Onira Posted January 1, 2025 Posted January 1, 2025 Hello I wanted to change kernel from meson to sunxi[code] $ dpkg -l | grep linux-image rc linux-image-current-meson64 24.11.1 arm64 Armbian Linux current kernel image 6.6.63-current-meson64 ii linux-image-current-sunxi:armhf 24.11.1 armhf Armbian Linux current kernel image 6.6.62-current-sunxi[/code] and after reboot It is not booting What can I do is it possible to copy some files from fresh downloaded image or edit any file to make it boot from sunxi kernel? 0 Quote
Werner Posted January 2, 2025 Posted January 2, 2025 First question? Why??? Replace boot: https://docs.armbian.com/User-Guide_Recovery/#replacing-boot Easiest would be if you had another arm64 based system since you could simply chroot into the sdcard and then do regular apt operations to install correct packages again. 0 Quote
Onira Posted January 3, 2025 Author Posted January 3, 2025 (edited) It's not SD but it is eMMC and I hope replacing /boot will be the same I don't remember how to chroot I've done it over 10 years ago when installing gentoo but it is still alive and don't need to chroot Edited January 3, 2025 by Onira 0 Quote
SteeMan Posted January 3, 2025 Posted January 3, 2025 47 minutes ago, Onira said: I hope replacing /boot will be the same Replacing /boot is not the same. You also have to make sure that the contents of the kernel modules are present for the kernel you are loading (i.e. /lib/modules) 0 Quote
SteeMan Posted January 3, 2025 Posted January 3, 2025 On 1/1/2025 at 3:21 PM, Onira said: to make it boot from sunxi kernel? You didn't answer the question from Werner above. What are you trying to do? meson (i.e. Amlogic cpus) and sunxi (i.e. Alwinner cpus) are completely different kernels designed for different CPU families from different CPU manufacturers. You can only use the kernel built for your CPU. 0 Quote
Onira Posted January 3, 2025 Author Posted January 3, 2025 (edited) I just thought that if it's available in repo I can switch between those kernels I have downloaded https://mirror.hostiko.network/armbian/pool/main/l/linux-6.6.63/linux-image-current-meson64_24.11. 1_arm64__6.6.63-Sbff3-D0531-P0ad2-Cf15dH1526-HK01ba-Ve377-B59f0-R448a.deb https://mirror.hostiko.network/armbian/pool/main/l/linux-dtb-current-meson64/linux-dtb-current-mes on64_24.11.1_arm64__6.6.63-Sbff3-D0531-P0ad2-Cf15dH1526-HK01ba-Ve377-B59f0-R448a.deb https://mirror.hostiko.network/armbian/pool/main/a/armbian-firmware/armbian-firmware_24.11.1_all__ 1-SA8dbb-B6c7f-R448a.deb But don't know about root filesystem Edited January 3, 2025 by Onira 0 Quote
SteeMan Posted January 3, 2025 Posted January 3, 2025 FYI. Using armbian-config will limit you to compatible kernels for your current distribution. 0 Quote
Werner Posted January 3, 2025 Posted January 3, 2025 3 minutes ago, Onira said: But don't know about root filesystem Have you read https://docs.armbian.com/User-Guide_Recovery/#replacing-boot ? There is also procedure how to extract the contents of .debs to the sdcard without chroot. 0 Quote
Onira Posted January 3, 2025 Author Posted January 3, 2025 (edited) Yes I am reading it and there are 4 things to download but I can't find the first one Is there 4th thing I should download? With those 3 I've downloaded I don't see uInitrd and initrd Edited January 3, 2025 by Onira 0 Quote
Onira Posted January 4, 2025 Author Posted January 4, 2025 I have flashed another sd card with 24.11.1 Bookworm Minimal / IOTand upgraded kernel to 6.6.63 please an advice which files / folder shoult I copy? 0 Quote
Werner Posted January 4, 2025 Posted January 4, 2025 Easiest is probably to copy the whole /boot directory. Make sure to adjust the UUID in armbianEnv.txt to match the target sdcard. Otherwise boot will probably stuck in initramfs. Use blkid to get the value. 0 Quote
Onira Posted January 4, 2025 Author Posted January 4, 2025 the old card has /lib directory while the new has ~lib pointing to /usr/lib is this a matter? I guess I have to copy correct version of modules to the specific directory 0 Quote
Solution going Posted January 4, 2025 Solution Posted January 4, 2025 1 час назад, Onira сказал: I have flashed another sd card with 24.11.1 Bookworm Minimal / IOTand upgraded kernel to 6.6.63 please an advice which files / folder shoult I copy? Did you download the device from the SD card? Is your broken space located on eMMC? If so, you will need to mount your eMMC. sudo mount /dev/mmcblk*** /mnt sudo mount --bind /proc /mnt/proc sudo mount --bind /sys /mnt/sys sudo mount --bind /dev /mnt/dev sudo mount --bind /dev/pts /mnt/dev/pts sudo chroot /mnt apt update; apt install linux-image-current-meson64 linux-dtb-current-meson64 exit sudo umount /mnt/dev/pts sudo umount /mnt/dev sudo umount /mnt/sys sudo umount /mnt/proc 0 Quote
Onira Posted January 4, 2025 Author Posted January 4, 2025 (edited) I copied whole /boot directory changing UUID and copied modules to /usr/lib now I get GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:800;NAND:81;SD:0;READ:0;CHK:0; TE: 121174 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from SD, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from SD, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from SD, src: 0x0001c200, des: 0x01000000, size: 0x000018c0 Wait bl30...Done Sending bl301.......OK. Run bl301... 1 from SD, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipid: eLoad bl33 from SD, src: 0x00034200, des: 0x01000000, size: 0x00080f90 f be ad de d f0 ad ba ef be ad de not ES chip [0.235956 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2019.07-armbian (Sep 02 2019 - 01:17:47 +0200) odroid-c2 Model: Hardkernel ODROID-C2 Soc: Amlogic Meson GXBB (S905) Revision 1f:b (0:1) DRAM: 2 GiB MMC: mmc@72000: 0, mmc@74000: 1 Loading Environment from EXT4... ** File not found /boot/boot.env ** ** Unable to read "/boot/boot.env" from mmc0:1 ** In: serial Out: serial Err: serial Net: eth0: ethernet@c9410000 Hit any key to stop autoboot: 0 => and it stucks, not doing anything more... If I plug any USB with SDcard it reboots and doesn't boot properly Edited January 4, 2025 by Onira 0 Quote
going Posted January 4, 2025 Posted January 4, 2025 01.01.2025 в 23:21, Onira сказал: wanted to change kernel from meson to sunxi[code] $ dpkg -l | grep linux-image rc linux-image-current-meson64 24.11.1 arm64 Armbian Linux current kernel image 6.6.63-current-meson64 ii linux-image-current-sunxi:armhf 24.11.1 armhf Armbian Linux current kernel image 6.6.62-current-sunxi[/code] and after reboot It is not booting I think we need to remember this and publish it in the documentation in the section HOW TO KILL\DESTROY THE DEVICE CORRECTLY. 0 Quote
Onira Posted January 4, 2025 Author Posted January 4, 2025 Well is there any way to rescue this system? 0 Quote
going Posted January 4, 2025 Posted January 4, 2025 13 минут назад, Onira сказал: Well is there any way to rescue this system? Download the device from the SD card. Mount the eMMC in /mnt. Post what is there: ls -al /mnt/boot ls -al /mnt/usr/lib/modules 0 Quote
Onira Posted January 4, 2025 Author Posted January 4, 2025 (edited) ls -l /mnt/sdcard/boot/armbianEnv.txt -rw-r--r-- 1 1011 1011 161 01-04 18:39 /mnt/sdcard/boot/armbianEnv.txt cat /mnt/sdcard/boot/armbianEnv.txt verbosity=1 console=both overlay_prefix=meson rootdev=UUID=015d852a-9602-49c3-9c98-b032271fcc05 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u mount | grep sdcard /dev/sdd1 on /mnt/sdcard type ext4 (rw,relatime) blkid | grep sdd /dev/sdd1: UUID="015d852a-9602-49c3-9c98-b032271fcc05" BLOCK_SIZE="4096" TYPE="ext4" PARTUUID="c21f0000-01" ambian minimal doesn't seem to have any USB support I don't see any USB device that I connect, SD reader flash drive network card or anything else ls -al /mnt/sdcard/boot/ razem 61308 drwxr-xr-x 3 root root 4096 01-04 18:39 . drwxr-xr-x 20 root root 4096 01-04 12:31 .. -rw-r--r-- 1 1011 1011 161 01-04 18:39 armbianEnv.txt -rw-r--r-- 1 root root 38518 11-17 13:43 boot.bmp -rw-r--r-- 1 1011 1011 8061 11-17 13:40 boot.cmd -rw-rw-r-- 1 root root 8133 11-17 13:43 boot.scr -rw-r--r-- 1 root root 259048 11-25 12:33 config-6.6.63-current-meson64 lrwxrwxrwx 1 root root 26 01-04 17:20 dtb -> dtb-6.6.63-current-meson64 drwxr-xr-x 3 root root 4096 01-04 17:19 dtb-6.6.63-current-meson64 lrwxrwxrwx 1 root root 30 01-04 16:49 Image -> vmlinuz-6.6.63-current-meson64 -rw-r--r-- 1 root root 15287081 01-04 16:52 initrd.img-6.6.63-current-meson64 -rw-r--r-- 1 root root 0 01-04 16:49 .next -rw-r--r-- 1 root root 4429862 11-25 12:33 System.map-6.6.63-current-meson64 lrwxrwxrwx 1 root root 30 01-04 16:52 uInitrd -> uInitrd-6.6.63-current-meson64 -rw-r--r-- 1 root root 15287145 01-04 16:52 uInitrd-6.6.63-current-meson64 -rw-r--r-- 1 root root 27429376 11-25 12:33 vmlinuz-6.6.63-current-meson64 ls -al /mnt/sdcard/usr/lib/modules razem 12 drwxr-xr-x 3 root root 4096 01-04 12:33 . drwxr-xr-x 72 root root 4096 01-04 18:49 .. drwxr-xr-x 3 root root 4096 11-17 13:42 6.6.63-current-meson64 Edited January 4, 2025 by Onira 0 Quote
Onira Posted January 5, 2025 Author Posted January 5, 2025 I found nanopineo+2 from someone at my work and borrowed it but I get $ sudo mount --bind /proc /mnt/proc $ sudo mount --bind /sys /mnt/sys $ sudo mount --bind /dev /mnt/dev $ sudo mount --bind /dev/pts /mnt/dev/pts $ sudo chroot /mnt chroot: failed to run command ‘/bin/bash’: No such file or directory 0 Quote
going Posted January 5, 2025 Posted January 5, 2025 8 часов назад, Onira сказал: I found nanopineo+2 from someone at my work and borrowed it but I get First, you need to mount your memory device in the /mnt folder. ls -l /mnt/bin/bash 0 Quote
Onira Posted January 5, 2025 Author Posted January 5, 2025 I did it first $ sudo mount /dev/sda1 /mnt Before all those --bind mounting $ ls -l /mnt/bin/bash -rwxr-xr-x 1 root root 1346480 Mar 29 2024 /mnt/bin/bash there you go 0 Quote
going Posted January 6, 2025 Posted January 6, 2025 Maybe so: sudo chroot /mnt/ or sudo chroot /mnt/bin/bash or cd /mnt sudo chroot ./bin/bash 0 Quote
Onira Posted January 6, 2025 Author Posted January 6, 2025 $ sudo mount /dev/sda1 /mnt $ sudo mount --bind /proc /mnt/proc $ sudo mount --bind /sys /mnt/sys $ sudo mount --bind /dev /mnt/dev $ sudo mount --bind /dev/pts /mnt/dev/pts $ sudo chroot /mnt/ chroot: failed to run command ‘/bin/bash’: No such file or directory $ sudo chroot /mnt/bin/bash chroot: cannot change root directory to '/mnt/bin/bash': Not a directory $ cd /mnt /mnt$ sudo chroot ./bin/bash chroot: cannot change root directory to './bin/bash': Not a directory 0 Quote
Onira Posted January 10, 2025 Author Posted January 10, 2025 (edited) after many tryings I thought of connecting other (more powerful) supply when the one dedicated for C2 didn't work nor any micro USB helped I connected heavy supply to GPIO pins and this time it didn't hang when SD and eMMC were present at the same time the board booted from SD and this time it was possible to make chroot I don't see any logical explanation for this situation but it worked my old os C2 is alive 😸 Edited January 12, 2025 by Onira 1 Quote
going Posted January 12, 2025 Posted January 12, 2025 10.01.2025 в 22:33, Onira сказал: for C2 didn't work nor any micro USB helped 10.01.2025 в 22:33, Onira сказал: I connected heavy supply to GPIO pins and this time it didn't hang when SD and eMMC were present at the same time micro USB is a fairly delicate connector. He might get loose. The power supply circuit on most of these development boards is implemented in a fairly simple way and any additional load can lead to a decrease in the supply voltage in individual circuits. The variation of the actual resistance value from the nominal value in the resistors can lead to both an increase in voltage and a decrease. This leads to the fact that my NVME is working, but it is very hot (increased supply voltage) or, in your case, a malfunction (low supply voltage). This can be cured if you pick up a soldering iron. But for this you need to be well versed in circuit design and have experience in such work. I have encountered such problems when connecting HDD, SSD, NVME via USB-SATA adapter. But never with an SD card. Will you be able to publish the brand of the equipment so that other users can read about this issue? 0 Quote
Onira Posted January 12, 2025 Author Posted January 12, 2025 (edited) The strange thing is that when I was writing OS to eMMC years ago I had both microSD and eMMC present and they were working properly with this dedicated 5V 2A power supply One is 5V 2A 0.8mm connector (dedicated one) the other I used is an old Stontronics 5V 2A (T5582Dv) used to power RPi, Pine64, NanoPiNeoPlus2 and other things I've used within those years I had it None of them worked for me when I had microSD and eMMC present (it was hanging as I've wrote in the topic) So I connected any other 5V supply to the GPIO, I only have at home a MeanWell RS-100-5 but it is 16A so it's a bullshit that It's needed to power the board; I bet any 5V connected to GPIO would work maybe when connected through GPIO there's a different power circuit so both cards now work? My ODROID C2 is REV0.2 20151218; I don't remember when I bought it but I guess it was in summer 2019 or even earlier Edited January 12, 2025 by Onira 0 Quote
going Posted January 13, 2025 Posted January 13, 2025 12 часов назад, Onira сказал: Stontronics 5V 2A (T5582Dv) 1500 mm - It's a long cable. The Council. Shorten the cable and solder a new connector. The connectors are sold disassembled in specialty stores. The connector on the board itself may also be loose or the soldering location may be oxidized (poor contact). It can also be replaced (solder a new one). Maybe it will serve you for a few more years. 0 Quote
going Posted January 13, 2025 Posted January 13, 2025 12 часов назад, Onira сказал: So I connected any other 5V supply to the GPIO, I only have at home a MeanWell RS-100-5 but it is 16A so it's a bullshit that It's needed to power the board; I bet any 5V connected to GPIO would work maybe when connected through GPIO there's a different power circuit so both cards now work? Perhaps nothing needs to be soldered. Try to purchase a 4 amp power supply with a detachable power cable. For example: Power supply <-> USB-microUSB cable <-> Board. 0 Quote
Werner Posted January 13, 2025 Posted January 13, 2025 15 hours ago, Onira said: I only have at home a MeanWell RS-100-5 but it is 16A so it's a bullshit that It's needed to power the board; While it is overpowered it would be ideal to power any SBC since the output voltage can be adjusted/raised to compensate for losses. I personally have something similar but with 35 amps output current Check my ramble here: 0 Quote
