sovking Posted August 14, 2024 Posted August 14, 2024 I was updating packages on a host running on board "Orange PI PC", running Armbian bullseye version 22.02.1. There is only one package left: The following packages have been kept back: armbian-bsp-cli-orangepipc and if I try to run: sudo apt install armbian-bsp-cli-orangepipc I get: The following packages have unmet dependencies: armbian-bsp-cli-orangepipc-current : Depends: base-files (>= 24.5.1) but 11.1+deb11u10 is to be installed E: Unable to correct problems, you have held broken packages. If I look at my installation of base-files I see that that's is right. How I can fix this ? 0 Quote
Werner Posted August 14, 2024 Posted August 14, 2024 26 minutes ago, sovking said: you have held broken packages. Check packages on hold and unhold them. Perhaps this helps. 0 Quote
sovking Posted August 14, 2024 Author Posted August 14, 2024 apt-mark showhold does not return any hold packages. 0 Quote
Igor Posted August 14, 2024 Posted August 14, 2024 2 hours ago, sovking said: bullseye This is unmaintained. bsp packages are going to main repo, which is release independent like kernel ... and here is the problem. Fix is to not update this package. For future: - use maintained builds - we can fix this on our side, but don't know when. 0 Quote
sovking Posted August 14, 2024 Author Posted August 14, 2024 Ok. So I should not try to upgrade this package. Then, if I wish, to keep the system updated, I could upgrade from bullseye to Debian 12 (Bookworm), probably following the procedure illustrated here ? The kernel is Linux 6.6.31-current-sunxi, while the specific armbian packages installed are: armbian-bsp-cli-orangepipc/now 22.02.1 armhf [installed,upgradable to: 24.5.1] armbian-config/bullseye,bullseye,now 24.5.5 all [installed] armbian-firmware/bullseye,bullseye,now 24.5.6 all [installed] armbian-zsh/bullseye,bullseye,now 24.5.5 all [installed] hostapd/now 3:2.10-6~armbian22.02.3+1 armhf [installed,local] htop/now 3.1.0-0~armbian20.08.2+1 armhf [installed,local] This procedure could work to keep the system upgraded with armbian distribution ? Thanks! 0 Quote
ovacikar Posted September 14, 2024 Posted September 14, 2024 (edited) I believe I have the same issue on lepotato and bookworm armbian-bsp-cli-lepotato-current : Depends: base-files (>= 24.8.2) but 24.5.1-12.4+deb12u5-bookworm is to be installed Edited September 15, 2024 by ovacikar 0 Quote
Igor Posted September 15, 2024 Posted September 15, 2024 On 8/14/2024 at 10:59 PM, sovking said: probably following Yes. 13 hours ago, ovacikar said: I believe I have the same issue on lepotato and bookworm Little more data is needed, like full logs via armianmonitor. 0 Quote
ovacikar Posted September 15, 2024 Posted September 15, 2024 Ok here it is: https://paste.armbian.com/toqukabuje 0 Quote
