D.Cent Posted April 7, 2017 Posted April 7, 2017 I recently got a ClearFog Pro board and wanted to replace my router with it. In order to add Wi-Fi functionality, I installed an Intel 4965 AGN PCI-E extension card. So far I have tried the following two images in order to get it to work: Mainline 4.9.7 The mainline kernel neither detected my Wi-Fi module nor the additional, built-in LAN ports. However, after updating the kernel with "apt upgrade" to 4.10.x, the "iwlegacy" driver necessary for the Intel Wi-Fi module started to work. However, the LAN ports are still missing. Entering "ip link" gives the following output: Quote 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 532 link/ether 00:50:43:25:fb:84 brd ff:ff:ff:ff:ff:ff 3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 532 link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff 4: eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 532 link/ether 00:50:43:0d:19:18 brd ff:ff:ff:ff:ff:ff Expand Usually, there should be lan1, lan2, lan3... for all built-in ports, but they are completely missing. So no problem I thought and tried the other image... LTS 4.4.45 Using this kernel, the LAN ports were detected automatically: Quote 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 532 link/ether 00:50:43:25:fb:84 brd ff:ff:ff:ff:ff:ff 3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 532 link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff 4: eth2: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN mode DEFAULT group default qlen 532 link/ether 00:50:43:0d:19:18 brd ff:ff:ff:ff:ff:ff 5: lan5@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000 link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff 6: lan4@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000 link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff 7: lan3@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000 link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff 8: lan2@eth1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state LOWERLAYERDOWN mode DEFAULT group default qlen 1000 link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff 9: lan1@eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DEFAULT group default qlen 1000 link/ether 00:50:43:84:25:2f brd ff:ff:ff:ff:ff:ff Expand But unfortunately, in this kernel version, the Intel Wi-Fi module isn't detected correctly. Loading the "iwlegacy" and "iwl4965" drivers causes an error (extracted from dmesg): Quote [ 375.101577] iwl4965: Intel(R) Wireless WiFi 4965 driver for Linux, in-tree: [ 375.101586] iwl4965: Copyright(c) 2003-2011 Intel Corporation [ 375.102186] iwl4965 0000:01:00.0: enabling device (0000 -> 0002) [ 375.102270] iwl4965 0000:01:00.0: Detected Intel(R) Wireless WiFi Link 4965AGN, REV=0xFFFFFFFF [ 375.119640] ------------[ cut here ]------------ [ 375.119666] WARNING: CPU: 1 PID: 2173 at drivers/net/wireless/iwlegacy/common.c:116 _il_grab_nic_access+0x70/0xa4 [iwlegacy]() [ 375.119671] Timeout waiting for ucode processor access (CSR_GP_CNTRL 0xffffffff) [ 375.119674] Modules linked in: iwl4965(+) iwlegacy cpufreq_userspace cpufreq_stats mac80211 cfg80211 firmware_class rfkill marvell_c esa des_generic rtc_armada38x uio_pdrv_genirq uio mv_cesa fuse autofs4 btrfs xor xor_neon zlib_deflate raid6_pq ehci_orion [last unload ed: iwlegacy] [ 375.119729] CPU: 1 PID: 2173 Comm: modprobe Tainted: G W 4.4.51-mvebu #5 [ 375.119733] Hardware name: Marvell Armada 380/385 (Device Tree) [ 375.119746] [<c010da9d>] (unwind_backtrace) from [<c0109a49>] (show_stack+0x11/0x14) [ 375.119756] [<c0109a49>] (show_stack) from [<c0360465>] (dump_stack+0x81/0xa8) [ 375.119766] [<c0360465>] (dump_stack) from [<c011d2e5>] (warn_slowpath_common+0x79/0x90) [ 375.119774] [<c011d2e5>] (warn_slowpath_common) from [<c011d31f>] (warn_slowpath_fmt+0x23/0x2c) [ 375.119794] [<c011d31f>] (warn_slowpath_fmt) from [<bfb727f1>] (_il_grab_nic_access+0x70/0xa4 [iwlegacy]) [ 375.119849] [<bfb727f1>] (_il_grab_nic_access [iwlegacy]) from [<bfb72aa3>] (il_wr_prph+0x22/0x70 [iwlegacy]) [ 375.119879] [<bfb72aa3>] (il_wr_prph [iwlegacy]) from [<bfb73a17>] (il_apm_init+0xd2/0x17c [iwlegacy]) [ 375.119908] [<bfb73a17>] (il_apm_init [iwlegacy]) from [<bfb7412f>] (il_eeprom_init+0x3e/0x170 [iwlegacy]) [ 375.119942] [<bfb7412f>] (il_eeprom_init [iwlegacy]) from [<bfb8b933>] (il4965_pci_probe+0x236/0x9dc [iwl4965]) [ 375.119967] [<bfb8b933>] (il4965_pci_probe [iwl4965]) from [<c0394829>] (pci_device_probe+0x59/0xa4) [ 375.119975] [<c0394829>] (pci_device_probe) from [<c03d2c2f>] (driver_probe_device+0xe3/0x200) [ 375.119982] [<c03d2c2f>] (driver_probe_device) from [<c03d2d8d>] (__driver_attach+0x41/0x54) [ 375.119991] [<c03d2d8d>] (__driver_attach) from [<c03d1933>] (bus_for_each_dev+0x2f/0x60) [ 375.119998] [<c03d1933>] (bus_for_each_dev) from [<c03d24c3>] (bus_add_driver+0x8f/0x178) [ 375.120004] [<c03d24c3>] (bus_add_driver) from [<c03d3555>] (driver_register+0x5d/0x84) [ 375.120024] [<c03d3555>] (driver_register) from [<bfb9e04b>] (il4965_init+0x4a/0xfff [iwl4965]) [ 375.120045] [<bfb9e04b>] (il4965_init [iwl4965]) from [<c01017ed>] (do_one_initcall+0xdd/0x170) [ 375.120054] [<c01017ed>] (do_one_initcall) from [<c01e50f5>] (do_init_module+0x4d/0x328) [ 375.120063] [<c01e50f5>] (do_init_module) from [<c018b553>] (load_module+0x123f/0x1908) [ 375.120071] [<c018b553>] (load_module) from [<c018bd65>] (SyS_finit_module+0x45/0x60) [ 375.120079] [<c018bd65>] (SyS_finit_module) from [<c0106081>] (ret_fast_syscall+0x1/0x18) [ 375.120084] ---[ end trace fb4c9f2cc6815c15 ]--- [ 375.137366] iwl4965 0000:01:00.0: bad EEPROM signature,EEPROM_GP=0x00000007 [ 375.137374] iwl4965 0000:01:00.0: EEPROM not found, EEPROM_GP=0xffffffff [ 375.137399] iwl4965 0000:01:00.0: Unable to init EEPROM [ 375.137460] iwl4965: probe of 0000:01:00.0 failed with error -2 Expand Basically I'd love to run the latest kernel, but it seems like there are problems with the DTS configuration not enabling the LAN ports and the LTS kernel doesn't work for me either because of a crashing Wi-Fi driver :/ Does anyone have an idea on how to get either the LTS kernel or the 4.10.x kernel to work?
zador.blood.stained Posted April 7, 2017 Posted April 7, 2017 There are some ongoing changes in mainline (for example upcoming 4.11 will split Clearfog DT into Pro and Base models). Please provide a log from a mainline image with "armbianmonitor -u" - this may give some info about why DSA support was not initialized properly.
D.Cent Posted April 7, 2017 Author Posted April 7, 2017 Thank you for the information! The log can be found here: http://sprunge.us/VXiE
zador.blood.stained Posted April 7, 2017 Posted April 7, 2017 Hm. [ 3.884648] Distributed Switch Architecture driver version 0.1 [ 3.884683] mvneta f1030000.ethernet eth1: [0]: could not detect attached switch [ 3.884689] mvneta f1030000.ethernet eth1: [0]: couldn't create dsa switch instance (error -22) @Igor Can you test the mvebu-next kernel with all additional patches disabled (except for packaging)? This may kill SFP support, but it is possible that it is already partially broken on this branch and DSA issues IMO are a higher priority problem.
Igor Posted April 7, 2017 Posted April 7, 2017 Working on ... Edit 1: some strange problems ... can't boot the board. Edit 2: http://sprunge.us/IcUG with all patches, as is Edit 3: http://sprunge.us/RKBT (only with packaging patch) I guess unrelated to our patches.
zador.blood.stained Posted April 15, 2017 Posted April 15, 2017 On 4/7/2017 at 6:30 PM, Igor said: Edit 3: http://sprunge.us/RKBT (only with packaging patch) I guess unrelated to our patches. Expand Strange. Let's wait for 4.11 and then check again.
