denprog Posted August 12, 2024 Posted August 12, 2024 Is there any description how to setup the boot logo? I tried what I found: in build/packages/blobs/splash change logo.png and run command line with "BOOT_LOGO=yes", it doesn't work. After I found "What we use now is plymouth". OK. Does it work in compile time? I don't have plymouth after installing armbian in a docker container. How should I use plymouth (if it is the only way) to make a boot logo in compile time? 0 Quote
Igor Posted August 12, 2024 Posted August 12, 2024 4 hours ago, denprog said: Is there any description how to setup the boot logo? This was not designed to be user configurable, but you might find something on forums. If you are a business user, sponsor and we will rework it. I have added this task to those that are in award pool. Once you find out, make notes and submit this to main documentation. You might make someone else happy. And yourself if you win a cool mini PC https://github.com/armbian/documentation/issues/471 It would be best if both is done, rework to be user configurable and some notes in documentation. 0 Quote
denprog Posted August 14, 2024 Author Posted August 14, 2024 12.08.2024 в 21:31, Igor сказал: This was not designed to be user configurable In this case what does this option mean? "BOOT_LOGO=yes". 0 Quote
Igor Posted August 14, 2024 Posted August 14, 2024 This is just enabling disabling armbian logo on boot time and i think it might be deprecated functionality since inteoduction of playmouth. We user to bake logo to the kernel.Wrote on mobile 0 Quote
