Hi all,
I've been building armbian images for my nanopim4 boards for some time with great success, however I refreshed the build scripts today and I'm seeing LOADS of errors flashing by and then It crashes - my build machine is an intel nuc I5 with 16gb RAM running Debian bookworm - I hope I've got the log url correct
If you look at the log you will see that a patch is failing to apply.  If you look at the error, you will see that the failure is for:  drivers/usb/typec/tcpm/tcmp.c  and if you look at kernel.org you will see that that file change earlier today as part of changes for 6.6.31 which was released today.  So you can either contribute a fix for the patch, wait until someone else does that, or pin your build to the previous kernel version.
Just tried a fresh clone and ran compile.sh - and it crashed as before - it builds a ras pi image OK but not the nanopim4v2
@Werner I ran this from the build folder
git fetch origin pull/6618/head
and I'm trying to build it again - from what I see on the tty it looks to be compiling and linking
Edited by pkfox
4 hours ago, Werner said:
Let me google that for you!
https://gprivate.com/6b9kg
1 - Follow the Build Armbian instructions
if it doesnt Build your image as espected
rm -rf build
git clone --depth 1 --branch v24.05 https://github.com/armbian/build
try again and again and again and again
gh pr checkout 6618
Edited by Hqnicolas
@Hqnicolas that did the trick thanks for that, presumably this branch predates the breaking change
gh pr checkout 6618
the above command didn't work on my Linux box - thanks again.
 gh pr checkout 6618
fatal: couldn't find remote ref refs/heads/fix-broken-patch
Edited by pkfox
edit
17.05.2024 в 19:21, pkfox сказал:
[ LINUXFAMILY='rockchip64' ]
Try to freeze the kernel version for the target family.
Apply this patch to the build system itself.
fix-6.6.30-version.patch
cd /mnt/music/Armbian/build
ls ../fix-6.6.30-version.patch
git status
git restore file1 file2 ....
git pull
patch -p1 -i ../fix-6.6.30-version.patch
Put the patch in a /mnt/music/Armbian/ folder.
Check the status and if there are modified files, do the following:
git restore "list files"
All this is for the main branch
P.S. Try to make an assembly.
And please post the log.
Edited by going
Add P.S.
@going thank you for your time -  I tried your suggestion and got this
diff: unrecognized option '--git'
diff: Try 'diff --help' for more information.
../fix-6.6.30-version.patch: line 2: index: command not found
../fix-6.6.30-version.patch: line 3: ---: command not found
../fix-6.6.30-version.patch: line 4: +++: command not found
../fix-6.6.30-version.patch: line 5: @@: command not found
../fix-6.6.30-version.patch: line 7: syntax error near unexpected token `)'
../fix-6.6.30-version.patch: line 7: `  current)
Edited by pkfox
2 часа назад, pkfox сказал:
😞 Please read some documentation on BASH commands.
The BASH command:
Command output:
This only tells you that the patch file is in /mnt/music/Armbian/fix-6.6.30-version.patch
If there are modified files in the build system itself, you will not be able to update it.
Therefore, it is necessary to check the status.
git status
And if the files exist then make a command:
Where file1 and file2 ... are the files reported by the command git status
The git pull command will pull the latest updates from the remote repository.
Apply the patch that I posted:
After that, run the build command:
./compile.sh ..........
All commands must be executed in the /mnt/music/Armbian/build directory
I have a very good understanding of bash commands I just read it differently than you intended, everything actually worked without applying the patch so I'm not sure what we've achieved. What doesn't work is downloading a fresh clone - thanks for your help
Edit
Someone must have merged the fix into the current tree as it now works perfectly again - thanks again
Edited by pkfox
New content
