Skip to content
View in the app
Armbian Community Forums
Orange Pi 5 Ultra: Armbian 26.11 / Linux 6.18.60 test report and maintainer interest
Featured Replies
Hi everyone,
I have physical access to an Orange Pi 5 Ultra with 16 GB RAM and would like to help with testing and maintenance of this board. Here is my first round of hardware testing on the current/mainline image. I am posting the working features, reproducible problems and remaining gaps separately. This is an initial test report, not a release sign-off.
Image and test environment
  • Board: Orange Pi 5 Ultra, RK3588, 16 GB RAM.
  • Image: Armbian community 26.11.0-trunk.120, Ubuntu 26.04 Resolute, GNOME/Wayland, booted from microSD.
  • Kernel: 6.18.60-current-rockchip64. Image build commit: c24ea08f8759a37aaa83a101774582c37c18eda6.
  • Kernel, DTB and BSP packages: 26.11.0-trunk.120. Mesa: 26.0.8-1ubuntu0.3.
  • Storage: 64 GB SDXC card using SDR104 at approximately 148.5 MHz; Samsung SSD 980 500 GB on PCIe 3.0 x4; Toshiba MQ04UBF100 1 TB USB hard disk detected at SuperSpeed 5000M.
  • Ethernet: RTL8125B using r8169, linked to a 1 GbE LAN peer. Cooling fan present. PSU model/specification has not yet been recorded.
  • Tests were run on 5–6 November 2026, UTC+8, using remote shell/Python automation and local hands-on cable/desktop checks.
A baseline package list and boot log were saved before testing. The desktop updater subsequently updated userspace packages, including libc6 from 2.43-2ubuntu2.3 to 2.43-2ubuntu2.4. The recorded kernel/DTB packages and Mesa version remained as listed above. This should therefore not be treated as a completely untouched-image test for every later result. Additional test utilities were unpacked into a separate test directory.
I do not yet have an armbianmonitor -u upload URL from this session. Redacted baseline boot, hardware and package information is included with the test evidence; a formal support report is still incomplete.
Completed checks
  • Boot and desktop: SD boot, GNOME/Wayland desktop, HDMI output, USB keyboard and mouse were usable. This covers this desktop image only, not a separate minimal/CLI image.
  • GPU: accelerated OpenGL renderer reported Mali-G610 MC4 (Panfrost). glmark2 output validation passed. Vulkan enumeration with the Panfrost ICD and a 240-frame Wayland vkcube run completed successfully. Three short glmark2 scenes also completed; this was not the full default performance benchmark.
  • RAM: memtester completed one full pass over 2 GiB with exit status 0 in 836.51 seconds. The highest sampled temperature during that test was 53.6°C. This is not exhaustive coverage of all 16 GB.
  • CPU policy: three cpufreq policies were present, with observed peaks of 1.8 / 2.4 / 2.4 GHz during the memory test. The desktop tuning profile and ext4 commit=15 setting were present. A full CPU/VM soak result is still missing, as noted below.
  • RTC: HYM8563 time reads worked. A future, minute-aligned alarm triggered the RTC hardware interrupt at the requested RTC timestamp; its IRQ counter increased from 0 to 1. This was an awake-system alarm test, not a suspend wake-up or battery-backed power-off retention test.
  • Ethernet: TCP receive to the board was approximately 940 Mb/s and transmit from the board approximately 764 Mb/s. A bidirectional run also completed. IPv4, IPv6 and 1500-byte-MTU ping checks passed. The peer was limited to 1 GbE, so 2.5 GbE throughput was not validated.
Storage checks
fio 3.41 was used for bounded tests. SD and USB file tests used 1 MiB blocks, direct I/O, libaio queue depth 16 and CRC32C write/read verification. The NVMe test used direct, read-only access with a 4 GiB working set for 15 seconds. Rates below are decimal MB/s.
Device / scope
Write
Read
Result
SD, 2 GiB file
24.75 MB/s
65.81 MB/s
CRC32C verification passed
USB hard disk, 1 GiB file, first USB 3 port
59.08 MB/s
138.65 MB/s
NVMe, read-only
Not tested
1403.87 MB/s
Read test passed; health queries completed
The SD and USB 4 KiB random-read tests also completed. No new storage-related kernel errors were found during this test interval. These tests do not cover the entire capacity of the media. NVMe write verification and the second USB 3 port remain untested.
Open finding 1: onboard Wi-Fi interface is missing
At baseline, Ethernet and Bluetooth were present but no WLAN interface or wireless PHY appeared. The installed bcmdhd-sdio-dkms package was built for the running kernel, while the SDIO bus had no enumerated device. The live device tree contained:
mmc@fe2d0000 {
    status = "disabled";
Observed package/driver state:
bcmdhd-sdio-dkms: 101.10.591.52.27-10
bcmdhd-sdio/101.10.591.52.27-10, 6.18.60-current-rockchip64, aarch64: installed
iw dev / iw phy: no wireless interface or PHY listed
/sys/bus/sdio/devices/: empty
The vendor board DTS contains SDIO enablement and a Wi-Fi power sequence. Missing board-level SDIO/power-sequence description is a suspect; no proposed fix or overlay has been runtime-tested in this session.
Open finding 2: HDMI input self-loop did not lock
With no independent HDMI source available, I connected this board's HDMI OUT to its HDMI IN. A fullscreen colour-bar pattern was generated, and the receiver was given the v4l2-ctl HDMI EDID preset. DRM state confirmed a 1920×1080 at 60 Hz RGB 8 bpc transmitter mode, with a 148.5 MHz TMDS clock.
The receiver reported power_present=1, but v4l2-ctl --query-dv-timings failed with “No locks available”. The kernel logged:
hdmirx_phy_register_write wait cr write done failed
hdmirx_controller_init wait timer base lock failed
hdmirx_query_dv_timings: signal is not locked
The HDMI RX HDMI/DMA IRQ counters stayed at zero while the 5V-detect GPIO IRQ counter increased. Unloading/reloading synopsys_hdmirx and reapplying the test EDID reproduced the same result. The original receiver EDID and monitor connection were restored afterward.
This is a reproducible self-loop observation on this setup, not proof that every external HDMI source will fail. Testing with an independent source and checking a clean cold boot remain necessary. Relevant earlier changes include #10172 and the 6.18 patch adjustment #10180.
Incomplete and intentionally omitted checks
  • A 15-minute all-CPU plus 4 GiB VM verification run was started, but no final completion record has been collected. The last collected progress line was around 58 seconds. I am not counting this soak as passed.
  • Later, new SSH connections were closed before authentication while the board still answered LAN pings. The cause has not been established, and I am not attributing it to the load test or kernel without further evidence.
  • Bluetooth firmware loading, discovery and three rfkill recovery cycles were observed; pairing and data transfer were not validated. Further Bluetooth testing was intentionally skipped.
  • Actual audio playback/capture, the second USB 3 port, repeated warm/cold boot recovery, RTC power-off retention, other images/kernel branches and additional header/camera interfaces remain outside this completed test set.
Maintenance interest
I would like to contribute release-image testing and reproducible board reports for the Orange Pi 5 Ultra. In particular, #10673 explicitly noted missing Ultra/Linux 6.18 runtime coverage, and #11157 reported no board hardware testing for the CPU policy changes. The observations above provide some additional runtime evidence, with the limitations stated.
I have saved the scripts, package inventories and logs, and can provide specific redacted excerpts. Guidance on the highest-priority follow-up tests and the board-maintainer application process would be appreciated.
KingFalse
orangepi5-ultra-6.18-first-round-evidence.zip
  • Author
Follow-up to my earlier current 6.18 GNOME report: this round tests vendor 6.1 on Debian Minimal.
Board: Orange Pi 5 Ultra, 16 GB. Image: Armbian_26.11.0-trunk.127_Orangepi5-ultra_trixie_vendor_6.1.172_minimal.img.xz. Kernel: 6.1.172-vendor-rk35xx; build commit: e5a400a. This is a nightly/rolling build, not a release sign-off.
Tests ran on 10-11 November 2026 (UTC+8). Commands and log summaries used automation and AI assistance. A person confirmed display, audio, cable connections, pairing-code matching, and the power cycle.
Check
Result
Boot
SD boot/root expansion, software reboot and an approximately 30-second power-off/cold boot passed.
Networking
Ethernet RX/TX 935/762 Mb/s; 5 GHz Wi-Fi RX/TX 341/377 Mb/s. Ethernet IPv4/IPv6/MTU checks and Wi-Fi IPv4 pings passed.
SD / USB storage
2 GiB / 1 GiB CRC32C file checks passed. Write/read: 23.86/63.56 and 54.21/119.93 MiB/s.
NVMe
Read-only 1570.44 MiB/s; zero write bytes. Existing data preserved.
RAM / CPU
2 GiB memtester pass; 15-minute 8-CPU + 4 GiB VM verification passed. Peak core 76.7 C.
RTC / cooling
Future alarm IRQ 0 to 1 at the requested time; automatic fan PWM 0 to 255 observed.
Display / audio
HDMI console and 1080p60 RGB888 output worked; left/right 48 kHz stereo was confirmed locally.
The original 349-package set remained unchanged during core testing; additional test utilities ran from a separate directory. The Bluetooth supplement then added only rfkill=2.41.5-0+deb13u1 and bluez=5.82-1.1+rpt2, giving 351 packages. No other package was upgraded or removed. The workaround did not change the kernel, bootloader, DTB or firmware file.
On this Minimal image, Bluetooth initially failed before firmware loading. The enabled ap6611s-bluetooth.service could not execute /usr/sbin/rfkill (status 203/EXEC), and BlueZ management userspace was absent. After adding those dependencies, three logical power/scan cycles passed. SSP pairing with a Xiaomi Pad 6 Pro succeeded, with the matching code confirmed locally. Services started automatically after a whole-device software reboot; Paired, Bonded and Trusted remained true. L2CAP echo returned 10/10 replies both before and after reboot. Codec-capability -22 warnings remain; no HCI transport timeout was captured. These are post-workaround results, not an out-of-box Bluetooth pass. Bluetooth audio, OBEX, HID and LE GATT applications were not tested.
HDMI-IN same-board loopback did not lock under load or at idle. The transmitter was 1920x1080p60 RGB888 at 148.5 MHz. Input power was detected, and the 256-byte receiver EDID had valid checksums. QUERY_DV_TIMINGS returned ENOLCK; the kernel logged vertical-sync threshold events. An independent external HDMI source was unavailable, so the root cause remains unassigned.
On the second USB 3 port, the disk did not enumerate and its power LED stayed off. I skipped further checks of this port. Another controller reported device mode; hardware damage is unconfirmed. The Ethernet link was only 1 Gb/s, and the memory test did not cover all 16 GB. RTC battery-backed retention, desktops/3D/video decoding, installation/upgrade paths and other expansion interfaces remain untested.
The attached ZIP contains selected redacted evidence, exact command templates and the result matrix. Feedback on the missing Bluetooth dependencies and the HDMI-IN reproduction would be appreciated.
KingFalse
orangepi5-ultra-vendor127-validation-evidence.zip
  • Author
Follow-up: Ubuntu Resolute Minimal .128 validation (11 November 2026)
I have completed another bounded validation run on my Orange Pi 5 Ultra, complementing the earlier Debian results.
Image: Armbian_26.11.0-trunk.128_Orangepi5-ultra_resolute_vendor_6.1.172_minimal.img.xz
Ubuntu 26.04 Resolute Minimal; kernel 6.1.172-vendor-rk35xx; build commit e5a400a.
Hardware: 16 GB RAM, approximately 59.5 GiB SD card, root filesystem on /dev/mmcblk1p1.
The imported first-boot preset was consumed successfully. Ethernet, Wi-Fi and automatic NTP synchronization worked. Initial IPv6 NTP queries timed out, then IPv4 fallback synchronized the clock around 52 seconds after boot.
Area
Result
Memory
PASS: one locked 2 GiB memtester pass; all 18 checks completed successfully.
CPU / VM
PASS: approximately 15 minutes, eight CPU workers plus one 4 GiB VM worker with verification; peak 76.7 C.
SD storage
PASS: 2 GiB CRC32C file verification; write 23.74 MiB/s, verification read 64.23 MiB/s.
NVMe
PASS: unmounted, raw read-only test at 1,568.35 MiB/s; no host-written sector increase.
Network
Functional PASS: 12/12 checks; Ethernet and Wi-Fi observations detailed below.
RTC
PASS: HYM8563 future-minute alarm fired, incremented its interrupt counter, and was cleared.
HDMI / keyboard
PASS: visible console refresh and USB keyboard Enter response confirmed manually.
HDMI audio
PASS: 48 kHz S16_LE stereo playback; left and right channels confirmed audible manually.
Boot persistence
Core PASS: two warm reboots and one cold boot after approximately 30 seconds without power.
Stock Bluetooth
FAIL: missing rfkill / BlueZ; details below.
Ethernet negotiated 1 Gb/s with my router. Separate TCP tests measured approximately 937 Mb/s board RX and 771 Mb/s board TX. Wi-Fi measured approximately 326 Mb/s RX and 373 Mb/s TX. RX means router to board; TX means board to router. These are receiver-reported decimal Mbit/s, not MiB/s. The peer cannot validate 2.5GbE performance.
Wi-Fi accumulated 232 additional TX drops during testing, with retransmissions. The iw RX packet count was also inconsistent with kernel interface counters. Similar observations already existed in my Debian .127 evidence; this does not establish a new Ubuntu regression.
HDMI controller state was 2560x1440p59.95. Reboot checks confirmed changed boot IDs, the expected SD root, working network, synchronized NTP and an unchanged installed-package set. Test utilities and their libraries came from 61 DEBs in the configured Ubuntu/Armbian repositories, extracted into a separate directory. No test packages were installed into the system.
The stock image lacks rfkill and BlueZ clients. ap6611s-bluetooth.service fails at ExecStartPre with 203/EXEC before firmware loading. I did not patch this image, and Bluetooth pairing remains untested. This Ubuntu image was uploaded at 03:24 UTC on 11 November, before dependency-fix PR #11331 merged at 05:26 UTC:
https://github.com/armbian/build/pull/11331
This confirms the packaging problem in the older image; it does not validate the merged fix on Ubuntu. I am keeping this result with the existing issue rather than opening a duplicate.
Power supply rating: 5 V / 5 A. Two ML307 modules and one 2454 radar remained GPIO powered, with unchanged wiring. Their serial functions and power margin were not tested. No USB storage device was connected this round.
Not covered: USB storage/other ports, HDMI input, GPU rendering, codecs, NPU inference, camera/MIPI, eMMC/SPI or NVMe boot, analog audio, mouse interaction, RTC battery retention, full-capacity RAM/media testing, or extended stability.
Command execution, evidence collection and log review were AI-assisted. I performed the physical actions and confirmed the display, keyboard and audio observations. This is bounded single-board testing, not full release certification.
Selected redacted evidence archive: orangepi5-ultra-ubuntu128-validation-evidence.zip
KingFalse
  • Author
Follow-up to my earlier Orange Pi 5 Ultra reports: I tested the newer Debian 13 vendor Minimal image on 13 November 2026 (Asia/Taipei), focusing on Bluetooth startup and reboot recovery.
Official image: Armbian_26.11.0-trunk.130_Orangepi5-ultra_trixie_vendor_6.1.172_minimal.img.xz; kernel 6.1.172-vendor-rk35xx. Booted from the native TF/microSD slot. I retained my first-boot preset, including Tailscale state restoration. The original image file was not independently hashed this round. No packages were installed, upgraded or repaired during testing, and the beginning/end package inventories matched; this comparison starts after first-boot setup.
  • Bluetooth: rfkill 2.41.5-0+deb13u1 and bluez 5.82-1.1 were preinstalled. Both ap6611s-bluetooth.service and bluetooth.service were active before Bluetooth client queries. The earlier missing-rfkill 203/EXEC failure was not observed. Pairing with Xiaomi Pad 6 Pro initially timed out during confirmation (AuthenticationCanceled); after rediscovery, pairing succeeded. This was not a first-attempt success.
  • Boot recovery: 5/5 warm reboots and 1/1 cold boot passed; the cold test included approximately 30 seconds disconnected from power. Each boot automatically restored the controller, Paired/Bonded state and Tailscale connectivity. Initial checks and another check after 15 seconds found no HCI initialization timeout or failed systemd units. No recovery commands were needed. These limited repetitions cannot rule out occasional failures or establish an upper bound on startup time.
  • Ethernet: negotiated 1 Gb/s full duplex; gateway pings 10/10 and WAN pings 5/5. DNS resolution and the APT endpoint response (HTTP 302) worked. This checks endpoint reachability, not a complete package download or installation.
  • Wi-Fi: the initial dual-interface, same-subnet setup had packet loss. Header capture showed five requests leaving WLAN but their five replies entering Ethernet. With a temporary router-neighbor fixture scoped to this board, WLAN sent and received 5/5 packets with zero loss. Dynamic neighbor learning was restored afterward. This conditional short test does not establish sustained throughput or long-term wireless stability.
Remaining observations: /etc/udev/rules.d/60-media.rules is absent; MPP, RGA and DMA heap device nodes remain root:root 0600, without permission changes for testing. Codec-capability -22 warnings remain in the logs; these were not classified as HCI initialization failures. Other kernel warnings also remain. Related work: PR #11331 and PR #11353.
Desktop environments, hardware video decoding, Bluetooth audio/application data transfer, the full peripheral matrix and RTC retention were not tested in this round. Commands and log summaries used automation and AI assistance; I confirmed device pairing and the physical power cycle. A selected, sanitized evidence summary is attached as orangepi5-ultra-debian130-validation-evidence.zip. This is a scoped regression report, not formal release sign-off.
  • Author
Orange Pi 5 Ultra hardware validation on Armbian edge 7.3.5
Tested on 19 November 2026 by KingFalse. Ubuntu 26.04 Resolute GNOME, AArch64, 7.3.5-edge-rockchip64, booted from a microSD card. The image was built from the Armbian snapshot below. The NVMe drive was used for read-only checks. Build snapshot
Results
  • MicroSD boot and Ethernet · Booted from the onboard slot. The Ethernet link negotiated 1 Gb/s full duplex. TCP throughput to the router was 665 Mb/s, and throughput in the reverse direction was 939 Mb/s.
  • AP6611S Wi-Fi · The stock image contained the board overlay and bcmdhd-sdio-dkms 101.10.591.52.27-11. Enabling the bundled overlay brought up the SDIO radio. Wi-Fi-bound DNS and HTTPS passed at 5 GHz and 2.4 GHz. The 2.4 GHz gateway ping passed while the public ICMP probe received no replies. NetworkManager reconnected to the 5 GHz AP about 20 seconds after a warm reboot. Board overlay PR
  • Bluetooth · The UART controller initialized and ordinary-user discovery succeeded before and after a warm reboot. Numeric-confirmation pairing with a Xiaomi Pad 6 Pro passed. An explicit disconnect and reconnect using the saved bond also passed. With the Wi-Fi overlay enabled, the kernel enumerated an additional btsdio HCI entry. BlueZ exposed one usable adapter, the UART controller.
  • HDMI output · The Dell S2719DM ran its preferred mode at 2560×1440, 59.951 Hz. The operator confirmed left and right audio and automatic picture recovery after unplugging and reconnecting the cable. The DRM connector returned to connected and enabled, with the same EDID.
  • GNOME GPU · Wayland offscreen rendering used Mali-G610 via Panthor/Mesa. The measured GPU clock rose from 200 MHz to 1 GHz under load and returned to 200 MHz at idle.
  • VP9 decode · GStreamer v4l2slvp9dec drove rkvdec at 1080p30. The 8-bit and 10-bit clips each completed 60 hardware requests, and each set of 60 frames matched the software reference. Explicitly fixing downstream caps to 1920×1080 failed before any decode requests when the driver reported 1920×1088 capture buffers. Format-only caps allowed both clips to decode at the correct visible size. GStreamer issue #5445
  • Samsung SSD 980 NVMe · Read-only validation passed with GNU dd, uutils dd 0.12.0, and a page-aligned preadv reader. The first apparent read mismatch reproduced with the image's uutils dd 0.10.0 direct-I/O path, as described below.
Findings to track
Stock edge Wi-Fi and unattended first boot. With the image's default boot settings, the SDIO node was disabled and no WLAN interface was present. An imported Imager preset requested Wi-Fi. On this boot, first-login provisioning produced a Netplan file with an empty interface key and stopped before creating the requested user. Skipping the Wi-Fi provisioning step allowed setup to finish over Ethernet. Enabling the bundled orangepi-5-ultra-ap6611s overlay on the installed image made Wi-Fi work. The unattended first-boot flow with the overlay already enabled remains to be verified on a fresh image. Edge overlay · Board enablement for current 6.18
NVMe read tool comparison. The board ran Ubuntu rust-coreutils 0.10.0-1ubuntu2~26.04.1. In an interleaved comparison of the same allocated extent and expected data on the same boot, its dd returned mismatched bytes on 11 of 24 direct reads. GNU dd 9.7 and upstream uutils dd 0.12.0 each matched all 24 reads. All 40 independent page-aligned direct reads matched. GNU dd also produced identical hashes on three reads of the original 256 MiB interval. The device recorded zero sectors written during the comparisons. An upstream change addresses alignment in the dd direct-read buffer. The linked report describes an I/O error with stricter DMA alignment, and the exact relationship to the silent mismatch on this board remains to be established. Ubuntu package · uutils #12085 · uutils #12143
Experimental deep suspend. The image shipped with AllowSuspend=no. The RTC alarm fired at the requested minute while the board was awake. With a temporary runtime override and deep selected, a suspend request was followed by loss of display and network access. The board remained unresponsive past the scheduled RTC wake time and after a key press. A manual reboot brought the board back. The temporary setting was removed and the RTC alarm cleared. The failed boot's journal was unavailable after reset, so the suspend or resume stage at which the system stopped remains unknown. A separate loss of responsiveness before the suspend experiment also required a reboot.
HDMI input. The receiver driver failed its startup probe with -110 and reported that it requires open-source TF-A. The image's board boot configuration selects Rockchip's packaged BL31. Frame capture remains blocked at receiver initialization. Board HPD fix · Kernel receiver probe
Coverage limits
  • The monitor supports up to 1440p in the reported EDID. A 4K60 output test remains open.
  • The Ethernet test used a 1 GbE partner. A 2.5 GbE direct-link test was skipped.
  • WPA3-SAE association remains unverified. The iPhone hotspot was seen advertising WPA2/WPA3 during discovery and was observed advertising WPA2 during the failed retry.
  • A second clean-install run was deferred because the existing test image occupies the only available microSD card.
  • Author
Tested the bundled USB Host overlay on the Orange Pi 5 Ultra with Armbian 26.11.0-trunk.135, Debian 13 Minimal, and the 6.1.172 vendor kernel.
With the stock OTG configuration, a WD My Passport connected to the upper USB port stayed unlit and did not enumerate. To use that port in Host mode, add dwc3-host to the existing overlays= line in /boot/armbianEnv.txt. If that line is absent, use the following setting.
overlays=dwc3-host
I tested with the bundled overlay alone and the drive connected throughout a 30-second power-off. After power-on, the drive lit up and enumerated on the upper port during boot. Two 64 KiB block reads returned identical data. The WD link negotiated 480 Mb/s (USB 2.0 High-Speed). A 5 Gb/s connection and filesystem mounting were outside this test.
  • Author
Orange Pi 5 Ultra hardware test on official Armbian 26.11.2, Debian 14 Forky
I tested the official Hyprland-crypt image on 25 November 2026. It uses 7.3.5-edge-rockchip64 and was built on 20 November from a99790201. I verified the download checksum and the full readback after writing the image to a 64 GB microSD card. I collected a baseline from the fresh install, then added the diagnostics needed for the media and GPU tests. Official image · Build commit
Results
  • Boot and storage. Initial boot, warm reboot and a cold boot after about 30 seconds without power all passed. The LUKS2 root unlocked automatically and Btrfs expanded to 56.8 GiB. The LUKS re-key service was disabled and had no entries in the boot journal. Two direct 128 MiB reads from the Samsung SSD 980 returned identical hashes, with zero sectors written to the SSD during the check.
  • Ethernet and Wi-Fi. Ethernet negotiated 1 Gb/s full duplex and passed gateway pings and HTTPS. One Ethernet-bound HTTPS probe timed out after the warm reboot. The cold-boot probe returned HTTP 200. The built-in AP6611S Wi-Fi interface was available on the stock image. Wi-Fi-bound HTTPS worked at 5 GHz and 2.4 GHz, and NetworkManager reconnected automatically after the warm and cold boots. Board Wi-Fi change
  • Bluetooth. Discovery worked before and after reboot. The first board-initiated pairing attempt timed out. Pairing succeeded when initiated from a Xiaomi Pad 6 Pro. The bond persisted through both reboots, and I reconnected from the board after the cold boot. The kernel logged codec-capability warnings (-22). Bluetooth audio was outside this test.
  • Display, audio and GPU. Hyprland drove a Dell S2719DM at 2560×1440 and approximately 59.95 Hz. The picture recovered after HDMI was unplugged and reinserted. Both HDMI audio channels were confirmed by listening. A Wayland glmark2 run reported Mali-G610 MC4 through Mesa, and Hyprland had active Panthor file descriptors.
  • Video decoding. GStreamer 1.28.9 decoded the 1080p VP9 Profile 0 (8-bit) and Profile 2 (10-bit) samples through rkvdec. Each clip completed 60 hardware requests and all 60 frames matched the software reference. The 640×384 H.264 and HEVC checks also matched all 60 reference frames each.
  • Chromium. Chromium 156.0.8078.79 used software decoding for both VP9 clips with the stock launcher. In an isolated Wayland test profile with --enable-features=AcceleratedVideoDecoder,PreferV4L2VideoAcceleration, 8-bit VP9 used V4L2VideoDecoder and 10-bit VP9 still used VpxVideoDecoder. Both clips played 60 frames with zero drops.
Open items
  • USB SuperSpeed. The same WD drive and cable enumerated and passed read-only checks on both ports, each at 480 Mb/s. The NTFS volume was marked dirty, so I used a read-only mount. This run leaves 5 Gb/s operation and USB writes unverified.
  • HDMI input. The receiver driver failed its probe with -110 and reported that it requires open-source TF-A. Capture was blocked at driver initialization.
  • VP9 negotiation. Fixing the downstream raw caps to 1920×1080 reproduced the format negotiation failure for both VP9 profiles. Specifying the pixel format alone let both clips complete. GStreamer issue #5445
  • Suspend. The shipped configuration has AllowSuspend=no. I left it disabled for this run.
  • Author
Orange Pi 5 Ultra A/B test of 6.18.64 and 6.18.65 Beta on Ubuntu 26.04 GNOME
I ran both tests on the same Orange Pi 5 Ultra and microSD installation on 25 November 2026. The baseline was the official Armbian 26.11.2 Ubuntu 26.04 GNOME image with 6.18.64-current-rockchip64. I then installed the matching kernel, DTB and headers from Armbian Beta 26.11.0-trunk.144 for 6.18.65-current-rockchip64. Both runs used GNOME Shell 50.1, GStreamer 1.28.2 and Chromium 156.0.8078.73. Official image · Beta package index
  • GStreamer VP9. The RKVDEC device on 6.18.64 did not advertise VP9F. On 6.18.65 Beta it did, and both 1080p30 samples (Profile 0, 8-bit and Profile 2, 10-bit) completed 60 hardware decode requests each. All 60 frames from each sample matched the software reference. VDPU381 VP9 backport #11459
  • Chromium VP9. Both samples used VpxVideoDecoder with the stock launcher on both kernels. With --enable-features=AcceleratedVideoDecoder,PreferV4L2VideoAcceleration in a separate Wayland test profile, 6.18.64 still used software for both. On 6.18.65 Beta, the 8-bit sample switched to V4L2VideoDecoder and the 10-bit sample still used VpxVideoDecoder. Each run played all 60 frames with zero drops.
  • 5 GHz Wi-Fi. The stored profile reconnected automatically after the 6.18.64 warm reboot, the first boot into 6.18.65 and a further 6.18.65 warm reboot. Gateway pings and HTTPS bound to the Wi-Fi interface passed in each case. The existing bcmdhd-sdio DKMS driver rebuilt for the Beta kernel.
  • Other video checks. H.264 hardware decoding matched all 60 software-reference frames on both kernels. This GStreamer installation did not expose v4l2slh265dec, so I could not verify HEVC through that pipeline.
  • GNOME startup. On the 6.18.64 image's first boot, GNOME logged No GPUs found and the display manager stopped. Starting the display manager again brought up the desktop. GNOME subsequently started automatically on both kernels. The Beta test used the already provisioned installation and covered warm boots.
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
