MrT Posted December 30, 2024 Posted December 30, 2024 So something is wrong. When booting up the i can see all the checks that debian normally does. But then my screen turns black and the disks spin down. I will try to see when this happens an if i can see the error on the screen. 0 Quote
Igor Posted December 30, 2024 Author Posted December 30, 2024 28 minutes ago, MrT said: for Odroid XU4 with OMV 32 bit Debian / OMV packages could be a problem. Can you try the same using some other hw platform? 0 Quote
MrT Posted December 30, 2024 Posted December 30, 2024 I only have a Raspberry pi 4 or 3 to play with. Would that do? 0 Quote
Werner Posted December 30, 2024 Posted December 30, 2024 Feel free to try with rpi4 since we provide 64bit images for it. 0 Quote
AlexVS Posted January 10, 2025 Posted January 10, 2025 Hello Igor. May I ask you to build an image with OMV7 preinstalled for RockPro64? I don't have enough knowledge to do it on my own. I know that OMV6 can be upgraded to OMV7 using omv-release-upgrade. But as I understand it, the Armbian version will remain current. 0 Quote
Werner Posted January 10, 2025 Posted January 10, 2025 There isn't much to it. tl;dr: clone the repo using git and execute ./compile.sh. Rest is interactive. https://docs.armbian.com/Developer-Guide_Build-Preparation/ Yes it is possible to include omv6(!) while building the image but there is actually not much to it doing by hand. This is basically how an Armbian omv-preinstalled image is made: https://github.com/armbian/os/blob/3c2bf37c3544f2d16ac12e1c407e6976367ec4d0/userpatches/extensions/omv.sh#L15-L35 tl;dr: grab omv key, install omv key, apt update, apt install openmediavault You can do that manually after first boot. 0 Quote
AlexVS Posted January 11, 2025 Posted January 11, 2025 Hello. Thanks for the hints, but unfortunately I don't understand everything. In the previous version of armbian, OMV6 was included in the repository and installation was easy even for me. In the new version (Bookworm), OMV7 is missing from the repository. If you can tell me which commands to add OMV7 to the repository, then I'll just have to write apt install omv. 0 Quote
Werner Posted January 11, 2025 Posted January 11, 2025 Just checked and it seems like their Release file on the repo is still marked with ovm6 while the package you get when installing is omv7. Tried to build an image with omv pre-installed, but throw a bunch of errors, so no idea if it works. https://fi.mirror.armbian.de/.testing/Armbian-unofficial_25.02.0-trunk_Rockpro64_bookworm_current_6.12.9-omv.img.xz If not grab a standard rockpro image ( https://dl.armbian.com/rockpro64/Bookworm_current_minimal ) and proceed according omv docs: https://docs.openmediavault.org/en/stable/installation/on_debian.html Keep in mind that omv heavily messes with the system, so if anything breaks after installation (like network access or even boot) we cannot help. This is userspace. 1 Quote
AlexVS Posted February 8, 2025 Posted February 8, 2025 11.01.2025 в 14:36, Werner сказал: If not grab a standard rockpro image ( https://dl.armbian.com/rockpro64/Bookworm_current_minimal ) and proceed according omv docs: https://docs.openmediavault.org/en/stable/installation/on_debian.html Keep in mind that omv heavily messes with the system, so if anything breaks after installation (like network access or even boot) we cannot help. This is userspace. Thanks for your help, the OMV7 installation went smoothly. 1 Quote
Floyd2000 Posted April 6, 2025 Posted April 6, 2025 Hi all, I installed the pre-built OMV Image for my RPi4 the other week (Image from section "Dedicated applications images with Armbian Linux v6.12 Build Date: Mar 6, 2025") and everything is working fine so far. However, today I noticed that the unattended-upgrades would not upgrade libraspberrypi0 and libraspberrypi-run. Upon attempting a manual upgrade I got the message that libc6 should be at least 2.38 while the installed version is 2.36. Before I trigger a dependency avalanche and possibly break things, I was just going to ask whether these 2 upgrades could simply be ignored or if there is a safe way to solve this. Thanks for any feedback. 0 Quote
Igor Posted April 22, 2025 Author Posted April 22, 2025 On 4/6/2025 at 10:43 AM, Floyd2000 said: today I noticed that the unattended-upgrades would not upgrade libraspberrypi0 and libraspberrypi-run. This should be fixed, but there might be an error with firmware package. Fix is uninstalling armbian-bsp*, updating all packages, installing bsp againg. 0 Quote
Floyd2000 Posted April 22, 2025 Posted April 22, 2025 Hello Igor, thanks for your reply and the advice about the armbian-bsp* package. It worked! 👍 I tried it out and finally managed to update all previously withheld packages and get rid of the error messages, but it was still kind of bumpy... I had to take these steps: 1. dpkg -r the armbian-bsp-cli-rpi4b-current because apt remove would not work and produce errors 2. apt --fix-broken install 3. dpkg -i --force-all /var/cache/apt/archives/armbian-bsp-cli-rpi4b-current_25.2.3_arm64.deb as apt install would not work without errors and dpkg would not work without forcing it. The error message was something about armbian-bsp* trying to overwrite a file that had been created by raspi-firmware (or something like that. Unfortunately, I did not copy the exact message) Now, everything seems up to date, including the RPi firmware (which had been quite old in the pre-built image, now it's up to date). BTW: in my previous post I wrote that OMV is running on an RPi4B, in fact that was a typo, it is an RPI3B+ really, so the firmware is not in an EEPROM, but only in a couple files in the /boot/firmware folder. Thanks again. I'm curious if it will stay stable or if future updates will cause trouble again at some point. 🙂 🙃 0 Quote
roastmeat Posted October 25, 2025 Posted October 25, 2025 This is my first time running Armbian on the odroid HC4, For some reason, I can boot without any drives (uSD card), and sometimes with one drive but never with two. Like no display on the monitor or can't ssh into the system. Anyone else getting something like this? I've wiped the 4 onboard memory locations so that it can boot from SD card (which it does without any drives) 0 Quote
usual user Posted October 25, 2025 Posted October 25, 2025 1 hour ago, roastmeat said: I can boot without any drives (uSD card), and sometimes with one drive but never with two. Out of curiosity, does it work if you drop my firmware build in place? dd bs=512 seek=1 conv=notrunc,fsync if=u-boot-meson.bin of=/dev/${entire-device-to-be-used} u-boot-meson.bin.tgz 0 Quote
d1nuc0m Posted November 2, 2025 Posted November 2, 2025 Hi all, I just installed Armbian Linux v6.12 with OpenMediaVault (build date 2025/09/23) on a Odroid HC4. When I try to use apt update I get these errors Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Err:3 file:/var/cache/openmediavault/archives Packages Method gave a blank filename Get:3 file:/var/cache/openmediavault/archives Packages Is this expected and related to Armbian setup or should I ask on OMV forum? 0 Quote
