  42.8 Mbits/sec   68             sender
[  4]   0.00-60.00  sec   304 MBytes  42.5 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   323 MBytes  45.1 Mbits/sec    5             sender
[  4]   0.00-60.00  sec   322 MBytes  45.0 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   306 MBytes  42.8 Mbits/sec   62             sender
[  4]   0.00-60.00  sec   303 MBytes  42.4 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   326 MBytes  45.6 Mbits/sec   10             sender
[  4]   0.00-60.00  sec   326 MBytes  45.5 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   307 MBytes  42.9 Mbits/sec   55             sender
[  4]   0.00-60.00  sec   324 MBytes  45.4 Mbits/sec    4             sender
[  4]   0.00-60.00  sec   324 MBytes  45.3 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   305 MBytes  42.6 Mbits/sec   59             sender
[  4]   0.00-60.00  sec   302 MBytes  42.3 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   327 MBytes  45.7 Mbits/sec   11             sender
[  4]   0.00-60.00  sec   326 MBytes  45.6 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   306 MBytes  42.7 Mbits/sec  138             sender
[  4]   0.00-60.00  sec   304 MBytes  42.4 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   325 MBytes  45.4 Mbits/sec   10             sender
[  4]   0.00-60.00  sec   304 MBytes  42.5 Mbits/sec   40             sender
[  4]   0.00-60.00  sec   314 MBytes  43.9 Mbits/sec    8             sender
[  4]   0.00-60.00  sec   313 MBytes  43.7 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   304 MBytes  42.5 Mbits/sec   52             sender
[  4]   0.00-60.00  sec   302 MBytes  42.2 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   322 MBytes  45.0 Mbits/sec   10             sender
[  4]   0.00-60.00  sec   320 MBytes  44.7 Mbits/sec                  receiver
[  4]   0.00-60.00  sec   307 MBytes  43.0 Mbits/sec   65             sender
[  4]   0.00-60.00  sec   304 MBytes  42.6 Mbits/sec                  receiver
64 bytes from 192.168.83.146: icmp_seq=1 ttl=64 time=57.1 ms
64 bytes from 192.168.83.146: icmp_seq=120 ttl=64 time=1.67 ms
120 packets transmitted, 120 received, 0% packet loss, time 119209ms
rtt min/avg/max/mdev = 1.483/7.695/646.101/58.739 ms
On a close range and if you are the only one with better equipment on both sides ... why not? Consumer router + client with cheap wireless unlikely, probably impossible in residential areas.
Weeks ago I got Mikrotik's router with powerful (1000mW) 2.4 AP and can provide few real world testing once next week. I can only say that it works at almost full speed/signal in other router dead spots ... with lots of neighbours AP's around.
Hm. Laptop ~1m away from the router
HT20:
# iperf3 -4 -c 192.168.1.190
Connecting to host 192.168.1.190, port 5201
[  4] local 192.168.1.101 port 8575 connected to 192.168.1.190 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  2.46 MBytes  20.6 Mbits/sec
[  4]   1.00-2.00   sec  2.52 MBytes  21.2 Mbits/sec
[  4]   2.00-3.00   sec  2.52 MBytes  21.2 Mbits/sec
[  4]   3.00-4.00   sec  2.40 MBytes  20.1 Mbits/sec
[  4]   4.00-5.00   sec  2.58 MBytes  21.7 Mbits/sec
[  4]   5.00-6.00   sec  2.46 MBytes  20.6 Mbits/sec
[  4]   6.00-7.00   sec  1.66 MBytes  13.9 Mbits/sec
[  4]   7.00-8.00   sec  2.40 MBytes  20.1 Mbits/sec
[  4]   8.00-9.00   sec  2.46 MBytes  20.7 Mbits/sec
[  4]   9.00-10.00  sec  2.52 MBytes  21.1 Mbits/sec
[  4]   0.00-10.00  sec  24.0 MBytes  20.1 Mbits/sec                  sender
[  4]   0.00-10.00  sec  24.0 MBytes  20.1 Mbits/sec                  receiver
iperf Done.
Forced HT40:
[  4] local 192.168.1.101 port 8585 connected to 192.168.1.190 port 5201
[  4]   0.00-1.00   sec  7.57 MBytes  63.4 Mbits/sec
[  4]   1.00-2.00   sec  8.31 MBytes  69.8 Mbits/sec
[  4]   2.00-3.00   sec  8.37 MBytes  70.2 Mbits/sec
[  4]   3.00-4.00   sec  8.06 MBytes  67.5 Mbits/sec
[  4]   4.00-5.00   sec  8.00 MBytes  67.2 Mbits/sec
[  4]   5.00-6.00   sec  8.00 MBytes  67.1 Mbits/sec
[  4]   6.00-7.00   sec  8.31 MBytes  69.7 Mbits/sec
[  4]   7.00-8.00   sec  8.49 MBytes  71.2 Mbits/sec
[  4]   8.00-9.00   sec  7.94 MBytes  66.6 Mbits/sec
[  4]   9.00-10.00  sec  7.38 MBytes  61.9 Mbits/sec
[  4]   0.00-10.00  sec  80.4 MBytes  67.4 Mbits/sec                  sender
[  4]   0.00-10.00  sec  80.4 MBytes  67.4 Mbits/sec                  receiver
iperf Done.
So it should be marked as "YMMV"
Hmm... if it's 20.1 Mbits/sec with HT20 and 67.4 Mbits/sec with HT40 then obviously something else is different too (since otherwise HT40 is not able to double HT20 throughput numbers and especially not able to increase it by 3.35 times as in your example). So it's about channel settings that obviously differed (that's the reason I always also collect 'iwconfig' and 'nmcli dev wifi list' output since this reveals sometimes the real reasons why performance differs).
Instead of 'YMMV' we should still try to collect more information here to be able to start with an Armbian Wi-Fi FAQ collecting some general Wi-Fi resources but also SBC specific (eg. lack of TX power).
I tried to repeat my 'location 4' tests (11m away from AP) with RTL8189FTV (HT40 capable, 1T1R antenna) and the MIMO capable RTL8192CU USB dongle (also HT40 capable but 2T2R antenna). With HT40 enabled my AP switches from 13 (good channel) to 6 (pretty bad channel here) and results with HT40 get really horrible due to 2 other AP close to 'location 4' sitting on channel 6 with high TX power:
HT40 and channel 6:
OPi Lite: Bit Rate:150 Mb/s, Sensitivity:0/0, Link Quality=36/100, Signal level=68/100, Noise level=0/100, 1.20 Mbits/sec on average
TL-WN823N: Bit Rate:300 Mb/s, Sensitivity:0/0, Link Quality=50/100, Signal level=-83 dBm, Noise level=0 dBm, 280 Kbits/sec on average
That's how 'nmcli dev wifi list' looked like:
   ArcorWirelessLANGaby     Infra  6     54 Mbit/s  100     ▂▄▆█  WPA1
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  67      ▂▄▆_  WPA1 WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  60      ▂▄▆_  WPA1 WPA2
   EasyBox-188632           Infra  10    54 Mbit/s  57      ▂▄▆_  WPA1 WPA2
   UnserInternet4.0         Infra  1     54 Mbit/s  54      ▂▄__  WPA2
   UBNT2                    Infra  3     54 Mbit/s  54      ▂▄__
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  54      ▂▄__  WPA1 WPA2
*  Snort-Honeynet           Infra  6     54 Mbit/s  52      ▂▄__  WPA2
   Eichkatzenkind           Infra  5     54 Mbit/s  50      ▂▄__  WPA2
   o2-WLAN85                Infra  6     54 Mbit/s  50      ▂▄__  WPA2
   --                       Infra  6     54 Mbit/s  50      ▂▄__  WPA2
   DIRECT-1LC460 Series     Infra  10    54 Mbit/s  50      ▂▄__  WPA2
HT20 and back at channel 13:
OPi Lite: Bit Rate:65 Mb/s, Sensitivity:0/0, Link Quality=54/100, Signal level=69/100, Noise level=0/100, 11.6 Mbits/sec on average
TL-WN823N: Bit Rate:130 Mb/s, Sensitivity:0/0, Link Quality=98/100, Signal level=-67 dBm, Noise level=0 dBm, 12.4 Mbits/sec on average
Now 'nmcli dev wifi list' looked like:
   o2-WLAN85                Infra  6     54 Mbit/s  100     ▂▄▆█  WPA2
   DISTORTEDPEOPLE          Infra  9     54 Mbit/s  64      ▂▄▆_  WPA1 WPA2
   EasyBox-188632           Infra  10    54 Mbit/s  60      ▂▄▆_  WPA1 WPA2
   FRITZ!Box Fon WLAN 7360  Infra  1     54 Mbit/s  57      ▂▄▆_  WPA1 WPA2
   UBNT2                    Infra  3     54 Mbit/s  57      ▂▄▆_
   DIRECT-1LC460 Series     Infra  10    54 Mbit/s  54      ▂▄__  WPA2
   Freiheit                 Infra  13    54 Mbit/s  54      ▂▄__  WPA1 WPA2
*  Snort-Honeynet           Infra  13    54 Mbit/s  52      ▂▄__  WPA2
   DISTORTEDPEOPLE_EXT      Infra  9     54 Mbit/s  50      ▂▄__  WPA1 WPA2
   WLAN-341381              Infra  11    54 Mbit/s  50      ▂▄__  WPA2
   WLAN-3C3379              Infra  11    54 Mbit/s  50      ▂▄__  WPA2
To sum it up: My own AP was listed with same signal strength in both attempts (52 out of 100) but due to different channels performance either totally sucked (extreme example the small MIMO USB dongle with just 280 Kbits/sec (!) on average) or looked ok-ish (either 11.6 Mbits/sec with 1T1R but huge antenna or 12.4 Mbits/sec with crappy antenna but 2T2R MIMO).
So it's still that users have to learn how heavily environment matters. In my totally overcrowded area enabling so called 'high speed' modes totally ruins performance since way too much other AP sit on the same channels then). MIMO and antenna diversity can greatly improve performance even if antenna is crappy (see picture below) and in case of larger distances the type and position/orientation of the antenna matters even more.
Well, high TX power might improve transfer speeds from AP to device but not the other way around (something I had to realize already but it would've been too much of a waste of time to drop all of the above numbers since 'average TX/RX numbers' don't reflect TX power settings accordingly. So that's on the TODO for another set of example throughput numbers with a device where I can easily adjust TX power).
BTW: Over larger distances the small MIMO capable dongle shows best results when operated horizontally (makes sense) with antenna directed towards AP. But based on dimensions of the dongle it is obvious that any large external antenna will outperform the stick regarding both TX and RX performance. With my setup it looks like this:
NanoPi A64 has RealTek 8189ETV so i have ported it to 3.10.104 to see how it would performs on the A64 arena.
For the same distance, same antenna, no walls between i got the values below:
  • bpi-m64 AP6212 with BT enabled:  ~14 Mbits/sec
  • nanopi a64 with RTL8189es:  ~16 Mbits/sec
Unfortunately i don't have Wifi on my Pin64+ to compare with, but i realized it is very hard to get the same values (average values)  in different time of the day, for instance you get lower values during night.
RTL8189ETV seems to have better signal strength and better performance ( ~ 15% faster ) however i have had a hard time to authenticate with some of my wifi router.
Well, adding to your experiences (environment matters, eg. time of the day, you're never alone when using Wi-Fi) three things should be added:
  • 14 vs. 16 Mbits/sec is a difference of less than 15 percent so close to 'result variation' (especially when having in mind that the maximum with this implementation (2.4GHz/HT20) is around 45 Mbits/sec --> 2 Mbits/sec difference with 45 Mbits/sec max is not even 5 percent, so maybe it would be an idea to test again with 1m distance between board and AP?)
  • It seems you only tested from board to another host but not the other way around? If so I wonder whether different TX power settings make any difference (though no idea how to influence/test this, just based on a comment from Jon Smirl on CNX)
  • I would prefer to always get the output of 'iwconfig' too since some differences in performance/observations may be easy to understand by numbers/settings listed there (eg. with powermanagement active throughput might vary a lot and end result might look lower even if specific implementation would be faster)
The results for nanoPi A64 - RTL8189es, 1 meter away,  just the monitor between board and the wireless router/modem. tested against my ultra dual core pentium:):
*Update: no ehternet tune script this time!
iwconfig:
From the board:
The other direction:
Edited by @lex
spoiler
Results for bpi-m64, same condition:
iwconfig:
From the board:
Other direction:
Edited by @lex
spoiler
Hmm... really? Thanks for the iwconfig output since I was looking for this:
root@nanopiair:~# iwconfig wlan0 power off
root@nanopiair:~# iwconfig wlan0 | grep 'Power Management'
root@nanopiair:~# iwconfig wlan0 power on
          Power Managementmode:All packets received
With power management off:
ubuntu@bpi-m64:~$ sudo iwconfig wlan0 power off
iwconfig:
from board:
other direction:
Edited by @lex
spoiler
Since I ordered in the meantime this cheap dual-band/dual-antenna Wi-Fi dongle (based on Ralink RT5572, 802.11n capable, rt2800 driver in mainline kernel) I just gave it a try again and tested from location 4 only (description and results with the onboard variants see above):
I tested with a board using kernel 4.9 so getting Wi-Fi up and running was just the usual 'nmtui-connect' call and I were in. Please take the 2.4GHz results with a grain of salt since I don't wanted to wait until midnight for tests and Wi-Fi testing in a city in 2.4 GHz band on a saturday afternoon is almost stupid (since neighbours dictate your performance more than anything else). Test setup is as before, there's a GBit Ethernet connected machine running 'iperf3 -s' and I test from the board both directions with 'iperf3 -c 192.168.83.146 -t 120 && iperf3 -R -c 192.168.83.146 -t 120'. So there's always two values, the first one is the 'board to other device' number and the 2nd the opposite.
2.4 GHz: 8.21 Mbits/sec / 8.52 Mbits/sec
wlan1     IEEE 802.11  ESSID:"Snort-Honeynet"             Mode:Managed  Frequency:2.472 GHz  Access Point: BC:05:43:BE:C1:E7              Bit Rate=104 Mb/s   Tx-Power=20 dBm              Retry short limit:7   RTS thr:off   Fragment thr:off           Encryption key:off           Power Management:off           Link Quality=40/70  Signal level=-70 dBm             Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0           Tx excessive retries:880  Invalid misc:1664   Missed beacon:0
5 GHz: 3.95 Mbits/sec / 18.4 Mbits/sec
wlan1     IEEE 802.11  ESSID:"Snort-Honeynet 5GHz"             Mode:Managed  Frequency:5.24 GHz  Access Point: BC:05:43:BE:C1:E3              Bit Rate=26 Mb/s   Tx-Power=20 dBm              Retry short limit:7   RTS thr:off   Fragment thr:off           Encryption key:off           Power Management:off           Link Quality=34/70  Signal level=-76 dBm             Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0           Tx excessive retries:17  Invalid misc:59   Missed beacon:0
As already said results in 2.4GHz band are questionable since saturday afternoon and 5GHz results not that overwhelming when comparing with the little cheaper 2T2R RTL8192CU dongle above (2.4 GHz).
Since I ordered a 2nd Wi-Fi dongle that came with much larger antennas I shut the board down, replaced antennas and repeated the same test with exactly same software/setup. So from here on only antennas matter:
2.4 GHz: 5.65 Mbits/sec / 8.26 Mbits/sec
wlan1     IEEE 802.11  ESSID:"Snort-Honeynet"             Mode:Managed  Frequency:2.472 GHz  Access Point: BC:05:43:BE:C1:E7              Bit Rate=39 Mb/s   Tx-Power=20 dBm              Retry short limit:7   RTS thr:off   Fragment thr:off           Encryption key:off           Power Management:off           Link Quality=40/70  Signal level=-70 dBm             Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0           Tx excessive retries:1240  Invalid misc:2494   Missed beacon:0
5 GHz: 7.61 Mbits/sec / 36.7 Mbits/sec
wlan1 IEEE 802.11 ESSID:"Snort-Honeynet 5GHz" Mode:Managed Frequency:5.24 GHz Access Point: BC:05:43:BE:C1:E3 Bit Rate=60 Mb/s Tx-Power=20 dBm Retry short limit:7 RTS thr:off Fragment thr:off Encryption key:off Power Management:off Link Quality=38/70 Signal level=-72 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:5 Invalid misc:50 Missed beacon:0
In 5 GHz band the huge antennas led to a nice improvement (almost twice the numbers) so it seems that's always worth a test.
Waiting for the IPX RF cable to arrive and see how it will boost the signal, 12dBi Omni wifi antenna, $6.75 (now $7.50) on AliExpress. Will try to reproduce same test and post here.12db.thumb.jpg.2d5c0b174ba9b76d13836e191544b183.jpg
  • Igor unpinned this topic
Continuing discussion over there: The numbers you published here... were they made with HT40? Care to provide iwconfig output?
Output: with another round of iperf3, 3M from AP, just some equipment turned on around. Small antenna
* added info screen
ubuntu@nanopi-a64:~/iperf/iperf/src$ iw wlan0 info
Interface wlan0
    ifindex 9
    wdev 0x1
    addr 34:c3:d2:13:f1:f0
    ssid foxy
    type managed
    wiphy 0
ubuntu@nanopi-a64:~/iperf/iperf/src$ ./iperf3 -c 192.168.254.100
Connecting to host 192.168.254.100, port 5201
[  5] local 192.168.254.101 port 52448 connected to 192.168.254.100 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec  5.82 MBytes  48.9 Mbits/sec    0    136 KBytes
[  5]   1.00-2.00   sec  8.10 MBytes  68.0 Mbits/sec    0    335 KBytes
[  5]   2.00-3.00   sec  10.9 MBytes  91.2 Mbits/sec    0    752 KBytes
[  5]   3.00-4.00   sec  10.5 MBytes  87.9 Mbits/sec    0    919 KBytes
[  5]   4.00-5.00   sec  10.4 MBytes  87.5 Mbits/sec    0   1.11 MBytes
[  5]   5.00-6.00   sec  10.1 MBytes  84.4 Mbits/sec    0   1.14 MBytes
[  5]   6.00-7.00   sec  10.5 MBytes  88.2 Mbits/sec    0   1.17 MBytes
[  5]   7.00-8.00   sec  10.6 MBytes  88.9 Mbits/sec    0   1.17 MBytes
[  5]   8.00-9.00   sec  11.2 MBytes  93.9 Mbits/sec    0   1.17 MBytes
[  5]   9.00-10.00  sec  10.1 MBytes  84.4 Mbits/sec    0   1.17 MBytes
[  5]   0.00-10.00  sec  98.2 MBytes  82.3 Mbits/sec    0             sender
[  5]   0.00-10.00  sec  98.1 MBytes  82.3 Mbits/sec                  receiver
iperf Done.
ubuntu@nanopi-a64:~/iperf/iperf/src$ ./iperf3 -R -c 192.168.254.100
Reverse mode, remote host 192.168.254.100 is sending
[  5] local 192.168.254.101 port 52452 connected to 192.168.254.100 port 5201
[  5]   0.00-1.00   sec  5.80 MBytes  48.7 Mbits/sec
[  5]   1.00-2.00   sec  6.38 MBytes  53.6 Mbits/sec
[  5]   2.00-3.00   sec  6.75 MBytes  56.6 Mbits/sec
[  5]   3.00-4.00   sec  7.04 MBytes  59.0 Mbits/sec
[  5]   4.00-5.00   sec  7.05 MBytes  59.1 Mbits/sec
[  5]   5.00-6.00   sec  6.74 MBytes  56.5 Mbits/sec
[  5]   6.00-7.00   sec  6.68 MBytes  56.0 Mbits/sec
[  5]   7.00-8.00   sec  7.08 MBytes  59.4 Mbits/sec
[  5]   8.00-9.00   sec  7.34 MBytes  61.6 Mbits/sec
[  5]   9.00-10.00  sec  7.26 MBytes  60.9 Mbits/sec
[  5]   0.00-10.00  sec  69.0 MBytes  57.9 Mbits/sec    0             sender
[  5]   0.00-10.00  sec  68.1 MBytes  57.1 Mbits/sec                  receiver
iperf Done.
ubuntu@nanopi-a64:~/iperf/iperf/src$ iwconfig
gre0      no wireless extensions.
lo        no wireless extensions.
wlan1     no wireless extensions.
ifb1      no wireless extensions.
wlan0     no wireless extensions.
ifb0      no wireless extensions.
bond0     no wireless extensions.
tunl0     no wireless extensions.
gretap0   no wireless extensions.
eth0      no wireless extensions.
ubuntu@nanopi-a64:~/iperf/iperf/src$ ifconfig
eth0      Link encap:Ethernet  HWaddr 36:c9:e3:f1:b8:05
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:172
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:172 errors:0 dropped:0 overruns:0 frame:0
          TX packets:172 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:12678 (12.6 KB)  TX bytes:12678 (12.6 KB)
wlan0     Link encap:Ethernet  HWaddr 34:c3:d2:13:f1:f0
          inet addr:192.168.254.101  Bcast:192.168.255.255  Mask:255.255.0.0
          inet6 addr: fe80::9038:9be2:fbab:3b4b/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:219375 errors:0 dropped:1678 overruns:0 frame:0
          TX packets:217636 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:235441182 (235.4 MB)  TX bytes:228918541 (228.9 MB)
wlan1     Link encap:Ethernet  HWaddr 36:c3:d2:13:f1:f0
          RX packets:0 errors:0 dropped:45 overruns:0 frame:0
Edited by @lex
rtl8189es info
