OPi Zero + H5 unable to update/upgrade from Bulleye Sunxi 64 Kernel 6.1.92 to 6.6.nn
Go to solution Solved by Igor,
Posted (edited)
I had to freeze my device on Kernel 6.1.92 & Bullseye to remain operational. Now trying to update/upgrade to Kernel 6.6.nn I run into following probs:
1) Using Armbian-config defreeze and subsequently switch to kernel 6.6.nn works OK 4me, but subsequent apt-get update/upgrade throws me back to kernel 6.1.104. Armbian-config has changed significantly w/ No other Kernel available.
2) Using Armbian-config defreeze, only and going directly to apt-get update/upgrade throws me back to kernel 6.1.104 as well and from Bullseye back to Buster! Its a mess!
Will this eventually be corrected and when?
RGDS
Edited by Hans Kurscheidt
wrong pic
From this I can only see that you are using a code that is not supported on a hardware that is not supported.
For some reason you have two kernels installed, legacy and current, and this is causing randomness at upgrade. Uninstall one variant alongside with DT and headers if installed. And upgrade to Buster, or rather start with a clean Bookworm image.
Posted (edited)
vor 15 Stunden schrieb Igor:
Thank-you for reply. Sorry for the beginners question, but "How to"? I used armbian-configMobaXterm_z4hzjl7wzb.png.283eacd595df11d3c8d9c060644b95f1.png to move from 6.1.92 to 6.6.44 and I was assuming that 6.6.44 would replace 6.1.92; apparently it did not, as you said in your reply. So how can I make 6.6.44 the new 1 and only new kernel. I currently back to my old image w/ kernel 6.1.92 frozen and Debian Bullseye. I have a complex APP with tons of middleware and 3rd party SW; a fresh new installation would be a PITA.
typo, added pic
Posted (edited)
Hi there,
as expected, in my frozen image, they are pointing to 6.1.92. After unfreeze and apt-get update/upgrade I'm now lifted to 6.1.104 & Bullseye
However its not want I want, 6.644. a new issued apt-get update/upgrade has no effect.
looks like a security issue to me, now. https://github.armbian.... is not signed
RGDS
hk
amended
You need to change those symlinks Image and uInitrd to the files ending with 6.6.44
In your case, make a copy of your microSD now and try sudoing this:
rm /boot/Image
ln -s /boot/vmlinuz-6.6.44-current-sunxi64 /boot/Image
rm /boot/uInitrd
ln -s /boot/uInitrd-6.6.44-current-sunxi64 /boot/uInitrd
I don't know why the dtb folder symlink is already good for 6.6.44
Posted (edited)
OK, I can certainly do this, but is this supposed 2b the "normal way" or isn't there an issue w/ signing the package, so that "normal" apt ops would do the trick?
BTW thanks 4 Help
BR
hk
I think you have to go back to earlier in this thread where Igor stated:
I think there is information you are not including about your setup.  The first screenshot indicates you are/were running Buster as the screenshot says "Debian end of life (Buster)".  Then later screenshots indicate you are running Bullseye.  It looks like you have attempted to upgrade from Buster to Bullseye during this process.  Armbian doesn't support userspace upgrades.  An error in doing an upgrade like that would potentially leave your apt signing keys out of sync.
Posted (edited)
I'm sorry, but you misinterpreted the screenshots.
Please refer to my 1st line in my 1st post:
>>>>I had to freeze my device on Kernel 6.1.92 & Bullseye to remain operational. Now trying to update/upgrade to Kernel 6.6.nn <<<<
I was always on Bullseye since years now and Kernel 6.1.92  frozen since early this year. Trying to move from 6.1.92 to 6.6.42 (switching kernel after defreeze in armbian-config) created a mess including throwing me back onto Buster, God knows why and how!
May be, that I am using a code that is not supported on a hardware that is not supported, but normal Linux' way of upgrade should still work and for the time being, I am almost sure, that the upgrade doesn't work, because you guys haven't created the proper public key for apt.security to accept the upgrade.
RGDS
hk
clarification
It does work. Sometimes. Out of lets say 1000 packages that are on your OS, you are telling people, who are maintaining 3 of those (that only deals with hardware aspects), to fix a problem on all 1000. Making an OS better then Debian in user-space sense, deal with tens of thousands of packages, that is another level. We "hack" this by providing you Armbian assembled from Ubuntu packages / repo. Which might be better in this. Becoming yet another maintainer of all free software packages is insane. And there is no warranty to control this process better.
Exactly. Try upgrade, but be ready to start from a new image is the only advise that is realistic. Personally, I don't even try. When its time to move to a new point release, I do a backup of dot files following by fresh install. What I need to run, I do it with help of scripts & armbian-config, running apt. It takes less time then upgrade, which has great chances of failure.
apt.security folder was removed from upstream, from Debian main repo, to tell you that distro is EOL and there are no more security updates of (Debian assembled) packages. Once Debian maintainers decides to stop, there is nothing we / anyone can do about. Some distros claims to maintain this longer, but in reality it only has marketing / sales value.
Update and signing mechanism has been changed, not by us, but by upstream. At different time at different user space. If we fix for one, we have to fix for all. There is another aspect of why this software is not perfect. We are heavily under-staff since ever and there is close to no public funding to mitigate this. Join the project, dig into this upgrade problem, and (try to) fix it. Or at least improve, try many of possible scenarios and write instructions of best practices. Not for me/us, but for someone that might run into this.
RGDS
hk
Can you post what exactly you DID and solved your problem? (In case someone suffers the same thing you suffered)
Or if you haven't solved your problem, at least we know that it is unsolvable and do the sane thing: restart from scratch, from a new armbian image.
Then highlight it as the solution.
Well, I tried my very best to find a solution, just to run into other Armbian peculiarities.
1st, the problem with the missing signature can be solved by telling apt to ignore it.
Zitat
UNSIGNED REPOSITORIES
If an archive has an unsigned Release file or no Release file at all current APT versions will refuse to download data from them by default in update operations and even if forced to download front-ends like apt-get(8) will require explicit confirmation if an installation request includes a package from such an unauthenticated archive.
You can force all APT clients to raise only warnings by setting the configuration option Acquire::AllowInsecureRepositories to true. Individual repositories can also be allowed to be insecure via the sources.list(5) option allow-insecure=yes. Note that insecure repositories are strongly discouraged and all options to force apt to continue supporting them will eventually be removed. Users also have the Trusted option available to disable even the warnings, but be sure to understand the implications as detailed in sources.list(5).
A repository which previously was authenticated but would loose this state in an update operation raises an error in all APT clients irrespective of the option to allow or forbid usage of insecure repositories. The error can be overcome by additionally setting Acquire::AllowDowngradeToInsecureRepositories to true or for Individual repositories with the sources.list(5) option allow-downgrade-to-insecure=yes.
Hence I created my apt.config settings in /etc/apt/apt.config.d as following:
 cat 99mysettings
Acquire::AllowInsecureRepositories "1";
Acquire::AllowWeakRepositories "0";
Acquire::AllowDowngradeToInsecureRepositories "1";
So apt started to work on it, giving the appropriate warnings:
which I ignored, so it started the upgrade:
just to learn, that I'm stuck again w/ Armbian. something w/ "unknown compression"
Posted (edited)
OK, so I'm there!
but rather than doing a fresh install, I used the following method:
using armbian-config under kernel 6.1.92 to unfreeze
using armbian-config to switch to "other kernel" -> 6.6.44
That worked OK and gave me Debian Bullseye w/ kernel 6.6.44
I then edited /etc/apt/sources.list and /etc/apt/sources.list.d/armbian.list, replacing Bullseye w/ Bookworm. I then started apt-get update/upgrade. After a huge upgrade I ended up w/ Debian Bookworm, but had fallen back to kernel 6.1.104.
I then applied the method as described by robertoj to finally get Debian Bookworm w/ kernel 6.6.44
typo
Remove -legacy- kernels from the system.
vor 2 Minuten schrieb Igor:
I think, I asked you this question already. How to do this?? armbian-config doesn't have such cmd. Just deleting the legacy dirs in /boot??
RGDS
  • Solution
No, it doesn't. This needs to be done beyond.
sudo apt purge linux-image-legacy-sunxi64 linux-dtb-legacy-sunxi64
