Set3 Posted April 11 Posted April 11 Hi, since a few weeks I get these errors in multiple Orange pi-s unattended-upgrades-dpkg.log:3:E:Sub-process /usr/lib/armbian/armbian-live-patch apt returned an error code (127), E:Failure running script /usr/lib/armbian/armbian-live-patch apt unattended-upgrades.log:7:2024-04-11 11:00:58,211 ERROR Installing the upgrades failed! I have a local repos for debian and armbian, and the Orange pi-s have no internet access. Has been working fine in the past years Did a fresh install having internet access : ok Armbian_24.2.1_Orangepione_bookworm_current_6.6.16.img.xz then changed to offline, using my local repos as example tried to install ntp and docker.io All failed, with above like errors So, Q1 : is it no longer possible to work offline using local repos ? Q2 : Or is there a work around for this ? Set 0 Quote
Igor Posted April 11 Posted April 11 2 hours ago, Set3 said: is there a work around for this ? sudo systemctl disable armbian-live-patch.service 0 Quote
Set3 Posted April 12 Author Posted April 12 Thanks for the quick reply tried it , but got on my running hosts ( debian_12_bookworm_6.6.16-current-sunxi ) --> Failed to disable unit: Unit file armbian-live-patch.service does not exist. I am not aware, that I uninstalled anything like that. my next steps: Let me try with a fresh new image Armbian_24.2.1_Orangepione_bookworm_current_6.6.16.img.xz Update/upgrade online, then go offline and use local repo check every step with I guess " systemctl show armbian-live-patch.service" ? 0 Quote
Igor Posted April 12 Posted April 12 1 hour ago, Set3 said: check every step with I guess In recent images, this patch service should not be preset by default. If service is not there, then you should be fine. Also check / remove this file /etc/apt/apt.conf.d/02-armbian-preupdate if it exists. 0 Quote
Set3 Posted April 12 Author Posted April 12 Well, that was interesting Online update / upgrade : ok install/purge ntp :ok offline, changed in etc/apt/ the sources.list and armbian.list to local repo Suddenly got a signature error, never seen before W: GPG error: http://.../mirror/apt.armbian.com bookworm InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 wget armbian.key apt-key add armbian.key Warning: apt-key is deprecated. normally I use signature references in /etc/sources.list and armbian.list, but as a test it is ok anyway I count install / purge ntp needs further investigation, perhaps my repo was damaged a few weeks ago when there were mirror problems ? I think I renewed the armbian repo Have to do more checking/testing, Ill keep you informed. 0 Quote
Set3 Posted April 12 Author Posted April 12 Yes : removing 02-armbian-preupdate did the trick ! Since I automatically modify/override/repair some files in /etc/apt/apt.conf.d, on an regular basis, the preupdate file got restored, while it is not there in the standard install Thanks. Still wondering about the certicifate, but that is another issue now ;-) 0 Quote
