Erez Alster Posted March 4 Posted March 4 (edited) Hi I'm trying to use Armbian with Orange pi 5 Ultra. So far so good The hdmirx is working great! I'm not able to control my gpio pins with PWM in equivalent to orange pi 5 ultra image. I guess that i need to load additional overlays, Am I correct? Please review the armbian logs here: https://paste.next.armbian.com/nekodihico I also noticed that pin numbers were changed if I compare it to the Orange pi OS. Thanks in advance! Edited March 4 by Erez Alster 0 Quote
Werner Posted March 4 Posted March 4 The image you are using is intended for 5 max instead of 5 ultra? 0 Quote
Erez Alster Posted March 4 Author Posted March 4 yes. I copied the dtb from orange pi 5 ultra official image and copied it. 0 Quote
Werner Posted March 4 Posted March 4 So you are using a device tree for a different device and complain that things don't work as expected? 0 Quote
Erez Alster Posted March 4 Author Posted March 4 I'm not complaining at all.... I'm wondering how I can debug it. I'm able to use the same device tree with the official orange pi os. 0 Quote
Werner Posted March 4 Posted March 4 Well on the bright sight both max and ultra are very similar. Though overlays might differ but that would need investigation. Easiest route is the one you actually already got on by checking the vendor source. Maybe they also provide a handful of matching overlays for this board. Maybe they can be ported. 2 Quote
Amird Posted March 4 Posted March 4 Hello Erez Alster, im on the same page, but the issue is that im trying to get PWM to work using ubuntu that is from the orangepi wbesite, did you get it working? if yes, can you share with me how you got the pwm to work? for me, it blinks and its very choppy! thanks in advance. 0 Quote
Erez Alster Posted March 5 Author Posted March 5 I'm using the gpio cli. nothing else worked for me 0 Quote
Solution Erez Alster Posted March 5 Author Solution Posted March 5 I was able to make things work. i had bad configuration So everything is working correctly. I've another issue. I've the following errors in dmesg Quote [ 2920.617507] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 2920.650043] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 2920.736016] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:24! [ 2921.332591] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p30.00 (2200x1125) [ 2924.616773] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 2924.670940] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 2924.701372] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! [ 2925.298296] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p29.99 (2200x1125) [ 2927.883494] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 2927.955102] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! [ 2928.566048] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p25.05 (2200x1125) [ 2928.727603] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 2929.716865] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 2929.737624] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 2929.795089] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! [ 2930.399397] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p29.99 (2200x1125) [ 2932.150233] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 2932.224940] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! [ 2932.777658] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 2932.876647] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p30.00 (2200x1125) [ 2935.350287] fdee0000.hdmirx-controller: Vertical Sync threshold reached interrupt 0x2 [ 2935.421794] fdee0000.hdmirx-controller: hdmirx_wait_lock_and_get_timing signal lock ok, i:23! [ 2935.817696] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_delayed_work_audio: enable audio [ 2936.032717] fdee0000.hdmirx-controller: hdmirx_format_change: New format: 1920x1080p29.99 (2200x1125) Something I'm able to use the HDMI input and sometimes i'm not. Any idea what can be the issue? 0 Quote
Erez Alster Posted March 5 Author Posted March 5 The hdmirx is covered in different thread. I will continue there 0 Quote
