binkerd Posted Saturday at 11:12 PM Posted Saturday at 11:12 PM When I run apt update on my Armbian machine (station-p2) I have started getting the following error message: mark@station-m2:~$ sudo apt update Hit:2 http://deb.debian.org/debian bullseye InRelease Hit:3 http://deb.debian.org/debian bullseye-updates InRelease Hit:4 http://deb.debian.org/debian bullseye-backports InRelease Hit:5 http://security.debian.org bullseye-security InRelease Hit:1 http://armbian.chi.auroradev.org/apt bullseye InRelease Hit:7 http://giteduberger.fr rpimonitor/ InRelease Get:6 https://github.armbian.com/configng stable InRelease [3,264 B] Err:6 https://github.armbian.com/configng stable InRelease The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 Reading package lists... Done W: GPG error: https://github.armbian.com/configng stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 93D6889F9F0E78D5 E: The repository 'https://armbian.github.io/configng stable InRelease' is not signed. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. mark@station-m2:~$ This has been happening for the past few days, and I don't know how to resolve the issue. I can get to the https://github.armbian.com/configng webpage from my network but I keep getting errors when trying to update. Any ideas on how to resolve this? 0 Quote
Werner Posted yesterday at 06:38 AM Posted yesterday at 06:38 AM Try this: https://forum.armbian.com/topic/23465-apt-get-update-fails-with-public-key-errors/?do=findComment&comment=172106 and below 0 Quote
binkerd Posted 23 hours ago Author Posted 23 hours ago That worked! Thank you for the quick response and the simple fix to this issue. Mark Binkerd 0 Quote
binkerd Posted 19 hours ago Author Posted 19 hours ago I think I spoke too soon. The sudo apt update process is working but when I try to do sudo apt upgrade I get an error: mark@station-m2:~$ sudo apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-config 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/114 kB of archives. After this operation, 611 kB disk space will be freed. Do you want to continue? [Y/n] y dpkg-deb: error: archive '/var/cache/apt/archives/armbian-config_25.2.0-trunk.25.1114.223708_all.deb' uses unknown compression for member 'control.tar.zst', giving up dpkg: error processing archive /var/cache/apt/archives/armbian-config_25.2.0-trunk.25.1114.223708_all.deb (--unpack): dpkg-deb --control subprocess returned error exit status 2 Errors were encountered while processing: /var/cache/apt/archives/armbian-config_25.2.0-trunk.25.1114.223708_all.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Seems that whatever update this is it is compressed with the zst format. I don't know if this is a repository error or something that needs fixing on my system. Any help would be appreciated. 0 Quote
